  4. Fehler Meldungen immer zu
    6.4k
17 Beiträge 3 Kommentatoren 1.5k Aufrufe
  • I Offline
    I Offline
    iKlaus
    Zigbee adapter 0.7.7
    Alexa2 1.1.3
    undefined2018-11-27 19:35:00.032 - info: host.ubuntubroker instance system.adapter.tankerkoenig.0 started with pid 2114
    2018-11-27 19:35:01.599 - info: tankerkoenig.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.14.1
    2018-11-27 19:35:02.146 - info: host.ubuntubroker instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
    2018-11-27 19:40:00.033 - info: host.ubuntubroker instance system.adapter.tankerkoenig.0 started with pid 2176
    2018-11-27 19:40:01.579 - info: tankerkoenig.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.14.1
    2018-11-27 19:40:02.129 - info: host.ubuntubroker instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
    2018-11-27 19:45:00.031 - info: host.ubuntubroker instance system.adapter.tankerkoenig.0 started with pid 2202
    2018-11-27 19:45:01.574 - info: tankerkoenig.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.14.1
    2018-11-27 19:45:02.117 - info: host.ubuntubroker instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
    2018-11-27 19:47:51.792 - warn: broadlink2.0 Device RM:Broadlink-Buero not reachable
    2018-11-27 19:50:00.035 - info: host.ubuntubroker instance system.adapter.tankerkoenig.0 started with pid 2229
    2018-11-27 19:50:01.564 - info: tankerkoenig.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.14.1
    2018-11-27 19:50:02.110 - info: host.ubuntubroker instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
    2018-11-27 19:54:11.364 - info: iobroker add link --host ubuntubroker
    2018-11-27 19:54:13.581 - info: iobroker NPM version: 3.10.10
    2018-11-27 19:54:14.125 - info: iobroker npm install iobroker.link --production --save --prefix "/opt/iobroker" (System call)
    2018-11-27 19:55:00.026 - info: host.ubuntubroker instance system.adapter.tankerkoenig.0 started with pid 2287
    2018-11-27 19:55:01.560 - info: tankerkoenig.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.14.1
    2018-11-27 19:55:02.098 - info: host.ubuntubroker instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
    2018-11-27 19:55:20.467 - info: iobroker npm
    2018-11-27 19:55:20.468 - info: iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.ble/node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
    2018-11-27 19:55:20.576 - info: iobroker host.ubuntubroker install adapter link
    2018-11-27 19:55:20.593 - info: iobroker got /opt/iobroker/node_modules/iobroker.link/admin
    2018-11-27 19:55:20.621 - info: iobroker upload [2] link.admin /opt/iobroker/node_modules/iobroker.link/admin/words.js words.js application/javascript
    2018-11-27 19:55:20.705 - info: iobroker upload [1] link.admin /opt/iobroker/node_modules/iobroker.link/admin/link.png link.png image/png
    2018-11-27 19:55:20.771 - info: iobroker upload [0] link.admin /opt/iobroker/node_modules/iobroker.link/admin/index_m.html index_m.html text/html
    2018-11-27 19:55:20.854 - info: yahka.0 objectChange system.adapter.link.upload {"_id":"system.adapter.link.upload","type":"state","common":{"name":"link.upload","type":"number","role":"indicator.state","unit":"%","def":0,"desc":"Upload process indicator"},"from":"system.host.ubuntubroker.cli","ts":1543348520843,"native":{},"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2018-11-27 19:55:20.958 - info: yahka.0 objectChange system.adapter.link {"_id":"system.adapter.link","type":"adapter","common":{"name":"link","title":"Link VPN","desc":{"en":"Create VPN connection via ioBroker","de":"Erstellen Sie eine VPN-Verbindung über ioBroker","ru":"Создание VPN-соединения через ioBroker","pt":"Crie uma conexão VPN via ioBroker","nl":"Maak een VPN-verbinding via ioBroker","fr":"Créer une connexion VPN via ioBroker","it":"Crea una connessione VPN tramite ioBroker","es":"Crear una conexión VPN a través de ioBroker"},"version":"0.3.7","news":{"0.3.7":{"en":"No connection to the cloud if no configuration defined","de":"Keine Verbindung zur Cloud, wenn keine Konfiguration definiert ist","ru":"Нет соединения с облаком, если конфигурация не определена","pt":"Nenhuma conexão com a nuvem se nenhuma configuração definida","nl":"Geen verbinding met de cloud als geen configuratie is gedefinieerd","fr":"Aucune connexion au cloud si aucune configuration définie","it":"Nessuna connessione al cloud se non è stata definita alcuna configurazione","es":"Sin conexión a la nube si no se definió ninguna configuración","pl":"Brak połączenia z chmurą, jeśli nie zdefiniowano żadnej konfiguracji"},"0.3.6":{"en":"The download of SSF from github depending on platform was added","de":"Der Download von SSF von Github je nach Plattform wurde hinzugefügt","ru":"Добавлена ​​загрузка SSF из github в зависимости от платформы.","pt":"O download do SSF do github, dependendo da plataforma, foi adicionado","nl":"De download van SSF van github, afhankelijk van het platform, is toegevoegd","fr":"Le téléchargement de SSF de github en fonction de la plate-forme a été ajouté","it":"È stato aggiunto il download di SSF da github a seconda della piattaforma","es":"Se agregó la descarga de SSF desde github según la plataforma","pl":"Pobieranie SSF z github w zależności od platformy zostało dodane"},"0.2.7":{"en":"UDP communication is now supported","de":"UDP-Kommunikation wird jetzt unterstützt","ru":"Теперь поддерживается связь UDP","pt":"A comunicação UDP é agora suportada","nl":"UDP-communicatie wordt nu ondersteund","fr":"La communication UDP est maintenant supportée","it":"La comunicazione UDP è ora supportata","es":"La comunicación UDP ahora es compatible","pl":"Komunikacja UDP jest teraz obsługiwana"},"0.2.6":{"en":"Added support of HTTP proxy ","de":"Unterstützung von HTTP-Proxy hinzugefügt","ru":"Добавлена ​​поддержка HTTP-прокси","pt":"Adicionado suporte de proxy HTTP","nl":"Ondersteuning van HTTP-proxy toegevoegd","fr":"Ajout du support du proxy HTTP","it":"Aggiunto supporto del proxy