    6.3k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.4m Aufrufe 260 Beobachtet
  • K Kerschte_de
    @kerschte_de
    da ist was durcheinandergekommen, da ich die maximale Zeichenzahl übersteige. Ich versuche es nochmal ab Zeile 572
    javascript.0	18:20:28.125	info	Compiling TypeScript source script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT
    javascript.0	18:20:28.391	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: source code did not change, using cached compilation result...
    javascript.0	18:20:28.456	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
    javascript.0	18:20:28.459	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: setObjects enabled - create Alias Channels possible
    javascript.0	18:20:28.460	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: weather alias for accuweather.0. already exists
    javascript.0	18:20:28.464	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    javascript.0	18:20:28.502	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Desired TFT Firmware: 53 / v4.4.0
    javascript.0	18:20:28.502	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Installed TFT Firmware: 53 / v4.4.0
    javascript.0	18:20:28.720	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Debug mode activated
    javascript.0	18:20:28.788	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Tasmota Buzzer disabled
    javascript.0	18:20:28.800	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: NaN W
    javascript.0	18:20:28.801	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: get_current_tasmota_ip_address: 192.168.188.240
    javascript.0	18:20:28.809	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting tasmota firmware version
    javascript.0	18:20:28.810	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting current berry driver version
    javascript.0	18:20:28.811	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: get_current_tasmota_ip_address: 192.168.188.240
    javascript.0	18:20:28.811	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting online berry driver version
    javascript.0	18:20:28.811	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting online TFT version
    javascript.0	18:20:28.813	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting online firmware version
    javascript.0	18:20:28.828	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: import adbase as ad from luibackend.config import LuiBackendConfig from luibackend.controller import LuiController from luibackend.mqtt import LuiMqttListener, LuiMqttSender from luibackend.updater import Updater import apis import json from typing import Literal class NsPanelLovelaceUIManager(ad.ADBase): def initialize(self): self.adapi = self.get_ad_api() self.adapi.log('Starting') apis.ad_api = self.adapi apis.ha_api = self.get_plugin_api("HASS") apis.mqtt_api = self.get_plugin_api("MQTT") cfg = self._cfg = LuiBackendConfig(apis.ha_api, self.args["config"]) use_api = cfg.get("use_api") == True topic_send = cfg.get("panelSendTopic") topic_recv = cfg.get("panelRecvTopic") api_panel_name = cfg.get("panelName") api_device_id = cfg.get("panelDeviceId") quiet = cfg.get("quiet") mqttsender = self._mqttsender = LuiMqttSender(apis.ha_api, use_api, topic_send, api_panel_name, quiet) self._controller = LuiController(cfg, mqttsender.send_mqtt_msg) desired_tasmota_driver_version = 8 desired_display_firmware_version = 53 version = "v4.3.3" model = cfg.get("model") if model == "us-l": desired_display_firmware_url = cfg._config.get("displayURL-US-L", f"http://nspanel.pky.eu/lovelace-ui/github/nspanel-us-l-{version}.tft") elif model == "us-p": desired_display_firmware_url = cfg._config.get("displayURL-US-P", f"http://nspanel.pky.eu/lovelace-ui/github/nspanel-us-p-{version}.tft") else: desired_display_firmware_url = cfg._config.get("displayURL-EU", f"http://nspanel.pky.eu/lovelace-ui/github/nspanel-{version}.tft") desired_tasmota_driver_url = cfg._config.get("berryURL", "https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/tasmota/autoexec.be") mode = cfg.get("updateMode") updater = Updater(self.adapi.log, mqttsender, topic_send, mode, desired_display_firmware_version, model, desired_display_firmware_url, desired_tasmota_driver_version, desired_tasmota_driver_url) # Request Tasmota Driver Version updater.request_berry_driver_version() LuiMqttListener(use_api, topic_recv, api_panel_name, api_device_id, self._controller, updater) self.adapi.log(f'Started ({version})') # # helpers # def show_card(self, card_key: str) -> None: """Used to show card on panel""" msg = json.dumps({"CustomRecv":f"event,buttonPress2,navigate.{card_key},button"}) topic = self._cfg.get("panelRecvTopic") self._mqttsender.send_mqtt_msg(msg, topic) def navigate(self, direction: Literal['up', 'prev', 'next']) -> None: """Used to navigate different directions on the panel""" msg = json.dumps({"CustomRecv":f"event,buttonPress2,nav{direction.title()},button"}) topic = self._cfg.get("panelRecvTopic") self._mqttsender.send_mqtt_msg(msg, topic) @property def current_card(self) -> str: """Used to get the panel's current card""" return self._controller.current_card.key
