  4. Pimatic Adapter
Pimatic Adapter
26 Beiträge 3 Kommentatoren 3.9k Aufrufe
  • R Offline
    rowoy
    so gerade mal geschaut…
    pimatic.0 2018-09-24 21:03:25.509 info disconnected
    pimatic.0 2018-09-24 21:03:25.502 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
    pimatic.0 2018-09-24 21:03:25.502 error at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.pimatic/node_modules/component-bind/index.js:21:15)
    pimatic.0 2018-09-24 21:03:25.502 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/socket.io-client/lib/manager.js:332:8)
    pimatic.0 2018-09-24 21:03:25.502 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/component-emitter/index.js:133:20)
    pimatic.0 2018-09-24 21:03:25.502 error at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.pimatic/node_modules/component-bind/index.js:21:15)
    pimatic.0 2018-09-24 21:03:25.502 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/socket.io-client/lib/socket.js:228:12)
    pimatic.0 2018-09-24 21:03:25.502 error at Socket.onevent (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/socket.io-client/lib/socket.js:270:10)
    pimatic.0 2018-09-24 21:03:25.502 error at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/component-emitter/index.js:133:20)
    pimatic.0 2018-09-24 21:03:25.502 error at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.pimatic/main.js:510:9)
    pimatic.0 2018-09-24 21:03:25.502 error at syncDevices (/opt/iobroker/node_modules/iobroker.pimatic/main.js:213:87)
    pimatic.0 2018-09-24 21:03:25.502 error TypeError: Cannot read property 'replace' of undefined
    pimatic.0 2018-09-24 21:03:25.502 error uncaught exception: Cannot read property 'replace' of undefined
    pimatic.0 2018-09-24 21:03:25.454 info connected
    pimatic.0 2018-09-24 21:03:22.620 info starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.pimatic, node: v6.14.2
    pimatic.0 2018-09-24 21:02:51.395 info cleaned everything up...
    pimatic.0 2018-09-24 21:02:51.394 info disconnected
    hoffe ihr könnt damit was anfangen.
    wäre echt schön</anonymous></anonymous></anonymous>
    • apollon77A Offline
      Und davor kommt nichts hilfreiches??
      Gesendet vom Handy …
        Ok, scheinbar wird nicht viel geloggt. Habe das auf GitHub mal geändert. Bitte Version von GitHub installieren und im Debug Loglevel laufen lassen. Dann Log senden
        • R Offline
          rowoy
          Was soll ich sagen….. hab die GitHub Version installiert und Läuft auf Anhieb.
          Klasse... Ich danke dir... jetzt kann ich endlich die Rolläden mit einbinden. Supi.
          Schöne Grüße
            ooookkkk … ich hab aber nic geändert ausser Logging eingebaut ... Also scheint da wohl etwas neuer zu sein als zuletzt eReleased ... interessant. Check ich mal
            • R Offline
              rowoy
              ja das hab ich mir dann auch gedacht…. aber soweit steck ich da nicht in der Materie... dachte immer die Adapter werden eh direkt von GitHub gefüttert.... bin jetzt erst mal froh das alles funktioniert wie gewünscht....
              • R Offline
                rowoy
                Hallo…
                ich dann mal wieder, leider scheint der pimatic Adapter doch nicht so richtig zu laufen. Ist jetzt wieder ausgestiegen und läßt sich nicht wieder zum laufen zu bewegen. hier mal der LOG. vielleicht hilft es ja.
                pimatic.0 2018-10-29 19:05:30.933 info cleaned everything up...
