  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер Telegram Adapter
    5.9k
Geplant Angeheftet Gesperrt Verschoben ioBroker драйвера
55 Beiträge 20 Kommentatoren 23.5k Aufrufe
  • goofykG Offline
    goofykG Offline
    goofyk
    копать сюда https://github.com/kirovilya/ioBroker.telegram
    сделал PR в основной репозиторий, ждем обновления драйвера
      smoker_vvo
      Обновил драйвер, да же настроил прокси…...
      Но вы итоге......
      ! host.GoldFish2 2018-05-01 19:57:28.888 info instance system.adapter.telegram.0 started with pid 7164
      ! host.GoldFish2 2018-05-01 19:57:27.868 info Restart adapter system.adapter.telegram.0 because enabled
      ! host.GoldFish2 2018-05-01 19:57:27.868 error instance system.adapter.telegram.0 terminated with code 0 (OK)
      ! host.GoldFish2 2018-05-01 19:57:27.868 error Caught by controller[1]: port: 443 }
      ! host.GoldFish2 2018-05-01 19:57:27.868 error Caught by controller[1]: address: '88.212.233.100',
      ! host.GoldFish2 2018-05-01 19:57:27.868 error Caught by controller[1]: syscall: 'connect',
      ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: errno: 'ETIMEDOUT',
      ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: code: 'ETIMEDOUT',
      ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1087:14)
      ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: at exports._exceptionWithHostPort (util.js:1045:20)
      ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: at Object.exports._errnoException (util.js:1022:11)
      ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: { Error: connect ETIMEDOUT 88.212.233.100:443
      ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: port: 443 }
      ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: address: '88.212.233.100',
      ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: syscall: 'connect',
      ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[0]: See https://github.com/yagop/node-telegram- … issues/319. at module.js:570:32
      ! host.GoldFish2 2018-05-01 19:57:27.866 error Caught by controller[0]: In the future, you will have to enable it yourself.
      ! host.GoldFish2 2018-05-01 19:57:27.866 error Caught by controller[0]: Tue, 01 May 2018 09:57:05 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
      ! telegram.0 2018-05-01 19:57:27.354 error Error: connect ETIMEDOUT 88.212.233.100:443 at Object.exports._errnoException (util.js:1022:11) at exports._exceptionWithHostPort (util.js:1045:20) at TCPConnectWrap.afterConnect [as oncom
      ! telegram.0 2018-05-01 19:57:27.354 error uncaught exception: connect ETIMEDOUT 88.212.233.100:443
      ! telegram.0 2018-05-01 19:57:27.353 error uncaught exception: connect ETIMEDOUT 88.212.233.100:443
      ! telegram.0 2018-05-01 19:57:06.323 info starting. Version 1.2.3 in C:/ioBroker/node_modules/iobroker.telegram, node: v6.9.5
      ! host.GoldFish2 2018-05-01 19:56:56.386 info instance system.adapter.telegram.0 started with pid 7240
      ! host.GoldFish2 2018-05-01 19:56:55.357 info Restart adapter system.adapter.telegram.0 because enabled
      Куда рыть дальше??? Или какой прокси использовать??