HTTP","es":"Se agregó soporte de proxy HTTP","pl":"Dodano obsługę proxy HTTP"},"0.1.3":{"en":"Initial commit","de":"Erstes Commit","ru":"Начальное коммит","pt":"Compromisso inicial","nl":"Eerste commit","fr":"Engagement initial","it":"Commit iniziale","es":"Compromiso inicial"}},"mode":"daemon","platform":"Javascript/Node.js","loglevel":"info","keywords":["vpn","link","remote access"],"main":"main.js","enabled":true,"authors":["gh-god","Bluefox "],"materialize":true,"license":"CC-BY-NC-4.0","readme":"https://github.com/ioBroker/ioBroker.link/blob/master/README.md","icon":"link.png","extIcon":"https://raw.githubusercontent.com/ioBroker/ioBroker.link/master/admin/link.png","type":"communication","dependencies":[{"js-controller":">=1.2.3"}],"stopTimeout":10000,"installedVersion":"0.3.7"},"native":{"name":"","accessServerURI":"https://iobroker.link","accessServerPollInterval":10,"allowedUsers":[],"proxyURI":"","devices":[{"enabled":true,"name":"ioBroker Admin","host":"localhost","protocol":"TCP","port":8081},{"enabled":true,"name":"ioBroker Web","host":"localhost","protocol":"TCP","port":8082}]},"from":"system.host.ubuntubroker.cli","ts":1543348520937,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2018-11-27 19:55:20.960 - info: iobroker host.ubuntubroker object system.adapter.link created
    2018-11-27 19:55:20.985 - info: iobroker host.ubuntubroker create instance link
    2018-11-27 19:55:20.991 - info: iobroker host.ubuntubroker object link.0.info.status created
    2018-11-27 19:55:21.023 - info: iobroker host.ubuntubroker object link.0.info.connection created
    2018-11-27 19:55:21.053 - info: iobroker host.ubuntubroker object link.0.info created
    2018-11-27 19:55:21.086 - info: iobroker host.ubuntubroker object system.adapter.link.0.outputCount created
    2018-11-27 19:55:21.087 - info: yahka.0 objectChange system.adapter.link.0.outputCount {"_id":"system.adapter.link.0.outputCount","type":"state","common":{"name":"ubuntubroker outputs level","desc":"State's outputs in 15 seconds","type":"number","read":true,"write":false,"role":"state","unit":"events/15 seconds"},"native":{},"from":"system.host.ubuntubroker.cli","ts":1543348521079,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2018-11-27 19:55:21.117 - info: yahka.0 objectChange system.adapter.link.0.inputCount {"_id":"system.adapter.link.0.inputCount","type":"state","common":{"name":"ubuntubroker - inputs level","desc":"State's inputs in 15 seconds","type":"number","read":true,"write":false,"role":"state","unit":"events/15 seconds"},"native":{},"from":"system.host.ubuntubroker.cli","ts":1543348521112,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2018-11-27 19:55:21.119 - info: iobroker host.ubuntubroker object system.adapter.link.0.inputCount created
    2018-11-27 19:55:21.151 - info: yahka.0 objectChange system.adapter.link.0.uptime {"_id":"system.adapter.link.0.uptime","type":"state","common":{"name":"link.0.uptime","type":"number","read":true,"write":false,"role":"indicator.state","unit":"seconds"},"native":{},"from":"system.host.ubuntubroker.cli","ts":1543348521144,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2018-11-27 19:55:21.152 - info: iobroker host.ubuntubroker object system.adapter.link.0.uptime created
    2018-11-27 19:55:21.183 - info: yahka.0 objectChange system.adapter.link.0.memRss {"_id":"system.adapter.link.0.memRss","type":"state","common":{"name":"link.0.memRss","desc":"Resident set size","read":true,"write":false,"type":"number","role":"indicator.state","unit":"MB"},"native":{},"from":"system.host.ubuntubroker.cli","ts":1543348521177,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2018-11-27 19:55:21.183 - info: iobroker host.ubuntubroker object system.adapter.link.0.memRss created
    2018-11-27 19:55:21.216 - info: iobroker host.ubuntubroker object system.adapter.link.0.memHeapTotal created
    2018-11-27 19:55:21.217 - info: yahka.0 objectChange system.adapter.link.0.memHeapTotal {"_id":"system.adapter.link.0.memHeapTotal","type":"state","common":{"name":"link.0.memHeapTotal","read":true,"write":false,"type":"number","role":"indicator.state","unit":"MB"},"native":{},"from":"system.host.ubuntubroker.cli","ts":1543348521209,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2018-11-27 19:55:21.249 - info: yahka.0 objectChange system.adapter.link.0.memHeapUsed {"_id":"system.adapter.link.0.memHeapUsed","type":"state","common":{"name":"link.0.memHeapUsed","type":"number","read":true,"write":false,"role":"indicator.state","unit":"MB"},"native":{},"from":"system.host.ubuntubroker.cli","ts":1543348521242,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2018-11-27 19:55:21.252 - info: iobroker host.ubuntubroker object system.adapter.link.0.memHeapUsed created
    2018-11-27 19:55:21.283 - info: iobroker host.ubuntubroker object system.adapter.link.0.connected created
    2018-11-27 19:55:21.284 - info: yahka.0 objectChange system.adapter.link.0.connected {"_id":"system.adapter.link.0.connected","type":"state","common":{"name":"link.0.connected","type":"boolean","read":true,"write":false,"role":"indicator.state"},"native":{},"from":"system.host.ubuntubroker.cli","ts":1543348521276,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2018-11-27 19:55:21.314 - info: yahka.0 objectChange system.adapter.link.0.alive {"_id":"system.adapter.link.0.alive","type":"state","common":{"name":"link.0.alive","type":"boolean","read":true,"write":true,"role":"indicator.state"},"native":{},"from":"system.host.ubuntubroker.cli","ts":1543348521309,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2018-11-27 19:55:21.315 - info: iobroker host.ubuntubroker object system.adapter.link.0.alive created
    2018-11-27 19:55:21.350 - info: host.ubuntubroker object change system.adapter.link.0
    2018-11-27 19:55:21.370 - info: host.ubuntubroker instance system.adapter.link.0 started with pid 2316
    2018-11-27 19:55:21.375 - info: iobroker host.ubuntubroker object system.adapter.link.0 created
