  4. [gelöst] Amazon-dash instanz startet nicht
    1.9k
12 Beiträge 5 Kommentatoren 1.5k Aufrufe
    AingTii
    Hallo Zusammen,
    bei mir startet die Amazon-dash Instanz nicht. bzw. bleibt rot und schmeißt folgenden fehler ins log.
    host.raspberrypi	2018-04-17 17:17:44.471	info	Restart adapter system.adapter.amazon-dash.0 because enabled
    host.raspberrypi	2018-04-17 17:17:44.471	error	instance system.adapter.amazon-dash.0 terminated with code 0 (OK)
    host.raspberrypi	2018-04-17 17:17:44.470	error	Caught by controller[0]: at Module.load (module.js:565:32)
    host.raspberrypi	2018-04-17 17:17:44.470	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
    host.raspberrypi	2018-04-17 17:17:44.470	error	Caught by controller[0]: at Module._compile (module.js:652:30)
    host.raspberrypi	2018-04-17 17:17:44.470	error	Caught by controller[0]: at Object. (/opt/iobroker/node_modules/pcap/pcap.js:3:21)
    host.raspberrypi	2018-04-17 17:17:44.470	error	Caught by controller[0]: at require (internal/module.js:11:18)
    host.raspberrypi	2018-04-17 17:17:44.470	error	Caught by controller[0]: at Module.require (module.js:596:17)
    host.raspberrypi	2018-04-17 17:17:44.470	error	Caught by controller[0]: at Function.Module._load (module.js:497:3)
    host.raspberrypi	2018-04-17 17:17:44.470	error	Caught by controller[0]: at tryModuleLoad (module.js:505:12)
    host.raspberrypi	2018-04-17 17:17:44.469	error	Caught by controller[0]: at Object.Module._extensions..node (module.js:681:18)
    host.raspberrypi	2018-04-17 17:17:44.469	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.raspberrypi	2018-04-17 17:17:44.469	error	Caught by controller[0]: NODE_MODULE_VERSION 57\. Please try re-compiling or re-installing
    host.raspberrypi	2018-04-17 17:17:44.469	error	Caught by controller[0]: NODE_MODULE_VERSION 59\. This version of Node.js requires
    host.raspberrypi	2018-04-17 17:17:44.469	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.raspberrypi	2018-04-17 17:17:44.468	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/pcap/build/Release/pcap_binding.node'
    amazon-dash.0	2018-04-17 17:17:44.211	info	starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v8.11.1
    host.raspberrypi	2018-04-17 17:17:42.934	info	instance system.adapter.amazon-dash.0 started with pid 1065
    hat jemand eine Lösung dafür?
    ioBroker läuft auf einem Raspi 3 mit raspian Stretch
    node und nodejs v8.11.1
    npm v5.6.0
    Gruß Jens
    • wendy2702W Offline
      wendy2702W Offline
      hast du im Ordner des Adapters auf der Konsole mal einen der befehle aus dem Log versucht?
        AingTii
        nachdem ich sudo npm rebuild , sudo npm install durchgeführt hatte zeigte er ein update
        auf 5.8.0 an…
        installiert, noch mal sudo apt update und upgrade durch geführt.
        reboot..
        Erfolglos.
        Bis ich dann gelesen habe, im Ordner des Adapters! (Wer lesen kann ist klar im Vorteil!)
        Also im Ordner des AmazonDash Button durchgeführt
        und siehe da, kein Fehler mehr und Instanz ist Grün..
        Super Tipp!
          @AingTii:
          npm v5.6.0 `
          npm 5.6.0 ist böse!
          für ioBroker muss die Version >=5.7.1 sein, sonst gibt es u.U. irreparable Probleme.
          Bitte mit
          npm install -g npm@latest
          unbedingt upgraden.
            wendy2702W Offline
            @Rainer: wenn ich das richtig lese hat er den Node schon auf 5.8.0
            @AingTii: Kannst du dann bitte das [Problem] im Titel gegen ein [Gelöst] ersetzen!
            Und hast du zufällig ein logfile von dem NPM Upgrade bzw. Der 5.8.0 installation?
              @wendy2702:
              @Rainer: wenn ich das richtig lese hat er den Node schon auf 5.8.0 `
              Habe nur gelesen:
              @AingTii:
              auf 5.8.0 an… `
              von Ausführung steht da nix
                wendy2702W Offline
                Ich habe das so gelesen:
                ` > auf 5.8.0 an…
                reboot.. `
                Auf 5.8.0 an… installiert, ...