      • ViRV Offline
        ViRV Offline
        ViR
        Добрый день тоже сыпятся ошибки при настройки прокси:
        ! host.orangepipcplus 2018-05-09 12:22:13.425 error instance system.adapter.telegram.0 terminated with code 0 (OK)
        ! Caught 2018-05-09 12:22:13.425 error by controller[3]: at TCP.onread (net.js:607:20) code: 'EAUTHNOTSUPPORT' }
        ! Caught 2018-05-09 12:22:13.425 error by controller[3]: at Socket.Readable.push (_stream_readable.js:208:10)
        ! Caught 2018-05-09 12:22:13.425 error by controller[3]: at readableAddChunk (_stream_readable.js:250:11)
        ! Caught 2018-05-09 12:22:13.424 error by controller[3]: at addChunk (_stream_readable.js:263:12)
        ! Caught 2018-05-09 12:22:13.424 error by controller[3]: at Socket.emit (events.js:211:7)
        ! Caught 2018-05-09 12:22:13.424 error by controller[3]: at emitOne (events.js:116:13)
        ! Caught 2018-05-09 12:22:13.424 error by controller[3]: at Socket.Parser.__onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:33:10)
        ! Caught 2018-05-09 12:22:13.423 error by controller[3]: at Parser._onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:85:14)
        ! Caught 2018-05-09 12:22:13.423 error by controller[3]: at Parser.emit (events.js:211:7)
        ! Caught 2018-05-09 12:22:13.423 error by controller[3]: at emitOne (events.js:116:13)
        ! Caught 2018-05-09 12:22:13.423 error by controller[3]: at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.js:102:15)
        ! Caught 2018-05-09 12:22:13.422 error by controller[3]: { Error: Authentication method mismatch
        ! Caught 2018-05-09 12:22:13.422 error by controller[2]: at TCP.onread (net.js:607:20) code: 'EAUTHNOTSUPPORT' }
        ! Caught 2018-05-09 12:22:13.422 error by controller[2]: at Socket.Readable.push (_stream_readable.js:208:10)
        ! Caught 2018-05-09 12:22:13.422 error by controller[2]: at readableAddChunk (_stream_readable.js:250:11)
        ! Caught 2018-05-09 12:22:13.421 error by controller[2]: at addChunk (_stream_readable.js:263:12)
        ! Caught 2018-05-09 12:22:13.421 error by controller[2]: at Socket.emit (events.js:211:7)
        ! Caught 2018-05-09 12:22:13.421 error by controller[2]: at emitOne (events.js:116:13)
        ! Caught 2018-05-09 12:22:13.421 error by controller[2]: at Socket.Parser.__onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:33:10)
        ! Caught 2018-05-09 12:22:13.420 error by controller[2]: at Parser._onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:85:14)
        ! Caught 2018-05-09 12:22:13.420 error by controller[2]: at Parser.emit (events.js:211:7)
        ! Caught 2018-05-09 12:22:13.420 error by controller[2]: at emitOne (events.js:116:13)
        ! Caught 2018-05-09 12:22:13.420 error by controller[2]: at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.js:102:15)
        ! Caught 2018-05-09 12:22:13.420 error by controller[2]: { Error: Authentication method mismatch
        ! Caught 2018-05-09 12:22:13.419 error by controller[1]: at TCP.onread (net.js:607:20) code: 'EAUTHNOTSUPPORT' }
        ! Caught 2018-05-09 12:22:13.419 error by controller[1]: at Socket.Readable.push (_stream_readable.js:208:10)
        ! Caught 2018-05-09 12:22:13.419 error by controller[1]: at readableAddChunk (_stream_readable.js:250:11)
        ! Caught 2018-05-09 12:22:13.419 error by controller[1]: at addChunk (_stream_readable.js:263:12)
        ! Caught 2018-05-09 12:22:13.418 error by controller[1]: at Socket.emit (events.js:211:7)
        ! Caught 2018-05-09 12:22:13.418 error by controller[1]: at emitOne (events.js:116:13)
        ! Caught 2018-05-09 12:22:13.418 error by controller[1]: at Socket.Parser.__onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:33:10)
        ! Caught 2018-05-09 12:22:13.418 error by controller[1]: at Parser._onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:85:14)
        ! Caught 2018-05-09 12:22:13.417 error by controller[1]: at Parser.emit (events.js:211:7)
        ! Caught 2018-05-09 12:22:13.417 error by controller[1]: at emitOne (events.js:116:13)
        ! Caught 2018-05-09 12:22:13.417 error by controller[1]: at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.js:102:15)
        ! Caught 2018-05-09 12:22:13.417 error by controller[1]: { Error: Authentication method mismatch
        ! Caught 2018-05-09 12:22:13.416 error by controller[0]: See https://github.com/yagop/node-telegram- … issues/319. at module.js:652:30
        ! Caught 2018-05-09 12:22:13.416 error by controller[0]: In the future, you will have to enable it yourself.