    2018-11-27 19:55:21.380 - info: yahka.0 objectChange system.adapter.link.0 {"_id":"system.adapter.link.0","type":"instance","common":{"name":"link","title":"Link VPN","desc":{"en":"Create VPN connection via ioBroker","de":"Erstellen Sie eine VPN-Verbindung über ioBroker","ru":"Создание VPN-соединения через ioBroker","pt":"Crie uma conexão VPN via ioBroker","nl":"Maak een VPN-verbinding via ioBroker","fr":"Créer une connexion VPN via ioBroker","it":"Crea una connessione VPN tramite ioBroker","es":"Crear una conexión VPN a través de ioBroker"},"version":"0.3.7","news":{"0.3.7":{"en":"No connection to the cloud if no configuration defined","de":"Keine Verbindung zur Cloud, wenn keine Konfiguration definiert ist","ru":"Нет соединения с облаком, если конфигурация не определена","pt":"Nenhuma conexão com a nuvem se nenhuma configuração definida","nl":"Geen verbinding met de cloud als geen configuratie is gedefinieerd","fr":"Aucune connexion au cloud si aucune configuration définie","it":"Nessuna connessione al cloud se non è stata definita alcuna configurazione","es":"Sin conexión a la nube si no se definió ninguna configuración","pl":"Brak połączenia z chmurą, jeśli nie zdefiniowano żadnej konfiguracji"},"0.3.6":{"en":"The download of SSF from github depending on platform was added","de":"Der Download von SSF von Github je nach Plattform wurde hinzugefügt","ru":"Добавлена ​​загрузка SSF из github в зависимости от платформы.","pt":"O download do SSF do github, dependendo da plataforma, foi adicionado","nl":"De download van SSF van github, afhankelijk van het platform, is toegevoegd","fr":"Le téléchargement de SSF de github en fonction de la plate-forme a été ajouté","it":"È stato aggiunto il download di SSF da github a seconda della piattaforma","es":"Se agregó la descarga de SSF desde github según la plataforma","pl":"Pobieranie SSF z github w zależności od platformy zostało dodane"},"0.2.7":{"en":"UDP communication is now supported","de":"UDP-Kommunikation wird jetzt unterstützt","ru":"Теперь поддерживается связь UDP","pt":"A comunicação UDP é agora suportada","nl":"UDP-communicatie wordt nu ondersteund","fr":"La communication UDP est maintenant supportée","it":"La comunicazione UDP è ora supportata","es":"La comunicación UDP ahora es compatible","pl":"Komunikacja UDP jest teraz obsługiwana"},"0.2.6":{"en":"Added support of HTTP proxy ","de":"Unterstützung von HTTP-Proxy hinzugefügt","ru":"Добавлена ​​поддержка HTTP-прокси","pt":"Adicionado suporte de proxy HTTP","nl":"Ondersteuning van HTTP-proxy toegevoegd","fr":"Ajout du support du proxy HTTP","it":"Aggiunto supporto del proxy HTTP","es":"Se agregó soporte de proxy HTTP","pl":"Dodano obsługę proxy HTTP"},"0.1.3":{"en":"Initial commit","de":"Erstes Commit","ru":"Начальное коммит","pt":"Compromisso inicial","nl":"Eerste commit","fr":"Engagement initial","it":"Commit iniziale","es":"Compromiso inicial"}},"mode":"daemon","platform":"Javascript/Node.js","loglevel":"info","keywords":["vpn","link","remote access"],"main":"main.js","enabled":true,"authors":["gh-god","Bluefox "],"materialize":true,"license":"CC-BY-NC-4.0","readme":"https://github.com/ioBroker/ioBroker.link/blob/master/README.md","icon":"link.png","extIcon":"https://raw.githubusercontent.com/ioBroker/ioBroker.link/master/admin/link.png","type":"communication","dependencies":[{"js-controller":">=1.2.3"}],"stopTimeout":10000,"installedVersion":"0.3.7","host":"ubuntubroker"},"native":{"name":"","accessServerURI":"https://iobroker.link","accessServerPollInterval":10,"allowedUsers":[],"proxyURI":"","devices":[{"enabled":true,"name":"ioBroker Admin","host":"localhost","protocol":"TCP","port":8081},{"enabled":true,"name":"ioBroker Web","host":"localhost","protocol":"TCP","port":8082}]},"from":"system.host.ubuntubroker.cli","ts":1543348521342,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2018-11-27 19:55:21.385 - info: iobroker exit 0
    2018-11-27 19:55:21.616 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.link/main.js:1
    2018-11-27 19:55:21.616 - error: Caught by controller[0]: (function (exports, require, module, __filename, __dirname) { var _0x7c94=['enabled','undefined','object','Connected\x20to\x20','Disconnected\x20to\x20','Cannot\x20find\x20module\x20\x27','code','MODULE_NOT_FOUND','call','exports','function','./helpers/cert-helper.js','jwt-simple','node-rsa','util','EventEmitter','https-proxy-agent','./handler/ssh-proxy','log','error','warn','destroy','accessServerURI','api/brokers','/requests','Close\x20connection:\x20','info','Close\x20connection','/error','post','Bearer\x20','emit','get','AccessClient:\x20error\x20getting\x20connection\x20request\x20info:\x20','parse','status','CLOSED','accessServerPollInterval','AccessClient:\x20error\x20getting\x20connection\x20requests:\x20','statusMessage','statusCode','AccessClient:\x20Cannot\x20parse\x20answer\x20from\x20server:\x20','length','filter','REQUESTED','assign','AccessClient:\x20setting\x20up\x20reverse\x20proxy','setupTunnel','debug','AccessClient:\x20accepting\x20conne
    2018-11-27 19:55:21.616 - error: Caught by controller[0]: SyntaxError: missing ) after argument list
    2018-11-27 19:55:21.616 - error: Caught by controller[0]: at createScript (vm.js:56:10)
    2018-11-27 19:55:21.616 - error: Caught by controller[0]: at Object.runInThisContext (vm.js:97:10)
    2018-11-27 19:55:21.616 - error: Caught by controller[0]: at Module._compile (module.js:549:28)
    2018-11-27 19:55:21.616 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
    2018-11-27 19:55:21.616 - error: Caught by controller[0]: at Module.load (module.js:494:32)
    2018-11-27 19:55:21.616 - error: Caught by controller[0]: at tryModuleLoad (module.js:453:12)
    2018-11-27 19:55:21.617 - error: Caught by controller[0]: at Function.Module._load (module.js:445:3)
    2018-11-27 19:55:21.617 - error: Caught by controller[0]: at Module.runMain (module.js:611:10)
    2018-11-27 19:55:21.617 - error: Caught by controller[0]: at run (bootstrap_node.js:387:7)
