  4. IoBroker Admin lädt dauernd
17 Beiträge 5 Kommentatoren 3.1k Aufrufe
    Asatru
    das liefert bei mir folgenden output
    pi@ioBroker_Jonas:~ $ npm install iobroker.js-controller@latest
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/iobroker.js-controller
    npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
    npm WARN pi No description
    npm WARN pi No repository field.
    npm WARN pi No README data
    npm WARN pi No license field.
    npm ERR! path /home/pi/node_modules/iobroker.js-controller
    npm ERR! code EACCES
    npm ERR! errno -13
    npm ERR! syscall access
    npm ERR! Error: EACCES: permission denied, access '/home/pi/node_modules/iobroker.js-controller'
    npm ERR!  { Error: EACCES: permission denied, access '/home/pi/node_modules/iobroker.js-controller'
    npm ERR!   stack: 'Error: EACCES: permission denied, access \'/home/pi/node_modules/iobroker.js-controller\'',
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path: '/home/pi/node_modules/iobroker.js-controller' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator (though this is not recommended).
    npm ERR!     /home/pi/.npm/_logs/2018-08-16T14_49_22_499Z-debug.log
    In der Datei /home/pi/.npm/_logs/2018-08-16T14_49_22_499Z-debug.log steht folgendes (Letzten paar Zeilen)
    22 warn enoent ENOENT: no such file or directory, open '/home/pi/package.json'
    23 verbose enoent This is related to npm not being able to find a file.
    24 warn pi No description
    25 warn pi No repository field.
    26 warn pi No README data
    27 warn pi No license field.
    28 verbose stack Error: EACCES: permission denied, access '/home/pi/node_modules/iobroker.js-controller'
    29 verbose cwd /home/pi
    30 verbose Linux 4.14.30-v7+
    31 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.js-controller@latest"
    32 verbose node v8.11.1
    33 verbose npm  v5.8.0
    34 error path /home/pi/node_modules/iobroker.js-controller
    35 error code EACCES
    36 error errno -13
    37 error syscall access
    38 error Error: EACCES: permission denied, access '/home/pi/node_modules/iobroker.js-controller'
    38 error  { Error: EACCES: permission denied, access '/home/pi/node_modules/iobroker.js-controller'
    38 error   stack: 'Error: EACCES: permission denied, access \'/home/pi/node_modules/iobroker.js-controller\'',
    38 error   errno: -13,
    38 error   code: 'EACCES',
    38 error   syscall: 'access',
    38 error   path: '/home/pi/node_modules/iobroker.js-controller' }
    39 error The operation was rejected by your operating system.
    39 error It is likely you do not have the permissions to access this file as the current user
    39 error
    39 error If you believe this might be a permissions issue, please double-check the
    39 error permissions of the file and its containing directories, or try running
    39 error the command again as root/Administrator (though this is not recommended).
    40 verbose exit [ -13, true ]
    Führe ich das ganze mit sudo aus, klappt es auch nicht
    @Rainer: Was genau meinst Du mit korruptem Download? Ich habe das Image von http://www.iobroker.net/docu/?page_id=2563&lang=de. Diese Version: Homematic All-In-One mit piVCCU
    Ich versuche jetzt noch mal die ioBroker Image aufzuspielen…
    Danke und Gruß
    Asatru
    • StabilostickS Offline
      Stabilostick
      Was ist die Fehlermeldung mit „sudo npm…...“?
        Stabilostick
        Und, hast du wirklich den npm-Befehl so wie ich geschrieben habe, im Ordner /opt/iobroker ausgeführt? Vorher mit
        cd /opt/iobroker
        dorthin wechseln.
          Stabilostick
          Npm-Befehle für ioBroker bei Dir IMMER in diesem Pfad ausführen!
            Asatru
            Oh, nein in diesem Ordner war ich nicht. Soll ich das Image lieber noch mal komplett neu aufspielen und es noch mal versuchen?
            Habe jetzt auch mit sudo den output bekommen:
            pi@ioBroker_Jonas:~ $ sudo npm install iobroker.js-controller@latest
            > iobroker.js-controller@1.4.2 preinstall /home/pi/node_modules/iobroker.js-controller
            > node lib/preinstall_check.js
            │              npm update check failed              │
            │        Try running with sudo or get access        │
            │       to the local update config store via        │
            │ sudo chown -R $USER:$(id -gn $USER) /root/.config │
            NPM version: 5.8.0
            npm version >= 5: disabling package-lock
            > iobroker.js-controller@1.4.2 install /home/pi/node_modules/iobroker.js-controller
            > node iobroker.js setup first
            Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/home/pi/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
            Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/home/pi/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
            fs.js:885
              return binding.mkdir(pathModule._makeLong(path),
            Error: EACCES: permission denied, mkdir '/home/pi/node_modules/iobroker.js-controller/lib/setup/../../tmp'
                at Object.fs.mkdirSync (fs.js:885:18)
                at Setup.setup (/home/pi/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:143:58)
                at /home/pi/node_modules/iobroker.js-controller/lib/setup.js:629:27
                at processCommand (/home/pi/node_modules/iobroker.js-controller/lib/setup.js:661:15)
                at Object.module.exports.execute (/home/pi/node_modules/iobroker.js-controller/lib/setup.js:3166:5)
                at Object. <anonymous>(/home/pi/node_modules/iobroker.js-controller/iobroker.js:1:100)
                at Module._compile (module.js:652:30)
                at Object.Module._extensions..js (module.js:663:10)
                at Module.load (module.js:565:32)
                at tryModuleLoad (module.js:505:12)
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! iobroker.js-controller@1.4.2 install: `node iobroker.js setup first`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the iobroker.js-controller@1.4.2 install script.
