  3. Entwicklung
  4. Fehlermeldungen (dev-server) beim öffen der Config
    5.2k
28 Beiträge 6 Kommentatoren 2.6k Aufrufe 6 Beobachtet
  • M MCU
    Ich hänge mich mal hier dran.
    Versuche mal ein wenig mit dem dev-server.
    Mir fehlt so ein wenig die Info, in welcher Datei was drin stehen muss damit es ohne Probleme läuft.
    Meine Problemchen sind:
    • auch wie oben beschrieben jede Menge an error-Anzeigen
    2024-11-02 00:41:59.275  - debug: host.dev-jarvis-extensions-iobroker-dev Incoming Host message getHostInfo
    strict mode: missing type "object" for keyword "properties" at "#/if" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#" (strictTypes)
    strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
    strict mode: required property "items" is not defined at "#/properties/items/patternProperties/%5E.%2B/allOf/9/then/oneOf/0" (strictRequired)
    strict mode: required property "#include" is not defined at "#/properties/items/patternProperties/%5E.%2B/allOf/9/then/oneOf/1" (strictRequired)
    strict mode: required property "items" is not defined at "#/patternProperties/%5E.%2B/allOf/9/then/oneOf/0" (strictRequired)
    strict mode: required property "#include" is not defined at "#/patternProperties/%5E.%2B/allOf/9/then/oneOf/1" (strictRequired)
    strict mode: missing type "object" for keyword "required" at "#/definitions/sendToProps" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/sendToProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/sendToProps" (strictTypes)
    strict mode: missing type "object" for keyword "required" at "#/definitions/stateProps" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/stateProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/stateProps" (strictTypes)
    strict mode: missing type "object" for keyword "required" at "#/definitions/passwordProps" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/passwordProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/passwordProps" (strictTypes)
    strict mode: missing type "object" for keyword "required" at "#" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#" (strictTypes)
    strict mode: missing type "object" for keyword "required" at "#/definitions/checkboxProps" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/checkboxProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/checkboxProps" (strictTypes)
    strict mode: missing type "object" for keyword "required" at "#/definitions/fileSelectorProps" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/fileSelectorProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/fileSelectorProps" (strictTypes)
    strict mode: missing type "object" for keyword "required" at "#/definitions/numberProps" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/numberProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/numberProps" (strictTypes)
    strict mode: missing type "object" for keyword "required" at "#/definitions/aliveProps" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/aliveProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/aliveProps" (strictTypes)
    strict mode: missing type "object" for keyword "required" at "#/definitions/qrCodeProps" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/qrCodeProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/qrCodeProps" (strictTypes)
    strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/cronProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/cronProps" (strictTypes)
    strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/0" (strictTypes)
    strict mode: required property "complex" is not defined at "#/definitions/cronProps/oneOf/0" (strictRequired)
    strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/1" (strictTypes)
    strict mode: required property "simple" is not defined at "#/definitions/cronProps/oneOf/1" (strictRequired)
    strict mode: missing type "object" for keyword "required" at "#/definitions/deviceManagerProps" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/deviceManagerProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/deviceManagerProps" (strictTypes)
    strict mode: use allowUnionTypes to allow union type keyword at "#/properties/width" (strictTypes)
    strict mode: required property "items" is not defined at "#/items/allOf/10/then/allOf/1/oneOf/0" (strictRequired)
    strict mode: required property "#include" is not defined at "#/items/allOf/10/then/allOf/1/oneOf/1" (strictRequired)
    strict mode: required property "complex" is not defined at "#/items/allOf/21/then/oneOf/0" (strictRequired)
    strict mode: required property "simple" is not defined at "#/items/allOf/21/then/oneOf/1" (strictRequired)
    strict mode: missing type "object" for keyword "required" at "#/definitions/certificatesProps" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/certificatesProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/certificatesProps" (strictTypes)
    strict mode: missing type "object" for keyword "required" at "#/definitions/instanceProps" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/instanceProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/instanceProps" (strictTypes)
    strict mode: missing type "object" for keyword "required" at "#/definitions/objectIdProps" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/objectIdProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/objectIdProps" (strictTypes)
    strict mode: missing type "object" for keyword "required" at "#/definitions/timePickerProps" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/timePickerProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/timePickerProps" (strictTypes)
    strict mode: missing type "object" for keyword "required" at "#/definitions/coordinatesProps" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/coordinatesProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/coordinatesProps" (strictTypes)
    strict mode: missing type "object" for keyword "required" at "#/definitions/interfaceProps" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/interfaceProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/interfaceProps" (strictTypes)
    Als schema habe ich
    "$schema": "http://json-schema.org/draft-07/schema#",
    ist das richtig? oder muss da was anderes hinein?
    https://github.com/ioBroker/adapter-react-v5/blob/main/schemas/jsonConfig.json
    • habe beim Creator fälschlicherweise VIS angeklickt, jetzt bekomme ich den Fehler
      -> wie bekomme ich den wieder weg? Möchte erstmal nicht mit / für VIS entwickeln
      wo steht der entsprechende Eintrag in der io-package.json / package,json ?
