  4. KNX 2.0.30 startet nicht
    6.5k
1 Beiträge 1 Kommentatoren 83 Aufrufe 1 Beobachtet
  • P Offline
    Phil 0
    Hallo Zusammen,
    ich versuche seit ein paar Tagen mein MDT VC-Easy.03 mit dem KNX Adapter zu verbinden.
    Leider startet der Adapter nicht mit folgenden Fehlern.
    2025-09-29 13:38:14.015 - info: host.TNAS "system.adapter.knx.0" enabled
    2025-09-29 13:38:14.085 - info: host.TNAS instance system.adapter.knx.0 in version "2.0.30" started with pid 102196
    2025-09-29 13:38:14.536 - info: knx.0 (102196) starting. Version 2.0.30 in /opt/iobroker/node_modules/iobroker.knx, node: v22.19.0, js-controller: 7.0.7
    2025-09-29 13:38:14.547 - warn: knx.0 (102196) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses !
    2025-09-29 13:38:14.548 - info: knx.0 (102196) Connecting to knx GW: 192.168.178.21:3671 with phy. Adr: 1.1.10
    2025-09-29 13:38:14.551 - info: knx.0 (102196) Debuglevel: 2 3
    2025-09-29 13:38:14.552 - info: knx.0 (102196) Event : UDP - listening
    2025-09-29 13:38:14.553 - info: knx.0 (102196) Connected - local UDP Server listening on 192.168.178.75:54205
    2025-09-29 13:38:14.554 - info: knx.0 (102196) Send : description Request : 06 10 02 03 00 0e 08 01 c0 a8 b2 4b d3 bd sent to 192.168.178.21:3671
    2025-09-29 13:38:14.556 - info: knx.0 (102196) Send : searchReqExt Request : 06 10 02 0b 00 14 08 01 c0 a8 b2 4b d3 bd 06 04 01 02 08 06 sent to 192.168.178.21:3671
    2025-09-29 13:38:14.556 - info: knx.0 (102196) STATE_SEARCH_EXT_REQUEST : no defined handling for transition from State: STATE_DESCRIPTION_RESPONSE(18) to STATE_SEARCH_EXT_REQUEST(19).
    2025-09-29 13:38:14.560 - error: knx.0 (102196) uncaught exception: _0x4c9871[_0x4e88fd(...)] is not a function
    2025-09-29 13:38:14.560 - error: knx.0 (102196) TypeError: _0x4c9871[_0x4e88fd(...)] is not a function
    at _0x337b2b (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:83825)
    at _0x22f01e (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:97218)
    at _0x541942 (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:100445)
    at _0x4c80a7 (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:78546)
    at Socket. (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:125187)
    at Socket.emit (node:events:519:28)
    at Socket.emit (node:domain:489:12)
    at UDP.onMessage (node:dgram:988:8)
    2025-09-29 13:38:14.561 - error: knx.0 (102196) _0x4c9871[_0x4e88fd(...)] is not a function
    2025-09-29 13:38:14.564 - info: knx.0 (102196) Connection persists.....closing now
    2025-09-29 13:38:14.565 - info: knx.0 (102196) ... not able to close connection, because already closed
    2025-09-29 13:38:14.565 - info: knx.0 (102196) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_SEARCH_EXT_REQUEST(19) to STATE_NOT_CONNECTED(0).
    2025-09-29 13:38:14.565 - info: knx.0 (102196) terminating
    2025-09-29 13:38:14.565 - warn: knx.0 (102196) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2025-09-29 13:38:14.565 - info: knx.0 (102196) ( END ) Sending DISCONNECT_REQUEST : 06 10 02 09 00 10 00 00 08 01 c0 a8 b2 4b 00 00 ChID : 0 SeqCntIN : 0 SeqCntOUT : 0 msgCode : [object Object]
    2025-09-29 13:38:14.565 - info: knx.0 (102196) STATE_DISCONNECT_REQUEST : Transition from State: STATE_NOT_CONNECTED(0) to STATE_DISCONNECT_REQUEST(15) not possible because of cancelled connection.
    2025-09-29 13:38:14.565 - info: knx.0 (102196) Connection persists.....closing now
    2025-09-29 13:38:14.566 - info: knx.0 (102196) ... not able to close connection, because already closed
    2025-09-29 13:38:14.566 - info: knx.0 (102196) STATE_NOT_CONNECTED : Stop connection : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2025-09-29 13:38:14.567 - info: knx.0 (102196) STATE_DISCONNECT_RESPONSE : from State: STATE_NOT_CONNECTED(0) to STATE_DISCONNECT_RESPONSE(16) ... connection closed
    2025-09-29 13:38:14.567 - info: knx.0 (102196) Received DISCONNECT_RESPONSE06 10 02 0a 00 08 00 21
    2025-09-29 13:38:14.567 - info: knx.0 (102196) Connection persists.....closing now
    2025-09-29 13:38:14.567 - info: knx.0 (102196) ... not able to close connection, because already closed
    2025-09-29 13:38:14.567 - info: knx.0 (102196) STATE_NOT_CONNECTED : Stop connection : STATE_DISCONNECT_RESPONSE(16) to STATE_NOT_CONNECTED(0).
    2025-09-29 13:38:14.759 - error: host.TNAS Caught by controller[0]: TypeError: _0x4c9871[_0x4e88fd(...)] is not a function
    2025-09-29 13:38:14.759 - error: host.TNAS Caught by controller[0]: at _0x337b2b (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:83825)
    2025-09-29 13:38:14.759 - error: host.TNAS Caught by controller[0]: at _0x22f01e (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:97218)
    2025-09-29 13:38:14.759 - error: host.TNAS Caught by controller[0]: at _0x541942 (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:100445)
    2025-09-29 13:38:14.759 - error: host.TNAS Caught by controller[0]: at _0x4c80a7 (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:78546)
    2025-09-29 13:38:14.759 - error: host.TNAS Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:125187)
    2025-09-29 13:38:14.759 - error: host.TNAS Caught by controller[0]: at Socket.emit (node:events:519:28)
    2025-09-29 13:38:14.759 - error: host.TNAS Caught by controller[0]: at Socket.emit (node:domain:489:12)
    2025-09-29 13:38:14.759 - error: host.TNAS Caught by controller[0]: at UDP.onMessage (node:dgram:988:8)
    2025-09-29 13:38:14.759 - error: host.TNAS instance system.adapter.knx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2025-09-29 13:38:14.759 - info: host.TNAS Restart adapter system.adapter.knx.0 because enabled
    2025-09-29 13:38:20.009 - info: host.TNAS "system.adapter.knx.0" disabled
    2025-09-29 13:38:45.267 - error: knx.0 (102235) adapter disabled
    2025-09-29 13:38:45.350 - warn: knx.0 (102235) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
    2025-09-29 13:38:45.859 - error: host.TNAS instance system.adapter.knx.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
    2025-09-29 13:38:45.859 - info: host.TNAS Do not restart adapter system.adapter.knx.0 because disabled or deleted
    2025-09-29 14:53:37.746 - info: admin.0 (196) ==> Connected system.user.admin from ::ffff:192.168.178.43
    2025-09-29 14:54:41.655 - info: admin.0 (196) <== Disconnect system.user.admin from ::ffff:192.168.178.43 knx