               │   Update available 5.8.0 → 6.4.0    │
               │     Run npm i -g npm to update      │
            npm ERR!     /root/.npm/_logs/2018-08-16T15_00_51_581Z-debug.log</anonymous>
            npm i -g npm habe ich dann mal mit sudo ausgeführt, daraus kam dann der selbe Fehler. Aber wie ich sagte, war ich nicht in diesem Ordner.
            Aus dem Ordner heraus gibt es auch einen Fehler
            pi@ioBroker_Jonas:/opt/iobroker $ npm install iobroker.js-controller@latest
            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/cliui
            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/lru-cache
            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/moment
            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/p-limit
            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/which
            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/yargs
            npm ERR! path /opt/iobroker/node_modules/cliui
            npm ERR! errno -13
            npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/cliui'
            npm ERR!  { Error: EACCES: permission denied, access '/opt/iobroker/node_modules/cliui'
            npm ERR!   stack: 'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/cliui\'',
            npm ERR!   path: '/opt/iobroker/node_modules/cliui' }
            npm ERR!
            npm ERR!
            npm ERR!     /home/pi/.npm/_logs/2018-08-16T15_08_27_013Z-debug.log
            Und hier noch mal mit sudo
            pi@ioBroker_Jonas:/opt/iobroker $ sudo npm install iobroker.js-controller@latest
            > iobroker.js-controller@1.4.2 preinstall /opt/iobroker/node_modules/iobroker.js-controller
            NPM version: 6.4.0
            > iobroker.js-controller@1.4.2 install /opt/iobroker/node_modules/iobroker.js-controller
            Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
            Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
            fs.js:885
            Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
                at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:143:58)
                at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:629:27
                at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:661:15)
                at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3166:5)
                at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:100)
            npm ERR! errno 1
            npm ERR!
            npm ERR!     /root/.npm/_logs/2018-08-16T15_10_11_814Z-debug.log</anonymous>
            /root/.npm/_logs/2018-08-16T15_10_11_814Z-debug.log:
            2181 verbose stack Error: iobroker.js-controller@1.4.2 install: `node iobroker.js setup first`
            2181 verbose stack Exit status 1
            2181 verbose stack     at EventEmitter. <anonymous>(/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:304:16)
            2181 verbose stack     at emitTwo (events.js:126:13)
            2181 verbose stack     at EventEmitter.emit (events.js:214:7)
            2181 verbose stack     at ChildProcess. <anonymous>(/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
            2181 verbose stack     at ChildProcess.emit (events.js:214:7)
            2181 verbose stack     at maybeClose (internal/child_process.js:925:16)
            2181 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
            2182 verbose pkgid iobroker.js-controller@1.4.2
            2183 verbose cwd /opt/iobroker
            2184 verbose Linux 4.14.30-v7+
            2185 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.js-controller@latest"
            2186 verbose node v8.11.1
            2187 verbose npm  v6.4.0
            2188 error code ELIFECYCLE
            2189 error errno 1
            2190 error iobroker.js-controller@1.4.2 install: `node iobroker.js setup first`
            2190 error Exit status 1
            2191 error Failed at the iobroker.js-controller@1.4.2 install script.
            2191 error This is probably not a problem with npm. There is likely additional logging output above.
            2192 verbose exit [ 1, true ]</anonymous></anonymous>
            Wie gesagt, ich werde mal das andere image probieren
              @Asatru:
              Was genau meinst Du mit korruptem Download? Ich habe das Image von hier. Diese Version: Homematic All-In-One mit piVCCU `
              Es ist schon vorgekommen, dass die Datei unvollständig/defekt downgeloaded wurde.
              Erst ein erneuter Download hat dan ein funktionierendesd Image erzeugt.
                Asatru
                Habe jetzt das andere Image probiert…selbes Problem.
                Das Raspberry ist auch komplett neu... :?
                  Asatru
                  Ich weiß nicht wie, aber es läuft jetzt. Habe mehrere Updates gemacht, welche wohl in der korrekten Reihenfolge gemacht werden müssen.
                  Danke an alle, die geholfen haben!
                  Gruß Asatru
                    Stabilostick
                    Prima, dass es klappt. Kannst Du Dich erinnern, was Du gerade in welcher Reihenfolge gemacht hast? Möchte doch auch was lernen. [emoji3]
                      Asatru
                      Ehrlich gesagt nicht so richtig. Es musste auf jeden fall npm komplett aktualisiert werden, danach wurden mir dann Vulnerabilities angezeigt, welche ich mit einem Befehl (Glaube npm audit fix) updaten sollte. Dann musste ich einen report erstellen (npm audit –show-all oder so) und dann nochmal das audit fix. Danach musste ich dann den JS-controller neu installieren und dem user pi mit einem befehl zugriff auf einen config-datei geben. Dann habe ich iobroker neu gestartet und den raspberry neu gestartet.
                      Und das ganze hat immer nur mit sudo funktioniert.
                      Allerdings bin ich mir da bei allem nicht mehr so ganz sicher, auch in Bezug auf die Reihenfolge.
                      Gruß Asatru