    javascript.0	18:20:28.832	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: # Sonoff NSPanel Tasmota Lovelace UI Berry Driver (Extended Flashing to faster speeds; improved Error Handling)| code by joBr99 # based on; # Sonoff NSPanel Tasmota (Nextion with Flashing) driver | code by peepshow-21 # based on; # Sonoff NSPanel Tasmota driver v0.47 | code by blakadder and s-hadinger # Example Flash # FlashNextion http://ip-address-of-your-homeassistant:8123/local/nspanel.tft # FlashNextion http://nspanel.pky.eu/lui.tft class Nextion : Driver static header = bytes('55BB') static flash_block_size = 4096 var flash_mode var flash_start_millis var flash_size var flash_written var flash_buff var flash_offset var flash_proto_version var flash_proto_baud var awaiting_offset var tcp var ser var last_per var url def split_55(b) var ret = [] var s = size(b) var i = s-2 # start from last-1 while i > 0 if b[i] == 0x55 && b[i+1] == 0xBB ret.push(b[i..s-1]) # push last msg to list b = b[(0..i-1)] # write the rest back to b end i -= 1 end ret.push(b) return ret end def crc16(data, poly) if !poly poly = 0xA001 end # CRC-16 MODBUS HASHING ALGORITHM var crc = 0xFFFF for i:0..size(data)-1 crc = crc ^ data[i] for j:0..7 if crc & 1 crc = (crc >> 1) ^ poly else crc = crc >> 1 end end end return crc end # encode using custom protocol 55 BB [payload length] [payload length] [payload] [crc] [crc] def encode(payload) var b = bytes() b += self.header b.add(size(payload), 2) # add size as 2 bytes, little endian b += bytes().fromstring(payload) var msg_crc = self.crc16(b) b.add(msg_crc, 2) # crc 2 bytes, little endian return b end def encodenx(payload) var b = bytes().fromstring(payload) b += bytes('FFFFFF') return b end def sendnx(payload) import string var payload_bin = self.encodenx(payload) self.ser.write(payload_bin) log(string.format("NXP: Nextion command sent = %s",str(payload_bin)), 3) end def send(payload) var payload_bin = self.encode(payload) if self.flash_mode==1 log("NXP: skipped command becuase still flashing", 3) else self.ser.write(payload_bin) log("NXP: payload sent = " + str(payload_bin), 3) end end def write_to_nextion(b) self.ser.write(b) end def screeninit() log("NXP: Screen Initialized") self.sendnx("recmod=1") end def write_block() import string log("FLH: Read block",3) while size(self.flash_buff)<self.flash_block_size && self.tcp.connected() if self.tcp.available()>0 self.flash_buff += self.tcp.readbytes(4096) else tasmota.delay(50) log("FLH: Wait for available...",3) end end log("FLH: Buff size "+str(size(self.flash_buff)),3) var to_write if size(self.flash_buff)>self.flash_block_size to_write = self.flash_buff[0..self.flash_block_size-1] self.flash_buff = self.flash_buff[self.flash_block_size..] else to_write = self.flash_buff self.flash_buff = bytes() end log("FLH: Writing "+str(size(to_write)),3) var per = (self.flash_written*100)/self.flash_size if (self.last_per!=per) self.last_per = per tasmota.publish_result(string.format("{\"Flashing\":{\"complete\": %d, \"time_elapsed\": %d}}",per , (tasmota.millis()-self.flash_start_millis)/1000), "RESULT") end if size(to_write)>0 self.flash_written += size(to_write) self.ser.write(to_write) end log("FLH: Total "+str(self.flash_written),3) if (self.flash_written==self.flash_size) log("FLH: Flashing complete - Time elapsed: %d", (tasmota.millis()-self.flash_start_millis)/1000) self.flash_mode = 0 self.ser.deinit() self.ser = serial(17, 16, 115200, serial.SERIAL_8N1) end end def every_100ms() import string if self.ser.available() > 0 var msg = self.ser.read() if size(msg) > 0 log(string.format("NXP: Received Raw = %s",str(msg)), 3) if (self.flash_mode==1) var strv = msg[0..-4].asstring() if string.find(strv,"comok 2")>=0 tasmota.delay(50) log("FLH: Send (High Speed) flash start") self.flash_start_millis = tasmota.millis() #self.sendnx(string.format("whmi-wris %d,115200,res0",self.flash_size)) if self.flash_proto_version == 0 self.sendnx(string.format("whmi-wri %d,%d,res0",self.flash_size,self.flash_proto_baud)) else self.sendnx(string.format("whmi-wris %d,%d,res0",self.flash_size,self.flash_proto_baud)) end if self.flash_proto_baud != 115200 tasmota.delay(50) self.ser.deinit() self.ser = serial(17, 16, self.flash_proto_baud, serial.SERIAL_8N1) end elif size(msg)==1 && msg[0]==0x08 log("FLH: Waiting offset...",3) self.awaiting_offset = 1 elif size(msg)==4 && self.awaiting_offset==1 self.awaiting_offset = 0 self.flash_offset = msg.get(0,4) log("FLH: Flash offset marker "+str(self.flash_offset),3) if self.flash_offset != 0 self.open_url_at(self.url, self.flash_offset) self.flash_written = self.flash_offset end self.write_block() elif size(msg)==1 && msg[0]==0x05 self.write_block() else log("FLH: Something has gone wrong flashing display firmware ["+str(msg)+"]",2) end else var msg_list = self.split_55(msg) for i:0..size(msg_list)-1 msg = msg_list[i] if size(msg) > 0 if msg == bytes('000000FFFFFF88FFFFFF') self.screeninit() elif size(msg)>=2 && msg[0]==0x55 && msg[1]==0xBB var jm = string.format("{\"CustomRecv\":\"%s\"}",msg[4..-3].asstring()) tasmota.publish_result(jm, "RESULT") elif msg[0]==0x07 && size(msg)==1 # BELL/Buzzer tasmota.cmd("buzzer 1,1") else var jm = string.format("{\"nextion\":\"%s\"}",str(msg[0..