  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер Telegram Adapter
    5.9k
Geplant Angeheftet Gesperrt Verschoben ioBroker драйвера
55 Beiträge 20 Kommentatoren 23.5k Aufrufe
    smoker_vvo
    Обновил драйвер, да же настроил прокси…...
    Но вы итоге......
    ! host.GoldFish2 2018-05-01 19:57:28.888 info instance system.adapter.telegram.0 started with pid 7164
    ! host.GoldFish2 2018-05-01 19:57:27.868 info Restart adapter system.adapter.telegram.0 because enabled
    ! host.GoldFish2 2018-05-01 19:57:27.868 error instance system.adapter.telegram.0 terminated with code 0 (OK)
    ! host.GoldFish2 2018-05-01 19:57:27.868 error Caught by controller[1]: port: 443 }
    ! host.GoldFish2 2018-05-01 19:57:27.868 error Caught by controller[1]: address: '88.212.233.100',
    ! host.GoldFish2 2018-05-01 19:57:27.868 error Caught by controller[1]: syscall: 'connect',
    ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: errno: 'ETIMEDOUT',
    ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: code: 'ETIMEDOUT',
    ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1087:14)
    ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: at exports._exceptionWithHostPort (util.js:1045:20)
    ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: at Object.exports._errnoException (util.js:1022:11)
    ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: { Error: connect ETIMEDOUT 88.212.233.100:443
    ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: port: 443 }
    ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: address: '88.212.233.100',
    ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: syscall: 'connect',
    ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[0]: See https://github.com/yagop/node-telegram- … issues/319. at module.js:570:32
    ! host.GoldFish2 2018-05-01 19:57:27.866 error Caught by controller[0]: In the future, you will have to enable it yourself.
    ! host.GoldFish2 2018-05-01 19:57:27.866 error Caught by controller[0]: Tue, 01 May 2018 09:57:05 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
    ! telegram.0 2018-05-01 19:57:27.354 error Error: connect ETIMEDOUT 88.212.233.100:443 at Object.exports._errnoException (util.js:1022:11) at exports._exceptionWithHostPort (util.js:1045:20) at TCPConnectWrap.afterConnect [as oncom
    ! telegram.0 2018-05-01 19:57:27.354 error uncaught exception: connect ETIMEDOUT 88.212.233.100:443
    ! telegram.0 2018-05-01 19:57:27.353 error uncaught exception: connect ETIMEDOUT 88.212.233.100:443
    ! telegram.0 2018-05-01 19:57:06.323 info starting. Version 1.2.3 in C:/ioBroker/node_modules/iobroker.telegram, node: v6.9.5
    ! host.GoldFish2 2018-05-01 19:56:56.386 info instance system.adapter.telegram.0 started with pid 7240
    ! host.GoldFish2 2018-05-01 19:56:55.357 info Restart adapter system.adapter.telegram.0 because enabled
    Куда рыть дальше??? Или какой прокси использовать??
