  4. Berker IP Control
Berker IP Control
8 Beiträge 3 Kommentatoren 455 Aufrufe 2 Beobachtet
    tomtulli
    Hallo Leute,
    habe ein Problem mit meinem IP Control von Becker.
    Dieser hat immer mit dem KNX Adapter Funktioniert.
    Jetzt bekommt er keine Verbindung zum Gerät mehr.
    Über Oben KNX ist es kein Problem.
    nx.0
    2024-03-31 17:49:04.436	info	STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    knx.0
    2024-03-31 17:49:04.435	info	... not able to close connection, because already closed
    knx.0
    2024-03-31 17:49:04.428	info	Connection persists.....closing now
    knx.0
    2024-03-31 17:49:04.426	info	...set STATE-NOT-CONNECTED
    knx.0
    2024-03-31 17:49:03.424	info	STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    knx.0
    2024-03-31 17:49:03.422	info	... not able to close connection, because already closed
    knx.0
    2024-03-31 17:49:03.416	info	Connection persists.....closing now
    knx.0
    2024-03-31 17:49:03.415	info	STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECTION_STATE_RESPONSE(6) to STATE_DISCONNECT_REQUEST(15).
    knx.0
    2024-03-31 17:49:03.413	info	Received CONNECTIONSTATE_RESPONSE : 06 10 02 08 00 08 00 21 192.168.2.100:3671 ChID : 0 SeqCntIN : 0 SeqCntOUT : 0 msgCode : [object Object]
    knx.0
    2024-03-31 17:49:03.410	info	STATE_CONNECTION_STATE_REQUEST : no defined handling for transition from State: STATE_DESCRIPTION_REQUEST(17) to STATE_CONNECTION_STATE_REQUEST(5).
    knx.0
    2024-03-31 17:49:03.409	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 e7 f6 sent from Port: to 192.168.2.100:3671
    knx.0
    2024-03-31 17:49:01.405	info	Send : description Request : 06 10 02 03 00 0e 08 01 c0 a8 02 57 e7 f6 sent to 192.168.2.100:3671
    knx.0
    2024-03-31 17:49:01.403	info	Connected - local UDP Server listening on 192.168.2.87:59382
    knx.0
    2024-03-31 17:49:01.399	info	Event : UDP - listening
    knx.0
    2024-03-31 17:49:01.396	info	Using UDP with local IP: 192.168.2.87
    knx.0
    2024-03-3
    ich hoffe ihr habt eine Lösung.
    L 1 Antwort Letzte Antwort
    • T tomtulli
      Hallo Leute,
      nx.0
      knx.0
      knx.0
      knx.0
      knx.0
      knx.0
      knx.0
      knx.0
      knx.0
      knx.0
      knx.0
      knx.0
      knx.0
      knx.0
      knx.0
      knx.0
      2024-03-3
      lessthanmore
      @tomtulli said in Berker IP Control:
      Was spricht dagegen openKNX zu verwenden?
      Sofern du für den anderen Adapter zahlst, mach ein Issue bei github auf.
        tomtulli
        bei openknx bekomme ich nicht alle Punkte meiner Instalation Importiert.
        ETS 5.3 Adressen als XML Exportiert aber nur 6 Adressen statt 374.
        Mit dem normalen KNX Adapter hat es immer Funktioniert.
        • T tomtulli
          lessthanmore
          @tomtulli Es gibt aber doch ein Errorlog beim fehlerhaften Import, was steht denn da drin?
          • L lessthanmore
            tomtulli
            @lessthanmore
            Imported 9 states successfully
            Not adding Lichtszenen.Lichtszene.Lichtszene because no DPT is assigned to GA 0/0/1. The GA is not connected to a device communication object in the ETS.
            Not adding Lichtszenen.Lichtszene.Gesamthelligkeit because no DPT is assigned to GA 0/0/2. The GA is not connected to a device communication object in the ETS.
            Not adding Lichtszenen.Lichtszene.Umgebungshelligkeit because no DPT is assigned to GA 0/0/3. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_+KG.Wohnen_Strahler_1_schalten because no DPT is assigned to GA 1/0/0. The GA is not connected to a device communication object in the ETS.
            +KG.Wohnen_Strahler_1_dimmen because no DPT is assigned to GA 1/0/1. The GA is not connected to a device communication object in the ETS.
            +KG.Wohnen_Strahler_1_HW because no DPT is assigned to GA 1/0/2. The GA is not connected to a device communication object in the ETS.
            +KG.Wohnen_Strahler_2_schalten because no DPT is assigned to GA 1/0/3. The GA is not connected to a device communication object in the ETS.
            +KG.Wohnen_Strahler_2_dimmen because no DPT is assigned to GA 1/0/4. The GA is not connected to a device communication object in the ETS.
            +KG.Wohnen_Strahler_2_HW because no DPT is assigned to GA 1/0/5. The GA is not connected to a device communication object in the ETS.
            +KG.Wohnen_Wandlampen_schalten because no DPT is assigned to GA 1/0/6. The GA is not connected to a device communication object in the ETS.
            +KG.Wohnen_Wandlampen_dimmen because no DPT is assigned to GA 1/0/7. The GA is not connected to a device communication object in the ETS.
            +KG.Wohnen_Wandlampen_HW because no DPT is assigned to GA 1/0/8. The GA is not connected to a device communication object in the ETS.
            +KG.Essen_Pendelleuchte_schalten because no DPT is assigned to GA 1/0/9. The GA is not connected to a device communication object in the ETS.
            +KG.Küche_Strahler_schalten because no DPT is assigned to GA 1/0/10. The GA is not connected to a device communication object in the ETS.
            +KG.Küche_Strahler_dimmen because no DPT is assigned to GA 1/0/11. The GA is not connected to a device communication object in the ETS.
            +KG.Küche_Strahler_HW because no DPT is assigned to GA 1/0/12. The GA is not connected to a device communication object in the ETS.
            +KG.Beleuchtung_Tersasse_Hinten because no DPT is assigned to GA 1/0/13. The GA is not connected to a device communication object in the ETS.
            +KG.Küche_Bel__Hängeschrank_schalten because no DPT is assigned to GA 1/0/14. The GA is not connected to a device communication object in the ETS.
            +KG.Windfang_Strahler_schalten because no DPT is assigned to GA 1/0/15. The GA is not connected to a device communication object in the ETS.
            +KG.Flur_Strahler_schalten because no DPT is assigned to GA 1/0/16. The GA is not connected to a device communication object in the ETS.
            +KG.Schlafen_Strahler_schalten because no DPT is assigned to GA 1/0/17. The GA is not connected to a device communication object in the ETS.
            +KG.Schlafen_Wandlampe_schalten because no DPT is assigned to GA 1/0/18. The GA is not connected to a device communication object in the ETS.
            +KG.Ankleide_Strahler_schalten because no DPT is assigned to GA 1/0/19. The GA is not connected to a device communication object in the ETS.
            +KG.Bad_Strahler_schalten because no DPT is assigned to GA 1/0/20. The GA is not connected to a device communication object in the ETS.
            +KG.Bad_Spiegel_schalten because no DPT is assigned to GA 1/0/21. The GA is not connected to a device communication object in the ETS.
            +KG.Bad_Wanne_schalten because no DPT is assigned to GA 1/0/22. The GA is not connected to a device communication object in the ETS.
            +KG.Spielezimmer_Decke_schalten because no DPT is assigned to GA 1/0/23. The GA is not connected to a device communication object in the ETS.
            +KG.WC_Strahler_schalten because no DPT is assigned to GA 1/0/24. The GA is not connected to a device communication object in the ETS.
            +KG.Technik_Strahler_schalten because no DPT is assigned to GA 1/0/25. The GA is not connected to a device communication object in the ETS.
            +KG.WC_Spiegel_schalten because no DPT is assigned to GA 1/0/26. The GA is not connected to a device communication object in the ETS.
            +KG.Keller_Wohnzimmerlicht_Decke_Schalten because no DPT is assigned to GA 1/0/27. The GA is not connected to a device communication object in the ETS.
            +KG.Garage_Beleuchtung_schalten_RMSS because no DPT is assigned to GA 1/0/28. The GA is not connected to a device communication object in the ETS.
            +KG.Keller_Wohnung_Flurlicht_Schalten because no DPT is assigned to GA 1/0/29. The GA is not connected to a device communication object in the ETS.
            +KG.Zimmer_1_Licht_Wohnen_schalten_RMSS because no DPT is assigned to GA 1/0/30. The GA is not connected to a device communication object in the ETS.
            +KG.Keller_Wohnung_Bad_Deckenlicht_Schalten because no DPT is assigned to GA 1/0/31. The GA is not connected to a device communication object in the ETS.
            +KG.Zimmer_1_Licht_Decke_WC_schalten_RMSS because no DPT is assigned to GA 1/0/32. The GA is not connected to a device communication object in the ETS.
            +KG.Zimmer_1_Licht_Spiegel_WC_schalten because no DPT is assigned to GA 1/0/33. The GA is not connected to a device communication object in the ETS.
            +KG.Zimmer_1_Licht_Spiegel_WC_schalten_RMSS because no DPT is assigned to GA 1/0/34. The GA is not connected to a device communication object in the ETS.
            +KG.Keller_Wohnung_SZ_Licht_Decke_Schalten because no DPT is assigned to GA 1/0/35. The GA is not connected to a device communication object in the ETS.
            +KG.Zimmer_2_Licht_Wohnen_schalten_RMSS because no DPT is assigned to GA 1/0/36. The GA is not connected to a device communication object in the ETS.
            +KG.KG_SZ_Bett_Links because no DPT is assigned to GA 1/0/37. The GA is not connected to a device communication object in the ETS.
            +KG.Zimmer_2_Licht_Decke_WC_schalten_RMSS because no DPT is assigned to GA 1/0/38. The GA is not connected to a device communication object in the ETS.
            +KG.KG_SZ_Licht_Bett_Rechts because no DPT is assigned to GA 1/0/39. The GA is not connected to a device communication object in the ETS.
            +KG.Zimmer_2_Licht_Spiegel_WC_schalten_RMSS because no DPT is assigned to GA 1/0/40. The GA is not connected to a device communication object in the ETS.
            +KG.Flur_KG_Strahler_schalten because no DPT is assigned to GA 1/0/41. The GA is not connected to a device communication object in the ETS.
            +KG.Flur_KG_Strahler_schalten_RMSS because no DPT is assigned to GA 1/0/42. The GA is not connected to a device communication object in the ETS.
            +KG.Holzlager_Licht_schalten because no DPT is assigned to GA 1/0/43. The GA is not connected to a device communication object in the ETS.
            +KG.Holzlager_Licht_schalten_RMSS because no DPT is assigned to GA 1/0/44. The GA is not connected to a device communication object in the ETS.
            +KG.Flur_vor_Treppe_KG_schalten because no DPT is assigned to GA 1/0/45. The GA is not connected to a device communication object in the ETS.
            +KG.Flur_vor_Treppe_KG_schalten_RMSS because no DPT is assigned to GA 1/0/46. The GA is not connected to a device communication object in the ETS.
            +KG.LED_Strahler_Treppe_schalten because no DPT is assigned to GA 1/0/47. The GA is not connected to a device communication object in the ETS.
            +KG.LED_Strahler_Treppe_schalten_RMSS because no DPT is assigned to GA 1/0/48. The GA is not connected to a device communication object in the ETS.
            +KG.Ecklampe_Treppe_schalten because no DPT is assigned to GA 1/0/49. The GA is not connected to a device communication object in the ETS.
            +KG.Ecklampe_Treppe_schalten_RMSS because no DPT is assigned to GA 1/0/50. The GA is not connected to a device communication object in the ETS.
            +KG.Anbau_vorn_Lampe_schalten because no DPT is assigned to GA 1/0/51. The GA is not connected to a device communication object in the ETS.
            +KG.Anbau_vorn_Lampe_RMSS because no DPT is assigned to GA 1/0/52. The GA is not connected to a device communication object in the ETS.
            +KG.Anbau_hinten_Lampe_schalten because no DPT is assigned to GA 1/0/53. The GA is not connected to a device communication object in the ETS.
            +KG.Anbau_hinten_Lampe_RMSS because no DPT is assigned to GA 1/0/54. The GA is not connected to a device communication object in the ETS.
            +KG.HWR_Keller_Licht because no DPT is assigned to GA 1/0/55. The GA is not connected to a device communication object in the ETS.
            +KG.Keller_WZ_Wandlicht because no DPT is assigned to GA 1/0/56. The GA is not connected to a device communication object in the ETS.
            +KG.Keller_EZ_Deckenleuchte because no DPT is assigned to GA 1/0/57. The GA is not connected to a device communication object in the ETS.
            +KG.Keller_Technikraum because no DPT is assigned to GA 1/0/58. The GA is not connected to a device communication object in the ETS.
            +KG.Neue_Gruppenadresse because no DPT is assigned to GA 1/0/59. The GA is not connected to a device communication object in the ETS.
            +KG.Neue_Gruppenadresse because no DPT is assigned to GA 1/0/60. The GA is not connected to a device communication object in the ETS.
            +KG.Springbrunnen because no DPT is assigned to GA 1/0/61. The GA is not connected to a device communication object in the ETS.
            +KG.Wohnzimmer_Easstisch_Licht because no DPT is assigned to GA 1/0/62. The GA is not connected to a device communication object in the ETS.
            +KG.Bad_TV because no DPT is assigned to GA 1/0/63. The GA is not connected to a device communication object in the ETS.
