  4. FHEM Adapter
    6.5k
FHEM Adapter
fhemadapter
676 Beiträge 82 Kommentatoren 280.8k Aufrufe 36 Beobachtet
  • E Offline
    Einklaus
    #236
    Hallo
    habe es installiert (von Git) und es gab Probleme. Adapter wollte nicht mehr starten.
    Caught 2019-01-31 19:02:05.459 error by controller[0]: at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
    Caught 2019-01-31 19:02:05.459 error by controller[0]: at Socket.Readable.push (_stream_readable.js:219:10)
    Caught 2019-01-31 19:02:05.459 error by controller[0]: at readableAddChunk (_stream_readable.js:264:11)
    Caught 2019-01-31 19:02:05.459 error by controller[0]: at addChunk (_stream_readable.js:283:12)
    Caught 2019-01-31 19:02:05.459 error by controller[0]: at Socket.emit (events.js:182:13)
    Caught 2019-01-31 19:02:05.459 error by controller[0]: at Socket.telnetSocket.on.data (D:\ioBroker\node_modules\iobroker.fhem\lib\telnet.js:136:30)
    Caught 2019-01-31 19:02:05.459 error by controller[0]: at Telnet.telnetOut.send [as requestCB] (D:\ioBroker\node_modules\iobroker.fhem\main.js:855:17)
    Caught 2019-01-31 19:02:05.459 error by controller[0]: at checkSubscribe (D:\ioBroker\node_modules\iobroker.fhem\main.js:918:15)
    Caught 2019-01-31 19:02:05.459 error by controller[0]: at checkSubscribe (D:\ioBroker\node_modules\iobroker.fhem\main.js:856:21)
    Caught 2019-01-31 19:02:05.458 error by controller[0]: at parseObjects (D:\ioBroker\node_modules\iobroker.fhem\main.js:1003:22)
    Caught 2019-01-31 19:02:05.458 error by controller[0]: TypeError: Cannot read property 'length' of undefined
    fhem.0 2019-01-31 19:02:05.429 error at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
    fhem.0 2019-01-31 19:02:05.429 error at Socket.Readable.push (_stream_readable.js:219:10)
    fhem.0 2019-01-31 19:02:05.429 error at readableAddChunk (_stream_readable.js:264:11)
    fhem.0 2019-01-31 19:02:05.429 error at addChunk (_stream_readable.js:283:12)
    fhem.0 2019-01-31 19:02:05.429 error at Socket.emit (events.js:182:13)
    Habe anschließend über IObroker 1.1.0. und dann 1.1.1. Installiert und es lief dann wieder.
    Klaus
    Suche Mitleidende in der Nähe von Buxtehude / Apensen / Harsefeld zum Erfahrungs- /Ideenaustausch ...............
    Iobroker über Window 10 (Mini PC),EZ-Control (FS20), Siemens Logo, Wolf ISM8 , Xiaomi Sauger, Fluoreon Wifi Heizregler , Zigbee (Xiaomi,HUE). Landroid WR141E, Tuya
    • LausiDL Offline
      LausiDL Offline
      LausiD
      #237
      Hallo Klaus,
      vielen Dank für Deinen Einsatz und die Rückmeldung :-)
      Du hast mit einer neuen Instanz getestet,oder?
      Konnte den Fehler jedenfalls nur bei Anlage einer neuen Instanz nachvollziehen.
      Sorry hatte ich nicht getestet :-(
      LausiD
      Doku zum FHEM Adapter
      Aktuelles zum FHEM Adapter
      Test FHEM Adapter
      • LausiDL Offline
        LausiDL Offline
        LausiD
        #238
        Hallo Klaus,
        Fehler sollten weg sein.
        Falls du Zeit und Lust hast darfst es gerne nochmal über github testen…...
        Danke und Gruß
        LausiD
        Test FHEM Adapter
        • E Offline
          Einklaus
          #239
          Hallo LausiD,
          Danke für deine Arbeit und das du es den Adapter immer weiter entwickelst.
          Bisschen testen und dann rummaulen ist nicht der große Einsatz ;)
          Einen Adapter zu entwickeln dürfte da deutlich mehr Einsatz bedeuten (und es zeigt auch das du deutlich mehr Ahnung hast).
          Werde es morgen erst testen können, hatte nebenbei nicht mit einer Neuen Instanz getestet.
          Gruß und noch einen schönen Abend
          Klaus
          • LausiDL Offline
            LausiDL Offline
            LausiD
            #240
            kein Übertrag von readingsGroup :-(
            viewtopic.php?f=30&t=21655&p=228934#p228934
            Brauch das noch jemand?
            Danke und Gruß
            LausiD
            Test FHEM Adapter
            • LausiDL Offline
              LausiDL Offline
              LausiD
              #241
              Nabend zusammen,
              auf github zum Testen bereit.
