  4. Blocky Hilfe bitte
    6.0k
Blocky Hilfe bitte
19 Beiträge 7 Kommentatoren 3.5k Aufrufe
  • paul53P Offline
    Aufgrund der eingebauten Hysterese ist folgende Lösung noch zuverlässiger (sendet nur, wenn wirklich erforderlich).
    <xml xmlns="http://www.w3.org/1999/xhtml"><block type="variables_set" id="zX3-_1w%Tfw1ll=E5Ypl" x="-550" y="-337"><field name="VAR">befeuchter</field>
    <value name="VALUE"><block type="get_value" id=";In!?f]hJ^R{yXkNxhzE"><field name="ATTR">val</field>
    <field name="OID">ID auswählen</field></block></value>
    <next><block type="comment" id="xY1ZWm,+2EJohhee~qTo"><field name="COMMENT">ID Luftfeuchte</field>
    <next><block type="on" id="R.tnni:[OVG-`,!SO?^-"><field name="OID">Object ID</field>
            <statement name="STATEMENT"><block type="controls_if" id="!ukq.(e%x7[?v)C^c9Pu"><mutation elseif="1"></mutation>
                <value name="IF0"><block type="logic_operation" id="TIi{f6Wr8tytMG3Q*JV8"><field name="OP">AND</field>
                    <value name="A"><block type="logic_compare" id="0=RYe[Fo!p6y1~J)aoQC"><field name="OP">LTE</field>
                        <value name="A"><block type="on_source" id="V:I%HObLeriqNo_#HwdQ"><field name="ATTR">state.val</field></block></value>
                        <value name="B"><block type="math_number" id="8[JVTbY@[n{][Ty]_%MA"><field name="NUM">35</field></block></value></block></value>
                    <value name="B"><block type="logic_negate" id="Kv2D6OmoX:DGJ%XGr+`x"><value name="BOOL"><block type="variables_get" id="`odN@@jN0UiUA.(oyLP|"><field name="VAR">befeuchter</field></block></value></block></value></block></value>
                <statement name="DO0"><block type="control" id="Ax-F333s_8JL6V*fQg0@"><mutation delay_input="false"></mutation>
                    <value name="VALUE"><block type="logic_boolean" id="xZ)z|lBDDq,f9FM,gy1|"><field name="BOOL">TRUE</field></block></value></block></statement>
                <value name="IF1"><block type="logic_operation" id="P|jrKgJzROk+5dTEA[a]"><field name="OP">AND</field>
                    <value name="A"><block type="logic_compare" id="XF1;wR%nXLmtmA+NQ;`("><field name="OP">GTE</field>
                        <value name="A"><block type="on_source" id="8oWSo(Z:mX)ILa{fb[8#"><field name="ATTR">state.val</field></block></value>
                        <value name="B"><block type="math_number" id="sZ-=`;4(FiWDP~IvO-LW"><field name="NUM">45</field></block></value></block></value>
                    <value name="B"><block type="variables_get" id="COXr;XMvjdFm3g%~e{]V"><field name="VAR">befeuchter</field></block></value></block></value>
                <statement name="DO1"><block type="control" id="/Jctsap|B6DF~z!/,7z,"><mutation delay_input="false"></mutation>
                    <value name="VALUE"><block type="logic_boolean" id="~KF,Az?ML1HN6o[CT[Rj"><field name="BOOL">FALSE</field></block></value></block></statement></block></statement>
            <next><block type="comment" id="zZloThnMeSu;p5jOW#Ec"><field name="COMMENT">ID Befeuchter</field>
                <next><block type="on" id="%tNgK/*+A0~k}iB1,cc,"><field name="OID">Object ID</field>
                    <field name="ACK_CONDITION">true</field>
                    <statement name="STATEMENT"><block type="variables_set" id="*Xy/Lu9J#cbgrq(j{5PE"><field name="VAR">befeuchter</field>
                        <value name="VALUE"><block type="on_source" id="F+u#OXL|y@+WdoIZa5Rf"><field name="ATTR">state.val</field></block></value></block></statement></block></next></block></next></block></next></block></next></block></xml>
    • rantanplanR Offline
      rantanplanR Offline
      rantanplan
      @paul53:
      Aufgrund der eingebauten Hysterese ist folgende Lösung noch zuverlässiger (sendet nur, wenn wirklich erforderlich). `
      @paul53 Echt genial.
