  4. Problem bei der installation
    6.6k
13 Beiträge 5 Kommentatoren 2.4k Aufrufe
    minim
    Habe die Deutsche Anleitung gefunden. Bei "curl -sL https://raw.githubusercontent.com/ioBro … staller.sh | bash -" bekomme ich aber erneut Errors.
    root@raspberrypi:~# curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/installer.sh | bash -
        Welcome to the ioBroker installer!
        Installer version: 2019-01-02
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
        Creating ioBroker directory (2/5)
        Downloading installation files (3/5)
    > iobroker@1.3.1 install /opt/iobroker/node_modules/iobroker
    > node lib/checkVersions.js
    NPM version: 6.5.0
    > iobroker@1.3.1 postinstall /opt/iobroker/node_modules/iobroker
    > node lib/install.js
    + iobroker@1.3.1
    updated 1 package and audited 165 packages in 9.701s
    found 0 vulnerabilities
        Installing ioBroker (4/5)
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN tar zlib: unexpected end of file
    npm ERR! code Z_BUF_ERROR
    npm ERR! errno -5
    npm ERR! zlib: unexpected end of file
    npm ERR!     /root/.npm/_logs/2019-01-04T21_49_25_672Z-debug.log
        Finalizing installation (5/5)
        ioBroker was installed successfully
        Open http://localhost:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    Das "npm install iobroker" hat funktioniert.
    Aber dann stand dort
     The iobroker files have been downloaded successfully. │
    │ To complete the installation, you need to run         │
    │           npm i --production --unsafe-perm
    Ich habe dann "npm i –production --unsafe-perm" eingegeben, dann kamen wieder Errors.
    Im Log steht:
    8146 silly saveTree │   │   │ ├── pify@2.3.0
    8146 silly saveTree │   │   │ └─┬ strip-bom@2.0.0
    8146 silly saveTree │   │   │   └── is-utf8@0.2.1
    8146 silly saveTree │   │   ├─┬ normalize-package-data@2.4.0
    8146 silly saveTree │   │   │ ├── hosted-git-info@2.7.1
    8146 silly saveTree │   │   │ ├─┬ is-builtin-module@1.0.0
    8146 silly saveTree │   │   │ │ └── builtin-modules@1.1.1
    8146 silly saveTree │   │   │ └─┬ validate-npm-package-license@3.0.4
    8146 silly saveTree │   │   │   ├─┬ spdx-correct@3.1.0
    8146 silly saveTree │   │   │   │ ├─┬ spdx-expression-parse@3.0.0
    8146 silly saveTree │   │   │   │ │ ├── spdx-exceptions@2.2.0
    8146 silly saveTree │   │   │   │ │ └── spdx-license-ids@3.0.3
    8146 silly saveTree │   │   │   │ └── spdx-license-ids@3.0.3
    8146 silly saveTree │   │   │   └── spdx-expression-parse@3.0.0
    8146 silly saveTree │   │   └── path-type@1.1.0
    8146 silly saveTree │   ├── which-module@1.0.0
    8146 silly saveTree │   └── yargs-parser@5.0.0
    8146 silly saveTree ├── semver@5.6.0
    8146 silly saveTree └── yargs@7.1.0
    8147 verbose stack ZlibError: zlib: unexpected end of file
    8147 verbose stack     at Zlib.(anonymous function).onerror (/usr/lib/node_modules/npm/node_modules/minizlib/index.js:131:21)
    8147 verbose stack     at Unzip.write (/usr/lib/node_modules/npm/node_modules/minizlib/index.js:255:31)
    8147 verbose stack     at Unzip.flush (/usr/lib/node_modules/npm/node_modules/minizlib/index.js:222:10)
    8147 verbose stack     at Unzip.end (/usr/lib/node_modules/npm/node_modules/minizlib/index.js:229:10)
    8147 verbose stack     at Unpack.end (/usr/lib/node_modules/npm/node_modules/tar/lib/parse.js:416:21)
    8147 verbose stack     at PassThrough.onend (_stream_readable.js:595:10)
    8147 verbose stack     at Object.onceWrapper (events.js:313:30)
    8147 verbose stack     at emitNone (events.js:111:20)
    8147 verbose stack     at PassThrough.emit (events.js:208:7)
    8147 verbose stack     at endReadableNT (_stream_readable.js:1064:12)
    8147 verbose stack     at _combinedTickCallback (internal/process/next_tick.js:139:11)
    8147 verbose stack     at process._tickCallback (internal/process/next_tick.js:181:9)
    8148 verbose cwd /root
    8149 verbose Linux 4.14.79-v7+
    8150 verbose argv "/usr/bin/node" "/usr/bin/npm" "i" "--production"
    8151 verbose node v8.15.0
    8152 verbose npm  v6.5.0
    8153 error code Z_BUF_ERROR
    8154 error errno -5
    8155 error zlib: unexpected end of file
    8156 verbose exit [ -5, true ]
      Alles gut!
      @minim:
      Open http://localhost:8081 in a browser and start configuring! `
      Aber unbedingt beachten
      @minim:
      You need to re-login before doing anything else on the console! `
        minim
        @Homoran:
        Alles gut!
