  3. Einsteigerfragen
  4. HDG Heizung über Waveshare Modbus Gateway
    5.3k
85 Beiträge 4 Kommentatoren 5.8k Aufrufe 3 Beobachtet
  • Strike498S Strike498
    @Homoran
    Da bekomme ich dann diese Errors im Log.
    2025-12-02 22:30:30.086 - info: host.raspberrypi instance system.adapter.modbus.0 in version "6.3.2" started with pid 302084
    2025-12-02 22:30:30.667 - debug: modbus.0 (302084) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2025-12-02 22:30:30.685 - debug: modbus.0 (302084) Objects client ready ... initialize now
    2025-12-02 22:30:30.686 - debug: modbus.0 (302084) Objects create System PubSub Client
    2025-12-02 22:30:30.687 - debug: modbus.0 (302084) Objects create User PubSub Client
    2025-12-02 22:30:30.714 - debug: modbus.0 (302084) Objects client initialize lua scripts
    2025-12-02 22:30:30.717 - debug: modbus.0 (302084) Objects connected to redis: 127.0.0.1:9001
    2025-12-02 22:30:30.735 - debug: modbus.0 (302084) Redis States: Use Redis connection: 127.0.0.1:9000
    2025-12-02 22:30:30.744 - debug: modbus.0 (302084) States create System PubSub Client
    2025-12-02 22:30:30.745 - debug: modbus.0 (302084) States create User PubSub Client
    2025-12-02 22:30:30.802 - debug: modbus.0 (302084) States connected to redis: 127.0.0.1:9000
    2025-12-02 22:30:30.822 - debug: modbus.0 (302084) Plugin sentry Initialize Plugin (enabled=true)
    2025-12-02 22:30:30.966 - info: modbus.0 (302084) starting. Version 6.3.2 in /opt/iobroker/node_modules/iobroker.modbus, node: v22.21.0, js-controller: 7.0.7
    2025-12-02 22:30:31.025 - debug: modbus.0 (302084) Initialize Objects for disInputs: []
    2025-12-02 22:30:31.025 - debug: modbus.0 (302084) Initialize Objects for coils: []
    2025-12-02 22:30:31.026 - debug: modbus.0 (302084) Initialize Objects for inputRegs: [{"_address":"211","name":"Puffer Temperatur Oben","description":"Puffer Temperatur Oben Ist","unit":"°C","type":"uint16le","len":1,"factor":1,"offset":0,"formula":"","role":"value.temperature","room":"","cw":"","isScale":"","address":211,"deviceId":1,"id":"inputRegisters.211_Puffer_Temperatur_Oben"}]
    2025-12-02 22:30:31.026 - debug: modbus.0 (302084) Add inputRegisters.211_Puffer_Temperatur_Oben: {"_id":"inputRegisters.211_Puffer_Temperatur_Oben","type":"state","common":{"name":"Puffer Temperatur Oben Ist","role":"value.temperature","type":"number","read":true,"write":false,"def":0,"unit":"°C"},"native":{"regType":"inputRegs","address":211,"deviceId":1,"type":"uint16le","len":1,"offset":0,"factor":1}}
    2025-12-02 22:30:31.026 - debug: modbus.0 (302084) Initialize Objects for holdingRegs: [{"_address":"211","name":"Puffer Oben Ist","description":"Puffer Temperatur Oben Ist","unit":"°C","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value.temperature","room":"","poll":true,"wp":"","cw":"","isScale":"","address":211,"deviceId":1,"id":"holdingRegisters.211_Puffer_Oben_Ist"}]
    2025-12-02 22:30:31.026 - debug: modbus.0 (302084) Add holdingRegisters.211_Puffer_Oben_Ist: {"_id":"holdingRegisters.211_Puffer_Oben_Ist","type":"state","common":{"name":"Puffer Temperatur Oben Ist","role":"value.temperature","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":211,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
    2025-12-02 22:30:31.142 - info: modbus.0 (302084) Connected to slave 192.168.178.143
    2025-12-02 22:30:31.143 - debug: modbus.0 (302084) [DevID_1] Poll start ---------------------
    2025-12-02 22:30:31.144 - debug: modbus.0 (302084) Initialization of scale factors done!
