  4. Gelöst Sonoff T1 TX 2CH als Rollladensteuerung
    5.1k
20 Beiträge 3 Kommentatoren 1.9k Aufrufe 3 Beobachtet
  • E Einstein2002
    @dieter_p
    Dann habe ich das mal kopiert
    14:06:43.425 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":0}
    14:06:44.290 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":6,"Direction":1,"Target":100,"Tilt":0}}
    14:06:44.313 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":6}'
    14:06:44.339 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":6}
    14:06:45.243 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":12,"Direction":1,"Target":100,"Tilt":0}}
    14:06:45.266 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":12}'
    14:06:45.292 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":12}
    14:06:46.253 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/STATE = {"Time":"2024-05-28T14:06:46","Uptime":"0T00:38:50","UptimeSec":2330,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":27,"MqttCount":1,"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"IoT","BSSId":"F4:92:BF:AA:EC:39","Channel":3,"Mode":"11n","RSSI":42,"Signal":-79,"LinkCount":1,"Downtime":"0T00:00:04"}}
    14:06:46.263 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/SENSOR = {"Time":"2024-05-28T14:06:46","Shutter1":{"Position":19,"Direction":1,"Target":100,"Tilt":0}}
    14:06:46.273 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":19,"Direction":1,"Target":100,"Tilt":0}}
    14:06:46.294 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":19}'
    14:06:46.304 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":19}
    14:06:47.292 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":26,"Direction":1,"Target":100,"Tilt":0}}
    14:06:47.312 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":26}'
    14:06:47.341 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":26}
    14:06:48.314 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":33,"Direction":1,"Target":100,"Tilt":0}}
    14:06:48.337 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":33}'
    14:06:48.348 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":33}
    14:06:49.280 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":39,"Direction":1,"Target":100,"Tilt":0}}
    14:06:49.303 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":39}'
    14:06:49.329 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":39}
    14:06:50.280 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":46,"Direction":1,"Target":100,"Tilt":0}}
    14:06:50.303 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":46}'
    14:06:50.329 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":46}
    14:06:51.354 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":53,"Direction":1,"Target":100,"Tilt":0}}
    14:06:51.375 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":53}'
    14:06:51.459 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":53}
    14:06:52.327 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":60,"Direction":1,"Target":100,"Tilt":0}}
    14:06:52.350 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":60}'
    14:06:52.360 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":60}
    14:06:53.262 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":66,"Direction":1,"Target":100,"Tilt":0}}
    14:06:53.284 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":66}'
    14:06:53.311 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":66}
    14:06:54.267 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":73,"Direction":1,"Target":100,"Tilt":0}}
    14:06:54.290 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":73}'
    14:06:54.316 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":73}
    14:06:55.285 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":79,"Direction":1,"Target":100,"Tilt":0}}
    14:06:55.309 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":79}'
    14:06:55.335 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":79}
    14:06:56.291 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/STATE = {"Time":"2024-05-28T14:06:56","Uptime":"0T00:39:00","UptimeSec":2340,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"IoT","BSSId":"F4:92:BF:AA:EC:39","Channel":3,"Mode":"11n","RSSI":42,"Signal":-79,"LinkCount":1,"Downtime":"0T00:00:04"}}
    14:06:56.302 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/SENSOR = {"Time":"2024-05-28T14:06:56","Shutter1":{"Position":86,"Direction":1,"Target":100,"Tilt":0}}
    14:06:56.310 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":86,"Direction":1,"Target":100,"Tilt":0}}
    14:06:56.332 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":86}'
    14:06:56.343 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":86}