        ! Caught 2018-05-09 12:22:13.415 error by controller[0]: Wed, 09 May 2018 02:22:11 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
        ! telegram.0 2018-05-09 12:22:13.324 info terminating
        ! telegram.0 2018-05-09 12:22:12.816 error at TCP.onread (net.js:607:20)
        ! telegram.0 2018-05-09 12:22:12.816 error at Socket.Readable.push (_stream_readable.js:208:10)
        ! telegram.0 2018-05-09 12:22:12.816 error at readableAddChunk (_stream_readable.js:250:11)
        ! telegram.0 2018-05-09 12:22:12.816 error at addChunk (_stream_readable.js:263:12)
        ! telegram.0 2018-05-09 12:22:12.816 error at Socket.emit (events.js:211:7)
        ! telegram.0 2018-05-09 12:22:12.816 error at emitOne (events.js:116:13)
        ! telegram.0 2018-05-09 12:22:12.816 error at Socket.Parser.__onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:33:10)
        ! telegram.0 2018-05-09 12:22:12.816 error at Parser._onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:85:14)
        ! telegram.0 2018-05-09 12:22:12.816 error at Parser.emit (events.js:211:7)
        ! telegram.0 2018-05-09 12:22:12.816 error at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.js:102:15)
        ! telegram.0 2018-05-09 12:22:12.816 error Error: Authentication method mismatch
        ! telegram.0 2018-05-09 12:22:12.815 error uncaught exception: Authentication method mismatch
        ! telegram.0 2018-05-09 12:22:12.809 error at TCP.onread (net.js:607:20)
        ! telegram.0 2018-05-09 12:22:12.809 error at Socket.Readable.push (_stream_readable.js:208:10)
        ! telegram.0 2018-05-09 12:22:12.809 error at readableAddChunk (_stream_readable.js:250:11)
        ! telegram.0 2018-05-09 12:22:12.809 error at addChunk (_stream_readable.js:263:12)
        ! telegram.0 2018-05-09 12:22:12.809 error at Socket.emit (events.js:211:7)
        ! telegram.0 2018-05-09 12:22:12.809 error at emitOne (events.js:116:13)
        ! telegram.0 2018-05-09 12:22:12.809 error at Socket.Parser.__onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:33:10)
        ! telegram.0 2018-05-09 12:22:12.809 error at Parser._onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:85:14)
        ! telegram.0 2018-05-09 12:22:12.809 error at Parser.emit (events.js:211:7)
        ! telegram.0 2018-05-09 12:22:12.809 error at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.js:102:15)
        ! telegram.0 2018-05-09 12:22:12.809 error Error: Authentication method mismatch
        ! telegram.0 2018-05-09 12:22:12.808 error uncaught exception: Authentication method mismatch
        ! telegram.0 2018-05-09 12:22:12.798 error at TCP.onread (net.js:607:20)
        ! telegram.0 2018-05-09 12:22:12.798 error at Socket.Readable.push (_stream_readable.js:208:10)
        ! telegram.0 2018-05-09 12:22:12.798 error at readableAddChunk (_stream_readable.js:250:11)
        ! telegram.0 2018-05-09 12:22:12.798 error at addChunk (_stream_readable.js:263:12)
        ! telegram.0 2018-05-09 12:22:12.798 error at Socket.emit (events.js:211:7)
        ! telegram.0 2018-05-09 12:22:12.798 error at emitOne (events.js:116:13)
        ! telegram.0 2018-05-09 12:22:12.798 error at Socket.Parser.__onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:33:10)
        ! telegram.0 2018-05-09 12:22:12.798 error at Parser._onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:85:14)
        ! telegram.0 2018-05-09 12:22:12.798 error at Parser.emit (events.js:211:7)
        ! telegram.0 2018-05-09 12:22:12.798 error at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.js:102:15)
        ! telegram.0 2018-05-09 12:22:12.798 error Error: Authentication method mismatch
        ! telegram.0 2018-05-09 12:22:12.796 error uncaught exception: Authentication method mismatch</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
        Кто подскажет где копать?
        • goofykG Offline
          goofykG Offline
          goofyk
          Похоже, что-то не так с прокси.
