  4. IRobot Roomba Steuerung
    1.5k
19 Beiträge 7 Kommentatoren 4.2k Aufrufe 1 Beobachtet
  • eric2905E Offline
    eric2905E Offline
    eric2905
    ich habe mir gebraucht einen iRobot Roomba 581 sehr günstig geschossen und ihn mir nun in Node-Red eingebaut.
    Dazu habe ich mir noch den WLAN-Aufsatz Thinking Cleaner (http://www.thinkingcleaner.com) besorgt - einfach und klasse Teil.
    Zuerst muss der Flow "Roomba - Initialisierung !!!" aufgerufen werden (einmal), um die notwendigen Datenpunkte zu erzeugen.
    [{"id":"24ac0962.db53f6","type":"inject","name":"Datenpunkte definieren - muss einmal gestartet werden!!!","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":242,"y":103,"z":"1231008e.edceff","wires":[["8c5bceff.73a43"]]},{"id":"d32a5e05.2cd5a","type":"ioBroker out","name":"","topic":"node-red.0.Roomba.command_Clean","ack":"false","autoCreate":"true","x":584,"y":269,"z":"1231008e.edceff","wires":[]},{"id":"8c5bceff.73a43","type":"function","name":"Trigger rücksetzen","func":"msg1 = {};\nbefehl = \"0\";\n\nmsg1.payload = befehl;\n\n\nreturn [msg1];","outputs":"1","noerr":0,"x":220,"y":269,"z":"1231008e.edceff","wires":[["d32a5e05.2cd5a","2181a5ff.de7e5a","f4efb6c1.0b1048","fadec315.05214","be3875de.41c788","4a6d87c0.b59278","7736dc3.f88c924"]]},{"id":"2181a5ff.de7e5a","type":"ioBroker out","name":"","topic":"node-red.0.Roomba.command_MaxSaugen","ack":"false","autoCreate":"true","x":605,"y":330,"z":"1231008e.edceff","wires":[]},{"id":"f4efb6c1.0b1048","type":"ioBroker out","name":"","topic":"node-red.0.Roomba.command_BackToDock","ack":"false","autoCreate":"true","x":607,"y":386,"z":"1231008e.edceff","wires":[]},{"id":"fadec315.05214","type":"ioBroker out","name":"","topic":"node-red.0.Roomba.command_LeaveDock","ack":"false","autoCreate":"true","x":605,"y":441,"z":"1231008e.edceff","wires":[]},{"id":"be3875de.41c788","type":"ioBroker out","name":"","topic":"node-red.0.Roomba.command_Findme","ack":"false","autoCreate":"true","x":596,"y":496,"z":"1231008e.edceff","wires":[]},{"id":"4a6d87c0.b59278","type":"ioBroker out","name":"","topic":"node-red.0.Roomba.command_DriveStop","ack":"false","autoCreate":"true","x":604,"y":549,"z":"1231008e.edceff","wires":[]},{"id":"7736dc3.f88c924","type":"ioBroker out","name":"","topic":"node-red.0.Roomba.command_PowerOff","ack":"false","autoCreate":"true","x":607,"y":605,"z":"1231008e.edceff","wires":[]}]
    Hier werden die Trigger-Datenpunkte gesetzt, die dann in Vis verwendet werden können, um Aktionen zu starten.
    Diese Trigger-Datenpunkte sind
    node-red.0.Roomba.command_Clean => Cleaning starten
    node-red.0.Roomba.command_MaxSaugen => Max-Saugen starten
    node-red.0.Roomba.command_BackToDock => Zurück zur Basis-Station (Dock / Ladestation)
    node-red.0.Roomba.command_LeaveDock => Verlasse die Basis-Station (Dock / Ladestation)
    node-red.0.Roomba.command_Findme => Der Roomba gibt eine Tonfolge aus, um ihn besser zu finden
    node-red.0.Roomba.command_DriveStop => So schnell wie möglich STOP
    node-red.0.Roomba.command_PowerOff => Den Roomba ausschalten
    Die Werte sind standardmäßig auf 0. Wird ein Wert (z.B. in Vis mit einer Taste) auf 1 gesetzt, wird die hinterlegte Funktion aufgerufen und der Wert wieder auf 0 zurückgesetzt.
    Der nächste Flow ist "Roomba Steuerung" - hier sind die genannten Funktionsaufrufe enthalten.
    [{"id":"53556f91.acaa9","type":"subflow","name":"Sub_Roomba_Steuerung","in":[{"x":63,"y":85,"wires":[{"id":"101dd7dd.efe228"}]}],"out":[{"x":1163,"y":134,"wires":[{"id":"6d393f45.92c6c","port":0}]}]},{"id":"41df1cc7.be20e4","type":"function","name":"Bauen","func":"var IP = msg.RoombaIP;\nvar Befehl = msg.kommando;\n\nvar Ausgabe = \"http://\" + IP + \"/command.json?command=\" + Befehl;\nmsg.url = Ausgabe;\n\nreturn msg;","outputs":"1","noerr":0,"x":344,"y":83,"z":"53556f91.acaa9","wires":[["30f42818.cf0bd8","6d393f45.92c6c"]]},{"id":"30f42818.cf0bd8","type":"http request","name":"Roomba command","method":"GET","ret":"txt","url":"","x":560,"y":82,"z":"53556f91.acaa9","wires":[["fcc86132.0337a"]]},{"id":"6d393f45.92c6c","type":"function","name":"Trigger rücksetzen","func":"msg.payload = \"0\";\nreturn msg;","outputs":"1","noerr":0,"x":555,"y":133,"z":"53556f91.acaa9","wires":[object Object]},{"id":"fcc86132.0337a","type":"function","name":"Antwort auswerten","func":"var quelle = msg.payload;\n\nmsg1 = {};\nvar name_startpos = quelle.indexOf('result');\nvar name = quelle.substr(name_startpos + 11, 50);\nvar name_endpos = name.indexOf('\"');\nname = name.substring(0, name_endpos);\nmsg1.payload = name;\n\nreturn [msg1];\n","outputs":"1","noerr":0,"x":777,"y":83,"z":"53556f91.acaa9","wires":[["60bf6063.9f40a"]]},{"id":"60bf6063.9f40a","type":"ioBroker