  3. Entwicklung
  4. Adapter: jeelink
Adapter: jeelink
jeelink
185 Beiträge 28 Kommentatoren 69.0k Aufrufe 4 Beobachtet
  • C Offline
    C1500
    #142
    Nächster Versuch:
    pi@ioBroker-Pi:/opt/iobroker $ sudo npm install https://github.com/foxthefox/ioBroker.jeelink/tarball/master --production
    > serialport@6.2.2 install /opt/iobroker/node_modules/iobroker.jeelink/node_modules/serialport
    > prebuild-install || node-gyp rebuild
    prebuild-install WARN install EACCES: permission denied, access '/root/.npm'
    gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.14.3"
    gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.jeelink/node_modules/serialport/.node-gyp"
    make: Verzeichnis „/opt/iobroker/node_modules/iobroker.jeelink/node_modules/serialport/build“ wird betreten
      CXX(target) Release/obj.target/serialport/src/serialport.o
    ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
    ../src/serialport.cpp:95:30: warning: ‘v8::Local <v8::value>Nan::Callback::Call(int, v8::Local<v8::value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(2, argv);
    In file included from ../src/./serialport.h:6:0,
                     from ../src/serialport.cpp:1:
    ../../nan/nan.h:1618:3: note: declared here
       Call(int argc, v8::Local <v8::value>argv[]) const {
    ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
    ../src/serialport.cpp:150:30: warning: ‘v8::Local <v8::value>Nan::Callback::Call(int, v8::Local<v8::value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(1, argv);
    ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
    ../src/serialport.cpp:188:30: warning: ‘v8::Local <v8::value>Nan::Callback::Call(int, v8::Local<v8::value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
    ../src/serialport.cpp:231:30: warning: ‘v8::Local <v8::value>Nan::Callback::Call(int, v8::Local<v8::value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
    ../src/serialport.cpp:285:30: warning: ‘v8::Local <v8::value>Nan::Callback::Call(int, v8::Local<v8::value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
    ../src/serialport.cpp:336:30: warning: ‘v8::Local <v8::value>Nan::Callback::Call(int, v8::Local<v8::value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
    ../src/serialport.cpp:383:30: warning: ‘v8::Local <v8::value>Nan::Callback::Call(int, v8::Local<v8::value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
    ../src/serialport.cpp:424:30: warning: ‘v8::Local <v8::value>Nan::Callback::Call(int, v8::Local<v8::value>*) const’ is deprecated [-Wdeprecated-declarations]
      CXX(target) Release/obj.target/serialport/src/serialport_unix.o
      CXX(target) Release/obj.target/serialport/src/poller.o
    ../src/poller.cpp: In static member function ‘static void Poller::onData(uv_poll_t*, int, int)’:
    ../src/poller.cpp:69:29: warning: ‘v8::Local <v8::value>Nan::Callback::Call(int, v8::Local<v8::value>*) const’ is deprecated [-Wdeprecated-declarations]
       obj->callback.Call(2, argv);
    In file included from ../src/poller.cpp:1:0:
      CXX(target) Release/obj.target/serialport/src/serialport_linux.o
      SOLINK_MODULE(target) Release/obj.target/serialport.node
      COPY Release/serialport.node
    make: Verzeichnis „/opt/iobroker/node_modules/iobroker.jeelink/node_modules/serialport/build“ wird verlassen
    iobroker@1.0.0 /opt/iobroker
    └─┬ iobroker.jeelink@0.0.6
      └─┬ serialport@6.2.2
        ├── bindings@1.3.0
        ├── commander@2.17.1
        ├─┬ debug@3.1.0
        │ └── ms@2.0.0
        ├── nan@2.10.0
        └── safe-buffer@5.1.2
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.ble/node_modules/noble/node_modules/xpc-connection):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
    pi@ioBroker-Pi:/opt/iobroker $</v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value>
    Immer noch 0.0.5 in ioBroker
    Update 20:34 Uhr
    Nach neustart des PI wird jetzt die 0.0.6 in ioBroker angezeigt
    Gruß Peer
    • F Abwesend
      F Abwesend
      foxthefox
      #143
      Servus Peer,
      ein reload hätte es evtl. auch getan, aber reboot tut es auch.
      Ich habe die Version 0.0.6 auf github für deinen TXH29DTH-IT und die Wetterstation fit gemacht.
      Beim TXH29DTH-It ist mir noch nicht ganz klar wie ein Telegramm mit schwacher batterie und Minusgraden gesendet wird, da ist noch Nacharbeit nötig.