          Попробуй такой прокси:
          Server: socks.kuzmitch.ru
          Port: 1080
          User: socksuser
          Pass: heropass2
          • ViRV Offline
            ViRV Offline
            ViR
            @goofyk:
            Port: 1080
            User: socksuser
            Pass: heropass2 `
            И с этим не хотит но ошибка уже другая, такая же как и без прокси
            ! telegram.0 2018-05-11 04:33:59.911 error polling_error:EFATAL, EFATAL: Error: self signed certificate
            ! telegram.0 2018-05-11 04:33:58.560 info starting. Version 1.2.3 in /opt/iobroker/node_modules/iobroker.telegram, node: v8.11.1
            причем когда останавливаешь бота Telegramm сыпятся ошибки
            ! host.orangepipcplus 2018-05-11 04:54:45.766 info instance system.adapter.telegram.0 terminated with code 0 (OK)
            ! Caught 2018-05-11 04:54:45.766 error by controller[1]: at process._tickCallback (internal/process/next_tick.js:180:9)
            ! Caught 2018-05-11 04:54:45.765 error by controller[1]: at _combinedTickCallback (internal/process/next_tick.js:138:11)
            ! Caught 2018-05-11 04:54:45.765 error by controller[1]: at emitErrorNT (internal/streams/destroy.js:64:8)
            ! Caught 2018-05-11 04:54:45.765 error by controller[1]: at TLSSocket.emit (events.js:211:7)
            ! Caught 2018-05-11 04:54:45.765 error by controller[1]: at emitOne (events.js:116:13)
            ! Caught 2018-05-11 04:54:45.764 error by controller[1]: at TLSSocket.socketErrorListener (_http_client.js:387:9)
            ! Caught 2018-05-11 04:54:45.764 error by controller[1]: at ClientRequest.emit (events.js:211:7)
            ! Caught 2018-05-11 04:54:45.764 error by controller[1]: at emitOne (events.js:116:13)
            ! Caught 2018-05-11 04:54:45.764 error by controller[1]: at Request.onRequestError (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request/request.js:878:8)
            ! Caught 2018-05-11 04:54:45.763 error by controller[1]: at Request.emit (events.js:211:7)
            ! Caught 2018-05-11 04:54:45.763 error by controller[1]: at emitOne (events.js:116:13)
            ! Caught 2018-05-11 04:54:45.763 error by controller[1]: at self.callback (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request/request.js:186:22)
            ! Caught 2018-05-11 04:54:45.763 error by controller[1]: at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request-promise/node_modules/request-promise-
            ! Caught 2018-05-11 04:54:45.763 error by controller[1]: at Request.plumbing.callback (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request-promise/node_modules/request-promise-core/lib/
            ! Caught 2018-05-11 04:54:45.762 error by controller[1]: at new RequestError (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request-promise/node_modules/request-promise-core/lib/errors.js
            ! Caught 2018-05-11 04:54:45.762 error by controller[1]: Unhandled rejection RequestError: Error: self signed certificate
            ! Caught 2018-05-11 04:54:45.762 error by controller[1]: at process._tickCallback (internal/process/next_tick.js:180:9)
            ! Caught 2018-05-11 04:54:45.762 error by controller[1]: at _combinedTickCallback (internal/process/next_tick.js:138:11)
            ! Caught 2018-05-11 04:54:45.761 error by controller[1]: at emitErrorNT (internal/streams/destroy.js:64:8)
            ! Caught 2018-05-11 04:54:45.761 error by controller[1]: at TLSSocket.emit (events.js:211:7)
            ! Caught 2018-05-11 04:54:45.761 error by controller[1]: at emitOne (events.js:116:13)
            ! Caught 2018-05-11 04:54:45.760 error by controller[1]: at TLSSocket.socketErrorListener (_http_client.js:387:9)
            ! Caught 2018-05-11 04:54:45.760 error by controller[1]: at ClientRequest.emit (events.js:211:7)
            ! Caught 2018-05-11 04:54:45.760 error by controller[1]: at emitOne (events.js:116:13)
            ! Caught 2018-05-11 04:54:45.759 error by controller[1]: at Request.onRequestError (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request/request.js:878:8)
            ! Caught 2018-05-11 04:54:45.759 error by controller[1]: at Request.emit (events.js:211:7)
            ! Caught 2018-05-11 04:54:45.759 error by controller[1]: at emitOne (events.js:116:13)
            ! Caught 2018-05-11 04:54:45.759 error by controller[1]: at self.callback (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request/request.js:186:22)
            ! Caught 2018-05-11 04:54:45.758 error by controller[1]: at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request-promise/node_modules/request-promise-
            ! Caught 2018-05-11 04:54:45.758 error by controller[1]: at Request.plumbing.callback (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request-promise/node_modules/request-promise-core/lib/
            ! Caught 2018-05-11 04:54:45.758 error by controller[1]: at new RequestError (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request-promise/node_modules/request-promise-core/lib/errors.js
            ! Caught 2018-05-11 04:54:45.758 error by controller[1]: Unhandled rejection RequestError: Error: self signed certificate
            ! Caught 2018-05-11 04:54:45.757 error by controller[0]: See https://github.com/yagop/node-telegram- … issues/319. at module.js:652:30
            ! Caught 2018-05-11 04:54:45.757 error by controller[0]: In the future, you will have to enable it yourself.
