  3. Entwicklung
  4. [Adapter] Neuer radar2-Adapter
adapterradar2 adapter
840 Beiträge 80 Kommentatoren 319.6k Aufrufe 54 Beobachtet
  • C ChrisXY
    also hier mal nach Installation was im Log steht:
    host.iobroker	2019-05-20 21:09:35.387	error	instance system.adapter.radar2.0 terminated with code null ()
    host.iobroker	2019-05-20 21:09:35.386	warn	instance system.adapter.radar2.0 terminated due to SIGSEGV
    host.iobroker	2019-05-20 21:09:02.739	error	instance system.adapter.radar2.0 terminated with code null ()
    host.iobroker	2019-05-20 21:09:02.739	warn	instance system.adapter.radar2.0 terminated due to SIGABRT
    Caught	2019-05-20 21:09:02.738	error	by controller[0]: .0: ../deps/uv/src/unix/poll.c:123: uv_poll_start: Assertion `!(((handle)->flags & (UV_HANDLE_CLOSING | UV_HANDLE_CLOSED)) != 0)' failed.
    noch mehr
    radar2.0	2019-05-20 21:12:03.904	info	found '@abandonware/noble'
    radar2.0	2019-05-20 21:12:03.714	info	radar2 initialization started...
    radar2.0	2019-05-20 21:12:03.602	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.radar2, node: v8.16.0
    radar2.0	2019-05-20 21:11:30.636	info	found '@abandonware/noble'
    radar2.0	2019-05-20 21:11:30.407	info	radar2 initialization started...
    radar2.0	2019-05-20 21:11:30.282	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.radar2, node: v8.16.0
    radar2.0	2019-05-20 21:10:57.684	info	radar2 initialization started...
    radar2.0	2019-05-20 21:10:57.555	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.radar2, node: v8.16.0
    radar2.0	2019-05-20 21:10:39.296	info	found '@abandonware/noble'
    radar2.0	2019-05-20 21:10:39.063	info	radar2 initialization started...
    radar2.0	2019-05-20 21:10:38.935	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.radar2, node: v8.16.0
    frankjokeF Offline
    frankjokeF Offline
    frankjoke
    schrieb am zuletzt editiert von frankjoke
    #619
    @ChrisXY
    Hast du das installationsscript ausgeführt (womöglich) bevor du den Adapter installiert hast?
    Es fehlen BT-Treiber bei der Installation.
    Du hast SIGSEGV error das Bedeutet dass der Adapter eventuell nicht die Rechte hat auf bestimmte Geräte/Funktionen zuzugreifen. Kann auch sein dass du ne andere Software wie Docker oder so verwendest die die Rechte einschränkt.
    Frank,
    NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
    Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
    frankjokeF 1 Antwort Letzte Antwort
    • frankjokeF frankjoke
      @ChrisXY
      frankjokeF Offline
      frankjokeF Offline
      frankjoke
      #620
      Habe gerade eine weitere (V1.2)-Version auf git gepostet mit folgenden Änderungen:
      1. Man kann zwischen Noble & hcitool lescan und BT scan & l2ping getrennt wählen
      2. Man sollte BT-LE Macs mit einem ! voran kennzeichnen damit sie nicht mit dem l2ping gescannt werden (und es 4 Sekunden/Adresse dauert bis l2ping nichts zurückmeldet).
      3. Die Abwesenheitszeit kann auf eine Minute gesenkt werden wenn die scan-Zeit < Abwesenheit/2.5 ist.
      4. Habe in den Readme's kurze Beschreibung für die BT-scans hinzugefügt
      Damit kann sich jeder seine Einstellungen zusammensetzen wie er sie benötigt.
      Frank,
      • C Offline
        ChrisXY
        #621
        Puh das kann sein ganz am anfang erst adapter installiert dann per Konsole die 2 sachen ausgeführt. Will nur das DHCP nutzen. Bt hab ich eh nicht. Was kann ich den nun machen? Muss doch ein Port bei docker frei gemacht werden?