    2024-11-02 00:42:04.096  - error: host.dev-jarvis-extensions-iobroker-dev cannot call visUtils: Not exists
    • Warum werden die Dateien im .devserver-Verzeichnis nicht aktualisiert? Bzw. wie werden sie dort aktualisiert?
      Welcher Befehl muss genutzt werden?
    .devserver
    admin
    ich ändere im admin-Verzeichnis und rufe dann dev-server watch im Adapter-Ordner auf.
    • Wo finde ich die zugehörige Datei? dev-jarvis-extensions-iobroker-dev
    startInstance system.adapter.jarvis-extensions.0 Adapter dependency not fulfilled on "dev-jarvis-extensions-iobroker-dev": required adapter "vis" not found!
    /* es scheint mit der package.json im .devserver zusammenzuhängen */
    /* package.json, dort muss der iobroker.vis-Eintrag sehr wahrscheinlich raus */
        "name":"dev-server.jarvis-extensions",
        "version":"1.0.0",
        "private":true,
        "dependencies":{
            "iobroker.admin":"latest",
            "iobroker.backitup":"3.0.26",
            "iobroker.jarvis-extensions":"file:../../iobroker.jarvis-extensions-0.0.1.tgz",
            "iobroker.js-controller":"latest",
            "iobroker.socketio":"6.7.1",
            "iobroker.vis":"1.5.6",
            "iobroker.web":"6.3.1",
            "iobroker.ws":"2.6.2"
        "dev-server":{
            "adminPort":8081,
            "useSymlinks":false
        "overrides":{
            "@iobroker/adapter-core":"^3.2.1"
    /* irgendwie doch nicht */
    system.adapter.jarvis-extensions.0 [sameHostDependency]: {"js-controller":">=3.3.22","vis":"*"}
    Vielen Dank
    OliverIOO Offline
    OliverIOO Offline
    OliverIO
    ich versuche mal, soweit ich weiß
    @mcu sagte in Fehlermeldungen (dev-server) beim öffen der Config:
    die erscheinen nur bei der entwicklung, die kannst du ignorieren. ich glaube, die müssten weg sein, wenn m,an auf "@iobroker/adapter-core": "^3.2.2", aktualisiert.
    wo hast du das schema?
    wenn du die vscode settings meinst, habe ich dort das drin stehen (ausschnitt).
    das wirkt aber nur im editor. beim build prozess hat das keine auswirkungen
    Als schema habe ich
        "json.schemas": [
                "fileMatch": ["io-package.json"],
                "url": "https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/schemas/io-package.json"
                "fileMatch": ["admin/jsonConfig.json", "admin/jsonCustom.json", "admin/jsonTab.json"],
                "url": "https://raw.githubusercontent.com/ioBroker/adapter-react-v5/main/schemas/jsonConfig.json"
    verzeichnis widget löschen
    und in datei io-package.json
    bei dependencies vis entfernen
    was soll dieser schnipfel sagen, wahrscheinlich hängt das mit der dependency in package.json weiter unten zusammen.
    wann wird etwas nicht aktualisiert wenn du WAS machst?
    package.json und io-package.json wird nicht automatisch im dev-server aktualisiert
    da muss man dann mit dem dev-server upload machen.
    ansonsten werden alle anderen dateien eigentlich schon aktualisiert (admin, adapter und auch widget-dateien für vis, bei letzterem muss man aber noch was machen, aber das brauchst du ja nicht.)
    lokal auf der festplatte des erstellers. in der package.json siehst du ja die dependency
    diese zeigt auf die eigene festplatte. das macht man aus gründen der dynamischen entwicklung, wenn man separate repositories für bestimmte anteile verwendet. sollte beim publish aber aufgelöst werden, da das nie für andere funktionieren kann.
    Meine Adapter und Widgets
    Links im Profil
    • M MCU
      Als schema habe ich
      .devserver
      admin
          "version":"1.0.0",
          "private":true,
          "dependencies":{
          "dev-server":{
              "adminPort":8081,
              "useSymlinks":false
          "overrides":{
      Vielen Dank
      mcm1957M Offline
      mcm1957M Offline
      mcm1957
      @mcu
      Generell sind Fragen zur Entwicklung / Entwicklungsumgebung in unseren Telegram Channels (Invites unter hhtps://www.iobroker.dev) besser aufgehoben da sie dort Entwickeler gezielter erreichen.
      Inwieweit der dev-server zur Entwicklung von REACT taugt stell ich jetzt mal als Frage in den Raum. Wirkliche React Kenner gibt es nur seeehr wenige.
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      OliverIOO M 2 Antworten Letzte Antwort
      • mcm1957M mcm1957
        @mcu
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        @mcm1957
        Mit dem dev-Server kann man mit react entwickeln.
