  4. Eigenes Widget erstellen und mit Daten füllen
    5.8k
25 Beiträge 5 Kommentatoren 2.0k Aufrufe 4 Beobachtet
  • OliverIOO OliverIO
    @mattes-0
    Hier das widget zum importieren.
    es verwendet wie oben schon gesagt den vis-jsontemplate adapter
    im svg sind die folgenden datenpunkte eingebaut
    0_userdata.0.val1
    0_userdata.0.val2
    falls was nicht klappt einfach nochmal fragen.
    vis1
    [{"tpl":"tplJSONTemplate4","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","json_dpCount":"2","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"json_template":"<% debugger; %> \n<?xml version=\"1.0\" encoding=\"UTF-8\" standalone=\"no\"?>\n<svg version=\"1.2\" width=\"297mm\" height=\"210mm\" viewBox=\"0 0 29700 21000\" preserveAspectRatio=\"xMidYMid\" fill-rule=\"evenodd\" stroke-width=\"28.222\" stroke-linejoin=\"round\" xml:space=\"preserve\" id=\"svg14\"\n\txmlns=\"http://www.w3.org/2000/svg\"\n\txmlns:svg=\"http://www.w3.org/2000/svg\">\n\t<defs id=\"defs14\"/>&#10;\n\t<g visibility=\"visible\" id=\"MasterSlide_1_Default\">&#10;\n\t\t<desc id=\"desc1\">Master slide&#10;</desc>&#10;\n\t\t<rect fill=\"none\" stroke=\"none\" x=\"0\" y=\"0\" width=\"29700\" height=\"21000\" id=\"rect1\"/>&#10;\n\t</g>&#10;&#10;\n\t<g visibility=\"visible\" id=\"Slide_1_page1\">&#10;\n\t\t<g id=\"Speicher\">&#10;\n\t\t\t<path fill=\"rgb(255,255,255)\" stroke=\"none\" d=\"M 22750,10500 C 22375,10500 22000,10875 22000,11250 L 22000,17250 C 22000,17625 22375,18001 22750,18001 L 25750,18001 C 26125,18001 26501,17625 26501,17250 L 26501,11250 C 26501,10875 26125,10500 25750,10500 L 22750,10500 Z\" id=\"path1\"/>&#10;\n\t\t\t<path fill=\"none\" stroke=\"rgb(0,0,0)\" id=\"Drawing_1_0\" stroke-linejoin=\"round\" d=\"M 22750,10500 C 22375,10500 22000,10875 22000,11250 L 22000,17250 C 22000,17625 22375,18001 22750,18001 L 25750,18001 C 26125,18001 26501,17625 26501,17250 L 26501,11250 C 26501,10875 26125,10500 25750,10500 L 22750,10500 Z\"/>&#10;\n\t\t\t<rect fill=\"none\" stroke=\"none\" x=\"22000\" y=\"10500\" width=\"4501\" height=\"7501\" id=\"rect2\"/>&#10;&#10;\n\t\t</g>&#10;&#10;\n\t\t<g id=\"Puffer\">&#10;\n\t\t\t<path fill=\"rgb(255,255,255)\" stroke=\"none\" d=\"M 9250,10500 C 8875,10500 8500,10875 8500,11250 L 8500,17250 C 8500,17625 8875,18001 9250,18001 L 12250,18001 C 12625,18001 13001,17625 13001,17250 L 13001,11250 C 13001,10875 12625,10500 12250,10500 L 9250,10500 Z\" id=\"path2\"/>&#10;\n\t\t\t<path fill=\"none\" stroke=\"rgb(0,0,0)\" id=\"Drawing_2_0\" stroke-linejoin=\"round\" d=\"M 9250,10500 C 8875,10500 8500,10875 8500,11250 L 8500,17250 C 8500,17625 8875,18001 9250,18001 L 12250,18001 C 12625,18001 13001,17625 13001,17250 L 13001,11250 C 13001,10875 12625,10500 12250,10500 L 9250,10500 Z\"/>&#10;\n\t\t\t<rect fill=\"none\" stroke=\"none\" x=\"8500\" y=\"10500\" width=\"4501\" height=\"7501\" id=\"rect3\"/>&#10;\n\t\t</g>&#10;&#10;\n\t\t<g id=\"Solar\">&#10;\n\t\t\t<path fill=\"rgb(255,255,255)\" stroke=\"none\" d=\"M 3625,3500 L 7001,3500 5875,6501 2500,6501 3625,3500 Z\" id=\"path3\"/>&#10;\n\t\t\t<path fill=\"none\" stroke=\"rgb(0,0,0)\" id=\"Drawing_3_0\" stroke-linejoin=\"round\" d=\"M 3625,3500 L 7001,3500 5875,6501 2500,6501 3625,3500 Z\"/>&#10;\n\t\t\t<rect fill=\"none\" stroke=\"none\" x=\"2500\" y=\"3500\" width=\"4501\" height=\"3001\" id=\"rect4\"/>&#10;\n\t\t</g>&#10;&#10;\n\t\t<g id=\"WP_PU\">&#10;\n\t\t\t<path fill=\"rgb(255,255,255)\" stroke=\"none\" d=\"M 6000,19500 L 4000,19500 4000,17500 8000,17500 8000,19500 6000,19500 Z\" id=\"path4\"/>&#10;\n\t\t\t<path fill=\"none\" stroke=\"rgb(0,0,0)\" stroke-linejoin=\"round\" d=\"M 6000,19500 L 4000,19500 4000,17500 8000,17500 8000,19500 6000,19500 Z\" id=\"path5\"/>&#10;\n\t\t</g>&#10;\n\t\t<g id=\"Heizen\">&#10;\n\t\t\t<path fill=\"rgb(255,255,255)\" stroke=\"none\" d=\"M 18000,4000 L 15500,4000 15500,1500 20500,1500 20500,4000 18000,4000 Z\" id=\"path6\"/>&#10;\n\t\t\t<path fill=\"none\" stroke=\"rgb(0,0,0)\" stroke-linejoin=\"round\" d=\"M 18000,4000 L 15500,4000 15500,1500 20500,1500 20500,4000 18000,4000 Z\" id=\"path7\"/>&#10;\n\t\t\t<text xml:space=\"preserve\" style=\"font-size:493.889px;fill:#000000;stroke-width:746.707\" x=\"16243.243\" y=\"2189.1892\" id=\"text14\">\n\t\t\t\t<tspan id=\"tspan14\" style=\"font-size:493.889px;stroke-width:746.707\" x=\"16243.243\" y=\"2189.1892\">test1: <%- dp[\"0_userdata.0.val1\"] %></tspan>\n\t\t\t</text>\n\t\t\t<text xml:space=\"preserve\" style=\"font-size:493.89px;fill:#000000;stroke-width:746.707\" x=\"16222.973\" y=\"2918.9187\" id=\"text15\">\n\t\t\t\t<tspan id=\"tspan15\" style=\"stroke-width:746.707\" x=\"16222.973\" y=\"2918.9187\">test2: <%- dp[\"0_userdata.0.val2\"] %></tspan>\n\t\t\t</text>\t\t\t\n\t\t</g>&#10;&#10;&#10;\n\t\t<line id=\"von_Puffer_an_Heizen_VL\" x1=\"15000\" y1=\"2500\" x2=\"15500\" y2=\"2500\" stroke=\"#FF0000\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10;\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10;\n\t\t</line>&#10;\n\t\t<line id=\"line7\" x1=\"15000\" y1=\"2500\" x2=\"15000\" y2=\"11000\" stroke=\"#FF0000\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10;\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10;\n\t\t</line>&#10;\n\t\t<line