          schreda
          schrieb am zuletzt editiert von schreda
          #622
          Hi
          Ich nöchte gerne auf folgenden GitHub issue verweisen:
          https://github.com/frankjoke/ioBroker.radar2/issues/17
          Ich habe mir mittlerweile die MAC-Adressen-Erkennung selbst geschrieben und möchte diese gerne teilen:
          const objPrefix          = 'geofence.';
          const objPostfixIsHere   = '.isHere';
          const objPostfixLastSeen = '.lastSeen';
          const arp_scan_cmd      = 'sudo arp-scan --interface=wlan0 -lgq --retry=5 --timeout=400';
          const arp_scan_interval = 20 * 1000; // ms
          const device_timeout    = 3; // min
          const welcomeTimeDelay  = 20 * 1000; // ms
          const macs = [
              { 'id': 'id1', 'mac':  'XX:XX:XX:XX:XX:XX'},
              { 'id': 'id2', 'mac':  'XX:XX:XX:XX:XX:XX'},
              { 'id': 'id3', 'mac':  'XX:XX:XX:XX:XX:XX'}
          for (var i in macs) {
              createState(objPrefix + macs[i].id + objPostfixIsHere,   false, { type: 'boolean', def: false });
              createState(objPrefix + macs[i].id + objPostfixLastSeen, false, { type: 'string', def: '' });
          createState(objPrefix + 'nHere', false, { read: true, write: true, type: 'number', def: 0 });
          setInterval(() => {
              exec(arp_scan_cmd, (err, stdout, stderr) => {
                  if (!err) {
                      var macs_found = '';
                          if (stdout.includes(macs[i].mac.toLowerCase())) {
                              macs_found += macs[i].mac + ' ';
                              setState(objPrefix + macs[i].id + objPostfixLastSeen, new Date().toString(),true);
                              setState(objPrefix + macs[i].id + objPostfixIsHere, true, true);
                          } else {
                              var lastSeen = new Date(getState(objPrefix + macs[i].id + objPostfixLastSeen).val);
                              lastSeen.setMinutes(lastSeen.getMinutes() + device_timeout)
                              if (new Date() > lastSeen) {
                                  log('Device ' + macs[i].mac + ' went inactive', 'debug');
                                  setState(objPrefix + macs[i].id + objPostfixIsHere, false, true);
                      if (macs_found) {
                          log('MACS found: '+macs_found, 'debug');
                      var nHere = 0;
                          if (getState(objPrefix + macs[i].id + objPostfixIsHere).val) {
                              nHere++;
                      setState(objPrefix + 'nHere', nHere, true);
                  } else {
                      log(err.message, 'error');
          }, arp_scan_interval);
              const mac = macs[i];
              on({ id: OBJ_JS_INSTANCE + objPrefix + mac.id + objPostfixIsHere, change: 'ne', val: true }, (obj) => {
                  log('Devie ' + mac.mac + ' went active', 'debug');
                  // user func
          Sollte zugleich eine feature suggestion sein, um eine MAC-only-detection zu ermöglichen
          • S schreda
            Hi
            const macs = [
            setInterval(() => {
                    if (!err) {
                            } else {
                        if (macs_found) {
                        var nHere = 0;
                                nHere++;
                    } else {
                    // user func
            frankjokeF Offline
            frankjokeF Offline
            frankjoke
            #623
            @schreda
            Das sollte aber schon mit radar funktionieren da ja radar auch arp-scan verwendet!
            Du musst ja nicht unbedingt etwas in die ip eintragen!
            Hab's gerade getestet und es funktioniert nur mit der mac-Adresse auch!
            p.s.: Verwende ja auch das arp-scan...
            p.s.:: das geht natürlich nur wenn die mac auf den Netz ist wo der adapter direkt zugriff hat, nicht in einem entfernten Netz über den Router.
            Frank,
            • C ChrisXY
              frankjokeF Offline
              frankjokeF Offline
              frankjoke
              #624
              @ChrisXY
              Leider muss gerade DHCP auf broadcasts zugreifen die der interne router der docker-Anwendung eventuell nicht zulässt.
              Hab sowas schon bei einem Nutzer erlebt der pihole laufen gehabt hat...
              Frank,
              • C Offline
                ChrisXY
                #625
                habe aber iobroker als macvlan am laufen das sollte glaube ich klappen ?
                ABER wenn in der Fritzbox es doch erkannt wird , kann man es nicht direkt von dort abgreifen ?
                  @schreda
                  schreda
                  #626
                  @frankjoke
                  Ich hatte genau die selbe Frage auf GitHub gestellt und da hast du anders geantwortet ;)
                  Nunja, es hat mit dem radar Adapter leider nicht funktioniert..
                  • C ChrisXY
                    frankjokeF Offline
                    frankjokeF Offline
                    frankjoke
                    #627
                    @ChrisXY
                    Das kannst vielleicht mit dem TR???-Adapter.