-4])) tasmota.publish_result(jm, "RESULT") end end end end end end end def begin_nextion_flash() self.flash_written = 0 self.awaiting_offset = 0 self.flash_offset = 0 self.sendnx('DRAKJHSUYDGBNCJHGJKSHBDN') self.sendnx('recmod=0') self.sendnx('recmod=0') self.flash_mode = 1 self.sendnx("connect") end def open_url_at(url, pos) self.url = url import string var host var port var s1 = string.split(url,7)[1] var i = string.find(s1,":") var sa if i<0 port = 80 i = string.find(s1,"/") sa = string.split(s1,i) host = sa[0] else sa = string.split(s1,i) host = sa[0] s1 = string.split(sa[1],1)[1] i = string.find(s1,"/") sa = string.split(s1,i) port = int(sa[0]) end var get = sa[1] log(string.format("FLH: host: %s, port: %s, get: %s",host,port,get)) self.tcp = tcpclient() self.tcp.connect(host,port) log("FLH: Connected:"+str(self.tcp.connected()),3) var get_req = "GET "+get+" HTTP/1.0\r\n" get_req += string.format("Range: bytes=%d-\r\n", pos) get_req += string.format("HOST: %s:%s\r\n\r\n",host,port) self.tcp.write(get_req) var a = self.tcp.available() i = 1 while a==0 && i<5 tasmota.delay(100*i) tasmota.yield() i += 1 log("FLH: Retry "+str(i),3) a = self.tcp.available() end if a==0 log("FLH: Nothing available to read!",3) return end var b = self.tcp.readbytes() i = 0 var end_headers = false; var headers while i<size(b) && headers==nil if b[i..(i+3)]==bytes().fromstring("\r\n\r\n") headers = b[0..(i+3)].asstring() self.flash_buff = b[(i+4)..] else i += 1 end end #print(headers) # check http respose for code 200/206 if string.find(headers,"200 OK")>0 || string.find(headers,"206 Partial Content")>0 log("FLH: HTTP Respose is 200 OK or 206 Partial Content",3) else log("FLH: HTTP Respose is not 200 OK or 206 Partial Content",3) print(headers) return -1 end # only set flash size if pos is zero if pos == 0 # check http respose for content-length var tag = "Content-Length: " i = string.find(headers,tag) if (i>0) var i2 = string.find(headers,"\r\n",i) var s = headers[i+size(tag)..i2-1] self.flash_size=int(s) end log("FLH: Flash file size: "+str(self.flash_size),3) end end def flash_nextion(url) self.flash_size = 0 var res = self.open_url_at(url, 0) if res != -1 self.begin_nextion_flash() end end def init() log("NXP: Initializing Driver") self.ser = serial(17, 16, 115200, serial.SERIAL_8N1) self.flash_mode = 0 self.flash_proto_version = 1 self.flash_proto_baud = 921600 end end var nextion = Nextion() tasmota.add_driver(nextion) def get_current_version(cmd, idx, payload, payload_json) import string var version_of_this_script = 9 var jm = string.format("{\"nlui_driver_version\":\"%s\"}", version_of_this_script) tasmota.publish_result(jm, "RESULT") end tasmota.add_cmd('GetDriverVersion', get_current_version) def update_berry_driver(cmd, idx, payload, payload_json) def task() import path import string if string.find(payload, ".tapp") > 0 print("tapp in URL; will do .tapp update and migration if necessary") if path.exists("autoexec.be") print("autoexec.be found; will check for migration") var autoexecfile = open('autoexec.be') var line = autoexecfile.readline() autoexecfile.close() if string.find(line, "NSPanel Tasmota Lovelace UI Berry Driver") > 0 print("found lovelace berry driver, going to delete autoexec.be and .bec") path.remove("autoexec.be") path.remove("autoexec.bec") end end var r = tasmota.urlfetch(payload, "nsp-lovelace-driver.tapp") if r < 0 print("Update failed") else tasmota.cmd("Restart 1") end elif string.find(payload, ".be") > 0 print("be in URL; will do .be update") if path.exists("nsp-lovelace-driver.tapp") print("Error: there is the tapp version of the berry driver installed; cannot do .be update.") else var cl = webclient() cl.begin(payload) var r = cl.GET() if r == 200 print("Sucessfully downloaded nspanel-lovelace-ui berry driver") else print("Error while downloading nspanel-lovelace-ui berry driver") end r = cl.write_file("autoexec.be") if r < 0 print("Error while writeing nspanel-lovelace-ui berry driver") else print("Sucessfully written nspanel-lovelace-ui berry driver") tasmota.cmd("Restart 1") end end else print("invalid url filetype") end if path.exists("nsp-lovelace-driver.tapp") var r = string.find(payload, ".tapp") if r < 0 print("URL doesn't contain .tapp skipping update") else end else var r = string.find(payload, ".be") if r < 0 print("URL doesn't contain .be skipping update") else end end end tasmota.set_timer(0,task) tasmota.resp_cmnd_done() end tasmota.add_cmd('UpdateDriverVersion', update_berry_driver) def flash_nextion(cmd, idx, payload, payload_json) def task() nextion.flash_proto_version = 1 nextion.flash_proto_baud = 921600 nextion.flash_nextion(payload) end tasmota.set_timer(0,task) tasmota.resp_cmnd_done() end def flash_nextion_adv(cmd, idx, payload, payload_json) def task() if idx==0 nextion.flash_proto_version = 1 nextion.flash_proto_baud = 921600 elif idx==1 nextion.flash_proto_version = 0 nextion.flash_proto_baud = 921600 elif idx==2 nextion.flash_proto_version = 1 nextion.flash_proto_baud = 115200 elif idx==3 nextion.flash_proto_version = 0 nextion.flash_proto_baud = 115200 elif idx==4 nextion.flash_proto_version = 1 nextion.flash_proto_baud = 256000 elif idx==5 nextion.flash_proto_version = 0 nextion.flash_proto_baud = 256000 elif idx==6 nextion.ser.deinit() nextion.ser = serial(17, 16, 9600, serial.SERIAL_8N1) nextion.flash_proto_version = 0 nextion.flash_proto_baud = 921600 else nextion.flash_proto_version = 0 nextion.flash_proto_baud = 115200 end nextion.flash_nextion(payload) end tasmota.set_timer(0,task) tasmota.resp_cmnd_done() end def send_cmd(cmd, idx, payload, payload_json) nextion.sendnx(payload) tasmota.resp_cmnd_done() end def send_cmd2(cmd, idx, payload, payload_json) nextion.send(payload) tasmota.resp_cmnd_done() end tasmota.add_cmd('Nextion', send_cmd) tasmota.add_cmd('CustomSend', send_cmd2) tasmota.add_cmd('FlashNextion', flash_nextion) tasmota.add_cmd('FlashNextionAdv', flash_nextion_adv)
