  4. Viele Gyp-Fehler bei Installation
    6.3k
9 Beiträge 5 Kommentatoren 6.3k Aufrufe
    mrMuppet
    ich bin gerade dabei meine iobroker Installation in eine neue Virtualisierung (iocage) umzuziehen und habe bei der Installation ziemlich viele gyp-Fehler
    ! npm install iobroker –unsafe-perm
    ! > iobroker@1.0.8 install /opt/iobroker/node_modules/iobroker
    ! > node lib/setup.js
    ! NPM version: 4.6.1
    ! npm install iobroker.discovery --production --save --prefix "/opt/iobroker"
    ! node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAd ... x64.tar.gz
    ! node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.12.2 (node-v48 ABI) (falling back to source compile with node-gyp)
    ! gyp ERR! configure error
    ! gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.
    ! gyp ERR! stack at Object.failNoPython (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:482:19)
    ! gyp ERR! stack at Object. <anonymous>(/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:396:16)
    ! gyp ERR! stack at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:68:16)
    ! gyp ERR! stack at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:80:29)
    ! gyp ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/which.js:89:16
    ! gyp ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:42:5
    ! gyp ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/mode.js:8:5
    ! gyp ERR! stack at FSReqWrap.oncomplete (fs.js:123:15)
    ! gyp ERR! System FreeBSD 11.1-STABLE
    ! gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/serialport/build/Release"
    ! gyp ERR! cwd /opt/iobroker/node_modules/serialport
    ! gyp ERR! node -v v6.12.2
    ! gyp ERR! node-gyp -v v3.6.0
    ! gyp ERR! not ok
    ! node-pre-gyp ERR! build error
    ! node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/serialport/build/Release' (1)
    ! node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    ! node-pre-gyp ERR! stack at emitTwo (events.js:106:13)
    ! node-pre-gyp ERR! stack at ChildProcess.emit (events.js:191:7)
    ! node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:920:16)
    ! node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
    ! node-pre-gyp ERR! System FreeBSD 11.1-STABLE
    ! node-pre-gyp ERR! command "/usr/local/bin/node" "/opt/iobroker/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    ! node-pre-gyp ERR! cwd /opt/iobroker/node_modules/serialport
    ! node-pre-gyp ERR! node -v v6.12.2
    ! node-pre-gyp ERR! node-pre-gyp -v v0.6.32
    ! node-pre-gyp ERR! not ok
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@4.0.7 (node_modules/serialport):
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@4.0.7 install: node-pre-gyp install --fallback-to-build
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    ! npm install iobroker.admin --production --save --prefix "/opt/iobroker"
    ! gyp ERR! not ok
    ! npm install iobroker.js-controller --production --save --prefix "/opt/iobroker"
    ! npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
    ! npm WARN prefer global npm@2.15.12 should be installed with -g
    ! gyp ERR! stack at Object.failNoPython (/opt/iobroker/node_modules/npm/node_modules/node-gyp/lib/configure.js:482:19)
    ! gyp ERR! stack at Object. <anonymous>(/opt/iobroker/node_modules/npm/node_modules/node-gyp/lib/configure.js:396:16)
    ! gyp ERR! stack at F (/opt/iobroker/node_modules/npm/node_modules/which/which.js:69:16)
    ! gyp ERR! stack at E (/opt/iobroker/node_modules/npm/node_modules/which/which.js:81:29)
    ! gyp ERR! stack at /opt/iobroker/node_modules/npm/node_modules/which/which.js:90:16
