  4. [gelöst]kein Zugriff per Web (Port8081)
    5.8k
22 Beiträge 3 Kommentatoren 3.2k Aufrufe
    der_Auge
    was sagt denn der Befehl:
     ps -A |grep " io.*"
    wenn du per ssh auf deiner Installation bist
    Master: DN2820FYKH (4GB) Linux NUC 4.4.0-22-generic #40-Ubuntu x86_64
    Slave: Linux RPi2-1 4.1.19-v7+ #858 v4.4.3 # 2.15.1
    SQL-DB : Linux DS 3.10.77 #7321 x86_64 synology412+
    Test : DS916+ VM Debian
    Test : Tinker mit piVCCU
      dippi
      Hallo
      es wird dann flgendes angezeigt
      pi@ioBroker-Pi3:~ $ ps -A |grep " io.*"
      597 ? 00:18:13 iobroker.js-con
      694 ? 00:01:50 io.hm-rpc.0
      736 ? 00:00:57 io.hm-rega.0
      757 ? 00:00:45 io.history.0
      767 ? 00:00:29 io.socketio.0
      793 ? 00:15:18 io.javascript.0
      811 ? 00:02:10 io.rpi2.0
      827 ? 00:00:59 io.hm-rpc.3
      893 ? 00:00:34 io.sonos.0
      pi@ioBroker-Pi3:~ $
        der_Auge
        Dann versuch mal
        cd /opt/iobroker
        sudo iobroker stop
        sudo iobroker del admin
        sudo npm install iobroker.admin --production
        sudo iobroker add admin
        sudo iobroker start
          dippi
          Guten Morgen
          leider ohne Erfolg mit dieser Warnmeldung
          pi@ioBroker-Pi3:/opt/iobroker $ sudo npm install iobroker.admin --production
          iobroker@1.0.0 /opt/iobroker
          └── iobroker.admin@2.0.9
          npm WARN Failed to parse json
          npm WARN Unexpected token '\n' at 73:65
          npm WARN   "homepage": "https://github.com/TimBeyer/cls-bluerird#readme"
          npm WARN        ^
          npm WARN File: /opt/iobroker/node_modules/cls-bluebird/package.json
          npm WARN Unexpected token '\u0002' at 5:30
          npm WARN         "raw": "asj1@~0�2.3",       "scope": .sll,
          npm WARN                              ^
          npm WARN File: /opt/iobroker/node_modules/iobroker.sonos/node_modules/asn1/package.json
          npm WARN Unexpected token '_' at 2:4
          npm WARN    _args":`�
          npm WARN    ^
          npm WARN File: /opt/iobroker/node_modules/iobroker.sonos/node_modules/debug/package.json
          npm WARN Unexpected token ';' at 2:10
          npm WARN   "_args"; [
          npm WARN          ^
          npm WARN File: /opt/iobroker/node_modules/iobroker.sonos/node_modules/engine.io/package.json
          npm WARN Unexpected token 'z' at 1:1
          npm WARN z
          npm WARN ^
          npm WARN File: /opt/iobroker/node_modules/iobroker.sonos/node_modules/hawk/package.json
          npm WARN Unexpected token '&' at 2:3
          npm WARN   &_azgs": [
          npm WARN   ^
          npm WARN File: /opt/iobroker/node_modules/iobroker.sonos/node_modules/minimist/package.json
          npm WARN Unexpected token '\u0002' at 3:6
          npm WARN     [( 0   {
          npm WARN      ^
          npm WARN File: /opt/iobroker/node_modules/iobroker.sonos/node_modules/tweetnacl/package.json
          npm WARN No value found for key [args at 2:11
          npm WARN   "[args":$[
          npm WARN           ^
          npm WARN File: /opt/iobroker/node_modules/iobroker.sonos/node_modules/uuid/package.json
            Was sagt
            node -v
            npm -v
            Gruß Rainer
              dippi
              pi@ioBroker-Pi3:/opt/iobroker $ node -v
              v6.12.2
              pi@ioBroker-Pi3:/opt/iobroker $ npm -v
              3.10.10
                Welche js-controller version hast du?
                  dippi
                  Wo seh ich das ?
                    dippi
                    Habs gefunden unter
                    iobroker update
                    Controller "js-controller" : 1.2.3 , installed 1.2.3
                    Dippi
                      Was um alles in der Welt ist dann
                      @dippi:
                      iobroker@1.0.0 `
                      Ich hatte befürchtet, dass du noch diese version hast.