out","name":"","topic":"node-red.0.Roomba.CommandStatus","ack":"false","autoCreate":"true","x":1034,"y":83,"z":"53556f91.acaa9","wires":[]},{"id":"101dd7dd.efe228","type":"function","name":"IP setzen","func":"msg.RoombaIP = \"[IP_ROOMBA_EINTRAGEN]\"\nreturn msg;","outputs":1,"noerr":0,"x":196,"y":83,"z":"53556f91.acaa9","wires":[["41df1cc7.be20e4"]]},{"id":"6d2de672.92d218","type":"ioBroker in","name":"command_Clean","topic":"node-red.0.Roomba.command_Clean","payloadType":"value","x":83,"y":52,"z":"898d14e1.7672e8","wires":[["163fe4db.e9c01b"]]},{"id":"163fe4db.e9c01b","type":"switch","name":"Wenn gesetzt","property":"payload","rules":[{"t":"eq","v":"1"}],"checkall":"true","outputs":1,"x":313,"y":51,"z":"898d14e1.7672e8","wires":[["982c2ff5.67d3d"]]},{"id":"982c2ff5.67d3d","type":"function","name":"Daten setzen","func":"msg.kommando = \"clean\"\nmsg.topic=\"command_Clean\";\nreturn msg;","outputs":1,"noerr":0,"x":480,"y":50,"z":"898d14e1.7672e8","wires":[["f19fbacf.0e6048"]]},{"id":"4ed9ac69.b12654","type":"ioBroker out","name":"","topic":"","ack":"false","autoCreate":"true","x":1085,"y":194,"z":"898d14e1.7672e8","wires":[]},{"id":"15b0d45d.ea4f2c","type":"function","name":"Join","func":"msg.topic = \"node-red.0.Roomba.\" + msg.topic;\nreturn msg;","outputs":1,"noerr":0,"x":954.142822265625,"y":194.00001525878906,"z":"898d14e1.7672e8","wires":[["4ed9ac69.b12654"]]},{"id":"f19fbacf.0e6048","type":"subflow:53556f91.acaa9","name":"","x":778,"y":193,"z":"898d14e1.7672e8","wires":[["15b0d45d.ea4f2c"]]},{"id":"6c20afb.f93df5","type":"ioBroker in","name":"command_SpotSaugen","topic":"node-red.0.Roomba.command_SpotSaugen","payloadType":"value","x":103,"y":116,"z":"898d14e1.7672e8","wires":[["bdd39ea3.422c6"]]},{"id":"bdd39ea3.422c6","type":"switch","name":"Wenn gesetzt","property":"payload","rules":[{"t":"eq","v":"1"}],"checkall":"true","outputs":1,"x":313,"y":116,"z":"898d14e1.7672e8","wires":[["f4ff457.f0b00b8"]]},{"id":"f4ff457.f0b00b8","type":"function","name":"Daten setzen","func":"msg.kommando = \"spot\"\nmsg.topic=\"command_SpotSaugen\";\nreturn msg;","outputs":1,"noerr":0,"x":480,"y":115,"z":"898d14e1.7672e8","wires":[["f19fbacf.0e6048"]]},{"id":"74533a2a.8bacc4","type":"ioBroker in","name":"command_MaxSaugen","topic":"node-red.0.Roomba.command_MaxSaugen","payloadType":"value","x":103,"y":176,"z":"898d14e1.7672e8","wires":[["2e79d958.d18626"]]},{"id":"2e79d958.d18626","type":"switch","name":"Wenn gesetzt","property":"payload","rules":[{"t":"eq","v":"1"}],"checkall":"true","outputs":1,"x":313,"y":176,"z":"898d14e1.7672e8","wires":[["fc216cd6.03de9"]]},{"id":"fc216cd6.03de9","type":"function","name":"Daten setzen","func":"msg.kommando = \"max\"\nmsg.topic=\"command_MaxSaugen\";\nreturn msg;","outputs":1,"noerr":0,"x":480,"y":175,"z":"898d14e1.7672e8","wires":[["f19fbacf.0e6048"]]},{"id":"8bc1a754.743e58","type":"ioBroker in","name":"command_BackToDock","topic":"node-red.0.Roomba.command_BackToDock","payloadType":"value","x":102,"y":234,"z":"898d14e1.7672e8","wires":[["5200de48.adff2"]]},{"id":"5200de48.adff2","type":"switch","name":"Wenn gesetzt","property":"payload","rules":[{"t":"eq","v":"1"}],"checkall":"true","outputs":1,"x":312,"y":234,"z":"898d14e1.7672e8","wires":[["daf582cf.250a8"]]},{"id":"daf582cf.250a8","type":"function","name":"Daten setzen","func":"msg.kommando = \"dock\"\nmsg.topic=\"command_BackToDock\";\nreturn msg;","outputs":1,"noerr":0,"x":479,"y":233,"z":"898d14e1.7672e8","wires":[["f19fbacf.0e6048"]]},{"id":"5a728e93.a58d7","type":"ioBroker in","name":"command_LeaveDock","topic":"node-red.0.Roomba.command_LeaveDock","payloadType":"value","x":103.5,"y":302,"z":"898d14e1.7672e8","wires":[["c0a89ca3.3f576"]]},{"id":"c0a89ca3.3f576","type":"switch","name":"Wenn gesetzt","property":"payload","rules":[{"t":"eq","v":"1"}],"checkall":"true","outputs":1,"x":313.5,"y":302,"z":"898d14e1.7672e8","wires":[["8f619f7c.709e6"]]},{"id":"8f619f7c.709e6","type":"function","name":"Daten setzen","func":"msg.kommando = \"leavehomebase\"\nmsg.topic=\"command_LeaveDock\";\nreturn msg;","outputs":1,"noerr":0,"x":480.5,"y":301,"z":"898d14e1.7672e8","wires":[["f19fbacf.0e6048"]]},{"id":"219c0db1.de63f2","type":"ioBroker in","name":"command_Findme","topic":"node-red.0.Roomba.command_Findme","payloadType":"value","x":99.5,"y":368,"z":"898d14e1.7672e8","wires":[["b16cad9d.4e935"]]},{"id":"b16cad9d.4e935","type":"switch","name":"Wenn gesetzt","property":"payload","rules":[{"t":"eq","v":"1"}],"checkall":"true","outputs":1,"x":309.5,"y":368,"z":"898d14e1.7672e8","wires":[["2c5eb0a.fd3a15"]]},{"id":"2c5eb0a.fd3a15","type":"function","name":"Daten