      Bin gespannt, was deine Tests sagen. Grundsätzlich sollte es laufen.
      Klaus
      Adapterüberblick: Profil Github;
      Wenn der Adapter gefällt und nützlich ist, bitte ins Repo gehen und Star setzen. Danke
      Ein Aufruf: video
      • C Offline
        C1500
        schrieb am zuletzt editiert von Jey Cee
        #144
        Servus Klaus
        Leider keine guten Nachrichten
        Hab gerade die Wetterstation aufgebaut und den Adapter neu installiert.
        Es handelt sich übrigens leider um eine OOK-Version.
        Die OOK-Version erkennt man an:
        • Runder grüner Aufkleber im Batteriefach der Station mit dem Aufdruck "PASS A14C"
        Leider klappt es noch nicht.
        Er scheint zwar unter ID9 die Wetterstation zu finden, aber auch von den anderen Sensoren werden keine Werte ausgewertet
        Welchen Adapter soll ich denn einstellen?
        Es stehen ja nur die 4 zur Verfügung
        Hier ein Auszug aus dem LOG:
        elink.0	2018-08-23 17:48:21.870	debug	received ID :7 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:48:21.870	info	data received: H002500760242
        jeelink.0	2018-08-23 17:48:21.110	debug	received ID :0 is not defined in the adapter or not unique received address
        jeelink.0	2018-08-23 17:48:21.109	info	data received: H000001100700
        jeelink.0	2018-08-23 17:48:18.792	debug	received ID :7 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:48:18.791	info	data received: H000700250269
        jeelink.0	2018-08-23 17:48:17.517	debug	received ID :1 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:48:17.517	info	data received: H000100220271
        jeelink.0	2018-08-23 17:48:14.812	debug	received ID :9 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:48:14.811	info	data received: H005400450260
        jeelink.0	2018-08-23 17:48:14.581	debug	received ID :9 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:48:14.581	info	data received: H002700450263
        jeelink.0	2018-08-23 17:48:13.470	debug	received ID :7 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:48:13.469	info	data received: H002500760242
        jeelink.0	2018-08-23 17:48:13.103	debug	received ID :0 is not defined in the adapter or not unique received address
        jeelink.0	2018-08-23 17:48:13.102	info	data received: H000001100700
        jeelink.0	2018-08-23 17:48:10.669	debug	received ID :7 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:48:10.669	info	data received: H000700250269
        jeelink.0	2018-08-23 17:48:09.488	debug	received ID :1 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:48:09.488	info	data received: H000100220271
        jeelink.0	2018-08-23 17:48:06.145	debug	received ID :9 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:48:06.145	info	data received: H002700450263
        jeelink.0	2018-08-23 17:48:05.954	debug	received ID :9 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:48:05.953	info	data received: H005400450260
        jeelink.0	2018-08-23 17:48:05.093	debug	received ID :7 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:48:05.093	info	data received: H002500760242
        jeelink.0	2018-08-23 17:48:02.566	debug	received ID :7 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:48:02.566	info	data received: H000700250269
        jeelink.0	2018-08-23 17:48:01.480	debug	received ID :1 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:48:01.479	info	data received: H000100220271
        jeelink.0	2018-08-23 17:47:57.724	debug	received ID :9 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:47:57.723	info	data received: H002700450263
        jeelink.0	2018-08-23 17:47:57.100	debug	received ID :0 is not defined in the adapter or not unique received address
        jeelink.0	2018-08-23 17:47:57.099	info	data received: H000001100700
        jeelink.0	2018-08-23 17:47:56.700	debug	received ID :7 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:47:56.700	info	data received: H002500760242
        jeelink.0	2018-08-23 17:47:53.455	debug	received ID :1 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:47:53.455	info	data received: H000100220271
        jeelink.0	2018-08-23 17:47:49.314	debug	received ID :9 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:47:49.313	info	data received: H002700450263
        jeelink.0	2018-08-23 17:47:49.107	debug	received ID :0 is not defined in the adapter or not unique received address
        jeelink.0	2018-08-23 17:47:49.107	info	data received: H000001100700
        jeelink.0	2018-08-23 17:47:48.275	debug	received ID :9 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:47:48.274	info	data received: H005400450260
        jeelink.0	2018-08-23 17:47:46.339	debug	received ID :7 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:47:46.339	info	data received: H000700250269
