  4. [gelöst]ioBroker upgrade - ('Invalid version of %s. Required %s', adapter, adapters[adapter]);
    5.5k
7 Beiträge 4 Kommentatoren 2.5k Aufrufe
  • P Offline
    pix
    nachdem ich meinen macmini wieder flot gemacht habe, wollte ich mal aus der Konsole ein paar Updates machen.
    ./iobroker upgrade
    ````brachte allerdings eine Fehlermeldung
    MacMini-Ethernet:iobroker pix$ ./iobroker upgrade
    /Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:89
    if (!semver.satisfies(that.main.objects['system.host.' + that.main.currentHost].common.installedVersion, adapters[adapter])) return _('Invalid version of %s. Required %s', adapter, adapters[adapter]);
    TypeError: Cannot read property 'objects' of undefined
    at checkDependencies (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:89:48)
    at Upgrade.upgradeAdapter (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:173:29)
    at Upgrade.upgradeAdapterHelper (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:51:14)
    at /Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1156:37
    at /Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/tools.js:458:27
    at _getRepositoryFile (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/tools.js:422:23)
    at null._onTimeout (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/tools.js:403:29)
    at Timer.listOnTimeout (timers.js:92:15)
    Pix
    • BluefoxB Offline
      BluefoxB Offline
      Js-controller 0.11.2 ?
      Falls nicht, bitte updaten.
      • H Offline
        Heinzelmaennchen
        Hallo Bluefox,
        wie hier http://forum.iobroker.net/viewtopic.php … 507#p32422 schon beschrieben kommt bei mir ein:
        root@castor:~# cd /opt/iobroker/
        root@castor:/opt/iobroker# iobroker upgrade
        (node) warning: possible EventEmitter memory leak detected. 11 error listeners added. Use emitter.setMaxListeners() to increase limit.
        Trace
            at TLSSocket.addListener (events.js:239:js-contorller ist auf dem aktuelle17)
            at TLSSocket.Readable.on (_stream_readable.js:680:33)
            at Request. <anonymous>(/opt/iobroker/node_modules/npm-registry-client/lib/request.js:153:7)
            at emitOne (events.js:77:13)
            at Request.emit (events.js:169:7)
            at ClientRequest. <anonymous>(/opt/iobroker/node_modules/request/request.js:791:10)
            at emitOne (events.js:82:20)
            at ClientRequest.emit (events.js:169:7)
            at tickOnSocket (_http_client.js:502:7)
            at onSocketNT (_http_client.js:514:5)</anonymous></anonymous>
        js-controller ist 0.11.2
        npm -v
        2.15.8
        node -v
        v4.4.7
        Ich habe keine Ahnung was ich noch machen kann.
        Bernhard
        263 Kanäle in 91 Geräten
        3x Sonos Play:1, 1x Sonos:Amp, 1x Sonos Playbar
        4x Hue E27, 21xHue GU10, 1x Lightify RGB Stripe, 1x Lightify E27 TW
        • P Offline
          pix
          @Bluefox:
          Falls nicht, bitte updaten. `
          Das war das Problem. Controller manuell erneuert (ist http://www.iobroker.net/?page_id=3074&lang=de erklärt)
          Ich dachte, der Controller wird auch mit diesem Befehl ( <size size="85">iobroker upgrade</size> ) erneuert.
          Danke, alles wieder gut. :P
          Pix
          • BluefoxB Offline
            BluefoxB Offline
            @Heinzelmaennchen:
            Hallo Bluefox,
            Trace
            npm -v
            2.15.8
            node -v
            v4.4.7
            Ich habe keine Ahnung was ich noch machen kann. `
            Ist schon seltsam.
            Erst probiere js-controller neu zu installieren.
            Dann versuch mal die Adapter gezielt updaten.
            "iobroker upgrade admin" z.B.
            • H Offline
              Heinzelmaennchen
              Wenn ich das mache, kommt:
              Adapter "admin" js up to date.
              Obwohl in der Adapter Übersicht 1.4.0 steht, aber in github die Versionsnummer 1.4.1 angeboten werden sollte.
              Bernhard
              • paul53P Offline
                @Bluefox:
                "iobroker upgrade admin" `
                @Heinzelmaennchen:
                Obwohl in der Adapter Übersicht 1.4.0 steht, aber in github die Versionsnummer 1.4.1 angeboten werden sollte. `
                mit "iobroker upgrade admin" wird die letzte in https://www.npmjs.com/ veröffentlichte Version (1.4.0) installiert. Die Installation von github geht anders.