    2025-12-02 22:30:31.144 - debug: modbus.0 (302084) [DevID_1/inputRegs] Poll address 211 - 1 registers
    2025-12-02 22:30:31.207 - warn: modbus.0 (302084) [DevID_1] Poll error count: 1 code: "ReadInputRegisters: Invalid FC 0"
    2025-12-02 22:30:32.257 - debug: modbus.0 (302084) [DevID_1] Poll start ---------------------
    2025-12-02 22:30:32.257 - debug: modbus.0 (302084) [DevID_1/inputRegs] Poll address 211 - 1 registers
    2025-12-02 22:30:34.176 - warn: modbus.0 (302084) [DevID_1] Poll error count: 2 code: "ReadInputRegisters: Invalid FC 100"
    2025-12-02 22:30:35.227 - debug: modbus.0 (302084) [DevID_1] Poll start ---------------------
    2025-12-02 22:30:35.228 - debug: modbus.0 (302084) [DevID_1/inputRegs] Poll address 211 - 1 registers
    2025-12-02 22:30:36.026 - warn: modbus.0 (302084) [DevID_1] Poll error count: 3 code: "ReadInputRegisters: Invalid FC 91"
    2025-12-02 22:30:37.077 - debug: modbus.0 (302084) [DevID_1] Poll start ---------------------
    2025-12-02 22:30:37.078 - debug: modbus.0 (302084) [DevID_1/inputRegs] Poll address 211 - 1 registers
    2025-12-02 22:30:37.226 - warn: modbus.0 (302084) [DevID_1] Poll error count: 4 code: "ReadInputRegisters: Invalid FC 100"
    2025-12-02 22:30:38.277 - debug: modbus.0 (302084) [DevID_1] Poll start ---------------------
    2025-12-02 22:30:38.278 - debug: modbus.0 (302084) [DevID_1/inputRegs] Poll address 211 - 1 registers
    2025-12-02 22:30:38.426 - warn: modbus.0 (302084) [DevID_1] Poll error count: 5 code: "ReadInputRegisters: Invalid FC 100"
    2025-12-02 22:30:39.020 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 302099
    2025-12-02 22:30:39.219 - warn: shelly.0 (138837) [Mqtt.statusNotifications] 192.168.178.150 (shelly1minig3 / shelly1minig3-cc8da245f348 / shelly1minig3#cc8da245f348#1): "General Status Notifications" are disabled (see adapter documentation for details)
    2025-12-02 22:30:39.477 - debug: modbus.0 (302084) [DevID_1] Poll start ---------------------
    2025-12-02 22:30:39.477 - debug: modbus.0 (302084) [DevID_1/inputRegs] Poll address 211 - 1 registers
    2025-12-02 22:30:39.636 - warn: modbus.0 (302084) [DevID_1] Poll error count: 6 code: "ReadInputRegisters: Invalid FC 100"
    2025-12-02 22:30:39.687 - debug: modbus.0 (302084) Closing client on purpose.
    2025-12-02 22:30:39.687 - info: modbus.0 (302084) Disconnected from slave 192.168.178.143
    @Strike498 sagte in HDG Heizung über Waveshare Modbus Gateway:
    das sieht schon mal gut aus.
    Die Eth verbindung Adapter <-> Konverter steht.
    aber
    Die Abfrage der/des Registers klappt nicht
    Das kann natürlich auch an der Konfiguration der seriellen Seite liegen.
    Mach mal den Haken bei Aliases verwenden rein.
    (hab allerdings keine allzugroße Hoffnung)
    Strike498S 1 Antwort Letzte Antwort
      was bietet der Konverter in dem pulldown 'server' bei eth network sonst noch an?
      Strike498S Offline
      Strike498S Offline
      Strike498
      @Homoran sagte in HDG Heizung über Waveshare Modbus Gateway:
      Da gibt’s noch „Client“. Das habe ich jetzt ausgewählt, aber dann kann er laut Log nicht mal mehr connecten.
