  4. Abendämmerung script???
    5.8k
32 Beiträge 5 Kommentatoren 3.0k Aufrufe
    denjo
    sooo das mit meiner haus tür habe ich dank eurer hilfe schonmal hin bekommen, dankeeee
    aber das mit mein licht draußen nocht nicht so ganz, weiß jemand was falsch ist vielleicht???
    ! <xml 1999/xmlns="<URL url=" http:/www.w3.org/xhtml"="">http://www.w3.org/1999/xhtml">
    ! <block type="controls_if" id="zBZnOXSV6KbTQ7S!y.V]" x="-213" y="13"><value name="IF0"><block type="logic_operation" id="(Ok~ZD5S%[oW{qI|{8EL"><field name="OP">OR</field>
    ! <value name="A"><block type="time_compare_ex" id="V=Ead|oaeLW@0j09GWC]"><mutation end_time="true" actual_time="true"></mutation>
    ! <field name="USE_ACTUAL_TIME">TRUE</field>
    ! <field name="OPTION">between</field>
    ! <value name="START_TIME"><shadow type="text" id="V-,VYcJh)g9A:[qBO]s"><field name="TEXT">12:00</field></shadow> ! <block type="time_astro" id="+mJcR=~uSi_k.j5:%N7C"><field name="TYPE">sunset</field> ! <field name="OFFSET">0</field></block></value> ! <value name="END_TIME"><shadow type="text" id="UwkbQ]+O;Pi1/tm-zmIo"><field name="TEXT">18:00</field></shadow> ! <block type="text" id="TX%hyTOj{-HKQwi45t!#"><field name="TEXT">23:59</field></block></value></block></value> ! <value name="B"><block type="time_compare_ex" id="o,-_aZ(,hCl(G9{B%::)"><mutation end_time="true" actual_time="true"></mutation> ! <field name="USE_ACTUAL_TIME">TRUE</field> ! <field name="OPTION">between</field> ! <value name="START_TIME"><shadow type="text" id="{9?Mo8)@c%~H,f)*53b#"><field name="TEXT">12:00</field></shadow> ! <block type="text" id="y2iD5v)HNdnH~4NQR^Y"><field name="TEXT">00:01</field></block></value>
    ! <value name="END_TIME"><shadow type="text" id="{A_VNSTvO/u%5KoN(e;m"><field name="TEXT">18:00</field></shadow>
    ! <block type="time_astro" id="Ls0p_~mqt@IeN|SL,[b!"><field name="TYPE">sunrise</field>
    ! <field name="OFFSET">0</field></block></value></block></value></block></value>
    ! <statement name="DO0"><block type="control" id="f@8(fT+PbF/Iu08Nh;B"><mutation delay_input="false"></mutation>
    ! <field name="OID">broadlink.0.learnedSignals.000000.Steckdose_2C</field>
    ! <field name="WITH_DELAY">FALSE</field>
    ! <value name="VALUE"><block type="logic_boolean" id=".0W+]HIaY^B[qsaQp?jp"><field name="BOOL">TRUE</field></block></value></block></statement>
    ! <next><block type="controls_if" id="S!4zK#[K#q-(?u~HTXCX"><value name="IF0"><block type="time_compare_ex" id="Yw+dlLJ~+/,H8gPd)4"><mutation end_time="true" actual_time="true"></mutation>
    ! <value name="START_TIME"><shadow type="text" id="V-,VYcJh)g9A:[qBO]s"><field name="TEXT">12:00</field></shadow> ! <block type="time_astro" id="X2!}4(|Jc10b,*:Ic/Q"><field name="TYPE">sunrise</field>
    ! <value name="END_TIME"><shadow type="text" id="nEB9FoK{fHFH]lK_f{l:"><field name="TEXT">18:00</field></shadow>
    ! <block type="time_astro" id="P/7Ubuc-?WAZ:DqDwnEL"><field name="TYPE">sunset</field>
    ! <statement name="DO0"><block type="control" id="0moaawhJMYSaj8
    [,@Bb"><mutation delay_input="false"></mutation>
    ! <value name="VALUE"><block type="logic_boolean" id="tt~Dr3Kt]vO(dV%a9Y3h"><field name="BOOL">FALSE</field></block></value></block></statement></block></next></block></xml>
    • J Offline
      Jan1
      Mach doch mal ein Screenshot vom Blockly
        denjo
        am ende steht sonnen aufgang, habe nicht alles auf ein bild bekommen
        • J Offline
          Jan1
          Du mischt hier schon ganz schön was zusammen. Grün ist Text und da schreibst die Zeit rein, kein Plan ob das hinhaut, denn Zeit sind immer noch Zahlen. Was soll denn dann noch das ODER? Nimm doch das Blockly von mir als Beispiel.