            +KG.Flur_hinten because no DPT is assigned to GA 1/0/64. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG.Flur_Strahler_schalten because no DPT is assigned to GA 1/1/0. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG.Paula_Strahler_schalten because no DPT is assigned to GA 1/1/1. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG.Anton_Strahler_schalten because no DPT is assigned to GA 1/1/2. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG.Emil_Strahler_schalten because no DPT is assigned to GA 1/1/3. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG.Gäste_Strahler_schalten because no DPT is assigned to GA 1/1/4. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG.Büro_Strahler_1_schalten because no DPT is assigned to GA 1/1/5. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG.Büro_Strahler_1_dimmen because no DPT is assigned to GA 1/1/6. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG.Büro_Strahler_1_HW because no DPT is assigned to GA 1/1/7. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG.Büro_Strahler_2_schalten because no DPT is assigned to GA 1/1/8. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG.Büro_Strahler_2_dimmen because no DPT is assigned to GA 1/1/9. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG.Büro_Strahler_2_HW because no DPT is assigned to GA 1/1/10. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG.Abstellraum_Decke_schalten because no DPT is assigned to GA 1/1/11. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG.Kinderbad_Strahler_schalten because no DPT is assigned to GA 1/1/12. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG.Kinderbad_Spiegel_schalten because no DPT is assigned to GA 1/1/13. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.Spitzboden.Spitzboden_Bel__1_schalten because no DPT is assigned to GA 1/2/0. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.Spitzboden.Spitzboden_Bel__2_schalten because no DPT is assigned to GA 1/2/1. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Wohnen_Strahler_1_schalten because no DPT is assigned to GA 1/3/0. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Wohnen_Strahler_1_dimmen because no DPT is assigned to GA 1/3/1. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Wohnen_Strahler_1_HW because no DPT is assigned to GA 1/3/2. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Wohnen_Strahler_2_schalten because no DPT is assigned to GA 1/3/3. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Wohnen_Strahler_2_dimmen because no DPT is assigned to GA 1/3/4. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Wohnen_Strahler_2_HW because no DPT is assigned to GA 1/3/5. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Wohnen_Wandlampen_schalten because no DPT is assigned to GA 1/3/6. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Wohnen_Wandlampen_dimmen because no DPT is assigned to GA 1/3/7. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Wohnen_Wandlampen_HW because no DPT is assigned to GA 1/3/8. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Essen_Pendelleuchte_schalten because no DPT is assigned to GA 1/3/9. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Küche_Strahler_schalten because no DPT is assigned to GA 1/3/10. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Küche_Strahler_dimmen because no DPT is assigned to GA 1/3/11. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Küche_Strahler_HW because no DPT is assigned to GA 1/3/12. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Küche_Bel__Wandschrank_schalten because no DPT is assigned to GA 1/3/13. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Küche_Bel__Hängeschrank_schalten because no DPT is assigned to GA 1/3/14. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Windfang_Strahler_schalten because no DPT is assigned to GA 1/3/15. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Flur_Strahler_schalten because no DPT is assigned to GA 1/3/16. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Schlafen_Strahler_schalten because no DPT is assigned to GA 1/3/17. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Schlafen_Wandlampe_schalten because no DPT is assigned to GA 1/3/18. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Ankleide_Strahler_schalten because no DPT is assigned to GA 1/3/19. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Bad_Strahler_schalten because no DPT is assigned to GA 1/3/20. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Bad_Spiegel_schalten because no DPT is assigned to GA 1/3/21. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Bad_Wanne_schalten because no DPT is assigned to GA 1/3/22. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Spielezimmer_Decke_schalten because no DPT is assigned to GA 1/3/23. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.WC_Strahler_schalten because no DPT is assigned to GA 1/3/24. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.Technik_Strahler_schalten because no DPT is assigned to GA 1/3/25. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.EG_RM.WC_Spiegel_schalten because no DPT is assigned to GA 1/3/26. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG_RM.Flur_Strahler_schalten because no DPT is assigned to GA 1/4/0. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG_RM.Paula_Strahler_schalten because no DPT is assigned to GA 1/4/1. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG_RM.Anton_Strahler_schalten because no DPT is assigned to GA 1/4/2. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG_RM.Emil_Strahler_schalten because no DPT is assigned to GA 1/4/3. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG_RM.Gäste_Strahler_schalten because no DPT is assigned to GA 1/4/4. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG_RM.Büro_Strahler_1_schalten because no DPT is assigned to GA 1/4/5. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG_RM.Büro_Strahler_1_dimmen because no DPT is assigned to GA 1/4/6. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG_RM.Büro_Strahler_1_HW because no DPT is assigned to GA 1/4/7. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG_RM.Büro_Strahler_2_schalten because no DPT is assigned to GA 1/4/8. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG_RM.Büro_Strahler_2_dimmen because no DPT is assigned to GA 1/4/9. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG_RM.Büro_Strahler_2_HW because no DPT is assigned to GA 1/4/10. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG_RM.Abstellraum_Decke_schalten because no DPT is assigned to GA 1/4/11. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG_RM.Kinderbad_Strahler_schalten because no DPT is assigned to GA 1/4/12. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.OG_RM.Kinderbad_Spiegel_schalten because no DPT is assigned to GA 1/4/13. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.Spitzboden_RM.Spitzboden_Bel__1_schalten because no DPT is assigned to GA 1/5/0. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.Spitzboden_RM.Spitzboden_Bel__2_schalten because no DPT is assigned to GA 1/5/1. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.Zentralfunktionen.Wohnen_Strahler_1+2_schalten
            because no DPT is assigned to GA 1/7/0. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.Zentralfunktionen.Wohnen_Strahler_1+2_dimmen because no DPT is assigned to GA 1/7/1. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.Zentralfunktionen.Wohnen_Strahler_1+2_HW because no DPT is assigned to GA 1/7/2. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.Zentralfunktionen.Trigger_BWM_kleiner_Flur_KG because no DPT is assigned to GA 1/7/3. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.Zentralfunktionen.Trigger_BWM_Impuls because no DPT is assigned to GA 1/7/4. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Innen.Zentralfunktionen.Sperrung_BWM_Windfang because no DPT is assigned to GA 1/7/5. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Eingangsbereich.Eingangsbeleuchtung_Treppe_schalten because no DPT is assigned to GA 2/3/0. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Eingangsbereich.Eingangsbeleuchtung_Treppe_RMSS because no DPT is assigned to GA 2/3/1. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Terrasse.Wandlampen_Terrasse_schalten because no DPT is assigned to GA 2/4/0. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Terrasse.Wandlampen_Terrasse_dimmen because no DPT is assigned to GA 2/4/1. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Terrasse.Wandlampen_Terrasse_Helligkeitswert because no DPT is assigned to GA 2/4/2. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Terrasse.Wandlampen_Terrasse_Rückm__Schaltstatus because no DPT is assigned to GA 2/4/3. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Terrasse.Wandlampen_Terrasse_Rückm__Helligkeitswert because no DPT is assigned to GA 2/4/4. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Terrasse.Wandlampe_Hauseingang_schalten because no DPT is assigned to GA 2/4/5. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Terrasse.Wandlampe_Hauseingang_dimmen because no DPT is assigned to GA 2/4/6. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Terrasse.Wandlampe_Hauseingang_HW because no DPT is assigned to GA 2/4/7. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Terrasse.Wandlampe_Hauseingang_RMSS because no DPT is assigned to GA 2/4/8. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Terrasse.Wandlampe_Hauseingang_RMHW because no DPT is assigned to GA 2/4/9. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Terrasse.Weihnachtsstern_schalten because no DPT is assigned to GA 2/4/10. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Balkon_OG.Balkonlicht_schalten because no DPT is assigned to GA 2/5/0. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Balkon_OG.Balkonlicht_RM because no DPT is assigned to GA 2/5/1. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Garage.Licht_Garage_schalten because no DPT is assigned to GA 2/6/0. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Garage.Licht_Garage_RMSS because no DPT is assigned to GA 2/6/1. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Garage.Licht_Garage_Automatik because no DPT is assigned to GA 2/6/2. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Garage.Außenlampen_vor_Garage_Werkstatt_schalten because no DPT is assigned to GA 2/6/3. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Garage.Außenlampen_vor_Garage_Werkstatt_RMSS because no DPT is assigned to GA 2/6/4. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Garage.Strahler_Durchgang_Garage_schalten because no DPT is assigned to GA 2/6/5. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Garage.Strahler_Durchgang_Garage_RMSS because no DPT is assigned to GA 2/6/6. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Garage.Strahler_vor_Garage_schalten because no DPT is assigned to GA 2/6/7. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Garage.Strahler_vor_Garage_RMSS because no DPT is assigned to GA 2/6/8. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Zentralfunktionen.Durchgang_Garage_+Wandl__Hauseingang_THF because no DPT is assigned to GA 2/7/0. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Zentralfunktionen.Dämmerung_AN_AUS because no DPT is assigned to GA 2/7/1. The GA is not connected to a device communication object in the ETS.
            Not adding Beleuchtung_Außen.Zentralfunktionen.Außenbeleuchtung_Komplett because no DPT is assigned to GA 2/7/3. The GA is not connected to a device communication object in the ETS.
            Not adding Heizung.EG.HK_Küche because no DPT is assigned to GA 3/0/1. The GA is not connected to a device communication object in the ETS.
            Not adding Heizung.EG.HK_Schlafen_Ankleide because no DPT is assigned to GA 3/0/2. The GA is not connected to a device communication object in the ETS.
            Not adding Heizung.EG.HK_WC_Flur because no DPT is assigned to GA 3/0/3. The GA is not connected to a device communication object in the ETS.
            Not adding Heizung.EG.HK_Spielezimmer because no DPT is assigned to GA 3/0/4. The GA is not connected to a device communication object in the ETS.
            Not adding Heizung.EG.Warmwasser_Wärmepumpe
            because no DPT is assigned to GA 3/0/6. The GA is not connected to a device communication object in the ETS.
            Not adding Heizung.OG.HK_Paula because no DPT is assigned to GA 3/1/0. The GA is not connected to a device communication object in the ETS.
            Not adding Heizung.OG.HK_Anton because no DPT is assigned to GA 3/1/1. The GA is not connected to a device communication object in the ETS.
            Not adding Heizung.OG.HK_Emil because no DPT is assigned to GA 3/1/2. The GA is not connected to a device communication object in the ETS.
            Not adding Heizung.OG.HK_Gäste_Flur because no DPT is assigned to GA 3/1/3. The GA is not connected to a device communication object in the ETS.
            Not adding Heizung.OG.HK_Büro because no DPT is assigned to GA 3/1/4. The GA is not connected to a device communication object in the ETS.
            Not adding Heizung.OG.HK_Kinderbad because no DPT is assigned to GA 3/1/5. The GA is not connected to a device communication object in the ETS.
            Not adding Heizung.Zentralfunktionen.Zentralumschaltung_Komfort because no DPT is assigned to GA 3/7/0. The GA is not connected to a device communication object in the ETS.
            Not adding Heizung.Zentralfunktionen.Zentralumschaltung_Standby because no DPT is assigned to GA 3/7/1. The GA is not connected to a device communication object in the ETS.
            Not adding Heizung.Zentralfunktionen.Zentralumschaltung_Nacht because no DPT is assigned to GA 3/7/2. The GA is not connected to a device communication object in the ETS.
            Not adding Heizung.Zentralfunktionen.Betriebsmodusumschaltung because no DPT is assigned to GA 3/7/3. The GA is not connected to a device communication object in the ETS.
            Not adding Heizung.Zentralfunktionen.Präsenzmelderbetrieb because no DPT is assigned to GA 3/7/4. The GA is not connected to a device communication object in the ETS.
            Not adding Lüftung+Beregnung.KG.Lüfter_WC_Zimmer_1_schalten because no DPT is assigned to GA 4/0/0. The GA is not connected to a device communication object in the ETS.
            Not adding Lüftung+Beregnung.KG.Lüfter_WC_Zimmer_1_schalten_RMSS because no DPT is assigned to GA 4/0/1. The GA is not connected to a device communication object in the ETS.
            Not adding Lüftung+Beregnung.KG.Lüfter_WC_Zimmer_1_schalten_Nachlauf because no DPT is assigned to GA 4/0/2. The GA is not connected to a device communication object in the ETS.
            Not adding Lüftung+Beregnung.KG.Lüfter_WC_Zimmer_2_schalten because no DPT is assigned to GA 4/0/3. The GA is not connected to a device communication object in the ETS.
            Not adding Lüftung+Beregnung.KG.Lüfter_WC_Zimmer_2_schalten_RMSS because no DPT is assigned to GA 4/0/4. The GA is not connected to a device communication object in the ETS.