    • ViRV Offline
      ViRV Offline
      ViR
      Добрый день тоже сыпятся ошибки при настройки прокси:
      ! host.orangepipcplus 2018-05-09 12:22:13.425 error instance system.adapter.telegram.0 terminated with code 0 (OK)
      ! Caught 2018-05-09 12:22:13.425 error by controller[3]: at TCP.onread (net.js:607:20) code: 'EAUTHNOTSUPPORT' }
      ! Caught 2018-05-09 12:22:13.425 error by controller[3]: at Socket.Readable.push (_stream_readable.js:208:10)
      ! Caught 2018-05-09 12:22:13.425 error by controller[3]: at readableAddChunk (_stream_readable.js:250:11)
      ! Caught 2018-05-09 12:22:13.424 error by controller[3]: at addChunk (_stream_readable.js:263:12)
      ! Caught 2018-05-09 12:22:13.424 error by controller[3]: at Socket.emit (events.js:211:7)
      ! Caught 2018-05-09 12:22:13.424 error by controller[3]: at emitOne (events.js:116:13)
      ! Caught 2018-05-09 12:22:13.424 error by controller[3]: at Socket.Parser.__onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:33:10)
      ! Caught 2018-05-09 12:22:13.423 error by controller[3]: at Parser._onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:85:14)
      ! Caught 2018-05-09 12:22:13.423 error by controller[3]: at Parser.emit (events.js:211:7)
      ! Caught 2018-05-09 12:22:13.423 error by controller[3]: at emitOne (events.js:116:13)
      ! Caught 2018-05-09 12:22:13.423 error by controller[3]: at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.js:102:15)
      ! Caught 2018-05-09 12:22:13.422 error by controller[3]: { Error: Authentication method mismatch
      ! Caught 2018-05-09 12:22:13.422 error by controller[2]: at TCP.onread (net.js:607:20) code: 'EAUTHNOTSUPPORT' }
      ! Caught 2018-05-09 12:22:13.422 error by controller[2]: at Socket.Readable.push (_stream_readable.js:208:10)
      ! Caught 2018-05-09 12:22:13.422 error by controller[2]: at readableAddChunk (_stream_readable.js:250:11)
      ! Caught 2018-05-09 12:22:13.421 error by controller[2]: at addChunk (_stream_readable.js:263:12)
      ! Caught 2018-05-09 12:22:13.421 error by controller[2]: at Socket.emit (events.js:211:7)
      ! Caught 2018-05-09 12:22:13.421 error by controller[2]: at emitOne (events.js:116:13)
      ! Caught 2018-05-09 12:22:13.421 error by controller[2]: at Socket.Parser.__onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:33:10)
      ! Caught 2018-05-09 12:22:13.420 error by controller[2]: at Parser._onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:85:14)
      ! Caught 2018-05-09 12:22:13.420 error by controller[2]: at Parser.emit (events.js:211:7)
      ! Caught 2018-05-09 12:22:13.420 error by controller[2]: at emitOne (events.js:116:13)
      ! Caught 2018-05-09 12:22:13.420 error by controller[2]: at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.js:102:15)
      ! Caught 2018-05-09 12:22:13.420 error by controller[2]: { Error: Authentication method mismatch
      ! Caught 2018-05-09 12:22:13.419 error by controller[1]: at TCP.onread (net.js:607:20) code: 'EAUTHNOTSUPPORT' }
      ! Caught 2018-05-09 12:22:13.419 error by controller[1]: at Socket.Readable.push (_stream_readable.js:208:10)
      ! Caught 2018-05-09 12:22:13.419 error by controller[1]: at readableAddChunk (_stream_readable.js:250:11)
      ! Caught 2018-05-09 12:22:13.419 error by controller[1]: at addChunk (_stream_readable.js:263:12)
      ! Caught 2018-05-09 12:22:13.418 error by controller[1]: at Socket.emit (events.js:211:7)
      ! Caught 2018-05-09 12:22:13.418 error by controller[1]: at emitOne (events.js:116:13)
      ! Caught 2018-05-09 12:22:13.418 error by controller[1]: at Socket.Parser.__onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:33:10)
      ! Caught 2018-05-09 12:22:13.418 error by controller[1]: at Parser._onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:85:14)
      ! Caught 2018-05-09 12:22:13.417 error by controller[1]: at Parser.emit (events.js:211:7)
      ! Caught 2018-05-09 12:22:13.417 error by controller[1]: at emitOne (events.js:116:13)
      ! Caught 2018-05-09 12:22:13.417 error by controller[1]: at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.js:102:15)
      ! Caught 2018-05-09 12:22:13.417 error by controller[1]: { Error: Authentication method mismatch
      ! Caught 2018-05-09 12:22:13.416 error by controller[0]: See https://github.com/yagop/node-telegram- … issues/319. at module.js:652:30
      ! Caught 2018-05-09 12:22:13.416 error by controller[0]: In the future, you will have to enable it yourself.
