  4. [gelöst]per Ping SV steuern
13 Beiträge 2 Kommentatoren 2.7k Aufrufe
  • fischi87F Offline
    fischi87F Offline
    fischi87
    ich wollte gerne aus meinen ganzen ip-gäreten die True/False Geschichte auslesen und damit meine SV steuern also !Wenn auch nur ein Gerät True ist soll der SV zustand auch Wach sein und !Wenn alle False sind dann wechseln in Schläft. Ich habe da schon mal was vorbereitet, vielleicht könnt ihr mir da weiterhelfen, hab überhaupt kein Ansatz, fand auch gerade erst mit Node-Red an.
    [{"id":"e3f701a3.1c09","type":"ioBroker in","name":"TV SZ","topic":"ping.0.RaspberryPi.192_168_178_20","payloadType":"value","x":123,"y":55,"z":"751d0e6f.8ae2f","wires":[object Object]},{"id":"6adadbdb.952524","type":"ioBroker in","name":"TV AZ","topic":"ping.0.RaspberryPi.192_168_178_34","payloadType":"value","x":125,"y":112,"z":"751d0e6f.8ae2f","wires":[object Object]},{"id":"3894613b.c76b9e","type":"ioBroker in","name":"IPad","topic":"ping.0.RaspberryPi.192_168_178_21","payloadType":"value","x":126,"y":170,"z":"751d0e6f.8ae2f","wires":[object Object]},{"id":"aed12f1d.512ed","type":"ioBroker in","name":"Mac-Mini","topic":"ping.0.RaspberryPi.192_168_178_26","payloadType":"value","x":137,"y":286,"z":"751d0e6f.8ae2f","wires":[object Object]},{"id":"f7a2cf94.085d3","type":"ioBroker in","name":"PS 4","topic":"ping.0.RaspberryPi.192_168_178_31","payloadType":"value","x":141,"y":397,"z":"751d0e6f.8ae2f","wires":[object Object]},{"id":"8fbce7f9.704318","type":"ioBroker in","name":"Drucker","topic":"ping.0.RaspberryPi.192_168_178_52","payloadType":"value","x":129,"y":229,"z":"751d0e6f.8ae2f","wires":[object Object]},{"id":"37de680c.c82198","type":"ioBroker in","name":"IPhone Axel","topic":"ping.0.RaspberryPi.192_168_178_84","payloadType":"value","x":150,"y":340,"z":"751d0e6f.8ae2f","wires":[object Object]},{"id":"1a23bbe8.e5dc44","type":"ioBroker out","name":"Schlafzustand","topic":"hm-rega.0.4769","ack":"false","autoCreate":"false","x":666,"y":203,"z":"751d0e6f.8ae2f","wires":[]}]
    danke Mit freundlichen Grüßen
    • paul53P Offline
      Das lässt sich mittels Javascript-Adapter sicherlich besser lösen, da der Ping-Adapter zu jedem Ping-Gerät einen Datenpunkt erzeugt. Bei dem JS-Programm kann ich Dir helfen.
      Hast Du schon eine Javascript-Instanz erstellt ?
      • fischi87F Offline
        fischi87F Offline
        fischi87
        Okay auch gut.
        Java Adapter habe ich drauf ja.
        • paul53P Offline
          Dann kann das Script etwa so aussehen (vielleicht habe ich was vergessen):
          // Deklaration und Initialisierung von Variablen
          var id1 = "ping.0.RaspberryPi.192_168_178_20"; //TV SZ
          var id2 = "ping.0.RaspberryPi.192_168_178_34"; //TV AZ
          var id3 = "ping.0.RaspberryPi.192_168_178_21"; //IPad
          var id4 = "ping.0.RaspberryPi.192_168_178_26"; //Mac-Mini
          var id5 = "ping.0.RaspberryPi.192_168_178_31"; //PS 4
          var id6 = "ping.0.RaspberryPi.192_168_178_52"; //Drucker
          var idsv = "hm-rega.0.4769"; //Schlafzustand true = wach
          var ping1 = getState(id1).val;
          var ping2 = getState(id2).val;
          var ping3 = getState(id3).val;
          var ping4 = getState(id4).val;
          var ping5 = getState(id5).val;
          var ping6 = getState(id6).val;
          //Funktion zur Abfrage und Setzen der SV
          function wach()
              if(ping1 || ping2 || ping3 || ping4 || ping5 || ping6)
          		setState(idsv, true);
              else
          		setState(idsv, false);
          // Bei Änderung der Zustände Aufruf der Funktion
          on(id1, function(dp)
             ping1 = dp.newState.val;
             wach();
          on({d2, function(dp)
             ping2 = dp.newState.val;
             wach();
          on(id3, function(dp)
             ping3 = dp.newState.val;
             wach();
          on(id4, function(dp)
             ping4 = dp.newState.val;
             wach();
          on(id5, function(dp)
             ping5 = dp.newState.val;
             wach();
          on(id6, function(dp)
             ping6 = dp.newState.val;
             wach();
          // Scriptstart mit Initialwerten
          wach();
          • fischi87F Offline
            fischi87F Offline
            fischi87
            Wow vielen Dank aber die sv ändert sich nicht?
            Wie oft wird das Script aktualisiert oder passiert das per Änderung?
            • paul53P Offline
              @fischi87:
              Wow vielen Dank aber die sv ändert sich nicht? `
              Die SV ändert sich nur, wenn kein Gerät mehr per ping erreichbar ist.
              @fischi87:
              Wie oft wird das Script aktualisiert oder passiert das per Änderung? `
              Das passiert nur bei Scriptstart und bei Änderung.
              • fischi87F Offline
                fischi87F Offline
                fischi87
                Cool, wenn es jetzt funktionieren würde wäre das echt klasse :-)
                • paul53P Offline
                  Lösche bitte die geschweiften Klammern bei on({id}, –> on(id,
                  Beispiel:
                     allewach();
                  Die Bezeichnung "allewach" ist blöd gewählt. Es sollte eigentlich "min_einer_wach" o.ä. sein.
                  • fischi87F Offline
                    fischi87F Offline
                    fischi87
                    Riesen dank, funktioniert. Kann ich das mit allwatch trotzdem mal lassen?
                    Sag mal wo lernt man Java?
                    Mfg
                    • paul53P Offline
                      @fischi87:
                      Kann ich das mit allwatch trotzdem mal lassen? `
                      Wenn es Dich nicht stört :)
                      @fischi87:
                      Sag mal wo lernt man Java? `
                      Du meinst Javascript ? Das hängt von den Voraussetzungen / Programmiererfahrungen in anderen Sprachen ab. Siehe http://forum.iobroker.de/viewtopic.php?f=21&t=1820&sid=c3dd6a9e9bd788d88cdc7303f72a1ada.
                      • fischi87F Offline
                        fischi87F Offline
                        fischi87
                        Solange es nix ausmacht ist mir das Wurst :-)
                        Danke dir übelst!!!
                        Mfg
                        • fischi87F Offline
                          fischi87F Offline
                          fischi87
                          Es wäre doch kein Problem das Skript einfach zu erweitern richtig?
                          • paul53P Offline
                            @fischi87:
                            Es wäre doch kein Problem das Skript einfach zu erweitern richtig? `
                            Kein Problem, wenn es zur Funktion passt.