              1. FHEM readingsGroup werden jetzt auch übertragen
              2. In FHEM Raum ioB_System wird fhem.x.alive automatisch angelegt -> on = FHEM Adapter OK; off = FHEM Adapter keine Verbindung
              LausiD
              Test FHEM Adapter
              • LausiDL Offline
                LausiDL Offline
                LausiD
                #242
                hat wirklich niemand Zeit und Lust den Adapter über GitHub zu aktualisieren und kurz zu testen ?
                LausiD
                Test FHEM Adapter
                • E Offline
                  Einklaus
                  #243
                  Hallo LausiD,
                  installiert habe ich ihn. Fhem zeigt mir allerdings in ioB_System kein fhem.x.alive an
                  Habe dort:......
                  dummy
                  send2ioB ???
                  ......stehen.
                  Klaus
                  • LausiDL Offline
                    LausiDL Offline
                    LausiD
                    schrieb am zuletzt editiert von LausiD
                    #244
                    Hallo Klaus,
                    auf Dich ist halt Verlass.....Danke:-)
                    Was steht unter Step 10 beim Start?
                    Kannst du mal noch fhem.x.info.Configurations.autoConfigFHEM auf true setzen und nochmal probieren?
                    Mit send2ioB kann aus FHEM ein Objekt/State in ioBroker direkt beschrieben werden.
                    zB alexa2.0.Echo-Devices.xxxxxx.Commands.speak .Text aus FHEM
                    Ab sofort sollte auch ein dummy mit fhem.x.send2ioB angelegt werden
                    Danke und Gruß
                    LausiD
                    Test FHEM Adapter
                    • E Offline
                      Einklaus
                      #245
                      Hallo LausiD,
                      Adapter sicherheitshalber nochmal Neu installiert (über GIT)
                      Adapter lief nicht mehr hoch. Nach Step3 gab es Probleme
                      fhem.0 2019-02-15 11:29:35.385 debug statesDB connected
                      fhem.0 2019-02-15 11:29:34.711 silly transport error
                      fhem.0 2019-02-15 11:29:34.711 error Error: server error at Socket.onPacket (D:\ioBroker\node_modules\iobroker.js-controller\node_modules\engine.io-client\lib\socket.js:450:19) at WS.<anonymous> (D:\ioBroker\node_modules\iobroker
                      fhem.0 2019-02-15 11:29:34.711 error server error
                      fhem.0 2019-02-15 11:29:34.711 error TypeError: Cannot read property 'write' of null at Timeout.setTimeout [as _onTimeout] (D:\ioBroker\node_modules\iobroker.fhem\lib\telnet.js:128:60) at ontimeout (timers.js:436:11) at tryOn
                      fhem.0 2019-02-15 11:29:34.711 error uncaught exception: Cannot read property 'write' of null
                      fhem.0 2019-02-15 11:29:34.695 error uncaught exception: Cannot read property 'split' of undefined
                      fhem.0 2019-02-15 11:29:34.695 info > FUNCTION delete unused objects automatically - info.Configurations.deleteUnusedObjects (true)
                      fhem.0 2019-02-15 11:29:34.695 info > FUNCTION if fhem.0 set smartName automatically (Adapter Cloud) - info.Configurations.autoSmartName (true)
                      fhem.0 2019-02-15 11:29:34.695 info > FUNCTION allow special configurations FHEM - info.Configurations.autoConfigFHEM (true)
                      fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.onlySyncRoomioBroker,ioB_OUT
                      fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.onlySyncNAME
                      fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.ignorePossibleSetsgetConfig,etRegRaw,egBulk,regSet,deviceMsg,CommandAccepted
                      fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.ignoreReadingscurrentTrackPositionSimulated,currentTrackPositionSimulatedSec
                      fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.allowedInternalsTYPE,NAME
                      fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.allowedAttributesroom,alias,comment
                      fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.ignoreObjectsInternalsTYPE
                      fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.ignoreObjectsInternalsNAMEinfo
                      fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.ignoreObjectsAttributesroom
                      fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.allowedIOBin
                      fhem.0 2019-02-15 11:29:34.677 debug [getSetting] info.Configurations.oldState false
                      fhem.0 2019-02-15 11:29:34.677 debug [getSetting] info.Configurations.deleteUnusedObjects true
                      fhem.0 2019-02-15 11:29:34.677 debug [getSetting] info.Configurations.autoSmartName true
                      fhem.0 2019-02-15 11:29:34.676 debug [getSetting] info.Configurations.autoConfigFHEM false
                      fhem.0 2019-02-15 11:29:34.676 debug [getSetting] info.Configurations.autoFunction false
                      fhem.0 2019-02-15 11:29:34.676 debug [getSetting] info.Configurations.autoRole false
                      fhem.0 2019-02-15 11:29:34.676 debug [getConfigurations] start
                      fhem.0 2019-02-15 11:29:34.676 info STEP 03 ===== select function of Adapter (FUNCTION) and Devices to sync (SYNC) - check fhem.0.info.Configurations (true or value)
                      • E Offline
                        Einklaus
                        #246
                        Habe ihn Neu installiert und die autoconfFHEM auf true gesetzt
                        Denke mal so soll es auch sein
                        • LausiDL Offline
                          LausiDL Offline
                          LausiD
                          #247
                          Genau so soll es aussehen :-)
                          Vielleicht kann am WE noch Version 1.2 an den Start gehen
                          Vielen Dank Klaus für deine Mitarbeit
                          LausiD
                          Test FHEM Adapter
                          • E Offline
                            Einklaus
                            schrieb am zuletzt editiert von Einklaus
                            #248
                            Hallo LausiD
                            habe noch folgende Meldung im Log (Debug = Info Meldung) die alle paar Sekunden wieder kommt..