                      Gruß Rainer
                        dippi
                        keine Ahnung was ich da gemacht habe, wahrscheinlich vor lauter verzweiflung ein Update gemacht.
                        Muss ich wieder downgraden ?
                        Wenn ja hast du mir den Befehl dafür ?
                        Gruß Dippi
                          Nein!
                          Wenn du jetzt das Update gemacht hast weißich evtl. weiter.
                          Wenn du schon immer 1.2.3 drauf hattest nicht.
                          Gruß Rainer
                            dippi
                            Das Update hab ich glaub schon erst jetzt gemacht.
                              Dann versuch mal
                              cd /opt/iobroker
                              sudo iobroker stop
                              sudo npm cache clean
                              sudo iobroker upload admin
                              sudo iobroker start
                                dippi
                                ich bekomme diese Warnmeldungen
                                • express node_modules/iobroker.js-controller/node_modules/iobroker.admin/node_modules/express
                                • express-fileupload node_modules/iobroker.js-controller/node_modules/iobroker.admin/node_modules/express-fileupload
                                npm WARN ^
                                npm WARN ^
                                npm WARN _args":`�
                                npm WARN ^
                                npm WARN "_args"; [
                                npm WARN ^
                                npm WARN z
                                npm WARN ^
                                npm WARN &_azgs": [
                                npm WARN ^
                                npm WARN [( 0 {
                                npm WARN ^
                                npm WARN "[args":$[
                                npm WARN ^
                                pi@ioBroker-Pi3:/opt/iobroker $ sudo iobroker upload admin
                                got /home/pi/node_modules/iobroker.admin/admin
                                upload [2] admin.admin /home/pi/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                                upload [1] admin.admin /home/pi/node_modules/iobroker.admin/admin/index.html index.html text/html
                                upload [0] admin.admin /home/pi/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                                system.adapter.admin does not exist
                                pi@ioBroker-Pi3:/opt/iobroker $ sudo iobroker start
                                Starting iobroker controller daemon…
                                iobroker controller daemon started. PID: 19950
                                  Hast du mal den raspi neu gestartet, dass 1.2.3 auch gestartet wird?
                                    dippi
                                    Ich hab es nochmal versucht und nach dem Cache clean den RP neugestartet und dann weiter gemacht, nun sieht es etwas besser aus glsub ich
                                    pi@ioBroker-Pi3:~ $ sudo npm install iobroker.admin
                                    - after@0.8.2 node_modules/iobroker.admin/node_modules/after
                                    - array-flatten@1.1.1 node_modules/iobroker.admin/node_modules/array-flatten
                                    - arraybuffer.slice@0.0.6 node_modules/iobroker.admin/node_modules/arraybuffer.slice
                                    - asn1@0.2.3 node_modules/iobroker.admin/node_modules/asn1
                                    - assert-plus@1.0.0 node_modules/iobroker.admin/node_modules/assert-plus
                                    - asynckit@0.4.0 node_modules/iobroker.admin/node_modules/asynckit
                                    - aws-sign2@0.7.0 node_modules/iobroker.admin/node_modules/aws-sign2
                                    - aws4@1.6.0 node_modules/iobroker.admin/node_modules/aws4
                                    - backo2@1.0.2 node_modules/iobroker.admin/node_modules/backo2
                                    - balanced-match@1.0.0 node_modules/iobroker.admin/node_modules/balanced-match
                                    - base64-arraybuffer@0.1.5 node_modules/iobroker.admin/node_modules/base64-arraybuffer
                                    - base64id@1.0.0 node_modules/iobroker.admin/node_modules/base64id
                                    - blob@0.0.4 node_modules/iobroker.admin/node_modules/blob
                                    - bytes@3.0.0 node_modules/iobroker.admin/node_modules/bytes
                                    - callsite@1.0.0 node_modules/iobroker.admin/node_modules/callsite
                                    - better-assert@1.0.2 node_modules/iobroker.admin/node_modules/better-assert
