  4. Neuer admin-Adapter
    5.3k
Neuer admin-Adapter
13 Beiträge 4 Kommentatoren 3.2k Aufrufe
  • derAugeD Offline
    derAugeD Offline
    derAuge
    hi,
    ich denke das passt hier rein….
    Habe heute morgen mal auf einer VM eine neuinstallation durchgeführt und auch einige Adappter installiert.
    Problem macht nun der "node-red"
    node-red.0	2015-04-18 06:57:09	warn	node-red.0 18 Apr 06:57:09 - [warn] [redisout] Error: Cannot find module 'redis' 18 Apr 06:57:09 - [warn] ------------------------------------------ 18 Apr 06:57:09 - [info] User Directory : /opt/iobr
    node-red.0	2015-04-18 06:57:09	warn	node-red.0 18 Apr 06:57:09 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node.
    node-red.0	2015-04-18 06:57:09	warn	node-red.0 18 Apr 06:57:09 - [warn] [arduino] Error: Cannot find module 'arduino-firmata'
    node-red.0	2015-04-18 06:57:09	warn	node-red.0 18 Apr 06:57:09 - [warn] ------------------------------------------
    node-red.0	2015-04-18 06:57:08	warn	node-red.0 js-bson: Failed to load c++ bson extension, using pure JS version
    node-red.0	2015-04-18 06:57:07	warn	node-red.0 js-bson: Failed to load c++ bson extension, using pure JS version
    node-red-0	2015-04-18 06:56:55	info	Starting node-red: /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/node_modules/iobroker.node-red/userdata/settings.js
    node-red-0	2015-04-18 06:56:55	info	starting. Version 0.1.9 in /opt/iobroker/node_modules/iobroker.node-red
    iobroker	2015-04-18 06:56:53	info	exit 0
    iobroker	2015-04-18 06:56:53	info	object system.adapter.node-red.0 created
    host-VMioBrokerMaster	2015-04-18 06:56:53	info	instance system.adapter.node-red.0 started with pid 3629
    host-VMioBrokerMaster	2015-04-18 06:56:53	info	object change system.adapter.node-red.0
    iobroker	2015-04-18 06:56:53	info	object system.adapter.node-red.0.alive created
    iobroker	2015-04-18 06:56:53	info	object system.adapter.node-red.0.connected created
    iobroker	2015-04-18 06:56:53	info	object system.adapter.node-red.0.memHeapUsed created
    iobroker	2015-04-18 06:56:53	info	object system.adapter.node-red.0.memHeapTotal created
    iobroker	2015-04-18 06:56:53	info	object system.adapter.node-red.0.memRss created
    iobroker	2015-04-18 06:56:53	info	object system.adapter.node-red.0.uptime created
    iobroker	2015-04-18 06:56:53	info	object node-red.0 created
    iobroker	2015-04-18 06:56:53	info	create instance node-red
    iobroker	2015-04-18 06:56:53	info	object system.adapter.node-red created
    iobroker	2015-04-18 06:56:53	info	upload node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html
    iobroker	2015-04-18 06:56:53	info	upload node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
    iobroker	2015-04-18 06:56:53	info	got /opt/iobroker/node_modules/iobroker.node-red/admin
    iobroker	2015-04-18 06:56:53	info	install adapter node-red
    iobroker	2015-04-18 06:56:37	info	npm WARN optional dep failed, continuing iconv@2.1.6
    iobroker	2015-04-18 06:56:37	info	gyp ERR! not ok
    iobroker	2015-04-18 06:56:37	info	gyp ERR! node-gyp -v v1.0.1
    iobroker	2015-04-18 06:56:37	info	gyp ERR! node -v v0.10.38
    iobroker	2015-04-18 06:56:37	info	command "node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/irc/node_modules
    iobroker	2015-04-18 06:56:37	info	ERR! System Linux 3.2.0-4-amd64gyp ERR!