            ! Caught 2018-05-11 04:54:45.756 error by controller[0]: Thu, 10 May 2018 18:54:28 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
            • goofykG Offline
              goofykG Offline
              goofyk
              как будто кто-то сертификат подменяет… уж не провайдер ли...
              даже не знаю почему так.
              • aurodionovA Offline
                aurodionovA Offline
                aurodionov
                у меня драйвер даже через впн не пошел, горит жёлтый и нихрена не работает
                Пишу с пульта….
                • goofykG Offline
                  goofykG Offline
                  goofyk
                  видать провайдер-провайдеру рознь.
                  у меня на Мегафоне и РТ через прокси нормально работают боты
                    aurodionovA Offline
                    aurodionov
                    у меня один из пров РТ. не работает и всё
                    Пишу с пульта….
                    • ViRV Offline
                      ViRV Offline
                      ViR
                      Так и не появилось решение, пробовал через Tor тоже не получилось?
                        andrey1509
                        Здравствуйте все.
                        Пытаюсь подключить Telegram.
                        Что сделал. Установил драйвер. Зашел в https://web.telegram.org получил API ключ , дальше
                        попытался получить пароль , не пойму как.
                        На системе ( У меня Кубик) установил SOCKS5 (dante-server). Запустился вроде работает.
                        Выхожу в мир через Keenetic ADSL, порт TCP пробросил
                        Как это все увязать до кучи мозгов не хватает. Помогите пожалуйста.
                        При запуске telegram.0 в логе получаю ошибки:
                        ! Caught by controller[0]: Sat, 01 Sep 2018 13:14:39 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
                        ! 2018-09-01 16:14:41.959 - [31merror[39m: Caught by controller[0]: In the future, you will have to enable it yourself.
                        ! 2018-09-01 16:14:41.959 - [31merror[39m: Caught by controller[0]: See https://github.com/yagop/node-telegram- … issues/319. at internal/modules/cjs/loader.js:689:30
                        ! 2018-09-01 16:14:41.960 - [31merror[39m: Caught by controller[1]: { Error: connection not allowed by ruleset
                        ! 2018-09-01 16:14:41.960 - [31merror[39m: Caught by controller[1]: at Parser._onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:122:21)
                        ! 2018-09-01 16:14:41.960 - [31merror[39m: Caught by controller[1]: at Socket.Parser.__onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:33:10)
                        ! 2018-09-01 16:14:41.960 - [31merror[39m: Caught by controller[1]: at Socket.emit (events.js:182:13)
                        ! 2018-09-01 16:14:41.961 - [31merror[39m: Caught by controller[1]: at addChunk (_stream_readable.js:283:12)
                        ! 2018-09-01 16:14:41.961 - [31merror[39m: Caught by controller[1]: at readableAddChunk (_stream_readable.js:264:11)
                        ! 2018-09-01 16:14:41.961 - [31merror[39m: Caught by controller[1]: at Socket.Readable.push (_stream_readable.js:219:10)
                        ! 2018-09-01 16:14:41.961 - [31merror[39m: Caught by controller[1]: at TCP.onread (net.js:639:20) code: 'EACCES' }
                        ! 2018-09-01 16:14:41.962 - [31merror[39m: Caught by controller[2]: { Error: connection not allowed by ruleset
                        ! 2018-09-01 16:14:41.962 - [31merror[39m: Caught by controller[2]: at Parser._onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:122:21)
                        ! 2018-09-01 16:14:41.962 - [31merror[39m: Caught by controller[2]: at Socket.Parser.__onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:33:10)
