  4. BananaPi Master / RaspberryPi Slave - läuft nicht stabil
    5.5k
13 Beiträge 2 Kommentatoren 486 Aufrufe
  • L Offline
    LJSven
    Habe ich gemacht. Die Frage ist, warum das passiert?
    • L LJSven
      @LJSven sagte in BananaPi Master / RaspberryPi Slave - läuft nicht stabil:
      warum das passiert?
      Gute Frage, nächste Frage ;-)
      Was war denn zum Zeitpunkt als die Meldungen anfingen?
      • L Offline
        LJSven
        So sieht die Log aus ->
        2019-03-02 03:37:46.543 - error: iot.0 read ECONNRESET
        2019-03-02 03:37:46.545 - info: iot.0 Connection changed: disconnect
        2019-03-02 03:37:46.546 - info: iot.0 Connection lost
        2019-03-02 03:37:50.806 - info: alexa2.0 Alexa-Push-Connection disconnected - retry: Retry Connection in 5s
        2019-03-02 03:37:51.845 - info: iot.0 Connection changed: connect
        2019-03-02 03:37:56.898 - info: alexa2.0 Alexa-Push-Connection established. Disable Polling
        2019-03-02 03:38:04.955 - error: telegram.0 polling_error:EFATAL, EFATAL: Error: read ECONNRESET
        2019-03-02 03:38:20.822 - info: alexa2.0 Alexa-Push-Connection disconnected - retry: Retry Connection in 5s
        2019-03-02 03:38:26.708 - info: alexa2.0 Alexa-Push-Connection established. Disable Polling
        2019-03-02 04:00:00.175 - info: host.bananapimaster instance system.adapter.ical.0 started with pid 25111
        2019-03-02 04:00:05.225 - info: ical.0 starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.ical, node: v8.15.0
        2019-03-02 04:00:13.286 - info: host.bananapimaster instance system.adapter.ical.0 terminated with code 0 (OK)
        2019-03-02 04:29:56.006 - error: sonoff.0 websocket error
        2019-03-02 04:29:56.019 - error: sonoff.0 Error: websocket error
        at WS.Transport.onError (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:64:13)
        at WebSocket.ws.onerror (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transports/websocket.js:150:10)
        at WebSocket.onError (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/EventTarget.js:109:16)
        at emitOne (events.js:116:13)
        at WebSocket.emit (events.js:211:7)
        at WebSocket.finalize (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/WebSocket.js:182:41)
        at Socket.emit (events.js:211:7)
        at emitErrorNT (internal/streams/destroy.js:66:8)
        at _combinedTickCallback (internal/process/next_tick.js:139:11)
        2019-03-02 05:04:00.081 - info: telegram.0 Scheduled restart.
        2019-03-02 05:04:01.599 - info: telegram.0 terminating with timeout
        2019-03-02 05:20:15.581 - info: javascript.0 script.js.common.Sonstige.Astro-Tageszeit: neue Tagezeit: Morgendämmerung
        2019-03-02 05:20:15.583 - info: javascript.0 script.js.common.Sonstige.Astro-Tageszeit: nächte kommende Tagezeit: Sonnenaufgang
        2019-03-02 07:18:17.604 - info: javascript.0 script.js.common.Sonstige.Astro-Tageszeit: neue Tagezeit: Sonnenaufgang
        2019-03-02 07:18:17.606 - info: javascript.0 script.js.common.Sonstige.Astro-Tageszeit: nächte kommende Tagezeit: Morgen
        2019-03-02 07:21:49.848 - info: javascript.0 script.js.common.Sonstige.Astro-Tageszeit: neue Tagezeit: Morgen
        2019-03-02 07:21:49.850 - info: javascript.0 script.js.common.Sonstige.Astro-Tageszeit: nächte kommende Tagezeit: Vormittag
        • L LJSven
          @LJSven
          Das log geht nur bis 7:21, da ist noch kein code7 drin.
          Im anderen Ausschnitt war es 8:50
          • L Offline
            LJSven
            Das stimmt - der Auslöser warum das System in die Knie gegangen ist, war aber um 4:29 Uhr
            Hier der Log nach 8 (war schon nach dem Neustart):
            2019-03-02 08:39:41.406 - info: host.bananapimaster instance system.adapter.iot.0 started with pid 2815
            2019-03-02 08:39:46.150 - info: host.bananapimaster instance system.adapter.info.0 started with pid 2862
            2019-03-02 08:39:49.357 - info: vis-google-fonts.0 starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v8.15.0
            2019-03-02 08:39:50.413 - info: host.bananapimaster instance system.adapter.vis-google-fonts.0 terminated while should be started once
            2019-03-02 08:40:01.698 - error: info.0 no connection to objects DB
            2019-03-02 08:40:05.339 - warn: backitup.0 Reconnection to DB.