      2025-12-03 06:41:06.153 - info: modbus.0 (305479) starting. Version 6.3.2 in /opt/iobroker/node_modules/iobroker.modbus, node: v22.21.0, js-controller: 7.0.7
      2025-12-03 06:41:06.213 - debug: modbus.0 (305479) Initialize Objects for disInputs: []
      2025-12-03 06:41:06.214 - debug: modbus.0 (305479) Initialize Objects for coils: []
      2025-12-03 06:41:06.214 - debug: modbus.0 (305479) Initialize Objects for inputRegs: [{"_address":30212,"name":"Puffer Temperatur Oben","description":"Puffer Temperatur Oben Ist","unit":"°C","type":"uint16le","len":1,"factor":1,"offset":0,"formula":"","role":"value.temperature","room":"","cw":"","isScale":"","address":211,"deviceId":1,"id":"inputRegisters.30212_Puffer_Temperatur_Oben"}]
      2025-12-03 06:41:06.214 - debug: modbus.0 (305479) Add inputRegisters.30212_Puffer_Temperatur_Oben: {"_id":"inputRegisters.30212_Puffer_Temperatur_Oben","type":"state","common":{"name":"Puffer Temperatur Oben Ist","role":"value.temperature","type":"number","read":true,"write":false,"def":0,"unit":"°C"},"native":{"regType":"inputRegs","address":211,"deviceId":1,"type":"uint16le","len":1,"offset":0,"factor":1}}
      2025-12-03 06:41:06.214 - debug: modbus.0 (305479) Initialize Objects for holdingRegs: [{"_address":40212,"name":"Puffer Oben Ist","description":"Puffer Temperatur Oben Ist","unit":"°C","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value.temperature","room":"","poll":true,"wp":"","cw":"","isScale":"","address":211,"deviceId":1,"id":"holdingRegisters.40212_Puffer_Oben_Ist"}]
      2025-12-03 06:41:06.214 - debug: modbus.0 (305479) Add holdingRegisters.40212_Puffer_Oben_Ist: {"_id":"holdingRegisters.40212_Puffer_Oben_Ist","type":"state","common":{"name":"Puffer Temperatur Oben Ist","role":"value.temperature","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":211,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
      2025-12-03 06:41:06.262 - debug: modbus.0 (305479) Remove old object modbus.0.holdingRegisters.211_Puffer_Oben_Ist
      2025-12-03 06:41:06.262 - debug: modbus.0 (305479) Remove old object modbus.0.inputRegisters.211_Puffer_Temperatur_Oben
      2025-12-03 06:41:06.391 - error: modbus.0 (305479) Socket Error
      2025-12-03 06:41:06.392 - error: modbus.0 (305479) Client in error state.
      2025-12-03 06:41:06.392 - warn: modbus.0 (305479) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.143","port":502}
      2025-12-03 06:41:06.392 - debug: modbus.0 (305479) Socket closed with error
      2025-12-03 06:41:06.393 - debug: modbus.0 (305479) Cleaning up request fifo.
      2025-12-03 06:41:07.392 - debug: modbus.0 (305479) Closing client on purpose.
        aber
        Strike498S Offline
        Strike498S Offline
        Strike498
        Hat leider auch nichts gebracht.
        • Strike498S Offline
          Strike498S Offline
          Strike498
          @homoran Wenn dir nichts mehr einfällt werde ich wohl doch versuchen auf usb2rs485 zu gehen und irgendwie das Kabel zu ziehen.
            Sorry, mit den RTU2ETH kenne ich mich gar nicht aus.
              Strike498S Offline
              Strike498S Offline
              Strike498
              @Homoran schade, danke trotzdem
              • Ganner86G Offline
                Ganner86G Offline
                Ganner86
                Welche Steuerung hast du in der Heizung verbaut? Die Touch und Touch XL haben meines Wissens nach ein RJ45 zum einbinden ins Netzwerk. Darüber lassen sich auch viele Daten lesen. Da gibt es auch einen fertigen Adapter für den IOB.
                • Ganner86G Ganner86
                  Strike498S Offline
                  Strike498S Offline
                  Strike498
                  @Ganner86 Hey, danke für deine Antwort.
                  Welcher Adapter ist das denn? Am Netz hab ich die Heizung schon.
                  Grüße, Tim
                  Ganner86G 1 Antwort Letzte Antwort
                    Grüße, Tim
                    Ganner86G Offline
                    Ganner86G Offline
                    Ganner86
                    @Strike498
                    https://www.iobroker.net/#de/adapters/adapterref/iobroker.hdg-bavaria/README.md
                    Das ist der Adapter. Wird leider vom Entwickler nicht mehr weiter gepflegt. Hatte kurzfristig Mailkontakt mit ihm. Diesen Adapter verwende ich in einer angepassten Form da er in der Ursprungsversion nicht mit meiner Steuerung funktioniert hat. Sollte im iob in der Adapter Liste aber auch zu finden sein.
                      @Strike498
                      Strike498S Offline
                      Strike498S Offline
                      Strike498
                      @Ganner86
                      Habe ihn jetzt über Github installiert, da er bei mir in der Adapter Liste nicht zu finden war.
                      Was hast du denn noch geändert am Adapter? Ich bekomme schon einige Werte, nur bei manchen steht „unbekannt“ oder einfach nichts drin.