                            event ioBroker "fhem.0.info.Commands.sendFHEM set fhem.0.alive on-for-timer 70" > set fhem.0.alive on-for-timer 70
                            Sieht so aus, als ob das so sein soll (nehme an ein Lebensbit das gesendet wird) .
                            Schreibe es nur sicherheitshalber, falls nicht so sein sollte.
                            Klaus
                            • LausiDL Offline
                              LausiDL Offline
                              LausiD
                              #249
                              Hallo Klaus,
                              vielen Dank für den Hinweis.
                              Stimmt genau was du schreibst, alle 60 Sek wird "set fhem.x.alive on-for-timer 70" an FHEM geschickt.
                              Falls dies ausbleibt wechselt fhem.x.alive spätestens nach 70 Sek auf off.
                              Somit kann in FHEM die Funktion FHEM Adapter/iobroker überwacht werden.
                              Eigentlich kann die Zeit auf 5 Min verlängert werden, oder ?
                              Unter fhem.x.info.Settings können die gewünschten Meldungen mit true/false ausgewählt werden.
                              Keine Meldungen "event ioBroker ......"
                              fhem.0.info.Settings.logEventIOB= false
                              Gruß und Danke
                              LausiD
                              Test FHEM Adapter
                              • LausiDL Offline
                                LausiDL Offline
                                LausiD
                                #250
                                Nabend zusammen,
                                auf github steht Version 1.2.0 zum Testen bereit.
                                Bei entsprechenden Rückmeldungen kann Version in latest übernommen werden.
                                Vielen Dank und Gruß
                                LausiD
                                Test FHEM Adapter
                                • E Offline
                                  Einklaus
                                  #251
                                  Scheint alles i.O. zu sein
                                    Domoe
                                    #252
                                    Moin zusammen,
                                    ich habe ein kleines Problem vielleicht ist es aber auch nur eine Einstellungssache.
                                    Ich habe an Fhem nur EnOcean Geräte. Diese über den Adapter in ioBroker.
                                    Wenn ich ioBroker Neustarte dann reagieren diverse Schalter als ob man selber auf den Schalter gedrückt hat.
                                    Beispiel:
                                    Fernseher an Z-Wave Steckdose.
                                    Enocean Wandschalter.
                                    Beide über ein Blockly Script verbunden.
                                    Wenn der Fernseher an ist und ich ioBroker neu starte geht der Fernseher aus.
                                    Im Logbuch sind keine Fehler zu finden.
                                    Hatte jemand schonmal dieses Problem?
                                    Vielen Dank im voraus.
                                    • LausiDL Offline
                                      LausiDL Offline
                                      LausiD
                                      #253
                                      Hallo ﹰDomoe,
                                      ﹰﹰbei einem ﹰNeustart ioBroker wird natürlich auch der FHEM Adapter neu gestartet.
                                      Dabei werden alle Devices aus FHEM neu eingelesen und die jeweiligen States im ioBroker neu gesetzt.
                                      Vermutlich tritt das Verhalten auch nur bei einem Neustart FHEM Adapter auf, oder?
                                      Daher vermute ich den Fehler eher im Blocky Script.....
                                      LausiD
                                      Test FHEM Adapter
                                        Domoe
                                        #254
                                        Moin Lausi,
                                        ja bis jetzt konnte ich das verhalten nur beim Neustart feststellen.
                                        Ich guck mir meine Scripte nochmal an vielleicht habe ich da ja ein Fehler gemacht.
                                        Danke für deine Antwort
                                        • H Offline
                                          hippoo
                                          #255
                                          Hallo ich habe seit dem Update auf 1.20, alle 60 sek. folgende warning im iobroker:
                                          warn	detect detect: missing "set fhem.0.alive on-for-timer 70" > set manuelly in FHEM or automatically with "fhem.0.info.Configuration.autoConfigFhem" = true | more info README.md
                                          Der room "IoB_System" wird wohl korrekt angelegt in fhem.
                                          Was ist da los?!