            Not adding Lüftung+Beregnung.KG.Lüfter_WC_Zimmer_2_schalten_Nachlauf because no DPT is assigned to GA 4/0/5. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_1_fahren because no DPT is assigned to GA 5/0/0. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_1_verstellen because no DPT is assigned to GA 5/0/1. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_1_Pos because no DPT is assigned to GA 5/0/2. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_2_fahren because no DPT is assigned to GA 5/0/3. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_2_verstellen because no DPT is assigned to GA 5/0/4. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_2_Pos because no DPT is assigned to GA 5/0/5. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_3_fahren because no DPT is assigned to GA 5/0/6. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_3_verstellen because no DPT is assigned to GA 5/0/7. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_3_Pos because no DPT is assigned to GA 5/0/8. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Esszimmer_Rollo_fahren because no DPT is assigned to GA 5/0/9. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Esszimmer_Rollo_verstellen because no DPT is assigned to GA 5/0/10. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Esszimmer_Rollo_Pos because no DPT is assigned to GA 5/0/11. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Küche_Rollo_1_fahren because no DPT is assigned to GA 5/0/12. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Küche_Rollo_1_verstellen because no DPT is assigned to GA 5/0/13. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Küche_Rollo_1_Pos because no DPT is assigned to GA 5/0/14. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Küche_Rollo_2_fahren because no DPT is assigned to GA 5/0/15. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Küche_Rollo_2_verstellen because no DPT is assigned to GA 5/0/16. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Küche_Rollo_2_Pos because no DPT is assigned to GA 5/0/17. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Schlafen_Rollo_fahren because no DPT is assigned to GA 5/0/18. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Schlafen_Rollo_verstellen because no DPT is assigned to GA 5/0/19. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Schlafen_Rollo_Pos because no DPT is assigned to GA 5/0/20. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Ankleide_Rollo_1_fahren because no DPT is assigned to GA 5/0/21. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Ankleide_Rollo_1_verstellen because no DPT is assigned to GA 5/0/22. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Ankleide_Rollo_1_Pos because no DPT is assigned to GA 5/0/23. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Ankleide_Rollo_2_fahren because no DPT is assigned to GA 5/0/24. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Ankleide_Rollo_2_verstellen because no DPT is assigned to GA 5/0/25. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Ankleide_Rollo_2_Pos because no DPT is assigned to GA 5/0/26. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.WC_Rollo_fahren because no DPT is assigned to GA 5/0/27. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.WC_Rollo_verstellen because no DPT is assigned to GA 5/0/28. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.WC_Rollo_Pos because no DPT is assigned to GA 5/0/29. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Spielezimmer_Rollo_fahren because no DPT is assigned to GA 5/0/30. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Spielezimmer_Rollo_verstellen because no DPT is assigned to GA 5/0/31. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Spielezimmer_Rollo_Pos because no DPT is assigned to GA 5/0/32. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Bad_Rollo_fahren because no DPT is assigned to GA 5/0/33. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Bad_Rollo_verstellen because no DPT is assigned to GA 5/0/34. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Bad_Rollo_Pos because no DPT is assigned to GA 5/0/35. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Zimmer_1_Rollo_fahren because no DPT is assigned to GA 5/0/36. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Zimmer_1_Rollo_verstellen because no DPT is assigned to GA 5/0/37. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Zimmer_1_Rollo_Pos because no DPT is assigned to GA 5/0/38. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Zimmer_2_Rollo_li_fahren because no DPT is assigned to GA 5/0/39. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Zimmer_2_Rollo_li_verstellen because no DPT is assigned to GA 5/0/40. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Zimmer_2_Rollo_li_Pos because no DPT is assigned to GA 5/0/41. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Zimmer_2_Rollo_re_fahren because no DPT is assigned to GA 5/0/42. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Zimmer_2_Rollo_re_verstellen because no DPT is assigned to GA 5/0/43. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Zimmer_2_Rollo_re_Pos because no DPT is assigned to GA 5/0/44. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Anbau_hinten_Rollo_fahren because no DPT is assigned to GA 5/0/45. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Anbau_hinten_Rollo_verstellen because no DPT is assigned to GA 5/0/46. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Anbau_hinten_Rollo_Pos because no DPT is assigned to GA 5/0/47. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Anbau_hinten_Rollo_RMPos because no DPT is assigned to GA 5/0/48. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Garderobe_Rollo_1_Fahren because no DPT is assigned to GA 5/0/49. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Garderobe_Rollo_1_verstellen because no DPT is assigned to GA 5/0/50. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Garderobe_Rollo_1_Pos because no DPT is assigned to GA 5/0/51. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Keller_Jalousie_Fahren because no DPT is assigned to GA 5/0/52. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Keller_Jalousie_Verstellen because no DPT is assigned to GA 5/0/53. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG+KG.Keller_Jalousie_Pos because no DPT is assigned to GA 5/0/54. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG.Paula_Rollo_fahren because no DPT is assigned to GA 5/1/0. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG.Paula_Rollo_verstellen because no DPT is assigned to GA 5/1/1. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG.Paula_Rollo_Pos because no DPT is assigned to GA 5/1/2. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG.Anton_Rollo_fahren because no DPT is assigned to GA 5/1/3. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG.Anton_Rollo_verstellen because no DPT is assigned to GA 5/1/4. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG.Anton_Rollo_Pos because no DPT is assigned to GA 5/1/5. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG.Büro_Rollo_1_fahren because no DPT is assigned to GA 5/1/6. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG.Büro_Rollo_1_verstellen because no DPT is assigned to GA 5/1/7. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG.Büro_Rollo_1_Pos because no DPT is assigned to GA 5/1/8. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG.Büro_Rollo_2_fahren because no DPT is assigned to GA 5/1/9. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG.Büro_Rollo_2_verstellen because no DPT is assigned to GA 5/1/10. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG.Büro_Rollo_2_Pos because no DPT is assigned to GA 5/1/11. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG.Büro_Rollo_3_fahren because no DPT is assigned to GA 5/1/12. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG.Büro_Rollo_3_verstellen because no DPT is assigned to GA 5/1/13. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG.Büro_Rollo_3_Pos because no DPT is assigned to GA 5/1/14. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_1_fahren because no DPT is assigned to GA 5/2/0. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_1_verstellen because no DPT is assigned to GA 5/2/1. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_1_Pos because no DPT is assigned to GA 5/2/2. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_2_fahren because no DPT is assigned to GA 5/2/3. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_2_verstellen because no DPT is assigned to GA 5/2/4. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_2_Pos because no DPT is assigned to GA 5/2/5. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_3_fahren because no DPT is assigned to GA 5/2/6. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_3_verstellen because no DPT is assigned to GA 5/2/7. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_3_Pos because no DPT is assigned to GA 5/2/8. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Esszimmer_Rollo_fahren because no DPT is assigned to GA 5/2/9. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Esszimmer_Rollo_verstellen because no DPT is assigned to GA 5/2/10. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Esszimmer_Rollo_Pos because no DPT is assigned to GA 5/2/11. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Küche_Rollo_1_fahren because no DPT is assigned to GA 5/2/12. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Küche_Rollo_1_verstellen because no DPT is assigned to GA 5/2/13. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Küche_Rollo_1_Pos because no DPT is assigned to GA 5/2/14. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Küche_Rollo_2_fahren because no DPT is assigned to GA 5/2/15. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Küche_Rollo_2_verstellen because no DPT is assigned to GA 5/2/16. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Küche_Rollo_2_Pos because no DPT is assigned to GA 5/2/17. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Schlafen_Rollo_fahren because no DPT is assigned to GA 5/2/18. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Schlafen_Rollo_verstellen because no DPT is assigned to GA 5/2/19. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Schlafen_Rollo_Pos because no DPT is assigned to GA 5/2/20. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Ankleide_Rollo_1_fahren because no DPT is assigned to GA 5/2/21. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Ankleide_Rollo_1_verstellen because no DPT is assigned to GA 5/2/22. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Ankleide_Rollo_1_Pos because no DPT is assigned to GA 5/2/23. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Ankleide_Rollo_2_fahren because no DPT is assigned to GA 5/2/24. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Ankleide_Rollo_2_verstellen because no DPT is assigned to GA 5/2/25. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Ankleide_Rollo_2_Pos because no DPT is assigned to GA 5/2/26. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.WC_Rollo_fahren because no DPT is assigned to GA 5/2/27. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.WC_Rollo_verstellen because no DPT is assigned to GA 5/2/28. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.WC_Rollo_Pos because no DPT is assigned to GA 5/2/29. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Spielezimmer_Rollo_fahren because no DPT is assigned to GA 5/2/30. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Spielezimmer_Rollo_verstellen because no DPT is assigned to GA 5/2/31. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Spielezimmer_Rollo_Pos because no DPT is assigned to GA 5/2/32. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Bad_Rollo_fahren because no DPT is assigned to GA 5/2/33. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Bad_Rollo_verstellen because no DPT is assigned to GA 5/2/34. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Bad_Rollo_Pos because no DPT is assigned to GA 5/2/35. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Zimmer_1_Rollo_fahren because no DPT is assigned to GA 5/2/36. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Zimmer_1_Rollo_verstellen because no DPT is assigned to GA 5/2/37. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Zimmer_1_Rollo_Pos because no DPT is assigned to GA 5/2/38. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Zimmer_2_Rollo_li_fahren because no DPT is assigned to GA 5/2/39. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Zimmer_2_Rollo_li_verstellen because no DPT is assigned to GA 5/2/40. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Zimmer_2_Rollo_li_Pos because no DPT is assigned to GA 5/2/41. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Zimmer_2_Rollo_re_fahren because no DPT is assigned to GA 5/2/42. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Zimmer_2_Rollo_re_verstellen because no DPT is assigned to GA 5/2/43. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.EG_RM.Zimmer_2_Rollo_re_Pos because no DPT is assigned to GA 5/2/44. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG_RM.Paula_Rollo_fahren because no DPT is assigned to GA 5/3/0. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG_RM.Paula_Rollo_verstellen because no DPT is assigned to GA 5/3/1. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG_RM.Paula_Rollo_Pos because no DPT is assigned to GA 5/3/2. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG_RM.Anton_Rollo_fahren because no DPT is assigned to GA 5/3/3. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG_RM.Anton_Rollo_verstellen because no DPT is assigned to GA 5/3/4. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG_RM.Anton_Rollo_Pos because no DPT is assigned to GA 5/3/5. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_1_fahren because no DPT is assigned to GA 5/3/6. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_1_verstellen because no DPT is assigned to GA 5/3/7. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_1_Pos because no DPT is assigned to GA 5/3/8. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_2_fahren because no DPT is assigned to GA 5/3/9. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_2_verstellen because no DPT is assigned to GA 5/3/10. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_2_Pos because no DPT is assigned to GA 5/3/11. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_3_fahren because no DPT is assigned to GA 5/3/12. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_3_verstellen because no DPT is assigned to GA 5/3/13. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_3_Pos because no DPT is assigned to GA 5/3/14. The GA is not connected to a device communication object in the ETS.
            Rollos+Verschattung.Markise_Balkon.Markise_Fahren_Balkon has only set base DPT DPT1 in ETS. No additional informations (e.g. unit) available for this GA.
            Not adding Rollos+Verschattung.Zentralfunktionen.Wohnen_1-3_fahren because no DPT is assigned to GA 5/7/0. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.Zentralfunktionen.Wohnen_1-3_verstellen because no DPT is assigned to GA 5/7/1. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.Zentralfunktionen.Wohnen_1-3_Pos because no DPT is assigned to GA 5/7/2. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.Zentralfunktionen.Ankleide_1+2_fahren because no DPT is assigned to GA 5/7/3. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.Zentralfunktionen.Ankleide_1+2_verstellen because no DPT is assigned to GA 5/7/4. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.Zentralfunktionen.Zimmer_2_KG_Rollos_fahren because no DPT is assigned to GA 5/7/5. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.Zentralfunktionen.Zimmer_2_KG_Rollos_verstellen because no DPT is assigned to GA 5/7/6. The GA is not connected to a device communication object in the ETS.
            Not adding Rollos+Verschattung.Zentralfunktionen.Zimmer_2_KG_Rollos_Pos because no DPT is assigned to GA 5/7/7. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.EG.Wohnen_Steckd_1_schalten because no DPT is assigned to GA 6/0/0. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.EG.Wohnen_Steckd_2_schalten because no DPT is assigned to GA 6/0/1. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.EG.Esszimmer_Steckd_schalten because no DPT is assigned to GA 6/0/2. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.EG.Küche_Steckd_schalten because no DPT is assigned to GA 6/0/3. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.EG.Flur_Steckd_schalten because no DPT is assigned to GA 6/0/4. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.EG.Schlafen_Steckd_li_Bett_schalten because no DPT is assigned to GA 6/0/5. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.EG.Schlafen_Steckd_re_Bett_schalten because no DPT is assigned to GA 6/0/6. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.EG.Spielezimmer_Steckd_schalten because no DPT is assigned to GA 6/0/7. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.EG.Bad_Radio_schalten because no DPT is assigned to GA 6/0/8. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.EG.Ankleide_Steckd_schalten because no DPT is assigned to GA 6/0/9. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.OG.Büro_Steckdosen_1_schalten because no DPT is assigned to GA 6/1/0. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.OG.Büro_Steckdosen_2_schalten because no DPT is assigned to GA 6/1/1. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.OG.Büro_Steckdosen_1_RM because no DPT is assigned to GA 6/1/2. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.OG.Büro_Steckdosen_2_RM because no DPT is assigned to GA 6/1/3. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.EG_RM.Wohnen_Steckd_1_schalten because no DPT is assigned to GA 6/3/0. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.EG_RM.Wohnen_Steckd_2_schalten because no DPT is assigned to GA 6/3/1. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.EG_RM.Esszimmer_Steckd_schalten because no DPT is assigned to GA 6/3/2. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.EG_RM.Küche_Steckd_schalten because no DPT is assigned to GA 6/3/3. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.EG_RM.Flur_Steckd_schalten because no DPT is assigned to GA 6/3/4. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.EG_RM.Schlafen_Steckd_li_Bett_schalten because no DPT is assigned to GA 6/3/5. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.EG_RM.Schlafen_Steckd_re_Bett_schalten because no DPT is assigned to GA 6/3/6. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.EG_RM.Spielezimmer_Steckd_schalten because no DPT is assigned to GA 6/3/7. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.EG_RM.Bad_Radio_schalten because no DPT is assigned to GA 6/3/8. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.EG_RM.Ankleide_Steckd_schalten because no DPT is assigned to GA 6/3/9. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.Terrasse.Balkon_Steckdose_Straße because no DPT is assigned to GA 6/4/0. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.Terrasse.Neue_Gruppenadresse because no DPT is assigned to GA 6/4/1. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.Garten.Steckdose_linke_Hausseite_schalten because no DPT is assigned to GA 6/5/0. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.Garten.Steckdose_linke_Hausseite_dimmen because no DPT is assigned to GA 6/5/1. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.Garten.Steckdose_linke_Hausseite_Helligkeitswert because no DPT is assigned to GA 6/5/2. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.Garten.Steckdose_linke_Hausseite_Rückm__Schaltstatus because no DPT is assigned to GA 6/5/3. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.Garten.Steckdose_linke_Hausseite_Rück__Helligkeitswert because no DPT is assigned to GA 6/5/4. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.Garten.Steckdose_rechte_Hausseite_schalten because no DPT is assigned to GA 6/5/5. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.Garten.Steckdose_rechte_Hausseite_dimmen because no DPT is assigned to GA 6/5/6. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.Garten.Steckdose_rechte_Hausseite_Helligkeitswert because no DPT is assigned to GA 6/5/7. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.Garten.Steckdose_rechte_Hausseite_Rückm__Schaltstatus because no DPT is assigned to GA 6/5/8. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.Garten.Steckdose_rechte_Hausseite_Rückm__Helligkeitswert because no DPT is assigned to GA 6/5/9. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.Balkon_OG.Balkonsteckdose_schalten because no DPT is assigned to GA 6/6/0. The GA is not connected to a device communication object in the ETS.
            Not adding Steckdosen.Balkon_OG.Balkonsteckdose_RM because no DPT is assigned to GA 6/6/1. The GA is not connected to a device communication object in the ETS.
            Not adding Wetter_Zeit_Datum_Alarm.Daten.Türöffner_Haustür because no DPT is assigned to GA 7/0/2. The GA is not connected to a device communication object in the ETS.
            Not adding Wetter_Zeit_Datum_Alarm.Daten.RM_Türöffner_Haustür because no DPT is assigned to GA 7/0/3. The GA is not connected to a device communication object in the ETS.
            Not adding Wetter_Zeit_Datum_Alarm.Daten.Freigabe_Datum because no DPT is assigned to GA 7/0/4. The GA is not connected to a device communication object in the ETS.
            Not adding Wetter_Zeit_Datum_Alarm.Daten.Freigabe_Uhrzeit because no DPT is assigned to GA 7/0/5. The GA is not connected to a device communication object in the ETS.
            Not adding Wetter_Zeit_Datum_Alarm.Bewegungsmelder.Meldung_Haupt_Nebenstelle_Flur_EG because no DPT is assigned to GA 7/1/0. The GA is not connected to a device communication object in the ETS.
            Not adding Wetter_Zeit_Datum_Alarm.Rauchmelder.Rauchmelder_Alarm_manuell_starten because no DPT is assigned to GA 7/2/0. The GA is not connected to a device communication object in the ETS.
            Not adding Wetter_Zeit_Datum_Alarm.Rauchmelder.Rauchmelder_ALARM because no DPT is assigned to GA 7/2/1. The GA is not connected to a device communication object in the ETS.
            See log for more information
            OK
            DJMarc75D L 2 Antworten Letzte Antwort
            • T tomtulli
              @lessthanmore
              Imported 9 states successfully
              Not adding Lichtszenen.Lichtszene.Lichtszene because no DPT is assigned to GA 0/0/1. The GA is not connected to a device communication object in the ETS.
              Not adding Lichtszenen.Lichtszene.Gesamthelligkeit because no DPT is assigned to GA 0/0/2. The GA is not connected to a device communication object in the ETS.
              Not adding Lichtszenen.Lichtszene.Umgebungshelligkeit because no DPT is assigned to GA 0/0/3. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_+KG.Wohnen_Strahler_1_schalten because no DPT is assigned to GA 1/0/0. The GA is not connected to a device communication object in the ETS.
              +KG.Wohnen_Strahler_1_dimmen because no DPT is assigned to GA 1/0/1. The GA is not connected to a device communication object in the ETS.
