  4. USV in ioBroker integrieren
17 Beiträge 4 Kommentatoren 3.5k Aufrufe
    Kuddel
    Das Webinterface funktioniert auch schonmal:
    Leider kommen im ioBroker immer noch keine Daten an
    • apollon77A Offline
      Dann fang mal "Low level" an:
      https://github.com/Apollon77/ioBroker.n … leshooting
      bzw was sagt das log vom Adapter wenn Du Debug log einschaltest?
        Kuddel
        nut.0 Log
        nut.0	2018-11-16 10:43:46.415	debug	system.adapter.admin.0: logging true
        nut.0	2018-11-16 10:37:27.478	debug	system.adapter.admin.0: logging false
        nut.0	2018-11-16 10:34:10.393	debug	Set State status.severity = 4
        nut.0	2018-11-16 10:34:10.393	debug	Set State status.shutdown = false
        nut.0	2018-11-16 10:34:10.393	debug	Create State status.shutdown
        nut.0	2018-11-16 10:34:10.393	debug	Set State status.boosting = false
        nut.0	2018-11-16 10:34:10.393	debug	Create State status.boosting
        nut.0	2018-11-16 10:34:10.393	debug	Set State status.trimming = false
        nut.0	2018-11-16 10:34:10.393	debug	Create State status.trimming
        nut.0	2018-11-16 10:34:10.393	debug	Set State status.overload = false
        nut.0	2018-11-16 10:34:10.393	debug	Create State status.overload
        nut.0	2018-11-16 10:34:10.393	debug	Set State status.offline = false
        nut.0	2018-11-16 10:34:10.393	debug	Create State status.offline
        nut.0	2018-11-16 10:34:10.393	debug	Set State status.calibration = false
        nut.0	2018-11-16 10:34:10.393	debug	Create State status.calibration
        nut.0	2018-11-16 10:34:10.393	debug	Set State status.bypass = false
        nut.0	2018-11-16 10:34:10.393	debug	Create State status.bypass
        nut.0	2018-11-16 10:34:10.392	debug	Set State status.discharging = false
        nut.0	2018-11-16 10:34:10.392	debug	Create State status.discharging
        nut.0	2018-11-16 10:34:10.392	debug	Set State status.charging = false
        nut.0	2018-11-16 10:34:10.392	debug	Create State status.charging
        nut.0	2018-11-16 10:34:10.392	debug	Set State status.replacebattery = false
        nut.0	2018-11-16 10:34:10.392	debug	Create State status.replacebattery
        nut.0	2018-11-16 10:34:10.392	debug	Set State status.highbattery = false
        nut.0	2018-11-16 10:34:10.392	debug	Create State status.highbattery
        nut.0	2018-11-16 10:34:10.392	debug	Set State status.lowbattery = false
        nut.0	2018-11-16 10:34:10.392	debug	Create State status.lowbattery
        nut.0	2018-11-16 10:34:10.392	debug	Set State status.onbattery = false
        nut.0	2018-11-16 10:34:10.392	debug	Create State status.onbattery
        nut.0	2018-11-16 10:34:10.392	debug	Set State status.online = false
        nut.0	2018-11-16 10:34:10.392	debug	Create State status.online
        nut.0	2018-11-16 10:34:10.391	debug	NUT Connection closed. Done.
        nut.0	2018-11-16 10:34:10.391	error	Error happend: Error: connect ECONNREFUSED 192.168.4.33:3493
        nut.0	2018-11-16 10:34:10.302	info	starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.nut, node: v8.11.3
        nut.0	2018-11-16 10:34:10.196	debug	statesDB connected
        nut.0	2018-11-16 10:34:10.184	debug	objectDB connected
          Dann bin ich weiter bei: irgendwas verweigert den Zugriff direkt auf Netzwerkebene! Da musst Du schauen was das ist, Sorry
            Kuddel
            Das ist ja eine Abfrage von einer Debian-VM (iobroker) auf eine Ubuntu-VM (Nut-Server).
            Haben die VMs überhaupt Firewalls?
            Muss ich evtl. auf dem ESX Host den Port in der Firewall freigeben ?
            • eric2905E Offline
              eric2905E Offline
              eric2905
              Hast Du ggf. auf der Nut-Serverseite die Konfig nicht sauber und der läßt keine Zugriffe über LAN zu?
              Gruß,
              Eric
              Von unterwegs getippert
              • SegwayS Offline
                SegwayS Offline
                Segway
                @Kuddel:
                Das ist ja eine Abfrage von einer Debian-VM (iobroker) auf eine Ubuntu-VM (Nut-Server). `
                Ich habe es mit einem javascript gemacht und habe auch eine VM.
                Du musst den USB Port durchreichen in deine VM und den service apcusvd installieren / starten.
                Bei Fragen bitte melden.
                Gruß Dirk
                  Kuddel
                  @Segway:
                  @Kuddel:
                  Bei Fragen bitte melden. `
                  Der NUT-Server lief / läuft ja korrekt (siehe miene Screenshots der USV Leistungsdaten oben).
                  Das Problem ist nur die Kommunikation zwischen NUT-Adapter auf ioBroker und dem NUT-Server
                  • SegwayS Offline
                    SegwayS Offline
                    Segway
                    Ich hatte mich gegen den Nut-Adapter entschieden, da ich meine, dass dies nur läuft, wenn er an der VM eingebunden ist, auf der auch iobroker läuft. Bei mir ist aber eine andere VM dafür zuständig um mit der USV zu kommunizieren. sprich da muss man also eine (andere) IP Adresse eingeben um zu kommunizieren. Geht das ? da bin ich überfragt.
                    Daher das Script - war super einfach.
                    Readme:
                    Description of parameters
                    host_ip
                    IP address of the NUT server. NUT needs to run in server mode and needs to be accessible by the computer the
                    iobroker NUT adapter runs on. So check firewall settings if you have problems and allow the access. If the UPS
                    is connected locally you can also use 127.0.0.1 or localhost.
                    host_port
                    Port of NUT. The default port is 3493
                    Demnach schaut er nur auf localhost. Bei einer VM Software sitzt der USB aber am Main Server und jeder andere VM hat eine abweichende IP Adresse. Da bin ich überfragt ob das dann geht.
                    Gruß Dirk
                      Wo liesst Du da das es nur localhost geht, da steht "Nutze 127.0.0.1 wennn dein Nut Server lokal läuft".
                      Installiere Nut-Adapter doch mal dann sieh in die Konfiguration und Deine Frage beantwortet sich aber mal sowas von ganz alleine :-)
                      Na klar kannst Du da eine IP angeben … jede die Du willst