id=\"line8\" x1=\"13000\" y1=\"11000\" x2=\"15000\" y2=\"11000\" stroke=\"#FF0000\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10;\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10;\n\t\t</line>&#10;&#10;&#10;&#10;&#10;&#10;\n\t\t<line id=\"von_Solar_an_Puffer_VL\" x1=\"13000\" y1=\"11500\" x2=\"18000\" y2=\"11500\" stroke=\"#FF5500\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10;\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10;\n\t\t</line>&#10;&#10;&#10;\n\t\t<line id=\"von_Puffer_an_Speicher_RL\" x1=\"13001\" y1=\"16200\" x2=\"22000\" y2=\"16200\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10;\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10;\n\t\t</line>&#10;&#10;&#10;&#10;\n\t\t<line id=\"Puffer_Speicher_VL\" x1=\"13001\" y1=\"11200\" x2=\"22000\" y2=\"11200\" stroke=\"#FF00F0\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10;\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10;\n\t\t</line>&#10;&#10;\n\t\t<line id=\"Puffer_Speicher_VL_1\" x1=\"18000\" y1=\"11500\" x2=\"22000\" y2=\"11500\" stroke=\"#FF5500\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10;\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10;\n\t\t</line>&#10;\n\t\t<line id=\"Puffer_Speicher_RL\" x1=\"13001\" y1=\"16000\" x2=\"17600\" y2=\"16000\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10;\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10;\n\t\t</line>&#10;\n\t\t<line id=\"Puffer_Speicher_RL_1\" x1=\"17600\" y1=\"16000\" x2=\"22000\" y2=\"16000\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10;\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10;\n\t\t</line>&#10;&#10;&#10;\n\t\t<line id=\"Speicher_Solar_VL_1\" x1=\"7001\" y1=\"3600\" x2=\"7001\" y2=\"7001\" stroke=\"#FF5500\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10;\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10;\n\t\t</line>&#10;\n\t\t<line id=\"Speicher_Solar_VL_2\" x1=\"7001\" y1=\"7001\" x2=\"18000\" y2=\"7001\" stroke=\"#FF5500\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10;\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10;\n\t\t</line>&#10;\n\t\t<line id=\"Speicher_Solar_VL_3\" x1=\"18000\" y1=\"7001\" x2=\"18000\" y2=\"11500\" stroke=\"#FF5500\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10;\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10;\n\t\t</line>&#10;\n\t\t<line id=\"Speicher_Solar_RL_1\" x1=\"6000\" y1=\"6000\" x2=\"6000\" y2=\"7600\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10;\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10;\n\t\t</line>&#10;\n\t\t<line id=\"line9\" x1=\"6000\" y1=\"7600\" x2=\"17600\" y2=\"7600\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10;\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10;\n\t\t</line>&#10;\n\t\t<line id=\"line10\" x1=\"17600\" y1=\"7600\" x2=\"17600\" y2=\"16000\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10;\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10;\n\t\t</line>&#10;&#10;\n\t\t<line id=\"Speicher_WWPU_VL_\" x1=\"8000\" y1=\"18600\" x2=\"17000\" y2=\"18600\" stroke=\"#FF0000\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10;\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10;\n\t\t</line>&#10;\n\t\t<line id=\"line11\" x1=\"17000\" y1=\"18600\" x2=\"17000\" y2=\"11600\" stroke=\"#FF0000\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10;\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10;\n\t\t</line>&#10;\n\t\t<line id=\"line12\" x1=\"17000\" y1=\"11600\" x2=\"22000\" y2=\"11600\" stroke=\"#FF0000\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10;\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10;\n\t\t</line>&#10;&#10;&#10;&#10;\n\t\t<line id=\"Speicher_WWPU_RL_\" x1=\"8000\" y1=\"19000\" x2=\"17500\" y2=\"19000\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10;\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10;\n\t\t</line>&#10;\n\t\t<line id=\"line13\" x1=\"17500\" y1=\"19000\" x2=\"17500\" y2=\"16500\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10;\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10;\n\t\t</line>&#10;\n\t\t<line id=\"line14\" x1=\"17500\" y1=\"16500\" x2=\"22000\" y2=\"16500\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10;\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10;\n\t\t</line>&#10;&#10;\n\t</g>&#10;\n</svg>\n","json_dp1":"0_userdata.0.val1","json_dp2":"0_userdata.0.val2"},"style":{"left":"19px","top":"25px","width":""},"widgetSet":"jsontemplate"}]
    vis2
       "tpl": "tplJSONTemplateWidget4vis2",
       "data": {
         "bindings": [],
         "oid": "nothing_selected",
         "dpcount": 2,
         "g_common": true,
