  3. Cloud Dienste
  4. Cloud Adapter nicht erreichbar
    6.4k
24 Beiträge 5 Kommentatoren 3.4k Aufrufe 4 Beobachtet
  • mcm1957M mcm1957
    @siggi25
    Poste mal
    • die LANGFASSUNG von iob diag (in code tags).
    • die genaue Fehlermelung im log
    Und check mal ob deine Internetverbindung (vom iob host aus) ok ist.
    siggi25
    @mcm1957
      v.2024-05-22
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.12-1-pve
        Architecture: x86-64
    Installation:           lxc
    Kernel:                 x86_64
    Userland:               64 bit
    User-ID:                0
    Display-Server:         false
    Pending OS-Updates:     2
    Cannot download repository hash file from "http://download.iobroker.net/sources-dist-latest-hash.json": timeout of 10000ms exceeded
    Cannot download repository file from "http://download.iobroker.net/sources-dist-latest.json": timeout of 10000ms exceeded
    Pending iob updates:    0
    Nodejs-Installation:
    /usr/bin/nodejs         v20.17.0
    /usr/bin/node           v20.17.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.3
    Recommended versions are nodejs 20.17.0 and npm 10.8.2
    MEMORY:
    Mem:             10G        2.3G        7.7G        102K        767M        8.5G
    Swap:           536M          0B        536M
    Total:           11G        2.3G        8.2G
    Active iob-Instances:   23
    Upgrade policy: none
    ioBroker Core:          js-controller           6.0.11
                            admin                   7.1.0
    Objects type: jsonl
    States  type: jsonl
    Objects:                24302
    States:                 18542
    Size of iob-Database:
    39M     /opt/iobroker/iobroker-data/objects.jsonl
    4.4M    /opt/iobroker/iobroker-data/states.jsonl
    iobroker diag funktioniert nicht kann die Diagnose nicht senden Fehler im iobroker
    2024-09-14 20:07:26.112 - error: cloud.0 (956) Error while connecting to cloud: Error: websocket error
    2024-09-14 20:07:39.354 - error: iot.0 (1468) Error by device connection: {"code":"ETIMEDOUT"}
    2024-09-14 20:07:39.355 - info: iot.0 (1468) Connection changed: disconnect
    2024-09-14 20:08:25.546 - info: cloud.0 (956) Trying to connect as system.user.admin to cloud
    2024-09-14 20:08:25.815 - error: cloud.0 (956) Error while connecting to cloud: Error: websocket error
    2024-09-14 20:09:01.382 - error: iot.0 (1468) Error by device connection: {"code":"ETIMEDOUT"}
    Der cloud Adapter ist manchmal für kurze Zeit online die Verbindung bricht aber immer wieder ab., was kann ich da tun
    • S siggi25
      @mcm1957
        v.2024-05-22
        Virtualization: lxc
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               64 bit
      User-ID:                0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      MEMORY:
      Swap:           536M          0B        536M
                              admin                   7.1.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                24302
      States:                 18542
      @siggi25 das ist doch nicht die Langfassung!
      da fehlt einiges
        da fehlt einiges
        siggi25
        wie bekomme ich das komplette script herein in den post
        • S siggi25
          @siggi25 sagte in Cloud Adapter nicht erreichbar:
          Komplett markieren (dazu dienen die Kennzeichnungen in der Ausgabe), dann hier einfügen.