                        ! 2018-09-01 16:14:41.962 - [31merror[39m: Caught by controller[2]: at Socket.emit (events.js:182:13)
                        ! 2018-09-01 16:14:41.963 - [31merror[39m: Caught by controller[2]: at addChunk (_stream_readable.js:283:12)
                        ! 2018-09-01 16:14:41.963 - [31merror[39m: Caught by controller[2]: at readableAddChunk (_stream_readable.js:264:11)
                        ! 2018-09-01 16:14:41.963 - [31merror[39m: Caught by controller[2]: at Socket.Readable.push (_stream_readable.js:219:10)
                        ! 2018-09-01 16:14:41.963 - [31merror[39m: Caught by controller[2]: at TCP.onread (net.js:639:20) code: 'EACCES' }
                        ! 2018-09-01 16:14:41.964 - [31merror[39m: Caught by controller[3]: { Error: connection not allowed by ruleset
                        ! 2018-09-01 16:14:41.964 - [31merror[39m: Caught by controller[3]: at Parser._onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:122:21)
                        ! 2018-09-01 16:14:41.964 - [31merror[39m: Caught by controller[3]: at Socket.Parser.__onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:33:10)
                        ! 2018-09-01 16:14:41.964 - [31merror[39m: Caught by controller[3]: at Socket.emit (events.js:182:13)
                        ! 2018-09-01 16:14:41.965 - [31merror[39m: Caught by controller[3]: at addChunk (_stream_readable.js:283:12)
                        ! 2018-09-01 16:14:41.965 - [31merror[39m: Caught by controller[3]: at readableAddChunk (_stream_readable.js:264:11)
                        ! 2018-09-01 16:14:41.965 - [31merror[39m: Caught by controller[3]: at Socket.Readable.push (_stream_readable.js:219:10)
                        ! 2018-09-01 16:14:41.965 - [31merror[39m: Caught by controller[3]: at TCP.onread (net.js:639:20) code: 'EACCES' }
                        ! 2018-09-01 16:14:41.966 - [31merror[39m: host.cubie instance system.adapter.telegram.0 terminated with code 0 (OK)
                        ! 2018-09-01 16:14:41.966 - [32minfo[39m: host.cubie Restart adapter system.adapter.telegram.0 because enabled
                        ! 2018-09-01 16:14:43.011 - [32minfo[39m: host.cubie instance system.adapter.telegram.0 started with pid 14390
                        ! 2018-09-01 16:14:49.076 - [32minfo[39m: telegram.0 starting. Version 1.2.7 in /opt/iobroker/node_modules/iobroker.telegram, node: v10.9.0
                        ! 2018-09-01 16:14:50.097 - [31merror[39m: telegram.0 uncaught exception: connection not allowed by ruleset
                        ! 2018-09-01 16:14:50.103 - [31merror[39m: telegram.0 Error: connection not allowed by ruleset
                        ! at Parser._onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:122:21)
                        ! at Socket.Parser.__onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:33:10)
                        ! at Socket.emit (events.js:182:13)
                        ! at addChunk (_stream_readable.js:283:12)
                        ! at readableAddChunk (_stream_readable.js:264:11)
                        ! at Socket.Readable.push (_stream_readable.js:219:10)
                        ! at TCP.onread (net.js:639:20)
                        Ходил по адресу https://github.com/yagop/node-telegram- … issues/319 , но ни чего так и не понял.
                          aurodionovA Offline
                          aurodionov
                          @andrey1509:
                          дальше
                          Ходил по адресу https://github.com/yagop/node-telegram- … issues/319 , но ни чего так и не понял. `
                          пароль задаешь свой, при конекте бот его спросит
                          Пишу с пульта….
                            andrey1509
                            @aurodionov:
                            @andrey1509:
                            дальше
                            пароль задаешь свой, при конекте бот его спросит `
                            Бот ни чего не просит.