                        @Ganner86
                        Ganner86G Offline
                        Ganner86G Offline
                        Ganner86
                        @Strike498 Ich hatte mir den Adapter geforked und den request geändert da meine Steuerung nicht auf den request des original Adapter reagiert hat. Zusätzlich hab ich mir noch den Brauchwasserspeicher mit aufgenommen und ob eine Störung oder Warnung ansteht. Kenne deine Heizungsanlage nicht, eventuell stellt sie bei den unbekannten Werten keine Daten zur Verfügung. Bin leider selbst kein Entwickler und hab mir den Adapter etwas zurecht gebastelt das er für mich funktioniert.
                          Strike498S Offline
                          Strike498S Offline
                          Strike498
                          @Ganner86
                          Der Kessel ist ein HDG F20(E) Stückholzkessel.
                          Vom Adapter anpassen habe ich leider gar keine Ahnung.
                            @Ganner86
                            Ganner86G Offline
                            Ganner86G Offline
                            Ganner86
                            @Strike498
                            Hab leider auch sehr wenig Ahnung von der Adapter Entwicklung. Da du einen Stückholzkessel hast werden sich die ID's die in der Steuerung angefragt werden teilweise zu den Pelletkessel unterscheiden. Ich hatte mir die benötigten ID's über die webvisu von der Steuerung mit den Entwicklertools vom Chrome raus gelesen und dann händisch im Adapter rein gebastelt. Wollte vor einiger Zeit mal in die Entwicklung von Adapter einsteigen, finde aber nicht so wirklich einen roten Faden.
                            Theoretisch kannst du die Daten von der Steuerung auch mit einem blockly Script zyklisch abfragen und in eigene Datenpunkte im iob schreiben lassen. Die Abfrage die an die HDG geht ist ein post request, hatte mit da testweise mal ein blockly gebaut.
                              @Strike498
                              Strike498S Offline
                              Strike498S Offline
                              Strike498
                              @Ganner86 Habe mir jetzt auch mal eine ID rausgesucht, mit der ich es probieren will. Habe nur leider absolut keinen Ansatz wie ich da Daten erhalten kann über blockly.
                              fuzzy1955F 1 Antwort Letzte Antwort
                                fuzzy1955F Offline
                                fuzzy1955F Offline
                                fuzzy1955
                                schrieb am zuletzt editiert von fuzzy1955
                                @Ganner86
                                Hallo ihr beide!
                                Mit Modbus hab ich schon viel experimentiert und auch hingekriegt. Habt ihr den IOB-Modbus-Adapter schon probiert? Der Konverter müsste etwa so konfiguriert werden:
                                Und der IOB-Modbus-Adapter - wahrscheinlich Holding-Register:
                                EDIT: Wenn dann Datenpunkte im IOB angezeigt werden, könnt ihr mit Blockly oder JS gut weiterarbeiten.
                                Vielleicht hilft euch das.
                                Gruß, Fuzzy1955
                                Smart-Home-Automation unter IOB auf RASPI5, 16GB RAM, 50GB SSD, MariaSQL, VIS-2.
                                Anfang 2025 war ich Newbie in Sachen RaspBerry, Linux und IOB.
                                Jetzt läuft alles konstant gut und ich gebe gern meine Erfahrungen und mein Wissen an die Forums-User/Innen weiter.
                                Großes Danke an alle tatkräftigen Helfer im Forum!
                                • fuzzy1955F fuzzy1955
                                  @Ganner86
                                  Hallo ihr beide!
                                  Gruß, Fuzzy1955
                                  Ganner86G Offline
                                  Ganner86G Offline
                                  Ganner86
                                  schrieb am zuletzt editiert von Ganner86
                                  @fuzzy1955 Vielen Dank für die Antwort. Ich selbst nutze keinen Modbus für die Kommunikation mit der Heizungssteuerung sondern die API der Webvisu über den ioBroker Adapter den ich mir etwas angepasst habe damit die Kommunikation funktioniert. Der Ursprungsadapter verwendet im Request einen String was bei mir nicht funktioniert hat da meine Steuerung als Request ein JSON Objekt mit jeweils 2 Key-Value Pairs pro Datenpunkt/ID erwartet. Zusätzlich habe ich mir noch ein zwei ID´s eingebaut die nicht vorhanden waren. Funktioniert bisher auch tadellos. Da ich leider kein Entwickler bin und wenig bis gar keine Ahnung von der Adapterentwicklung habe kann ich hier wenig unterstützen.
                                  Da @strike498 einen anderen Kessel hat (Stückholz statt Pellet) werden bei ihm verschiedene Daten fehlen und andere keine Werte bringen da sie in der Steuerung nicht vorhanden sind.