         "template": "<% debugger; %>  <?xml version=\"1.0\" encoding=\"UTF-8\" standalone=\"no\"?> <svg version=\"1.2\" width=\"297mm\" height=\"210mm\" viewBox=\"0 0 29700 21000\" preserveAspectRatio=\"xMidYMid\" fill-rule=\"evenodd\" stroke-width=\"28.222\" stroke-linejoin=\"round\" xml:space=\"preserve\" id=\"svg14\" \txmlns=\"http://www.w3.org/2000/svg\" \txmlns:svg=\"http://www.w3.org/2000/svg\"> \t<defs id=\"defs14\"/>&#10; \t<g visibility=\"visible\" id=\"MasterSlide_1_Default\">&#10; \t\t<desc id=\"desc1\">Master slide&#10;</desc>&#10; \t\t<rect fill=\"none\" stroke=\"none\" x=\"0\" y=\"0\" width=\"29700\" height=\"21000\" id=\"rect1\"/>&#10; \t</g>&#10;&#10; \t<g visibility=\"visible\" id=\"Slide_1_page1\">&#10; \t\t<g id=\"Speicher\">&#10; \t\t\t<path fill=\"rgb(255,255,255)\" stroke=\"none\" d=\"M 22750,10500 C 22375,10500 22000,10875 22000,11250 L 22000,17250 C 22000,17625 22375,18001 22750,18001 L 25750,18001 C 26125,18001 26501,17625 26501,17250 L 26501,11250 C 26501,10875 26125,10500 25750,10500 L 22750,10500 Z\" id=\"path1\"/>&#10; \t\t\t<path fill=\"none\" stroke=\"rgb(0,0,0)\" id=\"Drawing_1_0\" stroke-linejoin=\"round\" d=\"M 22750,10500 C 22375,10500 22000,10875 22000,11250 L 22000,17250 C 22000,17625 22375,18001 22750,18001 L 25750,18001 C 26125,18001 26501,17625 26501,17250 L 26501,11250 C 26501,10875 26125,10500 25750,10500 L 22750,10500 Z\"/>&#10; \t\t\t<rect fill=\"none\" stroke=\"none\" x=\"22000\" y=\"10500\" width=\"4501\" height=\"7501\" id=\"rect2\"/>&#10;&#10; \t\t</g>&#10;&#10; \t\t<g id=\"Puffer\">&#10; \t\t\t<path fill=\"rgb(255,255,255)\" stroke=\"none\" d=\"M 9250,10500 C 8875,10500 8500,10875 8500,11250 L 8500,17250 C 8500,17625 8875,18001 9250,18001 L 12250,18001 C 12625,18001 13001,17625 13001,17250 L 13001,11250 C 13001,10875 12625,10500 12250,10500 L 9250,10500 Z\" id=\"path2\"/>&#10; \t\t\t<path fill=\"none\" stroke=\"rgb(0,0,0)\" id=\"Drawing_2_0\" stroke-linejoin=\"round\" d=\"M 9250,10500 C 8875,10500 8500,10875 8500,11250 L 8500,17250 C 8500,17625 8875,18001 9250,18001 L 12250,18001 C 12625,18001 13001,17625 13001,17250 L 13001,11250 C 13001,10875 12625,10500 12250,10500 L 9250,10500 Z\"/>&#10; \t\t\t<rect fill=\"none\" stroke=\"none\" x=\"8500\" y=\"10500\" width=\"4501\" height=\"7501\" id=\"rect3\"/>&#10; \t\t</g>&#10;&#10; \t\t<g id=\"Solar\">&#10; \t\t\t<path fill=\"rgb(255,255,255)\" stroke=\"none\" d=\"M 3625,3500 L 7001,3500 5875,6501 2500,6501 3625,3500 Z\" id=\"path3\"/>&#10; \t\t\t<path fill=\"none\" stroke=\"rgb(0,0,0)\" id=\"Drawing_3_0\" stroke-linejoin=\"round\" d=\"M 3625,3500 L 7001,3500 5875,6501 2500,6501 3625,3500 Z\"/>&#10; \t\t\t<rect fill=\"none\" stroke=\"none\" x=\"2500\" y=\"3500\" width=\"4501\" height=\"3001\" id=\"rect4\"/>&#10; \t\t</g>&#10;&#10; \t\t<g id=\"WP_PU\">&#10; \t\t\t<path fill=\"rgb(255,255,255)\" stroke=\"none\" d=\"M 6000,19500 L 4000,19500 4000,17500 8000,17500 8000,19500 6000,19500 Z\" id=\"path4\"/>&#10; \t\t\t<path fill=\"none\" stroke=\"rgb(0,0,0)\" stroke-linejoin=\"round\" d=\"M 6000,19500 L 4000,19500 4000,17500 8000,17500 8000,19500 6000,19500 Z\" id=\"path5\"/>&#10; \t\t</g>&#10; \t\t<g id=\"Heizen\">&#10; \t\t\t<path fill=\"rgb(255,255,255)\" stroke=\"none\" d=\"M 18000,4000 L 15500,4000 15500,1500 20500,1500 20500,4000 18000,4000 Z\" id=\"path6\"/>&#10; \t\t\t<path fill=\"none\" stroke=\"rgb(0,0,0)\" stroke-linejoin=\"round\" d=\"M 18000,4000 L 15500,4000 15500,1500 20500,1500 20500,4000 18000,4000 Z\" id=\"path7\"/>&#10; \t\t\t<text xml:space=\"preserve\" style=\"font-size:493.889px;fill:#000000;stroke-width:746.707\" x=\"16243.243\" y=\"2189.1892\" id=\"text14\"> \t\t\t\t<tspan id=\"tspan14\" style=\"font-size:493.889px;stroke-width:746.707\" x=\"16243.243\" y=\"2189.1892\">test1: <%- dp[\"0_userdata.0.val1\"] %></tspan> \t\t\t</text> \t\t\t<text xml:space=\"preserve\" style=\"font-size:493.89px;fill:#000000;stroke-width:746.707\" x=\"16222.973\" y=\"2918.9187\" id=\"text15\"> \t\t\t\t<tspan id=\"tspan15\" style=\"stroke-width:746.707\" x=\"16222.973\" y=\"2918.9187\">test2: <%- dp[\"0_userdata.0.val2\"] %></tspan> \t\t\t</text>\t\t\t \t\t</g>&#10;&#10;&#10; \t\t<line id=\"von_Puffer_an_Heizen_VL\" x1=\"15000\" y1=\"2500\" x2=\"15500\" y2=\"2500\" stroke=\"#FF0000\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t</line>&#10; \t\t<line id=\"line7\" x1=\"15000\" y1=\"2500\" x2=\"15000\" y2=\"11000\" stroke=\"#FF0000\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t</line>&#10; \t\t<line id=\"line8\" x1=\"13000\" y1=\"11000\" x2=\"15000\" y2=\"11000\" stroke=\"#FF0000\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t</line>&#10;&#10;&#10;&#10;&#10;&#10; \t\t<line id=\"von_Solar_an_Puffer_VL\" x1=\"13000\" y1=\"11500\" x2=\"18000\" y2=\"11500\" stroke=\"#FF5500\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t</line>&#10;&#10;&#10; \t\t<line id=\"von_Puffer_an_Speicher_RL\" x1=\"13001\" y1=\"16200\" x2=\"22000\" y2=\"16200\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t</line>&#10;&#10;&#10;&#10; \t\t<line id=\"Puffer_Speicher_VL\" x1=\"13001\" y1=\"11200\" x2=\"22000\" y2=\"11200\" stroke=\"#FF00F0\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t</line>&#10;&#10; \t\t<line id=\"Puffer_Speicher_VL_1\" x1=\"18000\" y1=\"11500\" x2=\"22000\" y2=\"11500\" stroke=\"#FF5500\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t</line>&#10; \t\t<line id=\"Puffer_Speicher_RL\" x1=\"13001\" y1=\"16000\" x2=\"17600\" y2=\"16000\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t</line>&#10; \t\t<line id=\"Puffer_Speicher_RL_1\" x1=\"17600\" y1=\"16000\" x2=\"22000\" y2=\"16000\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t</line>&#10;&#10;&#10; \t\t<line id=\"Speicher_Solar_VL_1\" x1=\"7001\" y1=\"3600\" x2=\"7001\" y2=\"7001\" stroke=\"#FF5500\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t</line>&#10; \t\t<line id=\"Speicher_Solar_VL_2\" x1=\"7001\" y1=\"7001\" x2=\"18000\" y2=\"7001\" stroke=\"#FF5500\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t</line>&#10; \t\t<line