  4. Admin Scripte Tab lädt nach Update nicht mehr
javascript script enginejavascriptadmin adapter
13 Beiträge 5 Kommentatoren 1.4k Aufrufe 3 Beobachtet
  • wendy2702W wendy2702
    Welche Versionen von Node/NPM/JS-Controller/Admin habt ihr installiert?
    Kommt eine Error Meldung in der Browser Konsole (F12)?
    walli545W Offline
    walli545W Offline
    walli545
    @wendy2702
    Node: 8.15.1
    NPM: 6.4.1
    js-controller: 1.5.7
    Admin: 3.6.0
    Dieser log kommt:
    Subscribe logs
    blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_EQ}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_NEQ}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_LT}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_LTE}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_GT}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_GTE}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_OPERATION_TOOLTIP_AND}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_OPERATION_TOOLTIP_OR}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_WHILEUNTIL_TOOLTIP_WHILE}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_WHILEUNTIL_TOOLTIP_UNTIL}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_FLOW_STATEMENTS_TOOLTIP_BREAK}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_FLOW_STATEMENTS_TOOLTIP_CONTINUE}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_FOR_TOOLTIP}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_FOREACH_TOOLTIP}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ARITHMETIC_TOOLTIP_ADD}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ARITHMETIC_TOOLTIP_MINUS}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ARITHMETIC_TOOLTIP_MULTIPLY}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ARITHMETIC_TOOLTIP_DIVIDE}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ARITHMETIC_TOOLTIP_POWER}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_ROOT}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_ABS}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_NEG}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_LN}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_LOG10}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_EXP}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_POW10}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_SIN}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_COS}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_TAN}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_ASIN}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_ACOS}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_ATAN}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_SUM}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_MIN}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_MAX}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_AVERAGE}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_MEDIAN}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_MODE}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_STD_DEV}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_RANDOM}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_CHANGE_TOOLTIP}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_TEXT_APPEND_TOOLTIP}.
    Gestern ging die Seite einmal kurz am Handy, ein zweites mal dann aber nicht mehr.
    • wendy2702W Online
      wendy2702W Online
      Hm,
      hast du mal einen anderen Browser probiert?
      Sonst würde ich mal einen Downgrade auf die alte Version machen.
      walli545W 1 Antwort Letzte Antwort
        Hm,
        walli545W Offline
        walli545W Offline
        walli545
        @wendy2702
        mit Edge und Firefox das gleiche Verhalten, inkl. log. Auch am Handy.
        Wie würde das gehen?
        • wendy2702W Online
          wendy2702W Online
          Schau mal hier:
          https://forum.iobroker.net/topic/20884/hue-adapter-error-socket-hang-up/10
          Da habe ich es für den HUE Adapter beschrieben. Für den Javascript Adapter dann halt für den machen.
            Schau mal hier:
            walli545W Offline
            walli545W Offline
            walli545
            @wendy2702
            hab jetzt wieda auf 3.6.4 downgegraded.
            Hierbei lädt der frame aber auch teilweise nicht ...
            Könnte es sein, dass das mit https/auth zu tun hat? Ist ja auch nur ein iframe der /adapter/javascript/tab.html anzeigt.
            Habe auch mal alle Scripte entfernt und js2fs deaktivert und dann nochmal upgedated/downgegraded hat auch nichts gebracht...
            • wendy2702W Online
              wendy2702W Online
              Ich habe kein HTTPS/Auth aktiviert.
              Kannst du ja zum testen deaktivieren.
              • walli545W Offline
                walli545W Offline
                walli545
                schrieb am zuletzt editiert von walli545
                Ich kann meine Vermutung bestätigen, wenn ich https und auth deaktiviere, funktioniert der admin und der scripte tab wieder einwandfrei.
                Eigentlich möchte ich aber weiterhin https und auth verwenden ... Hat eventuell jmd eine Idee an was das liegen könnte?
                Meine Vermutung warum der Admin teilweise unendlich lädt ist, dass evtl. die gespeicherten Login Daten in den Cookies nicht richtig restored werden. Wenn ich diese lösche gehts meistens. Vielleicht ist das Problem mit dem Scripte Tab auf das gleiche zurückzuführen.
                @Marty56 hast du ebenfalls https und auth aktiviert?
                M SpegeliS 2 Antworten Letzte Antwort
                • walli545W walli545
                  Marty56
                  @walli545 Nein, ich habe HTTPS/Auth nicht aktiviert.
                  HW:NUC (16 GB Ram)
                  OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                    SpegeliS Offline
                    SpegeliS Offline
                    Spegeli
                    @walli545 said in Admin Scripte Tab lädt nach Update nicht mehr:
                    Hast du eine Lösung für das Problem gefunden gehabt?
                    Hab das selbe Problem sein heute und konnte folgendes rausfinden:
                    Hab das Problem seit heute selber und konnte es etwas einschränken:
                    Ist im Admin.0 Adapter bei "Ausführen als" der Standard "Admin" ausgewählt funktioniert alles ohne Probleme.
                    Wählt man dort aber einen anderen User bzw. selbst angelegten Admin aus dann lässt sich der Skripte Tab nicht mehr öffnen.
                    Auch wenn man die Authentifikation beim Admin.0 einschaltet und sich dann per Standard Admin einloggt geht es, mit dem selbst angelegten Admin allerdings nicht.
                    Eine Fix, eine Lösung oder ein Workaround dafür wären schön.
                      Smartin
                      schrieb am zuletzt editiert von Smartin
                      Hier klinke ich mich mal ein, habe genau dieses Problem mit dem Skriptadapter schon seit der ersten 4er Version.
                      Hatte auch schon viel getestet und dann bis gestern mit der 3.64 Version gearbeitet. Erst als ich hier gelesen habe, dass es mit dem Standard Admin funktioniert bin ich umgestiegen.
                      Ich dachte ehrlich gesagt die ganze Zeit, dass es an meinem System liegt, aber es scheinen ja mehrere davon betroffen zu sein.
                      Vielleicht gibts ja mal einen Fix, aber Hauptsache es funzt so erst mal.