setzen","func":"msg.kommando = \"find_me\"\nmsg.topic=\"command_Findme\";\nreturn msg;","outputs":1,"noerr":0,"x":476.5,"y":367,"z":"898d14e1.7672e8","wires":[["f19fbacf.0e6048"]]},{"id":"42f8276d.bd07d8","type":"ioBroker in","name":"command_DriveStop","topic":"node-red.0.Roomba.command_DriveStop","payloadType":"value","x":102,"y":426,"z":"898d14e1.7672e8","wires":[["c2538f0d.3dac7"]]},{"id":"c2538f0d.3dac7","type":"switch","name":"Wenn gesetzt","property":"payload","rules":[{"t":"eq","v":"1"}],"checkall":"true","outputs":1,"x":312,"y":426,"z":"898d14e1.7672e8","wires":[["ec479d75.13b86"]]},{"id":"ec479d75.13b86","type":"function","name":"Daten setzen","func":"msg.kommando = \"drivestop\"\nmsg.topic=\"command_DriveStop\";\nreturn msg;","outputs":1,"noerr":0,"x":479,"y":425,"z":"898d14e1.7672e8","wires":[["f19fbacf.0e6048"]]},{"id":"e6f764de.190898","type":"ioBroker in","name":"command_PowerOff","topic":"node-red.0.Roomba.command_PowerOff","payloadType":"value","x":107,"y":488,"z":"898d14e1.7672e8","wires":[["9557c46c.6aa838"]]},{"id":"9557c46c.6aa838","type":"switch","name":"Wenn gesetzt","property":"payload","rules":[{"t":"eq","v":"1"}],"checkall":"true","outputs":1,"x":317,"y":488,"z":"898d14e1.7672e8","wires":[["8a3d3738.75c2c8"]]},{"id":"8a3d3738.75c2c8","type":"function","name":"Daten setzen","func":"msg.kommando = \"poweroff\"\nmsg.topic=\"command_PowerOff\";\nreturn msg;","outputs":1,"noerr":0,"x":484,"y":487,"z":"898d14e1.7672e8","wires":[["f19fbacf.0e6048"]]}]
    Dieser Flow hat einen Sub-Flow "Sub_Roomba_Steuerung", in dem UNBEDINGT in der Funktion "setzen" die IP-Adresse des Roomba eingetragen werden muss.
    Der dritte und letzte Flow ist der "Roomba Status". Hiermit wird zeitgesteuert (ich habe derzeit jede Minute eingestellt) der Status des Roomba abgefragt und in die entsprechenden Datenpunkte geschrieben.
    [{"id":"a5a2adf.f5a5d5","type":"inject","name":"Full Status jede 1 Minute","topic":"","payload":"","payloadType":"date","repeat":"60","crontab":"","once":true,"x":180,"y":62,"z":"7859072e.87a6f8","wires":[["504181f6.afbe8","182e191.fe7d1e7"]]},{"id":"504181f6.afbe8","type":"http request","name":"Roomba command","method":"GET","ret":"txt","url":"http://192.168.178.55/full_status.xml","x":408,"y":63,"z":"7859072e.87a6f8","wires":[["b7123aff.48edc8","3050ead5.cfaf16","6c22b045.93dd5","c8c15059.373eb","205772fb.dfa88e","bee92f3c.4116d","f8aef704.075108","a899536.f5766b","666e081d.9991f8"]]},{"id":"b7123aff.48edc8","type":"function","name":"Name auswerten","func":"var quelle = msg.payload;\n\nmsg1 = {};\n\nsuche = \"<name>\";\nsuche_laenge = (suche && suche.length);\n\n//  Suchwort \"suche\" finden \n// var daten_startpos = quelle.indexOf('cleaning_distance');\nvar daten_startpos = quelle.indexOf(suche);\nvar daten = quelle.substr(daten_startpos + suche_laenge, 50);\n\n\n// Finde \"<\" und merke dir die Position. Schneide aus von 0 bis Position\nvar daten_endpos = daten.indexOf('<');\ndaten = daten.substring(0, daten_endpos);\nmsg1.payload = daten; // String\n\nreturn [msg1];","outputs":"1","noerr":0,"x":658,"y":63,"z":"7859072e.87a6f8","wires":[["5f503576.a0afcc"]]},{"id":"5f503576.a0afcc","type":"ioBroker out","name":"","topic":"node-red.0.Roomba.name","ack":"false","autoCreate":"true","x":990,"y":64,"z":"7859072e.87a6f8","wires":[]},{"id":"3050ead5.cfaf16","type":"function","name":"Strecke auswerten","func":"var quelle = msg.payload;\n\nmsg1 = {};\n\nsuche = \"<cleaning_distance>\";\nsuche_laenge = (suche && suche.length);\n\n//  Suchwort \"suche\" finden \n// var daten_startpos = quelle.indexOf('cleaning_distance');\nvar daten_startpos = quelle.indexOf(suche);\nvar daten = quelle.substr(daten_startpos + suche_laenge, 50);\n\n\n// Finde \"<\" und merke dir die Position. Schneide aus von 0 bis Position\nvar daten_endpos = daten.indexOf('<');\ndaten = daten.substring(0, daten_endpos);\nmsg1.payload = daten; // String\n\nreturn [msg1];","outputs":"1","noerr":0,"x":664,"y":133,"z":"7859072e.87a6f8","wires":[["b475f945.4b8a08"]]},{"id":"b475f945.4b8a08","type":"ioBroker out","name":"","topic":"node-red.0.Roomba.strecke","ack":"false","autoCreate":"true","x":996,"y":134,"z":"7859072e.87a6f8","wires":[]},{"id":"6c22b045.93dd5","type":"function","name":"Schmutzbehälter auswerten","func":"var quelle = msg.payload;\n\nmsg1 = {};\n\nsuche = \"<bin_status>\";\nsuche_laenge = (suche && suche.length);\n\n//  Suchwort \"suche\" finden \n// var daten_startpos = quelle.indexOf('cleaning_distance');\nvar daten_startpos = quelle.indexOf(suche);\nvar daten = quelle.substr(daten_startpos + suche_laenge, 50);\n\n\n// Finde \"<\" und merke dir die Position. Schneide