              +KG.Wohnen_Strahler_1_HW because no DPT is assigned to GA 1/0/2. The GA is not connected to a device communication object in the ETS.
              +KG.Wohnen_Strahler_2_schalten because no DPT is assigned to GA 1/0/3. The GA is not connected to a device communication object in the ETS.
              +KG.Wohnen_Strahler_2_dimmen because no DPT is assigned to GA 1/0/4. The GA is not connected to a device communication object in the ETS.
              +KG.Wohnen_Strahler_2_HW because no DPT is assigned to GA 1/0/5. The GA is not connected to a device communication object in the ETS.
              +KG.Wohnen_Wandlampen_schalten because no DPT is assigned to GA 1/0/6. The GA is not connected to a device communication object in the ETS.
              +KG.Wohnen_Wandlampen_dimmen because no DPT is assigned to GA 1/0/7. The GA is not connected to a device communication object in the ETS.
              +KG.Wohnen_Wandlampen_HW because no DPT is assigned to GA 1/0/8. The GA is not connected to a device communication object in the ETS.
              +KG.Essen_Pendelleuchte_schalten because no DPT is assigned to GA 1/0/9. The GA is not connected to a device communication object in the ETS.
              +KG.Küche_Strahler_schalten because no DPT is assigned to GA 1/0/10. The GA is not connected to a device communication object in the ETS.
              +KG.Küche_Strahler_dimmen because no DPT is assigned to GA 1/0/11. The GA is not connected to a device communication object in the ETS.
              +KG.Küche_Strahler_HW because no DPT is assigned to GA 1/0/12. The GA is not connected to a device communication object in the ETS.
              +KG.Beleuchtung_Tersasse_Hinten because no DPT is assigned to GA 1/0/13. The GA is not connected to a device communication object in the ETS.
              +KG.Küche_Bel__Hängeschrank_schalten because no DPT is assigned to GA 1/0/14. The GA is not connected to a device communication object in the ETS.
              +KG.Windfang_Strahler_schalten because no DPT is assigned to GA 1/0/15. The GA is not connected to a device communication object in the ETS.
              +KG.Flur_Strahler_schalten because no DPT is assigned to GA 1/0/16. The GA is not connected to a device communication object in the ETS.
              +KG.Schlafen_Strahler_schalten because no DPT is assigned to GA 1/0/17. The GA is not connected to a device communication object in the ETS.
              +KG.Schlafen_Wandlampe_schalten because no DPT is assigned to GA 1/0/18. The GA is not connected to a device communication object in the ETS.
              +KG.Ankleide_Strahler_schalten because no DPT is assigned to GA 1/0/19. The GA is not connected to a device communication object in the ETS.
              +KG.Bad_Strahler_schalten because no DPT is assigned to GA 1/0/20. The GA is not connected to a device communication object in the ETS.
              +KG.Bad_Spiegel_schalten because no DPT is assigned to GA 1/0/21. The GA is not connected to a device communication object in the ETS.
              +KG.Bad_Wanne_schalten because no DPT is assigned to GA 1/0/22. The GA is not connected to a device communication object in the ETS.
              +KG.Spielezimmer_Decke_schalten because no DPT is assigned to GA 1/0/23. The GA is not connected to a device communication object in the ETS.
              +KG.WC_Strahler_schalten because no DPT is assigned to GA 1/0/24. The GA is not connected to a device communication object in the ETS.
              +KG.Technik_Strahler_schalten because no DPT is assigned to GA 1/0/25. The GA is not connected to a device communication object in the ETS.
              +KG.WC_Spiegel_schalten because no DPT is assigned to GA 1/0/26. The GA is not connected to a device communication object in the ETS.
              +KG.Keller_Wohnzimmerlicht_Decke_Schalten because no DPT is assigned to GA 1/0/27. The GA is not connected to a device communication object in the ETS.
              +KG.Garage_Beleuchtung_schalten_RMSS because no DPT is assigned to GA 1/0/28. The GA is not connected to a device communication object in the ETS.
              +KG.Keller_Wohnung_Flurlicht_Schalten because no DPT is assigned to GA 1/0/29. The GA is not connected to a device communication object in the ETS.
              +KG.Zimmer_1_Licht_Wohnen_schalten_RMSS because no DPT is assigned to GA 1/0/30. The GA is not connected to a device communication object in the ETS.
              +KG.Keller_Wohnung_Bad_Deckenlicht_Schalten because no DPT is assigned to GA 1/0/31. The GA is not connected to a device communication object in the ETS.
              +KG.Zimmer_1_Licht_Decke_WC_schalten_RMSS because no DPT is assigned to GA 1/0/32. The GA is not connected to a device communication object in the ETS.
              +KG.Zimmer_1_Licht_Spiegel_WC_schalten because no DPT is assigned to GA 1/0/33. The GA is not connected to a device communication object in the ETS.
              +KG.Zimmer_1_Licht_Spiegel_WC_schalten_RMSS because no DPT is assigned to GA 1/0/34. The GA is not connected to a device communication object in the ETS.
              +KG.Keller_Wohnung_SZ_Licht_Decke_Schalten because no DPT is assigned to GA 1/0/35. The GA is not connected to a device communication object in the ETS.
              +KG.Zimmer_2_Licht_Wohnen_schalten_RMSS because no DPT is assigned to GA 1/0/36. The GA is not connected to a device communication object in the ETS.
              +KG.KG_SZ_Bett_Links because no DPT is assigned to GA 1/0/37. The GA is not connected to a device communication object in the ETS.
              +KG.Zimmer_2_Licht_Decke_WC_schalten_RMSS because no DPT is assigned to GA 1/0/38. The GA is not connected to a device communication object in the ETS.
              +KG.KG_SZ_Licht_Bett_Rechts because no DPT is assigned to GA 1/0/39. The GA is not connected to a device communication object in the ETS.
              +KG.Zimmer_2_Licht_Spiegel_WC_schalten_RMSS because no DPT is assigned to GA 1/0/40. The GA is not connected to a device communication object in the ETS.
              +KG.Flur_KG_Strahler_schalten because no DPT is assigned to GA 1/0/41. The GA is not connected to a device communication object in the ETS.
              +KG.Flur_KG_Strahler_schalten_RMSS because no DPT is assigned to GA 1/0/42. The GA is not connected to a device communication object in the ETS.
              +KG.Holzlager_Licht_schalten because no DPT is assigned to GA 1/0/43. The GA is not connected to a device communication object in the ETS.
              +KG.Holzlager_Licht_schalten_RMSS because no DPT is assigned to GA 1/0/44. The GA is not connected to a device communication object in the ETS.
              +KG.Flur_vor_Treppe_KG_schalten because no DPT is assigned to GA 1/0/45. The GA is not connected to a device communication object in the ETS.
              +KG.Flur_vor_Treppe_KG_schalten_RMSS because no DPT is assigned to GA 1/0/46. The GA is not connected to a device communication object in the ETS.
              +KG.LED_Strahler_Treppe_schalten because no DPT is assigned to GA 1/0/47. The GA is not connected to a device communication object in the ETS.
              +KG.LED_Strahler_Treppe_schalten_RMSS because no DPT is assigned to GA 1/0/48. The GA is not connected to a device communication object in the ETS.
              +KG.Ecklampe_Treppe_schalten because no DPT is assigned to GA 1/0/49. The GA is not connected to a device communication object in the ETS.
              +KG.Ecklampe_Treppe_schalten_RMSS because no DPT is assigned to GA 1/0/50. The GA is not connected to a device communication object in the ETS.
              +KG.Anbau_vorn_Lampe_schalten because no DPT is assigned to GA 1/0/51. The GA is not connected to a device communication object in the ETS.
              +KG.Anbau_vorn_Lampe_RMSS because no DPT is assigned to GA 1/0/52. The GA is not connected to a device communication object in the ETS.
              +KG.Anbau_hinten_Lampe_schalten because no DPT is assigned to GA 1/0/53. The GA is not connected to a device communication object in the ETS.
              +KG.Anbau_hinten_Lampe_RMSS because no DPT is assigned to GA 1/0/54. The GA is not connected to a device communication object in the ETS.
              +KG.HWR_Keller_Licht because no DPT is assigned to GA 1/0/55. The GA is not connected to a device communication object in the ETS.
              +KG.Keller_WZ_Wandlicht because no DPT is assigned to GA 1/0/56. The GA is not connected to a device communication object in the ETS.
              +KG.Keller_EZ_Deckenleuchte because no DPT is assigned to GA 1/0/57. The GA is not connected to a device communication object in the ETS.
              +KG.Keller_Technikraum because no DPT is assigned to GA 1/0/58. The GA is not connected to a device communication object in the ETS.
              +KG.Neue_Gruppenadresse because no DPT is assigned to GA 1/0/59. The GA is not connected to a device communication object in the ETS.
              +KG.Neue_Gruppenadresse because no DPT is assigned to GA 1/0/60. The GA is not connected to a device communication object in the ETS.
              +KG.Springbrunnen because no DPT is assigned to GA 1/0/61. The GA is not connected to a device communication object in the ETS.
              +KG.Wohnzimmer_Easstisch_Licht because no DPT is assigned to GA 1/0/62. The GA is not connected to a device communication object in the ETS.
              +KG.Bad_TV because no DPT is assigned to GA 1/0/63. The GA is not connected to a device communication object in the ETS.
              +KG.Flur_hinten because no DPT is assigned to GA 1/0/64. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG.Flur_Strahler_schalten because no DPT is assigned to GA 1/1/0. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG.Paula_Strahler_schalten because no DPT is assigned to GA 1/1/1. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG.Anton_Strahler_schalten because no DPT is assigned to GA 1/1/2. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG.Emil_Strahler_schalten because no DPT is assigned to GA 1/1/3. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG.Gäste_Strahler_schalten because no DPT is assigned to GA 1/1/4. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG.Büro_Strahler_1_schalten because no DPT is assigned to GA 1/1/5. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG.Büro_Strahler_1_dimmen because no DPT is assigned to GA 1/1/6. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG.Büro_Strahler_1_HW because no DPT is assigned to GA 1/1/7. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG.Büro_Strahler_2_schalten because no DPT is assigned to GA 1/1/8. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG.Büro_Strahler_2_dimmen because no DPT is assigned to GA 1/1/9. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG.Büro_Strahler_2_HW because no DPT is assigned to GA 1/1/10. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG.Abstellraum_Decke_schalten because no DPT is assigned to GA 1/1/11. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG.Kinderbad_Strahler_schalten because no DPT is assigned to GA 1/1/12. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG.Kinderbad_Spiegel_schalten because no DPT is assigned to GA 1/1/13. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.Spitzboden.Spitzboden_Bel__1_schalten because no DPT is assigned to GA 1/2/0. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.Spitzboden.Spitzboden_Bel__2_schalten because no DPT is assigned to GA 1/2/1. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Wohnen_Strahler_1_schalten because no DPT is assigned to GA 1/3/0. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Wohnen_Strahler_1_dimmen because no DPT is assigned to GA 1/3/1. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Wohnen_Strahler_1_HW because no DPT is assigned to GA 1/3/2. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Wohnen_Strahler_2_schalten because no DPT is assigned to GA 1/3/3. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Wohnen_Strahler_2_dimmen because no DPT is assigned to GA 1/3/4. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Wohnen_Strahler_2_HW because no DPT is assigned to GA 1/3/5. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Wohnen_Wandlampen_schalten because no DPT is assigned to GA 1/3/6. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Wohnen_Wandlampen_dimmen because no DPT is assigned to GA 1/3/7. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Wohnen_Wandlampen_HW because no DPT is assigned to GA 1/3/8. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Essen_Pendelleuchte_schalten because no DPT is assigned to GA 1/3/9. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Küche_Strahler_schalten because no DPT is assigned to GA 1/3/10. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Küche_Strahler_dimmen because no DPT is assigned to GA 1/3/11. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Küche_Strahler_HW because no DPT is assigned to GA 1/3/12. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Küche_Bel__Wandschrank_schalten because no DPT is assigned to GA 1/3/13. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Küche_Bel__Hängeschrank_schalten because no DPT is assigned to GA 1/3/14. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Windfang_Strahler_schalten because no DPT is assigned to GA 1/3/15. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Flur_Strahler_schalten because no DPT is assigned to GA 1/3/16. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Schlafen_Strahler_schalten because no DPT is assigned to GA 1/3/17. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Schlafen_Wandlampe_schalten because no DPT is assigned to GA 1/3/18. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Ankleide_Strahler_schalten because no DPT is assigned to GA 1/3/19. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Bad_Strahler_schalten because no DPT is assigned to GA 1/3/20. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Bad_Spiegel_schalten because no DPT is assigned to GA 1/3/21. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Bad_Wanne_schalten because no DPT is assigned to GA 1/3/22. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Spielezimmer_Decke_schalten because no DPT is assigned to GA 1/3/23. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.WC_Strahler_schalten because no DPT is assigned to GA 1/3/24. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.Technik_Strahler_schalten because no DPT is assigned to GA 1/3/25. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.EG_RM.WC_Spiegel_schalten because no DPT is assigned to GA 1/3/26. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG_RM.Flur_Strahler_schalten because no DPT is assigned to GA 1/4/0. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG_RM.Paula_Strahler_schalten because no DPT is assigned to GA 1/4/1. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG_RM.Anton_Strahler_schalten because no DPT is assigned to GA 1/4/2. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG_RM.Emil_Strahler_schalten because no DPT is assigned to GA 1/4/3. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG_RM.Gäste_Strahler_schalten because no DPT is assigned to GA 1/4/4. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG_RM.Büro_Strahler_1_schalten because no DPT is assigned to GA 1/4/5. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG_RM.Büro_Strahler_1_dimmen because no DPT is assigned to GA 1/4/6. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG_RM.Büro_Strahler_1_HW because no DPT is assigned to GA 1/4/7. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG_RM.Büro_Strahler_2_schalten because no DPT is assigned to GA 1/4/8. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG_RM.Büro_Strahler_2_dimmen because no DPT is assigned to GA 1/4/9. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG_RM.Büro_Strahler_2_HW because no DPT is assigned to GA 1/4/10. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG_RM.Abstellraum_Decke_schalten because no DPT is assigned to GA 1/4/11. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG_RM.Kinderbad_Strahler_schalten because no DPT is assigned to GA 1/4/12. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.OG_RM.Kinderbad_Spiegel_schalten because no DPT is assigned to GA 1/4/13. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.Spitzboden_RM.Spitzboden_Bel__1_schalten because no DPT is assigned to GA 1/5/0. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.Spitzboden_RM.Spitzboden_Bel__2_schalten because no DPT is assigned to GA 1/5/1. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.Zentralfunktionen.Wohnen_Strahler_1+2_schalten
              because no DPT is assigned to GA 1/7/0. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.Zentralfunktionen.Wohnen_Strahler_1+2_dimmen because no DPT is assigned to GA 1/7/1. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.Zentralfunktionen.Wohnen_Strahler_1+2_HW because no DPT is assigned to GA 1/7/2. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.Zentralfunktionen.Trigger_BWM_kleiner_Flur_KG because no DPT is assigned to GA 1/7/3. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.Zentralfunktionen.Trigger_BWM_Impuls because no DPT is assigned to GA 1/7/4. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Innen.Zentralfunktionen.Sperrung_BWM_Windfang because no DPT is assigned to GA 1/7/5. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Eingangsbereich.Eingangsbeleuchtung_Treppe_schalten because no DPT is assigned to GA 2/3/0. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Eingangsbereich.Eingangsbeleuchtung_Treppe_RMSS because no DPT is assigned to GA 2/3/1. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Terrasse.Wandlampen_Terrasse_schalten because no DPT is assigned to GA 2/4/0. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Terrasse.Wandlampen_Terrasse_dimmen because no DPT is assigned to GA 2/4/1. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Terrasse.Wandlampen_Terrasse_Helligkeitswert because no DPT is assigned to GA 2/4/2. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Terrasse.Wandlampen_Terrasse_Rückm__Schaltstatus because no DPT is assigned to GA 2/4/3. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Terrasse.Wandlampen_Terrasse_Rückm__Helligkeitswert because no DPT is assigned to GA 2/4/4. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Terrasse.Wandlampe_Hauseingang_schalten because no DPT is assigned to GA 2/4/5. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Terrasse.Wandlampe_Hauseingang_dimmen because no DPT is assigned to GA 2/4/6. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Terrasse.Wandlampe_Hauseingang_HW because no DPT is assigned to GA 2/4/7. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Terrasse.Wandlampe_Hauseingang_RMSS because no DPT is assigned to GA 2/4/8. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Terrasse.Wandlampe_Hauseingang_RMHW because no DPT is assigned to GA 2/4/9. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Terrasse.Weihnachtsstern_schalten because no DPT is assigned to GA 2/4/10. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Balkon_OG.Balkonlicht_schalten because no DPT is assigned to GA 2/5/0. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Balkon_OG.Balkonlicht_RM because no DPT is assigned to GA 2/5/1. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Garage.Licht_Garage_schalten because no DPT is assigned to GA 2/6/0. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Garage.Licht_Garage_RMSS because no DPT is assigned to GA 2/6/1. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Garage.Licht_Garage_Automatik because no DPT is assigned to GA 2/6/2. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Garage.Außenlampen_vor_Garage_Werkstatt_schalten because no DPT is assigned to GA 2/6/3. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Garage.Außenlampen_vor_Garage_Werkstatt_RMSS because no DPT is assigned to GA 2/6/4. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Garage.Strahler_Durchgang_Garage_schalten because no DPT is assigned to GA 2/6/5. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Garage.Strahler_Durchgang_Garage_RMSS because no DPT is assigned to GA 2/6/6. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Garage.Strahler_vor_Garage_schalten because no DPT is assigned to GA 2/6/7. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Garage.Strahler_vor_Garage_RMSS because no DPT is assigned to GA 2/6/8. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Zentralfunktionen.Durchgang_Garage_+Wandl__Hauseingang_THF because no DPT is assigned to GA 2/7/0. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Zentralfunktionen.Dämmerung_AN_AUS because no DPT is assigned to GA 2/7/1. The GA is not connected to a device communication object in the ETS.