      @Robbsy Du hast doch jetzt sicherlich verstanden wie es geht.
      Rantanplan
        Super!
        Jetzt fängt @Paul53 auch noch an, bei Blockly hochoptimierten Code zu schreiben. :o
        Wahnsinn, was da alles sogar mit Blockly geht!
        Gruß Rainer
        • paul53P Offline
          @Homoran:
          Wahnsinn, was da alles sogar mit Blockly geht! `
          Ja, aber es gibt schon einige Einschränkungen in Blockly.
          @Homoran:
          bei Blockly hochoptimierten Code zu schreiben. `
          Die Begeisterung teilen nicht alle, denn einige Nutzer sind der Meinung, dass es in Blockly http://forum.iobroker.net/viewtopic.php?f=21&t=10807&start=40#p118668 geht.
          • R Offline
            Robbsy
            Liebe Leute,
            ein wenig peinlich ist es mir zwar nicht selbst auf die Lösung zu kommen, aber der Luftbefeuchter springt einfach nicht an :shock:
            ! <xml 1999/xmlns="<URL url=" http:/www.w3.org/xhtml"="">http://www.w3.org/1999/xhtml">
            ! <block type="variables_set" id="zX3-1w%Tfw1ll=E5Ypl" x="-550" y="-337"><field name="VAR">befeuchter</field>
            ! <value name="VALUE"><block type="get_value" id=";In!?f]hJ^R{yXkNxhzE"><field name="ATTR">val</field>
            ! <field name="OID">netatmo.0.Robert.Indoor.Humidity.Humidity</field></block></value>
            ! <next><block type="comment" id="xY1ZWm,+2EJohhee~qTo"><field name="COMMENT">ID Luftfeuchte</field>
            ! <next><block type="on" id="R.tnni:[OVG-`,!SO?^-"><field name="OID">netatmo.0.Robert.Indoor.Humidity.Humidity</field>
            ! <field name="CONDITION">ne</field>
            ! <statement name="STATEMENT"><block type="controls_if" id="!ukq.(e%x7[?v)C^c9Pu"><mutation elseif="1"></mutation>
            ! <value name="IF0"><block type="logic_operation" id="TIi{f6Wr8tytMG3Q*JV8"><field name="OP">AND</field>
            ! <value name="A"><block type="logic_compare" id="0=RYe[Fo!p6y1~J)aoQC"><field name="OP">LTE</field>
            ! <value name="A"><block type="on_source" id="V:I%HObLeriqNo
            ! <value name="B"><block type="math_number" id="8[JVTbY@[n{][Ty]_%MA"><field name="NUM">39</field></block></value></block></value>
            ! <value name="B"><block type="logic_negate" id="Kv2D6OmoX:DGJ%XGr+`x"><value name="BOOL"><block type="variables_get" id="`odN@@jN0UiUA.(oyLP|"><field name="VAR">befeuchter</field></block></value></block></value></block></value>
            ! <statement name="DO0"><block type="control" id="Ax-F333s_8JL6VfQg0@"><mutation delay_input="false"></mutation>
            ! <field name="OID">hue.0.Philips_hue.On/Off_Osram.on</field>
            ! <field name="WITH_DELAY">FALSE</field>
            ! <value name="VALUE"><block type="logic_boolean" id="xZ)z|lBDDq,f9FM,gy1|"><field name="BOOL">TRUE</field></block></value></block></statement>
            ! <value name="IF1"><block type="logic_operation" id="P|jrKgJzROk+5dTEA[a]"><field name="OP">AND</field>
            ! <value name="A"><block type="logic_compare" id="XF1;wR%nXLmtmA+NQ;`("><field name="OP">GTE</field>
            ! <value name="A"><block type="on_source" id="8oWSo(Z:mX)ILa{fb[8#"><field name="ATTR">state.val</field></block></value>
            ! <value name="B"><block type="math_number" id="sZ-=`;4(FiWDP~IvO-LW"><field name="NUM">43</field></block></value></block></value>
            ! <value name="B"><block type="variables_get" id="COXr;XMvjdFm3g%~e{]V"><field name="VAR">befeuchter</field></block></value></block></value>
            ! <statement name="DO1"><block type="control" id="/Jctsap|B6DF~z!/,7z,"><mutation delay_input="false"></mutation>
            ! <value name="VALUE"><block type="logic_boolean" id="~KF,Az?ML1HN6o[CT[Rj"><field name="BOOL">FALSE</field></block></value></block></statement></block></statement>