    ! gyp ERR! stack at /opt/iobroker/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
    ! gyp ERR! stack at /opt/iobroker/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    ! gyp ERR! command "/usr/local/bin/node" "/opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/serialport/build/Release"
    ! gyp ERR! not ok
    ! node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/serialport/build/Release' (1)
    ! gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    ! gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
    ! gyp ERR! not ok
    ! gyp ERR! cwd /opt/iobroker/node_modules/ursa
    ! gyp ERR! not ok
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: node-gyp rebuild
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa@0.9.4 (node_modules/ursa):
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa@0.9.4 install: node-gyp rebuild
    ! Write "service iobroker start" to start the ioBroker
    ! Cannot create file /usr/local/bin/iobroker!. Non critical
    ! You can manually copy file into /usr/local/bin/. Just write:
    ! cp /opt/iobroker/node_modules/iobroker/install/iobroker /usr/local/bin/
    ! /bin/sh: bash: not found
    ! Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
    ! iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
    ! /opt/iobroker
    ! -- iobroker@1.0.8 ! -- yargs@7.1.0
    ! +-- camelcase@3.0.0
    ! +-- cliui@3.2.0
    ! | +-- string-width@1.0.2 deduped
    ! | +-- strip-ansi@3.0.1
    ! | | -- ansi-regex@2.1.1 ! | -- wrap-ansi@2.1.0
    ! | -- strip-ansi@3.0.1 deduped ! +-- decamelize@1.2.0 ! +-- get-caller-file@1.0.2 ! +-- os-locale@1.4.0 ! | -- lcid@1.0.0
    ! | -- invert-kv@1.0.0 ! +-- read-pkg-up@1.0.1 ! | +-- find-up@1.1.2 ! | | +-- path-exists@2.1.0 ! | | | -- pinkie-promise@2.0.1 deduped
    ! | | -- pinkie-promise@2.0.1 ! | | -- pinkie@2.0.4
    ! | -- read-pkg@1.1.0 ! | +-- load-json-file@1.1.0 ! | | +-- graceful-fs@4.1.11 ! | | +-- parse-json@2.2.0 ! | | | -- error-ex@1.3.1
    ! | | | -- is-arrayish@0.2.1 ! | | +-- pify@2.3.0 ! | | +-- pinkie-promise@2.0.1 deduped ! | | -- strip-bom@2.0.0
    ! | | -- is-utf8@0.2.1 ! | +-- normalize-package-data@2.4.0 ! | | +-- hosted-git-info@2.5.0 ! | | +-- is-builtin-module@1.0.0 ! | | | -- builtin-modules@1.1.1
    ! | | +-- semver@5.5.0
    ! | | -- validate-npm-package-license@3.0.1 ! | | +-- spdx-correct@1.0.2 ! | | | -- spdx-license-ids@1.2.2
    ! | | -- spdx-expression-parse@1.0.4 ! | -- path-type@1.1.0
    ! | +-- graceful-fs@4.1.11 deduped
    ! | +-- pify@2.3.0 deduped
    ! | -- pinkie-promise@2.0.1 deduped ! +-- require-directory@2.1.1 ! +-- require-main-filename@1.0.1 ! +-- set-blocking@2.0.0 ! +-- string-width@1.0.2 ! | +-- code-point-at@1.1.0 ! | +-- is-fullwidth-code-point@1.0.0 ! | | -- number-is-nan@1.0.1
    ! | -- strip-ansi@3.0.1 deduped ! +-- which-module@1.0.0 ! +-- y18n@3.2.1 ! -- yargs-parser@5.0.0
    ! `-- camelcase@3.0.0 deduped
    ! npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
    ! npm WARN iobroker No description
    ! npm WARN iobroker No repository field.
    ! npm WARN iobroker No README data
    ! npm WARN iobroker No license field.</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
    Irgendwo hatte ich mal gelesen, die gyp-fehler seien nicht problematisch. Ist das wirklich so? Oder sollte ich mich um die Behebung kümmern?
    ioBroker auf NUC (Celeron mit Ubuntu-Server)
    Homematic, HMIP, Hue, Unifi, Plex, Nest, Roborock, Google Assistant
    • apollon77A Offline
      Grundsätzlich ist alles was du hier an Fehlern bekommst "OPTIONAL DEPENDECIES". Bedeutet: Bei einigen Adaptern gehen dann ggf spezielle Funktionen nicht.