                                    - caseless@0.12.0 node_modules/iobroker.admin/node_modules/caseless
                                    - co@4.6.0 node_modules/iobroker.admin/node_modules/co
                                    - component-bind@1.0.0 node_modules/iobroker.admin/node_modules/component-bind
                                    - component-emitter@1.1.2 node_modules/iobroker.admin/node_modules/component-emitter
                                    - component-inherit@0.0.3 node_modules/iobroker.admin/node_modules/component-inherit
                                    - concat-map@0.0.1 node_modules/iobroker.admin/node_modules/concat-map
                                    - brace-expansion@1.1.8 node_modules/iobroker.admin/node_modules/brace-expansion
                                    - connect-flash@0.1.1 node_modules/iobroker.admin/node_modules/connect-flash
                                    - content-disposition@0.5.2 node_modules/iobroker.admin/node_modules/content-disposition
                                    - content-type@1.0.4 node_modules/iobroker.admin/node_modules/content-type
                                    - cookie@0.3.1 node_modules/iobroker.admin/node_modules/cookie
                                    - cookie-signature@1.0.6 node_modules/iobroker.admin/node_modules/cookie-signature
                                    - cookie-parser@1.4.3 node_modules/iobroker.admin/node_modules/cookie-parser
                                    - core-util-is@1.0.2 node_modules/iobroker.admin/node_modules/core-util-is
                                    - crc@3.4.4 node_modules/iobroker.admin/node_modules/crc
                                    - dashdash@1.14.1 node_modules/iobroker.admin/node_modules/dashdash
                                    - delayed-stream@1.0.0 node_modules/iobroker.admin/node_modules/delayed-stream
                                    - combined-stream@1.0.5 node_modules/iobroker.admin/node_modules/combined-stream
                                    - depd@1.1.1 node_modules/iobroker.admin/node_modules/depd
                                    - destroy@1.0.4 node_modules/iobroker.admin/node_modules/destroy
                                    - ee-first@1.1.1 node_modules/iobroker.admin/node_modules/ee-first
                                    - encodeurl@1.0.1 node_modules/iobroker.admin/node_modules/encodeurl
                                    - component-emitter@1.2.1 node_modules/iobroker.admin/node_modules/engine.io-client/node_modules/component-emitter
                                    - ms@0.7.2 node_modules/iobroker.admin/node_modules/engine.io-client/node_modules/ms
                                    - debug@2.3.3 node_modules/iobroker.admin/node_modules/engine.io-client/node_modules/debug
                                    - ms@0.7.2 node_modules/iobroker.admin/node_modules/engine.io/node_modules/ms
                                    - debug@2.3.3 node_modules/iobroker.admin/node_modules/engine.io/node_modules/debug
                                    - escape-html@1.0.3 node_modules/iobroker.admin/node_modules/escape-html
                                    - etag@1.8.1 node_modules/iobroker.admin/node_modules/etag
                                    - setprototypeof@1.1.0 node_modules/iobroker.admin/node_modules/express/node_modules/setprototypeof
                                    - statuses@1.3.1 node_modules/iobroker.admin/node_modules/express/node_modules/statuses
                                    - extend@3.0.1 node_modules/iobroker.admin/node_modules/extend
                                    - extsprintf@1.3.0 node_modules/iobroker.admin/node_modules/extsprintf
                                    - fast-deep-equal@1.0.0 node_modules/iobroker.admin/node_modules/fast-deep-equal
                                    - fast-json-stable-stringify@2.0.0 node_modules/iobroker.admin/node_modules/fast-json-stable-stringify
                                    - statuses@1.3.1 node_modules/iobroker.admin/node_modules/finalhandler/node_modules/statuses
                                    - forever-agent@0.6.1 node_modules/iobroker.admin/node_modules/forever-agent
                                    - forwarded@0.1.2 node_modules/iobroker.admin/node_modules/forwarded
                                    - fresh@0.5.2 node_modules/iobroker.admin/node_modules/fresh
                                    - fs.realpath@1.0.0 node_modules/iobroker.admin/node_modules/fs.realpath
                                    - getpass@0.1.7 node_modules/iobroker.admin/node_modules/getpass
                                    - graceful-fs@4.1.11 node_modules/iobroker.admin/node_modules/graceful-fs
                                    - har-schema@2.0.0 node_modules/iobroker.admin/node_modules/har-schema
                                    - has-cors@1.1.0 node_modules/iobroker.admin/node_modules/has-cors
