  4. [gelöst] Installation geht nicht da node.js hängt.
2 Beiträge 2 Kommentatoren 531 Aufrufe
    B3ta
    Wollte gerade auf einem RPI3 mit jessie ioBroker installieren.
    Aber er installiert node nicht !!!
    pi@RPI_Ebusd:~ $ curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
    ## Installing the NodeSource Node.js 8.x LTS Carbon repo...
    ## Populating apt-get cache...
    + apt-get update
    OK   http://archive.raspberrypi.org jessie InRelease
    OK   http://mirrordirector.raspbian.org jessie InRelease
    Ign https://deb.nodesource.com jessie InRelease
    Ign https://deb.nodesource.com jessie Release.gpg
    OK   http://archive.raspberrypi.org jessie/main armhf Packages
    OK   http://archive.raspberrypi.org jessie/ui armhf Packages
    Ign http://archive.raspberrypi.org jessie/main Translation-de_DE
    Ign http://archive.raspberrypi.org jessie/main Translation-en
    Ign http://archive.raspberrypi.org jessie/ui Translation-de_DE
    Ign http://archive.raspberrypi.org jessie/ui Translation-en
    OK   http://mirrordirector.raspbian.org jessie/main armhf Packages
    OK   http://mirrordirector.raspbian.org jessie/contrib armhf Packages
    OK   http://mirrordirector.raspbian.org jessie/non-free armhf Packages
    OK   http://mirrordirector.raspbian.org jessie/rpi armhf Packages
    Fehl https://deb.nodesource.com jessie/main Sources
      server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
    Fehl https://deb.nodesource.com jessie/main armhf Packages
    Ign https://deb.nodesource.com jessie/main Translation-de_DE
    Ign https://deb.nodesource.com jessie/main Translation-en
    Ign http://mirrordirector.raspbian.org jessie/contrib Translation-de_DE
    Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en
    Ign http://mirrordirector.raspbian.org jessie/main Translation-de_DE
    Ign http://mirrordirector.raspbian.org jessie/main Translation-en
    Ign http://mirrordirector.raspbian.org jessie/non-free Translation-de_DE
    Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en
    Ign http://mirrordirector.raspbian.org jessie/rpi Translation-de_DE
    Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en
    W: Fehlschlag beim Holen von https://deb.nodesource.com/node_8.x/dists/jessie/main/source/Sources  server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
    W: Fehlschlag beim Holen von https://deb.nodesource.com/node_8.x/dists/jessie/main/binary-armhf/Packages  server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
    E: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
    Error executing command, exiting
    • eric2905E Offline
      eric2905E Offline
      eric2905
      Hast Du es mal mit „sudo curl ….“ probiert, da Du nicht als root angemeldet bist.
      Gruß,
      Eric
