<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Test Adapter anthbot-genie v0.1.x npm&#x2F;GitHub]]></title><description><![CDATA[<table class="table table-bordered table-striped">
<thead>
<tr>
<th>Info</th>
<th></th>
</tr>
</thead>
<tbody>
<tr>
<td>Adapter</td>
<td><code>anthbot-genie</code></td>
</tr>
<tr>
<td>Version</td>
<td><code>0.1.5</code></td>
</tr>
<tr>
<td>npm latest</td>
</tr>
<tr>
<td>npm next</td>
<td><code>-</code></td>
</tr>
<tr>
<td>Source</td>
<td>npm / GitHub</td>
</tr>
<tr>
<td>GitHub</td>
<td><a href="https://github.com/reloxx13/ioBroker.anthbot-genie" rel="nofollow ugc">https://github.com/reloxx13/ioBroker.anthbot-genie</a></td>
</tr>
<tr>
<td>npm</td>
<td><a href="https://www.npmjs.com/package/iobroker.anthbot-genie" rel="nofollow ugc">https://www.npmjs.com/package/iobroker.anthbot-genie</a></td>
</tr>
<tr>
<td>Package</td>
<td><code>iobroker.anthbot-genie</code></td>
</tr>
<tr>
<td>js-controller</td>
<td><code>&gt;= 6.0.11</code></td>
</tr>
<tr>
<td>Admin</td>
<td><code>&gt;= 7.6.20</code></td>
</tr>
<tr>
<td>Node.js</td>
<td><code>&gt;= 20</code></td>
</tr>
<tr>
<td>Connection</td>
<td>Cloud</td>
</tr>
<tr>
<td>Status</td>
<td>latest</td>
</tr>
<tr>
<td>Note</td>
<td>unofficial, not affiliated with Anthbot</td>
</tr>
</tbody>
</table>
<p dir="auto">Hello everyone,</p>
<p dir="auto">I would like to make version 0.1.x of my ioBroker adapter for Anthbot Genie robotic lawn mowers available.</p>
<p dir="auto">The adapter is an unofficial cloud adapter for Anthbot Mowrobots. It logs in to the Anthbot Cloud, discovers the available devices, determines the region and IoT endpoints, and regularly polls status data from the robotic mower. In addition, it provides writable states for settings, mowing commands, docking, maintenance, and zones.</p>
<h2>Features</h2>
<ul>
<li>Anthbot Cloud login</li>
<li>Device discovery</li>
<li>Region and IoT endpoint detection</li>
<li>Polling of mower property shadow and service shadow</li>
<li>Status, metric, diagnostic, and raw-data states per robotic mower</li>
<li>Control commands via ioBroker states</li>
<li>Full-area mowing, manual zone mowing, and automatic zone mowing</li>
<li>Spot mowing, edge mowing, and mowing near the charging station</li>
<li>Start, pause, resume, stop, and finish mowing tasks</li>
<li>Return to charging station, including pausing the return trip</li>
<li>Maintenance commands such as find robot, grass disposal, and disc maintenance mode</li>
<li>Consumable states for charging port, cameras, and blades, including reset buttons</li>
<li>Rain and mowing parameter control</li>
<li>Password is stored as encrypted native configuration</li>
</ul>
<h2>Requirements</h2>
<ul>
<li>ioBroker with js-controller &gt;= 6.0.11</li>
<li>Admin &gt;= 7.6.20</li>
<li>Node.js &gt;= 20</li>
<li>Anthbot account with a configured Genie robotic mower</li>
</ul>
<h2>Created States</h2>
<p dir="auto">For each detected robotic mower, the following areas are created, among others:</p>
<ul>
<li><code>info.*</code></li>
<li><code>metrics.*</code></li>
<li><code>diagnostics.*</code></li>
<li><code>location.*</code></li>
<li><code>consumable.*</code></li>
<li><code>controls.*</code></li>
<li><code>commands.*</code></li>
<li><code>zones.*</code></li>
<li><code>raw.*</code></li>
</ul>
<h2>Important Notes for 0.1.x</h2>
<ul>
<li>new grouped state structure under <code>metrics</code>, <code>diagnostics</code>, <code>consumable</code>, <code>controls</code>, <code>commands</code>, <code>zones</code>, and <code>raw</code></li>
<li>diagnostic values for RTK, firmware, OTA, network, GPS/position, map, and errors</li>
<li>reset buttons for charging port, camera, and blade lifetime</li>
<li>new commands: find robot, grass disposal, disc maintenance mode, edge mowing, mowing near the charging station, and spot mowing</li>
<li>task commands: pause/resume mowing, pause return trip, and finish mowing</li>
<li>control for mowing near the charging station</li>
<li>full-area mowing with optional edge cutting</li>
<li>RTK antenna moved warning and command to reset this warning</li>
</ul>
<p dir="auto">Some commands may not be available or may be rejected by the mower depending on the model, firmware, current mower state, and available map/edge data.</p>
<h2>Manual Zone Mowing</h2>
<p dir="auto">The known manual zones are stored as a JSON array under the following state:</p>
<pre><code class="language-text">&lt;instance&gt;.&lt;serial&gt;.zones.manual.list</code></pre>
]]></description><link>https://forum.iobroker.net/topic/84547/test-adapter-anthbot-genie-v0.1.x-npm-github</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 15:31:59 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/84547.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 14 May 2026 10:41:00 GMT</pubDate><ttl>60</ttl></channel></rss>