                    Wenn auf der Kommandozeile (in dem v-lan) arp-scan geht dann sollte auch radar2 gehen, verwend ja auch nichts anderes.
                    Frank,
                    • S schreda
                      @frankjoke
                      frankjokeF Offline
                      frankjokeF Offline
                      frankjoke
                      #628
                      @schreda
                      Ich weiß, habe nicht an arp-scan gedacht, aber es dann selbst ausprobiert und bei mir findet er einträge nur mit macs die arp-scan auch findet.
                      Frank,
                      • C Offline
                        ChrisXY
                        #629
                        Muss ich den arp-scan Installieren ? Will es nur zusätzlich nutzen neben der fritzbox und Ping als 3. erkennung DHCP .
                        Da ich Docker nutze will ich nichts im System groß machen
                        • C ChrisXY
                          frankjokeF Offline
                          frankjokeF Offline
                          frankjoke
                          #630
                          @ChrisXY
                          Ich kenn mich bei Docker nicht so aus (verwende nur VM's auf meinem QNAP NAS da ich da auch andere Betriebssysteme verwenden kann).
                          Radar2 braucht arp-scan nur um mac-Adressen zu finden, wenn du das nicht brauchst kannst es weglassen.
                          Aber ich würde so System-nahe Programme eher am Host system und nicht im container installieren, es sei denn der container kann nicht auf host-Programme zugreifen.
                          DHCP für IPv4 sind broadcasts auf Port 69 die der mittels dgram modul (von nodejs selbst) gelesen wird, dazu aber erweiterte Systemberechtigungen benötigt (wie auch arp-scan) welche mittels meinem Installationsscript für debian/Ubuntu erteilt werden. Ob diese dann auch in Containern gelten kann ich nicht sagen.
                          Bei den jetztigen linux-Versionen sind die Bewilligungen auch an das aktuelle Programm (z.B. node oder arp-scan) gebunden, wird dieses per apt(-get) upgedated muss sie neu erteilt werden (mein script neu aufrufen).
                          Das soll verhindern dass irgendwer das Programm austauscht und dann auf Befehle Zughreifen kann welche die Sicherheit gefährden können.
                          Frank,
                          MathiasJM 1 Antwort Letzte Antwort
                            @ChrisXY
                            MathiasJM Offline
                            MathiasJM Offline
                            MathiasJ
                            #631
                            @frankjoke
                            Bei mir werden die G-Tags nur noch gefunden, wenn ich Noble aktiviere.
                            Das kann ich aber gar nicht gebrauchen, denn wenn ich den USB-Extender endlich mal installiert habe, schmiert Noble ab.
                            I2ping ist deaktiviert., hcitool lescan deaktiviert,
                            Ich habe auch gelesen, ein ! vor der MAC-Adresse zu setzen. hat auch nichts gebracht.
                            Gruß,
                            Mathias
                            IObroker auf dem NUC als VM.
                            • MathiasJM MathiasJ
                              @ChristianF
                              So weit ich es mitbekommen habe, gibt es mit den Gigaset Keepern Probleme.
                              Mit meinen G-Tags funktionert alles.
                              Es werden bei mir sogar die Xiaomi flower care in den Blumentöpfen, allerdings als "unbekannt" gescannt.
                              Hier kommt dann die Instanz BT und ein 2. Dongle (der noch nicht angeschlossen ist) zum tragen.
                              @Supermicha
                              Bei Anwesenheit reagiert Radar2 ja sofort.
                              Damit soll verhindert werden, daß z.B. die Heizung hin- und herschaltet, wenn man doch anwesend ist und Radar2 einen Scan versemmelt hat.
                              bei Radar hat eine Abwesenheitskennung (bei mir zumindest) bis zu 10 Minuten gedauert. Da sind 2 Minuten ja richtig schnell. Bis die Anwesenheit erkannt wurde, mußte ich bis zu 30 Sekunden vor der Türe stehen, bis ich die Türe aufschließen konnte. da ist ja Anwesenheit sofort bei Radar2 ja richtig toll.
                              Supermicha
                              #632
                              @MathiasJ sagte in [Adapter] Neuer radar2-Adapter:
                              @Supermicha
                              Ich kann von dem alten Radar-Adapter sowas nicht vermelden. Die Geräte wurden beim nächsten Scan direkt als offline angezeigt. (so wie ich es gerne hätte) Da ist der jetzige Adapter bisher langsamer...
                              Das mit dem Verhindern, das die Heizung hin und her schaltet, wenn er mal falsch scannt, lässt sich ja ohne Probleme über ein Script abfangen.