    14:06:57.244 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":92,"Direction":1,"Target":100,"Tilt":0}}
    14:06:57.266 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":92}'
    14:06:57.278 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":92}
    14:06:58.284 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":99,"Direction":1,"Target":100,"Tilt":0}}
    14:06:58.307 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":99}'
    14:06:58.334 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":99}
    14:06:58.384 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"POWER1":"ON"}
    14:06:58.388 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/POWER1 = ON
    14:06:58.395 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/SHUTTER1 = 100
    14:06:58.400 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":100,"Direction":0,"Target":100,"Tilt":0}}
    14:06:58.422 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":100}'
    14:06:58.433 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":100}
    14:07:06.247 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/STATE = {"Time":"2024-05-28T14:07:06","Uptime":"0T00:39:10","UptimeSec":2350,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"IoT","BSSId":"F4:92:BF:AA:EC:39","Channel":3,"Mode":"11n","RSSI":40,"Signal":-80,"LinkCount":1,"Downtime":"0T00:00:04"}}
    14:07:06.259 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/SENSOR = {"Time":"2024-05-28T14:07:06","Shutter1":{"Position":100,"Direction":0,"Target":100,"Tilt":0}}
    14:07:16.356 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/STATE = {"Time":"2024-05-28T14:07:16","Uptime":"0T00:39:20","UptimeSec":2360,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"IoT","BSSId":"F4:92:BF:AA:EC:39","Channel":3,"Mode":"11n","RSSI":42,"Signal":-79,"LinkCount":1,"Downtime":"0T00:00:04"}}
    14:07:16.364 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/SENSOR = {"Time":"2024-05-28T14:07:16","Shutter1":{"Position":100,"Direction":0,"Target":100,"Tilt":0}}
    14:07:26.280 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/STATE = {"Time":"2024-05-28T14:07:26","Uptime":"0T00:39:30","UptimeSec":2370,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":26,"MqttCount":1,"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"IoT","BSSId":"F4:92:BF:AA:EC:39","Channel":3,"Mode":"11n","RSSI":42,"Signal":-79,"LinkCount":1,"Downtime":"0T00:00:04"}}
    14:07:26.292 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/SENSOR = {"Time":"2024-05-28T14:07:26","Shutter1":{"Position":100,"Direction":0,"Target":100,"Tilt":0}}
    14:07:28.473 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"POWER1":"OFF"}
    14:07:28.477 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/POWER1 = OFF
    Dieter_P
    @einstein2002 said in Sonoff T1 TX 2CH als Rollladensteuerung:
    @dieter_p
    Kannst Du mal zeigen was er ausgibt wenn Du ShutterPosition1 50 als kommando eingibst?
    Mich interessiert ob er das Target dann auch auf 50 setzt und warum er es dann nicht anfährt
    E 2 Antworten Letzte Antwort
    • D Dieter_P
      @dieter_p
      Einstein2002
      @dieter_p
      dann macht er das:
      14:21:57.102 CMD: ShutterPosition1 50
      14:21:57.112 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"POWER2":"ON"}
      14:21:57.117 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/POWER2 = ON
      14:21:57.124 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":100,"Direction":-1,"Target":50,"Tilt":0}}
      14:21:57.145 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":100}'
      14:21:57.228 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":100}
      14:21:57.242 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":99,"Direction":-1,"Target":50,"Tilt":0}}
      14:21:57.263 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":99}'
      14:21:57.293 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":99}
      14:21:58.278 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":93,"Direction":-1,"Target":50,"Tilt":0}}
      14:21:58.300 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":93}'
      14:21:58.326 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":93}
      14:21:59.259 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":86,"Direction":-1,"Target":50,"Tilt":0}}
      14:21:59.281 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":86}'
      14:21:59.308 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":86}
      14:22:00.273 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":79,"Direction":-1,"Target":50,"Tilt":0}}
      14:22:00.296 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":79}'
      14:22:00.321 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":79}
      14:22:01.277 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":73,"Direction":-1,"Target":50,"Tilt":0}}