id=\"Speicher_Solar_VL_3\" x1=\"18000\" y1=\"7001\" x2=\"18000\" y2=\"11500\" stroke=\"#FF5500\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t</line>&#10; \t\t<line id=\"Speicher_Solar_RL_1\" x1=\"6000\" y1=\"6000\" x2=\"6000\" y2=\"7600\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t</line>&#10; \t\t<line id=\"line9\" x1=\"6000\" y1=\"7600\" x2=\"17600\" y2=\"7600\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t</line>&#10; \t\t<line id=\"line10\" x1=\"17600\" y1=\"7600\" x2=\"17600\" y2=\"16000\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t</line>&#10;&#10; \t\t<line id=\"Speicher_WWPU_VL_\" x1=\"8000\" y1=\"18600\" x2=\"17000\" y2=\"18600\" stroke=\"#FF0000\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t</line>&#10; \t\t<line id=\"line11\" x1=\"17000\" y1=\"18600\" x2=\"17000\" y2=\"11600\" stroke=\"#FF0000\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t</line>&#10; \t\t<line id=\"line12\" x1=\"17000\" y1=\"11600\" x2=\"22000\" y2=\"11600\" stroke=\"#FF0000\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t</line>&#10;&#10;&#10;&#10; \t\t<line id=\"Speicher_WWPU_RL_\" x1=\"8000\" y1=\"19000\" x2=\"17500\" y2=\"19000\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t</line>&#10; \t\t<line id=\"line13\" x1=\"17500\" y1=\"19000\" x2=\"17500\" y2=\"16500\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t</line>&#10; \t\t<line id=\"line14\" x1=\"17500\" y1=\"16500\" x2=\"22000\" y2=\"16500\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t</line>&#10;&#10; \t</g>&#10; </svg>",
         "g_datapoints-0": true,
         "g_datapoints-1": true,
         "g_datapoints-2": true,
         "datapoint-oid1": "0_userdata.0.val1",
         "datapoint-oid2": "0_userdata.0.val2"
       "style": {
         "bindings": [],
         "left": 49,
         "top": 28,
         "width": "518px",
         "height": "300px"
       "widgetSet": "jsontemplate",
       "_id": "i000001"
    habe gerade festgestellt, das jsontemplate von vis1 nach vis2 nicht übertragbar ist. daher noch mal eine 2. version des imports für vis2
    Mattes 0
    @oliverio vielen dank, werde ich heute Abend nach Feierabend ausprobieren - morgen dann zur Frühschicht... hoffe es klappt alles.
    Berichte aber so oder so
    • M Mattes 0
      @homoran ja, allerdings leider auch nicht das was ich gerne hätte.
      Was funktioniert ist die Hardware und die Steuerung via Scripte, bspw. bei Dämmerung automatisch das Außenlicht ein bzw ausschalten, Türklingel an Smartphone weiterleiten uvm.
      Jetzt versuche ich mich an der Visualisierung und stoße bei den bisherigen Widgets an Grenzen... Vis bzw vis2 sind irgendwie nix für mich, habpanel schon eher, allerdings wird es extrem unübersichtlich und sieht jedesmal auf verschiedenen Geräten anders aus (Auflösung).
      Speziell geht's bei mir momentan vor allem um Wärme.
      Quelle ist je nach Lage solarthermie, Wärmepumpe, heizstab oder Pufferspeicher.
      Bei Störungen ist so ein animiertes Hydraulikschema dann sehr praktisch...
      Ziel, je nach Situation entweder Warmwasserspeicher, Pufferspeicher oder heizkreis oder die noch zu bauende Lüftungsanlage...
      Situation ist abhängig von Raumtemperaturen, Außentemperaturen, Speicher bzw Puffer Temperaturen und Tageszeit oder sowas wie Legionnellen Schaltung (Desinfektion).
      Die Solarthermie ist momentan mit 10 Kollektoren Heizung und 3 Kollektoren für Warmwasser realisiert und als Altbestand (ehemalige Holzvergaserheizung) stehen noch 3x800l Pufferspeicher im Keller+ 800l die ich anschließen kann wenn Platz gemacht wurde.
      Sind noch immer im Umbau bzw energetischer Sanierung - Fassaden sind gedämmt, Dach muß noch... hauptsächlich Eigenleistung, da nichts vermietet ist - sind 9 Personen und alles Familie mit geringem Einkommen da Rentner (Generationen Haus).
      @mattes-0 sagte in Eigenes Widget erstellen und mit Daten füllen:
      wovon reden wir?
      Darstellung oder Steuerung.
      Auch zu EE gibt es einige Beispiele den Energiefluss von vergleichbaren Heizungssystemen zu visualisieren.
      • M Mattes 0
        Hallo, ich beschäftige mich schon seit ein paar Jahren mit dem Thema Automation und Steuerung(hatte vor IOBroker was eigenes gebaut).
        (War mal Softwareentwickler für Internet und Datenbanken, allerdings mehr VB, Python, PHP, CPP und Java, weniger JS).
        Ich möchte meine Heizungsanlage und alles drum herum in SVG darstellen und je nach Situation den Energie(Wärme)-fluss animiert darstellen.
        Das habe ich teilweise bereits erledigt, allerdings schaffe ich es nicht die Daten aus IOBroker in meiner SVG Datei darzustellen und die Dokumentationen die ich bisher gelesen habe, haben mir auch nicht geholfen. (selbst ChatGPT eiert herum)
        Die Datei im .../files/web Verzeichnis zu speichern und dann aufzurufen scheiter trotz korrekter pfade und Berechtigungen (wird vermutlich absichtlich unterbunden)
        Ich nutze momentan Habpanel - das dortige template widget verarbeitet aber kein javascript ....
        Ich bräuchte vermutlich nur einen Hinweis zum korrekten ablauf (vielleicht ein Beispiel) ... und keine Ahnung unter welcher Forumsrubrik ich das posten soll ...