aus von 0 bis Position\nvar daten_endpos = daten.indexOf('<');\ndaten = daten.substring(0, daten_endpos);\nmsg1.payload = daten; // String\n\nreturn [msg1];","outputs":"1","noerr":0,"x":693,"y":191,"z":"7859072e.87a6f8","wires":[["11db5550.ee24ab"]]},{"id":"11db5550.ee24ab","type":"ioBroker out","name":"","topic":"node-red.0.Roomba.schmutzbehaelter","ack":"false","autoCreate":"true","x":1029,"y":193,"z":"7859072e.87a6f8","wires":[]},{"id":"c8c15059.373eb","type":"function","name":"Akkuladung auswerten","func":"var quelle = msg.payload;\n\nmsg1 = {};\n\nsuche = \"<battery_charge>\";\nsuche_laenge = (suche && suche.length);\n\n//  Suchwort \"suche\" finden \n// var daten_startpos = quelle.indexOf('cleaning_distance');\nvar daten_startpos = quelle.indexOf(suche);\nvar daten = quelle.substr(daten_startpos + suche_laenge, 50);\n\n\n// Finde \"<\" und merke dir die Position. Schneide aus von 0 bis Position\nvar daten_endpos = daten.indexOf('<');\ndaten = daten.substring(0, daten_endpos);\nmsg1.payload = daten; // String\n\nreturn [msg1];","outputs":"1","noerr":0,"x":666,"y":259,"z":"7859072e.87a6f8","wires":[["8c8c5798.7373a8"]]},{"id":"8c8c5798.7373a8","type":"ioBroker out","name":"","topic":"node-red.0.Roomba.akkuladung","ack":"false","autoCreate":"true","x":1030,"y":260,"z":"7859072e.87a6f8","wires":[]},{"id":"205772fb.dfa88e","type":"function","name":"Akkukapazität (Soll) auswerten","func":"var quelle = msg.payload;\n\nmsg1 = {};\n\nsuche = \"<capacity>\";\nsuche_laenge = (suche && suche.length);\n\n//  Suchwort \"suche\" finden \n// var daten_startpos = quelle.indexOf('cleaning_distance');\nvar daten_startpos = quelle.indexOf(suche);\nvar daten = quelle.substr(daten_startpos + suche_laenge, 50);\n\n\n// Finde \"<\" und merke dir die Position. Schneide aus von 0 bis Position\nvar daten_endpos = daten.indexOf('<');\ndaten = daten.substring(0, daten_endpos);\nmsg1.payload = daten; // String\n\nreturn [msg1];","outputs":"1","noerr":0,"x":688,"y":319,"z":"7859072e.87a6f8","wires":[["5c1179c1.a3ee88"]]},{"id":"5c1179c1.a3ee88","type":"ioBroker out","name":"","topic":"node-red.0.Roomba.akkusoll","ack":"false","autoCreate":"true","x":1036,"y":319,"z":"7859072e.87a6f8","wires":[]},{"id":"bee92f3c.4116d","type":"function","name":"Akkukapazität (Ist) auswerten","func":"var quelle = msg.payload;\n\nmsg1 = {};\n\nsuche = \"<charge>\";\nsuche_laenge = (suche && suche.length);\n\n//  Suchwort \"suche\" finden \n// var daten_startpos = quelle.indexOf('cleaning_distance');\nvar daten_startpos = quelle.indexOf(suche);\nvar daten = quelle.substr(daten_startpos + suche_laenge, 50);\n\n\n// Finde \"<\" und merke dir die Position. Schneide aus von 0 bis Position\nvar daten_endpos = daten.indexOf('<');\ndaten = daten.substring(0, daten_endpos);\nmsg1.payload = daten; // String\n\nreturn [msg1];","outputs":"1","noerr":0,"x":690,"y":378,"z":"7859072e.87a6f8","wires":[["334dc150.ccb23e"]]},{"id":"334dc150.ccb23e","type":"ioBroker out","name":"","topic":"node-red.0.Roomba.akkuist","ack":"false","autoCreate":"true","x":1026,"y":380,"z":"7859072e.87a6f8","wires":[]},{"id":"f8aef704.075108","type":"function","name":"Temperatur auswerten","func":"var quelle = msg.payload;\n\nmsg1 = {};\n\nsuche = \"<temperature>\";\nsuche_laenge = (suche && suche.length);\n\n//  Suchwort \"suche\" finden \n// var daten_startpos = quelle.indexOf('cleaning_distance');\nvar daten_startpos = quelle.indexOf(suche);\nvar daten = quelle.substr(daten_startpos + suche_laenge, 50);\n\n\n// Finde \"<\" und merke dir die Position. Schneide aus von 0 bis Position\nvar daten_endpos = daten.indexOf('<');\ndaten = daten.substring(0, daten_endpos);\nmsg1.payload = daten; // String\n\nreturn [msg1];","outputs":"1","noerr":0,"x":692,"y":436,"z":"7859072e.87a6f8","wires":[["2712b369.d8ed4c"]]},{"id":"2712b369.d8ed4c","type":"ioBroker out","name":"","topic":"node-red.0.Roomba.temperatur","ack":"false","autoCreate":"true","x":1028,"y":438,"z":"7859072e.87a6f8","wires":[]},{"id":"a899536.f5766b","type":"function","name":"Status auswerten","func":"var quelle = msg.payload;\n\nmsg1 = {};\n\nsuche = \"<cleaner_state>\";\nsuche_laenge = (suche && suche.length);\n\n//  Suchwort \"suche\" finden \n// var daten_startpos = quelle.indexOf('cleaning_distance');\nvar daten_startpos = quelle.indexOf(suche);\nvar daten = quelle.substr(daten_startpos + suche_laenge, 50);\n\n\n// Finde \"<\" und merke dir die Position. Schneide aus von 0 bis Position\nvar daten_endpos = daten.indexOf('<');\ndaten = daten.substring(0, daten_endpos);\n\nif (daten == \"st_base\"){\n    daten = \"Auf Basis, nicht ladend\";\n}\n\nif (daten == \"st_base_recon\"){\n    daten = \"Auf Basis, Auffrischungsladung\";\n}\n\nif (daten == \"st_base_full\"){\n    daten = \"Auf Basis, normal aufladend\";\n}\n\nif (daten == \"st_base_trickle\"){\n    daten = \"Auf Basis, Erhaltungsladung\";\n}\n\nif (daten == \"st_base_wait\"){\n    daten = \"Auf Basis, wartend\";\n}\n\nif (daten == \"st_plug\"){\n    daten = \"Eingesteckt, nicht ladend\";\n}\n\nif (daten == \"st_plug_recon\"){\n    daten = \"Eingesteckt, Auffrischungsladung\";\n}\n\nif (daten == \"st_plug_full\"){\n    daten = \"Eingesteckt, normal aufladend\";\n}\n\nif (daten == \"st_plug_trickle\"){\n    daten = \"Eingesteckt, Erhaltungsladung\";\n}\n\nif (daten == \"st_plug_wait\"){\n    daten = \"Eingesteckt, wartend\";\n}\n\nif (daten == \"st_stopped\"){\n    daten = \"Angehalten\";\n}\n\nif (daten == \"st_clean\"){\n    daten = \"Reinigung läuft\";\n}\n\nif (daten == \"st_cleanstop\"){\n    daten = \"Reinigung gestoppt\";\n}\n\nif (daten == \"st_clean_spot\"){\n    daten = \"Spot-Reinigung\";\n}\n\nif (daten == \"st_clean_max\"){\n    daten = \"Max-Reinigung\";\n}\n\nif (daten == \"st_delayed\"){\n    daten = \"Reinigung verzögert, startet gleich\";\n}\n\nif (daten == \"st_dock\"){\n    daten = \"Suche Basis\";\n}\n\nif (daten == \"st_pickup\"){\n    daten = \"Roomba hochgehoben\";\n}\n\nif (daten == \"st_remote\"){\n    daten = \"Ferngesteuertes fahren\";\n}\n\nif (daten == \"st_wait\"){\n    daten = \"Warte auf Befehle\";\n}\n\nif (daten == \"st_off\"){\n    daten = \"Aus\";\n}\n\nif (daten == \"st_error\"){\n    daten = \"Fehler\";\n}\n\nif (daten == \"st_locate\"){\n    daten = \"Finde mich\";\n}\n\nif (daten == \"st_unknown\"){\n    daten = \"Status unbekannt\";\n}\n\n\nmsg1.payload = daten; // String\n\nreturn [msg1];","outputs":"1","noerr":0,"x":692,"y":497,"z":"7859072e.87a6f8","wires":[["f6e00de3.091ff"]]},{"id":"f6e00de3.091ff","type":"ioBroker out","name":"","topic":"node-red.0.Roomba.status","ack":"false","autoCreate":"true","x":1028,"y":499,"z":"7859072e.87a6f8","wires":[]},{"id":"666e081d.9991f8","type":"function","name":"Saugt gerade auswerten","func":"var quelle = msg.payload;\n\nmsg1 = {};\n\nsuche = \"<cleaning>\";\nsuche_laenge = (suche && suche.length);\n\n//  Suchwort \"suche\" finden \n// var daten_startpos = quelle.indexOf('cleaning_distance');\nvar daten_startpos = quelle.indexOf(suche);\nvar daten = quelle.substr(daten_startpos + suche_laenge, 50);\n\n// Finde \"<\" und merke dir die Position. Schneide aus von 0 bis Position\nvar daten_endpos = daten.indexOf('<');\ndaten = daten.substring(0, daten_endpos);\nmsg1.payload = daten; // String\n\nreturn [msg1];","outputs":"1","noerr":0,"x":706,"y":556,"z":"7859072e.87a6f8","wires":[["c7157fc8.38ea8"]]},{"id":"c7157fc8.38ea8","type":"ioBroker out","name":"","topic":"node-red.0.Roomba.saugt","ack":"false","autoCreate":"true","x":1042,"y":558,"z":"7859072e.87a6f8","wires":[]},{"id":"182e191.fe7d1e7","type":"function","name":"Status-Uhrzeit ermitteln","func":"msg = {};\n\n\nfunction addZero(i) {\n    if (i < 10) {\n        i = \"0\" + i;\n    }\n    return i;\n}\n\n\nvar currentdate = new Date(); \nvar h = addZero(currentdate.getHours());\nvar m = addZero(currentdate.getMinutes());\nvar s = addZero(currentdate.getSeconds());\n\n\nvar datetime = h + \":\" + m + \":\" + s;\n\nmsg.payload = datetime;\nreturn msg;\n","outputs":1,"noerr":0,"x":701,"y":631,"z":"7859072e.87a6f8","wires":[["57efa4f2.a8105c"]]},{"id":"57efa4f2.a8105c","type":"ioBroker out","name":"","topic":"node-red.0.Roomba.Statusuhrzeit","ack":"false","autoCreate":"true","x":1044,"y":636,"z":"7859072e.87a6f8","wires":[]}]</cleaning></cleaner_state></temperature></charge></capacity></battery_charge></bin_status></cleaning_distance></name>
    Auch hier muss UNBEDINGT im Aufruf "Roomba command" die IP-Adresse des Roomba eingetragen werden.
    Folgende Datenpunkte stehen zur Verfügung:
    node-red.0.Roomba.name => Der vergebene Name der Roomba
    node-red.0.Roomba.strecke => Gefahrene Strecke
    node-red.0.Roomba.schmutzbehaelter => Schmutzbehälter voll
    node-red.0.Roomba.akkuladung => Akkuladung in Prozent
    node-red.0.Roomba.akkusoll => Akkuleistung (Soll-Wert, ausgelesen) im mA
    node-red.0.Roomba.akkuist => Akkuleistung (Ist-Wert, gemessen) im mA
    node-red.0.Roomba.temperatur => Temperatur im Roomba
    node-red.0.Roomba.status => Status des Roomba (in Klartext)
    node-red.0.Roomba.saugt => Soll angeben, ob der Roomba gerade saugt (funktioniert aber irgendwie nicht, stattdessen besser den Datenpunkt "node-red.0.Roomba.status" benutzen)
    node-red.0.Roomba.Statusuhrzeit => Uhrzeit der Statusabfrage
    Die Flows laufen seit einigen Tagen ohne Probleme bei mir.