                Vielleicht kann AingTii licht in unser Dunkel bringen :D
                  AingTii
                  ich hatte vorher bereits 5.8.0 drauf, allerdings durch die Aktion des angleichens der Version von nodejs und node auf 8.11.1
                  ist irgendwie 5.6.0 mitgekommen.
                  Habe ich aber erst Gestern beim npm rebuild gemerkt. daher das update auf die 5.8.0 durchgeführt.
                  somit habe ich jetzt
                  nodejs und node auf v8.11.1 und npm auf v5.8.0
                  entscheidend war aber noch das npm rebuild im Ordner des amazondash Adapters.
                  Protokoll, Log?
                  wenn es irgendwo gespeichert wird nebenher und mir sagte jemand wo, dann schaue ich gern mal und poste es
                  Noch ne kurze Frage, ist das richtig so mit dem "gelöst" setzen, nur im ersten Post oder
                  gbit es da eine extra Funktion?
                  Gruß Jens
                    wendy2702W Offline
                    das mit dem "Gelöst" ist richtig.
                    Mit welchem Tool hast du das Upgrade gemacht (Putty !?)
                    Könntest mal im SYSLOG schauen, ob im iobroker log etwas davon steht glaube ich nicht.
                    Dann gibt es meistens noch ein NPM log, da dürften aber deine Upgrade befehle nicht drin stehen und um die würde es mir gehen da wie einen anderen User haben bei dem der Upgrade von 5.6.0 –> 5.8.0 mit allen möglichen Kombinationen nicht klappen will.
                      AingTii
                      Also im Log find ich so nix.
                      aber ich kann ja die history der eingaben im terminal einsehen. wenn ich mit dem Pfeil nach oben gehe
                      ich würde sagen diese Schritte habe ich Gestern durchgeführt ist vieles doppelt….
                      $ sudo npm rebuild
                      $ npm-v
                      $ sudo npm i -g npm
                      $ npm -v
                      $ sudo apt update
                      $ sudo apt upgrade
                      $ node -v
                      $ nodejs -v
                      $ npm -v
                      $ sudo npm rebuild
                      $ sudo npm install
                      $ sudo npm rebuild
                      $ npm -v
                      $ sudo reboot
                      $ cd /opt/iobroker/iobroker-data/files/amazon-dash.admin
                      $ sudo npm rebuild
                      $ npm -v
                      $ nodejs -v
                      ich schaue auch noch mal inwieweit ich es im anderen Post beschreiben habe.
                      so wie homoran bereits geschreiben hatte, hatte ich vor dem ganzen Thema, dass sich durch die node/nodejs etc
                      die 5.6.0 eingeschlichen hatte mit
                      sudo npm install -g npm@latest
                      die 5.8.0 installiert.
                      und Gestern kam bei einem der Schritte so eine Info in einem "grafischen kasten" das update von 5.6.0 -> 5.8.0 möglich ist
                      ich meine sogar mit kurzer Info wie.
                      Gruß Jens
                      • C Offline
                        Cliff
                        ` > cd /opt/iobroker/iobroker-data/files/amazon-dash.admin
                        $ sudo npm rebuild `
                        Nach tausenden Versuchen hat DAS bei mir den Durchbruch gebracht…
                        • R Offline
                          robson
                          schrieb am zuletzt editiert von robson
                          bei mir lässt sich die Dash-Instanz nun auch nicht mehr starten (dauerhaft rot). Bis heute Morgen lief alles gut. Ich musste den Javascript-Adapter jedoch neu installieren und seitdem habe ich die Probleme.
                          Deinstallation und Neuinstallation haben nicht geholfen.