        Will er glaube ich auch nicht
        Links im Profil
        • OliverIOO OliverIO
          Als schema habe ich
              "json.schemas": [
          M Online
          M Online
          MCU
          @oliverio
          Zunächst ein großes Dankeschön für die ganzen Infos. Ich taste mich langsam ran.
          package,json
          trotzdem kommen die Warnungen / Errors
          Ich musste das $schema in der iopackage.json eintragen, sonst kam immer ein Fehler beim Adapter-Check
          Ich dachte, wenn ich z.B. das Icon im admin-Verzeichnis ändere, dass dann mit dev-server watch, das Icon auch im dev-server angepasst wird. Anscheinend ja nur mit dev-server upload. Muss ich jetzt mal alles probleren.
          Ok, aber die Datei wird wodurch erzeugt? Ich finde diese nicht.
          Wird durch das build erstellt
          • mcm1957M mcm1957
            @mcu
            M Online
            M Online
            MCU
            @mcm1957
            Ich will zunächst den Umgang mit Adapter-Entwicklung kennenlernen. Wenn dazu auch react notwendig ist, was ja auch in jarvis genutzt wird, werde ich dies auch versuchen.
            Den Telegram Channel werden ich nutzen, danke für die Info.
              @mcm1957
              M Online
              M Online
              MCU
              @oliverio react ist sicherlich auch irgendwann ein Thema. Aber erstmal eins nach dem anderen.
              • M MCU
                @oliverio
                package,json
                mcm1957M Offline
                mcm1957M Offline
                mcm1957
                @mcu said in Fehlermeldungen (dev-server) beim öffen der Config:
                $schema gehört definitiv NICHT in io-package.json. Schmeiß das wieder raus.
                Welchen Fehler lieferte der Adapter Checker?
                • OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  hab ich bei keinem meiner adapter gemacht
                  das dann mal auf dem discord-server mit den anderen abklären
                  wo liegt den die datei, die du da anschaust?
                  nein, wie geschrieben, das gehört zu den anteilen, die durch ein separaten dev-server upload befehl nur geändert werden können.
                  nimm discord, ich finde den komfortabler. da erscheinen auch alle nachrichten aus telegram und antworten werden wieder zurückgespielt
                  Links im Profil
                  M mcm1957M 2 Antworten Letzte Antwort
                  • mcm1957M mcm1957
                    M Online
                    M Online
                    MCU
                    @mcm1957
                    War nicht im Adapter-Check sondern im VSCode, hab da einige Sachen durcheinander gebracht.
                    Habs jetzt rausgenommen.
                    Danke.
                      M Online
                      M Online
                      MCU
                      @oliverio sagte in Fehlermeldungen (dev-server) beim öffen der Config:
                      Nur Join geklickt
                        mcm1957M Offline
                        mcm1957M Offline
                        mcm1957
                        @oliverio said in Fehlermeldungen (dev-server) beim öffen der Config:
                        $schema gehört definitiv nicht rein. Ich schätze das es um einen Fehler aus admin-ui geht (mangels Info schwer abschätzbar) und der Eintrag das Prüfschema überschreibt. Damit kriegt man dann auch Fehler weg.
                        Also Eintrag raus und Fehelrmeldung auf Telegramm posten.
                        watch überwacht primär die CODETEILE des Adapters. Die UI benötigt meist ein upload. Ob watch mittlerweile jsonConfig.json schon überwacht weiß ich nicht auswendig.
                        Nimm den Telegramm Channel. Die Core Entwickler sind in Telegramm und da ist alles zentral. :-) :-) :-)
                        Im Ernst - nimm das was du schon benutzt. Im Prinzip werden die Posts zwischen Telegramm in Discord gespiegelt - wenn der Bot nicht grad hängt. Wenn's dringend ist ist Telegramm der sicherere Weg wen zu erreichen. Aber Discord ist auch voll OK. Und wenn du dich dort wohlfühlst ists auch OK. Wenn du mal keien Antwort kriegst frag halt (auch) direkt in Telegramm. Ev. wurde was nicht weitergeleitet.
                        • M MCU
                          @mcm1957
                          Danke.
                          mcm1957M Offline
                          mcm1957M Offline
                          mcm1957
                          @mcm1957
                          Danke.
                          OK - müßte man auch schaun was genau gemeckert wurde :-)
                          Die Prüfschemas stehen da in settings.json (aber natürlich auch via gui pfelegbar).
                          Sollte in etwa so aussehen:
                              "eslint.enable": true,
                              "json.schemas": [
                                      "fileMatch": [
                                          "io-package.json"
                                      "fileMatch": [
                          • mcm1957M mcm1957
                            @mcm1957
                            Danke.
                                "json.schemas": [
                                        "fileMatch": [
                                            "io-package.json"
                                        "fileMatch": [
                            M Online
                            M Online
                            MCU
                            @mcm1957 Da stand bei mir
                            "json.schemas": [
                            			"url": "https://json.schemastore.org/io-package"
                            • M MCU
                              Nur Join geklickt
                              OliverIOO Offline
                              OliverIOO Offline
                              OliverIO
                              @mcu
                              Probier mal das
                              https://discord.gg/6gDAmWDt
                              Links im Profil
                                @mcu
                                Probier mal das
                                M Online
                                M Online
                                MCU
                                @oliverio Klappt. Danke.