        Mattes
        fuerchtischlumpf
        @mattes-0 ich habe mir mal ein komplettes Heizsystem mit Animation gebaut und die SVG-Daten mit objekt-binding ins Standard HTML-Widget gepackt - nutze es nur nicht mehr. 3ac85ffc-16de-440b-ac3a-975d71f7c462-image.png
        F 1 Antwort Letzte Antwort
        • F fuerchtischlumpf
          fuerchtischlumpf
          @fuerchtischlumpf hier noch ein Code-Schnipsel mit meinen animierten Heizkörper - Aus und laufend mit Heat-Ani und Binding an einen Modbus-Datenpunkt:
          <svg x="0px" y="0px"
          width="66px" height="90px" viewBox="0 0 66 90" xml:space="preserve">
          <path class="Hitzewellen" d="M11.519,13.313c0,0,2,0.779,2,4.114c0,5.381-4,4.978-4,9.916c0,3.692,2,4.961,2,4.961"/>
          <path class="Hitzewellen" d="M54.477,13.313c0,0,2,0.779,2,4.114c0,5.381-4,4.978-4,9.916c0,3.692,2,4.961,2,4.961"/>
          <path class="Hitzewellen" d="M20.11,13.313c0,0,2,0.779,2,4.114c0,5.381-4,4.978-4,9.916c0,3.692,2,4.961,2,4.961"/>
          <path class="Hitzewellen" d="M28.702,13.313c0,0,2,0.779,2,4.114c0,5.381-4,4.978-4,9.916c0,3.692,2,4.961,2,4.961"/>
          <path class="Hitzewellen" d="M37.293,13.313c0,0,2,0.779,2,4.114c0,5.381-4,4.978-4,9.916c0,3.692,2,4.961,2,4.961"/>
          <path class="Hitzewellen" d="M45.885,13.313c0,0,2,0.779,2,4.114c0,5.381-4,4.978-4,9.916c0,3.692,2,4.961,2,4.961"/>
          <path class="Heizkoerper" d="M10.667,80.762c0,1.686-1.585,3.052-3.54,3.052l0,0
          c-1.957,0-3.543-1.366-3.543-3.052v-40.63c0-1.686,1.586-3.052,3.543-3.052l0,0c1.955,0,3.54,1.366,3.54,3.052V80.762z"/>
          <path class="Heizkoerper" d="M20.679,80.762c0,1.686-1.585,3.052-3.54,3.052l0,0
          <path class="Heizkoerper" d="M60.728,80.762c0,1.686-1.585,3.052-3.54,3.052l0,0
          <path class="Heizkoerper" d="M63.902,47.922c0,0.877-0.711,1.587-1.587,1.587l0,0
          c-0.877,0-1.588-0.71-1.588-1.587V42.79c0-0.876,0.711-1.587,1.588-1.587l0,0c0.876,0,1.587,0.711,1.587,1.587V47.922z"/>
          <path class="Heizkoerper" d="M30.691,80.762c0,1.686-1.585,3.052-3.54,3.052l0,0
          <path class="Heizkoerper" d="M50.716,80.762c0,1.686-1.585,3.052-3.54,3.052l0,0
          <path class="Heizkoerper" d="M40.703,80.762c0,1.686-1.585,3.052-3.54,3.052l0,0
          </svg>
          <style>
          .Hitzewellen {
          fill: none;
          stroke:#F29400;
          stroke-width:{h:modbus.0.coils.12_Pumpe_Heizkreis; h == 'true' ? '3' : '0'};
          stroke-linecap:round;
          stroke-miterlimit:10;
          filter: drop-shadow(0px 0px 5px #F29400);
          animation: Hitzewelle 4s linear infinite;
          .Heizkoerper {
          fill: none;
          stroke:{h:modbus.0.coils.12_Pumpe_Heizkreis; h == 'true' ? '#F29400' : '#ffffff'};
          stroke-width: 2;
          @keyframes Hitzewelle {
          60% {
          opacity: 0.4;
          </style>
            wovon reden wir?
            Mattes 0
            @homoran der erst Eindruck ist dann wohl der richtige - hab anfangs bewusst auf Details verzichtet um hier nicht unnötig Verwirrung zu stiften und deine frage zeigt mir, das war eigentlich richtig.
            Es geht noch immer um die Darstellung, den ganzen Rest schaffe ich ohne Hilfe und EE gefällt mir nicht - das sieht mir bisschen zu sehr nach "Lizenz! und Spende" aus und damit habe ich schlechte Erfahrungen gemacht.
            Danke für deine mühe.
            • M Mattes 0
              Samson71S Offline
              Samson71S Offline
              Samson71
              Deine "Erfahrungen" in allen Ehren, aber bevor Du hier so einen Quark in die Welt setzt, empfehle ich ganz dringend Dich VORHER mit ioBroker und insbesondere mit einem bestimmten Adapter, dessen Entstehungsgeschichte und seinem Dev auseinanderzusetzen. So ein Geschwurbel gefällt hier nämlich auch nicht unbedingt.
              Markus
              Bitte beachten:
                @mattes-0
                0_userdata.0.val1
                0_userdata.0.val2
                vis1
                vis2
                   "data": {
                     "bindings": [],
                     "dpcount": 2,
                     "g_common": true,
                   "style": {
                     "bindings": [],
                     "left": 49,
                     "top": 28,
                     "width": "518px",
                     "height": "300px"
                   "_id": "i000001"
                Mattes 0
                @oliverio funktioniert nicht, Meldung kommt das er das template/widget nicht kennt(unbekannter Widget-Typ), aber ich wollte eigentlich das ganze komplett ohne Vis oder Vis2 umsetzen.
                Hab mich jetzt bisschen mit Vis2 beschäftigt und schaffe es die SVG Daten anzuzeigen und auch die diversen Datenpunkte über diese Grafik zu legen.
                Wie blende ich aber die Animationen ein bzw aus?
                Das ist mir bisher nicht gelungen.
                Hatte gedacht ich könnte "boolsches SVG" nutzen, dort je eine Line mit bzw ohne animation eintragen und das ganze mit einem Datenpunkt verbinden, den ich auf True oder False setzen kann .... nur wird mir keine Line angezeigt, egal ob true oder false ....
                und jetzt habe ich eine Lösung gefunden - ich setze statt bolsches svg ein weiteres Basic HTML Widget ein und blende dessen line ein bzw aus.
                • Samson71S Samson71
                  Mattes 0
                  @samson71 muss es auch nicht - Meinungsfreiheit, von daher alles bestens.
                  Ja meine "Erfahrungen" sind MEINE Erfahrungen und bezüglich des genannten Projekts MUSS das auch nicht stimmen und ich kann komplett falsch liegen.
                  Trotzdem schreibe ich sowas nicht grundlos oder leichtfertig und das jemand der Zeit in etwas investiert hat, freiwillige Spenden nimmt ist ebenfalls okay für mich.
                  Mir ist aber schon mehrfach passiert, das ich bei so Projekten mitgewirkt habe und dann plötzlich war es Kommerziell und ich sollte bezahlen - deshalb auch die vorherige Eigenentwicklung meines Projektes.
                  Vielleicht ist der genannte Adapter auch einer der Besten die IOBroker zu bieten hat ... weiß ich nicht, gefällt mir trotzdem nicht und das sollte denke ich auch reichen.
                  Ist nicht Persönlich gemeint und sollte man auch nicht so auffassen.