      Bei Dir fehlt "python", was darauf hinweisst das das "build-essentials" Debian-Paket (oder die äquivalenz dazu) nicht installiert ist. Da einige Adapter Teile enthalten die Dinge kompilieren braucht es bestimmte Tools … die sollte man idealerweise haben, sonst kommt es schnell (je nach geplanten Adaptern) zu problemen und ganze Adapter können nicht installiert werden.
      Es lohnt sich die Fehler anzuschauen und die Ursachen zu beseitigen um es für die Zukunft einfacher zu haben.
        mrMuppet
        Ok. Ich habe jetzt mal git, python und bash installiert und da sind die Fehlermeldungen schon deutlich zurück gegangen (s.u.). Vielleicht mache ich nachher auch mal schnell ein Tutorial für andere FreeNAS nutzer.
        ! # npm install iobroker –unsafe-perm
        ! ../src/serialport.cpp:90:44: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        ! return getValueFromObject(options, key)->ToInt32()->Int32Value();
        ! /root/.node-gyp/6.12.2/include/node/v8.h:8214:21: note: 'ToInt32' has been explicitly marked deprecated here
        ! Local <int32>Value::ToInt32() const {
        ! ../src/serialport.cpp:102:44: warning: 'ToNumber' is deprecated [-Wdeprecated-declarations]
        ! return getValueFromObject(options, key)->ToNumber()->NumberValue();
        ! /root/.node-gyp/6.12.2/include/node/v8.h:8178:22: note: 'ToNumber' has been explicitly marked deprecated here
        ! Local <number>Value::ToNumber() const {
        ! ../src/serialport.cpp:174:23: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        ! int fd = argv[1]->ToInt32()->Int32Value();
        ! ../src/serialport.cpp:193:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        ! int fd = info[0]->ToInt32()->Int32Value();
        ! ../src/serialport.cpp:217:108: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        ! baton->baudRate = Nan::Get(options, Nan::Newv8::string("baudRate").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
        ! ../src/serialport.cpp:252:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        ! ../src/serialport.cpp:369:24: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        ! baton->fd = info[0]->ToInt32()->Int32Value();
        ! ../src/serialport.cpp:480:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        ! ../src/serialport.cpp:528:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        ! ../src/serialport.cpp:585:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        ! 10 warnings generated.
        ! ../src/serialport_unix.cpp:44:101: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        ! result->vmin = Nan::Get(options, Nan::Newv8::string("vmin").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
        ! ../src/serialport_unix.cpp:45:103: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        ! result->vtime = Nan::Get(options, Nan::Newv8::string("vtime").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
        ! 2 warnings generated.
        ! ../src/serialport_poller.cpp:86:23: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        ! obj->fd_ = info[0]->ToInt32()->Int32Value();
        ! 1 warning generated.
        ! npm install iobroker.admin –production --save --prefix "/opt/iobroker"
        ! ../src/unix_dgram.cc:53:13: warning: unused function 'SetNonBlock' [-Wunused-function]
        ! inline void SetNonBlock(int fd) {
        ! ../src/unix_dgram.cc:65:13: warning: unused function 'SetCloExec' [-Wunused-function]
        ! inline void SetCloExec(int fd) {
        ! /opt/iobroker
        ! +-- cliui@3.2.0
        ! npm WARN iobroker No license field.</int32></int32></v8::string></int32></v8::string></int32></int32></int32></int32></int32></int32></v8::string></int32></int32></number></int32>
          Anleitung wäre cool!!
          Die Serialport-Meldungen sind ggf mit der nächsten Version von Discovery weg.