                                    - hoek@4.2.0 node_modules/iobroker.admin/node_modules/hoek
                                    - boom@4.3.1 node_modules/iobroker.admin/node_modules/boom
                                    - boom@5.2.0 node_modules/iobroker.admin/node_modules/cryptiles/node_modules/boom
                                    - cryptiles@3.1.2 node_modules/iobroker.admin/node_modules/cryptiles
                                    - iconv-lite@0.4.19 node_modules/iobroker.admin/node_modules/iconv-lite
                                    - indexof@0.0.1 node_modules/iobroker.admin/node_modules/indexof
                                    - inherits@2.0.3 node_modules/iobroker.admin/node_modules/inherits
                                    - ipaddr.js@1.5.2 node_modules/iobroker.admin/node_modules/ipaddr.js
                                    - is-typedarray@1.0.0 node_modules/iobroker.admin/node_modules/is-typedarray
                                    - isarray@0.0.1 node_modules/iobroker.admin/node_modules/isarray
                                    - has-binary@0.1.7 node_modules/iobroker.admin/node_modules/has-binary
                                    - isstream@0.1.2 node_modules/iobroker.admin/node_modules/isstream
                                    - jsbn@0.1.1 node_modules/iobroker.admin/node_modules/jsbn
                                    - ecc-jsbn@0.1.1 node_modules/iobroker.admin/node_modules/ecc-jsbn
                                    - json-schema@0.2.3 node_modules/iobroker.admin/node_modules/json-schema
                                    - json-schema-traverse@0.3.1 node_modules/iobroker.admin/node_modules/json-schema-traverse
                                    - ajv@5.5.2 node_modules/iobroker.admin/node_modules/ajv
                                    - har-validator@5.0.3 node_modules/iobroker.admin/node_modules/har-validator
                                    - json-stringify-safe@5.0.1 node_modules/iobroker.admin/node_modules/json-stringify-safe
                                    - json3@3.3.2 node_modules/iobroker.admin/node_modules/json3
                                    - jsonfile@2.4.0 node_modules/iobroker.admin/node_modules/jsonfile
                                    - media-typer@0.3.0 node_modules/iobroker.admin/node_modules/media-typer
                                    - merge-descriptors@1.0.1 node_modules/iobroker.admin/node_modules/merge-descriptors
                                    - methods@1.1.2 node_modules/iobroker.admin/node_modules/methods
                                    - mime@1.4.1 node_modules/iobroker.admin/node_modules/mime
                                    - mime-db@1.30.0 node_modules/iobroker.admin/node_modules/mime-db
                                    - mime-types@2.1.17 node_modules/iobroker.admin/node_modules/mime-types
                                    - form-data@2.3.1 node_modules/iobroker.admin/node_modules/form-data
                                    - minimatch@3.0.4 node_modules/iobroker.admin/node_modules/minimatch
                                    - ms@2.0.0 node_modules/iobroker.admin/node_modules/ms
                                    - debug@2.6.9 node_modules/iobroker.admin/node_modules/debug
                                    - negotiator@0.6.1 node_modules/iobroker.admin/node_modules/negotiator
                                    - accepts@1.3.4 node_modules/iobroker.admin/node_modules/accepts
                                    - accepts@1.3.3 node_modules/iobroker.admin/node_modules/engine.io/node_modules/accepts
                                    - oauth-sign@0.8.2 node_modules/iobroker.admin/node_modules/oauth-sign
                                    - object-assign@4.1.0 node_modules/iobroker.admin/node_modules/object-assign
                                    - object-component@0.0.3 node_modules/iobroker.admin/node_modules/object-component
                                    - on-finished@2.3.0 node_modules/iobroker.admin/node_modules/on-finished
                                    - on-headers@1.0.1 node_modules/iobroker.admin/node_modules/on-headers
                                    - options@0.0.6 node_modules/iobroker.admin/node_modules/options
                                    - parsejson@0.0.3 node_modules/iobroker.admin/node_modules/parsejson
                                    - parseqs@0.0.5 node_modules/iobroker.admin/node_modules/parseqs
                                    - parseuri@0.0.5 node_modules/iobroker.admin/node_modules/parseuri
                                    - parseurl@1.3.2 node_modules/iobroker.admin/node_modules/parseurl
                                    - passport-strategy@1.0.0 node_modules/iobroker.admin/node_modules/passport-strategy
                                    - passport-local@1.0.0 node_modules/iobroker.admin/node_modules/passport-local
                                    - path-is-absolute@1.0.1 node_modules/iobroker.admin/node_modules/path-is-absolute