                pimatic.0 2018-10-29 19:05:30.933 info disconnected
                pimatic.0 2018-10-29 19:05:30.926 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                pimatic.0 2018-10-29 19:05:30.926 error at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.pimatic/node_modules/component-bind/index.js:21:15)
                pimatic.0 2018-10-29 19:05:30.926 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/socket.io-client/lib/manager.js:332:8)
                pimatic.0 2018-10-29 19:05:30.926 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/component-emitter/index.js:133:20)
                pimatic.0 2018-10-29 19:05:30.926 error at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.pimatic/node_modules/component-bind/index.js:21:15)
                pimatic.0 2018-10-29 19:05:30.926 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/socket.io-client/lib/socket.js:228:12)
                pimatic.0 2018-10-29 19:05:30.926 error at Socket.onevent (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/socket.io-client/lib/socket.js:270:10)
                pimatic.0 2018-10-29 19:05:30.926 error at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/component-emitter/index.js:133:20)
                pimatic.0 2018-10-29 19:05:30.926 error at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.pimatic/main.js:512:9)
                pimatic.0 2018-10-29 19:05:30.926 error at syncDevices (/opt/iobroker/node_modules/iobroker.pimatic/main.js:215:87)
                pimatic.0 2018-10-29 19:05:30.926 error TypeError: Cannot read property 'replace' of undefined
                pimatic.0 2018-10-29 19:05:30.925 error uncaught exception: Cannot read property 'replace' of undefined
                pimatic.0 2018-10-29 19:05:30.837 info connected
                pimatic.0 2018-10-29 19:05:28.931 info starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.pimatic, node: v6.14.2</anonymous></anonymous></anonymous>
                • R Offline
                  rowoy
                  Hallo…
                  nun ist es wieder passiert. Der Pimatic Adapter will nicht mehr. Hier mal das Logfile. Jemand eine Idee?
                  pimatic.1 2019-01-29 23:08:00.791 info disconnected
                  pimatic.1 2019-01-29 23:08:00.781 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                  pimatic.1 2019-01-29 23:08:00.781 error at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.pimatic/node_modules/component-bind/index.js:21:15)
                  pimatic.1 2019-01-29 23:08:00.781 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/socket.io-client/lib/manager.js:332:8)
                  pimatic.1 2019-01-29 23:08:00.781 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/component-emitter/index.js:133:20)
                  pimatic.1 2019-01-29 23:08:00.781 error at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.pimatic/node_modules/component-bind/index.js:21:15)
                  pimatic.1 2019-01-29 23:08:00.781 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/socket.io-client/lib/socket.js:228:12)
                  pimatic.1 2019-01-29 23:08:00.781 error at Socket.onevent (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/socket.io-client/lib/socket.js:270:10)
                  pimatic.1 2019-01-29 23:08:00.781 error at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/component-emitter/index.js:133:20)
                  pimatic.1 2019-01-29 23:08:00.781 error at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.pimatic/main.js:512:9)
                  pimatic.1 2019-01-29 23:08:00.781 error at syncDevices (/opt/iobroker/node_modules/iobroker.pimatic/main.js:215:87)
                  pimatic.1 2019-01-29 23:08:00.781 error TypeError: Cannot read property 'replace' of undefined
                  pimatic.1 2019-01-29 23:08:00.781 error uncaught exception: Cannot read property 'replace' of undefined
                  pimatic.1 2019-01-29 23:08:00.716 info connected
                  pimatic.1 2019-01-29 23:07:59.285 info starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.pimatic, node: v6.14.2
                  pimatic.1 2019-01-29 23:07:55.601 info terminating
                  pimatic.1 2019-01-29 23:07:55.542 info cleaned everything up...
                  pimatic.1 2019-01-29 23:07:29.414 info starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.pimatic, node: v6.14.2
                  pimatic.1 2019-01-29 23:07:25.628 info terminating
                  pimatic.1 2019-01-29 23:07:25.605 info cleaned everything up...
                  pimatic.1 2019-01-29 23:07:11.672 info starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.pimatic, node: v6.14.2
                  Schöne Grüße</anonymous></anonymous></anonymous>
                    Kannst Du es nachvollziehen? Dann schalte mal auf Debug Loglevel und schicke mal das log
                    • R Offline
                      rowoy
                      Moin moin..
                      hoffe ich hab das richtig gemacht…. hier der neue Log. nicht wundern hab das pimatic noch ma neu aufgesetzt... aber das Problem bleibt.
                      pimatic.0 2019-01-30 09:13:33.549 info connected
                      pimatic.0 2019-01-30 09:13:31.820 debug Connect: http://192.168.1.170:80/?username=admin&password=xxx
                      pimatic.0 2019-01-30 09:13:31.819 info starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.pimatic, node: v6.14.2
                      pimatic.0 2019-01-30 09:13:00.387 info terminating
                      pimatic.0 2019-01-30 09:13:00.354 info cleaned everything up...
