  4. [Vorlage] Spotify Skript
    6.6k
javascript
745 Beiträge 95 Kommentatoren 341.8k Aufrufe 41 Beobachtet
  • wendy2702W Online
    wendy2702W Online
    #208
    in Luckys script sieht es aber bei den Playlists so für mich aus:
    Ich habe mal ein Issue auf Github dazu aufgemacht. Hoffe das ist OK.
    Gerade gesehen, um 11:43 hat der Adapter einen restart gemacht ohne das irgendetwas am System gemacht wurde:
    host.openmediavault 2018-02-16 11:43:23.030 error instance system.adapter.spotify-premium.0 terminated with code 6 (uncaught exception)
    spotify-premium.0 2018-02-16 11:43:22.006 error at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
    spotify-premium.0 2018-02-16 11:43:22.006 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
    spotify-premium.0 2018-02-16 11:43:22.006 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    spotify-premium.0 2018-02-16 11:43:22.006 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
    spotify-premium.0 2018-02-16 11:43:22.006 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    spotify-premium.0 2018-02-16 11:43:22.006 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    spotify-premium.0 2018-02-16 11:43:22.006 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    spotify-premium.0 2018-02-16 11:43:22.006 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
    spotify-premium.0 2018-02-16 11:43:22.006 error at Socket. (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:724:13)
    spotify-premium.0 2018-02-16 11:43:22.006 error at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:698:40
    spotify-premium.0 2018-02-16 11:43:22.006 error TypeError: callback is not a function
    spotify-premium.0 2018-02-16 11:43:22.004 error uncaught exception: callback is not a function
    • twonkyT Offline
      twonkyT Offline
      twonky
      #209
      Ich war bereits dran und dank deines Screenshots habe ich verstanden was du meinst. Du kannst dir gerne Version https://github.com/twonky4/ioBroker.spotify-premium angucken.
      In Version 0.0.7 ist nun auch der letzte Fehler behoben. Der trat auf wenn der Spotify Session Token abgelaufen war. War aber in Luckys Skript auch schon so.
      • wendy2702W Online
        wendy2702W Online
        #210
        0.0.7 installiert.
        Sieht erstmal gut aus.
        Danke für den schnellen fix!
        • 0 Offline
          0 Offline
          0018
          #211
          Kurze Frage: Wenn ich die Updates aus eigener URL installiere, muss ich dann jedesmal die alte Spotify Instanz löschen und eine neue manuell anlegen?
          EDIT: Das habe ich jetzt mal gemacht und nun klappt es auch bei mir mit der 0.0.7
          Mfg
          0018
          • E Offline
            el-lutschi
            #212
            gibt es eigentlich die Möglichkeit, wenn ich am PC im Spotify Programm die Lautstäre ändere, diese an das Skript zurück gemeldet wird?
            Wenn ich aktuell die Laustäkre über den PC oder das Handy ändere, bleibt im Skript der Player -> Volume Wert immer gleich.
            Außerdem frage ich mich wozu unter Devices noch einmal ein Volume Wert für jedes einzelne Gerät ist? Wenn ich dort etwas ändere passiert nichts an der Lautstärke.
            • twonkyT Offline
              twonkyT Offline
              twonky
              #213
              @el-lutschi:
              Wenn du die Lautstärke über den PC oder der Spotify App änderst wird diese im Intervall von 5 Sekunden aktualisiert in dem State PlaybackInfo.Device.volume_percent. Aber nur wenn der Player auch abspielt.
              Die volume_percent States unter den Devices werden derzeit nur aktualisiert wenn du Devices.Get_Devices aufrufst.
              Ändern kannst du die Lautstärke immer über Player.Volume
              • E Offline
                el-lutschi
                #214
                @twonky:
                @el-lutschi:
                Ändern kannst du die Lautstärke immer über Player.Volume `
                Erstmal vielen Dank für die Antwort. Leider aktualisiert sich bei mir der Volume Wert nicht, wenn ich am PC oder in der App etwas ändere. Die andere Richtung funktioniert allerdings.
                • wendy2702W Online
                  wendy2702W Online
                  #215
                  heute nach ein paar Tagen mal Spotify über meine VISU starten wollen.
                  Als keine Musik ertönte mal ins log geschaut:
                  spotify-premium.0 2018-02-20 13:02:00.977 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.968 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.967 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.966 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.966 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.949 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.949 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.946 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.946 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.938 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.938 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.925 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.925 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.923 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.923 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.916 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.916 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.865 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.864 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.864 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.830 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.830 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.829 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.829 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.826 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.826 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.821 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.821 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.817 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.817 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.810 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.810 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.807 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.807 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.805 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.805 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.675 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.675 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.644 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.644 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.642 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.642 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.635 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.635 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.404 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.404 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.367 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.367 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.364 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.364 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.342 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.342 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.256 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.256 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.185 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.185 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  spotify-premium.0 2018-02-20 13:02:00.181 warn Spotify Intervall gestoppt !
                  spotify-premium.0 2018-02-20 13:02:00.181 warn HTTP Request Fehler wird nicht behandelt, bitte Debuggen !!
                  Nach Adapter restart scheint es wieder zu gehen.