      ! Caught 2018-05-09 12:22:13.415 error by controller[0]: Wed, 09 May 2018 02:22:11 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
      ! telegram.0 2018-05-09 12:22:13.324 info terminating
      ! telegram.0 2018-05-09 12:22:12.816 error at TCP.onread (net.js:607:20)
      ! telegram.0 2018-05-09 12:22:12.816 error at Socket.Readable.push (_stream_readable.js:208:10)
      ! telegram.0 2018-05-09 12:22:12.816 error at readableAddChunk (_stream_readable.js:250:11)
      ! telegram.0 2018-05-09 12:22:12.816 error at addChunk (_stream_readable.js:263:12)
      ! telegram.0 2018-05-09 12:22:12.816 error at Socket.emit (events.js:211:7)
      ! telegram.0 2018-05-09 12:22:12.816 error at emitOne (events.js:116:13)
      ! telegram.0 2018-05-09 12:22:12.816 error at Socket.Parser.__onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:33:10)
      ! telegram.0 2018-05-09 12:22:12.816 error at Parser._onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:85:14)
      ! telegram.0 2018-05-09 12:22:12.816 error at Parser.emit (events.js:211:7)
      ! telegram.0 2018-05-09 12:22:12.816 error at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.js:102:15)
      ! telegram.0 2018-05-09 12:22:12.816 error Error: Authentication method mismatch
      ! telegram.0 2018-05-09 12:22:12.815 error uncaught exception: Authentication method mismatch
      ! telegram.0 2018-05-09 12:22:12.809 error at TCP.onread (net.js:607:20)
      ! telegram.0 2018-05-09 12:22:12.809 error at Socket.Readable.push (_stream_readable.js:208:10)
      ! telegram.0 2018-05-09 12:22:12.809 error at readableAddChunk (_stream_readable.js:250:11)
      ! telegram.0 2018-05-09 12:22:12.809 error at addChunk (_stream_readable.js:263:12)
      ! telegram.0 2018-05-09 12:22:12.809 error at Socket.emit (events.js:211:7)
      ! telegram.0 2018-05-09 12:22:12.809 error at emitOne (events.js:116:13)
      ! telegram.0 2018-05-09 12:22:12.809 error at Socket.Parser.__onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:33:10)
      ! telegram.0 2018-05-09 12:22:12.809 error at Parser._onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:85:14)
      ! telegram.0 2018-05-09 12:22:12.809 error at Parser.emit (events.js:211:7)
      ! telegram.0 2018-05-09 12:22:12.809 error at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.js:102:15)
      ! telegram.0 2018-05-09 12:22:12.809 error Error: Authentication method mismatch
      ! telegram.0 2018-05-09 12:22:12.808 error uncaught exception: Authentication method mismatch
      ! telegram.0 2018-05-09 12:22:12.798 error at TCP.onread (net.js:607:20)
      ! telegram.0 2018-05-09 12:22:12.798 error at Socket.Readable.push (_stream_readable.js:208:10)
      ! telegram.0 2018-05-09 12:22:12.798 error at readableAddChunk (_stream_readable.js:250:11)
      ! telegram.0 2018-05-09 12:22:12.798 error at addChunk (_stream_readable.js:263:12)
      ! telegram.0 2018-05-09 12:22:12.798 error at Socket.emit (events.js:211:7)
      ! telegram.0 2018-05-09 12:22:12.798 error at emitOne (events.js:116:13)
      ! telegram.0 2018-05-09 12:22:12.798 error at Socket.Parser.__onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:33:10)
      ! telegram.0 2018-05-09 12:22:12.798 error at Parser._onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:85:14)
      ! telegram.0 2018-05-09 12:22:12.798 error at Parser.emit (events.js:211:7)
      ! telegram.0 2018-05-09 12:22:12.798 error at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.js:102:15)
      ! telegram.0 2018-05-09 12:22:12.798 error Error: Authentication method mismatch
      ! telegram.0 2018-05-09 12:22:12.796 error uncaught exception: Authentication method mismatch</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
      Кто подскажет где копать?
      • goofykG Offline
        goofykG Offline
        goofyk
        Похоже, что-то не так с прокси.