                      pimatic.0 2019-01-30 09:13:00.353 info disconnected
                      pimatic.0 2019-01-30 09:13:00.343 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                      pimatic.0 2019-01-30 09:13:00.343 error at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.pimatic/node_modules/component-bind/index.js:21:15)
                      pimatic.0 2019-01-30 09:13:00.343 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/socket.io-client/lib/manager.js:332:8)
                      pimatic.0 2019-01-30 09:13:00.343 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/component-emitter/index.js:133:20)
                      pimatic.0 2019-01-30 09:13:00.343 error at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.pimatic/node_modules/component-bind/index.js:21:15)
                      pimatic.0 2019-01-30 09:13:00.343 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/socket.io-client/lib/socket.js:228:12)
                      pimatic.0 2019-01-30 09:13:00.343 error at Socket.onevent (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/socket.io-client/lib/socket.js:270:10)
                      pimatic.0 2019-01-30 09:13:00.343 error at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.pimatic/node_modules/component-emitter/index.js:133:20)
                      pimatic.0 2019-01-30 09:13:00.343 error at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.pimatic/main.js:512:9)
                      pimatic.0 2019-01-30 09:13:00.343 error at syncDevices (/opt/iobroker/node_modules/iobroker.pimatic/main.js:215:87)
                      pimatic.0 2019-01-30 09:13:00.343 error TypeError: Cannot read property 'replace' of undefined
                      pimatic.0 2019-01-30 09:13:00.342 error uncaught exception: Cannot read property 'replace' of undefined
                      pimatic.0 2019-01-30 09:13:00.329 debug Handle Attribute: "temperature"
                      pimatic.0 2019-01-30 09:13:00.329 debug Handle Device: {"id":"dwd-wetter","name":"dwd-Wetter","template":"device","attributes":[],"actions":[],"config":{"station":"Leipzig-Flh., SN","attributes":["temperature","windSpeed","windGust","windD
                      pimatic.0 2019-01-30 09:13:00.328 debug Handle Attribute: {"description":"State of the contact","type":"boolean","labels":["closed","opened"],"label":"Contact","discrete":true,"name":"contact","value":false,"history":[{"t":1548793586056,"v
                      pimatic.0 2019-01-30 09:13:00.328 debug Handle Device: {"id":"dashbutton01","name":"Drainage Button","template":"contact","attributes":[{"description":"State of the contact","type":"boolean","labels":["closed","opened"],"label":"Contact","
                      pimatic.0 2019-01-30 09:13:00.327 debug Handle Attribute: {"description":"The current state of the switch","type":"boolean","labels":["on","off"],"label":"State","discrete":true,"name":"state","value":false,"history":[{"t":1548793585721,"v
                      pimatic.0 2019-01-30 09:13:00.327 debug Handle Device: {"id":"switch-all","name":"Alle Lampen","template":"switch","attributes":[{"description":"The current state of the switch","type":"boolean","labels":["on","off"],"label":"State","discr
                      pimatic.0 2019-01-30 09:13:00.327 debug Handle Attribute: {"description":"Presence of the human/device","type":"boolean","labels":["present","absent"],"label":"Presence","discrete":true,"name":"presence","value":false,"history":[{"t":15487
                      pimatic.0 2019-01-30 09:13:00.327 debug Handle Device: {"id":"eingangstur","name":"Eingangstür","template":"presence","attributes":[{"description":"Presence of the human/device","type":"boolean","labels":["present","absent"],"label":"Prese
                      pimatic.0 2019-01-30 09:13:00.326 debug Handle Attribute: {"description":"Presence of the human/device","type":"boolean","labels":["present","absent"],"label":"Presence","discrete":true,"name":"presence","value":false,"history":[{"t":15487
                      pimatic.0 2019-01-30 09:13:00.326 debug Handle Device: {"id":"terassentur","name":"Terassentür","template":"presence","attributes":[{"description":"Presence of the human/device","type":"boolean","labels":["present","absent"],"label":"Prese