        jeelink.0	2018-08-23 17:47:45.451	debug	received ID :1 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:47:45.448	info	data received: H000100220271
        jeelink.0	2018-08-23 17:47:41.100	debug	received ID :0 is not defined in the adapter or not unique received address
        jeelink.0	2018-08-23 17:47:41.099	info	data received: H000001100700
        jeelink.0	2018-08-23 17:47:40.889	debug	received ID :9 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:47:40.889	info	data received: H002700450263
        jeelink.0	2018-08-23 17:47:39.916	debug	received ID :7 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:47:39.915	info	data received: H002500760242
        jeelink.0	2018-08-23 17:47:39.436	debug	received ID :9 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:47:39.435	info	data received: H005400450260
        jeelink.0	2018-08-23 17:47:38.238	debug	received ID :7 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:47:38.237	info	data received: H000700250269
        jeelink.0	2018-08-23 17:47:37.438	debug	received ID :1 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:47:37.437	info	data received: H000100220271
        jeelink.0	2018-08-23 17:47:33.106	debug	received ID :0 is not defined in the adapter or not unique received address
        jeelink.0	2018-08-23 17:47:33.105	info	data received: H000001100700
        jeelink.0	2018-08-23 17:47:32.468	debug	received ID :9 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:47:32.468	info	data received: H002700450263
        jeelink.0	2018-08-23 17:47:31.523	debug	received ID :7 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:47:31.522	info	data received: H002500760242
        jeelink.0	2018-08-23 17:47:30.578	debug	received ID :9 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:47:30.577	info	data received: H005400450260
        jeelink.0	2018-08-23 17:47:30.136	debug	received ID :7 is not defined in the adapter as HMS100TF
        jeelink.0	2018-08-23 17:47:30.135	info	data received: H000700250269
        Hier noch der LOG vom Update:
        log.txt
        Gruß Peer
        • F Abwesend
          F Abwesend
          foxthefox
          #145
          @C1500:
          Servus Klaus
          ` > Die OOK-Version erkennt man an:
          • Runder grüner Aufkleber im Batteriefach der Station mit dem Aufdruck "PASS A14C" `
          Gruß Peer `
          Servus Peer,
          mein Fehler, habe in der Weboberfläche wohl noch die 2 Einträge für HMS100TF und LaCrosseWS vergessen.
          Ist jetzt in github drin.
          Sofern es dir möglich ist, kannst du auch in
          /opt/ioBroker/node_modules/iobroker.jeelink/admin/index_m.html
          die vorhandene Zeile
          type
          durch
          type
          ersetzen.
          Danach in /opt/iobroker
          den Befehl:
          sudo ./iobroker upload jeelink
          absetzen.
          Dann sollte es mit dem dropdown besser sein.
          Für deine Sensoren bitte HMS100TF auswählen und für die Wetterstation LaCrosseWS.
          Bei mir kommen auch sehr viele Meldungen auf dem raspi beim Installieren vom adapter, hab da allerdings noch node 4.9.1 drauf.
          Ich nehme an das OOK nicht kompatibel mit jeelink ist?!
          Wie sieht denn das Telegramm mit ID 9 aus?
          Klaus
          Ein Aufruf: video
          • C Offline
            C1500
            #146
            Servus Klaus
            Nach dem Update kann ich jetzt die 5 Sensoren sauber auswerten.
            Das klappt schon mal super. DANKE!
            Komisch ist nur das ich anscheinend dies ID9 empfange.
            Hab die auch angelegt und bekomme da Daten und plausible Werte.
            Jetzt wird es aber etwas komisch:
            Wenn ich einen CAT /DEV/ttyUSB0 mache, ist da nix mit ID9
            H002700440262
            H002500590244
            H000100220271
            H000700250269
            H000001100700
            H005400440260
            H002500590244
            H002700440262
            H000100220271
            H002500590244
            H000700250269
            H005400450260
            H000100220271
            H005400440260
            H000700250269
            H002500580244
            H005400440260
            H000100220271
            H002700440262
            H002500580244
            H005400440260
            Woher auch immer diese ID9 die Daten bekommt
            Leider aber anscheinend auch nix von der Wetterstation.
            Ich werde nachher auch noch mal genauer nach dem OOK suchen.
            Fürchte aber, mal wieder Pech zu haben ;o)
            Gruß Peer
            • C Offline
              C1500
              #147
              Hi
              Ich seh auch gerade das ID25 ID27 und ID54 keine Werte bekommen (Also uid3 , uid4 und uid5)
              Stimmt das denn so mit der ID oder rechnest du noch in von HEX in DEZ um?