                            В proxy пароль даю свой который в danted прописал.
                              aurodionovA Offline
                              aurodionov
                              все настройки
                              Пишу с пульта….
                                andrey1509
                                Эти настройки я делаю , но значок горит желтым.
                                В логе " telegram.0 polling_error:EFATAL, EFATAL: Error: connect ETIMEDOUT 149.154.167.220:443"
                                  aurodionovA Offline
                                  aurodionov
                                  @andrey1509:
                                  В логе " telegram.0 polling_error:EFATAL, EFATAL: Error: connect ETIMEDOUT 149.154.167.220:443" `
                                  провайдер блокирует, в России у многих так
                                  приходится телеграмм трафик заворачивать в впн канал, еще есть место с подменой днс
                                  Пишу с пульта….
                                    andrey1509
                                    @aurodionov:
                                    @andrey1509:
                                    приходится телеграмм трафик заворачивать в впн канал, еще есть место с подменой днс `
                                    Я это из лога понял.
                                    Как это обойти?
                                    Пробую danted не получается, в логе отправляют https://github.com/yagop/node-telegram- … issues/319.
                                    А там чего делать не понятно (англицкий на уровне - ниже плинтуса :D )
                                      aurodionovA Offline
                                      aurodionov
                                      @andrey1509:
                                      @aurodionov:
                                      @andrey1509:
                                      Как это обойти?
                                      А там чего делать не понятно (англицкий на уровне - ниже плинтуса :D ) `
                                      я же написал, завернуть трафик до серверов телеги в впн и проверить что пров не подменяет днс
                                      как завернуть ….каждому свое, у меня микрот и выделенный сервер на арубе
                                      Пишу с пульта….
                                        Bosya
                                        Писал ранее. Ответ не получил. Через клиент отправляю команду боту и тут он попадает в цикл.
                                        В драйвере это видно как одинаковые комманды одна за другой. Если послать другую комманду - может остановится, а может снова уйти в цикл...
                                        stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:12:24.526	2019-05-16 09:54:33.176
                                        stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:12:24.512	2019-05-16 09:43:37.614
                                        stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:12:17.123	2019-05-16 09:54:33.176
                                        stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:12:17.109	2019-05-16 09:43:37.614
                                        stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:12:09.541	2019-05-16 09:54:33.176
                                        stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:12:09.531	2019-05-16 09:43:37.614
                                        stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:12:01.159	2019-05-16 09:54:33.176
                                        stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:12:01.148	2019-05-16 09:43:37.614
                                        stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:53.498	2019-05-16 09:54:33.176
                                        stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:53.487	2019-05-16 09:43:37.614
                                        stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:45.920	2019-05-16 09:54:33.176
                                        stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:45.900	2019-05-16 09:43:37.614
                                        stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:38.172	2019-05-16 09:54:33.176
                                        stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:38.143	2019-05-16 09:43:37.614
                                        stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:30.547	2019-05-16 09:54:33.176
                                        stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:30.529	2019-05-16 09:43:37.614
                                        stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:23.653	2019-05-16 09:54:33.176
                                        stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:23.649	2019-05-16 09:43:37.614
                                        stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:16.572	2019-05-16 09:54:33.176
                                        stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:16.549	2019-05-16 09:43:37.614
                                        stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:09.178	2019-05-16 09:54:33.176
                                        stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:09.165	2019-05-16 09:43:37.614
                                        stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:01.639	2019-05-16 09:54:33.176
                                        stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:01.630	2019-05-16 09:43:37.614
                                        stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:10:54.357	2019-05-16 09:54:33.176
                                        stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:10:54.351	2019-05-16 09:43:37.614
                                        stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:10:45.658	2019-05-16 09:54:33.176
                                        stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:10:45.646	2019-05-16 09:43:37.614
                                        stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:10:38.446	2019-05-16 09:54:33.176
                                        stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:10:38.437	2019-05-16 09:43:37.614
                                        stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:10:31.055	2019-05-16 09:54:33.176
                                        stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:10:31.036	2019-05-16 09:43:37.614
                                        Не совсем понятно что с этим делать и как остановить...