            siggi25
            Skript v.2024-05-22
            *** BASE SYSTEM ***
              Virtualization: lxc
            model name      : Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz
            Docker          : false
            Virtualization  : lxc
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             20:33:36 up 35 min,  2 users,  load average: 0.12, 0.23, 0.24
            CPU threads: 4
            *** Time and Time Zones ***
                           Local time: Sat 2024-09-14 20:33:36 CEST
                       Universal time: Sat 2024-09-14 18:33:36 UTC
                             RTC time: n/a
                          NTP service: inactive
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            root
            HOME=/root
            GROUPS=root
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev
            *** Display-Server-Setup ***
            Desktop:
            Terminal:
            *** MEMORY ***
            Mem:             10G        2.4G        7.6G        110K        773M        8.4G
            Swap:           536M          0B        536M
            Total:           11G        2.4G        8.1G
            Active iob-Instances:   31
                    10240 M total memory
                     2271 M used memory
                     2237 M active memory
                      594 M inactive memory
                     7230 M free memory
                        0 M buffer memory
                      738 M swap cache
                      512 M total swap
                        0 M used swap
                      512 M free swap
            top - 20:33:36 up 35 min,  2 users,  load average: 0.12, 0.23, 0.24
            Tasks:  56 total,   1 running,  55 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :  10240.0 total,   7229.2 free,   2272.9 used,    738.1 buff/cache
            MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7967.1 avail Mem
            *** FAILED SERVICES ***
              UNIT               LOAD   ACTIVE SUB    DESCRIPTION
            * networking.service loaded failed failed Raise network interfaces
            1 loaded units listed.
            *** FILESYSTEM ***
            Filesystem                       Type   Size  Used Avail Use% Mounted on
            /dev/mapper/pve-vm--100--disk--1 ext4    63G   11G   49G  18% /
            none                             tmpfs  492K  4.0K  488K   1% /dev
            tmpfs                            tmpfs  7.7G     0  7.7G   0% /dev/shm
            tmpfs                            tmpfs  3.1G  104K  3.1G   1% /run
            tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
            [Sat Sep 14 10:25:57 2024] EXT4-fs (dm-1): mounted filesystem d9fd98c6-824d-40e5-a7d6-446096448298 ro with ordered data mode. Quota mode: none.
            [Sat Sep 14 10:25:57 2024] EXT4-fs (dm-1): re-mounted d9fd98c6-824d-40e5-a7d6-446096448298 r/w. Quota mode: none.
            [Sat Sep 14 10:26:05 2024] EXT4-fs (dm-9): mounted filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f r/w with ordered data mode. Quota mode: none.
            [Sat Sep 14 10:42:52 2024] EXT4-fs (dm-9): unmounting filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f.
            [Sat Sep 14 10:42:58 2024] EXT4-fs (dm-9): mounted filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f r/w with ordered data mode. Quota mode: none.
            [Sat Sep 14 11:01:25 2024] EXT4-fs (dm-9): unmounting filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f.
            [Sat Sep 14 11:01:36 2024] EXT4-fs (dm-9): mounted filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f r/w with ordered data mode. Quota mode: none.
            [Sat Sep 14 19:23:45 2024] EXT4-fs (dm-9): unmounting filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f.
            [Sat Sep 14 19:23:49 2024] EXT4-fs (dm-9): mounted filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f r/w with ordered data mode. Quota mode: none.
            [Sat Sep 14 19:24:16 2024] EXT4-fs (dm-11): mounted filesystem c49b7add-f631-4847-a7d4-926e242cf401 r/w with ordered data mode. Quota mode: none.
            [Sat Sep 14 19:26:38 2024] EXT4-fs (dm-11): unmounting filesystem c49b7add-f631-4847-a7d4-926e242cf401.
            [Sat Sep 14 19:27:28 2024] EXT4-fs (dm-11): mounted filesystem c49b7add-f631-4847-a7d4-926e242cf401 r/w with ordered data mode. Quota mode: none.
            [Sat Sep 14 19:27:58 2024] EXT4-fs (dm-11): unmounting filesystem c49b7add-f631-4847-a7d4-926e242cf401.
            [Sat Sep 14 19:55:25 2024] EXT4-fs (dm-9): unmounting filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f.
            [Sat Sep 14 19:57:40 2024] EXT4-fs (dm-9): mounted filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f r/w with ordered data mode. Quota mode: none.
