  3. Entwicklung
  4. Fehlermeldungen (dev-server) beim öffen der Config
    5.2k
28 Beiträge 6 Kommentatoren 2.6k Aufrufe 6 Beobachtet
  • Ben1983B Offline
    Ben1983B Offline
    Ben1983
    Hallo, wenn ich im dev-server den Adapter laufen lasse, bekomme ich seit heute folgende Fehlermeldungen beim Öffnen der Konfiguration des Adapters:
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/aliveProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/aliveProps" (strictTypes)
    strict mode: missing type "object" for keyword "required" at "#/definitions/qrCodeProps" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/qrCodeProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/qrCodeProps" (strictTypes)
    strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/cronProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/cronProps" (strictTypes)
    strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/0" (strictTypes)
    strict mode: required property "complex" is not defined at "#/definitions/cronProps/oneOf/0" (strictRequired)
    strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/1" (strictTypes)
    strict mode: required property "simple" is not defined at "#/definitions/cronProps/oneOf/1" (strictRequired)
    strict mode: missing type "object" for keyword "required" at "#/definitions/deviceManagerProps" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/deviceManagerProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/deviceManagerProps" (strictTypes)
    strict mode: missing type "object" for keyword "required" at "#" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#" (strictTypes)
    strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
    strict mode: use allowUnionTypes to allow union type keyword at "#/properties/width" (strictTypes)
    strict mode: required property "items" is not defined at "#/items/allOf/10/then/allOf/1/oneOf/0" (strictRequired)
    strict mode: required property "#include" is not defined at "#/items/allOf/10/then/allOf/1/oneOf/1" (strictRequired)
    strict mode: missing type "object" for keyword "required" at "#/definitions/aliveProps" (strictTypes)
    Ist da was am Schema angepasst worden?
    MartinPM OliverIOO 2 Antworten Letzte Antwort
    • Ben1983B Ben1983
      MartinPM Online
      MartinPM Online
      MartinP
      @ben1983 Sieht ja fast so aus, als ob da jemand untaugliche Auskommentierungen vorgenommen hat ;-)
      Ben1983B 2 Antworten Letzte Antwort
      • MartinPM MartinP
        Ben1983B Offline
        Ben1983B Offline
        Ben1983
        @martinp OK, ich wüsste aber bei mir nicht wo.
        Auch der Lint check ist ok
        • MartinPM MartinP
          Ben1983B Offline
          Ben1983B Offline
          Ben1983
          @martinp Also ich gehe mal ganz stark davon aus, dass es ein generelles schema problem ist, denn:
          Ich habe gerade einen anderen Adapter im dev-server gestartet, an dem ich schon ewig nichts geändert habe und da tritt es auch auf.
          • Ben1983B Ben1983
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            @ben1983
            das ist schon eine ganze weile so
            Meine Adapter und Widgets
            Links im Profil
            • OliverIOO OliverIO
              @ben1983
              Ben1983B Offline
              Ben1983B Offline
              Ben1983
              @oliverio OK. definiere ganze Weile.
              Letzte Woche war es zumindest bei mir definitiv noch nicht so.
              • Ben1983B Ben1983
                OliverIOO Offline
                OliverIOO Offline
                OliverIO
                @ben1983
                exakt weiß ich es nicht, aber mehrere monate sind es schon.
                ich habe das gefühl das es mit der build-kette react zu tun hat
                Links im Profil
                  @ben1983
                  Ben1983B Offline
                  Ben1983B Offline
                  Ben1983
                  @oliverio OK. Ich habe es jetzt mal ignoriert und einen neuen patch erzeugt.
                  OliverIOO mcm1957M 2 Antworten Letzte Antwort
                  • Ben1983B Ben1983
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    @ben1983
                    ja genau, so hab ich das auch gemacht.
                    ich habe auch gelernt das sich issue anlegen nicht lohnt, da es eh nicht bearbeitet wird bzw. einfach unbearbeitet geschlossen wird.
                    aber wahrscheinlich hab ich da einen fehler gemacht oder mich geirrt.
                    hatte zumindest auch was mit einem schema zu tun
                    Links im Profil
                    • Ben1983B Ben1983
                      mcm1957M Offline
                      mcm1957M Offline
                      mcm1957
                      @ben1983 said in Fehlermeldungen (dev-server) beim öffen der Config:
                      Hast du den Fehler nur mit dem dev-server oder auch der normale Adapter?
