  4. Alexa neue Fehlermeldungen
    1.0k
    6.1k
alexa problem
5 Beiträge 4 Kommentatoren 802 Aufrufe 2 Beobachtet
    Marty56
    schrieb am zuletzt editiert von Marty56
    Ich habe seit ca. 3 Tagen viele Fehlermeldung vom Alexa Adapter.
    Er hat die Version 3.23.2.
    Mein System läuft unter Debian Bullseye und ist aktuell.
    node -v v16.19.0
    npm -v 8.19.3
    Geändert und installiert habe ich nichts Neues.
    Was kann ich tun?
    	2023-01-31 06:15:39.086	error	G0014D0601940KNP Error getting display brightness setting: Error: Timeout
    alexa2.0
    2023-01-31 06:15:28.476	error	G0014D0695130SB1 Error getting display brightness setting: Error: Timeout
    alexa2.0
    2023-01-31 06:15:16.958	error	G090LF09650418PG Error getting equalizer setting: Error: Timeout
    alexa2.0
    2023-01-31 06:15:06.049	error	G090LV037324007K Error getting connected speaker setting: Error: Timeout
    alexa2.0
    2023-01-31 06:14:53.029	error	90F00818720400KN Error getting equalizer enabled: Error: Timeout
    alexa2.0
    2023-01-31 06:14:40.482	error	G070GV1463470146 Error getting connected speaker setting: Error: Timeout
    alexa2.0
    2023-01-31 05:11:46.070	error	G071R20713270V9A Error getting aux controller state: Error: Timeout
    alexa2.0
    2023-01-31 05:11:36.065	error	7094180751440K7B Error getting connected speaker setting: Error: Timeout
    alexa2.0
    2023-01-31 05:11:24.327	error	G090LV037324007K Error getting equalizer range: Error: Timeout
    alexa2.0
    2023-01-31 05:11:11.722	error	90F00818720400KN Error getting connected speaker setting: Error: Timeout
    alexa2.0
    2023-01-31 04:10:01.450	error	G071R20713270V9A Error getting connected speaker setting: Error: Timeout
    alexa2.0
    2023-01-31 04:09:51.006	error	G090LF09650418PG Error getting aux controller state: Error: Timeout
    alexa2.0
    2023-01-31 04:09:37.131	error	G2A0P308844308UB Error getting equalizer range: Error: Timeout
    alexa2.0
    2023-01-31 02:09:06.258	error	G090LV037324007K Error getting connected speaker setting: Error: Timeout
    alexa2.0
    2023-01-31 02:08:56.106	error	G090LV037324007K Error getting equalizer range: Error: Timeout
    alexa2.0
    2023-01-31 02:08:39.460	error	G2A0P308844308UB Error getting equalizer enabled: Error: Timeout
    mihome-vacuum.0
    2023-01-31 01:00:00.132	error	Socket Close
    alexa2.0
    2023-01-31 00:55:28.132	error	G0014D0601940KNP Error getting connected speaker setting: Error: Timeout
    alexa2.0
    2023-01-31 00:55:17.394	error	G0014D0695130SB1 Error getting connected speaker setting: Error: Timeout
    alexa2.0
    2023-01-31 00:55:03.073	error	G070L81491030GL8 Error getting aux controller state: Error: Timeout
    alexa2.0
    2023-01-31 00:54:51.481	error	G090LV03717501KP Error getting aux controller state: Error: Timeout
    HW:NUC (16 GB Ram)
    OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
    • M Marty56
      node -v v16.19.0
      npm -v 8.19.3
      Was kann ich tun?
      alexa2.0
      alexa2.0
      alexa2.0
      alexa2.0
      alexa2.0
      alexa2.0
      alexa2.0
      alexa2.0
      alexa2.0
      alexa2.0
      alexa2.0
      alexa2.0
      alexa2.0
      alexa2.0
      alexa2.0
      mihome-vacuum.0
      alexa2.0
      alexa2.0
      alexa2.0
      alexa2.0
      Jojobo
      stehe jetzt seit einigen Tagen vor demselben Problem.
      Neuinstallation behebt das Problem nur kurzfristig, dann laufen
      wieder die Fehler auf und der Adapter schmiert ab.
      Gibt es hier schon evtl. eine Lösung?
      • J Jojobo
        babl
        @jojobo sagte in Alexa neue Fehlermeldungen:
        Tja auch bei mir kommen nun die selben Fehler.
        Gibt es hier eine Lösung?
        Ro75R 1 Antwort Letzte Antwort
        • B babl
          Ro75R Offline
          Ro75R Offline
          Ro75
          @babl permanent?
          Ro75.
          • Ro75R Ro75
            @babl permanent?
            Ro75.
            babl
            @ro75 permanent nicht, aber so 2 - 3 fehlermeldungen am Tag ja. Immer nur von 2 Dot´s vom 3. bisher nicht.