            Show mounted filesystems:
            TARGET                                                  SOURCE                           FSTYPE     OPTIONS
            /                                                       /dev/mapper/pve-vm--100--disk--1 ext4       rw,relatime,stripe=32
            |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=3217104k,nr_inodes=819200,mode=755,inode64
            | |-/run/lock                                           tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
            | |-/run/rpc_pipefs                                     sunrpc                           rpc_pipefs rw,relatime
            | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
            | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
            | |-/run/credentials/systemd-sysctl.service             ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
            | `-/run/credentials/systemd-sysusers.service           ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
            |-/dev                                                  none                             tmpfs      rw,relatime,size=492k,mode=755,inode64
            | |-/dev/shm                                            tmpfs                            tmpfs      rw,nosuid,nodev,inode64
            | |-/dev/mqueue                                         mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
            | |-/dev/hugepages                                      hugetlbfs                        hugetlbfs  rw,relatime,pagesize=2M
            | |-/dev/.lxc/proc                                      proc                             proc       rw,relatime
            | |-/dev/.lxc/sys                                       sys                              sysfs      rw,relatime
            | |-/dev/pts                                            devpts                           devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
            | |-/dev/ptmx                                           devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
            | |-/dev/console                                        devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
            | |-/dev/tty1                                           devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
            | `-/dev/tty2                                           devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
            |-/proc                                                 proc                             proc       rw,nosuid,nodev,noexec,relatime
            | |-/proc/sys                                           proc[/sys]                       proc       ro,relatime
            | | |-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,inode64
            | | `-/proc/sys/net                                     proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
            | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]             proc       ro,relatime
            | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/diskstats                                     lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/loadavg                                       lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/meminfo                                       lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/stat                                          lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/swaps                                         lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | `-/proc/uptime                                        lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            `-/sys                                                  sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
              |-/sys/fs/fuse/connections                            fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
              |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
              |-/sys/fs/cgroup                                      none                             cgroup2    rw,nosuid,nodev,noexec,relatime
              `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            /var:
            821M    /var/
            341M    /var/log
            340M    /var/log/journal/8c4501404c6148fea043b969672b388d
            334M    /var/cache
            Archived and active journals take up 339.5M in the file system.
            /opt/iobroker/backups:
            339M    /opt/iobroker/backups/
            4.0K    /opt/iobroker/backups/redistmp
            /opt/iobroker/iobroker-data:
            1.7G    /opt/iobroker/iobroker-data/
            1.5G    /opt/iobroker/iobroker-data/files
            617M    /opt/iobroker/iobroker-data/files/javascript.admin
            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
            37M     /opt/iobroker/iobroker-data/objects.jsonl
            35M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.be60e800.js.map
            35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
            24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
            USB-Devices by-id:
            No Devices found 'by-id'
            HINT:
            Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
            tcp
            *** NodeJS-Installation ***
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Installed: 20.17.0-1nodesource1
              Candidate: 20.17.0-1nodesource1
              Version table:
             *** 20.17.0-1nodesource1 600
                    500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                 20.16.0-1nodesource1 600
                 20.15.1-1nodesource1 600
                 20.15.0-1nodesource1 600
                 20.14.0-1nodesource1 600
                 20.13.1-1nodesource1 600
                 20.13.0-1nodesource1 600
                 20.12.2-1nodesource1 600
                 20.12.1-1nodesource1 600
                 20.12.0-1nodesource1 600
                 20.11.1-1nodesource1 600
                 20.11.0-1nodesource1 600
                 20.10.0-1nodesource1 600
                 20.9.0-1nodesource1 600
                 20.8.1-1nodesource1 600
                 20.8.0-1nodesource1 600
                 20.7.0-1nodesource1 600
                 20.6.1-1nodesource1 600
                 20.6.0-1nodesource1 600
                 20.5.1-1nodesource1 600
                 20.5.0-1nodesource1 600
                 20.4.0-1nodesource1 600
                 20.3.1-1nodesource1 600
                 20.3.0-1nodesource1 600
                 20.2.0-1nodesource1 600
                 20.1.0-1nodesource1 600
                 20.0.0-1nodesource1 600
                 18.19.0+dfsg-6~deb12u2 500
                    500 http://deb.debian.org/debian bookworm/main amd64 Packages
                 18.19.0+dfsg-6~deb12u1 500
                    500 http://security.debian.org bookworm-security/main amd64 Packages
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  6.0.11
            admin:          7.1.0
            javascript:     8.8.3
            nodejs modules from github:     2
            +-- iobroker.energiefluss@3.6.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#53944cad71449ceaa41c275f432df5423f218054)
            +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
            Adapter State
            + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
              system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
              system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
              system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
            + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
            + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 80
              system.adapter.devices.0                : devices               : iobroker                                 - disabled
            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
              system.adapter.dwd.0                    : dwd                   : iobroker                                 - disabled
            + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
            + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
              system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 - disabled
            + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
              system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