    Verbesserungen, Kommentare, usw. sind sehr willkommen.
    Gruß,
    Eric
    • H Offline
      hometm
      Sobald mein RooWifi für meinen 870 da ist, wollte ich einen Adapter hierfür schreiben
      Tobias
      Gesendet von meinem VT10416-2 mit Tapatalk
      • eric2905E Offline
        eric2905E Offline
        eric2905
        Moin,
        dann bin ich der erste, der den testen möchte ;-)
        Adapter programmieren muss ich mir irgendwann auch mal ansehen … momentan stehe ich mir immer wieder selber im Weg :-)
        Gruß,
        Eric
          tesso
          Ich werde den Adapter auch testen.
          Der Roomba hat bisher bei mir nur WLAN, aber keine Einbindung in die Steuerung.
          • eric2905E Offline
            eric2905E Offline
            eric2905
            @tesso:
            Übernimm einfach mal die Node-red Flows von mir - macht Spaß, den Roomba integriert zu wissen ;-)
            Eine passende View (Wigdets) kann ich auch bereitstellen, wenn gewünscht.
            Gruß,
            Eric
              tesso
              Die Widgets interessieren mich auch.
              Habe eben die flows importiert. dabei habe ich Fehler bekommen (iobroker input und output wären nicht vorhanden).
              Suche nun den Fehler und schaue dann weiter.
                Arminhh
                hat sofort funktioniert! Super Beschreibung und Flow!! :D
                Das Widget würde mich auch sehr interessieren!
                mfg
                Arminhh
                • eric2905E Offline
                  eric2905E Offline
                  eric2905
                  So, dann hier die Widgets.
                  Die Steuerung:
                  [{"tpl":"tplFrame","data":{"visibility-cond":"==","visibility-val":1,"title":"Steuerung","title_color":"black","title_top":"5","title_left":"15","header_height":"30","header_color":"#a0c0ca"},"style":{"left":"560px","top":"60px","width":"345px","height":"423px","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"bold","font-size":"large","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplJquiButtonState","data":{"oid":"node-red.0.Roomba.command_Clean","visibility-cond":"==","visibility-val":1,"buttontext":"Normal saugen","padding":"5","value":"1"},"style":{"left":"590px","top":"120px","z-index":"20"},"widgetSet":"jqui"},{"tpl":"tplJquiButtonState","data":{"oid":"node-red.0.Roomba.command_SpotSaugen","visibility-cond":"==","visibility-val":1,"buttontext":"Spot saugen","padding":"5","value":"1"},"style":{"left":"590px","top":"170px","z-index":"20"},"widgetSet":"jqui"},{"tpl":"tplJquiButtonState","data":{"oid":"node-red.0.Roomba.command_MaxSaugen","visibility-cond":"==","visibility-val":1,"buttontext":"Max saugen","padding":"5","value":"1"},"style":{"left":"590px","top":"220px","z-index":"20"},"widgetSet":"jqui"},{"tpl":"tplJquiButtonState","data":{"oid":"node-red.0.Roomba.command_DriveStop","visibility-cond":"==","visibility-val":1,"buttontext":"Stop","padding":"5","value":"1"},"style":{"left":"590px","top":"290px","z-index":"20"},"widgetSet":"jqui"},{"tpl":"tplJquiButtonState","data":{"oid":"node-red.0.Roomba.command_PowerOff","visibility-cond":"==","visibility-val":1,"buttontext":"Power off","padding":"5","value":"1"},"style":{"left":"590px","top":"420px","z-index":"20"},"widgetSet":"jqui"},{"tpl":"tplJquiButtonState","data":{"oid":"node-red.0.Roomba.command_Findme","visibility-cond":"==","visibility-val":1,"buttontext":"Find me","padding":"5","value":"1"},"style":{"left":"730px","top":"420px","z-index":"20"},"widgetSet":"jqui"},{"tpl":"tplJquiButtonState","data":{"oid":"node-red.0.Roomba.command_BackToDock","visibility-cond":"==","visibility-val":1,"buttontext":"Zur Basis","padding":"5","value":"1"},"style":{"left":"590px","top":"370px","z-index":"20"},"widgetSet":"jqui"},{"tpl":"tplJquiButtonState","data":{"oid":"node-red.0.Roomba.command_LeaveDock","visibility-cond":"==","visibility-val":1,"buttontext":"Basis verlassen","padding":"5","value":"1"},"style":{"left":"730px","top":"370px","z-index":"20"},"widgetSet":"jqui"}]
                  Die Statusinfos:
                  [{"tpl":"tplFrame","data":{"visibility-cond":"==","visibility-val":1,"title":"Status","title_color":"black","title_top":"5","title_left":"15","header_height":"30","header_color":"#a0c0ca"},"style":{"left":"50px","top":"60px","width":"435px","height":"453px","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"bold","font-size":"large","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"nothing_selected","visibility-cond":"==","visibility-val":1,"html_prepend":"Akkustatus"},"style":{"left":"70px","top":"120px","width":"200px","height":"20px","color":"white","text-align":"left","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"bold","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"node-red.0.Roomba.akkuladung","visibility-cond":"==","visibility-val":1,"is_comma":"true","factor":"1","html_append_singular":" %","html_append_plural":" %"},"style":{"left":"360px","top":"120px","width":"100px","height":"22px","color":"white","text-align":"right","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"bold","font-size":"large","z-index":"20"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"nothing_selected","visibility-cond":"==","visibility-val":1,"html_prepend":"Akkukapazität max."},"style":{"left":"70px","top":"160px","width":"200px","height":"20px","color":"white","text-align":"left","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"bold","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"node-red.0.Roomba.akkusoll","visibility-cond":"==","visibility-val":1,"is_comma":"true","factor":"1","html_append_singular":" mA","html_append_plural":" mA"},"style":{"left":"360px","top":"160px","width":"100px","height":"22px","color":"white","text-align":"right","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"bold","font-size":"large","z-index":"20"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"node-red.0.Roomba.akkuist","visibility-cond":"==","visibility-val":1,"is_comma":"true","factor":"1","html_append_singular":" mA","html_append_plural":" mA"},"style":{"left":"360px","top":"190px","width":"100px","height":"22px","color":"white","text-align":"right","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"bold","font-size":"large","z-index":"20"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"nothing_selected","visibility-cond":"==","visibility-val":1,"html_prepend":"Akkukapazität