    2018-11-27 19:55:21.617 - error: Caught by controller[0]: at startup (bootstrap_node.js:153:9)
    2018-11-27 19:55:21.617 - error: host.ubuntubroker instance system.adapter.link.0 terminated with code 1 ()
    2018-11-27 19:55:21.617 - info: host.ubuntubroker Restart adapter system.adapter.link.0 because enabled
    2018-11-27 19:55:51.629 - info: host.ubuntubroker instance system.adapter.link.0 started with pid 2323
    2018-11-27 19:55:51.791 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.link/main.js:1
    2018-11-27 19:55:51.791 - error: Caught by controller[0]: (function (exports, require, module, __filename, __dirname) { var _0x7c94=['enabled','undefined','object','Connected\x20to\x20','Disconnected\x20to\x20','Cannot\x20find\x20module\x20\x27','code','MODULE_NOT_FOUND','call','exports','function','./helpers/cert-helper.js','jwt-simple','node-rsa','util','EventEmitter','https-proxy-agent','./handler/ssh-proxy','log','error','warn','destroy','accessServerURI','api/brokers','/requests','Close\x20connection:\x20','info','Close\x20connection','/error','post','Bearer\x20','emit','get','AccessClient:\x20error\x20getting\x20connection\x20request\x20info:\x20','parse','status','CLOSED','accessServerPollInterval','AccessClient:\x20error\x20getting\x20connection\x20requests:\x20','statusMessage','statusCode','AccessClient:\x20Cannot\x20parse\x20answer\x20from\x20server:\x20','length','filter','REQUESTED','assign','AccessClient:\x20setting\x20up\x20reverse\x20proxy','setupTunnel','debug','AccessClient:\x20accepting\x20conne
    2018-11-27 19:55:51.792 - error: Caught by controller[0]: SyntaxError: missing ) after argument list
    2018-11-27 19:55:51.792 - error: Caught by controller[0]: at createScript (vm.js:56:10)
    2018-11-27 19:55:51.792 - error: Caught by controller[0]: at Object.runInThisContext (vm.js:97:10)
    2018-11-27 19:55:51.792 - error: Caught by controller[0]: at Module._compile (module.js:549:28)
    2018-11-27 19:55:51.792 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
    2018-11-27 19:55:51.792 - error: Caught by controller[0]: at Module.load (module.js:494:32)
    2018-11-27 19:55:51.793 - error: Caught by controller[0]: at tryModuleLoad (module.js:453:12)
    2018-11-27 19:55:51.793 - error: Caught by controller[0]: at Function.Module._load (module.js:445:3)
    2018-11-27 19:55:51.793 - error: Caught by controller[0]: at Module.runMain (module.js:611:10)
    2018-11-27 19:55:51.793 - error: Caught by controller[0]: at run (bootstrap_node.js:387:7)
    2018-11-27 19:55:51.793 - error: Caught by controller[0]: at startup (bootstrap_node.js:153:9)
    2018-11-27 19:55:51.793 - error: host.ubuntubroker instance system.adapter.link.0 terminated with code 1 ()
    2018-11-27 19:55:51.793 - info: host.ubuntubroker Restart adapter system.adapter.link.0 because enabled
    2018-11-27 19:56:21.811 - info: host.ubuntubroker instance system.adapter.link.0 started with pid 2331
    2018-11-27 19:56:21.978 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.link/main.js:1
    2018-11-27 19:56:21.979 - error: Caught by controller[0]: (function (exports, require, module, __filename, __dirname) { var _0x7c94=['enabled','undefined','object','Connected\x20to\x20','Disconnected\x20to\x20','Cannot\x20find\x20module\x20\x27','code','MODULE_NOT_FOUND','call','exports','function','./helpers/cert-helper.js','jwt-simple','node-rsa','util','EventEmitter','https-proxy-agent','./handler/ssh-proxy','log','error','warn','destroy','accessServerURI','api/brokers','/requests','Close\x20connection:\x20','info','Close\x20connection','/error','post','Bearer\x20','emit','get','AccessClient:\x20error\x20getting\x20connection\x20request\x20info:\x20','parse','status','CLOSED','accessServerPollInterval','AccessClient:\x20error\x20getting\x20connection\x20requests:\x20','statusMessage','statusCode','AccessClient:\x20Cannot\x20parse\x20answer\x20from\x20server:\x20','length','filter','REQUESTED','assign','AccessClient:\x20setting\x20up\x20reverse\x20proxy','setupTunnel','debug','AccessClient:\x20accepting\x20conne
    2018-11-27 19:56:21.979 - error: Caught by controller[0]: SyntaxError: missing ) after argument list
    2018-11-27 19:56:21.979 - error: Caught by controller[0]: at createScript (vm.js:56:10)
    2018-11-27 19:56:21.979 - error: Caught by controller[0]: at Object.runInThisContext (vm.js:97:10)
    2018-11-27 19:56:21.979 - error: Caught by controller[0]: at Module._compile (module.js:549:28)
    2018-11-27 19:56:21.980 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
    2018-11-27 19:56:21.980 - error: Caught by controller[0]: at Module.load (module.js:494:32)
    2018-11-27 19:56:21.980 - error: Caught by controller[0]: at tryModuleLoad (module.js:453:12)
    2018-11-27 19:56:21.980 - error: Caught by controller[0]: at Function.Module._load (module.js:445:3)
    2018-11-27 19:56:21.980 - error: Caught by controller[0]: at Module.runMain (module.js:611:10)
    2018-11-27 19:56:21.980 - error: Caught by controller[0]: at run (bootstrap_node.js:387:7)
    2018-11-27 19:56:21.980 - error: Caught by controller[0]: at startup (bootstrap_node.js:153:9)
    2018-11-27 19:56:21.981 - error: host.ubuntubroker instance system.adapter.link.0 terminated with code 1 ()
    2018-11-27 19:56:21.981 - info: host.ubuntubroker Restart adapter system.adapter.link.0 because enabled
    2018-11-27 19:56:36.885 - info: iobroker del ble.0
    2018-11-27 19:56:37.562 - info: iobroker Delete adapter "ble.0"
    2018-11-27 19:56:37.601 - info: iobroker host.ubuntubroker Counted 1 instances of ble
    2018-11-27 19:56:37.664 - info: iobroker host.ubuntubroker Counted 1 channels of ble.0
    2018-11-27 19:56:37.875 - info: iobroker host.ubuntubroker Counted 10 states of ble.0
    2018-11-27 19:56:37.892 - info: iobroker host.ubuntubroker Counted 1 states (io.ble.0.*) from states
    2018-11-27 19:56:37.908 - info: iobroker host.ubuntubroker Counted 8 states (system.adapter.ble.0.*) from states
    2018-11-27 19:56:39.481 - info: iobroker host.ubuntubroker Deleting 12 object(s).
