  4. Flot: Hover Details erzeugen nicht benutzbare Scroll Leisten
    5.5k
5 Beiträge 2 Kommentatoren 882 Aufrufe
  • Z Offline
    Z Offline
    Zippolighter
    wenn Hover details im flot edit aktiv sind und die Position der Hoverpunkte nah am Fensterrand sind, wird nur ein Teil der Hover Information angezeigt und Scrollleisten erzeugt.
    Die Scrollleisten sind aber nicht nutzbar, da sofort wenn der Hover verlassen wird um zu den Scrollleisten zu gelangen, die Scrollleisten natürlich verschwinden.
    Flot Link
    http://192.168.168.168:8082/flot/index.html?l%5B0%5D%5Bid%5D=tankerkoenig.0.stations.0.diesel.feed&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23FFFF00&l%5B0%5D%5Bmin%5D=0.850&l%5B0%5D%5Bmax%5D=1.300&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5Bname%5D=JET+Buschhausener+Str.&l%5B0%5D%5BafterComma%5D=3&l%5B0%5D%5Byaxe%5D=off&l%5B0%5D%5Bxaxe%5D=off&l%5B0%5D%5BignoreNull%5D=0&l%5B1%5D%5Bid%5D=tankerkoenig.0.stations.1.diesel.feed&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%23FBB206&l%5B1%5D%5Bmin%5D=0.850&l%5B1%5D%5Bmax%5D=1.300&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bname%5D=JET+Weiherstr.&l%5B1%5D%5BafterComma%5D=3&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5Byaxe%5D=off&l%5B1%5D%5BignoreNull%5D=0&l%5B2%5D%5Bid%5D=tankerkoenig.0.stations.2.diesel.feed&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=minmax&l%5B2%5D%5Bcolor%5D=%230040FF&l%5B2%5D%5Bmin%5D=0.850&l%5B2%5D%5Bmax%5D=1.300&l%5B2%5D%5Bthickness%5D=3&l%5B2%5D%5Bshadowsize%5D=3&l%5B2%5D%5Bname%5D=ESSO+Westmarkstr.&l%5B2%5D%5Byaxe%5D=off&l%5B2%5D%5Bxaxe%5D=off&l%5B2%5D%5BignoreNull%5D=0&l%5B3%5D%5Bid%5D=tankerkoenig.0.stations.3.diesel.feed&l%5B3%5D%5Boffset%5D=0&l%5B3%5D%5Baggregate%5D=minmax&l%5B3%5D%5Bcolor%5D=%23FF000C&l%5B3%5D%5Bmin%5D=0.850&l%5B3%5D%5Bmax%5D=1.300&l%5B3%5D%5Bthickness%5D=3&l%5B3%5D%5Bshadowsize%5D=3&l%5B3%5D%5Bname%5D=WESTFALEN+Herne&l%5B3%5D%5BignoreNull%5D=0&l%5B3%5D%5BafterComma%5D=3&timeType=relative&relativeEnd=today&range=1440&live=300&start=2016-06-30&start_time=00%3A01&end=2017-07-04&end_time=23%3A00&aggregateType=count&aggregateSpan=100&width=500&height=245&noBorder=noborder&window_bg=rgba(255%2C+255%2C+255%2C+0)&bg=0&legend=nw&hoverDetail=true&timeFormat=%25H%3A%25M+%25d.%25m&useComma=true&zoom=true&noedit=false&animation=0
    Denke richtig wäre die Hover information immer zwingend im Fenster anzuzeigen.
    Kann man das irgendwie einstellen??
    Danke Gruß Zippolighter
    • BluefoxB Offline
      BluefoxB Offline
      Stell mal overflow ein.
      • Z Offline
        Z Offline
        Zippolighter
        @Bluefox:
        Stell mal overflow ein. `
        Habe ich gemacht, aber keine Veränderung. Es werden weiterhin Scrollbalken erzeugt und der Hover Info ist abgeschnitten
        • Z Offline
          Z Offline
          Zippolighter
          @Zippolighter:
          @Bluefox:
          Stell mal overflow ein. Habe ich gemacht, aber keine Veränderung. Es werden weiterhin Scrollbalken erzeugt und der Hover Info ist abgeschnitten
          Habe gerade bei mir Charts gefunden die sich richtig verhalten. Schau mal ob ich den Unterschied finde.
          • Z Offline
            Z Offline
            Zippolighter
            Scheint irgendwie mit der Position der Datenpunkte zusammenzuhängen. Denke er wechselt zu früh von Anzeige hover über dem Wert zu Anzeige hover unter dem Wert.
            Habe einen neuen Chart erstellt. (Kann man irgendwie alles auf default setzen in flot edit??. Habe alle linien gelöscht. Allerdings ist z.B. noch ein Fehler bei "Nach Komma". Steht auf 0 und trotzdem Y Achse und Hoover haben nachkommastellen)
            Hier wird der Hooverpunkt am 05.07 21.44 halb ausserhalb angezeigt
            Der Wert am 04.07 wird innerhalb angezeigt
            Gruß Zippolighter