ist"},"style":{"left":"70px","top":"190px","width":"200px","height":"20px","color":"white","text-align":"left","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"bold","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":1,"html_prepend":"Saugt gerade"},"style":{"left":"70px","top":"240px","width":"200px","height":"20px","color":"white","text-align":"left","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"bold","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueListHtml8","data":{"oid":"node-red.0.Roomba.saugt","visibility-cond":"==","visibility-val":1,"count":"1","value0":"Nein","value1":"Ja","style1":"background-color: green","style0":"background-color: red","value2":"Offen","style2":"background-color: red; padding:4px;","test_list":"0"},"style":{"left":"360px","top":"240px","color":"white","text-align":"center","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"bold","font-size":"large","width":"100px","height":"22px","z-index":"20","overflow-x":""},"widgetSet":"basic"},{"tpl":"tplValueListHtml8","data":{"oid":"node-red.0.Roomba.schmutzbehaelter","visibility-cond":"==","visibility-val":1,"count":"1","value0":"Nein","value1":"Ja","style1":"background-color: red","style0":"background-color: green","value2":"Offen","style2":"background-color: red; padding:4px;","test_list":"0"},"style":{"left":"360px","top":"280px","color":"white","text-align":"center","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"bold","font-size":"large","width":"100px","height":"22px","z-index":"20","overflow-x":""},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":1,"html_prepend":"Staubbehälter voll"},"style":{"left":"70px","top":"280px","width":"200px","height":"20px","color":"white","text-align":"left","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"bold","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":1,"html_prepend":"Status"},"style":{"left":"70px","top":"360px","width":"200px","height":"20px","color":"white","text-align":"left","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"bold","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"node-red.0.Roomba.status","visibility-cond":"==","visibility-val":1},"style":{"left":"140px","top":"360px","z-index":"20","color":"rgb(255, 255, 255)","text-align":"right","text-shadow":"none","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"bold","font-size":"16px","line-height":"18px","letter-spacing":"0","word-spacing":"0px","width":"320px","height":"20px"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"nothing_selected","visibility-cond":"==","visibility-val":1,"html_prepend":"Gefahrene Strecke"},"style":{"left":"70px","top":"390px","width":"200px","height":"20px","color":"white","text-align":"left","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"bold","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"node-red.0.Roomba.strecke","visibility-cond":"==","visibility-val":1,"is_comma":"true","factor":"","html_append_singular":" m","html_append_plural":" m"},"style":{"left":"360px","top":"390px","width":"100px","height":"22px","color":"white","text-align":"right","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"bold","font-size":"large","z-index":"20"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"nothing_selected","visibility-cond":"==","visibility-val":1,"html_prepend":"Temperatur"},"style":{"left":"70px","top":"420px","width":"200px","height":"20px","color":"white","text-align":"left","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"bold","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"node-red.0.Roomba.temperatur","visibility-cond":"==","visibility-val":1,"is_comma":"true","factor":"","html_append_singular":" ºC","html_append_plural":" ºC"},"style":{"left":"360px","top":"420px","width":"100px","height":"22px","color":"white","text-align":"right","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"bold","font-size":"large","z-index":"20"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"node-red.0.Roomba.Statusuhrzeit","visibility-cond":"==","visibility-val":1,"html_prepend":"(Stand : ","html_append":")"},"style":{"left":"130px","top":"66px","color":"black","text-align":"left","width":"250px","height":"20px","z-index":"20","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-weight":"bold","font-size":"large"},"widgetSet":"basic"}]
                  Am node-red-Flow für die Statusinfos habe ich noch was angepasst - die Uhrzeit der Statusabfrage wird nun auch in einen Datenpunkt geschrieben und im Widget mit angezeigt. So sieht man immer, wie alt der angezeigte Status ist.
                  Hier der überarbeitete Flow "Roomba Status" (ist auch im Posting oben angepasst):
                  Viel Spaß damit :-)
                  Gruß,
                  Eric
                  smarthomegirlS 1 Antwort Letzte Antwort
                    Welche Roombas gehen denn per WLAN? und wo gibt's das WLAN-Modul?
                    • H Offline
                      hometm
                      Such mal nach roowifi im Netz. Bestellt habe ich das Modul vor 3 Wochen, aber erhalten habe ich es noch nicht. Daher kann ich noch keine Aussage dazu machen.
                      • eric2905E Offline
                        eric2905E Offline
                        eric2905
                        Hallo Rainer,
                        @Homoran:
                        Welche Roombas gehen denn per WLAN? und wo gibt's das WLAN-Modul? `
                        derzeit geht die 500/600er-Serie und für die 700/800er-Serie ist gerade auf Kickstarter wieder ein Projekt gestartet => Infos hier : http://www.thinkingcleaner.com
                        In Deutschland kannst Du das WLAN-Modul hier kaufen => http://www.homewizard.de/thinking-clean … 00-eu.html
                        Da habe ich meinen auch bestellt (ohne Versandkosten). Ging sehr zügig.
                        Gruß,
                        Eric
                          tesso
                          Ich kann die flows nicht testen. Suche immer noch nach den verlorenen nodes in/out.
                          Noch fehlt mir die Idee für eine Lösung.
                          • eric2905E Offline
                            eric2905E Offline
                            eric2905
                            Moin,
                            hast Du den node-red-Adapter schon deinstalliert und neu installiert?
                            Gruß,
                            Eric
                            • derAugeD Offline
                              derAugeD Offline
                              derAuge
                              Frage:
                              ist dieser Robi dafür brauchbar?