          Ich hatte auch mit den Astro Zeiten etwas Probleme und hab mir deshalb das Astro Script aus dem Forum hier als Zeiteingenerator eingebaut. Das liefert die Zeit in der Vorm HH:MM und die kann ich eben sehr leicht mit einer aktuellen Uhrzeit vergleichen.
          Und wo zum Geier sind denn nun Deine Türkontakte hin? Schalt mal das ODER auf "externe Eingänge"um, macht das ganze auch übersichtlicher.
            denjo
            Sorry bin Neuling in der Sache und bei deinem script verstehe ich echt nicht viel, möchte es ja auch verstehen.
            • J Offline
              Jan1
              wo hapert es denn beim Verstehen?
              Du willst Lampen schalten und das in Abhängigkeit eines Türkontakt und der Uhrzeit, exakt das macht mein Script.
              Nur verwende ich dazu nicht die internen Astrozeiten der Astro Blöcke, sondern lass die Zeiten von einem anderen Script, dass es hier fertig gibt berechnen, weil ich genau da paar Probleme hatte.
                denjo
                was bedeutet zum Beispiel das gelbe am anfang und die zahl im grünen??
                • J Offline
                  Jan1
                  Das Gelbe am Anfang ist ein Kommentar und da schreibe ich eben rein, was ich sonst vergessen würde. Der hat keine Funktion, außer ne Gedächtnisstütze.
                  Dein grüner Block ist ein Text Block und da sollte dann auch Text drin stehen. Da Du hier die Uhrzeit rein schreibst, ist das wohl nicht so doll.
                  Oder meinst Du das bei mir im grünen? Ist doch auch ersichtlich, wenn DU schaust was im gelben drin steht ;)
                    denjo
                    okay ja das grüne habe ich bei mir schon raus genommen und so die Uhrzeit rein geschrieben
                    • J Offline
                      Jan1
                      Schau mal ich hab das jetzt vereinfacht und ohne externes Script für die Zeiten angelegt.
                      Bau das mal nach und trage Deine DPs und den Wert Deines Türkontakt ein, sollte laufen
                        denjo
                        das script für mein tür kontakt habe ich ja schon fertig und kann ich erst wirklich testen wenn mein türkontakt aus China kommt, dauert ja etwas.
                        wovon ich rede ist mein script für mein licht draußen was bei abend Dämmerung an und morgen Dämmerung aus gehen soll. habe es mir jetzt aus dein script raus gebastelt wenn ich es richtig verstanden habe.
                        • J Offline
                          Jan1
                          Ach so, ob das ohne Trigger so funktioniert weiß ich auch nicht. Das würde ich aber eh anders erledigen:
                          Zum Sonnenuntergang gehts an und bei Sonnenaufgang wieder aus. Kann so einfach sein :D
                          Ich dachte das ganze soll nur innerhalb des vorgegebenen Zeitraum beim öffnen einer Tür ablaufen, denn genau das macht mein Script. War mir nicht wirklich ersichtlich, dass DU hier zwei unabhängige Geschichten haben willst.
                          • paul53P Offline
                            @denjo:
                            wenn ich die Haustür über einen tür kontakt, zwischen der abend Dämmerung und der morgen Dämmerung im Flur eine lampe angeht. `
                            https://forum.iobroker.net/viewtopic.php?f=21&t=15366&p=160887#p160712
                            • J Offline
                              Jan1
                              Servus paul53,
                              wie hast denn die externen Zeiten an den Block dran bekommen? Denn genau den Block vermisse ich schon die ganze Zeit.
                              • paul53P Offline
                                @Jan1:
                                wie hast denn die externen Zeiten an den Block dran bekommen? `
                                Rechte Maustaste über dem Zeit-Block und "externe Eingänge" auswählen.
                                • J Offline
                                  Jan1
                                  Ne, das hatte ich schon und da fehlen dann aber die Andockstellen 5076_2018_08_23_19_15_58_javascript_iobroker.png
                                  OK OK, ist der falsche Block :lol:
                                  Echt geil, das hatte ich schon voll vermisst und mich gewundert, dass es so was nicht gibt. Da muss man aber auch mal drauf kommen, dass man den so "umbauen" kann :D
                                  • paul53P Offline
                                    Nimm den anderen Block (mit dem Häkchen).
                                      denjo
                                      @Jan1:
                                      Ich dachte das ganze soll nur innerhalb des vorgegebenen Zeitraum beim öffnen einer Tür ablaufen, denn genau das macht mein Script. War mir nicht wirklich ersichtlich, dass DU hier zwei unabhängige Geschichten haben willst. `
                                      das klappt leider nicht
                                      • J Offline
                                        Jan1
                                        Dann stimmt die Uhrzeit an Deinem System nicht, denn das ist muss so funktionieren.
                                        Ich steure damit mein Rollladen und der geht jeden Abend 30 Minuten nach Sonnenuntergang runter.
                                          denjo
                                          Uhrzeit stimmt und im Java habe ich geo daten eingegeben