    iobroker	2015-04-18 06:56:37	info	ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:57:16gyp ERR! stack at Object.oncomplete (evalmachine.:108:15)
    iobroker	2015-04-18 06:56:37	info	ERR! stack at E (/usr/lib/node_modules/npm/node_modules/which/which.js:46:29)gyp
    iobroker	2015-04-18 06:56:37	info	at F (/usr/lib/node_modules/npm/node_modules/which/which.js:43:28)gyp
    iobroker	2015-04-18 06:56:37	info	stack Error: not found: makegyp ERR! stack
    iobroker	2015-04-18 06:56:37	info	build error
    iobroker	2015-04-18 06:56:27	info	npm WARN optional dep failed, continuing bufferutil@1.0.1
    iobroker	2015-04-18 06:56:27	info	gyp ERR! not ok
    iobroker	2015-04-18 06:56:27	info	gyp ERR! node-gyp -v v1.0.1
    iobroker	2015-04-18 06:56:27	info	gyp ERR! node -v v0.10.38
    iobroker	2015-04-18 06:56:27	info	gyp ERR! cwd /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/ws/node_modules/bufferutil
    iobroker	2015-04-18 06:56:27	info	gyp ERR! command "node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    iobroker	2015-04-18 06:56:27	info	gyp ERR! System Linux 3.2.0-4-amd64
    iobroker	2015-04-18 06:56:27	info	gyp ERR! stack at Object.oncomplete (evalmachine.:108:15)
    iobroker	2015-04-18 06:56:27	info	gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:57:16
    iobroker	2015-04-18 06:56:27	info	gyp ERR! stack at E (/usr/lib/node_modules/npm/node_modules/which/which.js:46:29)
    iobroker	2015-04-18 06:56:27	info	gyp ERR! stack at F (/usr/lib/node_modules/npm/node_modules/which/which.js:43:28)
    iobroker	2015-04-18 06:56:27	info	ERR! build error gyp ERR! stack Error: not found: make
    iobroker	2015-04-18 06:56:24	info	utf-8-validate@1.0.1
    iobroker	2015-04-18 06:56:24	info	optional dep failed, continuing
    iobroker	2015-04-18 06:56:24	info	WARN
    iobroker	2015-04-18 06:56:24	info	npm
    iobroker	2015-04-18 06:56:24	info	not ok
    iobroker	2015-04-18 06:56:24	info	gyp ERR! node-gyp -v v1.0.1gyp ERR!
    iobroker	2015-04-18 06:56:24	info	gyp ERR! node -v v0.10.38
    iobroker	2015-04-18 06:56:24	info	ERR! command "node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/ws/node_mo
    iobroker	2015-04-18 06:56:24	info	gyp ERR! stack at Object.oncomplete (evalmachine.:108:15)gyp ERR! System Linux 3.2.0-4-amd64
    iobroker	2015-04-18 06:56:24	info	gyp ERR! stack at E (/usr/lib/node_modules/npm/node_modules/which/which.js:46:29)gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:57:16
    iobroker	2015-04-18 06:56:24	info	ERR! stack Error: not found: makegyp ERR! stack at F (/usr/lib/node_modules/npm/node_modules/which/which.js:43:28)
    iobroker	2015-04-18 06:56:24	info	build error
    iobroker	2015-04-18 06:56:23	info	npm WARN optional dep failed, continuing bcrypt@0.8.1
    iobroker	2015-04-18 06:56:23	info	gyp ERR! not ok
    iobroker	2015-04-18 06:56:23	info	gyp ERR! node-gyp -v v1.0.1
    iobroker	2015-04-18 06:56:23	info	gyp ERR! node -v v0.10.38
    iobroker	2015-04-18 06:56:23	info	gyp ERR! cwd /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/bcrypt
    iobroker	2015-04-18 06:56:23	info	gyp ERR! command "node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    iobroker	2015-04-18 06:56:23	info	gyp ERR! System Linux 3.2.0-4-amd64
    iobroker	2015-04-18 06:56:23	info	stack at /usr/lib/node_modules/npm/node_modules/which/which.js:57:16gyp ERR! stack at Object.oncomplete (evalmachine.:108:15)
    iobroker	2015-04-18 06:56:23	info	gyp ERR! stack at E (/usr/lib/node_modules/npm/node_modules/which/which.js:46:29)
    iobroker	2015-04-18 06:56:23	info	stack Error: not found: makegyp ERR! stack at F (/usr/lib/node_modules/npm/node_modules/which/which.js:43:28)
    iobroker	2015-04-18 06:56:23	info	ERR!
