  4. Weboberfläche nicht erreichbar nach Installation
    1.9k
10 Beiträge 3 Kommentatoren 2.4k Aufrufe
    SvenH75
    ich habe iiBrocker nach der Anleitung von BUANET im Synology Docker installiert. Leider ereiche ich nicht die Weboberfläche über IP-der DS:8081…
    Was mache ich den falsch?
    Protokoll :
    ! No instances found for host "buanet-iobroker1".
    ! stdout
    ! 08:21:07
    ! Delete adapter "admin.0"
    ! stdout
    ! 08:21:07
    ! host.buanet-iobroker1 Counted 1 instances of admin
    ! stdout
    ! 08:21:07
    ! host.buanet-iobroker1 Counted 1 channels of admin.0
    ! stdout
    ! 08:21:07
    ! host.buanet-iobroker1 Counted 8 states of admin.0
    ! stdout
    ! 08:21:07
    ! host.buanet-iobroker1 Counted 1 objects of admin.0
    ! stdout
    ! 08:21:07
    ! host.buanet-iobroker1 Deleting 11 object(s).
    ! stdout
    ! 08:21:09
    ! Delete adapter "discovery.0"
    ! stdout
    ! 08:21:09
    ! host.buanet-iobroker1 Counted 1 instances of discovery
    ! stdout
    ! 08:21:09
    ! host.buanet-iobroker1 Counted 13 states of discovery.0
    ! stdout
    ! 08:21:09
    ! host.buanet-iobroker1 Deleting 14 object(s).
    ! stdout
    ! 08:21:12
    ! host.buanet-iobroker1 create instance admin
    ! stdout
    ! 08:21:12
    ! host.buanet-iobroker1 object admin.0 created
    ! stdout
    ! 08:21:12
    ! host.buanet-iobroker1 object admin.0.info created
    ! stdout
    ! 08:21:12
    ! host.buanet-iobroker1 object system.adapter.admin.upload created
    ! stdout
    ! 08:21:12
    ! host.buanet-iobroker1 object system.adapter.admin.0.outputCount created
    ! stdout
    ! 08:21:12
    ! host.buanet-iobroker1 object system.adapter.admin.0.inputCount created
    ! stdout
    ! 08:21:12
    ! host.buanet-iobroker1 object system.adapter.admin.0.uptime created
    ! stdout
    ! 08:21:12
    ! host.buanet-iobroker1 object system.adapter.admin.0.memRss created
    ! stdout
    ! 08:21:12
    ! host.buanet-iobroker1 object system.adapter.admin.0.memHeapTotal created
    ! stdout
    ! 08:21:12
    ! host.buanet-iobroker1 object system.adapter.admin.0.memHeapUsed created
    ! stdout
    ! 08:21:12
    ! host.buanet-iobroker1 object system.adapter.admin.0.connected created
    ! stdout
    ! 08:21:12
    ! host.buanet-iobroker1 object system.adapter.admin.0.alive created
    ! stdout
    ! 08:21:12
    ! host.buanet-iobroker1 object system.adapter.admin.0 created
    ! stdout
    ! 08:21:15
    ! host.buanet-iobroker1 create instance discovery
    ! stdout
    ! 08:21:15
    ! host.buanet-iobroker1 object discovery.0.scanRunning created
    ! stdout
    ! 08:21:15
    ! host.buanet-iobroker1 object discovery.0.devicesFound created
    ! stdout
    ! 08:21:15
    ! host.buanet-iobroker1 object discovery.0.instancesFound created
    ! stdout
    ! 08:21:15
    ! host.buanet-iobroker1 object discovery.0.servicesProgress created
    ! stdout
    ! 08:21:15
    ! host.buanet-iobroker1 object discovery.0.devicesProgress created
    ! stdout
    ! 08:21:15
    ! host.buanet-iobroker1 object system.adapter.discovery.0.outputCount created
    ! stdout
    ! 08:21:15
    ! host.buanet-iobroker1 object system.adapter.discovery.0.inputCount created
    ! stdout
    ! 08:21:15
    ! host.buanet-iobroker1 object system.adapter.discovery.0.uptime created
    ! stdout
    ! 08:21:15
    ! host.buanet-iobroker1 object system.adapter.discovery.0.memRss created
    ! stdout
    ! 08:21:15
    ! host.buanet-iobroker1 object system.adapter.discovery.0.memHeapTotal created
    ! stdout
    ! 08:21:15
    ! host.buanet-iobroker1 object system.adapter.discovery.0.memHeapUsed created
    ! stdout
    ! 08:21:15
    ! host.buanet-iobroker1 object system.adapter.discovery.0.connected created
    ! stdout
    ! 08:21:15
    ! host.buanet-iobroker1 object system.adapter.discovery.0.alive created
    ! stdout
    ! 08:21:15
    ! host.buanet-iobroker1 object system.adapter.discovery.0 created
    ! stdout
    ! 08:21:16
    ! rm: das Entfernen von '/var/run/dbus/pid' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
    ! stdout
    ! 08:21:16
    ! [….] Stopping Avahi mDNS/DNS-SD Daemon: avahi-daemon[ ok .