                  • M Mattes 0
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    so, du hast recht. ich habe noch ein problem im adapter gefunden, der dafür gesorgt hat. leider habe ich das nicht rechtzeitig entdeckt, da das nur dann auftritt, wenn man den adapter regulär installiert. in der dev umgebung ist jeweils edit und runtime alles gelaufen.
                    das problem ist hoffentlich in der version 4.1.0 des adapters behoben.
                    komplett ohne irgendeine visualisierung?
                    du meinst wahrscheinlich ohne das vis-template. wie gesagt. du kannst jederzeit über deine grafik die normalen widgets legen, die sich dann normal mit den daten aktualisieren. allerdings wird es dann bei deinem nächsten wunsch da schon wieder schwieriger
                    als du meinst die linien. meinst du den alle linien im einzelnen. oder alle linien gesamt? dann wahrscheinlich ersteres. dazu müsstest du jede einzelne linie in eine eigene grafik/svg packen. das dann alles übereinander stapeln(layern). über den abschnitt sichtbarkeit in der widgetkonfiguration (also bspw html) kannst du dann die sichtbarkeit über datenpunkte steuern und so ein layer/also einzelne linie ein oder ausblenden.
                    zeige das bitte als beispiel. das kommt darauf an wo/wie du das da eingetragen hast. theoretisch könnte man das per binding in die svg eintragen. da muss man aber immer genau schauen, was das jeweilige binding da konkret ausgibt, ansonste interpretiert der browser das falsch.
                    das hatte beschrieben. werden dann wahrscheinlich dann sehr viele widgets übereinander, was dann die bearbeitung etwas komplizierter macht. es gibt eine Lock-Funktion, die ein widget vor versehentlichem verschieben schützt.
                    mit dem json-template wäre das ebenfalls möglich. neben dem true/false setzen hättest du da auch die möglichkeit datenpunkt abhängig jeden einzelne linie zu rendern oder nicht.
                    denke daran, das svg nicht zu komplex zu machen, da bei jeder einzelnen änderung das html widget seinen inhalt komplett entfernt und neu einfügt. wenn der inhalt zu komplex ist kann das durch ein kleines flackern sichtbar werden. wenn dann dazu noch sehr häufige änderungen der daten vorkommen, dann sieht man das. hängt aber auch von der performance des anzeigegeräts ab.
                    hier habe ich mal so ein liniendemo gemacht. wieder als widget zum importieren
                    f2789709-1f52-428e-a130-82d96074d441-20250912-0054-42.6217983.mp4
                       "tpl": "tplJSONTemplate4",
                       "data": {
                         "bindings": [],
                         "dpcount": 3,
                         "g_common": true,
                         "template": "<% debugger; %>\r\n<?xml version=\"1.0\" encoding=\"UTF-8\" standalone=\"no\"?>\r\n<svg version=\"1.2\" width=\"297mm\" height=\"210mm\" viewBox=\"0 0 29700 21000\" preserveAspectRatio=\"xMidYMid\" fill-rule=\"evenodd\" stroke-width=\"28.222\" stroke-linejoin=\"round\" xml:space=\"preserve\" id=\"svg14\"\r\n\txmlns=\"http://www.w3.org/2000/svg\"\r\n\txmlns:svg=\"http://www.w3.org/2000/svg\">\r\n\t<defs id=\"defs14\"/>&#10; \t\r\n\t<g visibility=\"visible\" id=\"MasterSlide_1_Default\">&#10; \t\t\r\n\t\t<desc id=\"desc1\">Master slide&#10;</desc>&#10; \t\t\r\n\t\t<rect fill=\"none\" stroke=\"none\" x=\"0\" y=\"0\" width=\"29700\" height=\"21000\" id=\"rect1\"/>&#10; \t\r\n\t</g>&#10;&#10; \t\r\n\t<g visibility=\"visible\" id=\"Slide_1_page1\">&#10; \t\t\r\n\t\t<g id=\"Speicher\">&#10; \t\t\t\r\n\t\t\t<path fill=\"rgb(255,255,255)\" stroke=\"none\" d=\"M 22750,10500 C 22375,10500 22000,10875 22000,11250 L 22000,17250 C 22000,17625 22375,18001 22750,18001 L 25750,18001 C 26125,18001 26501,17625 26501,17250 L 26501,11250 C 26501,10875 26125,10500 25750,10500 L 22750,10500 Z\" id=\"path1\"/>&#10; \t\t\t\r\n\t\t\t<path fill=\"none\" stroke=\"rgb(0,0,0)\" id=\"Drawing_1_0\" stroke-linejoin=\"round\" d=\"M 22750,10500 C 22375,10500 22000,10875 22000,11250 L 22000,17250 C 22000,17625 22375,18001 22750,18001 L 25750,18001 C 26125,18001 26501,17625 26501,17250 L 26501,11250 C 26501,10875 26125,10500 25750,10500 L 22750,10500 Z\"/>&#10; \t\t\t\r\n\t\t\t<rect fill=\"none\" stroke=\"none\" x=\"22000\" y=\"10500\" width=\"4501\" height=\"7501\" id=\"rect2\"/>&#10;&#10; \t\t\r\n\t\t</g>&#10;&#10; \t\t\r\n\t\t<g id=\"Puffer\">&#10; \t\t\t\r\n\t\t\t<path fill=\"rgb(255,255,255)\" stroke=\"none\" d=\"M 9250,10500 C 8875,10500 8500,10875 8500,11250 L 8500,17250 C 8500,17625 8875,18001 9250,18001 L 12250,18001 C 12625,18001 13001,17625 13001,17250 L 13001,11250 C 13001,10875 12625,10500 12250,10500 L 9250,10500 Z\" id=\"path2\"/>&#10; \t\t\t\r\n\t\t\t<path fill=\"none\" stroke=\"rgb(0,0,0)\" id=\"Drawing_2_0\" stroke-linejoin=\"round\" d=\"M 9250,10500 C 8875,10500 8500,10875 8500,11250 L 8500,17250 C 8500,17625 8875,18001 9250,18001 L 12250,18001 C 12625,18001 13001,17625 13001,17250 L 13001,11250 C 13001,10875 12625,10500 12250,10500 L 9250,10500 Z\"/>&#10; \t\t\t\r\n\t\t\t<rect fill=\"none\" stroke=\"none\" x=\"8500\" y=\"10500\" width=\"4501\" height=\"7501\" id=\"rect3\"/>&#10; \t\t\r\n\t\t</g>&#10;&#10; \t\t\r\n\t\t<g id=\"Solar\">&#10; \t\t\t\r\n\t\t\t<path fill=\"rgb(255,255,255)\" stroke=\"none\" d=\"M 3625,3500 L 7001,3500 5875,6501 2500,6501 3625,3500 Z\" id=\"path3\"/>&#10; \t\t\t\r\n\t\t\t<path fill=\"none\" stroke=\"rgb(0,0,0)\" id=\"Drawing_3_0\" stroke-linejoin=\"round\" d=\"M 3625,3500 L 7001,3500 5875,6501 2500,6501 3625,3500 Z\"/>&#10; \t\t\t\r\n\t\t\t<rect fill=\"none\" stroke=\"none\" x=\"2500\" y=\"3500\" width=\"4501\" height=\"3001\" id=\"rect4\"/>&#10; \t\t\r\n\t\t</g>&#10;&#10; \t\t\r\n\t\t<g id=\"WP_PU\">&#10; \t\t\t\r\n\t\t\t<path fill=\"rgb(255,255,255)\" stroke=\"none\" d=\"M 6000,19500 L 4000,19500 4000,17500 8000,17500 8000,19500 6000,19500 Z\" id=\"path4\"/>&#10; \t\t\t\r\n\t\t\t<path fill=\"none\" stroke=\"rgb(0,0,0)\" stroke-linejoin=\"round\" d=\"M 6000,19500 L 4000,19500 4000,17500 8000,17500 8000,19500 6000,19500 Z\" id=\"path5\"/>&#10; \t\t\r\n\t\t</g>&#10; \t\t\r\n\t\t<g id=\"Heizen\">&#10; \t\t\t\r\n\t\t\t<path fill=\"rgb(255,255,255)\" stroke=\"none\" d=\"M 18000,4000 