        Попробуй такой прокси:
        Server: socks.kuzmitch.ru
        Port: 1080
        User: socksuser
        Pass: heropass2
        • ViRV Offline
          ViRV Offline
          ViR
          @goofyk:
          Port: 1080
          User: socksuser
          Pass: heropass2 `
          И с этим не хотит но ошибка уже другая, такая же как и без прокси
          ! telegram.0 2018-05-11 04:33:59.911 error polling_error:EFATAL, EFATAL: Error: self signed certificate
          ! telegram.0 2018-05-11 04:33:58.560 info starting. Version 1.2.3 in /opt/iobroker/node_modules/iobroker.telegram, node: v8.11.1
          причем когда останавливаешь бота Telegramm сыпятся ошибки
          ! host.orangepipcplus 2018-05-11 04:54:45.766 info instance system.adapter.telegram.0 terminated with code 0 (OK)
          ! Caught 2018-05-11 04:54:45.766 error by controller[1]: at process._tickCallback (internal/process/next_tick.js:180:9)
          ! Caught 2018-05-11 04:54:45.765 error by controller[1]: at _combinedTickCallback (internal/process/next_tick.js:138:11)
          ! Caught 2018-05-11 04:54:45.765 error by controller[1]: at emitErrorNT (internal/streams/destroy.js:64:8)
          ! Caught 2018-05-11 04:54:45.765 error by controller[1]: at TLSSocket.emit (events.js:211:7)
          ! Caught 2018-05-11 04:54:45.765 error by controller[1]: at emitOne (events.js:116:13)
          ! Caught 2018-05-11 04:54:45.764 error by controller[1]: at TLSSocket.socketErrorListener (_http_client.js:387:9)
          ! Caught 2018-05-11 04:54:45.764 error by controller[1]: at ClientRequest.emit (events.js:211:7)
          ! Caught 2018-05-11 04:54:45.764 error by controller[1]: at emitOne (events.js:116:13)
          ! Caught 2018-05-11 04:54:45.764 error by controller[1]: at Request.onRequestError (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request/request.js:878:8)
          ! Caught 2018-05-11 04:54:45.763 error by controller[1]: at Request.emit (events.js:211:7)
          ! Caught 2018-05-11 04:54:45.763 error by controller[1]: at emitOne (events.js:116:13)
          ! Caught 2018-05-11 04:54:45.763 error by controller[1]: at self.callback (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request/request.js:186:22)
          ! Caught 2018-05-11 04:54:45.763 error by controller[1]: at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request-promise/node_modules/request-promise-
          ! Caught 2018-05-11 04:54:45.763 error by controller[1]: at Request.plumbing.callback (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request-promise/node_modules/request-promise-core/lib/
          ! Caught 2018-05-11 04:54:45.762 error by controller[1]: at new RequestError (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request-promise/node_modules/request-promise-core/lib/errors.js
          ! Caught 2018-05-11 04:54:45.762 error by controller[1]: Unhandled rejection RequestError: Error: self signed certificate
          ! Caught 2018-05-11 04:54:45.762 error by controller[1]: at process._tickCallback (internal/process/next_tick.js:180:9)
          ! Caught 2018-05-11 04:54:45.762 error by controller[1]: at _combinedTickCallback (internal/process/next_tick.js:138:11)
          ! Caught 2018-05-11 04:54:45.761 error by controller[1]: at emitErrorNT (internal/streams/destroy.js:64:8)
          ! Caught 2018-05-11 04:54:45.761 error by controller[1]: at TLSSocket.emit (events.js:211:7)
          ! Caught 2018-05-11 04:54:45.761 error by controller[1]: at emitOne (events.js:116:13)
          ! Caught 2018-05-11 04:54:45.760 error by controller[1]: at TLSSocket.socketErrorListener (_http_client.js:387:9)
          ! Caught 2018-05-11 04:54:45.760 error by controller[1]: at ClientRequest.emit (events.js:211:7)
          ! Caught 2018-05-11 04:54:45.760 error by controller[1]: at emitOne (events.js:116:13)
          ! Caught 2018-05-11 04:54:45.759 error by controller[1]: at Request.onRequestError (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request/request.js:878:8)
          ! Caught 2018-05-11 04:54:45.759 error by controller[1]: at Request.emit (events.js:211:7)
          ! Caught 2018-05-11 04:54:45.759 error by controller[1]: at emitOne (events.js:116:13)
          ! Caught 2018-05-11 04:54:45.759 error by controller[1]: at self.callback (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request/request.js:186:22)
          ! Caught 2018-05-11 04:54:45.758 error by controller[1]: at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request-promise/node_modules/request-promise-
          ! Caught 2018-05-11 04:54:45.758 error by controller[1]: at Request.plumbing.callback (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request-promise/node_modules/request-promise-core/lib/
          ! Caught 2018-05-11 04:54:45.758 error by controller[1]: at new RequestError (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request-promise/node_modules/request-promise-core/lib/errors.js
          ! Caught 2018-05-11 04:54:45.758 error by controller[1]: Unhandled rejection RequestError: Error: self signed certificate
          ! Caught 2018-05-11 04:54:45.757 error by controller[0]: See https://github.com/yagop/node-telegram- … issues/319. at module.js:652:30
          ! Caught 2018-05-11 04:54:45.757 error by controller[0]: In the future, you will have to enable it yourself.