    2018-11-27 19:56:39.489 - info: yahka.0 objectChange system.adapter.ble.0.alive null
    2018-11-27 19:56:39.496 - info: yahka.0 objectChange system.adapter.ble.0.connected null
    2018-11-27 19:56:39.504 - info: yahka.0 objectChange system.adapter.ble.0.memHeapUsed null
    2018-11-27 19:56:39.509 - info: yahka.0 objectChange system.adapter.ble.0.memHeapTotal null
    2018-11-27 19:56:39.513 - info: yahka.0 objectChange system.adapter.ble.0.memRss null
    2018-11-27 19:56:39.521 - info: yahka.0 objectChange system.adapter.ble.0.uptime null
    2018-11-27 19:56:39.525 - info: yahka.0 objectChange system.adapter.ble.0.inputCount null
    2018-11-27 19:56:39.531 - info: yahka.0 objectChange system.adapter.ble.0.outputCount null
    2018-11-27 19:56:39.544 - info: host.ubuntubroker object change system.adapter.ble.0
    2018-11-27 19:56:39.544 - info: yahka.0 objectChange system.adapter.ble.0 null
    2018-11-27 19:56:39.544 - info: host.ubuntubroker object deleted system.adapter.ble.0
    2018-11-27 19:56:39.548 - info: iobroker host.ubuntubroker Deleting 9 state(s).
    2018-11-27 19:56:39.597 - info: iobroker exit 0
    2018-11-27 19:56:51.997 - info: host.ubuntubroker instance system.adapter.link.0 started with pid 2348
    2018-11-27 19:56:52.162 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.link/main.js:1
    2018-11-27 19:56:52.163 - error: Caught by controller[0]: (function (exports, require, module, __filename, __dirname) { var _0x7c94=['enabled','undefined','object','Connected\x20to\x20','Disconnected\x20to\x20','Cannot\x20find\x20module\x20\x27','code','MODULE_NOT_FOUND','call','exports','function','./helpers/cert-helper.js','jwt-simple','node-rsa','util','EventEmitter','https-proxy-agent','./handler/ssh-proxy','log','error','warn','destroy','accessServerURI','api/brokers','/requests','Close\x20connection:\x20','info','Close\x20connection','/error','post','Bearer\x20','emit','get','AccessClient:\x20error\x20getting\x20connection\x20request\x20info:\x20','parse','status','CLOSED','accessServerPollInterval','AccessClient:\x20error\x20getting\x20connection\x20requests:\x20','statusMessage','statusCode','AccessClient:\x20Cannot\x20parse\x20answer\x20from\x20server:\x20','length','filter','REQUESTED','assign','AccessClient:\x20setting\x20up\x20reverse\x20proxy','setupTunnel','debug','AccessClient:\x20accepting\x20conne
    2018-11-27 19:56:52.163 - error: Caught by controller[0]: SyntaxError: missing ) after argument list
    2018-11-27 19:56:52.163 - error: Caught by controller[0]: at createScript (vm.js:56:10)
    2018-11-27 19:56:52.163 - error: Caught by controller[0]: at Object.runInThisContext (vm.js:97:10)
    2018-11-27 19:56:52.163 - error: Caught by controller[0]: at Module._compile (module.js:549:28)
    2018-11-27 19:56:52.163 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
    2018-11-27 19:56:52.163 - error: Caught by controller[0]: at Module.load (module.js:494:32)
    2018-11-27 19:56:52.163 - error: Caught by controller[0]: at tryModuleLoad (module.js:453:12)
    2018-11-27 19:56:52.163 - error: Caught by controller[0]: at Function.Module._load (module.js:445:3)
    2018-11-27 19:56:52.164 - error: Caught by controller[0]: at Module.runMain (module.js:611:10)
    2018-11-27 19:56:52.164 - error: Caught by controller[0]: at run (bootstrap_node.js:387:7)
    2018-11-27 19:56:52.164 - error: Caught by controller[0]: at startup (bootstrap_node.js:153:9)
    2018-11-27 19:56:52.164 - error: host.ubuntubroker instance system.adapter.link.0 terminated with code 1 ()
    2018-11-27 19:56:52.164 - info: host.ubuntubroker Restart adapter system.adapter.link.0 because enabled
    2018-11-27 19:57:22.179 - info: host.ubuntubroker instance system.adapter.link.0 started with pid 2356
    2018-11-27 19:57:22.341 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.link/main.js:1
    2018-11-27 19:57:22.341 - error: Caught by controller[0]: (function (exports, require, module, __filename, __dirname) { var _0x7c94=['enabled','undefined','object','Connected\x20to\x20','Disconnected\x20to\x20','Cannot\x20find\x20module\x20\x27','code','MODULE_NOT_FOUND','call','exports','function','./helpers/cert-helper.js','jwt-simple','node-rsa','util','EventEmitter','https-proxy-agent','./handler/ssh-proxy','log','error','warn','destroy','accessServerURI','api/brokers','/requests','Close\x20connection:\x20','info','Close\x20connection','/error','post','Bearer\x20','emit','get','AccessClient:\x20error\x20getting\x20connection\x20request\x20info:\x20','parse','status','CLOSED','accessServerPollInterval','AccessClient:\x20error\x20getting\x20connection\x20requests:\x20','statusMessage','statusCode','AccessClient:\x20Cannot\x20parse\x20answer\x20from\x20server:\x20','length','filter','REQUESTED','assign','AccessClient:\x20setting\x20up\x20reverse\x20proxy','setupTunnel','debug','AccessClient:\x20accepting\x20conne
    2018-11-27 19:57:22.341 - error: Caught by controller[0]: SyntaxError: missing ) after argument list
    2018-11-27 19:57:22.342 - error: Caught by controller[0]: at createScript (vm.js:56:10)
    2018-11-27 19:57:22.342 - error: Caught by controller[0]: at Object.runInThisContext (vm.js:97:10)
    2018-11-27 19:57:22.342 - error: Caught by controller[0]: at Module._compile (module.js:549:28)
    2018-11-27 19:57:22.342 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
    2018-11-27 19:57:22.342 - error: Caught by controller[0]: at Module.load (module.js:494:32)
    2018-11-27 19:57:22.342 - error: Caught by controller[0]: at tryModuleLoad (module.js:453:12)
    2018-11-27 19:57:22.342 - error: Caught by controller[0]: at Function.Module._load (module.js:445:3)
    2018-11-27 19:57:22.342 - error: Caught by controller[0]: at Module.runMain (module.js:611:10)
    2018-11-27 19:57:22.342 - error: Caught by controller[0]: at run (bootstrap_node.js:387:7)
    2018-11-27 19:57:22.342 - error: Caught by controller[0]: at startup (bootstrap_node.js:153:9)