L 15500,4000 15500,1500 20500,1500 20500,4000 18000,4000 Z\" id=\"path6\"/>&#10; \t\t\t\r\n\t\t\t<path fill=\"none\" stroke=\"rgb(0,0,0)\" stroke-linejoin=\"round\" d=\"M 18000,4000 L 15500,4000 15500,1500 20500,1500 20500,4000 18000,4000 Z\" id=\"path7\"/>&#10; \t\t\t\r\n\t\t\t<text xml:space=\"preserve\" style=\"font-size:493.889px;fill:#000000;stroke-width:746.707\" x=\"16243.243\" y=\"2189.1892\" id=\"text14\">\r\n\t\t\t\t<tspan id=\"tspan14\" style=\"font-size:493.889px;stroke-width:746.707\" x=\"16243.243\" y=\"2189.1892\">test1: <%- dp[\"0_userdata.0.val1\"] %>\r\n\t\t\t\t</tspan>\r\n\t\t\t</text>\r\n\t\t\t<text xml:space=\"preserve\" style=\"font-size:493.89px;fill:#000000;stroke-width:746.707\" x=\"16222.973\" y=\"2918.9187\" id=\"text15\">\r\n\t\t\t\t<tspan id=\"tspan15\" style=\"stroke-width:746.707\" x=\"16222.973\" y=\"2918.9187\">test2: <%- dp[\"0_userdata.0.val2\"] %>\r\n\t\t\t\t</tspan>\r\n\t\t\t</text>\r\n\t\t</g>&#10;&#10;&#10;\r\n<% debugger; if (dp[\"0_userdata.0.val3\"]) { %>\t\t\r\n\t\t<line id=\"von_Puffer_an_Heizen_VL\" x1=\"15000\" y1=\"2500\" x2=\"15500\" y2=\"2500\" stroke=\"#FF0000\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t\r\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t\r\n\t\t</line>&#10; \r\n\t\r\n\t\t<line id=\"line7\" x1=\"15000\" y1=\"2500\" x2=\"15000\" y2=\"11000\" stroke=\"#FF0000\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t\r\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t\r\n\t\t</line>&#10; \r\n\t\t<line id=\"line8\" x1=\"13000\" y1=\"11000\" x2=\"15000\" y2=\"11000\" stroke=\"#FF0000\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t\r\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t\r\n\t\t</line>&#10;&#10;&#10;&#10;&#10;&#10; \t\t\r\n<% } %>\t\t\t\r\n\r\n\t\t<line id=\"von_Solar_an_Puffer_VL\" x1=\"13000\" y1=\"11500\" x2=\"18000\" y2=\"11500\" stroke=\"#FF5500\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t\r\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t\r\n\t\t</line>&#10;&#10;&#10; \t\t\r\n\t\t<line id=\"von_Puffer_an_Speicher_RL\" x1=\"13001\" y1=\"16200\" x2=\"22000\" y2=\"16200\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t\r\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t\r\n\t\t</line>&#10;&#10;&#10;&#10; \t\t\r\n\t\t<line id=\"Puffer_Speicher_VL\" x1=\"13001\" y1=\"11200\" x2=\"22000\" y2=\"11200\" stroke=\"#FF00F0\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t\r\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t\r\n\t\t</line>&#10;&#10; \t\t\r\n\t\t<line id=\"Puffer_Speicher_VL_1\" x1=\"18000\" y1=\"11500\" x2=\"22000\" y2=\"11500\" stroke=\"#FF5500\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t\r\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t\r\n\t\t</line>&#10; \t\t\r\n\t\t<line id=\"Puffer_Speicher_RL\" x1=\"13001\" y1=\"16000\" x2=\"17600\" y2=\"16000\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t\r\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t\r\n\t\t</line>&#10; \t\t\r\n\t\t<line id=\"Puffer_Speicher_RL_1\" x1=\"17600\" y1=\"16000\" x2=\"22000\" y2=\"16000\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t\r\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t\r\n\t\t</line>&#10;&#10;&#10; \t\t\r\n\t\t<line id=\"Speicher_Solar_VL_1\" x1=\"7001\" y1=\"3600\" x2=\"7001\" y2=\"7001\" stroke=\"#FF5500\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t\r\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t\r\n\t\t</line>&#10; \t\t\r\n\t\t<line id=\"Speicher_Solar_VL_2\" x1=\"7001\" y1=\"7001\" x2=\"18000\" y2=\"7001\" stroke=\"#FF5500\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t\r\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t\r\n\t\t</line>&#10; \t\t\r\n\t\t<line id=\"Speicher_Solar_VL_3\" x1=\"18000\" y1=\"7001\" x2=\"18000\" y2=\"11500\" stroke=\"#FF5500\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t\r\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t\r\n\t\t</line>&#10; \t\t\r\n\t\t<line id=\"Speicher_Solar_RL_1\" x1=\"6000\" y1=\"6000\" x2=\"6000\" y2=\"7600\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t\r\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t\r\n\t\t</line>&#10; \t\t\r\n\t\t<line id=\"line9\" x1=\"6000\" y1=\"7600\" x2=\"17600\" y2=\"7600\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t\r\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t\r\n\t\t</line>&#10; \t\t\r\n\t\t<line id=\"line10\" x1=\"17600\" y1=\"7600\" x2=\"17600\" y2=\"16000\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t\r\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t\r\n\t\t</line>&#10;&#10; \t\t\r\n\t\t<line id=\"Speicher_WWPU_VL_\" x1=\"8000\" y1=\"18600\" x2=\"17000\" y2=\"18600\" stroke=\"#FF0000\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t\r\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t\r\n\t\t</line>&#10; \t\t\r\n\t\t<line id=\"line11\" x1=\"17000\" y1=\"18600\" x2=\"17000\" y2=\"11600\" stroke=\"#FF0000\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t\r\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t\r\n\t\t</line>&#10; \t\t\r\n\t\t<line id=\"line12\" x1=\"17000\" y1=\"11600\" x2=\"22000\" y2=\"11600\" stroke=\"#FF0000\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t\r\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"-240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t\r\n\t\t</line>&#10;&#10;&#10;&#10; \t\t\r\n\t\t<line id=\"Speicher_WWPU_RL_\" x1=\"8000\" y1=\"19000\" x2=\"17500\" y2=\"19000\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t\r\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t\r\n\t\t</line>&#10; \t\t\r\n\t\t<line id=\"line13\" x1=\"17500\" y1=\"19000\" x2=\"17500\" y2=\"16500\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t\r\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t\r\n\t\t</line>&#10; \t\t\r\n\t\t<line id=\"line14\" x1=\"17500\" y1=\"16500\" x2=\"22000\" y2=\"16500\" stroke=\"#0000FF\" stroke-width=\"60\" stroke-linecap=\"round\" stroke-dasharray=\"120 120\" stroke-dashoffset=\"0\">&#10; \t\t\t\r\n\t\t\t<animate attributeName=\"stroke-dashoffset\" from=\"0\" to=\"240\" dur=\"1s\" repeatCount=\"indefinite\"/>&#10; \t\t\r\n\t\t</line>&#10;&#10; \t\r\n\t</g>&#10; \r\n</svg>",