              Not adding Beleuchtung_Außen.Zentralfunktionen.Außenbeleuchtung_Komplett because no DPT is assigned to GA 2/7/3. The GA is not connected to a device communication object in the ETS.
              Not adding Heizung.EG.HK_Küche because no DPT is assigned to GA 3/0/1. The GA is not connected to a device communication object in the ETS.
              Not adding Heizung.EG.HK_Schlafen_Ankleide because no DPT is assigned to GA 3/0/2. The GA is not connected to a device communication object in the ETS.
              Not adding Heizung.EG.HK_WC_Flur because no DPT is assigned to GA 3/0/3. The GA is not connected to a device communication object in the ETS.
              Not adding Heizung.EG.HK_Spielezimmer because no DPT is assigned to GA 3/0/4. The GA is not connected to a device communication object in the ETS.
              Not adding Heizung.EG.Warmwasser_Wärmepumpe
              because no DPT is assigned to GA 3/0/6. The GA is not connected to a device communication object in the ETS.
              Not adding Heizung.OG.HK_Paula because no DPT is assigned to GA 3/1/0. The GA is not connected to a device communication object in the ETS.
              Not adding Heizung.OG.HK_Anton because no DPT is assigned to GA 3/1/1. The GA is not connected to a device communication object in the ETS.
              Not adding Heizung.OG.HK_Emil because no DPT is assigned to GA 3/1/2. The GA is not connected to a device communication object in the ETS.
              Not adding Heizung.OG.HK_Gäste_Flur because no DPT is assigned to GA 3/1/3. The GA is not connected to a device communication object in the ETS.
              Not adding Heizung.OG.HK_Büro because no DPT is assigned to GA 3/1/4. The GA is not connected to a device communication object in the ETS.
              Not adding Heizung.OG.HK_Kinderbad because no DPT is assigned to GA 3/1/5. The GA is not connected to a device communication object in the ETS.
              Not adding Heizung.Zentralfunktionen.Zentralumschaltung_Komfort because no DPT is assigned to GA 3/7/0. The GA is not connected to a device communication object in the ETS.
              Not adding Heizung.Zentralfunktionen.Zentralumschaltung_Standby because no DPT is assigned to GA 3/7/1. The GA is not connected to a device communication object in the ETS.
              Not adding Heizung.Zentralfunktionen.Zentralumschaltung_Nacht because no DPT is assigned to GA 3/7/2. The GA is not connected to a device communication object in the ETS.
              Not adding Heizung.Zentralfunktionen.Betriebsmodusumschaltung because no DPT is assigned to GA 3/7/3. The GA is not connected to a device communication object in the ETS.
              Not adding Heizung.Zentralfunktionen.Präsenzmelderbetrieb because no DPT is assigned to GA 3/7/4. The GA is not connected to a device communication object in the ETS.
              Not adding Lüftung+Beregnung.KG.Lüfter_WC_Zimmer_1_schalten because no DPT is assigned to GA 4/0/0. The GA is not connected to a device communication object in the ETS.
              Not adding Lüftung+Beregnung.KG.Lüfter_WC_Zimmer_1_schalten_RMSS because no DPT is assigned to GA 4/0/1. The GA is not connected to a device communication object in the ETS.
              Not adding Lüftung+Beregnung.KG.Lüfter_WC_Zimmer_1_schalten_Nachlauf because no DPT is assigned to GA 4/0/2. The GA is not connected to a device communication object in the ETS.
              Not adding Lüftung+Beregnung.KG.Lüfter_WC_Zimmer_2_schalten because no DPT is assigned to GA 4/0/3. The GA is not connected to a device communication object in the ETS.
              Not adding Lüftung+Beregnung.KG.Lüfter_WC_Zimmer_2_schalten_RMSS because no DPT is assigned to GA 4/0/4. The GA is not connected to a device communication object in the ETS.
              Not adding Lüftung+Beregnung.KG.Lüfter_WC_Zimmer_2_schalten_Nachlauf because no DPT is assigned to GA 4/0/5. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_1_fahren because no DPT is assigned to GA 5/0/0. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_1_verstellen because no DPT is assigned to GA 5/0/1. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_1_Pos because no DPT is assigned to GA 5/0/2. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_2_fahren because no DPT is assigned to GA 5/0/3. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_2_verstellen because no DPT is assigned to GA 5/0/4. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_2_Pos because no DPT is assigned to GA 5/0/5. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_3_fahren because no DPT is assigned to GA 5/0/6. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_3_verstellen because no DPT is assigned to GA 5/0/7. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_3_Pos because no DPT is assigned to GA 5/0/8. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Esszimmer_Rollo_fahren because no DPT is assigned to GA 5/0/9. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Esszimmer_Rollo_verstellen because no DPT is assigned to GA 5/0/10. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Esszimmer_Rollo_Pos because no DPT is assigned to GA 5/0/11. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Küche_Rollo_1_fahren because no DPT is assigned to GA 5/0/12. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Küche_Rollo_1_verstellen because no DPT is assigned to GA 5/0/13. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Küche_Rollo_1_Pos because no DPT is assigned to GA 5/0/14. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Küche_Rollo_2_fahren because no DPT is assigned to GA 5/0/15. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Küche_Rollo_2_verstellen because no DPT is assigned to GA 5/0/16. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Küche_Rollo_2_Pos because no DPT is assigned to GA 5/0/17. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Schlafen_Rollo_fahren because no DPT is assigned to GA 5/0/18. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Schlafen_Rollo_verstellen because no DPT is assigned to GA 5/0/19. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Schlafen_Rollo_Pos because no DPT is assigned to GA 5/0/20. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Ankleide_Rollo_1_fahren because no DPT is assigned to GA 5/0/21. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Ankleide_Rollo_1_verstellen because no DPT is assigned to GA 5/0/22. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Ankleide_Rollo_1_Pos because no DPT is assigned to GA 5/0/23. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Ankleide_Rollo_2_fahren because no DPT is assigned to GA 5/0/24. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Ankleide_Rollo_2_verstellen because no DPT is assigned to GA 5/0/25. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Ankleide_Rollo_2_Pos because no DPT is assigned to GA 5/0/26. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.WC_Rollo_fahren because no DPT is assigned to GA 5/0/27. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.WC_Rollo_verstellen because no DPT is assigned to GA 5/0/28. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.WC_Rollo_Pos because no DPT is assigned to GA 5/0/29. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Spielezimmer_Rollo_fahren because no DPT is assigned to GA 5/0/30. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Spielezimmer_Rollo_verstellen because no DPT is assigned to GA 5/0/31. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Spielezimmer_Rollo_Pos because no DPT is assigned to GA 5/0/32. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Bad_Rollo_fahren because no DPT is assigned to GA 5/0/33. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Bad_Rollo_verstellen because no DPT is assigned to GA 5/0/34. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Bad_Rollo_Pos because no DPT is assigned to GA 5/0/35. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Zimmer_1_Rollo_fahren because no DPT is assigned to GA 5/0/36. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Zimmer_1_Rollo_verstellen because no DPT is assigned to GA 5/0/37. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Zimmer_1_Rollo_Pos because no DPT is assigned to GA 5/0/38. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Zimmer_2_Rollo_li_fahren because no DPT is assigned to GA 5/0/39. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Zimmer_2_Rollo_li_verstellen because no DPT is assigned to GA 5/0/40. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Zimmer_2_Rollo_li_Pos because no DPT is assigned to GA 5/0/41. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Zimmer_2_Rollo_re_fahren because no DPT is assigned to GA 5/0/42. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Zimmer_2_Rollo_re_verstellen because no DPT is assigned to GA 5/0/43. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Zimmer_2_Rollo_re_Pos because no DPT is assigned to GA 5/0/44. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Anbau_hinten_Rollo_fahren because no DPT is assigned to GA 5/0/45. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Anbau_hinten_Rollo_verstellen because no DPT is assigned to GA 5/0/46. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Anbau_hinten_Rollo_Pos because no DPT is assigned to GA 5/0/47. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Anbau_hinten_Rollo_RMPos because no DPT is assigned to GA 5/0/48. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Garderobe_Rollo_1_Fahren because no DPT is assigned to GA 5/0/49. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Garderobe_Rollo_1_verstellen because no DPT is assigned to GA 5/0/50. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Garderobe_Rollo_1_Pos because no DPT is assigned to GA 5/0/51. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Keller_Jalousie_Fahren because no DPT is assigned to GA 5/0/52. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Keller_Jalousie_Verstellen because no DPT is assigned to GA 5/0/53. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG+KG.Keller_Jalousie_Pos because no DPT is assigned to GA 5/0/54. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG.Paula_Rollo_fahren because no DPT is assigned to GA 5/1/0. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG.Paula_Rollo_verstellen because no DPT is assigned to GA 5/1/1. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG.Paula_Rollo_Pos because no DPT is assigned to GA 5/1/2. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG.Anton_Rollo_fahren because no DPT is assigned to GA 5/1/3. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG.Anton_Rollo_verstellen because no DPT is assigned to GA 5/1/4. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG.Anton_Rollo_Pos because no DPT is assigned to GA 5/1/5. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG.Büro_Rollo_1_fahren because no DPT is assigned to GA 5/1/6. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG.Büro_Rollo_1_verstellen because no DPT is assigned to GA 5/1/7. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG.Büro_Rollo_1_Pos because no DPT is assigned to GA 5/1/8. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG.Büro_Rollo_2_fahren because no DPT is assigned to GA 5/1/9. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG.Büro_Rollo_2_verstellen because no DPT is assigned to GA 5/1/10. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG.Büro_Rollo_2_Pos because no DPT is assigned to GA 5/1/11. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG.Büro_Rollo_3_fahren because no DPT is assigned to GA 5/1/12. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG.Büro_Rollo_3_verstellen because no DPT is assigned to GA 5/1/13. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG.Büro_Rollo_3_Pos because no DPT is assigned to GA 5/1/14. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_1_fahren because no DPT is assigned to GA 5/2/0. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_1_verstellen because no DPT is assigned to GA 5/2/1. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_1_Pos because no DPT is assigned to GA 5/2/2. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_2_fahren because no DPT is assigned to GA 5/2/3. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_2_verstellen because no DPT is assigned to GA 5/2/4. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_2_Pos because no DPT is assigned to GA 5/2/5. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_3_fahren because no DPT is assigned to GA 5/2/6. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_3_verstellen because no DPT is assigned to GA 5/2/7. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_3_Pos because no DPT is assigned to GA 5/2/8. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Esszimmer_Rollo_fahren because no DPT is assigned to GA 5/2/9. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Esszimmer_Rollo_verstellen because no DPT is assigned to GA 5/2/10. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Esszimmer_Rollo_Pos because no DPT is assigned to GA 5/2/11. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Küche_Rollo_1_fahren because no DPT is assigned to GA 5/2/12. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Küche_Rollo_1_verstellen because no DPT is assigned to GA 5/2/13. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Küche_Rollo_1_Pos because no DPT is assigned to GA 5/2/14. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Küche_Rollo_2_fahren because no DPT is assigned to GA 5/2/15. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Küche_Rollo_2_verstellen because no DPT is assigned to GA 5/2/16. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Küche_Rollo_2_Pos because no DPT is assigned to GA 5/2/17. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Schlafen_Rollo_fahren because no DPT is assigned to GA 5/2/18. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Schlafen_Rollo_verstellen because no DPT is assigned to GA 5/2/19. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Schlafen_Rollo_Pos because no DPT is assigned to GA 5/2/20. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Ankleide_Rollo_1_fahren because no DPT is assigned to GA 5/2/21. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Ankleide_Rollo_1_verstellen because no DPT is assigned to GA 5/2/22. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Ankleide_Rollo_1_Pos because no DPT is assigned to GA 5/2/23. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Ankleide_Rollo_2_fahren because no DPT is assigned to GA 5/2/24. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Ankleide_Rollo_2_verstellen because no DPT is assigned to GA 5/2/25. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Ankleide_Rollo_2_Pos because no DPT is assigned to GA 5/2/26. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.WC_Rollo_fahren because no DPT is assigned to GA 5/2/27. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.WC_Rollo_verstellen because no DPT is assigned to GA 5/2/28. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.WC_Rollo_Pos because no DPT is assigned to GA 5/2/29. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Spielezimmer_Rollo_fahren because no DPT is assigned to GA 5/2/30. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Spielezimmer_Rollo_verstellen because no DPT is assigned to GA 5/2/31. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Spielezimmer_Rollo_Pos because no DPT is assigned to GA 5/2/32. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Bad_Rollo_fahren because no DPT is assigned to GA 5/2/33. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Bad_Rollo_verstellen because no DPT is assigned to GA 5/2/34. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Bad_Rollo_Pos because no DPT is assigned to GA 5/2/35. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Zimmer_1_Rollo_fahren because no DPT is assigned to GA 5/2/36. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Zimmer_1_Rollo_verstellen because no DPT is assigned to GA 5/2/37. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Zimmer_1_Rollo_Pos because no DPT is assigned to GA 5/2/38. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Zimmer_2_Rollo_li_fahren because no DPT is assigned to GA 5/2/39. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Zimmer_2_Rollo_li_verstellen because no DPT is assigned to GA 5/2/40. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Zimmer_2_Rollo_li_Pos because no DPT is assigned to GA 5/2/41. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Zimmer_2_Rollo_re_fahren because no DPT is assigned to GA 5/2/42. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Zimmer_2_Rollo_re_verstellen because no DPT is assigned to GA 5/2/43. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.EG_RM.Zimmer_2_Rollo_re_Pos because no DPT is assigned to GA 5/2/44. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG_RM.Paula_Rollo_fahren because no DPT is assigned to GA 5/3/0. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG_RM.Paula_Rollo_verstellen because no DPT is assigned to GA 5/3/1. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG_RM.Paula_Rollo_Pos because no DPT is assigned to GA 5/3/2. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG_RM.Anton_Rollo_fahren because no DPT is assigned to GA 5/3/3. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG_RM.Anton_Rollo_verstellen because no DPT is assigned to GA 5/3/4. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG_RM.Anton_Rollo_Pos because no DPT is assigned to GA 5/3/5. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_1_fahren because no DPT is assigned to GA 5/3/6. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_1_verstellen because no DPT is assigned to GA 5/3/7. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_1_Pos because no DPT is assigned to GA 5/3/8. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_2_fahren because no DPT is assigned to GA 5/3/9. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_2_verstellen because no DPT is assigned to GA 5/3/10. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_2_Pos because no DPT is assigned to GA 5/3/11. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_3_fahren because no DPT is assigned to GA 5/3/12. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_3_verstellen because no DPT is assigned to GA 5/3/13. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_3_Pos because no DPT is assigned to GA 5/3/14. The GA is not connected to a device communication object in the ETS.