                      pimatic.0 2019-01-30 09:13:00.326 debug Handle Device: {"id":"activities-harmonyHub","name":"MediaCenter - Funktionen","template":"device","attributes":[],"actions":[],"config":{"class":"HarmonyHubActivitiesButtonsDevice","name":"MediaCent
                      pimatic.0 2019-01-30 09:13:00.325 debug Handle Attribute: {"description":"The current state of the switch","type":"boolean","labels":["on","off"],"label":"State","discrete":true,"name":"state","value":false,"history":[{"t":1548793584815,"v
                      pimatic.0 2019-01-30 09:13:00.325 debug Handle Device: {"id":"homesecure","name":"HomeSecure","template":"switch","attributes":[{"description":"The current state of the switch","type":"boolean","labels":["on","off"],"label":"State","discre
                      pimatic.0 2019-01-30 09:13:00.325 debug Handle Device: {"id":"Marantz-SR-4003-Volume","name":"MediaCenter - Volumen","template":"device","attributes":[],"actions":[],"config":{"class":"HarmonyHubButtonsDevice","name":"MediaCenter - Volumen
                      pimatic.0 2019-01-30 09:13:00.324 debug Handle Attribute: {"description":"The current state of the switch","type":"boolean","labels":["on","off"],"label":"State","discrete":true,"name":"state","value":false,"history":[{"t":1548793584436,"v
                      pimatic.0 2019-01-30 09:13:00.323 debug Handle Attribute: {"description":"The current dim level","type":"number","unit":"%","label":"Dimlevel","discrete":false,"name":"dimlevel","value":0,"history":[{"t":1548793584424,"v":5},{"t":154879638
                      pimatic.0 2019-01-30 09:13:00.322 debug Handle Device: {"id":"dimmerswitch001","name":"Schwippbogen","template":"dimmer","attributes":[{"description":"The current dim level","type":"number","unit":"%","label":"Dimlevel","discrete":false,"n
                      pimatic.0 2019-01-30 09:13:00.320 debug Handle Attribute: {"description":"Presence of the human/device","type":"boolean","labels":["present","absent"],"label":"Presence","discrete":true,"name":"presence","value":true,"history":[{"t":154879
                      pimatic.0 2019-01-30 09:13:00.320 debug Handle Device: {"id":"harmonyhubfritzbox","name":"HarmonyHub.fritz.box","template":"presence","attributes":[{"description":"Presence of the human/device","type":"boolean","labels":["present","absent"
                      pimatic.0 2019-01-30 09:13:00.320 debug Handle Attribute: {"description":"Presence of the human/device","type":"boolean","labels":["present","absent"],"label":"Presence","discrete":true,"name":"presence","value":false,"history":[{"t":15487
                      pimatic.0 2019-01-30 09:13:00.319 debug Handle Device: {"id":"homeduino-pir2","name":"Bewegungsmelder Kellertür","template":"presence","attributes":[{"description":"Presence of the human/device","type":"boolean","labels":["present","absent
                      pimatic.0 2019-01-30 09:13:00.319 debug Handle Attribute: {"description":"Presence of the human/device","type":"boolean","labels":["present","absent"],"label":"Presence","discrete":true,"name":"presence","value":false,"history":[{"t":15487
                      pimatic.0 2019-01-30 09:13:00.319 debug Handle Device: {"id":"homeduino-pir","name":"Bewegungsmelder Keller Windows","template":"presence","attributes":[{"description":"Presence of the human/device","type":"boolean","labels":["present","ab
                      pimatic.0 2019-01-30 09:13:00.318 debug Handle Attribute: {"description":"State of the contact","type":"boolean","labels":["closed","opened"],"label":"Contact","discrete":true,"name":"contact","value":true,"history":[{"t":1548793583187,"v"
                      pimatic.0 2019-01-30 09:13:00.318 debug Handle Device: {"id":"FenCon-001","name":"Fenster-Gästezimmer","template":"contact","attributes":[{"description":"State of the contact","type":"boolean","labels":["closed","opened"],"label":"Contact"
                      pimatic.0 2019-01-30 09:13:00.318 debug Handle Attribute: {"description":"The last pressed button","type":"string","label":"Button","discrete":true,"name":"button","value":null,"history":[{"t":1548793582845,"v":null},{"t":1548796386158,"v"