                              http://onlineshop.real.de/Saugroboter-R … 8947001001
                              oder
                              http://www.comtech.de/Markenshops/iRobo ... augroboter
                              Jürgen
                              • H Offline
                                hometm
                                Ich habe einen 870 und bin voll zufrieden.
                                Meiner Meinung nach sind die räumlichen Gegebenheiten viel wichtiger als das Modell.
                                Wenn z.B.
                                • Treppen vorhanden sind
                                • Gardinen bis auf den Boden reichen
                                • Kabel herum liegen
                                • Der sauger sich unter niedrigen Möbelstücken verklemmt
                                • Teppichfranzen
                                Dann ist der Spass schnell vorbei. Daher sollte man sich so ein Gerät da bestellen, wo man es auch ohne Probleme zurück geben kann
                                Tobias
                                  tesso
                                  Cool, endlich ist der Roomba in der Haussteuerung.
                                    Arminhh
                                    moin
                                    ich habe mir gerade eine Szene erstellt wenn der Staubbehälter voll ist, das ich eine Nachricht bekomme. Funktioniert auch soweit, ausser das nach dem leeren die Variable nicht zurückgesetzt wird. Hat der Staubbehälter einen Sensor? Wenn ja wo? Oder wie wird der Füllstand sonst ausgewertet?
                                    mfg
                                    Armin
                                    • eric2905E Offline
                                      eric2905E Offline
                                      eric2905
                                      Moin,
                                      eh, … bei mir wird die Variable (aus dem Flow) zurückgesetzt ... allerdings habe ich noch nie darauf geachtet, wann.
                                      Evtl. nach dem nächsten Clean-Start?
                                      Mal probieren.
                                      Ist die Verarbeitung über eine Szene einfacher, als über einen Flow?
                                      Ich habe mich noch nicht mit den Szenen befasst, daher meine Frage.
                                      Gruß,
                                      Eric
                                      • eric2905E eric2905
                                        Die Steuerung:
                                        Die Statusinfos:
                                        Viel Spaß damit :-)
                                        Gruß,
                                        Eric
                                        smarthomegirlS Offline
                                        smarthomegirl
                                        schrieb am zuletzt editiert von smarthomegirl
                                        @eric2905 sagte in IRobot Roomba Steuerung:
                                        Viel Spaß damit :-)
                                        Gruß,
                                        Eric
                                        Hallo @eric2905,
                                        beim Importieren des Roomba Status Flows in NodeRed kommt bei mir folgende Fehlermeldung:
                                        Was mache ich da falsch? Wo liegt der Fehler?
                                        EDIT:
                                        Es darf
                                        nicht enthalten sein.
                                        Ein Problem habe ich aber trotzdem noch.
                                        Ich habe wie beschrieben unter "Roomba command" meine IP Adresse des Saugroboters eingetragen, aber nach dem Deployen bekommt Node Red keine Verbindung. (siehe Bild) So wie es aussieht ist diese Verbindung nicht möglich.
                                        Der Aufruf dieses Links http://192.168.178.253/full_status.xml ist nicht möglich.
                                        Im Log steht folgende Fehlermeldung:
                                        node-red.0	2020-02-22 21:45:41.561	error	at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)
                                        node-red.0	2020-02-22 21:45:41.561	error	(2903) 22 Feb 21:45:41 - [error] [http request:Roomba command] Error: connect ECONNREFUSED 192.168.178.253:80
                                        node-red.0	2020-02-22 21:44:41.552	error	at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)
                                        node-red.0	2020-02-22 21:44:41.552	error	(2903) 22 Feb 21:44:41 - [error] [http request:Roomba command] Error: connect ECONNREFUSED 192.168.178.253:80
                                        node-red.0	2020-02-22 21:43:41.581	error	at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)
                                        node-red.0	2020-02-22 21:43:41.581	error	(2903) 22 Feb 21:43:41 - [error] [http request:Roomba command] Error: connect ECONNREFUSED 192.168.178.253:80
                                        node-red.0	2020-02-22 21:42:41.561	error	at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)
                                        node-red.0	2020-02-22 21:42:41.561	error	(2903) 22 Feb 21:42:41 - [error] [http request:Roomba command] Error: connect ECONNREFUSED 192.168.178.253:80
                                        node-red.0	2020-02-22 21:41:41.576	error	at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)
                                        node-red.0	2020-02-22 21:41:41.576	error	(2903) 22 Feb 21:41:41 - [error] [http request:Roomba command] Error: connect ECONNREFUSED 192.168.178.253:80
                                        node-red.0	2020-02-22 21:41:12.308	error	at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)
                                        node-red.0	2020-02-22 21:41:12.308	error	(2903) 22 Feb 21:41:12 - [error] [http request:Roomba command] Error: connect ECONNREFUSED 192.168.178.253:80
                                        node-red.0	2020-02-22 21:41:12.138	error	at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)
                                        node-red.0	2020-02-22 21:41:12.138	error	(2903) 22 Feb 21:41:12 - [error] [http request:Roomba command] Error: connect ECONNREFUSED 192.168.178.253:80
                                        node-red.0	2020-02-22 21:40:12.307	error	at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)
                                        node-red.0	2020-02-22 21:40:12.307	error	(2903) 22 Feb 21:40:12 - [error] [http request:Roomba command] Error: connect ECONNREFUSED 192.168.178.253:80
                                        node-red.0	2020-02-22 21:40:12.160	error	at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)
                                        node-red.0	2020-02-22 21:40:12.160	error	(2903) 22 Feb 21:40:12 - [error] [http request:Roomba command] Error: connect ECONNREFUSED 192.168.178.253:80
                                        node-red.0	2020-02-22 21:39:12.353	error	at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)
                                        node-red.0	2020-02-22 21:39:12.353	error	(2903) 22 Feb 21:39:12 - [error] [http request:Roomba command] Error: connect ECONNREFUSED 192.168.178.253:80
                                        node-red.0	2020-02-22 21:39:12.324	error	at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)
                                        node-red.0	2020-02-22 21:39:12.324	error	(2903) 22 Feb 21:39:12 - [error] [http request:Roomba command] Error: connect ECONNREFUSED 192.168.178.253:80
                                        Was ist da falsch? Was muss ich da machen?
                                        👍 Ich danke Euch im Voraus. 👍
                                        82.7k