              Rollos+Verschattung.Markise_Balkon.Markise_Fahren_Balkon has only set base DPT DPT1 in ETS. No additional informations (e.g. unit) available for this GA.
              Not adding Rollos+Verschattung.Zentralfunktionen.Wohnen_1-3_fahren because no DPT is assigned to GA 5/7/0. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.Zentralfunktionen.Wohnen_1-3_verstellen because no DPT is assigned to GA 5/7/1. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.Zentralfunktionen.Wohnen_1-3_Pos because no DPT is assigned to GA 5/7/2. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.Zentralfunktionen.Ankleide_1+2_fahren because no DPT is assigned to GA 5/7/3. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.Zentralfunktionen.Ankleide_1+2_verstellen because no DPT is assigned to GA 5/7/4. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.Zentralfunktionen.Zimmer_2_KG_Rollos_fahren because no DPT is assigned to GA 5/7/5. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.Zentralfunktionen.Zimmer_2_KG_Rollos_verstellen because no DPT is assigned to GA 5/7/6. The GA is not connected to a device communication object in the ETS.
              Not adding Rollos+Verschattung.Zentralfunktionen.Zimmer_2_KG_Rollos_Pos because no DPT is assigned to GA 5/7/7. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.EG.Wohnen_Steckd_1_schalten because no DPT is assigned to GA 6/0/0. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.EG.Wohnen_Steckd_2_schalten because no DPT is assigned to GA 6/0/1. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.EG.Esszimmer_Steckd_schalten because no DPT is assigned to GA 6/0/2. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.EG.Küche_Steckd_schalten because no DPT is assigned to GA 6/0/3. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.EG.Flur_Steckd_schalten because no DPT is assigned to GA 6/0/4. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.EG.Schlafen_Steckd_li_Bett_schalten because no DPT is assigned to GA 6/0/5. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.EG.Schlafen_Steckd_re_Bett_schalten because no DPT is assigned to GA 6/0/6. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.EG.Spielezimmer_Steckd_schalten because no DPT is assigned to GA 6/0/7. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.EG.Bad_Radio_schalten because no DPT is assigned to GA 6/0/8. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.EG.Ankleide_Steckd_schalten because no DPT is assigned to GA 6/0/9. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.OG.Büro_Steckdosen_1_schalten because no DPT is assigned to GA 6/1/0. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.OG.Büro_Steckdosen_2_schalten because no DPT is assigned to GA 6/1/1. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.OG.Büro_Steckdosen_1_RM because no DPT is assigned to GA 6/1/2. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.OG.Büro_Steckdosen_2_RM because no DPT is assigned to GA 6/1/3. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.EG_RM.Wohnen_Steckd_1_schalten because no DPT is assigned to GA 6/3/0. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.EG_RM.Wohnen_Steckd_2_schalten because no DPT is assigned to GA 6/3/1. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.EG_RM.Esszimmer_Steckd_schalten because no DPT is assigned to GA 6/3/2. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.EG_RM.Küche_Steckd_schalten because no DPT is assigned to GA 6/3/3. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.EG_RM.Flur_Steckd_schalten because no DPT is assigned to GA 6/3/4. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.EG_RM.Schlafen_Steckd_li_Bett_schalten because no DPT is assigned to GA 6/3/5. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.EG_RM.Schlafen_Steckd_re_Bett_schalten because no DPT is assigned to GA 6/3/6. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.EG_RM.Spielezimmer_Steckd_schalten because no DPT is assigned to GA 6/3/7. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.EG_RM.Bad_Radio_schalten because no DPT is assigned to GA 6/3/8. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.EG_RM.Ankleide_Steckd_schalten because no DPT is assigned to GA 6/3/9. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.Terrasse.Balkon_Steckdose_Straße because no DPT is assigned to GA 6/4/0. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.Terrasse.Neue_Gruppenadresse because no DPT is assigned to GA 6/4/1. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.Garten.Steckdose_linke_Hausseite_schalten because no DPT is assigned to GA 6/5/0. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.Garten.Steckdose_linke_Hausseite_dimmen because no DPT is assigned to GA 6/5/1. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.Garten.Steckdose_linke_Hausseite_Helligkeitswert because no DPT is assigned to GA 6/5/2. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.Garten.Steckdose_linke_Hausseite_Rückm__Schaltstatus because no DPT is assigned to GA 6/5/3. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.Garten.Steckdose_linke_Hausseite_Rück__Helligkeitswert because no DPT is assigned to GA 6/5/4. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.Garten.Steckdose_rechte_Hausseite_schalten because no DPT is assigned to GA 6/5/5. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.Garten.Steckdose_rechte_Hausseite_dimmen because no DPT is assigned to GA 6/5/6. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.Garten.Steckdose_rechte_Hausseite_Helligkeitswert because no DPT is assigned to GA 6/5/7. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.Garten.Steckdose_rechte_Hausseite_Rückm__Schaltstatus because no DPT is assigned to GA 6/5/8. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.Garten.Steckdose_rechte_Hausseite_Rückm__Helligkeitswert because no DPT is assigned to GA 6/5/9. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.Balkon_OG.Balkonsteckdose_schalten because no DPT is assigned to GA 6/6/0. The GA is not connected to a device communication object in the ETS.
              Not adding Steckdosen.Balkon_OG.Balkonsteckdose_RM because no DPT is assigned to GA 6/6/1. The GA is not connected to a device communication object in the ETS.
              Not adding Wetter_Zeit_Datum_Alarm.Daten.Türöffner_Haustür because no DPT is assigned to GA 7/0/2. The GA is not connected to a device communication object in the ETS.
              Not adding Wetter_Zeit_Datum_Alarm.Daten.RM_Türöffner_Haustür because no DPT is assigned to GA 7/0/3. The GA is not connected to a device communication object in the ETS.
              Not adding Wetter_Zeit_Datum_Alarm.Daten.Freigabe_Datum because no DPT is assigned to GA 7/0/4. The GA is not connected to a device communication object in the ETS.
              Not adding Wetter_Zeit_Datum_Alarm.Daten.Freigabe_Uhrzeit because no DPT is assigned to GA 7/0/5. The GA is not connected to a device communication object in the ETS.
              Not adding Wetter_Zeit_Datum_Alarm.Bewegungsmelder.Meldung_Haupt_Nebenstelle_Flur_EG because no DPT is assigned to GA 7/1/0. The GA is not connected to a device communication object in the ETS.
              Not adding Wetter_Zeit_Datum_Alarm.Rauchmelder.Rauchmelder_Alarm_manuell_starten because no DPT is assigned to GA 7/2/0. The GA is not connected to a device communication object in the ETS.
              Not adding Wetter_Zeit_Datum_Alarm.Rauchmelder.Rauchmelder_ALARM because no DPT is assigned to GA 7/2/1. The GA is not connected to a device communication object in the ETS.
              See log for more information
              OK
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              @tomtulli BitteBitte packe diese Ausgabe in Codetags ein, Danke
              Lehrling seit 1975 !!!
              • T tomtulli
                @lessthanmore
                Imported 9 states successfully
                Not adding Lichtszenen.Lichtszene.Lichtszene because no DPT is assigned to GA 0/0/1. The GA is not connected to a device communication object in the ETS.
                Not adding Lichtszenen.Lichtszene.Gesamthelligkeit because no DPT is assigned to GA 0/0/2. The GA is not connected to a device communication object in the ETS.
                Not adding Lichtszenen.Lichtszene.Umgebungshelligkeit because no DPT is assigned to GA 0/0/3. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_+KG.Wohnen_Strahler_1_schalten because no DPT is assigned to GA 1/0/0. The GA is not connected to a device communication object in the ETS.
                +KG.Wohnen_Strahler_1_dimmen because no DPT is assigned to GA 1/0/1. The GA is not connected to a device communication object in the ETS.
                +KG.Wohnen_Strahler_1_HW because no DPT is assigned to GA 1/0/2. The GA is not connected to a device communication object in the ETS.
                +KG.Wohnen_Strahler_2_schalten because no DPT is assigned to GA 1/0/3. The GA is not connected to a device communication object in the ETS.
                +KG.Wohnen_Strahler_2_dimmen because no DPT is assigned to GA 1/0/4. The GA is not connected to a device communication object in the ETS.
                +KG.Wohnen_Strahler_2_HW because no DPT is assigned to GA 1/0/5. The GA is not connected to a device communication object in the ETS.
                +KG.Wohnen_Wandlampen_schalten because no DPT is assigned to GA 1/0/6. The GA is not connected to a device communication object in the ETS.
                +KG.Wohnen_Wandlampen_dimmen because no DPT is assigned to GA 1/0/7. The GA is not connected to a device communication object in the ETS.
                +KG.Wohnen_Wandlampen_HW because no DPT is assigned to GA 1/0/8. The GA is not connected to a device communication object in the ETS.
                +KG.Essen_Pendelleuchte_schalten because no DPT is assigned to GA 1/0/9. The GA is not connected to a device communication object in the ETS.
                +KG.Küche_Strahler_schalten because no DPT is assigned to GA 1/0/10. The GA is not connected to a device communication object in the ETS.
                +KG.Küche_Strahler_dimmen because no DPT is assigned to GA 1/0/11. The GA is not connected to a device communication object in the ETS.
                +KG.Küche_Strahler_HW because no DPT is assigned to GA 1/0/12. The GA is not connected to a device communication object in the ETS.
                +KG.Beleuchtung_Tersasse_Hinten because no DPT is assigned to GA 1/0/13. The GA is not connected to a device communication object in the ETS.
                +KG.Küche_Bel__Hängeschrank_schalten because no DPT is assigned to GA 1/0/14. The GA is not connected to a device communication object in the ETS.
                +KG.Windfang_Strahler_schalten because no DPT is assigned to GA 1/0/15. The GA is not connected to a device communication object in the ETS.
                +KG.Flur_Strahler_schalten because no DPT is assigned to GA 1/0/16. The GA is not connected to a device communication object in the ETS.
                +KG.Schlafen_Strahler_schalten because no DPT is assigned to GA 1/0/17. The GA is not connected to a device communication object in the ETS.
                +KG.Schlafen_Wandlampe_schalten because no DPT is assigned to GA 1/0/18. The GA is not connected to a device communication object in the ETS.
                +KG.Ankleide_Strahler_schalten because no DPT is assigned to GA 1/0/19. The GA is not connected to a device communication object in the ETS.
                +KG.Bad_Strahler_schalten because no DPT is assigned to GA 1/0/20. The GA is not connected to a device communication object in the ETS.
                +KG.Bad_Spiegel_schalten because no DPT is assigned to GA 1/0/21. The GA is not connected to a device communication object in the ETS.
                +KG.Bad_Wanne_schalten because no DPT is assigned to GA 1/0/22. The GA is not connected to a device communication object in the ETS.
                +KG.Spielezimmer_Decke_schalten because no DPT is assigned to GA 1/0/23. The GA is not connected to a device communication object in the ETS.
                +KG.WC_Strahler_schalten because no DPT is assigned to GA 1/0/24. The GA is not connected to a device communication object in the ETS.
                +KG.Technik_Strahler_schalten because no DPT is assigned to GA 1/0/25. The GA is not connected to a device communication object in the ETS.
                +KG.WC_Spiegel_schalten because no DPT is assigned to GA 1/0/26. The GA is not connected to a device communication object in the ETS.
                +KG.Keller_Wohnzimmerlicht_Decke_Schalten because no DPT is assigned to GA 1/0/27. The GA is not connected to a device communication object in the ETS.
                +KG.Garage_Beleuchtung_schalten_RMSS because no DPT is assigned to GA 1/0/28. The GA is not connected to a device communication object in the ETS.
                +KG.Keller_Wohnung_Flurlicht_Schalten because no DPT is assigned to GA 1/0/29. The GA is not connected to a device communication object in the ETS.