          ! Caught 2018-05-11 04:54:45.756 error by controller[0]: Thu, 10 May 2018 18:54:28 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
          • goofykG Offline
            goofykG Offline
            goofyk
            как будто кто-то сертификат подменяет… уж не провайдер ли...
            даже не знаю почему так.
            • aurodionovA Offline
              aurodionovA Offline
              aurodionov
              у меня драйвер даже через впн не пошел, горит жёлтый и нихрена не работает
              Пишу с пульта….
              • goofykG Offline
                goofykG Offline
                goofyk
                видать провайдер-провайдеру рознь.
                у меня на Мегафоне и РТ через прокси нормально работают боты
                  aurodionovA Offline
                  aurodionov
                  у меня один из пров РТ. не работает и всё
                  Пишу с пульта….
                  • ViRV Offline
                    ViRV Offline
                    ViR
                    Так и не появилось решение, пробовал через Tor тоже не получилось?
                      andrey1509
                      Здравствуйте все.
                      Пытаюсь подключить Telegram.
                      Что сделал. Установил драйвер. Зашел в https://web.telegram.org получил API ключ , дальше
                      попытался получить пароль , не пойму как.
                      На системе ( У меня Кубик) установил SOCKS5 (dante-server). Запустился вроде работает.
                      Выхожу в мир через Keenetic ADSL, порт TCP пробросил
                      Как это все увязать до кучи мозгов не хватает. Помогите пожалуйста.
                      При запуске telegram.0 в логе получаю ошибки:
                      ! Caught by controller[0]: Sat, 01 Sep 2018 13:14:39 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
                      ! 2018-09-01 16:14:41.959 - [31merror[39m: Caught by controller[0]: In the future, you will have to enable it yourself.
                      ! 2018-09-01 16:14:41.959 - [31merror[39m: Caught by controller[0]: See https://github.com/yagop/node-telegram- … issues/319. at internal/modules/cjs/loader.js:689:30
                      ! 2018-09-01 16:14:41.960 - [31merror[39m: Caught by controller[1]: { Error: connection not allowed by ruleset
                      ! 2018-09-01 16:14:41.960 - [31merror[39m: Caught by controller[1]: at Parser._onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:122:21)
                      ! 2018-09-01 16:14:41.960 - [31merror[39m: Caught by controller[1]: at Socket.Parser.__onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:33:10)
                      ! 2018-09-01 16:14:41.960 - [31merror[39m: Caught by controller[1]: at Socket.emit (events.js:182:13)
                      ! 2018-09-01 16:14:41.961 - [31merror[39m: Caught by controller[1]: at addChunk (_stream_readable.js:283:12)
                      ! 2018-09-01 16:14:41.961 - [31merror[39m: Caught by controller[1]: at readableAddChunk (_stream_readable.js:264:11)
                      ! 2018-09-01 16:14:41.961 - [31merror[39m: Caught by controller[1]: at Socket.Readable.push (_stream_readable.js:219:10)
                      ! 2018-09-01 16:14:41.961 - [31merror[39m: Caught by controller[1]: at TCP.onread (net.js:639:20) code: 'EACCES' }
                      ! 2018-09-01 16:14:41.962 - [31merror[39m: Caught by controller[2]: { Error: connection not allowed by ruleset
                      ! 2018-09-01 16:14:41.962 - [31merror[39m: Caught by controller[2]: at Parser._onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:122:21)
                      ! 2018-09-01 16:14:41.962 - [31merror[39m: Caught by controller[2]: at Socket.Parser.__onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:33:10)
                      ! 2018-09-01 16:14:41.962 - [31merror[39m: Caught by controller[2]: at Socket.emit (events.js:182:13)