    iobroker	2015-04-18 06:56:23	info	build error
    iobroker	2015-04-18 06:56:17	info	optional dep failed, continuing node-icu-charset-detector@0.0.7
    iobroker	2015-04-18 06:56:17	info	WARN
    iobroker	2015-04-18 06:56:17	info	npm
    iobroker	2015-04-18 06:56:17	info	gyp ERR! not ok
    iobroker	2015-04-18 06:56:17	info	gyp ERR! node-gyp -v v1.0.1
    iobroker	2015-04-18 06:56:17	info	gyp ERR! node -v v0.10.38
    iobroker	2015-04-18 06:56:17	info	gyp ERR! cwd /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/irc/node_modules/node-icu-charset-detector
    iobroker	2015-04-18 06:56:17	info	gyp ERR! command "node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    iobroker	2015-04-18 06:56:17	info	gyp ERR! System Linux 3.2.0-4-amd64
    iobroker	2015-04-18 06:56:17	info	gyp ERR! stack at Object.oncomplete (evalmachine.:108:15)
    iobroker	2015-04-18 06:56:17	info	gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:57:16
    iobroker	2015-04-18 06:56:17	info	gyp ERR! stack at E (/usr/lib/node_modules/npm/node_modules/which/which.js:46:29)
    iobroker	2015-04-18 06:56:17	info	gyp ERR! stack at F (/usr/lib/node_modules/npm/node_modules/which/which.js:43:28)
    iobroker	2015-04-18 06:56:17	info	gyp ERR! build error gyp ERR! stack Error: not found: make
    iobroker	2015-04-18 06:55:56	info	npm install iobroker.node-red --production --prefix "/opt/iobroker" (System call)
    iobroker	2015-04-18 06:55:51	info	add node-red
    • derAugeD Offline
      derAugeD Offline
      derAuge
      Hallo bluefox,
      das admin-Interface sieht nun sehr aufgeräumt aus. Super
      ist es vielleicht möglich in der "tree"-Ansicht eine Überschrift für "Installierte Adapter" zu machen?
      Ja ich habe gesehen, das es auch einen Filter gibt.
      Jedoch vermischen wir aktuell das angebot von adaptern
      Nach der Installation eines Adapters aus einer anderen Kategorie wird diese dann in "Allgemein" geführt
      Ist nur so eine Idee
      derAuge
      'Mann' sieht sich gleich
      • derAugeD Offline
        derAugeD Offline
        derAuge
        Hi Bluefox,
        habe zwischendurch mein VM-System auf den Stand gebracht
        Update Admin:
        host-VMioBrokerMaster	2015-04-19 13:05:41	info	Restart adapter system.adapter.admin.0 because enabled
        host-VMioBrokerMaster	2015-04-19 13:05:41	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
        host-VMioBrokerMaster	2015-04-19 13:05:40	info	instance system.adapter.admin.0 started with pid 2694
        iobroker	2015-04-19 13:05:35	info	exit 0
        iobroker	2015-04-19 13:05:29	info	Cannot parse filehttps://raw.githubusercontent.com/ioBroker/ioBroker.admin/master/io-package.json
        iobroker	2015-04-19 13:05:29	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.admin/master/io-package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:24	info	Timeout by read all package.json (33) seconds
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.zwave/master/package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.web/master/package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroker/ioBr
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.vis/master/package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.sonos/master/package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.rickshaw/master/package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.owfs/master/package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroker/ioB
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.onkyo/master/package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.socketio/master/package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.simple-api/master/package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.ping/master/package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroker/ioB
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.node-red/master/package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.megad/master/package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroker/io
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.legacy/master/package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.knx/master/package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.javascript/master/package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/husky-koglhof/ioBroker.hmm/master/package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroker
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.hue/master/package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.hm-rpc/master/package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.hm-rega/master/package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.history/master/package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.email/master/package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.cul/master/package.json. Error: Error: ESOCKETTIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroke
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.b-control-em/master/package.json. Error: Error: ESOCKETTIMEDOUT
        iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.artnet/master/package.json. Error: Error: ESOCKETTIMEDOUT
        iobroker	2015-04-19 13:05:18	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.admin/master/package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.yr/master/io-package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroker/io
        iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.vis/master/io-package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroker/i
        iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.sonos/master/io-package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.rickshaw/master/io-package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.pushover/master/io-package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.owfs/master/io-package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.socketio/master/io-package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBro
        iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.sayit/master/io-package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroker
        iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.ping/master/io-package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.mqtt/master/io-package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroker/
        iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.legacy/master/io-package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroke
        iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.knx/master/io-package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.javascript/master/io-package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioB
        iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.ical/master/io-package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/husky-koglhof/ioBroker.hmm/master/io-package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.hue/master/io-package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.hm-rpc/master/io-package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.hm-rega/master/io-package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.history/master/io-package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.email/master/io-package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.dwd/master/io-package.json. Error: Error: ESOCKETTIMEDOUT
        iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.cul/master/io-package.json. Error: Error: ESOCKETTIMEDOUT
        iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.b-control-em/master/io-package.json. Error: Error: ESOCKETTIMEDOUT
        iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.artnet/master/io-package.json. Error: Error: ESOCKETTIMEDOUT
        iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.admin/master/io-package.json. Error: Error: ETIMEDOUT
        host-VMioBrokerMaster	2015-04-19 13:05:10	info	Restart adapter system.adapter.admin.0 because enabled
        host-VMioBrokerMaster	2015-04-19 13:05:10	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
        host-VMioBrokerMaster	2015-04-19 13:05:09	info	instance system.adapter.admin.0 started with pid 2688
        iobroker	2015-04-19 13:05:05	info	upgrade admin
        derAuge
        PS: Hoffe die Heimfahrt war Stressfrei
        EDIT: Zweiter Versuch
        admin-0	2015-04-19 13:28:21	info	received all states
        admin-0	2015-04-19 13:28:21	info	received all objects
        admin-0	2015-04-19 13:28:21	info	Use link "http://localhost:8081" to configure.