                          Folgende Fehler gibt mir das Log direkt beim Starten der Instanz aus:
                          host.ioBroker-RasPi	2019-02-16 13:35:21.990	info	Restart adapter system.adapter.amazon-dash.0 because enabled
                          host.ioBroker-RasPi	2019-02-16 13:35:21.990	error	instance system.adapter.amazon-dash.0 terminated with code 0 (OK)
                          host.ioBroker-RasPi	2019-02-16 13:35:21.990	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:787:25)
                          host.ioBroker-RasPi	2019-02-16 13:35:21.990	error	Caught by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:748:13)
                          host.ioBroker-RasPi	2019-02-16 13:35:21.990	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:788:29
                          host.ioBroker-RasPi	2019-02-16 13:35:21.990	error	Caught by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4990:18)
                          host.ioBroker-RasPi	2019-02-16 13:35:21.990	error	Caught by controller[0]: at Adapter.emit (events.js:208:7)
                          host.ioBroker-RasPi	2019-02-16 13:35:21.989	error	Caught by controller[0]: at emitNone (events.js:106:13)
                          host.ioBroker-RasPi	2019-02-16 13:35:21.989	error	Caught by controller[0]: at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:43:5)
                          host.ioBroker-RasPi	2019-02-16 13:35:21.989	error	Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:78:29)
                          host.ioBroker-RasPi	2019-02-16 13:35:21.989	error	Caught by controller[0]: at Object.exports.createSession (/opt/iobroker/node_modules/pcap/pcap.js:123:12)
                          host.ioBroker-RasPi	2019-02-16 13:35:21.989	error	Caught by controller[0]: at new PcapSession (/opt/iobroker/node_modules/pcap/pcap.js:49:39)
                          host.ioBroker-RasPi	2019-02-16 13:35:21.988	error	Caught by controller[0]: Error: socket: Operation not permitted
                          Wie gesagt, Neuinstallation, Neustart des Raspis und ein npm Rebuild (siehe oben) haben nichts gebracht.
                          Leider werde ich aus dem Log nicht schlau. Hat jemand eine Idee?
                          Installiert:
                          Npm 6.4.1
                          Node 8.15.0
                          UPDATE:
                          Ich habe den Adapter noch mal neu installiert und mir das Log angeschaut. Hier treten bereits einige Fehler auf. Die Instanz wird dann aber trotzdem angelegt:
                          sudo iobroker add amazon-dash
                          NPM version: 6.4.1
                          npm install iobroker.amazon-dash --production --save --prefix "/opt/iobroker" (System call)
                          WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
                          ../socket_watcher.cpp: In static member function ‘static void SocketWatcher::Callback(uv_poll_t*, int, int)’:
                          ../socket_watcher.cpp:77:60: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                             Nan::MakeCallback(watcher->handle(), callback, argc, argv);
                          In file included from ../socket_watcher.hpp:8:0,
                                           from ../socket_watcher.cpp:5:
                          ../../nan/nan.h:959:46: note: declared here
                             NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
                          ../pcap_session.cc: In static member function ‘static void PcapSession::PacketReady(u_char*, const pcap_pkthdr*, const u_char*)’:
                          ../pcap_session.cc:85:102: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                               Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(session->packet_ready_cb), 0, NULL);
                          In file included from ../pcap_session.h:4:0,
                                           from ../pcap_session.cc:7:
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                          host.ioBroker-RasPi install adapter amazon-dash
                          got /opt/iobroker/node_modules/iobroker.amazon-dash/admin
                          upload [3] amazon-dash.admin /opt/iobroker/node_modules/iobroker.amazon-dash/admin/words.js words.js application/javascript
                          upload [2] amazon-dash.admin /opt/iobroker/node_modules/iobroker.amazon-dash/admin/index_m.html index_m.html text/html
                          upload [1] amazon-dash.admin /opt/iobroker/node_modules/iobroker.amazon-dash/admin/index.html index.html text/html
                          upload [0] amazon-dash.admin /opt/iobroker/node_modules/iobroker.amazon-dash/admin/amazon-dash.png amazon-dash.png image/png
                          host.ioBroker-RasPi object system.adapter.amazon-dash created
                          host.ioBroker-RasPi create instance amazon-dash
                          host.ioBroker-RasPi object system.adapter.amazon-dash.0.outputCount created
                          host.ioBroker-RasPi object system.adapter.amazon-dash.0.inputCount created
                          host.ioBroker-RasPi object system.adapter.amazon-dash.0.uptime created
                          host.ioBroker-RasPi object system.adapter.amazon-dash.0.memRss created
                          host.ioBroker-RasPi object system.adapter.amazon-dash.0.memHeapTotal created
                          host.ioBroker-RasPi object system.adapter.amazon-dash.0.memHeapUsed created
                          host.ioBroker-RasPi object system.adapter.amazon-dash.0.connected created
                          host.ioBroker-RasPi object system.adapter.amazon-dash.0.alive created
                          host.ioBroker-RasPi object system.adapter.amazon-dash.0 created
                          UPDATE 2:
                          Ich habe den Adapter wieder ans Laufen bekommen.
                          Nachdem ich folgende zwei Befehle ausgeführt habe:
                          npm install pcap
                          npm install socketwatcher