                      ! 2018-09-01 16:14:41.963 - [31merror[39m: Caught by controller[2]: at addChunk (_stream_readable.js:283:12)
                      ! 2018-09-01 16:14:41.963 - [31merror[39m: Caught by controller[2]: at readableAddChunk (_stream_readable.js:264:11)
                      ! 2018-09-01 16:14:41.963 - [31merror[39m: Caught by controller[2]: at Socket.Readable.push (_stream_readable.js:219:10)
                      ! 2018-09-01 16:14:41.963 - [31merror[39m: Caught by controller[2]: at TCP.onread (net.js:639:20) code: 'EACCES' }
                      ! 2018-09-01 16:14:41.964 - [31merror[39m: Caught by controller[3]: { Error: connection not allowed by ruleset
                      ! 2018-09-01 16:14:41.964 - [31merror[39m: Caught by controller[3]: at Parser._onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:122:21)
                      ! 2018-09-01 16:14:41.964 - [31merror[39m: Caught by controller[3]: at Socket.Parser.__onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:33:10)
                      ! 2018-09-01 16:14:41.964 - [31merror[39m: Caught by controller[3]: at Socket.emit (events.js:182:13)
                      ! 2018-09-01 16:14:41.965 - [31merror[39m: Caught by controller[3]: at addChunk (_stream_readable.js:283:12)
                      ! 2018-09-01 16:14:41.965 - [31merror[39m: Caught by controller[3]: at readableAddChunk (_stream_readable.js:264:11)
                      ! 2018-09-01 16:14:41.965 - [31merror[39m: Caught by controller[3]: at Socket.Readable.push (_stream_readable.js:219:10)
                      ! 2018-09-01 16:14:41.965 - [31merror[39m: Caught by controller[3]: at TCP.onread (net.js:639:20) code: 'EACCES' }
                      ! 2018-09-01 16:14:41.966 - [31merror[39m: host.cubie instance system.adapter.telegram.0 terminated with code 0 (OK)
                      ! 2018-09-01 16:14:41.966 - [32minfo[39m: host.cubie Restart adapter system.adapter.telegram.0 because enabled
                      ! 2018-09-01 16:14:43.011 - [32minfo[39m: host.cubie instance system.adapter.telegram.0 started with pid 14390
                      ! 2018-09-01 16:14:49.076 - [32minfo[39m: telegram.0 starting. Version 1.2.7 in /opt/iobroker/node_modules/iobroker.telegram, node: v10.9.0
                      ! 2018-09-01 16:14:50.097 - [31merror[39m: telegram.0 uncaught exception: connection not allowed by ruleset
                      ! 2018-09-01 16:14:50.103 - [31merror[39m: telegram.0 Error: connection not allowed by ruleset
                      ! at Parser._onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:122:21)
                      ! at Socket.Parser.__onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:33:10)
                      ! at Socket.emit (events.js:182:13)
                      ! at addChunk (_stream_readable.js:283:12)
                      ! at readableAddChunk (_stream_readable.js:264:11)
                      ! at Socket.Readable.push (_stream_readable.js:219:10)
                      ! at TCP.onread (net.js:639:20)
                      Ходил по адресу https://github.com/yagop/node-telegram- … issues/319 , но ни чего так и не понял.
                        aurodionovA Offline
                        aurodionov
                        @andrey1509:
                        дальше
                        Ходил по адресу https://github.com/yagop/node-telegram- … issues/319 , но ни чего так и не понял. `
                        пароль задаешь свой, при конекте бот его спросит
                        Пишу с пульта….
                          andrey1509
                          @aurodionov:
                          @andrey1509:
                          дальше
                          пароль задаешь свой, при конекте бот его спросит `
                          Бот ни чего не просит.