    ! stdout
    ! 08:21:21
    ! [….] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon[ ok .
    ! stdout
    ! 08:29:56
    ! root@buanet-iobroker1:/opt/iobroker#
    ! stdout
    ! 08:29:56
    ! [….] Stopping Avahi mDNS/DNS-SD Daemon: avahi-daemonProcess 85 died: No such process; trying to remove PID file. (/var/run/avahi-daemon//pid)
    ! stdout
    ! 08:29:56
    ! [ ok .
    ! stdout
    ! 08:30:01
    ! stdout
    ! 08:32:57
    ! root@buanet-iobroker1:/opt/iobroker# ls
    ! stdout
    ! 08:32:57
    ! install iob iobroker iobroker-data killall.sh lib LICENSE log node_modules package.json package-lock.json README.md reinstall.sh
    Prozesse als Dateianhang…..
    Kann da jemand was sehen?
    Vielen Dank
    • apollon77A Offline
      Wie ist das Netzwerk eingerichtet? Ist der Port auch so freigeschaltet das du ihn von außerhalb des Docker erreichen kannst?
      Gesendet vom Handy …
        SvenH75
        Hall, ich habe beim erstellen des Containers angeklickt: "Dasselbe Netzwerk wie Docker Host verwenden".
        Muss ich da noch was anderes Einstellen/Freigeben?
        Hab auch noch mal den Container neu installiert, es sieht ja auch alles gut aus.
        Terminal:
        root@ioBroker:/opt/iobroker#
        root@ioBroker:/opt/iobroker# iobroker list instances
        system.adapter.admin.0 : admin - enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.discovery.0 : discovery - enabled
        Kann die DS 218+ da was blocken?
        • wendy2702W Offline
          wendy2702W Offline
          Mal die IP Adresse des Containers angesehen oder hast du versucht dich mit der Docker IP + Port zu verbinden?
            SvenH75
            Hallo, hat der Container eine eigene? Hatte doch "Dasselbe Netzwerk wie Docker Host verwenden" eingestellt.
            Nein ich versuche mit der IP meiner DS.
              wendy2702W Offline
              Ich frage nur, nutze keinen Docker.
              Sonst Firewall Einstellungen der DS ansehen.
                SvenH75
                Hallo, okay…..schalte ich die Firewall der Synology aus, funktioniert es :-)
                Jetzt müsste ich nur noch wissen, wie ich die Firewall korekt einstelle.
                  wendy2702W Offline
                  Kann man da nicht einzelne Ports oder Anwendungen erlauben?
                    SvenH75
                    Ja, hat geklappt.
                    bin jetzt soweit durch, bist auf das Backup.
                    Bekomme folgende Meldung:
                    Sehr geehrter Benutzer,
                    Aufgabenplaner hat eine geplante Aufgabe abgeschlossen.
                    Aufgabe: ioBroker Backup
                    Startzeit: Sat, 12 Jan 2019 14:18:24 GMT
                    Stoppzeit: Sat, 12 Jan 2019 14:18:24 GMT
                    Aktueller Status: 2 (Unterbrochen)
                    Standardausgabe/Fehler:
                    /volume1/docker/iobroker_backup/backupscript.sh: line 1: {rtf1ansiansicpg1252cocoartf1671cocoasubrtf200: command not found
                    /volume1/docker/iobroker_backup/backupscript.sh: line 2: syntax error near unexpected token `}'
                    /volume1/docker/iobroker_backup/backupscript.sh: line 2: `{\fonttbl\f0\fnil\fcharset0 Menlo-Regular;}'
                    Mit freundlichen Grüßen
                    Synology DiskStation
                    Ich denke es liegt am Programm, habe Datei mit TextEdit unter Mac erstellt und auf .sh umbenannt. Das geht wohl so nicht…..
                    Welches Textprogramm unter Mac muss ich da nehmen? Finde nix...
                    Update:
                    Habe mit dem Skript-Editor unter Mac versucht und bekomme jetzt folgenden Fehler :
                    Startzeit: Sat, 12 Jan 2019 14:38:00 GMT
                    Stoppzeit: Sat, 12 Jan 2019 14:38:00 GMT
                    Aktueller Status: 126 (Unterbrochen)
                    sh: /volume1/docker/iobroker_backup/backupscript.sh: cannot execute binary file: Exec format error
                    Jemand eine Idee?
                      SvenH75
                      Hallo, klappt jetzt….unter mac funktioniert MacVim....