                                    - path-to-regexp@0.1.7 node_modules/iobroker.admin/node_modules/path-to-regexp
                                    - pause@0.0.1 node_modules/iobroker.admin/node_modules/pause
                                    - passport@0.3.2 node_modules/iobroker.admin/node_modules/passport
                                    - performance-now@2.1.0 node_modules/iobroker.admin/node_modules/performance-now
                                    - proxy-addr@2.0.2 node_modules/iobroker.admin/node_modules/proxy-addr
                                    - punycode@1.4.1 node_modules/iobroker.admin/node_modules/punycode
                                    - qs@6.5.1 node_modules/iobroker.admin/node_modules/qs
                                    - random-bytes@1.0.0 node_modules/iobroker.admin/node_modules/random-bytes
                                    - range-parser@1.2.0 node_modules/iobroker.admin/node_modules/range-parser
                                    - safe-buffer@5.1.1 node_modules/iobroker.admin/node_modules/safe-buffer
                                    - statuses@1.3.1 node_modules/iobroker.admin/node_modules/send/node_modules/statuses
                                    - setprototypeof@1.0.3 node_modules/iobroker.admin/node_modules/setprototypeof
                                    - sntp@2.1.0 node_modules/iobroker.admin/node_modules/sntp
                                    - hawk@6.0.2 node_modules/iobroker.admin/node_modules/hawk
                                    - ms@0.7.2 node_modules/iobroker.admin/node_modules/socket.io-adapter/node_modules/ms
                                    - debug@2.3.3 node_modules/iobroker.admin/node_modules/socket.io-adapter/node_modules/debug
                                    - component-emitter@1.2.1 node_modules/iobroker.admin/node_modules/socket.io-client/node_modules/component-emitter
                                    - ms@0.7.2 node_modules/iobroker.admin/node_modules/socket.io-client/node_modules/ms
                                    - debug@2.3.3 node_modules/iobroker.admin/node_modules/socket.io-client/node_modules/debug
                                    - ms@0.7.1 node_modules/iobroker.admin/node_modules/socket.io-parser/node_modules/ms
                                    - debug@2.2.0 node_modules/iobroker.admin/node_modules/socket.io-parser/node_modules/debug
                                    - socket.io-parser@2.3.1 node_modules/iobroker.admin/node_modules/socket.io-parser
                                    - socket.io-adapter@0.5.0 node_modules/iobroker.admin/node_modules/socket.io-adapter
                                    - ms@0.7.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/ms
                                    - debug@2.3.3 node_modules/iobroker.admin/node_modules/socket.io/node_modules/debug
                                    - statuses@1.4.0 node_modules/iobroker.admin/node_modules/statuses
                                    - http-errors@1.6.2 node_modules/iobroker.admin/node_modules/http-errors
                                    - send@0.16.1 node_modules/iobroker.admin/node_modules/send
                                    - serve-static@1.13.1 node_modules/iobroker.admin/node_modules/serve-static
                                    - streamifier@0.1.1 node_modules/iobroker.admin/node_modules/streamifier
                                    - streamsearch@0.1.2 node_modules/iobroker.admin/node_modules/streamsearch
                                    - string_decoder@0.10.31 node_modules/iobroker.admin/node_modules/string_decoder
                                    - readable-stream@1.1.14 node_modules/iobroker.admin/node_modules/readable-stream
                                    - dicer@0.2.5 node_modules/iobroker.admin/node_modules/dicer
                                    - busboy@0.2.14 node_modules/iobroker.admin/node_modules/busboy
                                    - stringstream@0.0.5 node_modules/iobroker.admin/node_modules/stringstream
                                    - to-array@0.1.4 node_modules/iobroker.admin/node_modules/to-array
                                    - tough-cookie@2.3.3 node_modules/iobroker.admin/node_modules/tough-cookie
                                    - tunnel-agent@0.6.0 node_modules/iobroker.admin/node_modules/tunnel-agent
                                    - tweetnacl@0.14.5 node_modules/iobroker.admin/node_modules/tweetnacl
                                    - bcrypt-pbkdf@1.0.1 node_modules/iobroker.admin/node_modules/bcrypt-pbkdf
                                    - sshpk@1.13.1 node_modules/iobroker.admin/node_modules/sshpk
                                    - type-is@1.6.15 node_modules/iobroker.admin/node_modules/type-is
                                    - uid-safe@2.1.5 node_modules/iobroker.admin/node_modules/uid-safe