                          В proxy пароль даю свой который в danted прописал.
                            aurodionovA Offline
                            aurodionov
                            все настройки
                            Пишу с пульта….
                              andrey1509
                              Эти настройки я делаю , но значок горит желтым.
                              В логе " telegram.0 polling_error:EFATAL, EFATAL: Error: connect ETIMEDOUT 149.154.167.220:443"
                                aurodionovA Offline
                                aurodionov
                                @andrey1509:
                                В логе " telegram.0 polling_error:EFATAL, EFATAL: Error: connect ETIMEDOUT 149.154.167.220:443" `
                                провайдер блокирует, в России у многих так
                                приходится телеграмм трафик заворачивать в впн канал, еще есть место с подменой днс
                                Пишу с пульта….
                                  andrey1509
                                  @aurodionov:
                                  @andrey1509:
                                  приходится телеграмм трафик заворачивать в впн канал, еще есть место с подменой днс `
                                  Я это из лога понял.
                                  Как это обойти?
                                  Пробую danted не получается, в логе отправляют https://github.com/yagop/node-telegram- … issues/319.
                                  А там чего делать не понятно (англицкий на уровне - ниже плинтуса :D )
                                    aurodionovA Offline
                                    aurodionov
                                    @andrey1509:
                                    @aurodionov:
                                    @andrey1509:
                                    Как это обойти?
                                    А там чего делать не понятно (англицкий на уровне - ниже плинтуса :D ) `
                                    я же написал, завернуть трафик до серверов телеги в впн и проверить что пров не подменяет днс
                                    как завернуть ….каждому свое, у меня микрот и выделенный сервер на арубе
                                    Пишу с пульта….
                                      Bosya
                                      Писал ранее. Ответ не получил. Через клиент отправляю команду боту и тут он попадает в цикл.
                                      В драйвере это видно как одинаковые комманды одна за другой. Если послать другую комманду - может остановится, а может снова уйти в цикл...
                                      stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:12:24.526	2019-05-16 09:54:33.176
                                      stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:12:24.512	2019-05-16 09:43:37.614
                                      stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:12:17.123	2019-05-16 09:54:33.176
                                      stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:12:17.109	2019-05-16 09:43:37.614
                                      stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:12:09.541	2019-05-16 09:54:33.176
                                      stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:12:09.531	2019-05-16 09:43:37.614
                                      stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:12:01.159	2019-05-16 09:54:33.176
                                      stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:12:01.148	2019-05-16 09:43:37.614
                                      stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:53.498	2019-05-16 09:54:33.176
                                      stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:53.487	2019-05-16 09:43:37.614
                                      stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:45.920	2019-05-16 09:54:33.176
                                      stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:45.900	2019-05-16 09:43:37.614
                                      stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:38.172	2019-05-16 09:54:33.176
                                      stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:38.143	2019-05-16 09:43:37.614
                                      stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:30.547	2019-05-16 09:54:33.176
                                      stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:30.529	2019-05-16 09:43:37.614
                                      stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:23.653	2019-05-16 09:54:33.176
                                      stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:23.649	2019-05-16 09:43:37.614
                                      stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:16.572	2019-05-16 09:54:33.176
                                      stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:16.549	2019-05-16 09:43:37.614
                                      stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:09.178	2019-05-16 09:54:33.176
                                      stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:09.165	2019-05-16 09:43:37.614
                                      stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:01.639	2019-05-16 09:54:33.176
                                      stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:01.630	2019-05-16 09:43:37.614
                                      stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:10:54.357	2019-05-16 09:54:33.176
                                      stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:10:54.351	2019-05-16 09:43:37.614
                                      stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:10:45.658	2019-05-16 09:54:33.176
                                      stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:10:45.646	2019-05-16 09:43:37.614
                                      stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:10:38.446	2019-05-16 09:54:33.176
                                      stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:10:38.437	2019-05-16 09:43:37.614
                                      stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:10:31.055	2019-05-16 09:54:33.176
                                      stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:10:31.036	2019-05-16 09:43:37.614
                                      Не совсем понятно что с этим делать и как остановить...