    2018-11-27 19:57:22.342 - error: host.ubuntubroker instance system.adapter.link.0 terminated with code 1 ()
    2018-11-27 19:57:22.343 - info: host.ubuntubroker Restart adapter system.adapter.link.0 because enabled
    2018-11-27 19:57:52.352 - info: host.ubuntubroker instance system.adapter.link.0 started with pid 2363
    2018-11-27 19:57:52.515 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.link/main.js:1
    2018-11-27 19:57:52.515 - error: Caught by controller[0]: (function (exports, require, module, __filename, __dirname) { var _0x7c94=['enabled','undefined','object','Connected\x20to\x20','Disconnected\x20to\x20','Cannot\x20find\x20module\x20\x27','code','MODULE_NOT_FOUND','call','exports','function','./helpers/cert-helper.js','jwt-simple','node-rsa','util','EventEmitter','https-proxy-agent','./handler/ssh-proxy','log','error','warn','destroy','accessServerURI','api/brokers','/requests','Close\x20connection:\x20','info','Close\x20connection','/error','post','Bearer\x20','emit','get','AccessClient:\x20error\x20getting\x20connection\x20request\x20info:\x20','parse','status','CLOSED','accessServerPollInterval','AccessClient:\x20error\x20getting\x20connection\x20requests:\x20','statusMessage','statusCode','AccessClient:\x20Cannot\x20parse\x20answer\x20from\x20server:\x20','length','filter','REQUESTED','assign','AccessClient:\x20setting\x20up\x20reverse\x20proxy','setupTunnel','debug','AccessClient:\x20accepting\x20conne
    2018-11-27 19:57:52.515 - error: Caught by controller[0]: SyntaxError: missing ) after argument list
    2018-11-27 19:57:52.515 - error: Caught by controller[0]: at createScript (vm.js:56:10)
    2018-11-27 19:57:52.515 - error: Caught by controller[0]: at Object.runInThisContext (vm.js:97:10)
    2018-11-27 19:57:52.515 - error: Caught by controller[0]: at Module._compile (module.js:549:28)
    2018-11-27 19:57:52.516 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
    2018-11-27 19:57:52.516 - error: Caught by controller[0]: at Module.load (module.js:494:32)
    2018-11-27 19:57:52.516 - error: Caught by controller[0]: at tryModuleLoad (module.js:453:12)
    2018-11-27 19:57:52.516 - error: Caught by controller[0]: at Function.Module._load (module.js:445:3)
    2018-11-27 19:57:52.516 - error: Caught by controller[0]: at Module.runMain (module.js:611:10)
    2018-11-27 19:57:52.517 - error: Caught by controller[0]: at run (bootstrap_node.js:387:7)
    2018-11-27 19:57:52.517 - error: Caught by controller[0]: at startup (bootstrap_node.js:153:9)
    2018-11-27 19:57:52.517 - error: host.ubuntubroker instance system.adapter.link.0 terminated with code 1 ()
    2018-11-27 19:57:52.517 - info: host.ubuntubroker Restart adapter system.adapter.link.0 because enabled
    2018-11-27 19:58:10.660 - info: telegram.0 getMe (reconnect): {"id":420247416,"is_bot":true,"first_name":"BotKlaus","username":"BotKlaus_bot"}
    2018-11-27 19:58:22.530 - info: host.ubuntubroker instance system.adapter.link.0 started with pid 2371
    2018-11-27 19:58:22.695 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.link/main.js:1
    2018-11-27 19:58:22.696 - error: Caught by controller[0]: (function (exports, require, module, __filename, __dirname) { var _0x7c94=['enabled','undefined','object','Connected\x20to\x20','Disconnected\x20to\x20','Cannot\x20find\x20module\x20\x27','code','MODULE_NOT_FOUND','call','exports','function','./helpers/cert-helper.js','jwt-simple','node-rsa','util','EventEmitter','https-proxy-agent','./handler/ssh-proxy','log','error','warn','destroy','accessServerURI','api/brokers','/requests','Close\x20connection:\x20','info','Close\x20connection','/error','post','Bearer\x20','emit','get','AccessClient:\x20error\x20getting\x20connection\x20request\x20info:\x20','parse','status','CLOSED','accessServerPollInterval','AccessClient:\x20error\x20getting\x20connection\x20requests:\x20','statusMessage','statusCode','AccessClient:\x20Cannot\x20parse\x20answer\x20from\x20server:\x20','length','filter','REQUESTED','assign','AccessClient:\x20setting\x20up\x20reverse\x20proxy','setupTunnel','debug','AccessClient:\x20accepting\x20conne
    2018-11-27 19:58:22.696 - error: Caught by controller[0]: SyntaxError: missing ) after argument list
    2018-11-27 19:58:22.696 - error: Caught by controller[0]: at createScript (vm.js:56:10)
    2018-11-27 19:58:22.696 - error: Caught by controller[0]: at Object.runInThisContext (vm.js:97:10)
    2018-11-27 19:58:22.696 - error: Caught by controller[0]: at Module._compile (module.js:549:28)
    2018-11-27 19:58:22.697 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
    2018-11-27 19:58:22.697 - error: Caught by controller[0]: at Module.load (module.js:494:32)
    2018-11-27 19:58:22.697 - error: Caught by controller[0]: at tryModuleLoad (module.js:453:12)
    2018-11-27 19:58:22.697 - error: Caught by controller[0]: at Function.Module._load (module.js:445:3)
    2018-11-27 19:58:22.697 - error: Caught by controller[0]: at Module.runMain (module.js:611:10)
    2018-11-27 19:58:22.697 - error: Caught by controller[0]: at run (bootstrap_node.js:387:7)
    2018-11-27 19:58:22.697 - error: Caught by controller[0]: at startup (bootstrap_node.js:153:9)
    2018-11-27 19:58:22.698 - error: host.ubuntubroker instance system.adapter.link.0 terminated with code 1 ()
    2018-11-27 19:58:22.698 - info: host.ubuntubroker Restart adapter system.adapter.link.0 because enabled
    2018-11-27 19:58:52.712 - info: host.ubuntubroker instance system.adapter.link.0 started with pid 2378
    2018-11-27 19:58:52.875 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.link/main.js:1