            + system.adapter.history.0                : history               : iobroker                                 -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
            + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 42010
            + system.adapter.homekit-controller.0     : homekit-controller    : iobroker                                 -  enabled
            + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
              system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
              system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
              system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
              system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
              system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
            + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
            + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
              system.adapter.iqontrol.0               : iqontrol              : iobroker                                 - disabled
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
              system.adapter.lgtv11.0                 : lgtv11                : iobroker                                 - disabled, port: 8080
              system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 - disabled
              system.adapter.material.0               : material              : iobroker                                 - disabled
              system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, port: 54321
              system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 - disabled, port: 54321
              system.adapter.minuvis.0                : minuvis               : iobroker                                 - disabled
              system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
            + system.adapter.myvbus.0                 : myvbus                : iobroker                                 -  enabled
              system.adapter.onvif.0                  : onvif                 : iobroker                                 - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
            + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
              system.adapter.resol.0                  : resol                 : iobroker                                 - disabled
              system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled
              system.adapter.senec.0                  : senec                 : iobroker                                 - disabled
            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 192.168.0.139
              system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 - disabled
            + system.adapter.tedee.0                  : tedee                 : iobroker                                 -  enabled
              system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
            + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
              system.adapter.text2command.0           : text2command          : iobroker                                 - disabled
            + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
              system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
              system.adapter.tuya.0                   : tuya                  : iobroker                                 - disabled
              system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 - disabled
              system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
              system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: iobroker                                 -  enabled
            + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
              system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
              system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
              system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
              system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 - disabled
              system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
              system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
              system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
              system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
              system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
            + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
              system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: tcp://192.168.0.117:6638
            + instance is alive
            ioBroker-Repositories
            Active repo(s): beta
            Installed ioBroker-Instances
            Used repository: beta
            Adapter    "admin"        : 7.1.0    , installed 7.1.0
            Adapter    "alarm"        : 3.6.2    , installed 3.6.2
            Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
            Adapter    "alias-manager": 1.2.6    , installed 1.2.6
            Adapter    "backitup"     : 3.0.22   , installed 3.0.22
            Adapter    "deconz"       : 1.4.1    , installed 1.4.1
            Adapter    "devices"      : 1.1.5    , installed 1.1.5
            Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
            Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
            Adapter    "fronius"      : 2.1.1    , installed 2.1.1
            Adapter    "fronius-solarweb": 0.1.0 , installed 0.1.0
            Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
            Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
            Adapter    "homekit-controller": 0.5.10, installed 0.5.10
            Adapter    "hue"          : 3.12.0   , installed 3.12.0
            Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
            Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
            Adapter    "iot"          : 3.4.0    , installed 3.4.0
            Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
            Controller "js-controller": 6.0.11   , installed 6.0.11
            Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
            Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
            Adapter    "material"     : 1.3.1    , installed 1.3.1
            Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
            Adapter    "minuvis"      : 2.3.3    , installed 2.3.3
            Adapter    "modbus"       : 6.3.2    , installed 6.3.2
            Adapter    "myvbus"       : 0.4.0    , installed 0.4.0
            Adapter    "onvif"        : 1.1.4    , installed 1.1.4
            Adapter    "ping"         : 1.7.3    , installed 1.7.3
            Adapter    "resol"        : 1.3.0    , installed 1.3.0
            Adapter    "sayit"        : 5.0.0    , installed 5.0.0
            Adapter    "senec"        : 1.6.14   , installed 1.6.14
            Adapter    "shelly"       : 8.1.1    , installed 8.1.1
            Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
            Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
            Adapter    "tedee"        : 0.3.2    , installed 0.3.2
            Adapter    "telegram"     : 3.9.0    , installed 3.9.0
            Adapter    "terminal"     : 1.0.0    , installed 1.0.0
            Adapter    "text2command" : 3.0.3    , installed 3.0.3
            Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
            Adapter    "tuya"         : 3.16.0   , installed 3.16.0
            Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
            Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
            Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
            Adapter    "vis-2-widgets-weather-and-heating": 0.7.0, installed 0.7.0
            Adapter    "vis-icontwo"  : 1.6.3    , installed 1.6.3
            Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
            Adapter    "vis-material" : 0.1.3    , installed 0.1.3
            Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
            Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
            Adapter    "web"          : 6.3.0    , installed 6.3.0
            Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
            Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
            Objects and States
            Objects:        24302
            States:         18494
            Hit:2 http://security.debian.org bookworm-security InRelease
            Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
            Reading package lists...