        @minim:
        Habe schon versucht. Funktioniert nicht.
        ` > Aber unbedingt beachten
        @minim:
        Auch schon versucht. Kein Ergebnis
        • eric2905E Offline
          eric2905E Offline
          eric2905
          @minim:
          @minim:
          Open http://localhost:8081 in a browser and start configuring! Habe schon versucht. Funktioniert nicht.
          Was funktioniert nicht?
          Fehlermeldung?
          Mal localhost durch die IP des Hosts ersetzt?
          Gruß,
          Eric
            minim
            @eric2905:
            Fehlermeldung?
            Mal localhost durch die IP des Hosts ersetzt? `
            Ja habe es mit der IP versucht kein Ergebnis.
            Es gibt Errors:
            npm ERR! errno -5
            Dann im Log steht ganz vieles. Ganz unten gibt es paar Errormeldungen:
            8163 silly saveTree │   │   │   └── spdx-expression-parse@3.0.0
            8163 silly saveTree │   │   └── path-type@1.1.0
            8163 silly saveTree │   ├── which-module@1.0.0
            8163 silly saveTree │   └── yargs-parser@5.0.0
            8163 silly saveTree ├── semver@5.6.0
            8163 silly saveTree └── yargs@7.1.0
            8164 verbose stack ZlibError: zlib: unexpected end of file
            8164 verbose stack     at Zlib.(anonymous function).onerror (/usr/lib/node_modules/npm/node_modules/minizlib/index.js:131:21)
            8164 verbose stack     at Unzip.write (/usr/lib/node_modules/npm/node_modules/minizlib/index.js:255:31)
            8164 verbose stack     at Unzip.flush (/usr/lib/node_modules/npm/node_modules/minizlib/index.js:222:10)
            8164 verbose stack     at Unzip.end (/usr/lib/node_modules/npm/node_modules/minizlib/index.js:229:10)
            8164 verbose stack     at Unpack.end (/usr/lib/node_modules/npm/node_modules/tar/lib/parse.js:416:21)
            8164 verbose stack     at PassThrough.onend (_stream_readable.js:595:10)
            8164 verbose stack     at Object.onceWrapper (events.js:313:30)
            8164 verbose stack     at emitNone (events.js:111:20)
            8164 verbose stack     at PassThrough.emit (events.js:208:7)
            8164 verbose stack     at endReadableNT (_stream_readable.js:1064:12)
            8164 verbose stack     at _combinedTickCallback (internal/process/next_tick.js:139:11)
            8164 verbose stack     at process._tickCallback (internal/process/next_tick.js:181:9)
            8165 verbose cwd /opt/iobroker
            8166 verbose Linux 4.14.79-v7+
            8167 verbose argv "/usr/bin/node" "/usr/bin/npm" "i" "--production" "--unsafe-perm"
            8168 verbose node v8.15.0
            8169 verbose npm  v6.5.0
            8170 error code Z_BUF_ERROR
            8171 error errno -5
            8172 error zlib: unexpected end of file
            8173 verbose exit [ -5, true ]
            • apollon77A Offline
              Funktioniert dein Netzwerk vollständig? Es scheint als ob er Probeme hat Files vollständig runterzuladen.
              Unexpected End of Fule heisst das da irgendwas unvollständig ist
                minim
                @apollon77:
                Unexpected End of Fule heisst das da irgendwas unvollständig ist `
                Ja, mein Netzwerk funktioniert vollständig. Ich pinge auch schon seit beginn den Raspberry Pi es gibt keine aussetzter. Internet ist auch vorhanden.
                Kann das am Server von ioBroker liegen? –> Guck dir mal den Beitrag an: viewtopic.php?f=8&t=20389
                  Die ganzen Pakete werden von npmjs.org geladen, hat nichts mit dem iobroker Rechner zu tun. Vllt hatten die Probleme, wäre aber ein blöder Zufall
                    Versuch mal npm cache clean und neu :-)
                      minim
                      @apollon77:
                      Versuch mal npm cache clean und neu :-) `
                      Habe ich:
                      root@raspberrypi:~# npm cache clean
                      npm ERR! As of npm@5, the npm cache self-heals from corruption issues and data extracted from the cache is guaranteed to be valid. If you want to make sure everything is consistent, use 'npm cache verify' instead. On the other hand, if you're debugging an issue with the installer, you can use `npm install --cache /tmp/empty-cache` to use a temporary cache instead of nuking the actual one.
                      npm ERR!
                      npm ERR! If you're sure you want to delete the entire cache, rerun this command with --force.
                      npm ERR!     /root/.npm/_logs/2019-01-04T22_53_55_499Z-debug.log
                      Danach erneut:
                      NPM version: 6.5.0
                      > node lib/install.js
                      + iobroker@1.3.1
                      updated 1 package and audited 165 packages in 9.158s
                      npm ERR! errno -5
                      npm ERR!     /root/.npm/_logs/2019-01-04T22_55_44_775Z-debug.log
                      • StabilostickS Offline
                        Stabilostick
                        Wenn Du Dein Log durchsiehst, dann erkennst Du, dass da noch was fehlt:
                        npm cache clean --force
                        könnte helfen.