                              @frankjoke kann es sein, das Echo-Geräte irgendwie nicht sauber zu scannen sind? antworten die zu langsam oder gar nicht? Bei mir werden die fast immer als offline angezeigt, obwohl alle am laufen sind. Komischerweise aktualisieren sie sich oft, wenn ein anderes Gerät das Netzwerk betritt oder verlässt, aber nach kurzer Zeit sind sie wieder off..
                              P.S. Ich werd bei gelegenheit mal die 1.2 testen. Ob mir das mit der verkürzten Zeit schon reicht...
                              Was ich nicht so ganz verstehe: Du hattest geschrieben, das die Adapter-Logik mindestens 2 Scandurchgänge braucht... Im alten Adapter waren doch die Durchgänge einstellbar, ab wann ein Gerät als abwesend angezeigt wird. Und dort konnte man doch auch 0.. oder 1.. ich weiß es nicht mehr genau... einstellen und es lief auch...
                              • MathiasJM Offline
                                MathiasJM Offline
                                MathiasJ
                                #633
                                was vllt interessant wäre, ist jeder version einen anderen Namen zu geben.
                                Jetzt kann ich nicht mehr zurück von der 1.2.0 auf die 1.2.0
                                bei der letzten Version ging Radar mit hciscan, hier nur noch mit Noble.
                                • smileS smile
                                  @frankjoke Achso okay, sorry.
                                  Habe iobroker auf einem Intel i5 mit Windows 10Pro, 16GB RAM. Node 8.15.1, npm 6.9.0
                                  Hier einmal der LOG wenn ich den Radar Adapter starte:
                                  host.DJ-Server 2019-05-14 20:02:39.796 info Restart adapter system.adapter.radar2.0 because enabled
                                  host.DJ-Server 2019-05-14 20:02:39.796 error instance system.adapter.radar2.0 terminated with code 0 (OK)
                                  Caught 2019-05-14 20:02:39.796 error by controller[0]: at process._tickCallback (internal/process/next_tick.js:181:9)
                                  Caught 2019-05-14 20:02:39.796 error by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:132:7)
                                  Caught 2019-05-14 20:02:39.795 error by controller[0]: at Noble.<anonymous> (C:\ioBroker\node_modules@abandonware\noble\lib\noble.js:57:24)
                                  Caught 2019-05-14 20:02:39.795 error by controller[0]: at NobleBindings.init (C:\ioBroker\node_modules@abandonware\noble\lib\hci-socket\bindings.js:82:13)
                                  Caught 2019-05-14 20:02:39.795 error by controller[0]: at Hci.init (C:\ioBroker\node_modules@abandonware\noble\lib\hci-socket\hci.js:101:35)
                                  Caught 2019-05-14 20:02:39.795 error by controller[0]: at BluetoothHciSocket.bindRaw (C:\ioBroker\node_modules@abandonware\bluetooth-hci-socket\lib\usb.js:43:8)
                                  Caught 2019-05-14 20:02:39.795 error by controller[0]: at BluetoothHciSocket.bindUser (C:\ioBroker\node_modules@abandonware\bluetooth-hci-socket\lib\usb.js:87:11)
                                  Caught 2019-05-14 20:02:39.795 error by controller[0]: Error: No compatible USB Bluetooth 4.0 device found!
                                  radar2.0 2019-05-14 20:02:39.763 info Adapter disconnected and stopped with dostop(false) and callback(true)
                                  radar2.0 2019-05-14 20:02:39.762 error at process._tickCallback (internal/process/next_tick.js:181:9)
                                  radar2.0 2019-05-14 20:02:39.762 error at _combinedTickCallback (internal/process/next_tick.js:132:7)
                                  radar2.0 2019-05-14 20:02:39.762 error at Noble.<anonymous> (C:\ioBroker\node_modules@abandonware\noble\lib\noble.js:57:24)
                                  radar2.0 2019-05-14 20:02:39.762 error at NobleBindings.init (C:\ioBroker\node_modules@abandonware\noble\lib\hci-socket\bindings.js:82:13)
                                  radar2.0 2019-05-14 20:02:39.762 error at Hci.init (C:\ioBroker\node_modules@abandonware\noble\lib\hci-socket\hci.js:101:35)
                                  radar2.0 2019-05-14 20:02:39.762 error at BluetoothHciSocket.bindRaw (C:\ioBroker\node_modules@abandonware\bluetooth-hci-socket\lib\usb.js:43:8)
                                  radar2.0 2019-05-14 20:02:39.762 error at BluetoothHciSocket.bindUser (C:\ioBroker\node_modules@abandonware\bluetooth-hci-socket\lib\usb.js:87:11)
                                  radar2.0 2019-05-14 20:02:39.762 error Error: No compatible USB Bluetooth 4.0 device found!
