  4. [Vorlage] Spotify Skript
    6.7k
javascript
745 Beiträge 95 Kommentatoren 341.9k Aufrufe 41 Beobachtet
    tempestas
    #254
    via admin katze von url installieren und via putty sudo npm install iobroker.spotify-premium
    <size="85">ioBroker | 21 Adapter | Ubuntu Server | intel NUC | Homematic CCU2 | Hue | Osram Lightify| Sonos | 2x Instar Cam | Samsung Tab A 2016 im Holzrahmen| 3x Echo dot | 1x Echo | Neato Botvac D5</size>
    • wendy2702W Online
      wendy2702W Online
      #255
      Du hast bei der Katze diesen Link rein kopiert:
      https://github.com/twonky4/ioBroker.spotify-premium
      Kannst du davon mal das komplette Logfile posten bitte!
        tempestas
        #256
        ich installiere gerade nochmal mit debug ausgänge. mal sehen
          tempestas
          #257
          host.iobrokerNUC	2018-03-01 19:43:30.034	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
          iobroker	2018-03-01 19:43:29.565	info	exit 0
          iobroker	2018-03-01 19:43:29.485	info	npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          iobroker	2018-03-01 19:43:29.485	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
          iobroker	2018-03-01 19:43:29.485	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):
          iobroker	2018-03-01 19:43:29.485	info	npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          iobroker	2018-03-01 19:43:29.485	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents):
          iobroker	2018-03-01 19:43:29.485	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wa
          iobroker	2018-03-01 19:43:29.470	info	iobroker@1.0.0 /opt/iobroker└── iobroker.spotify-premium@0.1.0
          iobroker	2018-03-01 19:41:45.099	info	npm install https://github.com/twonky4/ioBroker.spotify-premium/tarball/master --production --prefix "/opt/iobroker" (System call)
          iobroker	2018-03-01 19:41:44.840	info	install https://github.com/twonky4/ioBroker.spotify-premium/tarball/master
          iobroker	2018-03-01 19:41:44.176	info	url "https://github.com/twonky4/ioBroker.spotify-premium" --debug
          • wendy2702W Online
            wendy2702W Online
            #258
            Mach mal bitte
            node -v
            npm -v
              tempestas
              #259
              node 6.11.3
              npm 4.6.1
              • fischi87F Offline
                fischi87F Offline
                fischi87
                #260
                servus, habe auch gerade versucht den adapter zu starten, installation passt, ohne problem aber ich bekomme die autorisierung nicht hin, bekomme immer diesen Fehler:
                error	invalid session. You need to open the actual Authorization.Authorization_URL
                Mit freundlichen Grüßen
                • wendy2702W Online
                  wendy2702W Online
                  #261
                  Hast du den neu installiert?
                  Wenn ja nach welcher Anleitung und mit welchem OS?
                  Ist der Adapter wirklich nicht installiert?
                  • wendy2702W Online
                    wendy2702W Online
                    #262
                    @fischi87:
                    Mit freundlichen Grüßen `
                    Du hast alle Schritte die im Adapter erklärt sind „Richtig“ ausgeführt?
                      tempestas
                      #263
                      edit:
                      ich war wieder zu blöd
                      iobroker add spotify-premium fehlte mir.
                      gut, dass ich mir mal rainers posting dazu in die favs gespeichert habe. nun kann ich mir den adapter anschauen
                      • wendy2702W Online
                        wendy2702W Online
                        #264
                        Also fehlte die Instanz
                        Machst du das nicht über die Admin Oberfläche?
                          tempestas
                          #265
                          doch hatte ich. passiert bei mir aber gelegentlich, dass da keine instanz mitkommt.
                          • wendy2702W Online
                            wendy2702W Online
                            #266
                            Ok
                            Ist das der neue Admin ?
                              tempestas
                              #267
                              Nein.
                              leider kann ich mich mal wieder nicht authen.
                              Die im Browser angezeigte URI bleibt genau die gleiche, die ich auch eingegeben habe aus dem Adapter. Ich sehe dann auch, dass ich verbinden soll, mache ich und dann kommt wie erwartet "invalid redirect uri".
                              Nur, dass in der Adresszeile halt das gleiche drin steht wie vorher. Ich bekomme nichts, um es in die auth Zeile einzugeben
                              genau genommen passiert auf der spotify account page halt einfach gar nichts, wenn ich mich anmelden will. Wenn ich was falsches angebe reagiert sie und sagt falsches PW, beim richtigen passiert einfach… nichts
                              • wendy2702W Online
                                wendy2702W Online
                                #268
                                Das sieht nur genauso aus.
                                Hast du bestimmt nicht Zeichen für Zeichen verglichen, oder doch !?
                                Einfach kopieren und einfügen.
                                  tempestas
                                  #269
                                  @wendy2702:
                                  Gesendet von iPhone mit Tapatalk Pro `
                                  hab sie mal untereinander gepackt die uris, die sahen für mich 100% gleich aus
                                  ok nun wirds vollends strange. wie gesagt reagiert der anmelde button nicht.
                                  wenn ich dann "ZURÜCK" klicke auf der Maus kommt dann die Abfrage, ob ich verbinden will (??) und auch hier tut der "ok" button einfach… gar nichts
                                  • C Offline
                                    Conquest
                                    #270
                                    @tempestas:
                                    @wendy2702:
                                    wenn ich dann "ZURÜCK" klicke auf der Maus kommt dann die Abfrage, ob ich verbinden will (??) und auch hier tut der "ok" button einfach… gar nichts ` Browser Cache gelöscht? Hat bei mir geholfen.
                                    LG Torsten
                                    • wendy2702W Online
                                      wendy2702W Online
                                      #271
                                      So,
                                      Rechner mal angeschmissen.
                                      Du hast alle Punkte aus der Adapter Beschreibung ausgeführt?
                                      Kein Copy & Paste fehler bei Client ID und/oder Client Secret? Da hatte ich mal ein leerzeichen am Anfang mit kopiert.
                                      Welchen Browser benutzt du? Cache gelöscht oder anderen Probiert!?
                                      Wie sieht deine Einstellung der Spotify Developer App aus?
                                        tempestas
                                        #272
                                        Danke, bei mir ändert sich nichts. Der Button tut einfach nichts. Wie gesagt, bei falschem PW wird genörgelt, beim richtiugen passiert nichts ??
                                        • fischi87F Offline
                                          fischi87F Offline
                                          fischi87
                                          #273
                                          @wendy2702:
                                          @fischi87:
                                          Du hast alle Schritte die im Adapter erklärt sind „Richtig“ ausgeführt? `
                                          Ja hab ich getan.