                      Wenn der Fehler auch bei einem normal installierten Adapter auftritt, geh dem Problem bite nach . Da stimmte dann entweder was bei deinem jsonConfig nicht oder es ist ein Fehler im Prüfschema. Falls Letzteres vermutet wird, mach bitte ein Issue auf (https://github.com/ioBroker/adapter-react-v5/issues/new/choose) und ignorier mal OliversIO's unqualifizierten Output. Keine Ahnung was ihm über die Leber gelaufen ist - wie man so schön sagt.
                      Support Repositoryverwaltung.
                      LESEN - gute Forenbeitrage
                        @ben1983
                        @oliverio
                        Dann hast Du leider was falsches gelernt. Unbearbeitet schließen kenne ich an sich nicht. Lange Bearbeitungsgebühr hängen von verschiedenen details ab und das generell zu diskutieren macht wenig Sinn.
                        • apollon77A apollon77
                          @oliverio
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          @apollon77
                          https://github.com/ioBroker/ioBroker.js-controller/issues/2818
                          Ich habe gesehen, mcm hat mittlerweile dann wohl den Issue bei vis2 erfasst..
                          Wie gesagt, issue schließen, ohne commit oder entsprechenden Kommentar fördert nicht unbedingt die Motivationen oder Mitarbeit der community
                          Wenn ein issue im falschen Repo ist, könnt ihr ihn ja auch verschieben.
                          Aber wie gesagt, wahrscheinlich hab ich was falsch gemacht
                          Links im Profil
                          • M Online
                            M Online
                            MCU
                            Ich hänge mich mal hier dran.
                            Versuche mal ein wenig mit dem dev-server.
                            Mir fehlt so ein wenig die Info, in welcher Datei was drin stehen muss damit es ohne Probleme läuft.
                            Meine Problemchen sind:
                            • auch wie oben beschrieben jede Menge an error-Anzeigen
                            2024-11-02 00:41:59.275  - debug: host.dev-jarvis-extensions-iobroker-dev Incoming Host message getHostInfo
                            strict mode: missing type "object" for keyword "properties" at "#/if" (strictTypes)
                            strict mode: required property "items" is not defined at "#/properties/items/patternProperties/%5E.%2B/allOf/9/then/oneOf/0" (strictRequired)
                            strict mode: required property "#include" is not defined at "#/properties/items/patternProperties/%5E.%2B/allOf/9/then/oneOf/1" (strictRequired)
                            strict mode: required property "items" is not defined at "#/patternProperties/%5E.%2B/allOf/9/then/oneOf/0" (strictRequired)
                            strict mode: required property "#include" is not defined at "#/patternProperties/%5E.%2B/allOf/9/then/oneOf/1" (strictRequired)
                            strict mode: missing type "object" for keyword "required" at "#/definitions/sendToProps" (strictTypes)
                            strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/sendToProps" (strictTypes)
                            strict mode: missing type "object" for keyword "properties" at "#/definitions/sendToProps" (strictTypes)
                            strict mode: missing type "object" for keyword "required" at "#/definitions/stateProps" (strictTypes)
                            strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/stateProps" (strictTypes)
                            strict mode: missing type "object" for keyword "properties" at "#/definitions/stateProps" (strictTypes)
                            strict mode: missing type "object" for keyword "required" at "#/definitions/passwordProps" (strictTypes)
                            strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/passwordProps" (strictTypes)
                            strict mode: missing type "object" for keyword "properties" at "#/definitions/passwordProps" (strictTypes)
                            strict mode: missing type "object" for keyword "required" at "#/definitions/checkboxProps" (strictTypes)
                            strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/checkboxProps" (strictTypes)
                            strict mode: missing type "object" for keyword "properties" at "#/definitions/checkboxProps" (strictTypes)
                            strict mode: missing type "object" for keyword "required" at "#/definitions/fileSelectorProps" (strictTypes)
                            strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/fileSelectorProps" (strictTypes)
                            strict mode: missing type "object" for keyword "properties" at "#/definitions/fileSelectorProps" (strictTypes)
                            strict mode: missing type "object" for keyword "required" at "#/definitions/numberProps" (strictTypes)
                            strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/numberProps" (strictTypes)
                            strict mode: missing type "object" for keyword "properties" at "#/definitions/numberProps" (strictTypes)
                            strict mode: required property "complex" is not defined at "#/items/allOf/21/then/oneOf/0" (strictRequired)
                            strict mode: required property "simple" is not defined at "#/items/allOf/21/then/oneOf/1" (strictRequired)
                            strict mode: missing type "object" for keyword "required" at "#/definitions/certificatesProps" (strictTypes)
                            strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/certificatesProps" (strictTypes)
                            strict mode: missing type "object" for keyword "properties" at "#/definitions/certificatesProps" (strictTypes)