    javascript.0	18:20:28.835	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: online display firmware version => 53
    javascript.0	18:20:28.852	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: {"nlui_driver_version":"9"}
    javascript.0	18:20:28.855	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: current tasmota firmware version => 14.3.0
    javascript.0	18:20:28.855	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: online berry driver version => 9
    javascript.0	18:20:28.882	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: current berry driver version => 9
    javascript.0	18:20:28.926	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: hidden Cards disabled
    javascript.0	18:20:29.007	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: {"url":"https://api.github.com/repos/joBr99/nspanel-lovelace-ui/releases/149090497","assets_url":"https://api.github.com/repos/joBr99/nspanel-lovelace-ui/releases/149090497/assets","upload_url":"https://uploads.github.com/repos/joBr99/nspanel-lovelace-ui/releases/149090497/assets{?name,label}","html_url":"https://github.com/joBr99/nspanel-lovelace-ui/releases/tag/v4.4.0","id":149090497,"author":{"login":"joBr99","id":29555657,"node_id":"MDQ6VXNlcjI5NTU1NjU3","avatar_url":"https://avatars.githubusercontent.com/u/29555657?v=4","gravatar_id":"","url":"https://api.github.com/users/joBr99","html_url":"https://github.com/joBr99","followers_url":"https://api.github.com/users/joBr99/followers","following_url":"https://api.github.com/users/joBr99/following{/other_user}","gists_url":"https://api.github.com/users/joBr99/gists{/gist_id}","starred_url":"https://api.github.com/users/joBr99/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/joBr99/subscriptions","organizations_url":"https://api.github.com/users/joBr99/orgs","repos_url":"https://api.github.com/users/joBr99/repos","events_url":"https://api.github.com/users/joBr99/events{/privacy}","received_events_url":"https://api.github.com/users/joBr99/received_events","type":"User","user_view_type":"public","site_admin":false},"node_id":"RE_kwDOGo1zRM4I4vDB","tag_name":"v4.4.0","target_commitish":"main","name":"v4.4.0 - Update for HA 2024.04","draft":false,"prerelease":false,"created_at":"2024-03-30T11:18:31Z","published_at":"2024-03-30T12:26:37Z","assets":[],"tarball_url":"https://api.github.com/repos/joBr99/nspanel-lovelace-ui/tarball/v4.4.0","zipball_url":"https://api.github.com/repos/joBr99/nspanel-lovelace-ui/zipball/v4.4.0","body":"## Besides the Update of the App in HACS you need to do the following things:\r\n\r\n🔄 **Restart the AppDaemon Container**\r\n\r\n**Add the following workaround to your Home Assistant configuration.yaml**\r\n\r\nhttps://docs.nspanel.pky.eu/stable/prepare_ha/#workaround-for-homeassistant-202404\r\n\r\n🔄 **Restart Home Assistant**\r\n\r\n## New Features:\r\n\r\n- **Implemented changes to work with upcoming Homeassistant Version 2024.04 @joBr99**\r\n","mentions_count":1}
    TT-Tom
    #6650
    @kerschte_de
    kannst zurück setzen
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    • T TT-Tom
      @kerschte_de
      aus dem Script diese Zeilen zeigen und ein Screenshot vom MQTT baum des Panel
      // DE: Anpassen an die Verzeichnisse der MQTT-Adapter-Instanz
      // EN: Adapt to the MQTT adapter instance directories
      const NSPanelReceiveTopic: string = 'mqtt.0.SmartHome.NSPanel_1.tele.RESULT';
      const NSPanelSendTopic: string = 'mqtt.0.SmartHome.NSPanel_1.cmnd.CustomSend';
      Kerschte_de
      #6651
      @tt-tom
      ... ja, mache ich:
      /***** 1. Tasmota-Config *****/
          const NSPanelReceiveTopic: string = 'mqtt.0.RagowSmartHome.NSPanel_85C180.tele.RESULT';
          const NSPanelSendTopic: string = 'mqtt.0.RagowSmartHome.NSPanel_85C180.cmnd.CustomSend';
          // DE: nur ändern, falls der User im Tasmota vor dem Kompilieren umbenannt wurde (Standard Tasmota: admin)
          // EN: only change if the user was renamed in Tasmota before compiling (default Tasmota: admin)
          const tasmota_web_admin_user: string = 'admin';
          // DE: setzten, falls "Web Admin Password" in Tasmota vergeben
          // EN set if "Web Admin Password" is assigned in Tasmota
          const tasmota_web_admin_password: string = '';
          // DE: Setzen der bevorzugten Tasmota32-Version (für Updates)
          // EN: Set preferred Tasmota32 version (for updates)
          const tasmotaOtaVersion: string = 'tasmota32-DE.bin';
              // DE: Es können ebenfalls andere Versionen verwendet werden wie zum Beispiel:
              // EN: Other versions can also be used, such as:
              // 'tasmota32-nspanel.bin' or 'tasmota32.bin' or 'tasmota32-DE.bin' or etc.