                      pimatic.0 2019-01-30 09:13:00.315 debug Handle Device: {"id":"rolladenT","name":"Terrassenrollo","template":"buttons","attributes":[{"description":"The last pressed button","type":"string","label":"Button","discrete":true,"name":"button","
                      pimatic.0 2019-01-30 09:13:00.315 debug Handle Attribute: {"description":"The last pressed button","type":"string","label":"Button","discrete":true,"name":"button","value":null,"history":[{"t":1548793582397,"v":null},{"t":1548796385785,"v"
                      pimatic.0 2019-01-30 09:13:00.315 debug Handle Device: {"id":"rolladenF","name":"Fensterrollo","template":"buttons","attributes":[{"description":"The last pressed button","type":"string","label":"Button","discrete":true,"name":"button","va
                      pimatic.0 2019-01-30 09:13:00.314 debug Handle Attribute: {"description":"Presence of the human/device","type":"boolean","labels":["present","absent"],"label":"Presence","discrete":true,"name":"presence","value":false,"history":[{"t":15487
                      pimatic.0 2019-01-30 09:13:00.314 debug Handle Device: {"id":"ClaudiaHandy","name":"Claudia Handy","template":"presence","attributes":[{"description":"Presence of the human/device","type":"boolean","labels":["present","absent"],"label":"Pr
                      pimatic.0 2019-01-30 09:13:00.313 debug Handle Attribute: {"description":"Presence of the human/device","type":"boolean","labels":["present","absent"],"label":"Presence","discrete":true,"name":"presence","value":false,"history":[{"t":15487
                      pimatic.0 2019-01-30 09:13:00.313 debug Handle Device: {"id":"RonnyHandy","name":"Ronny Handy","template":"presence","attributes":[{"description":"Presence of the human/device","type":"boolean","labels":["present","absent"],"label":"Presen
                      pimatic.0 2019-01-30 09:13:00.312 debug Handle Attribute: {"description":"Cloudyness","type":"number","unit":"%","acronym":"CLOUDS","label":"Clouds","discrete":false,"name":"clouds","value":0,"history":[{"t":1548809036634,"v":0},{"t":15488</anonymous></anonymous></anonymous>
                        Fast richtig :-) Bitte diezeilen mal aus dem Log auf der Platte rausholen (/opt/iobroker/log/…) ... Admin schneidet leider ab :-(
                        • R Offline
                          rowoy
                          Ok… kann ich aber im Moment nicht machen. Wird erst Heute Abend.
                          Danke bis dahin...
                          • R Offline
                            rowoy
                            so.. versuche jetzt schon eine ganze Weile an den Log File zu kommen….
                            Zur Info.. habe iObroker im Docker auf einer Synology am laufen. ImTerminal sehe ich die Datei. Habe aber kein Plan wie ich die jetzt "greifen" kann um sie hier hochzuladen. :roll:
                            • R Offline
                              rowoy
                              Hallo…
                              hab es heute noch mal versucht. Bekomm die Datein einfach nicht in einen "Normalen" Ordner kopiert. So ein Sch... :roll:
                              Wie wäre denn die perfekte Befehlszeile aus dem Terminal um die Datei *.log in einen Synology Ordner zu kopieren?
                              Schöne Grüße
                              • R Offline
                                rowoy
                                Hallo…
                                es ist soweit. hier die Log Datein mit den Angaben. Hoffe es ist alles dabei.
                                Schöne Grüße
                                5841_log_pimatic.log
                                • R rowoy
                                  Schöne Grüße
                                  arnold
                                  @rowoy
                                  Hallo.
                                  ist schon bisschen Zeit vergangen aber habe das gleiche Problem .
                                  bei mir laufen Pimatic und Iobroker parallel .Pimatik Adapter ist grün alles wird in iobroker Übernomen sonoff, funk- Steckdosen,present ,Wetter alles sogar RMF-R1/UP (Romotoren 24) werden erkannt
                                  ABER nur RMF-R1/UP KANN ICH NICHT SCHALTEN
                                  bist du weiter gekommen ?