                                    - ultron@1.0.2 node_modules/iobroker.admin/node_modules/ultron
                                    - ws@1.1.2 node_modules/iobroker.admin/node_modules/engine.io-client/node_modules/ws
                                    - unpipe@1.0.0 node_modules/iobroker.admin/node_modules/unpipe
                                    - finalhandler@1.1.0 node_modules/iobroker.admin/node_modules/finalhandler
                                    - raw-body@2.3.2 node_modules/iobroker.admin/node_modules/raw-body
                                    - body-parser@1.18.2 node_modules/iobroker.admin/node_modules/body-parser
                                    - utils-merge@1.0.1 node_modules/iobroker.admin/node_modules/utils-merge
                                    - express-session@1.15.6 node_modules/iobroker.admin/node_modules/express-session
                                    - uuid@3.1.0 node_modules/iobroker.admin/node_modules/uuid
                                    - vary@1.1.2 node_modules/iobroker.admin/node_modules/vary
                                    - express@4.16.2 node_modules/iobroker.admin/node_modules/express
                                    - verror@1.10.0 node_modules/iobroker.admin/node_modules/verror
                                    - jsprim@1.4.1 node_modules/iobroker.admin/node_modules/jsprim
                                    - http-signature@1.2.0 node_modules/iobroker.admin/node_modules/http-signature
                                    - request@2.83.0 node_modules/iobroker.admin/node_modules/request
                                    - wrappy@1.0.2 node_modules/iobroker.admin/node_modules/wrappy
                                    - once@1.4.0 node_modules/iobroker.admin/node_modules/once
                                    - inflight@1.0.6 node_modules/iobroker.admin/node_modules/inflight
                                    - glob@7.1.2 node_modules/iobroker.admin/node_modules/glob
                                    - rimraf@2.6.2 node_modules/iobroker.admin/node_modules/rimraf
                                    - fs-extra@0.22.1 node_modules/iobroker.admin/node_modules/fs-extra
                                    - express-fileupload@0.1.4 node_modules/iobroker.admin/node_modules/express-fileupload
                                    - ws@1.1.4 node_modules/iobroker.admin/node_modules/ws
                                    - wtf-8@1.0.0 node_modules/iobroker.admin/node_modules/wtf-8
                                    - engine.io-parser@1.3.2 node_modules/iobroker.admin/node_modules/engine.io-parser
                                    - engine.io@1.8.4 node_modules/iobroker.admin/node_modules/engine.io
                                    - xmlhttprequest-ssl@1.5.3 node_modules/iobroker.admin/node_modules/xmlhttprequest-ssl
                                    - xtend@4.0.1 node_modules/iobroker.admin/node_modules/xtend
                                    - passport.socketio@3.7.0 node_modules/iobroker.admin/node_modules/passport.socketio
                                    - yeast@0.1.2 node_modules/iobroker.admin/node_modules/yeast
                                    - engine.io-client@1.8.4 node_modules/iobroker.admin/node_modules/engine.io-client
                                    - socket.io-client@1.7.4 node_modules/iobroker.admin/node_modules/socket.io-client
                                    - socket.io@1.7.4 node_modules/iobroker.admin/node_modules/socket.io
                                    iobroker.inst@1.0.3 /home/pi
                                    pi@ioBroker-Pi3:~ $ sudo iobroker upload admin
                                    pi@ioBroker-Pi3:~ $ sudo iobroker start
                                    Starting iobroker controller daemon...
                                    iobroker controller daemon started. PID: 784
                                    nur ist wohl noch was mit dem admin adapter.
                                    OH ich glaub ich hab im falschen verzeichnis installiert. wenn icih wieder im iobroker Verzeichnis bin kommen wieder die Warnmeldungen
                                      @dippi:
                                      OH ich glaub ich hab im falschen verzeichnis installiert. `
                                      Das wäre meine nächste Frage gewesen.
                                      Dann hast du zweimal iobroker drauf und das gibt natürlich Probleme.
                                      Hast du ein aktuelles backup?
                                        dippi
                                        ne leider nicht, aber hab noch nicht so viel im Iobroker drin bin erst am anfang.
                                        Scheint nach einer neu install auszusehen.
                                          @dippi:
                                          Scheint nach einer neu install auszusehen. `
                                          Wäre wahrscheinlich das einfachste :(