            2019-03-02 08:40:05.344 - warn: backitup.0 Reconnection to DB.
            2019-03-02 08:40:05.360 - warn: zigbee.0 Reconnection to DB.
            2019-03-02 08:40:05.373 - warn: zigbee.0 Reconnection to DB.
            2019-03-02 08:40:05.542 - error: backitup.0 already running
            2019-03-02 08:40:05.556 - error: zigbee.0 already running
            2019-03-02 08:40:05.870 - warn: admin.0 Reconnection to DB.
            2019-03-02 08:40:05.880 - warn: admin.0 Reconnection to DB.
            2019-03-02 08:40:06.275 - error: host.bananapimaster instance system.adapter.backitup.0 terminated with code 7 (Adapter already running)
            2019-03-02 08:40:06.277 - info: host.bananapimaster Restart adapter system.adapter.backitup.0 because enabled
            2019-03-02 08:40:06.296 - error: host.bananapimaster instance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)
            2019-03-02 08:40:06.296 - info: host.bananapimaster Restart adapter system.adapter.zigbee.0 because enabled
            2019-03-02 08:40:06.413 - error: admin.0 already running
            2019-03-02 08:40:06.621 - error: host.bananapimaster instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
            2019-03-02 08:40:06.559 - info: tr-064.0 starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v8.15.0
            2019-03-02 08:40:06.623 - info: host.bananapimaster Restart adapter system.adapter.admin.0 because enabled
            2019-03-02 08:40:06.862 - info: info.0 starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.info, node: v8.15.0
            2019-03-02 08:40:08.273 - info: iot.0 starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.iot, node: v8.15.0
            2019-03-02 08:40:08.350 - info: iot.0 Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
            2019-03-02 08:40:09.381 - warn: opi.0 Reconnection to DB.
            2019-03-02 08:40:09.398 - warn: opi.0 Reconnection to DB.
            2019-03-02 08:40:15.660 - info: iot.0 Connection changed: connect
            2019-03-02 08:40:15.685 - error: iot.0 Cannot report device state: null
            2019-03-02 08:40:15.688 - warn: iot.0 Invalid URL key. Status update is disabled: {"error":"Unsupported version"}
            2019-03-02 08:40:36.356 - info: host.bananapimaster instance system.adapter.backitup.0 started with pid 3311
            2019-03-02 08:40:36.445 - info: host.bananapimaster instance system.adapter.zigbee.0 started with pid 3316
            2019-03-02 08:40:36.707 - info: host.bananapimaster instance system.adapter.admin.0 started with pid 3323
            • L LJSven
              @LJSven
              Und genau zwischen den beiden logs musst du suchen
              • L Offline
                LJSven
                Okay, es tut mir leid - ich kann da nichts sehen. Die erste Frage ist ja, was die Meldung um 4:29 Uhr bedeutet?! Da hat sich das System verabschiedet. Die 2. Frage ist, warum nach einem Reboot diese code7 Meldungen kommen.
                • L LJSven
                  Reboot oder restart?
                  Nach einem reboot sollten sie nicht kommen
                  • L Offline
                    LJSven
                    Ich mache folgendes als root
                    cd /opt/iobroker
                    iobroker stop
                    reboot
                    nachdem heute Nacht um 4:29 Uhr sich das System mit der o.g. Fehlermeldung aufgehangen hat. Nach dem Neustart kommen dann die Meldungen mit code7
                      Auch im ersten log fehlt die eigentliche ursache.
                      Was man da sieht ist nur, dass es anschließend verbindungsprobleme gibt.
                      Das könnte z.b. wegen der Zwangstrennung des ISP sein.
                      Dein ioBroker kommt dann nicht mehr ins Internet
                      • L Offline
                        LJSven
                        Die Zwangstrennung war um 03:37 - danach hat er die Verbindung auch wieder aufgebaut. Habe gerade nochmal in der Fritzbox nachgeschaut, danach war von Seiten des ISP kein Abbruch mehr.
                        2019-03-02 04:00:05.994 - info: ical.0 processing URL: Müllabfuhr https://calendar.google.com/calendar/ical/iv3htfrk6ua9t038g9u35c02uo%40group.calendar.google.com/private-dee65d06cf0190e3c162d7f916e3ed0b/basic.ics
                        2019-03-02 04:00:07.228 - info: ical.0 processing URL: ItaloBrothers https://calendar.google.com/calendar/ical/0ah106cilokm7mvs5i3v7cpm64%40group.calendar.google.com/private-a8dd673b0bad076698a352d940c2d828/basic.ics