    2018-11-27 19:58:52.875 - error: Caught by controller[0]: (function (exports, require, module, __filename, __dirname) { var _0x7c94=['enabled','undefined','object','Connected\x20to\x20','Disconnected\x20to\x20','Cannot\x20find\x20module\x20\x27','code','MODULE_NOT_FOUND','call','exports','function','./helpers/cert-helper.js','jwt-simple','node-rsa','util','EventEmitter','https-proxy-agent','./handler/ssh-proxy','log','error','warn','destroy','accessServerURI','api/brokers','/requests','Close\x20connection:\x20','info','Close\x20connection','/error','post','Bearer\x20','emit','get','AccessClient:\x20error\x20getting\x20connection\x20request\x20info:\x20','parse','status','CLOSED','accessServerPollInterval','AccessClient:\x20error\x20getting\x20connection\x20requests:\x20','statusMessage','statusCode','AccessClient:\x20Cannot\x20parse\x20answer\x20from\x20server:\x20','length','filter','REQUESTED','assign','AccessClient:\x20setting\x20up\x20reverse\x20proxy','setupTunnel','debug','AccessClient:\x20accepting\x20conne
    2018-11-27 19:58:52.876 - error: Caught by controller[0]: SyntaxError: missing ) after argument list
    2018-11-27 19:58:52.876 - error: Caught by controller[0]: at createScript (vm.js:56:10)
    2018-11-27 19:58:52.876 - error: Caught by controller[0]: at Object.runInThisContext (vm.js:97:10)
    2018-11-27 19:58:52.876 - error: Caught by controller[0]: at Module._compile (module.js:549:28)
    2018-11-27 19:58:52.876 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
    2018-11-27 19:58:52.876 - error: Caught by controller[0]: at Module.load (module.js:494:32)
    2018-11-27 19:58:52.876 - error: Caught by controller[0]: at tryModuleLoad (module.js:453:12)
    2018-11-27 19:58:52.876 - error: Caught by controller[0]: at Function.Module._load (module.js:445:3)
    2018-11-27 19:58:52.876 - error: Caught by controller[0]: at Module.runMain (module.js:611:10)
    2018-11-27 19:58:52.877 - error: Caught by controller[0]: at run (bootstrap_node.js:387:7)
    2018-11-27 19:58:52.877 - error: Caught by controller[0]: at startup (bootstrap_node.js:153:9)
    2018-11-27 19:58:52.877 - error: host.ubuntubroker instance system.adapter.link.0 terminated with code 1 ()
    2018-11-27 19:58:52.877 - info: host.ubuntubroker Restart adapter system.adapter.link.0 because enabled
    2018-11-27 19:59:22.890 - info: host.ubuntubroker instance system.adapter.link.0 started with pid 2387
    2018-11-27 19:59:22.911 - warn: alexa2.0 Disabling some commands for device because of unknown type. Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
    2018-11-27 19:59:22.912 - warn: alexa2.0 Device-type:ATH4K2BAIXVHQ (VOLUME_SETTING,MICROPHONE,PEONY)
    2018-11-27 19:59:23.090 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.link/main.js:1
    2018-11-27 19:59:23.090 - error: Caught by controller[0]: (function (exports, require, module, __filename, __dirname) { var _0x7c94=['enabled','undefined','object','Connected\x20to\x20','Disconnected\x20to\x20','Cannot\x20find\x20module\x20\x27','code','MODULE_NOT_FOUND','call','exports','function','./helpers/cert-helper.js','jwt-simple','node-rsa','util','EventEmitter','https-proxy-agent','./handler/ssh-proxy','log','error','warn','destroy','accessServerURI','api/brokers','/requests','Close\x20connection:\x20','info','Close\x20connection','/error','post','Bearer\x20','emit','get','AccessClient:\x20error\x20getting\x20connection\x20request\x20info:\x20','parse','status','CLOSED','accessServerPollInterval','AccessClient:\x20error\x20getting\x20connection\x20requests:\x20','statusMessage','statusCode','AccessClient:\x20Cannot\x20parse\x20answer\x20from\x20server:\x20','length','filter','REQUESTED','assign','AccessClient:\x20setting\x20up\x20reverse\x20proxy','setupTunnel','debug','AccessClient:\x20accepting\x20conne
    2018-11-27 19:59:23.090 - error: Caught by controller[0]: SyntaxError: missing ) after argument list
    2018-11-27 19:59:23.091 - error: Caught by controller[0]: at createScript (vm.js:56:10)
    2018-11-27 19:59:23.091 - error: Caught by controller[0]: at Object.runInThisContext (vm.js:97:10)
    2018-11-27 19:59:23.091 - error: Caught by controller[0]: at Module._compile (module.js:549:28)
    2018-11-27 19:59:23.091 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
    2018-11-27 19:59:23.091 - error: Caught by controller[0]: at Module.load (module.js:494:32)
    2018-11-27 19:59:23.091 - error: Caught by controller[0]: at tryModuleLoad (module.js:453:12)
    2018-11-27 19:59:23.091 - error: Caught by controller[0]: at Function.Module._load (module.js:445:3)
    2018-11-27 19:59:23.091 - error: Caught by controller[0]: at Module.runMain (module.js:611:10)
    2018-11-27 19:59:23.091 - error: Caught by controller[0]: at run (bootstrap_node.js:387:7)
    2018-11-27 19:59:23.091 - error: Caught by controller[0]: at startup (bootstrap_node.js:153:9)
    2018-11-27 19:59:23.092 - error: host.ubuntubroker instance system.adapter.link.0 terminated with code 1 ()
    2018-11-27 19:59:23.092 - info: host.ubuntubroker Restart adapter system.adapter.link.0 because enabled
    2018-11-27 19:59:53.101 - info: host.ubuntubroker instance system.adapter.link.0 started with pid 2394
    2018-11-27 19:59:53.262 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.link/main.js:1
    2018-11-27 19:59:53.263 - error: Caught by controller[0]: (function (exports, require, module, __filename, __dirname) { var _0x7c94=['enabled','undefined','object','Connected\x20to\x20','Disconnected\x20to\x20','Cannot\x20find\x20module\x20\x27','code','MODULE_NOT_FOUND','call','exports','function','./helpers/cert-helper.js','jwt-simple','node-rsa','util','EventEmitter','https-proxy-agent','./handler/ssh-proxy','log','error','warn','destroy','accessServerURI','api/brokers','/requests','Close\x20connection:\x20','info','Close\x20connection','/error','post','Bearer\x20','emit','get','AccessClient:\x20error\x20getting\x20connection\x20request\x20info:\x20','parse','status','CLOSED','accessServerPollInterval','AccessClient:\x20error\x20getting\x20connection\x20requests:\x20','statusMessage','statusCode','AccessClient:\x20Cannot\x20parse\x20answer\x20from\x20server:\x20','length','filter','REQUESTED','assign','AccessClient:\x20setting\x20up\x20reverse\x20proxy','setupTunnel','debug','AccessClient:\x20accepting\x20conne
