  4. Fehler bei Installation vis-jqui-mfd
    5.5k
3 Beiträge 2 Kommentatoren 1.1k Aufrufe
    tesso
    Beim Versuch den Adapter vis-jqui-mfd zu installieren erscheint folgender Fehler:
    root@pi01:/opt/iobroker# iobroker add vis-jqui-mfd
    npm install iobroker.vis-jqui-mfd --production --prefix "/opt/iobroker" (System call)
    npm http GET https://registry.npmjs.org/iobroker.vis-jqui-mfd
    npm http 404 https://registry.npmjs.org/iobroker.vis-jqui-mfd
    npm ERR! TypeError: Cannot read property 'latest' of undefined
    npm ERR!     at next (/usr/local/lib/node_modules/npm/lib/cache.js:687:35)
    npm ERR!     at /usr/local/lib/node_modules/npm/lib/cache.js:675:5
    npm ERR!     at saved (/usr/local/lib/node_modules/npm/node_modules/npm-registry-client/lib/get.js:142:7)
    npm ERR!     at /usr/local/lib/node_modules/npm/node_modules/graceful-fs/polyfills.js:133:7
    npm ERR!     at Object.oncomplete (fs.js:107:15)
    npm ERR! If you need help, you may report this log at:
    npm ERR!     <http: github.com/isaacs/npm/issues="">npm ERR! or email it to:
    npm ERR!     <npm-@googlegroups.com>npm ERR! System Linux 3.18.11-v7+
    npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.vis-jqui-mfd" "--production" "--prefix" "/opt/iobroker"
    npm ERR! cwd /opt/iobroker
    npm ERR! node -v v0.10.22
    npm ERR! npm -v 1.3.14
    npm ERR! type non_object_property_load
    npm ERR!
    npm ERR! Additional logging details can be found in:
    npm ERR!     /opt/iobroker/npm-debug.log
    npm ERR! not ok code 0
    host.pi01 Cannot install iobroker.vis-jqui-mfd: 1</npm-@googlegroups.com></http:>
      @tesso:
      npm http 404 https://registry.npmjs.org/iobroker.vis-jqui-mfd `
      oder:
      npm ERR! 404 Registry returned 404 for GET on https://registry.npmjs.org/iobroker.vis-jqui-mfd
      npm ERR! 404
      npm ERR! 404 'iobroker.vis-jqui-mfd' is not in the npm registry.
      npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
      npm ERR! 404
      npm ERR! 404 Note that you can also install from a
      npm ERR! 404 tarball, folder, http url, or git url.
      also:
      @tesso:
      OK, danke also einfach ignorieren. `
        tesso
        Also auch in Arbeit. dann werde ich auch das ignorieren.
        Ich dachte nur, weil eine Versionsnummer dabei steht müsste sich das installieren lassen.