                            strict mode: missing type "object" for keyword "required" at "#/definitions/instanceProps" (strictTypes)
                            strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/instanceProps" (strictTypes)
                            strict mode: missing type "object" for keyword "properties" at "#/definitions/instanceProps" (strictTypes)
                            strict mode: missing type "object" for keyword "required" at "#/definitions/objectIdProps" (strictTypes)
                            strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/objectIdProps" (strictTypes)
                            strict mode: missing type "object" for keyword "properties" at "#/definitions/objectIdProps" (strictTypes)
                            strict mode: missing type "object" for keyword "required" at "#/definitions/timePickerProps" (strictTypes)
                            strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/timePickerProps" (strictTypes)
                            strict mode: missing type "object" for keyword "properties" at "#/definitions/timePickerProps" (strictTypes)
                            strict mode: missing type "object" for keyword "required" at "#/definitions/coordinatesProps" (strictTypes)
                            strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/coordinatesProps" (strictTypes)
                            strict mode: missing type "object" for keyword "properties" at "#/definitions/coordinatesProps" (strictTypes)
                            strict mode: missing type "object" for keyword "required" at "#/definitions/interfaceProps" (strictTypes)
                            strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/interfaceProps" (strictTypes)
                            strict mode: missing type "object" for keyword "properties" at "#/definitions/interfaceProps" (strictTypes)
                            Als schema habe ich
                            "$schema": "http://json-schema.org/draft-07/schema#",
                            ist das richtig? oder muss da was anderes hinein?
                            https://github.com/ioBroker/adapter-react-v5/blob/main/schemas/jsonConfig.json
                            • habe beim Creator fälschlicherweise VIS angeklickt, jetzt bekomme ich den Fehler
                              -> wie bekomme ich den wieder weg? Möchte erstmal nicht mit / für VIS entwickeln
                              wo steht der entsprechende Eintrag in der io-package.json / package,json ?
                            2024-11-02 00:42:04.096  - error: host.dev-jarvis-extensions-iobroker-dev cannot call visUtils: Not exists
                            • Warum werden die Dateien im .devserver-Verzeichnis nicht aktualisiert? Bzw. wie werden sie dort aktualisiert?
                              Welcher Befehl muss genutzt werden?
                            .devserver
                            admin
                            ich ändere im admin-Verzeichnis und rufe dann dev-server watch im Adapter-Ordner auf.
                            • Wo finde ich die zugehörige Datei? dev-jarvis-extensions-iobroker-dev
                            startInstance system.adapter.jarvis-extensions.0 Adapter dependency not fulfilled on "dev-jarvis-extensions-iobroker-dev": required adapter "vis" not found!
                            /* es scheint mit der package.json im .devserver zusammenzuhängen */
                            /* package.json, dort muss der iobroker.vis-Eintrag sehr wahrscheinlich raus */
                                "name":"dev-server.jarvis-extensions",
                                "version":"1.0.0",
                                "private":true,
                                "dependencies":{
                                    "iobroker.admin":"latest",
                                    "iobroker.backitup":"3.0.26",
                                    "iobroker.jarvis-extensions":"file:../../iobroker.jarvis-extensions-0.0.1.tgz",
                                    "iobroker.js-controller":"latest",
                                    "iobroker.socketio":"6.7.1",
                                    "iobroker.vis":"1.5.6",
                                    "iobroker.web":"6.3.1",
                                    "iobroker.ws":"2.6.2"
                                "dev-server":{
                                    "adminPort":8081,
                                    "useSymlinks":false
                                "overrides":{
                                    "@iobroker/adapter-core":"^3.2.1"
                            /* irgendwie doch nicht */
                            system.adapter.jarvis-extensions.0 [sameHostDependency]: {"js-controller":">=3.3.22","vis":"*"}
                            Vielen Dank
                            • M MCU
                              Als schema habe ich
                              .devserver
                              admin
                                  "version":"1.0.0",
                                  "private":true,
                                  "dependencies":{
                                  "dev-server":{
                                      "adminPort":8081,
                                      "useSymlinks":false
                                  "overrides":{
                              Vielen Dank
                              OliverIOO Offline
                              OliverIOO Offline
                              OliverIO
                              ich versuche mal, soweit ich weiß
                              @mcu sagte in Fehlermeldungen (dev-server) beim öffen der Config:
                              die erscheinen nur bei der entwicklung, die kannst du ignorieren. ich glaube, die müssten weg sein, wenn m,an auf "@iobroker/adapter-core": "^3.2.2", aktualisiert.
                              wo hast du das schema?