    2018-11-27 19:59:53.263 - error: Caught by controller[0]: SyntaxError: missing ) after argument list
    2018-11-27 19:59:53.263 - error: Caught by controller[0]: at createScript (vm.js:56:10)
    2018-11-27 19:59:53.263 - error: Caught by controller[0]: at Object.runInThisContext (vm.js:97:10)
    2018-11-27 19:59:53.263 - error: Caught by controller[0]: at Module._compile (module.js:549:28)
    2018-11-27 19:59:53.263 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
    2018-11-27 19:59:53.263 - error: Caught by controller[0]: at Module.load (module.js:494:32)
    2018-11-27 19:59:53.263 - error: Caught by controller[0]: at tryModuleLoad (module.js:453:12)
    2018-11-27 19:59:53.263 - error: Caught by controller[0]: at Function.Module._load (module.js:445:3)
    2018-11-27 19:59:53.263 - error: Caught by controller[0]: at Module.runMain (module.js:611:10)
    2018-11-27 19:59:53.263 - error: Caught by controller[0]: at run (bootstrap_node.js:387:7)
    2018-11-27 19:59:53.263 - error: Caught by controller[0]: at startup (bootstrap_node.js:153:9)
    2018-11-27 19:59:53.264 - error: host.ubuntubroker instance system.adapter.link.0 terminated with code 1 ()
    2018-11-27 19:59:53.264 - info: host.ubuntubroker Restart adapter system.adapter.link.0 because enabled
    • apollon77A Offline
      Zigbee: Versuch mal die GitHub Version
      • I Offline
        I Offline
        iKlaus
        das wäre die version 0.5.5 dann grade drauf gemacht
        • J Offline
          J Riemann
          0.8.0b
          https://github.com/arteck/ioBroker.zigbee
          ****Viele Grüße!
          Jörg****
          • I Offline
            I Offline
            iKlaus
            so hatte die version 0.5.5 drauf gemacht dann update gezogen
            zigbee funktioniert jetzt ohne einen Fehler in mom zu min !
            habe jetzt nur noch diese Fehler drauf !
            host.ubuntubroker	2018-11-27 22:36:36.258	error	instance system.adapter.link.0 terminated with code 1 ()
            host.ubuntubroker	2018-11-27 22:36:36.258	error	Caught by controller[0]: at startup (bootstrap_node.js:153:9)
            host.ubuntubroker	2018-11-27 22:36:36.258	error	Caught by controller[0]: at run (bootstrap_node.js:387:7)
            host.ubuntubroker	2018-11-27 22:36:36.258	error	Caught by controller[0]: at Module.runMain (module.js:611:10)
            host.ubuntubroker	2018-11-27 22:36:36.258	error	Caught by controller[0]: at Function.Module._load (module.js:445:3)
            host.ubuntubroker	2018-11-27 22:36:36.258	error	Caught by controller[0]: at tryModuleLoad (module.js:453:12)
            host.ubuntubroker	2018-11-27 22:36:36.258	error	Caught by controller[0]: at Module.load (module.js:494:32)
            host.ubuntubroker	2018-11-27 22:36:36.258	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
            host.ubuntubroker	2018-11-27 22:36:36.258	error	Caught by controller[0]: at Module._compile (module.js:549:28)
            host.ubuntubroker	2018-11-27 22:36:36.258	error	Caught by controller[0]: at Object.runInThisContext (vm.js:97:10)
            host.ubuntubroker	2018-11-27 22:36:36.258	error	Caught by controller[0]: at createScript (vm.js:56:10)
            host.ubuntubroker	2018-11-27 22:36:36.257	error	Caught by controller[0]: SyntaxError: missing ) after argument list
            host.ubuntubroker	2018-11-27 22:36:36.257	error	Caught by controller[0]: (function (exports, require, module, __filename, __dirname) { var _0x7c94=['enabled','undefined','object','Connected\x20to\x20','Disconnected\x20to\x20','Cannot\x20find\x20mod
            host.ubuntubroker	2018-11-27 22:36:36.257	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.link/main.js:1
              mach auch mal update für link adapter (brauchst Du den?)
              • I Offline
                I Offline
                iKlaus
                ja bitte
                  Die Frage war ob Du den ioBroker.link Adapter der da Fehler anzeigt brauchst :-)
                  • I Offline
                    I Offline
                    iKlaus
                    ihm sorry jetzt stehe ich grade ganz auf dem schlauch !
                    das liegt am stress weil wenn meine Frau morgen aufsteht und wieder im dunkelt steht :( nicht gut fürs Wochenende :))
                    Bin grade etwas überfordert !
                    bitte langsam für einen alten mann
                      DIe oben (viewtopic.php?p=197760#p197750) gezeigte Fehlermeldung stammt vom Adapter ioBroker.link
                      Brauchst Du den?
                      • I Offline
                        I Offline
                        iKlaus
                        nein den hatte ich schon grade gelöscht weil ich den nicht brauche !
                        • I Offline
                          I Offline
                          iKlaus
                          Fehler werden weniger :)
                          in mom nur noch der
                          host.ubuntubroker	2018-11-27 22:18:53.604	error	startInstance system.adapter.link.0: object not found!
                            Scheinnar ist da noch eine Instanz übrig geblieben von link.0
                            • I Offline
                              I Offline
                              iKlaus
                              na klasse :( das heisst der stört grade nicht wirklich
                              viel wert dann heisst es morgen manuell suchen !
                              dann danke ich dir erst einmal und werde mich dann zu Bett begeben !
                              Gruss Klaus
                              • I Offline
                                I Offline
                                iKlaus
                                @iKlaus:
                                in mom nur noch der
                                reboot hat ausgereicht