      • K Kerschte_de
        @tt-tom
        ... ja, mache ich:
        TT-Tom
        #6652
        @kerschte_de
        der tele fehlt, der ist entscheidend
        Gruß Tom
        Public Transport
        • T TT-Tom
          @kerschte_de
          Kerschte_de
          #6653
          @tt-tom ... oh, sorry.
          • K Kerschte_de
            TT-Tom
            #6654
            @kerschte_de
            okay hier stimmt alles, jetzt bitte die Config einer Seite wo keine Werte kommen und den passenden Objektbaum vom ioBroker
            Gruß Tom
            Public Transport
            K 2 Antworten Letzte Antwort
            • T TT-Tom
              @kerschte_de
              Kerschte_de
              #6655
              @tt-tom ja, gern.
              Die Hauptseite ("HOME") dient der Navigation auf Unterseiten. Aktuell habe ich nur noch die im Erdgeschoss aktiv. Dort sind testweise 2 Temperatur-Sensoren verlinkt ... es kommt jedoch nichts an Werten an. Die Seiten selbst funktionieren alle ... so auch wie der Screensaver und das komplette Service-Menu:
              //-- Anfang für eigene Seiten -- z.T. selbstdefinierte Aliase erforderlich ----------------
              //-- Start for your own pages -- some self-defined aliases required ----------------
                  //-- https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Page-%E2%80%90-Typen_How-2_Beispiele
              //-- ##### ##### ##### KERSTEN #### ##### #####
              //Level 0
              let Navigation1: PageType =
                  'type': 'cardGrid',
                  'heading': 'HOME',
                  'useColor': true,
                  'items': [
                      /*PageItem*/{ navigate: true, id: 'SensorenEG', icon: 'home-floor-0',offColor: Menu, onColor: Menu, name: 'Sensoren EG'},
                      //*PageItem*/{ navigate: true, id: 'SensorenOG', icon: 'home-floor-1',offColor: Menu, onColor: Menu, name: 'Sensoren OG'},
                      //*PageItem*/{ navigate: true, id: 'SensorenKeller', icon: 'home-floor-negative-1',offColor: Menu, onColor: Menu, name: 'Sensoren Keller'},
                      /*PageItem*/{ navigate: true, id: 'NSPanel_Service', icon: 'hammer-screwdriver',offColor: Menu, onColor: Menu, name: 'ServiceMenu'},
                      //{ id: 'alias.0.NSPanel_1.TestFenster', offColor: MSRed, onColor: MSGreen, name: 'Büro Fenster'},
                      //{ id: 'alias.0.NSPanel_1.Luftreiniger', icon: 'power', offColor: MSRed, onColor: MSGreen},
                      //{ id: 'alias.0.NSPanel_1.TestBlind', icon: 'projector-screen', onColor: White, name: 'Beamer', secondRow: 'auch Text'},
                      //{ id: 'alias.0.NSPanel_1.Kippfenster', useValue: true }
                   //Level 1
                   let SensorenEG: PageType =
                       'type': 'cardGrid',
                       'heading': 'Zigbee-Geräte EG',
                       'useColor': true,
                       'subPage': true,
                       'parent': Navigation1,
                       'items': [
                           { id: 'alias.0.NSPanel.1.1_Haus.EG.TempWZ.ACTUAL', name: 'WZ Temp.°C', offColor: MSRed, onColor: MSGreen, useValue: true, fontSize: 3, colorScale: {'val_min': 15, 'val_max': 35, 'val_best': 21} },
                           { id: 'alias.0.NSPanel.1.1_Haus.EG.TempWZ.SECOND', name: 'WZ Luft %', offColor: MSYellow, onColor: MSYellow , useValue: true, fontSize: 3, colorScale: {'val_min': 30, 'val_max': 100, 'val_best': 60} },
                           { id: 'alias.0.NSPanel.1.1_Haus.EG.TempKueche.ACTUAL', name: 'Küche Temp.°C', offColor: MSRed, onColor: MSGreen, useValue: true, fontSize: 3, colorScale: {'val_min': 15, 'val_max': 35, 'val_best': 21} },
                           { id: 'alias.0.NSPanel.1.1_Haus.EG.TempKueche.SECOND', name: 'Küche Luft %', offColor: MSYellow, onColor: MSYellow , useValue: true, fontSize: 3, colorScale: {'val_min': 30, 'val_max': 100, 'val_best': 60} },
              //-- ENDE für eigene Seiten -- z.T. selbstdefinierte Aliase erforderlich -------------------------
              Hier noch die Einbindung der Seiten selbst:
               **                           Configuration                           **
              export const config: Config = {
                  // Seiteneinteilung / Page division
                  // Hauptseiten / Mainpages
                  pages: [
                      Navigation1,
                      //NSPanel_Service, //Auto-Alias Service Page
                      //Unlock_Service            //Auto-Alias Service Page (Service Pages used with cardUnlock)
                  // Unterseiten / Subpages
                  subPages: [
                      SensorenEG, // --> KeT hinzugefügt
                      NSPanel_Service, //Auto-Alias Service Page --> KeT von der Hauptseite auf die Sub-Seite verschoben (über Auskommentierung)
                      NSPanel_Service_SubPage, //Auto-Alias Service Page (only used with cardUnlock)
                      NSPanel_Infos, //Auto-Alias Service Page