                                  radar2.0 2019-05-14 20:02:39.762 error uncaught exception: No compatible USB Bluetooth 4.0 device found!
                                  radar2.0 2019-05-14 20:02:39.759 warn Promise problem unhandledRejection of Promise Promise { <rejected> TypeError: A.isLinuxApp(...).then is not a function at Network.updateMacdb.then.then (C:\ioBroker\node_modules\iobroker.radar2\radar
                                  radar2.0 2019-05-14 20:02:39.757 info radar2 set to scan every 20 seconds and printers every 720 minutes.
                                  radar2.0 2019-05-14 20:02:39.757 info arp-scan will use the following interfaces: [ 'Ethernet', 'USB Netzwerk Dongle' ]
                                  radar2.0 2019-05-14 20:02:39.757 info use known IP list: [ '1.1.1.1', '172.16.2.47' ]
                                  radar2.0 2019-05-14 20:02:39.756 info use known BT list: [ '3c:dc:bc:24:05:21', '00:00:46:00:00:01' ]
                                  radar2.0 2019-05-14 20:02:39.756 info radar2 set to flag items away if they are not seen for 2 minutes
                                  radar2.0 2019-05-14 20:02:39.756 info found 'node-bluetooth'
                                  radar2.0 2019-05-14 20:02:39.715 info found '@abandonware/noble'
                                  radar2.0 2019-05-14 20:02:39.296 info Connected with '0.0.0.0' for DHCP Scan
                                  radar2.0 2019-05-14 20:02:39.193 info radar2 initialization started...
                                  radar2.0 2019-05-14 20:02:39.160 info starting. Version 1.0.7 in C:/ioBroker/node_modules/iobroker.radar2, node: v8.15.1
                                  Danke für Deine Unterstützung.
                                  smileS Offline
                                  smileS Offline
                                  smile
                                  #634
                                  @smile sagte in [Adapter] Neuer radar2-Adapter:
                                  Hi frankjoke, darf ich nochmal nachfragen ob dir der Log weitergeholfen hat?
                                  Oder gibt es noch irgendetwas anderes was ich probieren kann um die Bluetooth Anwesenheit auf Windows zu realisieren?
                                  io.broker @ debian @ virtualbox @ Windows 10 Pro / Node 18.17.1, npm 9.6.7 / CCU3 / IR.Trans Server / Daslight 4 / Mobotix IP Cams / Qnap NAS / Sonos /
                                  Mein Rolladen - Blockly: https://forum.iobroker.net/topic/6442/das-ultimative-markisen-rolladen-blockly-script
                                  • C Offline
                                    ChristianF
                                    #635
                                    So, nun habe ich es auch geschafft und den Adapter kaputtgespielt.
                                    Habe den Raspi komplett neu aufgesetzt, frisches OS usw.
                                    Habe auch die Schritte mit den zusätzlichen Installationen durchgeführt.
                                    Aber:
                                    host.raspi	2019-05-25 02:25:50.258	info	Restart adapter system.adapter.radar2.1 because enabled
                                    host.raspi	2019-05-25 02:25:50.258	error	instance system.adapter.radar2.1 terminated with code 0 (OK)
                                    Caught	2019-05-25 02:25:50.258	error	by controller[0]: port: 67 }
                                    Caught	2019-05-25 02:25:50.258	error	by controller[0]: address: '0.0.0.0',
                                    Caught	2019-05-25 02:25:50.258	error	by controller[0]: syscall: 'bind',
                                    Caught	2019-05-25 02:25:50.257	error	by controller[0]: code: 'EADDRINUSE',
                                    Caught	2019-05-25 02:25:50.257	error	by controller[0]: errno: 'EADDRINUSE',
                                    Caught	2019-05-25 02:25:50.257	error	by controller[0]: at process._tickCallback (internal/process/next_tick.js:181:9)
                                    Caught	2019-05-25 02:25:50.257	error	by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:142:11)
                                    Caught	2019-05-25 02:25:50.257	error	by controller[0]: at _handle.lookup (dgram.js:266:18)
                                    Caught	2019-05-25 02:25:50.256	error	by controller[0]: { Error: bind EADDRINUSE 0.0.0.0:67
                                    radar2.1	2019-05-25 02:25:50.115	warn	Adapter will exit in latest 1 sec with code false!