                +KG.Zimmer_1_Licht_Wohnen_schalten_RMSS because no DPT is assigned to GA 1/0/30. The GA is not connected to a device communication object in the ETS.
                +KG.Keller_Wohnung_Bad_Deckenlicht_Schalten because no DPT is assigned to GA 1/0/31. The GA is not connected to a device communication object in the ETS.
                +KG.Zimmer_1_Licht_Decke_WC_schalten_RMSS because no DPT is assigned to GA 1/0/32. The GA is not connected to a device communication object in the ETS.
                +KG.Zimmer_1_Licht_Spiegel_WC_schalten because no DPT is assigned to GA 1/0/33. The GA is not connected to a device communication object in the ETS.
                +KG.Zimmer_1_Licht_Spiegel_WC_schalten_RMSS because no DPT is assigned to GA 1/0/34. The GA is not connected to a device communication object in the ETS.
                +KG.Keller_Wohnung_SZ_Licht_Decke_Schalten because no DPT is assigned to GA 1/0/35. The GA is not connected to a device communication object in the ETS.
                +KG.Zimmer_2_Licht_Wohnen_schalten_RMSS because no DPT is assigned to GA 1/0/36. The GA is not connected to a device communication object in the ETS.
                +KG.KG_SZ_Bett_Links because no DPT is assigned to GA 1/0/37. The GA is not connected to a device communication object in the ETS.
                +KG.Zimmer_2_Licht_Decke_WC_schalten_RMSS because no DPT is assigned to GA 1/0/38. The GA is not connected to a device communication object in the ETS.
                +KG.KG_SZ_Licht_Bett_Rechts because no DPT is assigned to GA 1/0/39. The GA is not connected to a device communication object in the ETS.
                +KG.Zimmer_2_Licht_Spiegel_WC_schalten_RMSS because no DPT is assigned to GA 1/0/40. The GA is not connected to a device communication object in the ETS.
                +KG.Flur_KG_Strahler_schalten because no DPT is assigned to GA 1/0/41. The GA is not connected to a device communication object in the ETS.
                +KG.Flur_KG_Strahler_schalten_RMSS because no DPT is assigned to GA 1/0/42. The GA is not connected to a device communication object in the ETS.
                +KG.Holzlager_Licht_schalten because no DPT is assigned to GA 1/0/43. The GA is not connected to a device communication object in the ETS.
                +KG.Holzlager_Licht_schalten_RMSS because no DPT is assigned to GA 1/0/44. The GA is not connected to a device communication object in the ETS.
                +KG.Flur_vor_Treppe_KG_schalten because no DPT is assigned to GA 1/0/45. The GA is not connected to a device communication object in the ETS.
                +KG.Flur_vor_Treppe_KG_schalten_RMSS because no DPT is assigned to GA 1/0/46. The GA is not connected to a device communication object in the ETS.
                +KG.LED_Strahler_Treppe_schalten because no DPT is assigned to GA 1/0/47. The GA is not connected to a device communication object in the ETS.
                +KG.LED_Strahler_Treppe_schalten_RMSS because no DPT is assigned to GA 1/0/48. The GA is not connected to a device communication object in the ETS.
                +KG.Ecklampe_Treppe_schalten because no DPT is assigned to GA 1/0/49. The GA is not connected to a device communication object in the ETS.
                +KG.Ecklampe_Treppe_schalten_RMSS because no DPT is assigned to GA 1/0/50. The GA is not connected to a device communication object in the ETS.
                +KG.Anbau_vorn_Lampe_schalten because no DPT is assigned to GA 1/0/51. The GA is not connected to a device communication object in the ETS.
                +KG.Anbau_vorn_Lampe_RMSS because no DPT is assigned to GA 1/0/52. The GA is not connected to a device communication object in the ETS.
                +KG.Anbau_hinten_Lampe_schalten because no DPT is assigned to GA 1/0/53. The GA is not connected to a device communication object in the ETS.
                +KG.Anbau_hinten_Lampe_RMSS because no DPT is assigned to GA 1/0/54. The GA is not connected to a device communication object in the ETS.
                +KG.HWR_Keller_Licht because no DPT is assigned to GA 1/0/55. The GA is not connected to a device communication object in the ETS.
                +KG.Keller_WZ_Wandlicht because no DPT is assigned to GA 1/0/56. The GA is not connected to a device communication object in the ETS.
                +KG.Keller_EZ_Deckenleuchte because no DPT is assigned to GA 1/0/57. The GA is not connected to a device communication object in the ETS.
                +KG.Keller_Technikraum because no DPT is assigned to GA 1/0/58. The GA is not connected to a device communication object in the ETS.
                +KG.Neue_Gruppenadresse because no DPT is assigned to GA 1/0/59. The GA is not connected to a device communication object in the ETS.
                +KG.Neue_Gruppenadresse because no DPT is assigned to GA 1/0/60. The GA is not connected to a device communication object in the ETS.
                +KG.Springbrunnen because no DPT is assigned to GA 1/0/61. The GA is not connected to a device communication object in the ETS.
                +KG.Wohnzimmer_Easstisch_Licht because no DPT is assigned to GA 1/0/62. The GA is not connected to a device communication object in the ETS.
                +KG.Bad_TV because no DPT is assigned to GA 1/0/63. The GA is not connected to a device communication object in the ETS.
                +KG.Flur_hinten because no DPT is assigned to GA 1/0/64. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG.Flur_Strahler_schalten because no DPT is assigned to GA 1/1/0. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG.Paula_Strahler_schalten because no DPT is assigned to GA 1/1/1. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG.Anton_Strahler_schalten because no DPT is assigned to GA 1/1/2. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG.Emil_Strahler_schalten because no DPT is assigned to GA 1/1/3. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG.Gäste_Strahler_schalten because no DPT is assigned to GA 1/1/4. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG.Büro_Strahler_1_schalten because no DPT is assigned to GA 1/1/5. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG.Büro_Strahler_1_dimmen because no DPT is assigned to GA 1/1/6. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG.Büro_Strahler_1_HW because no DPT is assigned to GA 1/1/7. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG.Büro_Strahler_2_schalten because no DPT is assigned to GA 1/1/8. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG.Büro_Strahler_2_dimmen because no DPT is assigned to GA 1/1/9. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG.Büro_Strahler_2_HW because no DPT is assigned to GA 1/1/10. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG.Abstellraum_Decke_schalten because no DPT is assigned to GA 1/1/11. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG.Kinderbad_Strahler_schalten because no DPT is assigned to GA 1/1/12. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG.Kinderbad_Spiegel_schalten because no DPT is assigned to GA 1/1/13. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.Spitzboden.Spitzboden_Bel__1_schalten because no DPT is assigned to GA 1/2/0. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.Spitzboden.Spitzboden_Bel__2_schalten because no DPT is assigned to GA 1/2/1. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Wohnen_Strahler_1_schalten because no DPT is assigned to GA 1/3/0. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Wohnen_Strahler_1_dimmen because no DPT is assigned to GA 1/3/1. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Wohnen_Strahler_1_HW because no DPT is assigned to GA 1/3/2. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Wohnen_Strahler_2_schalten because no DPT is assigned to GA 1/3/3. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Wohnen_Strahler_2_dimmen because no DPT is assigned to GA 1/3/4. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Wohnen_Strahler_2_HW because no DPT is assigned to GA 1/3/5. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Wohnen_Wandlampen_schalten because no DPT is assigned to GA 1/3/6. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Wohnen_Wandlampen_dimmen because no DPT is assigned to GA 1/3/7. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Wohnen_Wandlampen_HW because no DPT is assigned to GA 1/3/8. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Essen_Pendelleuchte_schalten because no DPT is assigned to GA 1/3/9. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Küche_Strahler_schalten because no DPT is assigned to GA 1/3/10. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Küche_Strahler_dimmen because no DPT is assigned to GA 1/3/11. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Küche_Strahler_HW because no DPT is assigned to GA 1/3/12. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Küche_Bel__Wandschrank_schalten because no DPT is assigned to GA 1/3/13. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Küche_Bel__Hängeschrank_schalten because no DPT is assigned to GA 1/3/14. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Windfang_Strahler_schalten because no DPT is assigned to GA 1/3/15. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Flur_Strahler_schalten because no DPT is assigned to GA 1/3/16. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Schlafen_Strahler_schalten because no DPT is assigned to GA 1/3/17. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Schlafen_Wandlampe_schalten because no DPT is assigned to GA 1/3/18. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Ankleide_Strahler_schalten because no DPT is assigned to GA 1/3/19. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Bad_Strahler_schalten because no DPT is assigned to GA 1/3/20. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Bad_Spiegel_schalten because no DPT is assigned to GA 1/3/21. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Bad_Wanne_schalten because no DPT is assigned to GA 1/3/22. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Spielezimmer_Decke_schalten because no DPT is assigned to GA 1/3/23. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.WC_Strahler_schalten because no DPT is assigned to GA 1/3/24. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.Technik_Strahler_schalten because no DPT is assigned to GA 1/3/25. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.EG_RM.WC_Spiegel_schalten because no DPT is assigned to GA 1/3/26. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG_RM.Flur_Strahler_schalten because no DPT is assigned to GA 1/4/0. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG_RM.Paula_Strahler_schalten because no DPT is assigned to GA 1/4/1. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG_RM.Anton_Strahler_schalten because no DPT is assigned to GA 1/4/2. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG_RM.Emil_Strahler_schalten because no DPT is assigned to GA 1/4/3. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG_RM.Gäste_Strahler_schalten because no DPT is assigned to GA 1/4/4. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG_RM.Büro_Strahler_1_schalten because no DPT is assigned to GA 1/4/5. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG_RM.Büro_Strahler_1_dimmen because no DPT is assigned to GA 1/4/6. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG_RM.Büro_Strahler_1_HW because no DPT is assigned to GA 1/4/7. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG_RM.Büro_Strahler_2_schalten because no DPT is assigned to GA 1/4/8. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG_RM.Büro_Strahler_2_dimmen because no DPT is assigned to GA 1/4/9. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG_RM.Büro_Strahler_2_HW because no DPT is assigned to GA 1/4/10. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG_RM.Abstellraum_Decke_schalten because no DPT is assigned to GA 1/4/11. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG_RM.Kinderbad_Strahler_schalten because no DPT is assigned to GA 1/4/12. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.OG_RM.Kinderbad_Spiegel_schalten because no DPT is assigned to GA 1/4/13. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.Spitzboden_RM.Spitzboden_Bel__1_schalten because no DPT is assigned to GA 1/5/0. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.Spitzboden_RM.Spitzboden_Bel__2_schalten because no DPT is assigned to GA 1/5/1. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.Zentralfunktionen.Wohnen_Strahler_1+2_schalten
                because no DPT is assigned to GA 1/7/0. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.Zentralfunktionen.Wohnen_Strahler_1+2_dimmen because no DPT is assigned to GA 1/7/1. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.Zentralfunktionen.Wohnen_Strahler_1+2_HW because no DPT is assigned to GA 1/7/2. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.Zentralfunktionen.Trigger_BWM_kleiner_Flur_KG because no DPT is assigned to GA 1/7/3. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.Zentralfunktionen.Trigger_BWM_Impuls because no DPT is assigned to GA 1/7/4. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Innen.Zentralfunktionen.Sperrung_BWM_Windfang because no DPT is assigned to GA 1/7/5. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Eingangsbereich.Eingangsbeleuchtung_Treppe_schalten because no DPT is assigned to GA 2/3/0. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Eingangsbereich.Eingangsbeleuchtung_Treppe_RMSS because no DPT is assigned to GA 2/3/1. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Terrasse.Wandlampen_Terrasse_schalten because no DPT is assigned to GA 2/4/0. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Terrasse.Wandlampen_Terrasse_dimmen because no DPT is assigned to GA 2/4/1. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Terrasse.Wandlampen_Terrasse_Helligkeitswert because no DPT is assigned to GA 2/4/2. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Terrasse.Wandlampen_Terrasse_Rückm__Schaltstatus because no DPT is assigned to GA 2/4/3. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Terrasse.Wandlampen_Terrasse_Rückm__Helligkeitswert because no DPT is assigned to GA 2/4/4. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Terrasse.Wandlampe_Hauseingang_schalten because no DPT is assigned to GA 2/4/5. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Terrasse.Wandlampe_Hauseingang_dimmen because no DPT is assigned to GA 2/4/6. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Terrasse.Wandlampe_Hauseingang_HW because no DPT is assigned to GA 2/4/7. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Terrasse.Wandlampe_Hauseingang_RMSS because no DPT is assigned to GA 2/4/8. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Terrasse.Wandlampe_Hauseingang_RMHW because no DPT is assigned to GA 2/4/9. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Terrasse.Weihnachtsstern_schalten because no DPT is assigned to GA 2/4/10. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Balkon_OG.Balkonlicht_schalten because no DPT is assigned to GA 2/5/0. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Balkon_OG.Balkonlicht_RM because no DPT is assigned to GA 2/5/1. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Garage.Licht_Garage_schalten because no DPT is assigned to GA 2/6/0. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Garage.Licht_Garage_RMSS because no DPT is assigned to GA 2/6/1. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Garage.Licht_Garage_Automatik because no DPT is assigned to GA 2/6/2. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Garage.Außenlampen_vor_Garage_Werkstatt_schalten because no DPT is assigned to GA 2/6/3. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Garage.Außenlampen_vor_Garage_Werkstatt_RMSS because no DPT is assigned to GA 2/6/4. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Garage.Strahler_Durchgang_Garage_schalten because no DPT is assigned to GA 2/6/5. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Garage.Strahler_Durchgang_Garage_RMSS because no DPT is assigned to GA 2/6/6. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Garage.Strahler_vor_Garage_schalten because no DPT is assigned to GA 2/6/7. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Garage.Strahler_vor_Garage_RMSS because no DPT is assigned to GA 2/6/8. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Zentralfunktionen.Durchgang_Garage_+Wandl__Hauseingang_THF because no DPT is assigned to GA 2/7/0. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Zentralfunktionen.Dämmerung_AN_AUS because no DPT is assigned to GA 2/7/1. The GA is not connected to a device communication object in the ETS.
                Not adding Beleuchtung_Außen.Zentralfunktionen.Außenbeleuchtung_Komplett because no DPT is assigned to GA 2/7/3. The GA is not connected to a device communication object in the ETS.
                Not adding Heizung.EG.HK_Küche because no DPT is assigned to GA 3/0/1. The GA is not connected to a device communication object in the ETS.
                Not adding Heizung.EG.HK_Schlafen_Ankleide because no DPT is assigned to GA 3/0/2. The GA is not connected to a device communication object in the ETS.
                Not adding Heizung.EG.HK_WC_Flur because no DPT is assigned to GA 3/0/3. The GA is not connected to a device communication object in the ETS.
                Not adding Heizung.EG.HK_Spielezimmer because no DPT is assigned to GA 3/0/4. The GA is not connected to a device communication object in the ETS.