                      NSPanel_Wifi_Info_1, //Auto-Alias Service Page
                      NSPanel_Wifi_Info_2, //Auto-Alias Service Page
                      NSPanel_Sensoren, //Auto-Alias Service Page
                      NSPanel_Hardware, //Auto-Alias Service Page
                      NSPanel_IoBroker, //Auot-Alias Service Page
                      NSPanel_Einstellungen, //Auto-Alias Service Page
                      NSPanel_Screensaver, //Auto-Alias Service Page
                      NSPanel_ScreensaverDimmode, //Auto-Alias Service Page
                      NSPanel_ScreensaverBrightness, //Auto-Alias Service Page
                      NSPanel_ScreensaverLayout, //Auto-Alias Service Page
                      NSPanel_ScreensaverWeather, //Auto-Alias Service Page
                      NSPanel_ScreensaverDateformat, //Auto-Alias Service Page
                      NSPanel_ScreensaverIndicators, //Auto-Alias Service Page
                      NSPanel_Relays, //Auto-Alias Service Page
                      NSPanel_Script, //Auto-Alias Service Page
                      NSPanel_Firmware, //Auto-Alias Service Page
                      NSPanel_FirmwareTasmota, //Auto-Alias Service Page
                      NSPanel_FirmwareBerry, //Auto-Alias Service Page
                      NSPanel_FirmwareNextion, //Auto-Alias Service Page
              und hier der Sreenshot der beiden Temperatur-Sensoren:
              • T TT-Tom
                @kerschte_de
                Kerschte_de
                #6656
                @tt-tom
                Das Konstrukt hatte in der alten Umgebung funktioniert. Testweise hatte ich es auf etliche Sensoren in den unterschiedlichen Etagen mal aufgebaut. Aktuell funktionieren die Seiten weiterhin, nur die Inhalte der Sensoren werden nicht transferiert.
                • K Kerschte_de
                  @tt-tom ja, gern.
                  //Level 0
                      'type': 'cardGrid',
                      'heading': 'HOME',
                      'useColor': true,
                      'items': [
                       //Level 1
                           'type': 'cardGrid',
                           'useColor': true,
                           'subPage': true,
                           'items': [
                   **                           Configuration                           **
                      pages: [
                          Navigation1,
                      subPages: [
                  TT-Tom
                  #6657
                  @kerschte_de
                  du hast zwei Fehler in deinem Setup.
                           'type': 'cardGrid',
                           'useColor': true,
                           'subPage': true,
                           'items': [
                  in einer Page Config, werden keine Datenpunkte angegeben, sonder immer nur die Cannel.
                  { id: 'alias.0.NSPanel.1.1_Haus.EG.TempWZ', name: 'WZ Temp.°C', offColor: MSRed, onColor: MSGreen, useValue: true, fontSize: 3, colorScale: {'val_min': 15, 'val_max': 35, 'val_best': 21} },
                  dein Channel hat für diese Kombi (ACTUAL, SECOND) den falschen Typ. Diese Datenpunkte werden nur beim Thermostat ausgewertet, was auch eine andere Page zur Folge hat. Beim Type Temperature wird nur der ACTUAL ausgewertet vom Script.
                  Bedeutet du musst für jeden Sensor einen eigenen Alias erstellen.
                  Im Screensaver sieht die Sache anders aus dort wird direkt auf den Datenpunkt verwiesen. Beispiel hier
                  // leftScreensaverEntity 1 (only Advanced Screensaver)
                                  ScreensaverEntity: NSPanel_Path + 'Sensor.ANALOG.Temperature',
                                  ScreensaverEntityFactor: 1,
                                  ScreensaverEntityDecimalPlaces: 1,
                                  ScreensaverEntityIconOn: 'thermometer',
                                  ScreensaverEntityIconOff: null,
                                  ScreensaverEntityText: 'Temperatur',
                                  ScreensaverEntityUnitText: '°C',
                                  ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 35, 'val_best': 22}
                  Gruß Tom
                  Public Transport
                  • T TT-Tom
                    @kerschte_de
                             'type': 'cardGrid',
                             'useColor': true,
                             'subPage': true,
                             'items': [
                    Kerschte_de
                    #6658
                    @tt-tom Großartig, dass Du auf fehlerhafte Punkte gestoßen bist. Ich habe gerade jedoch Mühe, Deinen Punkt richtig zu verstehen. Ich habe mitgenommen, dass ich die Aliase neu anlegen muss. Dabei darf ich jedoch nicht auf den Typ "Temperatur" gehen?
                    • K Kerschte_de
                      TT-Tom
                      #6659
                      @kerschte_de
                      Doch Temperatur ist richtig.