            ! <next><block type="comment" id="zZloThnMeSu;p5jOW#Ec"><field name="COMMENT">ID Befeuchter</field>
            ! <next><block type="on" id="%tNgK/
            +A0~k}iB1,cc,"><field name="OID">hue.0.Philips_hue.On/Off_Osram.on</field>
            ! <field name="CONDITION">any</field>
            ! <field name="ACK_CONDITION">true</field>
            ! <statement name="STATEMENT"><block type="variables_set" id="*Xy/Lu9J#cbgrq(j{5PE"><field name="VAR">befeuchter</field>
            ! <value name="VALUE"><block type="on_source" id="F+u#OXL|y@+WdoIZa5Rf"><field name="ATTR">state.val</field></block></value></block></statement></block></next></block></next></block></next></block></next></block></xml>
            Wenn es hilft: Mit einem IFTTT Trigger rennt es. Nur möchte ich IFTTT nicht verwenden, ist mir irgendwie niht sympatisch.
            • paul53P Offline
              Ganz oben muss die Objekt ID Philips_hue.On/Off_Osram.on rein.
                Marko79
                auch ich brauch mal eure Hilfe bezgl Blocky
                Ich versuche mittels RFID-Chip eine Lampe zu schalten.
                Per Sprache über IOBroker geht es.
                Das schalten mittels einer RFID für AN und einer anderen für AUS geht auch.
                Ich will aber keine 2 RFID-Chips dafür verwenden sondern der Zeitstempel mit einbinden.
                Das klappt aber gar nicht.
                Hier mal mein Script:
                on({id: 'mqtt.0.domoticz.in', change: "any"}, function (obj) {
                var value = obj.state.val;
                if (getState("mqtt.0.domoticz.in").ts != getState("mqtt.0.domoticz.in").ts) {
                if (getState("mqtt.0.domoticz.in").val == ('mqtt.0.domoticz.in' == '{"idx":1,"nvalue":0,"svalue":"909222828"}' && getState("broadlink.0.learnedSignals.TV_Licht").val == false)) {
                setStateDelayed("broadlink.0.learnedSignals.TV_Licht"/TV Licht_/, true, 1000, false);
                } else if (getState("mqtt.0.domoticz.in").val == ('mqtt.0.domoticz.in' == '{"idx":1,"nvalue":0,"svalue":"909222828"}' && getState("broadlink.0.learnedSignals.TV_Licht").val == true)) {
                setStateDelayed("broadlink.0.learnedSignals.TV_Licht"/TV Licht_/, false, 1000, false);
                Habt Ihr ne Idee??? Irgendwas mach ich wohl falsch.
                  rantanplanR Offline
                  rantanplan
                  @Marko79:
                  Hier mal mein Script: `
                  Hallo Marko79
                  Was sollen die Leute, die mit Blockly arbeiten, mit dem Script anfangen? :roll:
                  Ein Screenshot von dem Blockly wäre da bestimmt hilfreicher. ;)
                  Rantanplan
                    Marko79
                    Sorry, das hab ich nicht bedacht.
                    Hier nun also ein Screenshot.
                    • paul53P Offline
                      @Marko79:
                      if (getState("mqtt.0.domoticz.in").ts != getState("mqtt.0.domoticz.in").ts) { `
                      Dieser Ausdruck liefert immer false, die folgenden Befehle werden also nie ausgeführt.
                      @Marko79:
                      if (getState("mqtt.0.domoticz.in").val == ('mqtt.0.domoticz.in' == '{"idx":1,"nvalue":0,"svalue":"909222828"}' && getState("broadlink.0.learnedSignals.TV_Licht").val == false)) { `
                      Was soll hier geprüft werden ?
                        Marko79
                        Ich wollte prüfen ob der Zeitstempel der gleiche ist und wenn ja dann den token mit dem hinterlegten vergleichen.
                        Stimmt der Token und der Zeitstempel ist ein anderer dann soll der Schalter TV_Licht umschalten.