            Pending Updates: 2
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1612848    161/iobroker.js-con
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1607658    161/iobroker.js-con
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1597892    1/init
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1609629    324/master
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       1615477    797/io.shelly.1
            tcp        0      0 192.168.0.139:1886      0.0.0.0:*               LISTEN      1000       1616517    835/io.sonoff.0
            tcp        0      0 192.168.0.139:42010     0.0.0.0:*               LISTEN      1000       1618012    690/io.hm-rpc.1
            tcp6       0      0 :::22                   :::*                    LISTEN      0          1601033    1/init
            tcp6       0      0 :::111                  :::*                    LISTEN      0          1600937    1/init
            tcp6       0      0 :::29170                :::*                    LISTEN      1000       1616620    899/io.tedee.0
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1609630    324/master
            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1608546    430/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1626372    1847/io.web.0
            tcp6       0      0 :::8084                 :::*                    LISTEN      1000       1623978    1862/io.socketio.0
            tcp6       0      0 :::8087                 :::*                    LISTEN      1000       1620727    1494/io.simple-api.
            tcp6       0      0 :::8088                 :::*                    LISTEN      1000       1624240    1509/io.terminal.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1618484    1074/io.homekit-con
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       1618119    771/io.shelly.0
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1597893    1/init
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       1616164    586/io.deconz.0
            udp6       0      0 :::111                  :::*                                0          1597894    1/init
            udp6       0      0 :::1900                 :::*                                1000       1616166    586/io.deconz.0
            udp6       0      0 :::1900                 :::*                                1000       1616165    586/io.deconz.0
            2024-09-14 20:17:25.805  - error: cloud.0 (956) Error while connecting to cloud: Error: websocket error
            2024-09-14 20:17:41.503  - error: iot.0 (1468) Error by device connection: {"code":"ETIMEDOUT"}
            2024-09-14 20:17:41.503  - info: iot.0 (1468) Connection changed: disconnect
            2024-09-14 20:18:25.550  - info: cloud.0 (956) Trying to connect as system.user.admin to cloud
            2024-09-14 20:18:25.805  - error: cloud.0 (956) Error while connecting to cloud: Error: websocket error
            2024-09-14 20:19:25.550  - info: cloud.0 (956) Trying to connect as system.user.admin to cloud
            2024-09-14 20:19:25.763  - info: cloud.0 (956) Connection changed: connect
            2024-09-14 20:19:49.730  - info: iot.0 (1468) Connection changed: connect "g_oppel_web_de"
            2024-09-14 20:25:05.767  - error: cloud.0 (956) Ping timeout
            2024-09-14 20:25:11.814  - info: homekit-controller.0 (1074) IP-0B:C9:1D:29:14:8F (LG webOS TV 70CD) found without known pairing data and already paired: ignoring
            2024-09-14 20:25:12.908  - info: homekit-controller.0 (1074) IP-0B:C9:1D:29:14:8F (LG webOS TV 70CD) found without known pairing data and already paired: ignoring
            2024-09-14 20:26:05.772  - info: cloud.0 (956) Trying to connect as system.user.admin to cloud
            2024-09-14 20:26:05.904  - info: cloud.0 (956) Connection changed: connect
            • S siggi25
              Skript v.2024-05-22
              *** BASE SYSTEM ***
                Virtualization: lxc
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
              CPU threads: 4
                               RTC time: n/a
                        RTC in local TZ: no
              root
              HOME=/root
              GROUPS=root
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:
              *** MEMORY ***
              Swap:           536M          0B        536M
                       2271 M used memory
                       7230 M free memory
                          0 M buffer memory
                        738 M swap cache
                        512 M total swap
                          0 M used swap
                        512 M free swap
              *** FILESYSTEM ***
              /var:
              821M    /var/
              341M    /var/log
              334M    /var/cache
              USB-Devices by-id:
              HINT:
              tcp
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          7.1.0
              javascript:     8.8.3
              Adapter State
              + instance is alive
              Objects and States
              Objects:        24302
              States:         18494
              Pending Updates: 2
              root
              Auch in einem LXC wird nicht als root hantiert. Leg dir einen Standarduser an.