                      Aber nur ACTUAL ausfüllen. Für für Luftfeuchtigkeit gibt es einen anderen Typ/Cannel.
                      Gruß Tom
                      Public Transport
                      • T TT-Tom
                        @kerschte_de
                        Kerschte_de
                        #6660
                        @tt-tom ... das würde jedoch bedeuten, dass die Temp angezeigt, die Luftfeuchte jedoch nicht. Es wird allerdings gar keiner der 4 Werte angezeigt ... nur die Feldbezeichnungen und Einheiten.
                        Ich habe die Luftfeuchtigkeit als "SECOND" im Alias-Gerät herausgelöscht, so dass ausschließlich der ACTUAL existiert. Zudem im Script die Verlinkung herausgenommen bzw. auskommentiert.
                             //Level 1
                                 'type': 'cardGrid',
                                 'useColor': true,
                                 'subPage': true,
                                 'items': [
                                     {},//{ id: '', name: 'WZ Luft %', offColor: MSYellow, onColor: MSYellow , useValue: true, fontSize: 3, colorScale: {'val_min': 30, 'val_max': 100, 'val_best': 60} },
                                     {},//{ id: '', name: 'Küche Luft %', offColor: MSYellow, onColor: MSYellow , useValue: true, fontSize: 3, colorScale: {'val_min': 30, 'val_max': 100, 'val_best': 60} },
                        Die Seite besteht jetzt nur noch aus den beiden Temperaturen, die jedoch weiterhin mit "0" angezeigt werden.
                        Läuft die Kommunikation zw. ioB und NSP der Werte anders als die der Seiten? Oder wird das alles ausschließlich über die beiden Punkte "CustomSend" und "RESULT"?
                        • T TT-Tom
                          @kerschte_de
                          Kerschte_de
                          schrieb am zuletzt editiert von Kerschte_de
                          #6661
                          @tt-tom Die Luftfeuchtigkeit habe ich jetzt für die beiden Testräume als einzelnen Channel "Feuchtigkeit" angelegt und eingebunden. Die Felder werden wieder angezeigt, der Wert darin "0".
                          //Level 0
                              'type': 'cardGrid',
                              'heading': 'HOME',
                              'useColor': true,
                              'items': [
                               //Level 1
                                   'type': 'cardGrid',
                                   'useColor': true,
                                   'subPage': true,
                                   'items': [
                                       { id: 'alias.0.NSPanel.1.1_Haus.EG.LuftfeuchteWZ.ACTUAL', name: 'WZ Luft %', offColor: MSYellow, onColor: MSYellow , useValue: true, fontSize: 3, colorScale: {'val_min': 30, 'val_max': 100, 'val_best': 60} },
                                       { id: 'alias.0.NSPanel.1.1_Haus.EG.LuftfeuchteKueche.ACTUAL', name: 'Küche Luft %', offColor: MSYellow, onColor: MSYellow , useValue: true, fontSize: 3, colorScale: {'val_min': 30, 'val_max': 100, 'val_best': 60} },
                          //-- END for your own pages -- some self-defined aliases required ------------------------
                          Macht es Sinn, nochmal bestimmte Punkte der Installation zu wiederholen?
                          • K Kerschte_de
                            //Level 0
                                'type': 'cardGrid',
                                'heading': 'HOME',
                                'useColor': true,
                                'items': [
                                 //Level 1
                                     'type': 'cardGrid',
                                     'useColor': true,
                                     'subPage': true,
                                     'items': [
                            TT-Tom
                            #6662
                            @kerschte_de
                            du hast mein Post anscheinend nicht verstanden. In der Page/Seitenconfig wird nicht auf den Datenpunkt verwiesen, sondern auf den Folder/Channel.
                            Edit: link zum Post
                            das passt schon, sind nur kleine Fehler. Das Grundgerüst steht doch. :)
                            Gruß Tom
                            Public Transport
                            • T TT-Tom
                              @kerschte_de
                              Edit: link zum Post
                              Kerschte_de
                              #6663
                              @tt-tom sagte in SONOFF NSPanel mit Lovelace UI:
                              @kerschte_de
                              Oh Mann, jetzt raff ich es erst. Habe es angepasst und es funktioniert tadellos. Dann starte ich mal mit dem Aufbau. Tausend Dank @TT-Tom für's Entdecken meines Fehlers. Schönes WE und schönen 3. Advent heute :)
                              • K Kerschte_de
                                @kerschte_de
                                TT-Tom
                                #6664
                                @kerschte_de
                                viel Spass beim Neuaufbau und schönen 3. Advent🎄
                                Gruß Tom
                                Public Transport
                                  Kerschte_de
                                  #6665
                                  Guten Abend.
                                  Ich habe gerade eine Hue-Birne aus dem Hue-Adapter in das NSPanel integriert (als Gerät "Hue-Licht"). Die Steuerung der Farben geht soweit (auch wenn ich nicht auf ein sattes blau komme), aber bei der Steuerung der Farbtemperatur funktioniert genau diese nicht. Die Helligkeit auf der Seite läuft, die Farbtemperatur ist fest auf auf 2000 °K eingestellt (bei erstmaliger Betätigung des Farbtemperatur-Gebers). Man kann den Regler schieben wie man möchte, keine Reaktion. Ändere ich den Wert im Alias in der Objektstruktur durch Werteingabe, funktionert es tatellos. Handelt es sich um einen Fehler im Script?