      14:22:01.299 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":73}'
      14:22:01.327 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":73}
      14:22:02.307 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":66,"Direction":-1,"Target":50,"Tilt":0}}
      14:22:02.328 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":66}'
      14:22:02.341 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":66}
      14:22:03.273 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":59,"Direction":-1,"Target":50,"Tilt":0}}
      14:22:03.295 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":59}'
      14:22:03.322 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":59}
      14:22:04.246 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":53,"Direction":-1,"Target":50,"Tilt":0}}
      14:22:04.269 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":53}'
      14:22:04.296 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":53}
      14:22:04.697 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"POWER2":"ON"}
      14:22:04.702 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/POWER2 = ON
      14:22:04.707 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/SHUTTER1 = 50
      14:22:04.712 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":50,"Direction":0,"Target":50,"Tilt":0}}
      14:22:04.733 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":50}'
      14:22:04.830 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":50}
      14:22:06.247 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/STATE = {"Time":"2024-05-28T14:22:06","Uptime":"0T00:54:10","UptimeSec":3250,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":26,"MqttCount":1,"POWER1":"OFF","POWER2":"ON","Wifi":{"AP":1,"SSId":"IoT","BSSId":"F4:92:BF:AA:EC:39","Channel":3,"Mode":"11n","RSSI":40,"Signal":-80,"LinkCount":1,"Downtime":"0T00:00:04"}}
      14:22:06.258 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/SENSOR = {"Time":"2024-05-28T14:22:06","Shutter1":{"Position":50,"Direction":0,"Target":50,"Tilt":0}}
      14:22:16.250 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/STATE = {"Time":"2024-05-28T14:22:16","Uptime":"0T00:54:20","UptimeSec":3260,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"OFF","POWER2":"ON","Wifi":{"AP":1,"SSId":"IoT","BSSId":"F4:92:BF:AA:EC:39","Channel":3,"Mode":"11n","RSSI":36,"Signal":-82,"LinkCount":1,"Downtime":"0T00:00:04"}}
      14:22:16.258 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/SENSOR = {"Time":"2024-05-28T14:22:16","Shutter1":{"Position":50,"Direction":0,"Target":50,"Tilt":0}}
      14:22:26.243 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/STATE = {"Time":"2024-05-28T14:22:26","Uptime":"0T00:54:30","UptimeSec":3270,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":25,"MqttCount":1,"POWER1":"OFF","POWER2":"ON","Wifi":{"AP":1,"SSId":"IoT","BSSId":"F4:92:BF:AA:EC:39","Channel":3,"Mode":"11n","RSSI":36,"Signal":-82,"LinkCount":1,"Downtime":"0T00:00:04"}}
      14:22:26.255 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/SENSOR = {"Time":"2024-05-28T14:22:26","Shutter1":{"Position":50,"Direction":0,"Target":50,"Tilt":0}}
      14:22:34.717 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"POWER2":"OFF"}
      14:22:34.722 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/POWER2 = OFF
      Es wird die 50 angefahren, bleibt aber nicht stehen und wie man erkennen kann kommt der Power2 OFF Befehl erst viel später. :-(
      Proxmox, VM`s Windows, IoBroker im unprivilegiert LXC, Openmediavault; LXC `s Tasmota, PiHole, , InfluxDB, Motioneye, WireguardVPN, UniFi:
      Smarthome...Sonoff, Alexa, Wled, raspberrymatic,...
      • D Dieter_P
        @dieter_p
        Einstein2002
        @dieter_p
        Auch der Schieber erkennt das, blöde ist nur der Rollo ist ganz zu...😁
        • E Einstein2002
          @dieter_p
          Dieter_P
          @einstein2002
          Wenn er die Laufzeiten nicht nimmt, würde ich versuchen über
          ShutterSetClose<x>
          ShutterSetOpen<x>
          und ggf über ShutterCalibration<x> zu ergänzen.
          Klappt das alles nicht wirklich, hängt ggf. irgendwo was und ein Factory Reset mit anschließendem Neuversuch nach Kalibrierungsanleitung funtzt dann.
          • D Dieter_P
            @einstein2002
            ShutterSetClose<x>
            ShutterSetOpen<x>
            Einstein2002
            schrieb am zuletzt editiert von Einstein2002
            @dieter_p sagte in Sonoff T1 TX 2CH als Rollladensteuerung:
            @einstein2002
            ShutterSetClose<x>
            ShutterSetOpen<x>
            Das X ShutterSetClose<x> bleibt oder soll ich es so verändern ShutterSetClose<1> ??
            Da war ich mir nie sicher!