              Beim umrechnen komm ich aber trotzdem nicht auf 9 :shock:
              Gruß Peer
              EDIT:
              Hier noch der LOG von ID9 bzw. uid6
              jeelink.0	2018-08-23 19:39:18.650	info	stateChange jeelink.0.HMS100TF_6.abshumid {"val":13.1,"ack":true,"ts":1535045958633,"q":0,"from":"system.adapter.jeelink.0","lc":1535045958633}
              jeelink.0	2018-08-23 19:39:18.650	info	stateChange jeelink.0.HMS100TF_6.humid {"val":59,"ack":true,"ts":1535045958632,"q":0,"from":"system.adapter.jeelink.0","lc":1535045958632}
              jeelink.0	2018-08-23 19:39:18.650	info	stateChange jeelink.0.HMS100TF_6.temp {"val":24.4,"ack":true,"ts":1535045958632,"q":0,"from":"system.adapter.jeelink.0","lc":1535045568865}
              jeelink.0	2018-08-23 19:39:18.650	info	stateChange jeelink.0.HMS100TF_6.lowBatt {"val":0,"ack":true,"ts":1535045958631,"q":0,"from":"system.adapter.jeelink.0","lc":1535043737124}
              jeelink.0	2018-08-23 19:39:16.288	info	stateChange jeelink.0.HMS100TF_6.dewpoint {"val":16.4,"ack":true,"ts":1535045956272,"q":0,"from":"system.adapter.jeelink.0","lc":1535045956272}
              • F Abwesend
                F Abwesend
                foxthefox
                #148
                @C1500:
                Hi
                filename="jeelink2.png" index="0">~~
                Gruß Peer `
                Servus Peer,
                Ich denke das hängt damit zusammen, dass es 2stellige Zahlen sind. Da hatte ich beim coden schon gedacht, ob das man klappt.
                Scheinbar also nicht.
                Ich fixe das und geb Bescheid.
                Es ist zumindest auch gut zu wissen, das die neue Version vom serial link sauber arbeitet.
                Falls es mit ook nicht kompatibel ist, dann hoffe ich mal das Pearl auch Rücksendungen akzeptiert.
                Klaus
                Ein Aufruf: video
                • F Abwesend
                  F Abwesend
                  foxthefox
                  #149
                  Servus Peer,
                  das mit der 9 sollte sich erledigt haben ist die Summe aus 5+4 und steht für den 54er sensor.
                  Habs in github verbessert.
                  gruß
                  Klaus
                  Ein Aufruf: video
                  • C Offline
                    C1500
                    #150
                    Servus Klaus
                    jap, jetzt klappt es.
                    Alle 5 Thermostate werden korrekt ausgewertet.
                    Was das Rücksenden angeht, war ich da wohl etwas voreilig mit dem Aufbauen. Da hätte ich lieber noch warten sollen.
                    Ich hab mir jetzt einen noch einen Sender für das WS1600 besorgt.
                    Angeblich ist der kompatibel und vor allem mit dem richtigen Protokoll.
                    Sobald der da ist, werde ich weiter testen. Dauert aber noch ein paar Tage
                    Hoffentlich funktionieren dann daran die Sensoren auch problemlos.
                    Gruß Peer
                    • N Offline
                      N Offline
                      Nopax
                      #151
                      Hallo Klaus,
                      ich plane gerade den Wechsel von Fhem komplett rüber zu IOBroker.
                      In Fhem habe ich neben einigen Temperatursensoren (Technoline) auch die sehr sehr praktischen EC3000 Energiemess Steckdosen in Verwendung.
                      Habe mich sehr gefreut das es einen Jeelink Adapter in IOBroker gibt (vielen Dank dafür), allerdings habe ich gerade erst gesehen das die EC3000 Steckdosen leider nicht unterstützt werden.
                      Kannst du sagen ob diese noch implementiert werden?
                      Vielen Dank
                      Christian
                      • F Abwesend
                        F Abwesend
                        foxthefox
                        #152
                        @Nopax:
                        Hallo Klaus,
                        Vielen Dank
                        Christian `
                        Hallo Christian,
                        Ich denke da lässt sich was machen. Ich habe eine Aufschlüsselung für EM7170 gefunden. Also wenn sich die Steckdosen beim jeelink mit OK EM7170… melden, dann geht die Implementierung sehr schnell.
                        Klaus
                        Ein Aufruf: video
                          der_Auge
                          #153
                          Hallo Klaus,
                          ich sehe das du noch fleißig an der Weiterentwicklung arbeitest.
