  4. Installation von Buderus KM200 adapter schlägt fehl
    1.7k
7 Beiträge 2 Kommentatoren 908 Aufrufe
  • P Offline
    padi0-000
    Hallo versuche auf meinem Windows 10 Rechner vergeblich den Buderus KM200 Adapter zu installiern.
    Kann mir jemand helfen ?
    was muss ich dazu hier posten
    Danke im voraus..
    LG Patrick
    $ ./iobroker add km200
    npm install iobroker.km200 --production --prefix "C:/ioBroker" (System call)
    gyp
    ERR!
    configure error
    gyp
    ERR!
    stack
    Error: Can't find Python executable "python", you can set the PYTHON env variable.
    gyp
    ERR!
    stack
    at failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:449:14)
    gyp
    ERR!
    stack
    at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:404:11gyp
    ERR!
    stack
    at FSReqWrap.oncomplete (fs.js:82:15)
    gyp
    ERR!
    System
    Windows_NT 10.0.16299
    gyp
    ERR!
    command
    "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"gyp
    ERR!
    cwd
    C:\ioBroker\node_modules\iobroker.km200\node_modules\mcrypt
    gyp
    ERR!
    node -v
    v4.5.0
    gyp
    ERR!
    node-gyp -v
    v3.4.0
    gyp
    ERR!
    not ok
    npm
    ERR!
    npm
    ERR!
    argv
    "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js" "install" "iobroker.km200" "--production" "--prefix" "C:/ioBroker"
    npm
    ERR! node
    v4.5.0
    npm
    ERR!
    npm
    v2.15.9
    npm
    ERR! code ELIFECYCLE
    ! npm
    ERR!
    mcrypt@0.1.13 install: node-gyp rebuild
    npm
    ERR!
    Exit status 1
    npm
    ERR!
    npm
    ERR!
    Failed at the mcrypt@0.1.13 install script 'node-gyp rebuild'.
    npm
    ERR!
    This is most likely a problem with the mcrypt package,
    npm
    ERR!
    not with npm itself.
    npm
    ERR!
    Tell the author that this fails on your system:
    npm
    ERR!
    node-gyp rebuild
    npm
    ERR!
    You can get information on how to open an issue for this project with:
    npm
    ERR!
    npm bugs mcrypt
    npm
    ERR!
    Or if that isn't available, you can get their info via:
    npm
    ERR!
    npm
    ERR! npm owner ls mcryptnpm
    ERR!
    There is likely additional logging output above.
    ! npm
    ERR!
    Please include the following file with any support request:
    npm
    ERR!
    C:\ioBroker\node_modules\iobroker\npm-debug.log
    host.Wohnzimmer-PC install adapter km200
    gyp
    ERR!
    configure error
    gyp
    ERR!
    stack
    gyp
    ERR!
    stack
    gyp
    ERR!
    stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:404:11gyp ERR! stack at FSReqWrap.oncomplete (fs.js:82:15)
    ! gyp
    ERR!
    System
    gyp
    ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"gyp
    ERR!
    cwd
    gyp
    ERR!
    node -v
    v4.5.0
    gyp
    ERR!
    node-gyp -v
    v3.4.0
    gyp
    ERR!
    not ok
    npm
    ERR!
    npm
    ERR!
    argv
    npm
    ERR!
    node v4.5.0npm
    ERR!
    npm v2.15.9
    npm
    ERR!
    code ELIFECYCLE
    ! npm
    ERR!
    npm
    ERR!
    Exit status 1
    npm
    ERR!
    npm
    ERR!
    npm
    ERR!
    npm
    ERR!
    npm
    ERR!
    npm
    ERR!
    node-gyp rebuildnpm
    ERR!
    npm
    ERR! npm bugs mcrypt
    npm
    ERR!
    npm ERR! npm
    ERR!
    npm owner ls mcrypt
    npm
    ERR!
    ! npm
    ERR! Please include the following file with any support request:npm ERR! C:\ioBroker\node_modules\iobroker\npm-debug.log
    ! host.Wohnzimmer-PC install adapter km200
    gyp
    ERR!
    configure error
    gyp
    ERR!
    stack
    gyp
    ERR!
    stack
    gyp
    ERR!
    stack
    gyp
    ERR!
    stack
    gyp
    ERR!
    System
    gyp
    ERR!
    command
    gyp
    ERR!
    cwd
    gyp
    ERR! node -v v4.5.0gyp
    ERR!
    node-gyp -v
    v3.4.0
    gyp
    ERR!
    not ok
    npm
    ERR!
    npm
    ERR!
    argv
    npm
    ERR! node v4.5.0npm ERR! npm v2.15.9
    ! npm
    ERR!
    code ELIFECYCLE
    ! npm
    ERR!
    mcrypt@0.1.13 install: node-gyp rebuildnpm
    ERR!
    Exit status 1
    npm
    ERR!
    npm
    ERR!
    npm
    ERR!
    npm
    ERR!
    npm
    ERR!
    npm
    ERR!
    node-gyp rebuild
    npm
    ERR!
    npm ERR!
    npm bugs mcrypt
    npm
    ERR!
    npm
    ERR!
    npm
    ERR!
    npm owner ls mcrypt
    npm
    ERR!
    ! npm
    ERR!
    npm
    ERR!
    ERROR: host.Wohnzimmer-PC Cannot install km200
    ERROR: process exited with code 13
    ****geändert: Code in Code-Tags und Spoiler; Homoran (Admin)****
    • apollon77A Offline
      Kann es sein das du die Windows Build Tools nicht installiert hast? Wir von einigen Modulen gebraucht.
      https://www.npmjs.com/package/windows-build-tools
      • P Offline
        padi0-000
        wie kann ich das rausfinden .
        sollte aber mit Node js zusammen installiert worden sein .
          Im zweifel installiere es nochmal. Die Fehler sagen in jedem Fall das bei Dir "python" fehlt was da an sich mitkommt.
          Ich denke nicht das das automatisch mitinstalliert wird.
          • P Offline
            padi0-000
            wenn ich das installier so wie angegeben dann startet io Broker nicht mehr .
            habe iobroker noch mal installiert und bei der Installation gesehen das npn mit installisiert wird .
            sonst noch eine Idee ?
              Mit welchen Fehler startet er nicht mehr?
              • P Offline
                padi0-000
                Hallo
                habe viel rumexperimentiert .. bekomme es nicht zum laufen
                hat nboch jemand eine Idee ?
                @ apollon77 es startet garnicht es gibt keine fehlermelung oder sonstiges … erreiche keine oberflächen mehr .
                LG Patrick