          Die Unix-DGram wohl eher nicht :-(
            DeepCore
            Hier mal in Kurz-Form meine Schritt-für-Schritt Installation für Debian 9.3 in einer ESXi 6.5 Virtual-Machine vor rund einer Woche… ioBroker wurde dann ohne Gyp Meldungen installiert :D
            Alles als root ausgeführt …
            apt update
            apt upgrade
            apt install open-vm-tools
            apt install curl
            curl -sL https://deb.nodesource.com/setup_6.x | bash -
            apt install nodejs
            apt install build-essential
            apt install libavahi-compat-libdnssd-dev
            npm install -g node-gyp
            mkdir /opt/iobroker
            chmod 777 /opt/iobroker/
            cd /opt/iobroker/
            Dies hier````
              mrMuppet
              Mist. Hab was wichtiges vergessen: Mein iocage läuft auf FreeNAS, also einem FreeBSD-System. Ich werden noch mal durchgehen, welche Schritte ich übernehmen kann, aber ich vermute die Ähnlichkeiten zu Debian sind da nicht so groß!
                andyb
                Kann jemand einem Linux Noob erklären was hier alles fehlt. Kommt bei jeder Adapater Installation.
                $ ./iobroker add vis-justgage
                NPM version: 4.6.1
                npm install iobroker.vis-justgage --production --save --prefix "/opt/iobroker" (System call)
                prebuild-install
                WARN install No prebuilt binaries found (target=8.12.0 runtime=node arch=arm platform=linux)
                Traceback (most recent call last): File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 13, in <module>
                ! import gyp File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/init.py", line 8, in <module>
                import gyp.input
                File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 5, in <module>
                from compiler.ast import Const
                ImportError: No module named compiler.ast
                ! gyp
                gyp ERR! stack Error: gyp failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:336:16)
                ! gyp ERR! stack at emitTwo (events.js:126:13)gyp ERR! stack at ChildProcess.emit (events.js:214:7)
                gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
                ! gyp ERR! System Linux 4.14.70-sunxigyp
                ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport
                ! gyp ERR! node -v v8.12.0gyp ERR! node-gyp -v v3.6.0
                gyp ERR! not ok
                ! Traceback (most recent call last): File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 13, in <module>
                import gyp.input
                ! gyp
                gyp ERR!
                gyp ERR!
                stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)gyp ERR! System Linux 4.14.70-sunxi
                ! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/winston-syslog/node_modules/unix-dgram
                v3.6.0gyp ERR! not ok
                ! npm
                WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/authenticate-pam/package.json'npm
                WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/prompt-base/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/prompt-checkbox/package.json'
                npm WARN enoent
                ENOENT: no such file or directory, open '/opt/iobroker/node_modules/prompt-choices/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/prompt-question/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/prompt-radio/package.json'
                npm WARN
                enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/serialport/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/terminal-paginator/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/unix-dgram/package.json'
                ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@6.2.2 (node_modules/iobroker.discovery/node_modules/serialport):
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@6.2.2 install: prebuild-install || node-gyp rebuildnpm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/winston-syslog/node_modules/unix-dgram):
                ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: node-gyp rebuildnpm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                ! host.orangepiplus2e install adapter vis-justgage
                got /opt/iobroker/node_modules/iobroker.vis-justgage/admin
                upload [1] vis-justgage.admin /opt/iobroker/node_modules/iobroker.vis-justgage/admin/justgage.png justgage.png image/png
                upload [0] vis-justgage.admin /opt/iobroker/node_modules/iobroker.vis-justgage/admin/index.html index.html text/html
                Adapter "system.adapter.vis.0" restarted.
                host.orangepiplus2e object system.adapter.vis-justgage created
                host.orangepiplus2e create instance vis-justgage
                host.orangepiplus2e object system.adapter.vis-justgage.0 created
                process exited with code 0</module></module></module></module></module></module>
                Komplett clean neu aufgesetzt.
                ARMBIAN 5.60 stable Ubuntu 18.04.1 LTS 4.14.70-sunxi
                root@orangepiplus2e:~# node -v
                v8.12.0
                root@orangepiplus2e:~# npm -v
                4.6.1
                  andyb
                  push :D
                  • StabilostickS Offline
                    Stabilostick
                     apt-get install python-dev