                                  Das Script zum NSP habe ich mal auf debug gestellt und den Farbtemp-Regler betätigt. Aktion gibt es - sie kommt nur nirgends an und im Alias wird permanent die 2000 °K angezeigt. Alles andere lässt sich an der Lampe über das NSP bedienen.
                                  javascript.0	20:53:03.174	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_FINAL: HandleButtonEvent activePage: 4 id: 0 tempid: 0 pageItemId: alias.0.NSPanel.1.1_Haus.Og.Badlampe
                                  javascript.0	20:53:03.174	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_FINAL: HandleButtonEvent übergebene Werte event - buttonPress2 - 0 - colorTempSlider - 46 - PageId: 0
                                  javascript.0	20:53:03.174	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_FINAL: HandleButtonEvent buttonAction: colorTempSlider
                                  javascript.0	20:53:03.174	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_FINAL: HandleMessage -> buttonPress2 event - buttonPress2 - 0 - colorTempSlider - 46
                                  javascript.0	20:53:03.425	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_FINAL: findPageItem -> pageItem {"id":"alias.0.NSPanel.1.1_Haus.Og.Badlampe","offColor":{"red":251,"green":105,"blue":98},"onColor":{"red":121,"green":222,"blue":121},"name":"Bad-Lampe"}
                                  Der entsprechende Script-Eintrag lautet wie folgt:
                                           let EinzellichterWZ: PageType =
                                              'type': 'cardEntities',
                                              'heading': 'WZ Einzel-Lampen',
                                              'useColor': true,
                                              'subPage': true,
                                              'parent': Wohnzimmer1,
                                              'prev': undefined,
                                              'next': undefined,
                                              'home': 'HOME1',
                                              'items': [
                                                  { id: 'alias.0.NSPanel.1.1_Haus.Og.Badlampe', offColor: MSRed, onColor: MSGreen, name: 'Bad-Lampe', interpolateColor: true},
                                                  //{ id: 'alias.0.NSPanel.1.1_Haus.Og.Badlampe2', offColor: MSRed, onColor: MSGreen, name: 'Bad-Lampe'},
                                                  //{ id: 'alias.0.NSPanel.1.1_Haus.Og.Badlampe3', offColor: MSRed, onColor: MSGreen, name: 'Bad-Lampe'},
                                                  //{ id: 'alias.0.NSPanel.1.1_Haus.Og.Badlampe4', offColor: MSRed, onColor: MSGreen, name: 'Bad-Lampe'}
                                  Vielen Dank für eine Rückmeldung.
                                  Kersten
                                  • K Kerschte_de
                                    Guten Abend.
                                                'useColor': true,
                                                'subPage': true,
                                                'prev': undefined,
                                                'next': undefined,
                                                'home': 'HOME1',
                                                'items': [
                                    Kersten
                                    TT-Tom
                                    #6666
                                    @kerschte_de
                                    Zeige bitte auch mal die Datenpunkte im Alias
                                    der Slider geht auf TEMPERATURE
                                    Edit: Link zum Wiki
                                    noch ein Edit: du musst den Wertebereich für die Farbtemperatur angeben z.b. 2000 - 4400 sieht dann so aus.
                                    { id: 'alias.0.NSPanel.1.1_Haus.Og.Badlampe', offColor: MSRed, onColor: MSGreen, name: 'Bad-Lampe', interpolateColor: true, minValueColorTemp: 2000, maxValueColorTemp: 4400},
                                    Gruß Tom
                                    Public Transport
                                    • T TT-Tom
                                      @kerschte_de
                                      Edit: Link zum Wiki
                                      Kerschte_de
                                      #6667
                                      Hallo Tom,
                                      das hat funktioniert. Es fehlt an den Min-Max-Werten für die Farbtemperatur. Aktuell arbeite ich mich an der Doku auf github durch (Card-Beispiele: (https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Page-‐-Typen_How-2_Beispiele#page-beispiele)). Dort sind Beispiele, jedoch nicht so ausführliche Erklärungen wie im Wiki (das hatte ich leider aus den Augen verloren).
                                      Also der Slider funktioniert nun. Hab vielen Dank :)
                                      • K Kerschte_de
                                        Hallo Tom,
                                        TT-Tom
                                        #6668
                                        @kerschte_de
                                        wenn im Wiki was fehlt, bitte gib mir Bescheid, dass ich es nach liefern kann. danke
                                        Gruß Tom
                                        Public Transport
                                          Tom_W
                                          #6669
                                          ich habe auf einer pageGrid einen Button, der eine Liste aufruft und da wähle ich meinen Sender aus:
                                          { id: "alias.0.NSPanel1.Radiobuttons.Sender_wechseln", offColor: MenuLowInd, onColor: MenuLowInd, name: "Radio", icon: "radio", modeList: ['Aus', 'Bayern 1', 'Bayern 3', 'Antenne Bayern', 'Schlagerparadies', 'BR Schlager', 'Unser Radio'] },
                                          Bis gestern funktionierte das problemlos und heute bleibt die Seite irgendwie leer und es kommt die Warnung:
                                          script.js.NSPanels.PanelWohnzimmer: error at function GenerateDetailPage: Cannot read properties of undefined (reading 'split')
                                          Kann irgendjemand mit der Meldung was anfangen? Eigentlich habe ich nichts geändert und eine andere Liste die ich auf die selbe Weise verwende funktioniert tadellos.