                                  Wenn ich mir das ganze so anschaue gibt es 3 Varianten wie man da die Kuh vom Eis bekommt:
                                  1. Möglichkeit: Modbus weiter testen bis es funktioniert. Hierbei würde ich die Verkabelung überprüfen und nach den Abschlusswiderständen schauen und kontrollieren welchen der rs485 Anschlüsse für die übergeordnete Steuerung ist. An meiner Touch XL gibt es 3 Anschlüsse wovon einer für die Kommunikation mit dem Kesselschaltfeld ist, frag mich bitte nicht an welchen der 3 man sich da andocken kann, da kann vermutlich nur der Support oder try&error helfen. Weiterhin brauchen RS485 Verbindungen Abschlusswiderstände an den Enden, manche Steuerungen haben diese integriert und können per DIP Schalter zugeschaltet werden, so auch die Heizungssteuerung, andere brauchen einen externen Abschlusswiederstand. Ich hatte ein ähnliches Problem vor einiger Zeit bei der Verbindung eines WAGO Controllers mit einer Steuerung eines Almig Schraubenkompressor. Da lag es letztendlich an einem fehlenden Abschlusswiederstand am WAGO Controller. Was man hier ggf. machen könnte wäre sich einen simplen rs485-USB converter zu besorgen und mit einem Laptop und einem Modbus Tester zu probieren bis man die richtigen Paramerter eingestellt hat und die Kommunikation steht, dann kann man sie auf den MODBUS-ETH Adapter übertragen und schauen das die Verbindung zum ioBroker klappt.
                                    Edith: Die korrekten Pins sind wohl X4:1-3 habe ich gerade im Symcon Forum gelesen.
                                  2. Möglichkeit: ioBroker Adapter Anpassen
                                  3. Möglichkeit: Blockly script/Javascript bauen und zyklisch in einem definierten Intervall die Daten von der Webvisu abfragen und in selbst erstellte Datenpunkte im iob schreiben zu lassen. Ich habe mir damals das Programm "Postman" auf meinem PC installiert und über die Entwicklertools vom Chrome den Netzwerktraffic angeschaut und mir dann in Postman einen Request nachgebaut. Diesen dann in ein Blockly/Java Script im iob übertragen.
                                  HomoranH Strike498S 2 Antworten Letzte Antwort
                                    @Ganner86 sagte in HDG Heizung über Waveshare Modbus Gateway:
                                    korrekt!
                                    ich kenne mich leider nicht mit dem RTU2ETH Umsetzer aus. Vermute aber das Problem an dessen Konfiguration.
                                    Daher jetzt die Frage;
                                    liegt bei Verbindung des Touch via LAN dort bereits Modbus TCP an?
                                      korrekt!
                                      Ganner86G Offline
                                      Ganner86G Offline
                                      Ganner86
                                      @Homoran An meiner Touch XL Steuerung gibt es 1 LAN Schnittstelle fürs Netzwerk und Fernwartung durch den Hersteller (Webserver mit Visu) sowie 3 RS485 Schnittstellen. Was ich gerade in einem Symcon Forum gelesen habe ist es wohl die RS Schnittstelle an der Klemmleiste X4 Pins 1-3 (Bezeichnung RS485-2 Extern).
                                      Was ich im Beitrag von @strike498 gelesen habe ist das es Fehlermeldungen vom FC100 gibt, das ist die Funktion für einzelne Coils (Bits) zu lesen, das wird nicht gehen da man höchstwahrscheinlich nur komplette Register lesen kann. Jedenfalls habe ich in meiner Beschreibung der Modbus Adressen nur Register gefunden und keine Coils, da würde ich an seiner Stelle mal ansetzen.
                                        das have ich auch gedacht, @strike498 hat aber angeblich nur bei input resp. Holdingregister etwas eingetragen.
                                        kann der Rtu2eth Konverter da etwas verursachen?
                                          Ganner86G Offline
                                          Ganner86G Offline
                                          Ganner86
                                          @Homoran Puh da bin ich etwas überfragt, hab leider solch einen Konverter nicht da um mal zu schauen. Generell ist es so das man den richtigen Funktionscode nutzen muss um was raus zu bekommen. Wenn ich nicht ganz auf dem Holzweg bin waren die Inputregister read only und Holding register r/w. Demnach müsste in der Konfig des adapters m.M.n die Funktion für read Input Register genutzt werden und dann die korrekte Adresse ggf mit offset.
