  4. Mqtt nach Serverumzug
    6.3k
2 Beiträge 1 Kommentatoren 1.1k Aufrufe
  • X Offline
    X Offline
    xbow42
    ich bekomme mqtt nicht wieder zum laufen.
    root@iobroker-nuc:~# node -v && nodejs -v && npm -v
    v8.12.0
    v8.12.0
    4.6.1
    bisher habe ich alles auf relativ einfache Werte gelassen
    Servertyp:Server/Broker
    Port: 1883
    ohne ssl
    sonoff-Adapter habe ich auf Port 1500 eingestellt damit die sich nicht in die quere kommen.
    hier mal Auszug aus dem Log:
    host.iobroker-nuc	2018-11-11 21:00:18.201	error	instance system.adapter.mqtt.0 terminated with code 0 (OK)
    host.iobroker-nuc	2018-11-11 21:00:18.201	error	Caught by controller[0]: port: 1883 }
    host.iobroker-nuc	2018-11-11 21:00:18.201	error	Caught by controller[0]: address: '::',
    host.iobroker-nuc	2018-11-11 21:00:18.201	error	Caught by controller[0]: syscall: 'listen',
    host.iobroker-nuc	2018-11-11 21:00:18.201	error	Caught by controller[0]: code: 'EADDRINUSE',
    host.iobroker-nuc	2018-11-11 21:00:18.201	error	Caught by controller[0]: errno: 'EADDRINUSE',
    host.iobroker-nuc	2018-11-11 21:00:18.201	error	Caught by controller[0]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
    host.iobroker-nuc	2018-11-11 21:00:18.200	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
    host.iobroker-nuc	2018-11-11 21:00:18.200	error	Caught by controller[0]: at adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.mqtt/main.js:133:64)
    host.iobroker-nuc	2018-11-11 21:00:18.200	error	Caught by controller[0]: at MQTTServer (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:12:47)
    host.iobroker-nuc	2018-11-11 21:00:18.200	error	Caught by controller[0]: at new MQTTServer (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:1138:7)
    host.iobroker-nuc	2018-11-11 21:00:18.200	error	Caught by controller[0]: at _constructor (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:1121:9)
    host.iobroker-nuc	2018-11-11 21:00:18.200	error	Caught by controller[0]: at startServer (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:1018:28)
    host.iobroker-nuc	2018-11-11 21:00:18.199	error	Caught by controller[0]: at Server.listen (net.js:1485:7)
    host.iobroker-nuc	2018-11-11 21:00:18.199	error	Caught by controller[0]: at listenInCluster (net.js:1401:12)
    host.iobroker-nuc	2018-11-11 21:00:18.199	error	Caught by controller[0]: at Server.setupListenHandle [as _listen2] (net.js:1360:14)
    host.iobroker-nuc	2018-11-11 21:00:18.197	error	Caught by controller[0]: { Error: listen EADDRINUSE :::1883
    mqtt.0	2018-11-11 21:00:17.671	error	Error: listen EADDRINUSE :::1883 at Server.setupListenHandle [as _listen2] (net.js:1360:14) at listenInCluster (net.js:1401:12) at Server.listen (net.js:1485:7) at startServer (/opt/io
    mqtt.0	2018-11-11 21:00:17.671	error	uncaught exception: listen EADDRINUSE :::1883
    mqtt.0	2018-11-11 21:00:17.027	info	starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.mqtt, node: v8.12.0
    host.iobroker-nuc	2018-11-11 21:00:15.751	info	instance system.adapter.mqtt.0 started with pid 4972</anonymous>
    Was kann ich tun?
    cu xbow
    • X Offline
      X Offline
      xbow42
      … dann antworte ich mir mal selber, vielleicht kann es wer gebrauchen.
      Ich hatte den alten bananapi noch laufen als "Server/Broker" und auf dem neuen iobroker-Rechner auch noch mosquitto installiert
      *bananapi "shutdown now"
      *neuer iobroker-nuc
      -- #apt-get purge mosquitto
      -- mqtt-Instanz gelöscht
      -- Adapter noch mal übergebügelt https://github.com/ioBroker/ioBroker.mqtt
      -- Instanz neu installiert,eingerichtet & gestartet
      Logfile sieht schon mal gut aus
      ! mqtt.0 2018-11-12 17:46:50.200 info Starting MQTT ' server on port 1883
      ! mqtt.0 2018-11-12 17:46:49.876 info starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.mqtt, node: v8.12.0
      ! host.iobroker-nuc 2018-11-12 17:46:48.617 info instance system.adapter.mqtt.0 started with pid 5773
      Instanz wird zwar noch gelb angezeigt "Verbunden mit mqtt:falsch". Hoffe das gibts sich wenn er mit einem Client kommuniziert.
      ggf. muss ich hier noch mal nachfragen…
      Ist es richtig, dass nur ein Rechner als "Server/Broker" im Netz laufen darf?
      cu xbow