                              wenn du die vscode settings meinst, habe ich dort das drin stehen (ausschnitt).
                              das wirkt aber nur im editor. beim build prozess hat das keine auswirkungen
                              Als schema habe ich
                                  "json.schemas": [
                                          "fileMatch": ["io-package.json"],
                                          "url": "https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/schemas/io-package.json"
                                          "fileMatch": ["admin/jsonConfig.json", "admin/jsonCustom.json", "admin/jsonTab.json"],
                                          "url": "https://raw.githubusercontent.com/ioBroker/adapter-react-v5/main/schemas/jsonConfig.json"
                              verzeichnis widget löschen
                              und in datei io-package.json
                              bei dependencies vis entfernen
                              was soll dieser schnipfel sagen, wahrscheinlich hängt das mit der dependency in package.json weiter unten zusammen.
                              wann wird etwas nicht aktualisiert wenn du WAS machst?
                              package.json und io-package.json wird nicht automatisch im dev-server aktualisiert
                              da muss man dann mit dem dev-server upload machen.
                              ansonsten werden alle anderen dateien eigentlich schon aktualisiert (admin, adapter und auch widget-dateien für vis, bei letzterem muss man aber noch was machen, aber das brauchst du ja nicht.)
                              lokal auf der festplatte des erstellers. in der package.json siehst du ja die dependency
                              diese zeigt auf die eigene festplatte. das macht man aus gründen der dynamischen entwicklung, wenn man separate repositories für bestimmte anteile verwendet. sollte beim publish aber aufgelöst werden, da das nie für andere funktionieren kann.
                              Links im Profil
                              • M MCU
                                Als schema habe ich
                                .devserver
                                admin
                                    "version":"1.0.0",
                                    "private":true,
                                    "dependencies":{
                                    "dev-server":{
                                        "adminPort":8081,
                                        "useSymlinks":false
                                    "overrides":{
                                Vielen Dank
                                mcm1957M Offline
                                mcm1957M Offline
                                mcm1957
                                @mcu
                                Generell sind Fragen zur Entwicklung / Entwicklungsumgebung in unseren Telegram Channels (Invites unter hhtps://www.iobroker.dev) besser aufgehoben da sie dort Entwickeler gezielter erreichen.
                                Inwieweit der dev-server zur Entwicklung von REACT taugt stell ich jetzt mal als Frage in den Raum. Wirkliche React Kenner gibt es nur seeehr wenige.
                                OliverIOO M 2 Antworten Letzte Antwort
                                • mcm1957M mcm1957
                                  @mcu
                                  OliverIOO Offline
                                  OliverIOO Offline
                                  OliverIO
                                  @mcm1957
                                  Mit dem dev-Server kann man mit react entwickeln.
                                  Will er glaube ich auch nicht
                                  Links im Profil
                                    Als schema habe ich
                                        "json.schemas": [
                                    M Online
                                    M Online
                                    MCU
                                    @oliverio
                                    Zunächst ein großes Dankeschön für die ganzen Infos. Ich taste mich langsam ran.
                                    package,json
                                    trotzdem kommen die Warnungen / Errors
                                    Ich musste das $schema in der iopackage.json eintragen, sonst kam immer ein Fehler beim Adapter-Check
                                    Ich dachte, wenn ich z.B. das Icon im admin-Verzeichnis ändere, dass dann mit dev-server watch, das Icon auch im dev-server angepasst wird. Anscheinend ja nur mit dev-server upload. Muss ich jetzt mal alles probleren.
                                    Ok, aber die Datei wird wodurch erzeugt? Ich finde diese nicht.
                                    Wird durch das build erstellt
                                    • mcm1957M mcm1957
                                      @mcu
                                      M Online
                                      M Online
                                      MCU
                                      @mcm1957
                                      Ich will zunächst den Umgang mit Adapter-Entwicklung kennenlernen. Wenn dazu auch react notwendig ist, was ja auch in jarvis genutzt wird, werde ich dies auch versuchen.
                                      Den Telegram Channel werden ich nutzen, danke für die Info.
                                        @mcm1957
                                        M Online
                                        M Online
                                        MCU
                                        @oliverio react ist sicherlich auch irgendwann ein Thema. Aber erstmal eins nach dem anderen.
                                        • M MCU
                                          @oliverio
                                          package,json
                                          mcm1957M Offline
                                          mcm1957M Offline
                                          mcm1957
                                          @mcu said in Fehlermeldungen (dev-server) beim öffen der Config:
                                          $schema gehört definitiv NICHT in io-package.json. Schmeiß das wieder raus.
                                          Welchen Fehler lieferte der Adapter Checker?
