  3. Off Topic
  4. PiHole DNS Queries
    6.0k
PiHole DNS Queries
10 Beiträge 2 Kommentatoren 917 Aufrufe 2 Beobachtet
  • MartinPM Online
    MartinPM Online
    MartinP
    Habe in den Pi-Hole Statistiken gefunden, dass es sehr viele DNS-Anfragen nach "community.home-assistant.io" gibt
    2025-03-10 19:00:33.839 query[AAAA] community.home-assistant.io from 172.18.0.1
    2025-03-10 19:00:33.839 cached-stale community.home-assistant.io is 2606:4700:20::ac43:445a
    2025-03-10 19:00:33.839 cached-stale community.home-assistant.io is 2606:4700:20::681a:4ee
    2025-03-10 19:00:33.839 cached-stale community.home-assistant.io is 2606:4700:20::681a:5ee
    2025-03-10 19:00:33.845 query[A] community.home-assistant.io from 172.18.0.1
    2025-03-10 19:00:33.845 cached-stale community.home-assistant.io is 172.67.68.90
    2025-03-10 19:00:33.845 cached-stale community.home-assistant.io is 104.26.5.238
    2025-03-10 19:00:33.845 cached-stale community.home-assistant.io is 104.26.4.238
    2025-03-10 19:00:33.852 query[AAAA] community.home-assistant.io from 172.18.0.1
    2025-03-10 19:00:33.852 cached-stale community.home-assistant.io is 2606:4700:20::681a:5ee
    2025-03-10 19:00:33.852 cached-stale community.home-assistant.io is 2606:4700:20::ac43:445a
    2025-03-10 19:00:33.852 cached-stale community.home-assistant.io is 2606:4700:20::681a:4ee
    2025-03-10 19:00:33.858 reply community.home-assistant.io is 2606:4700:20::681a:4ee
    2025-03-10 19:00:33.858 reply community.home-assistant.io is 2606:4700:20::681a:5ee
    2025-03-10 19:00:33.858 reply community.home-assistant.io is 2606:4700:20::ac43:445a
    2025-03-10 19:00:33.860 reply community.home-assistant.io is 104.26.5.238
    2025-03-10 19:00:33.860 reply community.home-assistant.io is 104.26.4.238
    2025-03-10 19:00:33.860 reply community.home-assistant.io is 172.67.68.90
    2025-03-10 19:00:33.945 query[A] community.home-assistant.io from 172.18.0.1
    2025-03-10 19:00:33.945 cached community.home-assistant.io is 104.26.5.238
    2025-03-10 19:00:33.945 cached community.home-assistant.io is 104.26.4.238
    2025-03-10 19:00:33.945 cached community.home-assistant.io is 172.67.68.90
    2025-03-10 19:00:33.950 query[AAAA] community.home-assistant.io from 172.18.0.1
    2025-03-10 19:00:33.950 cached community.home-assistant.io is 2606:4700:20::681a:4ee
    2025-03-10 19:00:33.950 cached community.home-assistant.io is 2606:4700:20::681a:5ee
    2025-03-10 19:00:33.950 cached community.home-assistant.io is 2606:4700:20::ac43:445a
    2025-03-10 19:00:33.956 query[A] community.home-assistant.io from 172.18.0.1
    2025-03-10 19:00:33.956 cached community.home-assistant.io is 172.67.68.90
    2025-03-10 19:00:33.956 cached community.home-assistant.io is 104.26.5.238
    2025-03-10 19:00:33.956 cached community.home-assistant.io is 104.26.4.238
    2025-03-10 19:00:33.962 query[AAAA] community.home-assistant.io from 172.18.0.1
    172.18.0.1 ist die Bridge IP-Adresse des LXC-Containers, in dem der pi-Hole in einem Docker Container läuft...
    Wie kann ich herausfinden, wer die DNS-Anfragen absetzt? Ich habe keine home-assistant Anwendungen hier im Haus, und der Rest der Familie ist auch nicht affin....
    • MartinPM MartinP
      OliverIOO Offline
      OliverIOO Offline
      OliverIO
      @martinp
      wenn du da drauf clickst, dann siehst du die einzelanfragen.
      da steht dann auch der client dabei, entweder als hostname oder als ip
      Meine Adapter und Widgets
      Links im Profil
      • OliverIOO OliverIO
        @martinp
        MartinPM Online
        MartinPM Online
        MartinP
        @oliverio Hmm Auf Seite 5 kommt die erste Anfrage eines identifizierbaren Clients...
        • MartinPM MartinP
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          @martinp
          sieht nach docker container oder ähnlich virtualisiertem aus (also die ip 172...).
          du kannst mal in der netzwerkaufstellung schauen, welchem container/VM das netzwerksegment zugeordnet ist
          welches subnet hast du definiert? theoretisch 192.168.2.0
          192.168.2.26, könnte natürlich auch dein normaler rechner sein, bei dem der browser probiert hat den namen aufzulösen weil du da hingesurft bist.
