  4. Web Server Adapter web.0 funktioniert / läuft nicht mehr
    5.8k
5 Beiträge 3 Kommentatoren 3.3k Aufrufe
    Sinalco
    ich beschäftige mich seit ca. 2 Woche mit ioBroker
    Seit kurzem funktioniert mein web.0 Adapter nicht mehr, folgende Fehlermeldung kommt immer:
    host.raspberrypi	2018-02-04 20:05:03.197	error	instance system.adapter.web.0 terminated with code 0 (OK)
    host.raspberrypi	2018-02-04 20:05:03.196	error	Caught by controller[1]: port: 80 }
    host.raspberrypi	2018-02-04 20:05:03.196	error	Caught by controller[1]: address: '::',
    host.raspberrypi	2018-02-04 20:05:03.196	error	Caught by controller[1]: syscall: 'listen',
    host.raspberrypi	2018-02-04 20:05:03.196	error	Caught by controller[1]: errno: 'EADDRINUSE',
    host.raspberrypi	2018-02-04 20:05:03.196	error	Caught by controller[1]: code: 'EADDRINUSE',
    host.raspberrypi	2018-02-04 20:05:03.196	error	Caught by controller[1]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    host.raspberrypi	2018-02-04 20:05:03.195	error	Caught by controller[1]: at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    host.raspberrypi	2018-02-04 20:05:03.195	error	Caught by controller[1]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    host.raspberrypi	2018-02-04 20:05:03.195	error	Caught by controller[1]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    host.raspberrypi	2018-02-04 20:05:03.192	error	Caught by controller[1]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    host.raspberrypi	2018-02-04 20:05:03.192	error	Caught by controller[1]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    host.raspberrypi	2018-02-04 20:05:03.192	error	Caught by controller[1]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    host.raspberrypi	2018-02-04 20:05:03.192	error	Caught by controller[1]: at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:663:21)
    host.raspberrypi	2018-02-04 20:05:03.189	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.web/main.js:168:29
    host.raspberrypi	2018-02-04 20:05:03.188	error	Caught by controller[1]: at initWebServer (/opt/iobroker/node_modules/iobroker.web/main.js:698:28)
    host.raspberrypi	2018-02-04 20:05:03.188	error	Caught by controller[1]: at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:73:21)
    host.raspberrypi	2018-02-04 20:05:03.188	error	Caught by controller[1]: at Server.listen (net.js:1394:5)
    host.raspberrypi	2018-02-04 20:05:03.188	error	Caught by controller[1]: at listen (net.js:1298:10)
    host.raspberrypi	2018-02-04 20:05:03.188	error	Caught by controller[1]: at Server._listen2 (net.js:1262:14)
    host.raspberrypi	2018-02-04 20:05:03.188	error	Caught by controller[1]: at exports._exceptionWithHostPort (util.js:1043:20)
    host.raspberrypi	2018-02-04 20:05:03.187	error	Caught by controller[1]: at Object.exports._errnoException (util.js:1020:11)
    host.raspberrypi	2018-02-04 20:05:03.187	error	Caught by controller[1]: { Error: listen EADDRINUSE :::80
    host.raspberrypi	2018-02-04 20:05:03.186	error	Caught by controller[0]: le.challenges[tls-sni-01].loopback should be defined as function (opts, domain, token, cb) { ... } and should prove (by external means) that the ACME server challenge 'tls-sni
    Ich habe den Raspberry Pi schon öfters komplett neu aufgesetzt, nach der Installation läuft alles perfekt, bis ich den Raspberray pi neustarte, dann startet web.0 nicht mehr. Auch ändere Version hab ich schon ausprobiert und den Adapter neu installiert.
    Alles andere Funktioniert perfekt auch die Admin Oberfläche
    Anmerkung: Ich verwende das aktuellste Rasbian Light Image und habe nur piVCCU nach dieser Installationsanleitung installiert:
    https://github.com/alexreinert/piVCCU/b … berrypi.md
    Das läuft auch perfekt und auch die HomeMatic Weboberläche.
    Vieleicht kann mir einer sage was die Errors in der Log bedeuten, das sagt mir nichts.
    • apollon77A Offline
      EADDRINUSE sagt das der Port von einem anderen Programm belegt ist. In Deinem Fall wohl Port 80 (ist nicht iobroker Standard).
      Also: Was ist denn auf den Rechner noch installiert was auf Port 80 läuft?
      • HomoranH Offline
        HomoranH Offline
        …und wieso hast du den Port 80 bei web.0 konfiguriert?
          Sinalco
          Auf dem Rechner (Rasperry Pi 3 mit Rasbian) ist nur piVCCU installiert. Kann es sein, dass dieses Probleme macht?
          web.0 hab ich nicht mit Port 80 konfiguriert.
          Ich habe Port 443 für SSL verwendet und Port 80 für die Let's Encrypt Domain Prüfung aber auch mit 8082 kommt die Fehlermeldung mit Port 80.
            Sinalco
            Also ich habe den Port für web.0 auf 8082 gestellt und den Hacken bei Let's Encrypt -> "Benutze diese Instanz für automatische Updates:" raus genommen, dann funktioniert der web.0 Adapter wieder.
            Habe auch ausprobiert bei admin.0 Let's Encrypt -> "Benutze diese Instanz für automatische Updates:" den hacken raus und dafür bei web.0 rein dann funktioniert es auch.
            Kann es sein, dass man nicht beides mal also bei admin.0 und bei web.0 den Port 80 für die automatischen Let's Encrypt Updates rein machen darf?
            Mit Port 443 funktioniert dann web.0 auch. Aber kann ich nicht auch Port 8082 für SSL bei web.0 verwenden?