                                    radar2.1	2019-05-25 02:25:50.108	info	Adapter disconnected and stopped with dostop(false) and callback(true)
                                    radar2.1	2019-05-25 02:25:50.106	error	at process._tickCallback (internal/process/next_tick.js:181:9)
                                    radar2.1	2019-05-25 02:25:50.106	error	at _combinedTickCallback (internal/process/next_tick.js:142:11)
                                    radar2.1	2019-05-25 02:25:50.106	error	at _handle.lookup (dgram.js:266:18)
                                    radar2.1	2019-05-25 02:25:50.106	error	Error: bind EADDRINUSE 0.0.0.0:67
                                    radar2.1	2019-05-25 02:25:50.105	error	uncaught exception: bind EADDRINUSE 0.0.0.0:67
                                    radar2.1	2019-05-25 02:25:50.074	info	radar2 set to scan every 20 seconds and printers every 720 minutes.
                                    radar2.1	2019-05-25 02:25:50.074	info	arp-scan will use the following interfaces: [ 'eth0', 'wlan0' ]
                                    radar2.1	2019-05-25 02:25:50.072	info	use known IP list: [ '192.168.1.xxx
                                    radar2.1	2019-05-25 02:25:50.070	info	use known BT list: []
                                    radar2.1	2019-05-25 02:25:50.068	info	radar2 set to flag items away if they are not seen for 1 minutes
                                    radar2.1	2019-05-25 02:25:50.055	info	net-ping not available! Will try to use normal ping!
                                    radar2.1	2019-05-25 02:25:50.022	info	found and will use '@abandonware/noble'
                                    radar2.1	2019-05-25 02:25:49.678	info	found and will use 'node-bluetooth scan'
                                    radar2.1	2019-05-25 02:25:49.652	info	radar2 initialization started...
                                    radar2.1	2019-05-25 02:25:49.474	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.radar2, node: v8.16.0
                                    host.raspi	2019-05-25 02:25:47.835	info	instance system.adapter.radar2.1 started with pid 13802
                                    Das Spannende ist: eigentlich soll er gar keinen ARP Scan auf ETH0 durchführen, sondern bestenfalls auf wlan0, da der DNS Server nur auf eth0 lauscht. Dafür habe ich ihm im Parameterfeld für arp-scan folgende Parameter mitgegeben: -vN -I wlan0 192.168.179.0/24 -> scheint ihn nicht sonderlich zu interessieren.
                                    Hat jemand einen Tipp? Gern würde ich den ARP Scan sonst komplett abschalten..
                                    • C ChristianF
                                      Aber:
                                      frankjokeF Offline
                                      frankjokeF Offline
                                      frankjoke
                                      #636
                                      @ChristianF
                                      Hast wirklich die Liste der Befehle hier im Install Spoiler ausgeführt?
                                      Der Rechner hat keine Rechte für das Bind auf DHCP, auch arp-scan braucht Rechte.
                                      Und noch was, hast eventuell 'ne alte Instanz laufen? mach mal sudo pkill -f io.radar2.0
                                      Frank,
                                      C 1 Antwort Letzte Antwort
                                      • smileS smile
                                        frankjokeF Offline
                                        frankjokeF Offline
                                        frankjoke
                                        #637
                                        @smile
                                        Noble braucht spezielle BT-Treiber glaub ich für Windows und auch spezielle build-tools. Schau mal auf https://github.com/noble/noble#readme
                                        Ich kann nur auf https://github.com/jasongin/noble-uwp verweisen, das hab ich selbst gerade gefunden und noch nicht ausprobiert.
                                        Wenn das unter Windows funktioniert kann ich mal testen ob ich beide noble einbauen kann und je nach OS das eine oder andere verwende, wird aber dauern bis ich das testen kann, muss mir eine Windows vm bauen wo ich iobroker drauf gib und dann alles wie in obigen links beschrieben mal installiere...
                                        Frank,
                                        smileS 1 Antwort Letzte Antwort
                                          frankjokeF Offline
                                          frankjokeF Offline
                                          frankjoke
                                          #638
                                          @MathiasJ
                                          Wie meinst du das, du hast jetzt nur 2 flags getrennt! Wie schaut dein log aus wenn du auf hciscan schaltest ?
                                          Frank,
