  4. Harmony Adapter
    6.0k
Harmony Adapter
12 Beiträge 2 Kommentatoren 1.1k Aufrufe
    Blackeye
    ich habe mal wieder Probleme mit meinem Hamony Adapter, der sich nicht mehr verbindet.
    Hier mal das LOG:
    host.ioBroker-RasPi	2018-06-05 10:55:53.010	error	instance system.adapter.harmony.0 terminated with code 0 (OK)
    Caught	2018-06-05 10:55:53.009	error	by controller[0]: port: 5224 }
    Caught	2018-06-05 10:55:53.009	error	by controller[0]: address: '0.0.0.0',
    Caught	2018-06-05 10:55:53.009	error	by controller[0]: syscall: 'bind',
    Caught	2018-06-05 10:55:53.009	error	by controller[0]: errno: 'EADDRINUSE',
    Caught	2018-06-05 10:55:53.009	error	by controller[0]: code: 'EADDRINUSE',
    Caught	2018-06-05 10:55:53.009	error	by controller[0]: at process._tickCallback (internal/process/next_tick.js:180:9)
    Caught	2018-06-05 10:55:53.009	error	by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:141:11)
    Caught	2018-06-05 10:55:53.009	error	by controller[0]: at _handle.lookup (dgram.js:266:18)
    Caught	2018-06-05 10:55:53.009	error	by controller[0]: at _exceptionWithHostPort (util.js:1044:20)
    Caught	2018-06-05 10:55:53.008	error	by controller[0]: at Object._errnoException (util.js:1022:11)
    Caught	2018-06-05 10:55:53.008	error	by controller[0]: { Error: bind EADDRINUSE 0.0.0.0:5224
    harmony.0	2018-06-05 10:55:52.989	info	terminating
    harmony.0	2018-06-05 10:55:52.979	info	terminating
    harmony.0	2018-06-05 10:55:52.977	error	at process._tickCallback (internal/process/next_tick.js:180:9)
    harmony.0	2018-06-05 10:55:52.977	error	at _combinedTickCallback (internal/process/next_tick.js:141:11)
    harmony.0	2018-06-05 10:55:52.977	error	at _handle.lookup (dgram.js:266:18)
    harmony.0	2018-06-05 10:55:52.977	error	at _exceptionWithHostPort (util.js:1044:20)
    harmony.0	2018-06-05 10:55:52.977	error	at Object._errnoException (util.js:1022:11)
    harmony.0	2018-06-05 10:55:52.977	error	Error: bind EADDRINUSE 0.0.0.0:5224
    harmony.0	2018-06-05 10:55:52.977	error	uncaught exception: bind EADDRINUSE 0.0.0.0:5224
    harmony.0	2018-06-05 10:55:52.964	info	searching for Harmony Hubs...
    harmony.0	2018-06-05 10:55:52.655	info	starting. Version 0.9.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v8.9.4
    harmony.0	2018-06-05 10:55:52.415	info	States connected to redis: 127.0.0.1:6379
    host.ioBroker-RasPi	2018-06-05 10:55:50.470	info	instance system.adapter.harmony.0 started with pid 21900
    host.ioBroker-RasPi	2018-06-05 10:55:49.409	info	Restart adapter system.adapter.harmony.0 because enabled
    Lars
      @Blackeye:
      Error: bind EADDRINUSE 0.0.0.0:5224 `
      deutet darauf hin, dass da bereits etwas auf dem Port läuft.
      Der einfachste Test wäre als erstes ein Reboot.
      Wenn dann alles läuft -> ok.
      Wenn nicht ist da etwas im Argen, das man suchen muss.
        Blackeye
        restarts habe ich schon x Mal gemacht. Was könnte ich denn noch suchen?
        @Homoran:
        @Blackeye:
        Rainer `
          Restarts oder einen reboot?
          Fangen wir mal anders an:
          Was hast du zuletzt gemacht bevor diese Meldung auftrat?
            Blackeye
            habe alles gemacht:
            1. Restarts
            2. Reboots
            3. iobroker neustart
            4. ioboker stop / start
            und eigentlich nicht weiter. Ich habe gestern probiert die SD Karte in einen PI3b+ zu stopfen, leider ohne Erfolg (war wohl zu wenig Saft im Netzteil).
            Also Karte zurück in den alten PI und von da an Probleme. Ich kann nicht sagen ob der Fehler durch den Reboot oder durch den Wechsel der PI´s verursacht wurde.
            @Homoran:
            Was hast du zuletzt gemacht bevor diese Meldung auftrat? `
              @Blackeye:
              Ich habe gestern probiert die SD Karte in einen PI3b+ zu stopfen, leider ohne Erfolg (war wohl zu wenig Saft im Netzteil). `
              So etwas kann natürlich die gesamte Dateistruktur zerschießen :( wenn die Spannung genau während eines schreibzugriffs zusammenbricht.
              Außerdem braucht der Pi3B+ ein neueres Image, alte laufen da nicht drauf.
              Sicherheitshalber würde ich eine neue Karte neu aufbauen und ein Backup einspielen
                Blackeye
                wie kann ich denn ein Backup von iobroker machen?
                Würde dann direkt probieren den PI3b+ ans Laufen zu bekommen.
                @Homoran:
                @Blackeye:
                Rainer `
                  @Blackeye:
                  wie kann ich denn ein Backup von iobroker machen? `
                  Hast du keins?
                  http://www.iobroker.net/docu/?page_id=2380&lang=de
                  Ob es mit der eventuell defekten Version sinnvoll ist jetzt erst ein Backup zu erstellen ist natürlich fraglich.
                    Blackeye
                    ne von ioBroker leider nicht. Wie kommt das Backup denn anschließend wieder drauf und was ist da jetzt alles drin?
                    Lars
                    @Homoran:
                    @Blackeye:
                    Hast du keins?
                    Rainer `
                      Bitte keine sinnlosen Fullquotes vom Post davor!
                      @Blackeye:
                      Wie kommt das Backup denn anschließend wieder drauf und was ist da jetzt alles drin? `
                      viewtopic.php?f=17&t=13487&p=153492&hil … ps#p153492
                        Blackeye
                        Neuninstallation auf einem neuen PI hat geklappt.
                        Nach dem Backup musste ich noch diverse Adapter neu installieren, dann ging es aber.
                        Danke für die Hilfe
                          @Blackeye:
                          Nach dem Backup musste ich noch diverse Adapter neu installieren, `
                          das geht automatisch - dauert bis zu 2 Stunden;
                          da solltest du nicht zwischenpfuschen.
