  4. Neuling?
Neuling?
22 Beiträge 4 Kommentatoren 4.9k Aufrufe
  • H Offline
    HKF8770
    weis ich net ganz genau.
    Ich kann dir sagen wir man rundet
    sicherlich kann man da nen Zusatz machen dass man auch 2 Stellen nach dem Komma rundet, aber wie??
    [{"id":"cac18979.353e78","type":"inject","name":"","topic":"","payload":"99,9999","payloadType":"string","repeat":"","crontab":"","once":false,"x":167,"y":1094,"z":"fc6c7385.03939","wires":[["629e1530.9d61ec"]]},{"id":"216d9604.de926a","type":"debug","name":"","active":true,"console":"false","complete":"false","x":798,"y":1099,"z":"fc6c7385.03939","wires":[]},{"id":"629e1530.9d61ec","type":"function","name":"","func":"var Tage_Strom = msg.payload;\nvar Tage_Strom = parseInt(Tage_Strom); // in Zahl umwandeln\n//var Tage_Stromg = Tage_Strom.toFixed(2); \nmsg.payload=Tage_Strom;\nreturn msg;","outputs":1,"noerr":0,"x":451,"y":1097,"z":"fc6c7385.03939","wires":[["216d9604.de926a"]]}]
    Freddy
    • paul53P Offline
      Ersetze mal parseInt(Tage_Strom) durch parseFloat(Tage_Strom) und ändere in msg.payload=Tage_Stromg.
      • fischi87F Offline
        fischi87F Offline
        fischi87
        Sowas steht bei mir nicht?!
        [{"id":"46eaf489.b9150c","type":"inject","name":"Start","topic":"","payload":"","payloadType":"string","repeat":"900","crontab":"","once":false,"x":77.21598815917969,"y":62.86397933959961,"z":"3249cd7d.cdb632","wires":[["e832faba.17cd08"]]},{"id":"e832faba.17cd08","type":"http request","name":"Wetterinfo für Strehla über API-Key","method":"GET","ret":"obj","url":"http://api.openweathermap.org/data/2.5/ … 32":[["d69796bc.296868","62ede8a7.9d1218"]]},{"id":"d69796bc.296868","type":"function","name":"Daten extrahieren","func":"msg1 = {};\nmsg1.payload = msg.payload.main.temp;\nmsg2 = {};\nmsg2.payload = msg.payload.main.pressure;\nmsg3 = {};\nmsg3.payload = msg.payload.main.humidity;\nmsg4 = {};\nmsg4.payload = msg.payload.wind.speed;\nmsg5 = {};\nmsg5.payload = msg.payload.wind.deg;\n\nreturn [msg1,msg2,msg3,msg4,msg5];","outputs":"5","noerr":0,"x":631.2159881591797,"y":145.8639793395996,"z":"3249cd7d.cdb632","wires":[["49311bdd.b6cee4"],["1782aa54.e87d56"],["bd7c22f9.4283e"],["f39debec.0c6218"],["b02f0df9.4fd0f"]]},{"id":"49311bdd.b6cee4","type":"ioBroker out","name":"Außentemperatur","topic":"hm-rega.0.4764","ack":"false","autoCreate":"true","x":921.6127166748047,"y":62.86397933959961,"z":"3249cd7d.cdb632","wires":[]},{"id":"1782aa54.e87d56","type":"ioBroker out","name":"Luftdruck","topic":"hm-rega.0.4765","ack":"false","autoCreate":"false","x":899.0413055419922,"y":113.32455062866211,"z":"3249cd7d.cdb632","wires":[]},{"id":"bd7c22f9.4283e","type":"ioBroker out","name":"Luftfeuchtigkeit","topic":"hm-rega.0.4766","ack":"false","autoCreate":"false","x":917.6127166748047,"y":159.4673728942871,"z":"3249cd7d.cdb632","wires":[]},{"id":"f39debec.0c6218","type":"ioBroker out","name":"Windgeschwindigkeit","topic":"hm-rega.0.4767","ack":"false","autoCreate":"false","x":938.4698944091797,"y":209.75320053100586,"z":"3249cd7d.cdb632","wires":[]},{"id":"b02f0df9.4fd0f","type":"ioBroker out","name":"Windrichtung","topic":"hm-rega.0.4768","ack":"false","autoCreate":"false","x":918.6127166748047,"y":257.7530174255371,"z":"3249cd7d.cdb632","wires":[]},{"id":"62ede8a7.9d1218","type":"debug","name":"Ausgabe","active":true,"console":"false","complete":"payload","x":625.2159881591797,"y":62.86397933959961,"z":"3249cd7d.cdb632","wires":[]}]
        • H Offline
          HKF8770
          Hallo Paul,
          kannst du mir sagen wir mann da rundet?? Bei java ist das ja .toFixed(2). Somit kann ich dann nen Wert runden auf 2 Stellen nach dem Komma. Aber bei Node geht der Befehl nicht. Was du ne Lösung?