                          In meinem Produktiv-System läuft noch die Version 0.0.4
                          Nun habe ich gesehen, dass du bereits bei der Version 0.0.6 bist.
                          Warum bekomme ich es nicht als Update angezeigt?
                          Jürgen
                          PS: Es läuft einfauch nur SUPER
                          Master: DN2820FYKH (4GB) Linux NUC 4.4.0-22-generic #40-Ubuntu x86_64
                          Slave: Linux RPi2-1 4.1.19-v7+ #858 v4.4.3 # 2.15.1
                          SQL-DB : Linux DS 3.10.77 #7321 x86_64 synology412+
                          Test : DS916+ VM Debian
                          Test : Tinker mit piVCCU
                          • C Offline
                            C1500
                            #154
                            Servus
                            Ist noch nicht im Update, vermutlich auch, weil ich ihn die ganze Zeit wegen der WS1600 Wetterstation belästigt habe.
                            Dies aber mit hervorragendem Erfolg. Nochmal vielen Dank für die Hilfe und Unterstützung.
                            Jap, die WS1600 die es aktuell bei https://www.amazon.de/Technoline-WS-Wettercenter-Wetterstation-schwarz-silber/dp/B00185OGWY/ref=sr_1_1?ie=UTF8&qid=1536295517&sr=8-1&keywords=ws1600 gibt, ist voll integriert.
                            Windrichtung, Windstärke, Böe, Regenmenge, Luftfeuchtigkeit, Taupunkt, Abs. Luftfeuchte, Temperatur wird alles empfangen bzw ausgewertet.
                            Da die WS1600 aber eine andere Datenrate verwendet muss der JeeLink dementsprechende entweder in den Toggel-Modus gesetzt werden, oder so wie ich es gemacht habe, einen zweiten RFM bekommen.
                            Die Idee stammt aus dem SuperJee Threat im FHEM Forum.
                            Allerdings klappt das mit dem JeeLink V3 nicht direkt, da hier der CS des FlashIC an dem Port angeschlossen ist, der für den zweiten RFM in der Software verwendet wird.
                            Ich hab die Software dann auf Pin7 umgelegt, und dort dann des CS des zweiten RFM angeschlossen.
                            Dann noch mit 2mm Raster ein paar Stiftleisten in den ersten RFM gelötet und per Draht den CS des Zweiten an den Atmega328.
                            Und schwups… schon empfängt man beide Datenraten gleichzeitig und verpasst auf keinen Fall mehr die böse Böe ;o)
                            Eine Sache gibt es noch mit der Regenmenge.
                            Diese wird vom Sensor nur addiert. Er zählt also nur hoch.
                            Hier bräuchte ich noch ne gute Idee wie ich fortlaufend die Änderung der letzten Stunde als Wert ausgeben kann.
                            Also immer den Wert mit dem vor einer Stunde vergleichen und die Differenz dann in eine Variabel.
                            Aber wo speichert man die Werte eine Stunde lang?
                            Es kann auch sein, das sich die Werte eine Stunde lang nicht ändern, wenn es zum beispiel gar nicht regnet. (Ja soll auch vorkommen)
                            Soweit ich es an den Logfiles aber sehen konnte wird die Regenmenge doch relativ zyklisch übertragen.
                            Vielen Dank noch mal an Klaus für seine Geduld und Unterstützung!
                            Gruß Peer
                              der_Auge
                              #155
                              @C1500:
                              Da die WS1600 aber eine andere Datenrate `
                              Was ist da anders?
                              Was muss eingestellt werden?
                              Ist das nicht mit einem zweiten Stick und einer weiteren Instanz möglich?
                              Haben alle 3 Geräte die an WS1600 angebunden werden eine eigene Batterie und einen eigenen Übertragungs-Datensatz?
                              Jürgen
                              EDIT:
                              Außensender TX22, Regensensor TX23 und Windsensor TX26,
                              Station: Abmaße: 165 x 31 x 142 mm # Stromversorgung: 3 x AA Mignon LR06 (nicht inklusive)
                              Außensender WS22: Abmaße: 60 x 73 x 121 mm # Stromversorgung: 2 x AA Mignon LR06 (nicht inklusive)
                              Außensender WS23: Abmaße: 250 x 164 x 193 mm
                              Außensender WS26: Abmaße: 140 x 70 x 137 mm
                              Übertragungsfrequenz: 868 MHz
                              Übertragungsreichweite: 100 m
                              • C Offline
                                C1500
                                #156
                                Servus Jürgen,
                                Die meisten Sensoren arbeiten mit 17.241 kbps, die WS1600 aber mit 8.842 kbps
                                m: toggle mode
                                bits: 1= 17.241 kbps, 2= 9.579 kbps, 4= 8.842 kbps
                                Durch "echo '5m 30t' > /dev/ttyUSB0" kann der Stick in den Toggel-Modus zwischen den beiden Datenraten gesetzt werden.