          Links im Profil
            @martinp
            MartinPM Online
            MartinPM Online
            MartinP
            @oliverio Hmm, wenn ich das richtig sehe, ist das das "Gegenstück" im Docker Environment zum PiHole Container
            In der entsprechenden LXC Console:
            martin@DockerKlon1:~/gitea/pihole$ ip addr
            4: br-a5fdc64aa07a: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default
                link/ether 02:42:49:1a:da:cd brd ff:ff:ff:ff:ff:ff
                inet 172.18.0.1/16 brd 172.18.255.255 scope global br-a5fdc64aa07a
                   valid_lft forever preferred_lft forever
                inet6 fe80::42:49ff:fe1a:dacd/64 scope link
            5: br-b5bf3119207c: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default
                link/ether 02:42:28:96:61:9f brd ff:ff:ff:ff:ff:ff
                inet 172.20.0.1/16 brd 172.20.255.255 scope global br-b5bf3119207c
                inet6 fe80::42:28ff:fe96:619f/64 scope link
            • MartinPM MartinP
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              @martinp sagte in PiHole DNS Queries:
              hm, also bei mir taucht pihole gar nicht im query log auf.
              bei mir läuft pihole als docker container mit macvlan und eigener ip
              pihole:/# ip addr
              1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN qlen 1000
                  link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                  inet 127.0.0.1/8 scope host lo
                  inet6 ::1/128 scope host
              847: eth0@if2: <BROADCAST,MULTICAST,UP,LOWER_UP,M-DOWN> mtu 1500 qdisc noqueue state UP
                  link/ether 02:42:c0:a8:01:5a brd ff:ff:ff:ff:ff:ff
                  inet 192.168.1.90/24 brd 192.168.1.255 scope global eth0
                  inet6 2003:f3:f70a:xxxx:42:c0ff:fea8:15a/64 scope global dynamic flags 100
                     valid_lft 604763sec preferred_lft 86363sec
                  inet6 2003:f3:f70a:xxxx:42:c0ff:fea8:15a/64 scope global deprecated dynamic flags 100
                     valid_lft 6044sec preferred_lft 0sec
                  inet6 fd40:8435:4452:1:42:c0ff:fea8:15a/64 scope global dynamic flags 100
                     valid_lft 1814363sec preferred_lft 604763sec
                  inet6 fd63:33eb:5ac2:0:42:c0ff:fea8:15a/64 scope global dynamic flags 100
                  inet6 fd77:e11e:3d73:0:42:c0ff:fea8:15a/64 scope global dynamic flags 100
                  inet6 fd40:8435:4452:1::2/64 scope global flags 02
                  inet6 fe80::42:c0ff:fea8:15a/64 scope link
              so sieht die docker compose config aus
              version: '3'
              services:
                pihole:
                  container_name: piholev6-1
                  hostname: pihole
                  image: pihole/pihole:latest
                  restart: unless-stopped
                  networks:
                    macvlanipv6:
                      ipv4_address: 192.168.1.90
                  dns:
                    - 127.0.0.1
                    - 1.1.1.1
                  cap_add:
                    - NET_ADMIN
                    - CAP_SYS_TIME
                  environment:
                    FTLCONF_webserver_api_password: 'xxxxxxxx'
                    TZ: 'Europe/Berlin'
                  volumes:
                    - /home/iobroker/docker/volume/piholev6.1/dnsmasq.d/:/etc/dnsmasq.d/
                    - /home/iobroker/docker/volume/piholev6.1/pihole/:/etc/pihole/
              networks:
                macvlanipv6:
                  external: true
              Links im Profil
                pihole:/# ip addr
                version: '3'
                services:
                  pihole:
                    hostname: pihole
                    networks:
                      macvlanipv6:
                    dns:
                      - 127.0.0.1
                      - 1.1.1.1
                    cap_add:
                      - NET_ADMIN
                      - CAP_SYS_TIME
                    environment:
                      TZ: 'Europe/Berlin'
                    volumes:
                networks:
                  macvlanipv6:
                    external: true
                MartinPM Online
                MartinPM Online
                MartinP
                @oliverio kann man wahlweise auf der gleichen Docker Plattform Macvlan oder die konventionelle Lösung starten?
                Wie sieht es mit dem LXC Container aus, in dem Docker läuft?
                • MartinPM MartinP
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  @martinp
                  Das weiß ich leider nicht.
                  Das hängt vom Netzwerktreiber von proxmox ab.
                  Ich habe das hier gefunden
                  https://medium.com/@mmwent/proxmox-docker-vlan-1cd87707bdb
                  Vorteil der eigenen IP für Pihole ist, dass er per Broadcast von den Clients gefunden wird kann.
                  Das funktioniert ja bei einem Container im Bridge Modus nicht
                  Links im Profil
                    @martinp
                    MartinPM Online
                    MartinPM Online
                    MartinP
                    @oliverio Eine andere Möglichkeit wäre ja auch, PiHole einfach in einen eigenen LXC zu packen...
                    Macvlan wäre aber sicherlich etwas, wo es sinnvoll ist, sich damit zu beschäftigen ...
                    Wobei die Google Suchergebnisse da manchmal schon recht abschreckend sind ...
                    "An seinem Juniper Switch muss man dazu konfigurieren" ;-)
                    • MartinPM MartinP
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      @martinp
                      Das würde mich wundern, dass man da Hardware konfigurieren muss.
                      Macvlan ist ja was was der linux kernel in sich schon mitbringt.
                      https://developers.redhat.com/blog/2018/10/22/introduction-to-linux-interfaces-for-virtual-networking#
                      Bei proxmox ist ja nix anderes wie eine spezialisierte linux Distribution.
                      Es hängt davon ab, wie man bei proxmox diese Funktionen dann nutzen kann.
                      Macvlan selbst ist eigentlich auch nur ein virtueller Switch (switches funktionieren auf netzebene 2, daher nur auf der Mac Ebene)
                      Linux kernel kümmert sich dann zu entscheiden welches der ankommenden Päckchen an den Host oder an einen bestimmten Container weitergeleitet werden muss
                      Links im Profil
