  4. Icon mit Farbe je nach Temperatur-Wert eines Sensors
    5.9k
23 Beiträge 4 Kommentatoren 3.5k Aufrufe
    Warum nimmst du nicht das Widget Basic value list HTML?
    Ok, ich weiß nicht, ob du da für die Beschriftung auf die Werte eines Datenpunkts zugreifen kannst.
    Auf jeden Fall kannst Du da die Farbe nach Zustand ändern.
    Werde das aber mal mit deinem valve Widget testen. Dauert aber was am Tablet.
      Bei mir klappt es mit der Farbe des Icons.
      War allerdings faul und habe nicht zu viel eingetragen.
      [{"tpl":"tplMfdCustom10","data":{"oid":"hm-rpc.1.LEQ0773306.2.TEMPERATURE","visibility-cond":"==","visibility-val":1,"asButton":true,"icon0":"widgets/jqui-mfd/img/sani_valve_0.svg","icon1":"widgets/jqui-mfd/img/sani_valve_10.svg","icon2":"widgets/jqui-mfd/img/sani_valve_20.svg","icon3":"widgets/jqui-mfd/img/sani_valve_30.svg","icon4":"widgets/jqui-mfd/img/sani_valve_40.svg","icon5":"widgets/jqui-mfd/img/sani_valve_50.svg","icon6":"widgets/jqui-mfd/img/sani_valve_60.svg","icon7":"widgets/jqui-mfd/img/sani_valve_70.svg","icon8":"widgets/jqui-mfd/img/sani_valve_80.svg","icon9":"widgets/jqui-mfd/img/sani_valve_90.svg","icon10":"widgets/jqui-mfd/img/sani_valve_100.svg","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"min":"20","max":"30","iconColor10":"#f40906","iconColor9":"#efb40b","iconColor8":"#f7ce36","iconColor7":"#ece813","iconColor6":"#a847f5","iconColor5":"#2443e0"},"style":{"left":"511px","top":"141px"},"widgetSet":"jqui-mfd"}]
      • apollon77A Offline
        Hey,
        ich will ja nicht die Text-Werte farblich machen sondern ein Icon was davor steht, also in der Art so:
        Das Icon bekommt noch die Warnsymbole eingeblendet für LOWBAT und UNREACH :-)
        Habe gerade mal das valuelist gecheckt … da muss ich glaube ich noch mehr einsteigen wie ich da das Bild hinbekomme oder die Farben flexibilisieren?! Hab ich gerade spontan nicht gefunden :-(
          H …. dann muss ich heute Abend nochmal spielen und mir deins anschauen...
            Ooohje … gefunden ...
            Mit SVG Icons tut es ... mit PNG nicht :-(
            Andere off-Topic Frage: Wann werden denn die icons (speziell mdf) aktualisiert? Was muss man dazu tun?
            Es gibt neue Icons im Set laut deren Webseite. Habe nur gesehen das die wohl beim installieren des Adapters geladen werden ... Muss ich für ein Update den Adapter also löschen und neu anlegen?
              @apollon77:
              Es gibt neue Icons im Set laut deren Webseite. Habe nur gesehen das die wohl beim installieren des Adapters geladen werden … Muss ich für ein Update den Adapter also löschen und neu anlegen? `
              Ich denke du musst Bluefox ganz lieb bitten ein Update für den Adapter mit den neuen Icons zu machen ;)
                Jain … wenn ich den Code richtig verstehe wird es bei der Installation automagisch runtergeladen und ist gar nicht im Paket selbst drin
                  Dann würde ich einfach mal drüberinstallieren.
                  Vorher npm cache clean
                  Viel Glück
                  • ? Offline
                    dieser Beitrag ist zwar schon etwas älter, dennoch habe ich seit Jahren schon mehrere funktionierende Lösungen.
                    Meine neuste läuft bereits rein über php und zeigt zu jeder einzelnen Temperatur in 0,1°-Schriiten einen Farbwert, und auch die Farbe selbst.
                    Zuvor hatte ich bereits Bilder, wie im Eingangspost erwähnt und danach eine Javascript-Lösung. Die neueste Variante kann man sogar in einer sich ständig aktualisierenden PDF-Datei einbinden.
                    Falls hieran irgendjemand Interesse hat biete ich meine Hilfe an.
                    Mit freundlichen Grüßen
                    E 1 Antwort Letzte Antwort
                      Einstein2002
                      @solarfanenrico sagte in Icon mit Farbe je nach Temperatur-Wert eines Sensors:
                      ich würde gerne auf Deine Hilfe zurückkommen. Oder auf jede andere Hilfe.
                      Was möchte ich machen? Ich habe eine Raumtemperaturanzeige und die soll in den verschiedenen Farben je nach Temperatur Anzeigen.
                      Ich habe das Value & Indicator versucht, steige aber nicht so richtig durch wie ich was wo einzustellen habe.
                      Danke jetzt schon mal.
                      Gruß Michael
                      Proxmox, VM`s Windows, IoBroker im unprivilegiert LXC, Openmediavault; LXC `s Tasmota, PiHole, , InfluxDB, Motioneye, WireguardVPN, UniFi:
                      Smarthome...Sonoff, Alexa, Wled, raspberrymatic,...
                      • E Einstein2002
                        Gruß Michael
                        @einstein2002 sagte in Icon mit Farbe je nach Temperatur-Wert eines Sensors:
                        wo haperts denn?
                          wo haperts denn?
                          Einstein2002
                          Das habe ich eingestellt, aber die Anzeige bleibt immer nur weiß
                          • E Einstein2002
                            @einstein2002 da fehlt min, mid und max
                              Einstein2002
                              Okay,
                              was wären denn vernünftige Werte für einen Innenraum?
                              0, 15 40?
                              • E Einstein2002
                                Okay,
                                0, 15 40?
                                Okay,
                                0, 15 40?
                                nicht wirklich!
                                18, 21, 25??
                                kältest gewünschte, wohlfühltemperatur, Hitzegrenze
                                probiers aus
                                  Okay,
                                  0, 15 40?
                                  nicht wirklich!
                                  18, 21, 25??
                                  probiers aus
                                  Einstein2002
                                  Bleibt weiterhin weiß
                                  Hatte erst mit meinen Werten und jetzt Deine Werte gesetzt, nur wenn ich die 3 Farben lösche Ändert sich etwas, aber ich kann nicht genau nachvollziehen wie sich dann die Farben ändern.
                                  • E Einstein2002
                                    was?
                                    E 2 Antworten Letzte Antwort
                                      was?
                                      Einstein2002
                                      Ich habe jetzt die drei Farben gelöscht und meine Anzeige springt auf Rot.
                                      Ich ändere mal die Temperatur zum Test um, denke aber so könnte es gehen.
                                      Ich melde mich gleich...
                                        was?
                                        Einstein2002
                                        Danke das war der entscheidende Tipp!!
                                        Jetzt geht es, Dankeschön!!!!
                                        • E Einstein2002
                                          @einstein2002 hab's gerade angesehen
                                          dann hab ich -wie du- Hintergrund angehakt
                                          null problemo