                  • wendy2702W Online
                    wendy2702W Online
                    #216
                    @el-lutschi:
                    @twonky:
                    @el-lutschi:
                    Erstmal vielen Dank für die Antwort. Leider aktualisiert sich bei mir der Volume Wert nicht, wenn ich am PC oder in der App etwas ändere. Die andere Richtung funktioniert allerdings. `
                    Also bei mir ändert sich der Rot markierte Wert wenn ich z.B. über den Spotify Web Player Musik auf meinem Yamaha WX-030 abspiele:
                    • twonkyT Offline
                      twonkyT Offline
                      twonky
                      #217
                      @wendy2702:
                      Nach Adapter restart scheint es wieder zu gehen. `
                      Das gleiche ist mir heute Morgen auch aufgefallen. Ich habe zwar einen Fehler in der Intervall Steuerung gefunden, ich bezweifele allerdings, das es damit zu tun hat.
                      Ich baue gerade noch was anderes um und würde dann beides zusammen releasen.
                      • twonkyT Offline
                        twonkyT Offline
                        twonky
                        #218
                        Nun ist Version https://github.com/twonky4/ioBroker.spotify-premium verfügbar. Enthaltene Änderungen:
                        • Playlisten werden nun komplett geladen (nicht mehr nur die ersten 100 Tracks)
                        • Es gibt 2 neue Adapter Konfigurationen: * Nicht mehr vorhandene Playlisten werden beim Refresh(Get_User_Playlists) gelöscht
                          • Nicht mehr vorhandene Devices werden beim Refresh(Devices.Get_Devices) gelöscht
                        • Behoben: Das Durchführen der Authorization hat manchmal nicht geklappt, da die Authorization_Return_URI am Ende ein "#=" hatte. Das wird nun abgeschnitten.
                        • Behoben: Das Polling wurde bei manchen Fehlern nicht abgebrochen
                        • twonkyT Offline
                          twonkyT Offline
                          twonky
                          #219
                          Die Version https://github.com/twonky4/ioBroker.spotify-premium hat nun einige neuen Sachen:
                          • neuer State 'PlaybackInfo.repeat' mit möglichen Werten: off, context, track
                          • neuer State 'PlaybackInfo.shuffle' mit möglichen Werten: true, false
                          • States für das abspielende Device werden ebenfalls in 5s-Intervallen aktualisiert
                          • States in 'PlaybackInfo' werden jetzt auch aktualisiert, wenn kein Device aktiv ist
                          • States in 'PlaybackInfo' werden jetzt geleert, wenn kein Device verfügbar ist
                          • neue Playlisten werden beim ersten Abspielen nachgeladen
                          Die neuen States 'PlaybackInfo.repeat' und 'PlaybackInfo.shuffle' werden nur angelegt wenn ein neuer Adapter erstellt wird. Alternativ können diese natürlich auch manuel in vorhandene Adapter erstellt werden.
                          Sobald die Version ausreichend getestet ist kümmere ich mich auch um eine Veröffentlichung.
                          • wendy2702W Online
                            wendy2702W Online
                            #220
                            Werde ich heute oder morgen mal testen.
                            • twonkyT Offline
                              twonkyT Offline
                              twonky
                              #221
                              @wendy2702:
                              Ich kann schonmal bestätigen, das der o.g. Fehler noch da ist. Bin ihm aber noch nicht auf die schliche gekommen.
                              • wendy2702W Online
                                wendy2702W Online
                                #222
                                habe den Adapter per Cron so eingestellt das er nachts um 2 Uhr eine restart macht. Heute morgen trotzdem wieder der Fehler.
                                Es sieht auch, zumindest bei mir so aus das der Adapter die komplette Performance runter beeinflusst.
                                Wollte gerade mal das Loggen auf Debug stellen und dabei ist mir die hohe Anzahl der Ereignisse des Adapter aufgefallen.
                                Nutze noch Version 0.7.0 da sich ja laut deiner Aussage mit der neuen Version nichts an dem Problem geändert hat.
                                Edit: Nach dem umstellen auf Debug und dem dadurch bedingten Adapter restart ist auch die Anzahl der Ereignisse wieder OK.
                                • twonkyT Offline
                                  twonkyT Offline
                                  twonky
                                  #223
                                  Der hohe Messagedurchsatz kommt durch den bekannten Fehler zusande. Die Version 0.0.9 hat diesbezüglich auch besseres Logging (im debug) um ihn eher zu finden.
                                  • wendy2702W Online
                                    wendy2702W Online
                                    #224
                                    Drüber installieren oder besser alten deinstallieren und neuen installieren?
                                    • twonkyT Offline
                                      twonkyT Offline
                                      twonky
                                      #225
                                      @wendy2702:
                                      Drüber installieren oder besser alten deinstallieren und neuen installieren? `
                                      Das spielt nur eine Rolle ob du die neuen States 'PlaybackInfo.repeat' und 'PlaybackInfo.shuffle' selber anlegen möchtest oder nicht.
                                      • J Offline
                                        jankir
                                        #226
                                        Woran kann es liegen, dass ich die Werte nicht überschreiben kann in den Objekten? Ich versuche die volume_percent zu erhöhen aber es wird immer direkt wieder überschrieben? Komischerweise reagiert der Musiccast Lautsprecher nicht auf Änderungen der Lautstärke wenn spotify läuft wenn Sie über den ioBroker kommen… Kennt das jemand?
                                        • wendy2702W Online
                                          wendy2702W Online
                                          #227
                                          Ich nutze dafür den Musiccast Adapter und ändere darin die Lautstärke.
