  2. English
  3. Development
  4. Test Adapter anthbot-genie v0.1.x
    5.1k
Geplant Angeheftet Gesperrt Verschoben Development
6 Beiträge 2 Kommentatoren 1.9k Aufrufe 2 Beobachtet
  • reloxx13R Offline
    reloxx13R Offline
    reloxx13
    schrieb am zuletzt editiert von reloxx13
    Test and Release GitHub version NPM version Downloads ioBroker installs License ioBroker phase
    Info
    Version 0.1.13
    npm latest 0.1.13
    Source npm
    GitHub https://github.com/reloxx13/ioBroker.anthbot-genie
    npm https://www.npmjs.com/package/iobroker.anthbot-genie
    Package iobroker.anthbot-genie
    js-controller >= 6.0.11
    Admin >= 7.6.20
    Node.js >= 22
    Connection Cloud
    Status latest
    Note unofficial, not affiliated with Anthbot
    Hello everyone,
    Version 0.1.13 of my ioBroker adapter for Anthbot Genie robotic mowers is now available in the ioBroker latest repository.
    The adapter is an unofficial cloud adapter for Anthbot Genie. It logs in to the Anthbot Cloud, discovers the available devices, resolves the region and IoT endpoints, and regularly polls mower status data. It also provides writable states for settings, mowing commands, docking, maintenance, and zones. The state structure stays stable under the same ioBroker paths for Genie 600/1000/3000/5000 as well as M5/M9 models.
    Features
    • Anthbot Cloud login
    • device discovery
    • region and IoT endpoint resolution
    • polling of mower property shadow and service shadow
    • automatic refresh of temporary IoT credentials after AWS IoT 403
    • status, metrics, diagnostics, and raw data states per mower
    • location states for GPS and local position data
    • M5/M9 mappings for status, battery, errors, network, RTK, map, and total mowing time/area
    • control commands via ioBroker states
    • full-area mowing, manual zone mowing, and automatic zone mowing
    • spot mowing, edge mowing, and mowing near the charging station
    • start, pause, resume, stop, and terminate mowing tasks
    • return to the charging station including pause while returning
    • maintenance commands such as find robot, grass discharge, and disc maintenance mode
    • consumable states for charging port, cameras, and blades including reset buttons
    • rain, obstacle, voice volume, and mowing parameter controls
    • raw data for property shadow, service shadow, Anthbot event code translations, and area definitions
    • password is stored as encrypted native configuration
    Requirements
    • ioBroker with js-controller >= 6.0.11
    • ioBroker Admin >= 7.6.20
    • Node.js >= 22
    • Anthbot account with at least one connected Anthbot mower
    Created States
    For each detected mower, the adapter creates the following sections among others:
    • info.*
    • metrics.*
    • diagnostics.*
    • location.*
    • consumable.*
    • controls.*
    • commands.*
    • zones.*
    • raw.*
    Current Highlights in 0.1.13
    • available through the ioBroker latest repository
    • grouped state structure under metrics, diagnostics, consumable, controls, commands, zones, and raw
    • M5/M9 payloads for status, battery, errors, network, RTK, map, and total mowing time/area are mapped into the existing state structure
    • temporary IoT credentials are refreshed automatically once after AWS IoT 403, and the failed shadow read or command publish is retried
    • diagnostic values for RTK, firmware, OTA, network, GPS/position, map, and errors
    • reset buttons for charging port, camera, and blade lifetime
    • new commands: find robot, grass discharge, disc maintenance mode, edge mowing, mowing near the charging station, and spot mowing
    • task commands: pause/resume mowing, pause return trip, and terminate mowing
    • control for mowing near the charging station
    • full-area mowing with optional edge cutting
    • RTK antenna moved warning and command to clear that warning
    Some commands may be unavailable or may be rejected by the mower depending on model, firmware, current mower state, and available map/edge data.
    Manual Zone Mowing
    Known manual zones are stored as a JSON array under this state:
    <instance>.<serial>.zones.manual.list
    To start one or more zones, write to this state:
    <instance>.<serial>.commands.mowing.startZone
    Accepted values:
    • single zone by ID: 3
    • single zone by name: Front yard
    • multiple zones, comma-separated: 3,5,Back yard
    • multiple zones as JSON array: [3,5,"Back yard"]
    Automatic zones are available under <instance>.<serial>.zones.autoList and are started with <instance>.<serial>.commands.mowing.startAutoZone.