        admin-0	2015-04-19 13:28:21	info	http server listening on port 8081
        admin-0	2015-04-19 13:28:21	info	requesting all objects
        admin-0	2015-04-19 13:28:21	info	requesting all states
        admin-0	2015-04-19 13:28:20	info	starting. Version 0.4.3 in /opt/iobroker/node_modules/iobroker.admin
        host-VMioBrokerMaster	2015-04-19 13:28:15	info	instance system.adapter.admin.0 terminated with code 0 (OK)
        host-VMioBrokerMaster	2015-04-19 13:28:14	info	instance system.adapter.admin.0 started with pid 2669
        admin-0	2015-04-19 13:28:14	info	terminating
        admin-0	2015-04-19 13:28:13	info	terminating http server on port 8081
        iobroker	2015-04-19 13:28:12	info	exit 0
        iobroker	2015-04-19 13:28:12	info	Adapter "admin" updated
        host-VMioBrokerMaster	2015-04-19 13:28:12	info	stopInstance system.adapter.admin.0 killing pid 2562
        host-VMioBrokerMaster	2015-04-19 13:28:12	info	object change system.adapter.admin.0
        iobroker	2015-04-19 13:28:12	info	upload admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
        iobroker	2015-04-19 13:28:11	info	got /opt/iobroker/node_modules/iobroker.admin/adminupload admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
        iobroker	2015-04-19 13:28:03	info	npm install --production --prefix "/opt/iobroker/node_modules/iobroker.admin" (System call)
        host-VMioBrokerMaster	2015-04-19 13:27:37	error	instance system.adapter.yr.0 terminated with code 1 ()
        yr-0	2015-04-19 13:27:36	error	force terminate
        iobroker	2015-04-19 13:26:15	info	npm install iobroker.admin --production --prefix "/opt/iobroker" (System call)
        iobroker	2015-04-19 13:26:07	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.zwave/master/package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:26:06	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.onkyo/master/package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:26:06	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.socketio/master/package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:26:03	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.dwd/master/io-package.json. Error: Error: ESOCKETTIMEDOUT
        iobroker	2015-04-19 13:26:03	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.cul/master/io-package.json. Error: Error: ESOCKETTIMEDOUT
        iobroker	2015-04-19 13:26:03	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.b-control-em/master/io-package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:26:03	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.artnet/master/io-package.json. Error: Error: ETIMEDOUT
        iobroker	2015-04-19 13:25:58	info	upgrade admin
        • BluefoxB Offline
          BluefoxB Offline
          admin Adapter wurde schon upgedated.
          wenn du in /opt/iobroker
          npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master
          ./iobroker restart
          Es sollte dann besser sein ;)
            mimquadrat
            Hallo Jungs,
            ich habe 2 ioBrokers im Mutierst (beide mit gleichem Setup, aber eben einen als "slave").
            Update am "Master" läuft einwandfrei durch.
            Beim Slave:
            $ ./iobroker upgrade admin
            Cannot download json from https://raw.githubusercontent.com/ioBro … ckage.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBro ... ckage.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBro ... ckage.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBro ... ckage.json. Error: Error: ETIMEDOUT
            npm
            http GET
            https://registry.npmjs.org/iobroker.admin
            npm
            http 200 https://registry.npmjs.org/iobroker.admin
            npm
            http GET https://registry.npmjs.org/iobroker.adm ... -0.4.4.tgz
            npm
            Auch der Node.red hat eine ähnliches Problem bei der Installation mit ETIMEDOUT errors...
            könnte Ihr mir weiterhelfen? DANKE! Hoffe Kassel war erfolgreich...
            • BluefoxB Offline
              BluefoxB Offline
              Update hat geklappt. Ich denke, dass du doch 0.4.4 admin hast.
              Die Meldungen werden in der nächste Version nicht mehr erscheinen. Du kannst die ausprobieren mit:
              cd /opt/iobroker
              ./iobroker stop
              ./iobroker start
              Falls paar Leute das ausprobieren und hier darüber schreiben, dann mache ich npm packet.