            • D Dieter_P
              @einstein2002
              ShutterSetClose<x>
              ShutterSetOpen<x>
              Einstein2002
              @dieter_p
              14:41:12.387 CMD: ShutterSetClose<x>
              14:41:12.396 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"ShutterSetClose1":"Konfiguration zurücksetzen"}
              14:41:54.859 CMD: ShutterSetOpen<x>
              14:41:54.868 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"ShutterSetOpen1":"Konfiguration zurücksetzen"}
              • E Einstein2002
                @einstein2002
                ShutterSetClose<x>
                ShutterSetOpen<x>
                Dieter_P
                @einstein2002
                ShutterSetClose<x>
                ShutterSetOpen<x>
                das <x> ist zu ersetzen durch den Shutter den Du zurück setzen möchtest also bei dir Nr1
                ShutterSetClose1
                • D Dieter_P
                  @einstein2002
                  ShutterSetClose<x>
                  ShutterSetOpen<x>
                  ShutterSetClose1
                  Einstein2002
                  @dieter_p
                  was mir jetzt erst auffällt, ich kann den nicht mehr stoppen, soll heißen wenn ich power1 einmal drücke fährt er hoch, drücke ich noch einmal power1 bleibt er stehen. Das macht der hier nicht!
                  Warum?
                  • D Dieter_P
                    @einstein2002
                    ShutterSetClose<x>
                    ShutterSetOpen<x>
                    ShutterSetClose1
                    Einstein2002
                    @dieter_p
                    So ich habe den jetzt neu aufgebaut, hatte zum Glück eine Datensicherung von früher.
                    Jetzt gehen die Tasten wieder so wie sie sollen, dann versuche ich es mal erneut. Falls hier einer einen Tipp haben sollte, gerne her damit.
                    Dankeschön jetzt schon mal
                    • E Offline
                      Einstein2002
                      Hallo Leute,
                      Problem gelöst.
                      Es lag an der Pulstime.
                      Diese muß!! Auf "0" gesetzt werden. Danach die Zeiten nochmals für eine Hoch und eine Runterfahrt mit der Stoppuhr ermittelt und eingegeben.
                      Dies habe ich bei Github gefunden dazu:
                      backlog SetOption80 1; SetOption13 1; ShutterRelay1 1; PulseTime1 0; PulseTime2 0; Pulsetime3 1; Interlock 1,2,3; Interlock ON; PowerRetain 1
                      Und was soll ich sagen... es läuft!!
                      Ich hoffe dies hilft einen von Euch weiter.
                      Grüße Michael
                      • SantosS Offline
                        SantosS Offline
                        Santos
                        Guten Morgen zusammen,
                        Ich wollte keinen separaten Thread aufmachen, deswegen frage einfach hier.
                        Bei mir zu Hause sind 7 Fenster mit dem 2Ch Sonoff Schalter installiert und mit Tasmota gefälscht. Bei zwei letzten Fenster habe ich bei der Installation etwas schief gemacht, kriege es nicht mehr logisch kalibriert. Programmiert sind sie so, dass sie morgens auf 100% Open fahren und abends auf 30% abdunkeln.
                        Ich schildere kurz das Problem.
                        Wenn ich das Fenster ganz aufmache (power1), ist die Rolllade ganz oben und das Fenster ist somit offen, steht auf 100% Open bei den Datenpunkten in ioBroker.
                        Nach ein paar Tagen merke ich, dass die Rollladen bei 100% immer mehr durchhängen, bis sie irgendwann nach einer Woche mit halb verdunkelten Fenster stehen, obwohl im Datenpunkt 100% Open steht. Ich weiß, dass ich sie falsch kalibriert habe, stehe aber auf dem Schlauch und bekomme es nicht mehr hin.
                        Abhilfe schafft es, wenn ich die Rolladen mit power2 ganz zu mache, dann mit power1 ganz auf, so steht Macher das Fenster offen. Das nervt aber natürlich, jede Woche das durchzuführen.
                        Vielleicht findet jemand Zeit und Lust mir den Fehler zu erklären.
                        Danke im Voraus