              Mit deinem Netzwerk-Setup stimmt wohl was nicht.
              S HomoranH 2 Antworten Letzte Antwort
                root
                siggi25
                Wie kann ich herausfinden, was nicht stimmt
                vielen DAnk
                • S siggi25
                  vielen DAnk
                  Zuerst nicht als root herumhampeln.
                    siggi25
                    habe mich schon mit meinem Benutzer eingeloggt
                    • S siggi25
                      @siggi25
                      Und warum nicht sofort? Man meldet sich einfach NIE, NIE, NIE als root an.
                      Starte den Container neu und dann nochmal die vollständige Ausgabe von
                      iob diag
                      Und diesmal kopierst du bitte die Steuerzeichen für die Codetags mit. Dann kann man das auch besser lesen.
                        root
                        @thomas-braun sagte in Cloud Adapter nicht erreichbar:
                        das passt auch zu
                          das passt auch zu
                          Soweit hatte ich gar nicht mehr gelesen.
                          Bei root shell war es eigentlich schon durch.
                            siggi25
                            hier der neue post
                            Skript v.2024-05-22
                            *** BASE SYSTEM ***
                              Virtualization: lxc
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                             21:28:12 up 6 min,  2 users,  load average: 0.70, 0.47, 0.38
                            CPU threads: 4
                                           Local time: Sat 2024-09-14 21:28:12 CEST
                                       Universal time: Sat 2024-09-14 19:28:12 UTC
                                             RTC time: n/a
                                      RTC in local TZ: no
                            goppel
                            HOME=/home/goppel
                            GROUPS=goppel sudo users iobroker
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:
                            *** MEMORY ***
                            Mem:             10G        1.5G        8.9G        114K        350M        9.3G
                            Swap:           536M          0B        536M
                            Total:           11G        1.5G        9.5G
                            Active iob-Instances:   15
                                     1396 M used memory
                                     1492 M active memory
                                      164 M inactive memory
                                     8509 M free memory
                                        0 M buffer memory
                                      334 M swap cache
                                      512 M total swap
                                        0 M used swap
                                      512 M free swap
                            top - 21:28:13 up 6 min,  2 users,  load average: 0.70, 0.47, 0.38
                            Tasks:  41 total,   2 running,  39 sleeping,   0 stopped,   0 zombie
                            MiB Mem :  10240.0 total,   8504.0 free,   1401.6 used,    334.5 buff/cache
                            MiB Swap:    512.0 total,    512.0 free,      0.0 used.   8838.4 avail Mem
                            *** FILESYSTEM ***
                            /dev/mapper/pve-vm--100--disk--1 ext4    63G   11G   49G  19% /
                            tmpfs                            tmpfs  3.1G  108K  3.1G   1% /run
                            [Sat Sep 14 21:22:07 2024] EXT4-fs (dm-9): unmounting filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f.
                            [Sat Sep 14 21:22:07 2024] EXT4-fs (dm-9): mounted filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f r/w with ordered data mode. Quota mode: none.