          Freddy
          • paul53P Offline
            @fischi87:
            Sowas steht bei mir nicht?! Die einzige Stelle, an der man drehen kann, sehe ich bei > msg1.payload = msg.payload.main.temp Vielleicht hilft ein Ersetzen durch ?: > msg1.payload = msg.payload.main.temp.toFixed(2) `
            • BluefoxB Offline
              BluefoxB Offline
              @paul53:
              @fischi87:
              toFixed erwartet schon number als Typ. Deswegen:
              msg.payload = parseFloat(egalWas || 0).toFixed(2);
              • paul53P Offline
                @Bluefox:
                toFixed erwartet schon number als Typ. `
                Laut http://openweathermap.org/current sollte Typ "number" geliefert werden.
                Mit parseFloat(wert) ist es natürlich sicherer und sieht dann im konkreten Fall so aus:
                msg1.payload = parseFloat(msg.payload.main.temp).toFixed(2)
                • fischi87F Offline
                  fischi87F Offline
                  fischi87
                  hey paul53,
                  viele dank dein code hat funktioniert, nur wenn ich das übertrage auch auf "speed" steht bei mir in der ccm nur "nan" da????
                  Mit freundlichen Grüßen
                  • paul53P Offline
                    msg4.payload = parseFloat(msg.payload.wind.speed).toFixed(2)
                    funktioniert nicht ?
                    "nan" erzeugt Javascript, wenn Typ "number" erwartet wird, aber nicht vorliegt.
                    • fischi87F Offline
                      fischi87F Offline
                      fischi87
                      nein funktioniert leider nicht, selbst wenn ich das jetzt wieder ändere in original zustand komm ich nicht wieder auf die zahl??????
                      was mir auch gerade auffällt, ich bekomme jetzt immer eine 0 nach dem Komma auch wenn eine zahl übermittelt wird???
                      • fischi87F Offline
                        fischi87F Offline
                        fischi87
                        so jetzt hat es doch funktioniert, sorry hab mal neu gestartet, jetzt funktioniert alles, danke euch
                        ps. hab noch viel zu lernen was node-red betrifft, wo findet man die befehle und ihre Bedeutung?
                        • fischi87F Offline
                          fischi87F Offline
                          fischi87
                          hey paul53 ich nochmal, vielleicht kannst du oder jemand anderes nochmal helfen?!
                          wie gesagt versuche mir node-red irgendwie beizubringen.
                          ich habe vor per sind adapter eine sv zu schalten d.h. wenn alles Geräte in mehr im plan sind soll die sv sich ändern aber was schreibt man da für eine Funktion rein oder wie realisiert man dies?
                          das ist der Anfang:
                          [{"id":"f7a2cf94.085d3","type":"ioBroker in","name":"PS 4","topic":"ping.0.RaspberryPi.192_168_178_31","payloadType":"value","x":136,"y":434,"z":"751d0e6f.8ae2f","wires":[object Object]}]
                          • fischi87F Offline
                            fischi87F Offline
                            fischi87
                            @fischi87:
                            das ist der Anfang:
                            danke Mit freundlichen Grüßen
                            • paul53P Offline
                              Von node-red habe ich nicht die geringste Ahnung. Lediglich mit der darin eingebetten Javascript-Funktion (hinter "func":) kann ich etwas anfangen.
                              • fischi87F Offline
                                fischi87F Offline
                                fischi87
                                und kannst du mir da mit meinem Projekt helfen? ich werde ja eine Funktion brauchen und den true and false status der jeweiligen Geräte zu erkennen und dann eine "wenn oder" Auswertung zu bekommen?!
                                • paul53P Offline
                                  Bei der Funktion kann ich Dir sicherlich helfen, wenn Du genau beschreibst, was diese Funktion machen soll und was die Eingangs- und Ausgangsgrößen sind.
                                  • paul53P Offline
                                    So sieht die Javascript-Lösung für die Aufgabenstellng aus:
                                    var request = require('request');
                                    var url = 'http://api.openweathermap.org/data/2.5/weather?q=Strehla,DE&units=metric&APPID=e5de2c3e2339a69b6d181c0cb9d2e5d8';
                                    var wetter = {};
                                    // alle 15 Minuten
                                    schedule("*/15 * * * *", function () {
                                        request(url, function(error, response, body) {
                                        if (!error && response.statusCode == 200) {
                                            wetter = JSON.parse(body);
                                            setState("hm-rega.0.4764",wetter.main.temp.toFixed(2) + " °C");
                                            setState("hm-rega.0.4765",wetter.main.pressure.toFixed(1) + " hPa");
                                            setState("hm-rega.0.4766",wetter.main.humidity;.toFixed(0) + " %");
                                            setState("hm-rega.0.4767",wetter.wind.speed.toFixed(1) + " m/s");
                                            setState("hm-rega.0.4768",wetter.wind.deg.toFixed(0) + " °");
