  4. [Gelöst] Adapter installation nicht möglich - Exit 13
4 Beiträge 2 Kommentatoren 756 Aufrufe
  • W Offline
    W Offline
    Walkinlarge2010
    Hi zusammen,
    ich habe meinen Rock64 neu aufgesetzt und nun das problem, dass ich einige Adapter nicht installieren kann.
    Folgende Konstellation:
    Rock 64 mit Debian Stretch
    NPM 6.4.1
    Node 8.12.0
    Git ist installiert und libcap-dev auch. Folgende Fehlermeldung bekomme ich immer (am Beispiel des Yahia Adapters):
    ! $ ./iobroker add yahka
    ! NPM version: 6.4.1
    ! npm install iobroker.yahka –production --save --prefix "/opt/iobroker" (System call)
    ! Traceback (most recent call last): File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 13, in <module>import gyp File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/init.py", line 8, in <module>import gyp.input
    ! File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 5, in <module>from compiler.ast import Const
    ! ImportError: No module named compiler.ast
    ! gyp
    ! ERR! configure error
    ! gyp
    ! ERR! stack Error: gyp failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
    ! gyp ERR! stack at emitTwo (events.js:126:13)
    ! gyp ERR! stack
    ! at ChildProcess.emit (events.js:214:7)gyp
    ! ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)gyp
    ! ERR! System Linux 4.4.132-1075-rockchip-ayufan-ga83beded8524gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    ! gyp
    ! ERR! cwd /opt/iobroker/node_modules/curve25519-ngyp ERR! node -v v8.12.0
    ! gyp ERR! node-gyp -v
    ! v3.8.0gyp ERR! not ok
    ! npm
    ! ERR! code ELIFECYCLEnpm
    ! ERR! errno 1
    ! npm
    ! ERR! curve25519-n@1.4.0 install: node-gyp rebuildnpm ERR! Exit status 1
    ! npm
    ! ERR! npm ERR! Failed at the curve25519-n@1.4.0 install script.
    ! npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    ! npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2018-09-21T21_13_44_713Z-debug.log
    ! host.rock64 install adapter yahka
    ! npm install iobroker.yahka --production --save --prefix "/opt/iobroker" (System call)
    ! gyp
    ! ERR!
    ! configure error
    ! gyp ERR!
    ! gyp ERR! stack at ChildProcess.emit (events.js:214:7)
    ! gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
    ! gyp ERR! System Linux 4.4.132-1075-rockchip-ayufan-ga83beded8524gyp ERR!
    ! gyp
    ! gyp ERR! node-gyp -v v3.8.0
    ! gyp ERR! not ok
    ! npm
    ! ERR! code ELIFECYCLEnpm ERR!
    ! errno 1
    ! npm
    ! npm ERR! npm ERR! Failed at the curve25519-n@1.4.0 install script.
    ! npm ERR!
    ! npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2018-09-21T21_14_23_302Z-debug.log
    ! gyp
    ! ERR!
    ! configure error
    ! gyp ERR! stack
    ! Error: gyp failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
    ! gyp ERR! System Linux 4.4.132-1075-rockchip-ayufan-ga83beded8524gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    ! gyp ERR! cwd /opt/iobroker/node_modules/curve25519-n
    ! gyp ERR! node -v v8.12.0
    ! gyp ERR! not ok
    ! npm
    ! ERR! errno 1
    ! npm
    ! npm
    ! npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2018-09-21T21_15_01_667Z-debug.log
    ! ERROR: host.rock64 Cannot install yahka
    ! ERROR: process exited with code 13</module></module></module></module></module></module></module></module></module>
    und einen gleichen Fehler auch beim Amazon Dash Adapter, hier hatte ich es als root in der console direkt probiert:
    ! root@rock64:~# iobroker add amazon-dash 1
    ! npm install iobroker.amazon-dash –production --save --prefix "/opt/iobroker" (System call)
    ! File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 13, in <module>import gyp
    ! File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/init.py", line 8, in <module>import gyp.input
    ! gyp ERR! configure error
    ! gyp ERR! stack Error: gyp failed with exit code: 1
    ! gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
    ! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    ! gyp ERR! cwd /opt/iobroker/node_modules/socketwatcher
    ! gyp ERR! not ok
    ! npm ERR! code ELIFECYCLE
    ! npm ERR! errno 1
    ! npm ERR! socketwatcher@0.3.0 install: node-gyp rebuild
    ! npm ERR! Exit status 1
    ! npm ERR!
    ! npm ERR! Failed at the socketwatcher@0.3.0 install script.
    ! npm ERR! /root/.npm/_logs/2018-09-21T20_59_54_852Z-debug.log
    ! host.rock64 install adapter amazon-dash
    ! npm install iobroker.amazon-dash --production --save --prefix "/opt/iobroker" (System call)
    ! gyp ERR! not ok
    ! npm ERR! errno 1
    ! npm ERR!
    ! npm ERR! /root/.npm/_logs/2018-09-21T21_00_40_020Z-debug.log
    ! gyp ERR! not ok
    ! npm ERR! errno 1
    ! npm ERR!
    ! npm ERR! /root/.npm/_logs/2018-09-21T21_01_26_521Z-debug.log
    ! host.rock64 Cannot install amazon-dash</module></module></module></module></module></module></module></module></module>
    Jemand eine Idee woran das liegen könnte? Hab ich noch was vergessen zu installieren?
    Danke vorab!
    Viele Grüße
    Walkinlarge
    • StabilostickS Offline
      Stabilostick
      Probiere es damit:
      apt-get install python-dev
      • W Offline
        W Offline
        Walkinlarge2010
        Danke, das hat geholfen!
        Gesendet von iPad mit Tapatalk
          Stabilostick
          War mir eine Freude. Viel Spaß noch mit ioBroker.