                            /var:
                            845M    /var/
                            365M    /var/log
                            364M    /var/log/journal/8c4501404c6148fea043b969672b388d
                            334M    /var/cache
                            Archived and active journals take up 28.6M in the file system.
                            42M     /opt/iobroker/iobroker-data/objects.jsonl
                            USB-Devices by-id:
                            HINT:
                            tcp
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          7.1.0
                            javascript:     8.8.3
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        24304
                            States:         18441
                            Pending Updates: 2
                            tcp        0      0 192.168.0.139:1886      0.0.0.0:*               LISTEN      1000       1897625    655/io.sonoff.0
                            tcp        0      0 192.168.0.139:42010     0.0.0.0:*               LISTEN      1000       1891943    510/io.hm-rpc.1
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1876529    1/init
                            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       1895031    612/io.shelly.1
                            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1887923    328/master
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1888055    165/iobroker.js-con
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1889254    165/iobroker.js-con
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          1876530    1/init
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          1877864    1/init
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1891141    339/io.admin.0
                            tcp6       0      0 :::29170                :::*                    LISTEN      1000       1897869    909/io.tedee.0
                            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1887924    328/master
                            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       1896713    558/io.shelly.0
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1877773    1/init
                            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       1891262    440/io.deconz.0
                            udp6       0      0 :::111                  :::*                                0          1876531    1/init
                            udp6       0      0 :::1900                 :::*                                1000       1891264    440/io.deconz.0
                            udp6       0      0 :::1900                 :::*                                1000       1891263    440/io.deconz.0
                            2024-09-14 21:28:21.605  - info: cloud.0 (975) Connection changed: disconnect
                            2024-09-14 21:28:24.476  - info: host.iobroker instance system.adapter.discovery.0 in version "5.0.0" started with pid 1004
                            2024-09-14 21:28:24.664  - info: shelly.1 (612) [MQTT] Device with client id "shellypro1-30c6f7814ca8" connected!
                            2024-09-14 21:28:25.198  - info: discovery.0 (1004) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
                            2024-09-14 21:28:28.572  - info: host.iobroker instance system.adapter.energiefluss.0 in version "3.6.0" (non-npm: SKB-CGN/ioBroker.energiefluss#53944cad71449ceaa41c275f432df5423f218054) started with pid 1051
                            2024-09-14 21:28:29.267  - info: energiefluss.0 (1051) starting. Version 3.6.0 (non-npm: SKB-CGN/ioBroker.energiefluss#53944cad71449ceaa41c275f432df5423f218054) in /opt/iobroker/node_modules/iobroker.energiefluss, node: v20.17.0, js-controller: 6.0.11
                            2024-09-14 21:28:29.273  - info: energiefluss.0 (1051) Starting Energiefluss Adapter
                            2024-09-14 21:28:29.324  - warn: energiefluss.0 (1051) The adapter could not find the state shelly.1.SHSW-25#8CAAB55517CD#1.Relay1.Power! Please review your configuration of the adapter!
                            2024-09-14 21:28:29.325  - warn: energiefluss.0 (1051) The adapter could not find the state sonoff.0.Kuehlschrank .ENERGY_Power! Please review your configuration of the adapter!
                            2024-09-14 21:28:29.326  - warn: energiefluss.0 (1051) The adapter could not find the state hm-rpc.1.0001D3C99C7EDA.6! Please review your configuration of the adapter!
                            2024-09-14 21:28:29.327  - info: energiefluss.0 (1051) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
                            2024-09-14 21:28:29.328  - info: energiefluss.0 (1051) Adapter started and listening to 13 States
                            2024-09-14 21:28:32.468  - info: host.iobroker instance system.adapter.homekit-controller.0 in version "0.5.10" started with pid 1625
                            MOD-EDIT :Code in code-tags gesetzt!