                Habe eben den js-adapter wie empfohlen upgedated:
                cd /opt/iobroker
                ./iobroker stop
                ./iobroker start
                Im log auf der Console keine Fehler,
                aber nach dem neustart im log:
                quad-pi	2015-04-20 10:14:33	error	host.quad-pi instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
                quad-pi	2015-04-20 10:14:33	info	host.quad-pi Restart adapter system.adapter.hmm.0 because enabled
                host-quad-pi	2015-04-20 10:14:31	error	instance system.adapter.ical.0 terminated with code 7 (Adapter already running)
                host-quad-pi	2015-04-20 10:14:31	info	instance system.adapter.hmm.0 started with pid 12071
                host-quad-pi	2015-04-20 10:14:27	info	instance system.adapter.ical.0 started with pid 12069
                host-quad-pi	2015-04-20 10:14:27	info	instance scheduled system.adapter.ical.0 0,30 * * * *
                host-quad-pi	2015-04-20 10:14:25	info	instance system.adapter.dwd.0 terminated with code 0 (OK)
                host-quad-pi	2015-04-20 10:14:25	info	Restart adapter system.adapter.node-red.0 because enabled
                host-quad-pi	2015-04-20 10:14:25	error	instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
                Auch stand die Version des controllers unter hosts noch auf 0.6.4
                Momentan läuft reboot ;-)
                  Bei der aktuellen Version sind ja schon einige Adapter in Kategorien eingeteilt.
                  für den Rest hätte ich folgende Vorschläge:
                  Hardware
                  -KNX
                  -ZWave
                  -(MegaD)
                  -(Siemens S7)
                  Visualistaion
                  -vis !
                  -legacy
                  Zeitplanung
                  -occ
                  Skripte und Logik
                  -Javascript
                  Kommunikation
                  diese Kategorie würde ich für Dinge wie
                  -email
                  -pushover
                  -Fritzbox (wenn es die mal gibt)
                  Wie die jetzige Kategorie heissen könnte ????
                  Media
                  -Onkyo
                  Wetter
                  -DWD
                  und eine neue Kategorie:
                  Beleuchtung
                  -artnet
                  -hue
                  für die restlichen habe ich auch keine Ahnung
                  • derAugeD Offline
                    derAugeD Offline
                    derAuge
                    ` > Wetter
                    -DWD `
                    • yr
                      @derAuge:
                      ` > Wetter
                      -DWD `
                      • yr `
                      ist doch schon drin :shock:
                      ich habe nur die noch nicht verteilten aufgezählt.
                        @Homoran:
                        cd /opt/iobroker
                        ./iobroker stop
                        ./iobroker start
                        Rainer `
                        inzwischen werden es immer mehr:
                        host-quad-pi	2015-04-20 20:39:36	info	instance system.adapter.cul.0 started with pid 11818
                        host-quad-pi	2015-04-20 20:39:28	info	Restart adapter system.adapter.ping.0 because enabled
                        host-quad-pi	2015-04-20 20:39:28	error	instance system.adapter.ping.0 terminated with code 7 (Adapter already running)
                        host-quad-pi	2015-04-20 20:39:27	info	Restart adapter system.adapter.pushover.0 because enabled
                        host-quad-pi	2015-04-20 20:39:27	error	instance system.adapter.pushover.0 terminated with code 7 (Adapter already running)
                        host-quad-pi	2015-04-20 20:39:25	info	instance system.adapter.ping.0 started with pid 11794
                        host-quad-pi	2015-04-20 20:39:25	info	instance system.adapter.pushover.0 started with pid 11792
                        host-quad-pi	2015-04-20 20:39:23	info	Restart adapter system.adapter.admin.0 because enabled
                        host-quad-pi	2015-04-20 20:39:23	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
                        inMem	2015-04-20 20:39:23	debug	message *.logging system.adapter.admin.0.logging val=false, ack=true, ts=1429555164, from=system.host.quad-pi, lc=1429554380
                        host-quad-pi	2015-04-20 20:39:22	info	Restart adapter system.adapter.javascript.0 because enabled
                        host-quad-pi	2015-04-20 20:39:22	error	instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
                        host-quad-pi	2015-04-20 20:39:18	info	instance system.adapter.admin.0 started with pid 11782
                        host-quad-pi	2015-04-20 20:39:18	info	instance system.adapter.javascript.0 started with pid 11780
                        host-quad-pi	2015-04-20 20:39:17	info	Restart adapter system.adapter.web.0 because enabled
                        host-quad-pi	2015-04-20 20:39:17	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