    Spot Mowing
    Spot mowing is started through this state:
    <instance>.<serial>.commands.mowing.startPoint
    Accepted values:
    • coordinates as text: 123,456
    • coordinates as JSON object: {"x":123,"y":456}
    After successful execution, the state is cleared again.
    What Feedback Is Helpful
    • login with Anthbot account
    • detection of one or more mowers
    • updates of status, metrics, diagnostic values, and connection state
    • M5/M9 mappings for status, network, RTK, map status, and total mowing values
    • return to the charging station and pausing the return trip
    • manual and automatic zone mowing, if zones exist in the Anthbot app
    • spot mowing, edge mowing, and mowing near the charging station, if supported by the device
    • resetting consumable values only when the corresponding lifetime value is at or below 5 percent
    • behavior with wrong credentials, cloud connection issues, or AWS IoT 403
    Please include adapter version, ioBroker/js-controller version, Node.js version, and relevant log excerpts when posting feedback. Please do not publish credentials, tokens, serial numbers, or other personal data.
    Note: The adapter is unofficial and is not affiliated with or supported by Anthbot.
    Transparency Note
    AI was used as a supporting tool while creating this adapter, especially for code drafting, structuring, documentation, and review. Technical responsibility, testing, and publishing remain with the developer.
    Installation
    Via ioBroker Admin
    1. Open the adapter view.
    2. If the latest repository is not active yet, select or enable latest in ioBroker Admin under Settings -> Repositories and refresh the adapter list.
    3. Search for anthbot-genie in the latest repository and install the adapter.
    4. Create an adapter instance after installation.
    5. Enter Anthbot username, password, and country code in the adapter configuration.
    6. Start the instance and check the log and states.
    Via CLI
    Install the current version via npm:
    iobroker repo set latest
    iobroker update
    iobroker add anthbot-genie
    Or install the exact version:
    iobroker add anthbot-genie@0.1.13
    If the instance was not created automatically after installation:
    iobroker add anthbot-genie --enabled
    • reloxx13R Offline
      reloxx13R Offline
      reloxx13
      Hello everyone,
      Current adapter status:
      • current version: 0.1.13
      • installation via npm is available
      • Node.js requirement is now >= 22
      • the state structure has been expanded quite a bit and remains stable under the same ioBroker paths for both Genie and M5/M9
      • it now includes status, diagnostics, location, consumable, zone, control, and command states
      • M5/M9-specific payloads for status, network, RTK, map status, and total mowing time/area are now also mapped into the existing state structure
      • on AWS IoT 403 responses, temporary IoT credentials are refreshed once automatically and the failed shadow read or command publish is retried
      Over the last few days I also split up and cleaned up the adapter internally and expanded the checks so the internal modules and tests are validated properly. Functionally, this should not have changed any state IDs or command payload behavior.
      The adapter is now included in the ioBroker latest repository and can be installed directly from the ioBroker adapter view.
      It would be especially helpful to get confirmations from users with an M5 or M9 that the new payload mappings work reliably in day-to-day use.
      If anyone tests the current build, these points are especially interesting:
      • login and device discovery
      • shadow/status updates over longer runtimes
      • point mowing
      • near-charger mowing
      • behavior after connection issues or 403 errors
      As always, feedback is welcome together with adapter version, js-controller version, Node.js version, and relevant log output.
      • reloxx13R Offline
        reloxx13R Offline
        reloxx13
        Adapter got added to latest repo!
        • M Online
          M Online
          MrHenker27
          @reloxx13 kann man sich auch die Karte als IMG ausgeben lassen? Ich habe den M9
          reloxx13R 1 Antwort Letzte Antwort
          • M MrHenker27
            reloxx13R Offline
            reloxx13R Offline
            reloxx13
            @MrHenker27 sagte:
            aktuell leider nicht.
            • M Online
              M Online
              MrHenker27
              schrieb zuletzt editiert von
              ich habe mal nen fork erstellt und nacharbeiten "lassen" ;)
              greets