                         "datapoint-oid2": "0_userdata.0.val2",
                         "g_datapoints-3": true,
                         "datapoint-oid3": "0_userdata.0.val3"
                       "style": {
                         "bindings": [],
                         "left": -220,
                         "top": -165,
                         "width": "1030px",
                         "height": "753px",
                         "transform": "scale(0.5)"
                       "widgetSet": "vis-jsontemplate",
                       "_id": "i000001"
                    Meine Adapter und Widgets
                    Links im Profil
                    • M Mattes 0
                      doch es ist leichtfertig!
                      Solche Posts fürhren regelmäßig zu Shitstormähnlichen Threads, dass hier bald alles gebührenpflichtig wird.
                      Das wird es nicht!
                      egal welche Erfahrungen du gemacht haben willst.
                      Das hier ist eine Community
                      Da gibt es eher die User, die ein ähnliches Verhalten wie du an den Tag legen, und sich hier beraten lassen, um anschließend das Ergebnis gewerblich zu nutzen.
                        Das wird es nicht!
                        Mattes 0
                        @homoran tut mir aufrichtig leid, denn das war nicht meine Absicht.
                        Wie bereits erwähnt, Erfahrungen in dieser Hinsicht sind scheinbar bei mehreren vorhanden, aber deshalb einen shitstorm veranstalten weil's hier vielleicht, vielleicht auch nicht so kommen könnte ist mega übertrieben und unfair euch gegenüber.
                             "data": {
                               "bindings": [],
                               "dpcount": 3,
                               "g_common": true,
                             "style": {
                               "bindings": [],
                               "left": -220,
                               "top": -165,
                               "width": "1030px",
                               "height": "753px",
                             "_id": "i000001"
                          Mattes 0
                          @oliverio ich bin mir noch nicht ganz sicher ob ich das jetzt wirklich mit so vielen Widgets machen möchte oder ob ich die Linien bspw mit CSS dynamisch ein und ausblenden möchte - oder Javascript... das mit dem übereinander legen funktioniert in habpanel nicht, deshalb Anfangs die Verwirrung.
                          Ist schon bisschen was her das ich mit dem Thema zu tun hatte - zuletzt mein Lebenslauf, auf allen Browsern und allen Displays exakt die selbe Seite darzustellen war damals sehr aufwendig.
                          Bei meiner letzten Steuerung habe ich die Daten mit einem Python Script von den arduinos gesammelt und mit einem anderen regelmäßig die HTML Seiten gebastelt... das ging relativ lange und sehr zuverlässig, aber kein Vergleich zu dem was jetzt geht.
                          Ich habe auch am 24. mündliche Prüfung, also eigentlich kaum Zeit für so Spielereien ... und schon habe ich die nächste Idee, was ich mit SVG (ohne iobroker) etc. noch anstellen kann... aber erst nach der Prüfung.
                          • M Mattes 0
                            OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            @mattes-0
                            ohne das widget kannst du im svg an das jeweilige liniensegment folgenden ausdruck hinzufügen
                            visibility="{val:0_userdata.0.val3;debugger;val?"visible":"hidden"}"
                            so dass ein komplettes liniensegment
                            wie folgt aussieht
                            <line visibility="{val:0_userdata.0.val3;debugger;val?"visible":"hidden"}" id="von_Puffer_an_Heizen_VL" x1="15000" y1="2500" x2="15500" y2="2500" stroke="#FF0000" stroke-width="60" stroke-linecap="round" stroke-dasharray="120 120" stroke-dashoffset="0">&#10;
                                <animate attributeName="stroke-dashoffset" from="0" to="-240" dur="1s" repeatCount="indefinite"/>&#10;
                            </line>
                            wenn du dann noch einen datenpunkt vom typ boolean hast, kannst du die visibility des elements darüber steuern. der ausdruck ist relativ einfach zu lesen.
                            {} innerhalb der Klammern erkennt vis den binding ausdruck
                            val:0_userdata.0.val3;debugger weise der variable val den inhalt des datenpunkts zu
                            val?"visible":"hidden" prüfe die variable val, wenn wahr gebe das hinter dem fragezeichen aus, wenn falsch, dann das hinter dem doppelpunkt.
                            so wird dynamisch die visibility des elements wahlweise auf visible oder hidden gestellt.
                            da eine linie bei dir aus mehreren segmenten bestellt, muss man zu jedem einzelnen liniensegment die gleiche prüfung hinzufügen.
                            ohne javascript geht, aber ohne boolsche logik wird es dann bei so einer steuerung schwierig.
                            Links im Profil
                              @mattes-0
                              wie folgt aussieht
                              </line>
                              Mattes 0
                              @oliverio said in Eigenes Widget erstellen und mit Daten füllen:
                              es funktioniert echt wunderbar - danke für deine hilfe!
                              @mattes-0
                              wie folgt aussieht
                              </line>
                              • M Mattes 0
                                @mattes-0
                                wie folgt aussieht
                                </line>
                                OliverIOO Offline
                                OliverIOO Offline
                                OliverIO
                                super aber mir ist da noch was reingerutscht.
                                bitte
                                visibility="{val:0_userdata.0.val3;val?"visible":"hidden"}"
                                ohne debugger verwenden
                                Links im Profil