                            • S siggi25
                              hier der neue post
                              Skript v.2024-05-22
                              *** BASE SYSTEM ***
                                Virtualization: lxc
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                              CPU threads: 4
                                               RTC time: n/a
                                        RTC in local TZ: no
                              goppel
                              HOME=/home/goppel
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:
                              *** MEMORY ***
                              Swap:           536M          0B        536M
                                       1396 M used memory
                                       8509 M free memory
                                          0 M buffer memory
                                        334 M swap cache
                                        512 M total swap
                                          0 M used swap
                                        512 M free swap
                              *** FILESYSTEM ***
                              /var:
                              845M    /var/
                              365M    /var/log
                              334M    /var/cache
                              USB-Devices by-id:
                              HINT:
                              tcp
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          7.1.0
                              javascript:     8.8.3
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        24304
                              States:         18441
                              Pending Updates: 2
                              @siggi25
                              systemctl status networking.service
                              spuckt was aus?
                                @siggi25
                                spuckt was aus?
                                siggi25
                                @thomas-braun said in Cloud Adapter nicht erreichbar:
                                === Mark text until here for copying ===
                                goppel@iobroker:~$ systemctl status networking.service
                                x networking.service - Raise network interfaces
                                     Loaded: loaded (/lib/systemd/system/networking.service; enabled; preset: enabled)
                                     Active: failed (Result: timeout) since Sat 2024-09-14 21:27:10 CEST; 6min ago
                                       Docs: man:interfaces(5)
                                    Process: 68 ExecStart=/sbin/ifup -a --read-environment (code=exited, status=1/FAILU>
                                    Process: 164 ExecStopPost=/usr/bin/touch /run/network/restart-hotplug (code=exited,>
                                   Main PID: 68 (code=exited, status=1/FAILURE)
                                        CPU: 66ms
                                Warning: some journal files were not opened due to insufficient permissions.
                                Samson71S Thomas BraunT 2 Antworten Letzte Antwort
                                • S siggi25
                                          CPU: 66ms
                                  Samson71S Offline
                                  Samson71S Offline
                                  Samson71
                                  @siggi25
                                  Sind Code-Tags (</>) wirklich so schwer zu benutzen?
                                  Markus
                                  Bitte beachten:
                                  • S siggi25
                                            CPU: 66ms
                                    Setz den user 'goppel' in die Gruppe 'adm' rein.
                                    sudo usermod -aG adm goppel
                                    exit
                                      exit
                                      siggi25
                                      habe ich gemacht
                                      • S siggi25
                                        habe ich gemacht
                                        @siggi25
                                        Dann nochmal
                                          @siggi25
                                          Dann nochmal
                                          siggi25
                                          permitted by applicable law.
                                          Last login: Sat Sep 14 21:27:39 CEST 2024 on tty1
                                               Active: failed (Result: timeout) since Sat 2024-09-14 21:27:10 CEST; 25min ago
                                              Process: 68 ExecStart=/sbin/ifup -a --read-environment (code=exited, status=1/FAILURE)
                                              Process: 164 ExecStopPost=/usr/bin/touch /run/network/restart-hotplug (code=exited, status=0/SUCCESS)
                                                  CPU: 66ms
                                          Sep 14 21:26:44 iobroker ifup[157]: XMT:  | X-- Request renew in  +3600
                                          Sep 14 21:26:44 iobroker ifup[157]: XMT:  | X-- Request rebind in +5400
                                          Sep 14 21:26:44 iobroker ifup[157]: XMT: Solicit on eth0, interval 128150ms.
                                          Sep 14 21:26:44 iobroker dhclient[157]: XMT: Solicit on eth0, interval 128150ms.
                                          Sep 14 21:27:10 iobroker systemd[1]: networking.service: start operation timed out. Terminating.
                                          Sep 14 21:27:10 iobroker systemd[1]: networking.service: Main process exited, code=exited, status=1/FAILURE
                                          Sep 14 21:27:10 iobroker ifup[68]: Got signal Terminated, terminating...
                                          Sep 14 21:27:10 iobroker ifup[68]: ifup: failed to bring up eth0
                                          Sep 14 21:27:10 iobroker systemd[1]: networking.service: Failed with result 'timeout'.
                                          Sep 14 21:27:10 iobroker systemd[1]: Failed to start networking.service - Raise network interfaces.