                                Er wechselt dann alle 30 Sekunden zwischen den Datenraten.
                                Theoretisch könnte man auch 2 Sticks verwenden, braucht dann aber wie du schon schreibst 2 Instanzen vom Adapter.
                                Hab ich aber nie Probiert, hab nur einen Stick.
                                Einfacher und erheblich günstiger (~5€ für den zweiten RFM) ist da die Umbau Variante.
                                @Christian: Der EM7170 und vermutlich auch der EC3000 arbeiten mit einer Datenrate von 9.579 kbps
                                Gruß Peer
                                • N Offline
                                  N Offline
                                  Nopax
                                  #157
                                  @foxthefox:
                                  Hallo Christian,
                                  Klaus
                                  Gesendet von iPhone mit Tapatalk `
                                  Das hört sich gut an, wäre schade die EC3000 nicht weiter nutzen zu können.
                                  Im Moment lese ich diese in Fhem über das LaCrosse Gateway ein, würde mir dann aber für IOBroker einen Jeelink Stick kaufen,
                                  obwohl das LaCross Gateway schon sehr genial ist, da über Wlan, und so gut positioniert werden konnte.
                                  Brauche ich einen bestimmten Jeelink? (v3x oder classic oder Nachbau)
                                  Christian
                                  • C Offline
                                    C1500
                                    #158
                                    Servus Zusammen
                                    Ich wollte nur ein kleines Update geben
                                    Mein Stick ist nun ein fertiger SuperJee
                                    Ich hab 2x RFM69CW und 1x BMP180 verbaut
                                    Somit kann ich jetzt beide Datenraten und den aktuellen Luftdruck in ioBroker verarbeiten.
                                    Ich hab dann auch gleich die von den Katzen zerkaute Antenne gegen neue Lamda/2 getauscht.
                                    Und so schaut das ganze aus:
                                    @Christian, ich hab als Basis den normalen JeeLink V3 genommen da hier der FTDI mit drauf ist.
                                    @Klaus: Test mit dem BMP180 kommt heute Abend. Auf der RS232 seh ich schon Daten "OK WS 0 …"
                                    Gruß Peer
                                    • F Abwesend
                                      F Abwesend
                                      foxthefox
                                      #159
                                      Servus Peer,
                                      bin gespannt ob der BMP180 nicht jetzt schon läuft.
                                      Servus Christian,
                                      ich habe auf GitHub das EC3000 und EMT7110 mit aufgenommen, da ich solche Geräte nicht besitze bin ich auf Testberichte angewiesen.
                                      Ich denke der jeelinkv3, so wie ihn auch Peer benutzt sollte passen. Er bekommt ohnehin ein angepasstes Flash um die verschiedensten Dinge empfangen zu können.
                                      Falls du ihn dann haben solltest wäre ein paralleler Empfang in IoBroker und FHEM möglich, so daß man dann die empfangenen Datenpakete verifizieren könnte.
                                      Ohnehin wäre es gut von EC3000 ein paar Rohdaten mit Auswertung, wie der jeelink sie empfängt und was es dann bedeutet, zu bekommen.
                                      Bin auf Rückmeldungen gespannt.
                                      Klaus
                                      Ein Aufruf: video
                                      • C Offline
                                        C1500
                                        #160
                                        Servus Klaus
                                        Sorry, hab vor Begeisterung glatt vergessen zu schreiben das der BMP180 natürlich schon und vor allem Problemlos funktioniert.
                                        Wenn jetzt noch das senden der Befehle bei Initialisierung des JeeLink funktionieren würde, könnte man die Höhe über NormalNull mit übergeben und somit die Abweichung von 4-5 mPh korigieren.
                                        Freu mich schon auf deine Ideen zur Regenmenge ;o)
                                        War ja gestern Abend "Testwetter"
                                        Gruß Peer
                                        • P Offline
                                          peterchen88
                                          #161
                                          Hallo, wie bekommt man den JeeLink in den toggle mode ?
                                          ` > m: toggle mode
                                          Er wechselt dann alle 30 Sekunden zwischen den Datenraten. `
