  4. Z Wave Adapter Windows 10
    1.9k
5 Beiträge 2 Kommentatoren 454 Aufrufe
  • P Offline
    Partystoned
    Hallo :)
    Habe folgendes Problem bei der Installation vom Z-Wave Adapter! Kann nur leider absolut nicht nachvollziehen warum es nicht funktioniert?!
    Folgender Fehler wird mir bei der Installation angezeigt!
    $ ./iobroker add zwave –host DESKTOP-2LSE629
    NPM version: 6.4.1
    npm install iobroker.zwave --unsafe-perm --production --save --prefix "C:/iobroker" (System call)
    npm WARN deprecated wrench@1.5.9: wrench.js is deprecated! You should check out fs-extra (https://github.com/jprichardson/node-fs-extra) for any operations you were using wrench for. Thanks for all the usage over the years.npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
    internal/modules/cjs/loader.js:583
    throw err;
    Error: Cannot find module 'C:\WINDOWS\TEMP\ozwinstall-uutov/node_modules/request'
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
    at Function.Module._load (internal/modules/cjs/loader.js:507:25)
    at Module.require (internal/modules/cjs/loader.js:637:17)
    at require (internal/modules/cjs/helpers.js:22:18)
    at Module.module.exports (C:\iobroker\node_modules\iobroker.zwave\node_modules\openzwave-shared\lib\install-ozw.js:165:13)
    at Object. <anonymous>(C:\iobroker\node_modules\iobroker.zwave\node_modules\openzwave-shared\lib\install-ozw.js:220:12)
    at Module._compile (internal/modules/cjs/loader.js:689:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:700:10)
    at Module.load (internal/modules/cjs/loader.js:599:32)
    at tryModuleLoad (internal/modules/cjs/loader.js:538:12)
    C:\iobroker\node_modules\iobroker.zwave\lib\preinstall.js:8
    const isRoot = process.getuid() === 0;
    TypeError: process.getuid is not a function
    at Object. <anonymous>(C:\iobroker\node_modules\iobroker.zwave\lib\preinstall.js:8:24)
    at Function.Module._load (internal/modules/cjs/loader.js:530:3)
    at Function.Module.runMain (internal/modules/cjs/loader.js:742:12)
    at startup (internal/bootstrap/node.js:283:19)
    at bootstrapNodeJSCore (internal/bootstrap/node.js:743:3)
    npm
    ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm
    ERR! openzwave-shared@1.4.6 preinstall: node lib/install-ozw.jsnpm ERR!
    Exit status 1npm ERR!
    npm ERR! Failed at the openzwave-shared@1.4.6 preinstall script.
    npm ERR!
    This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR! C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2019-01-20T08_51_18_123Z-debug.log
    host.DESKTOP-2LSE629 install adapter zwave
    NPM version: 6.4.1
    throw err;
    Error: Cannot find module 'C:\WINDOWS\TEMP\ozwinstall-it9iau/node_modules/request'
    npm
    npm ERR! errno 1
    npm
    ERR! openzwave-shared@1.4.6 preinstall: node lib/install-ozw.jsnpm ERR! Exit status 1
    npm
    ERR! npm ERR! Failed at the openzwave-shared@1.4.6 preinstall script.
    npm
    ERR! A complete log of this run can be found in:npm ERR! C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2019-01-20T08_52_34_444Z-debug.log
    NPM version: 6.4.1
    throw err;
    Error: Cannot find module 'C:\WINDOWS\TEMP\ozwinstall-sk92z/node_modules/request'
    npm
    npm ERR! errno 1
    npm
    npm
    npm ERR! C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2019-01-20T08_53_48_252Z-debug.log
    ERROR: host.DESKTOP-2LSE629 Cannot install zwave
    ERROR: process exited with code 13
    Kann mir dazu jemand was sagen?
    Verzweifel sollangsam <emoji seq="1f602">😂</emoji>
    Gruß Marcel</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
    • apollon77A Offline
      Welche nodejs Version nutzt du?
      Gesendet vom Handy …
      • P Offline
        Partystoned
        Also habe Version:
        Node.js: v10.15.0
        NPM: 6.4.1
        Gruß Marcel
        • P Offline
          Partystoned
          Also warum auch immer ist er nun installiert!
          aber im Log kommt folgender Fehler:
          zwave.0 2019-01-20 11:01:50.555 info List of ports: []
          zwave.0 2019-01-20 11:01:50.555 error Cannot read "/dev": Error: ENOENT: no such file or directory, scandir '/dev'
          zwave.0 2019-01-20 11:01:49.543 info List of ports: []
          zwave.0 2019-01-20 11:01:49.543 error Cannot read "/dev": Error: ENOENT: no such file or directory, scandir '/dev'
          zwave.0 2019-01-20 11:01:48.518 info List of ports: []
          zwave.0 2019-01-20 11:01:48.518 error Cannot read "/dev": Error: ENOENT: no such file or directory, scandir '/dev'
          zwave.0 2019-01-20 11:01:46.517 info List of ports: []
          zwave.0 2019-01-20 11:01:46.517 error Cannot read "/dev": Error: ENOENT: no such file or directory, scandir '/dev'
          zwave.0 2019-01-20 11:01:45.445 info List of ports: []
          zwave.0 2019-01-20 11:01:45.444 error Cannot read "/dev": Error: ENOENT: no such file or directory, scandir '/dev'
          zwave.0 2019-01-20 11:01:44.401 info List of ports: []
          zwave.0 2019-01-20 11:01:44.400 error Cannot read "/dev": Error: ENOENT: no such file or directory, scandir '/dev'
          zwave.0 2019-01-20 11:01:43.357 info List of ports: []
          zwave.0 2019-01-20 11:01:43.357 error Cannot read "/dev": Error: ENOENT: no such file or directory, scandir '/dev'
          zwave.0 2019-01-20 11:01:42.330 info List of ports: []
          zwave.0 2019-01-20 11:01:42.330 error Cannot read "/dev": Error: ENOENT: no such file or directory, scandir '/dev'
          zwave.0 2019-01-20 11:01:41.317 info List of ports: []
          zwave.0 2019-01-20 11:01:41.317 error Cannot read "/dev": Error: ENOENT: no such file or directory, scandir '/dev'
          zwave.0 2019-01-20 11:01:40.302 info List of ports: []
          Desweiteren habe im im Z-Wave Adapter unter !USB Device Name:!° Keine Auswahl Möglichkeit!
          Bringt das jemand weiter!?
          Danke und Gruß
            Mein Gefühl sagt mir: geh mal weg von nodejs 10… node 8 könnte besser laufen. Kenne mich aber zu wenig mit Windows aus als das das fundiert wäre ... ;-)
            Nach einem node Wechsel musst du aber Im iobroker Verzeichnis ein „npm rebuild“ ausführen!
            Gesendet vom Handy ...