                Not adding Heizung.EG.Warmwasser_Wärmepumpe
                because no DPT is assigned to GA 3/0/6. The GA is not connected to a device communication object in the ETS.
                Not adding Heizung.OG.HK_Paula because no DPT is assigned to GA 3/1/0. The GA is not connected to a device communication object in the ETS.
                Not adding Heizung.OG.HK_Anton because no DPT is assigned to GA 3/1/1. The GA is not connected to a device communication object in the ETS.
                Not adding Heizung.OG.HK_Emil because no DPT is assigned to GA 3/1/2. The GA is not connected to a device communication object in the ETS.
                Not adding Heizung.OG.HK_Gäste_Flur because no DPT is assigned to GA 3/1/3. The GA is not connected to a device communication object in the ETS.
                Not adding Heizung.OG.HK_Büro because no DPT is assigned to GA 3/1/4. The GA is not connected to a device communication object in the ETS.
                Not adding Heizung.OG.HK_Kinderbad because no DPT is assigned to GA 3/1/5. The GA is not connected to a device communication object in the ETS.
                Not adding Heizung.Zentralfunktionen.Zentralumschaltung_Komfort because no DPT is assigned to GA 3/7/0. The GA is not connected to a device communication object in the ETS.
                Not adding Heizung.Zentralfunktionen.Zentralumschaltung_Standby because no DPT is assigned to GA 3/7/1. The GA is not connected to a device communication object in the ETS.
                Not adding Heizung.Zentralfunktionen.Zentralumschaltung_Nacht because no DPT is assigned to GA 3/7/2. The GA is not connected to a device communication object in the ETS.
                Not adding Heizung.Zentralfunktionen.Betriebsmodusumschaltung because no DPT is assigned to GA 3/7/3. The GA is not connected to a device communication object in the ETS.
                Not adding Heizung.Zentralfunktionen.Präsenzmelderbetrieb because no DPT is assigned to GA 3/7/4. The GA is not connected to a device communication object in the ETS.
                Not adding Lüftung+Beregnung.KG.Lüfter_WC_Zimmer_1_schalten because no DPT is assigned to GA 4/0/0. The GA is not connected to a device communication object in the ETS.
                Not adding Lüftung+Beregnung.KG.Lüfter_WC_Zimmer_1_schalten_RMSS because no DPT is assigned to GA 4/0/1. The GA is not connected to a device communication object in the ETS.
                Not adding Lüftung+Beregnung.KG.Lüfter_WC_Zimmer_1_schalten_Nachlauf because no DPT is assigned to GA 4/0/2. The GA is not connected to a device communication object in the ETS.
                Not adding Lüftung+Beregnung.KG.Lüfter_WC_Zimmer_2_schalten because no DPT is assigned to GA 4/0/3. The GA is not connected to a device communication object in the ETS.
                Not adding Lüftung+Beregnung.KG.Lüfter_WC_Zimmer_2_schalten_RMSS because no DPT is assigned to GA 4/0/4. The GA is not connected to a device communication object in the ETS.
                Not adding Lüftung+Beregnung.KG.Lüfter_WC_Zimmer_2_schalten_Nachlauf because no DPT is assigned to GA 4/0/5. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_1_fahren because no DPT is assigned to GA 5/0/0. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_1_verstellen because no DPT is assigned to GA 5/0/1. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_1_Pos because no DPT is assigned to GA 5/0/2. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_2_fahren because no DPT is assigned to GA 5/0/3. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_2_verstellen because no DPT is assigned to GA 5/0/4. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_2_Pos because no DPT is assigned to GA 5/0/5. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_3_fahren because no DPT is assigned to GA 5/0/6. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_3_verstellen because no DPT is assigned to GA 5/0/7. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Wohnen_Rollo_3_Pos because no DPT is assigned to GA 5/0/8. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Esszimmer_Rollo_fahren because no DPT is assigned to GA 5/0/9. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Esszimmer_Rollo_verstellen because no DPT is assigned to GA 5/0/10. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Esszimmer_Rollo_Pos because no DPT is assigned to GA 5/0/11. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Küche_Rollo_1_fahren because no DPT is assigned to GA 5/0/12. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Küche_Rollo_1_verstellen because no DPT is assigned to GA 5/0/13. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Küche_Rollo_1_Pos because no DPT is assigned to GA 5/0/14. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Küche_Rollo_2_fahren because no DPT is assigned to GA 5/0/15. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Küche_Rollo_2_verstellen because no DPT is assigned to GA 5/0/16. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Küche_Rollo_2_Pos because no DPT is assigned to GA 5/0/17. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Schlafen_Rollo_fahren because no DPT is assigned to GA 5/0/18. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Schlafen_Rollo_verstellen because no DPT is assigned to GA 5/0/19. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Schlafen_Rollo_Pos because no DPT is assigned to GA 5/0/20. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Ankleide_Rollo_1_fahren because no DPT is assigned to GA 5/0/21. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Ankleide_Rollo_1_verstellen because no DPT is assigned to GA 5/0/22. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Ankleide_Rollo_1_Pos because no DPT is assigned to GA 5/0/23. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Ankleide_Rollo_2_fahren because no DPT is assigned to GA 5/0/24. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Ankleide_Rollo_2_verstellen because no DPT is assigned to GA 5/0/25. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Ankleide_Rollo_2_Pos because no DPT is assigned to GA 5/0/26. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.WC_Rollo_fahren because no DPT is assigned to GA 5/0/27. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.WC_Rollo_verstellen because no DPT is assigned to GA 5/0/28. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.WC_Rollo_Pos because no DPT is assigned to GA 5/0/29. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Spielezimmer_Rollo_fahren because no DPT is assigned to GA 5/0/30. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Spielezimmer_Rollo_verstellen because no DPT is assigned to GA 5/0/31. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Spielezimmer_Rollo_Pos because no DPT is assigned to GA 5/0/32. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Bad_Rollo_fahren because no DPT is assigned to GA 5/0/33. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Bad_Rollo_verstellen because no DPT is assigned to GA 5/0/34. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Bad_Rollo_Pos because no DPT is assigned to GA 5/0/35. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Zimmer_1_Rollo_fahren because no DPT is assigned to GA 5/0/36. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Zimmer_1_Rollo_verstellen because no DPT is assigned to GA 5/0/37. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Zimmer_1_Rollo_Pos because no DPT is assigned to GA 5/0/38. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Zimmer_2_Rollo_li_fahren because no DPT is assigned to GA 5/0/39. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Zimmer_2_Rollo_li_verstellen because no DPT is assigned to GA 5/0/40. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Zimmer_2_Rollo_li_Pos because no DPT is assigned to GA 5/0/41. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Zimmer_2_Rollo_re_fahren because no DPT is assigned to GA 5/0/42. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Zimmer_2_Rollo_re_verstellen because no DPT is assigned to GA 5/0/43. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Zimmer_2_Rollo_re_Pos because no DPT is assigned to GA 5/0/44. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Anbau_hinten_Rollo_fahren because no DPT is assigned to GA 5/0/45. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Anbau_hinten_Rollo_verstellen because no DPT is assigned to GA 5/0/46. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Anbau_hinten_Rollo_Pos because no DPT is assigned to GA 5/0/47. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Anbau_hinten_Rollo_RMPos because no DPT is assigned to GA 5/0/48. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Garderobe_Rollo_1_Fahren because no DPT is assigned to GA 5/0/49. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Garderobe_Rollo_1_verstellen because no DPT is assigned to GA 5/0/50. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Garderobe_Rollo_1_Pos because no DPT is assigned to GA 5/0/51. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Keller_Jalousie_Fahren because no DPT is assigned to GA 5/0/52. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Keller_Jalousie_Verstellen because no DPT is assigned to GA 5/0/53. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG+KG.Keller_Jalousie_Pos because no DPT is assigned to GA 5/0/54. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG.Paula_Rollo_fahren because no DPT is assigned to GA 5/1/0. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG.Paula_Rollo_verstellen because no DPT is assigned to GA 5/1/1. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG.Paula_Rollo_Pos because no DPT is assigned to GA 5/1/2. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG.Anton_Rollo_fahren because no DPT is assigned to GA 5/1/3. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG.Anton_Rollo_verstellen because no DPT is assigned to GA 5/1/4. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG.Anton_Rollo_Pos because no DPT is assigned to GA 5/1/5. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG.Büro_Rollo_1_fahren because no DPT is assigned to GA 5/1/6. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG.Büro_Rollo_1_verstellen because no DPT is assigned to GA 5/1/7. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG.Büro_Rollo_1_Pos because no DPT is assigned to GA 5/1/8. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG.Büro_Rollo_2_fahren because no DPT is assigned to GA 5/1/9. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG.Büro_Rollo_2_verstellen because no DPT is assigned to GA 5/1/10. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG.Büro_Rollo_2_Pos because no DPT is assigned to GA 5/1/11. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG.Büro_Rollo_3_fahren because no DPT is assigned to GA 5/1/12. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG.Büro_Rollo_3_verstellen because no DPT is assigned to GA 5/1/13. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG.Büro_Rollo_3_Pos because no DPT is assigned to GA 5/1/14. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_1_fahren because no DPT is assigned to GA 5/2/0. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_1_verstellen because no DPT is assigned to GA 5/2/1. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_1_Pos because no DPT is assigned to GA 5/2/2. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_2_fahren because no DPT is assigned to GA 5/2/3. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_2_verstellen because no DPT is assigned to GA 5/2/4. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_2_Pos because no DPT is assigned to GA 5/2/5. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_3_fahren because no DPT is assigned to GA 5/2/6. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_3_verstellen because no DPT is assigned to GA 5/2/7. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Wohnen_Rollo_3_Pos because no DPT is assigned to GA 5/2/8. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Esszimmer_Rollo_fahren because no DPT is assigned to GA 5/2/9. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Esszimmer_Rollo_verstellen because no DPT is assigned to GA 5/2/10. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Esszimmer_Rollo_Pos because no DPT is assigned to GA 5/2/11. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Küche_Rollo_1_fahren because no DPT is assigned to GA 5/2/12. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Küche_Rollo_1_verstellen because no DPT is assigned to GA 5/2/13. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Küche_Rollo_1_Pos because no DPT is assigned to GA 5/2/14. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Küche_Rollo_2_fahren because no DPT is assigned to GA 5/2/15. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Küche_Rollo_2_verstellen because no DPT is assigned to GA 5/2/16. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Küche_Rollo_2_Pos because no DPT is assigned to GA 5/2/17. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Schlafen_Rollo_fahren because no DPT is assigned to GA 5/2/18. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Schlafen_Rollo_verstellen because no DPT is assigned to GA 5/2/19. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Schlafen_Rollo_Pos because no DPT is assigned to GA 5/2/20. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Ankleide_Rollo_1_fahren because no DPT is assigned to GA 5/2/21. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Ankleide_Rollo_1_verstellen because no DPT is assigned to GA 5/2/22. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Ankleide_Rollo_1_Pos because no DPT is assigned to GA 5/2/23. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Ankleide_Rollo_2_fahren because no DPT is assigned to GA 5/2/24. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Ankleide_Rollo_2_verstellen because no DPT is assigned to GA 5/2/25. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Ankleide_Rollo_2_Pos because no DPT is assigned to GA 5/2/26. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.WC_Rollo_fahren because no DPT is assigned to GA 5/2/27. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.WC_Rollo_verstellen because no DPT is assigned to GA 5/2/28. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.WC_Rollo_Pos because no DPT is assigned to GA 5/2/29. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Spielezimmer_Rollo_fahren because no DPT is assigned to GA 5/2/30. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Spielezimmer_Rollo_verstellen because no DPT is assigned to GA 5/2/31. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Spielezimmer_Rollo_Pos because no DPT is assigned to GA 5/2/32. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Bad_Rollo_fahren because no DPT is assigned to GA 5/2/33. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Bad_Rollo_verstellen because no DPT is assigned to GA 5/2/34. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Bad_Rollo_Pos because no DPT is assigned to GA 5/2/35. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Zimmer_1_Rollo_fahren because no DPT is assigned to GA 5/2/36. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Zimmer_1_Rollo_verstellen because no DPT is assigned to GA 5/2/37. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Zimmer_1_Rollo_Pos because no DPT is assigned to GA 5/2/38. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Zimmer_2_Rollo_li_fahren because no DPT is assigned to GA 5/2/39. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Zimmer_2_Rollo_li_verstellen because no DPT is assigned to GA 5/2/40. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Zimmer_2_Rollo_li_Pos because no DPT is assigned to GA 5/2/41. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Zimmer_2_Rollo_re_fahren because no DPT is assigned to GA 5/2/42. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Zimmer_2_Rollo_re_verstellen because no DPT is assigned to GA 5/2/43. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.EG_RM.Zimmer_2_Rollo_re_Pos because no DPT is assigned to GA 5/2/44. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG_RM.Paula_Rollo_fahren because no DPT is assigned to GA 5/3/0. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG_RM.Paula_Rollo_verstellen because no DPT is assigned to GA 5/3/1. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG_RM.Paula_Rollo_Pos because no DPT is assigned to GA 5/3/2. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG_RM.Anton_Rollo_fahren because no DPT is assigned to GA 5/3/3. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG_RM.Anton_Rollo_verstellen because no DPT is assigned to GA 5/3/4. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG_RM.Anton_Rollo_Pos because no DPT is assigned to GA 5/3/5. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_1_fahren because no DPT is assigned to GA 5/3/6. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_1_verstellen because no DPT is assigned to GA 5/3/7. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_1_Pos because no DPT is assigned to GA 5/3/8. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_2_fahren because no DPT is assigned to GA 5/3/9. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_2_verstellen because no DPT is assigned to GA 5/3/10. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_2_Pos because no DPT is assigned to GA 5/3/11. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_3_fahren because no DPT is assigned to GA 5/3/12. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_3_verstellen because no DPT is assigned to GA 5/3/13. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.OG_RM.Büro_Rollo_3_Pos because no DPT is assigned to GA 5/3/14. The GA is not connected to a device communication object in the ETS.
                Rollos+Verschattung.Markise_Balkon.Markise_Fahren_Balkon has only set base DPT DPT1 in ETS. No additional informations (e.g. unit) available for this GA.
                Not adding Rollos+Verschattung.Zentralfunktionen.Wohnen_1-3_fahren because no DPT is assigned to GA 5/7/0. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.Zentralfunktionen.Wohnen_1-3_verstellen because no DPT is assigned to GA 5/7/1. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.Zentralfunktionen.Wohnen_1-3_Pos because no DPT is assigned to GA 5/7/2. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.Zentralfunktionen.Ankleide_1+2_fahren because no DPT is assigned to GA 5/7/3. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.Zentralfunktionen.Ankleide_1+2_verstellen because no DPT is assigned to GA 5/7/4. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.Zentralfunktionen.Zimmer_2_KG_Rollos_fahren because no DPT is assigned to GA 5/7/5. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.Zentralfunktionen.Zimmer_2_KG_Rollos_verstellen because no DPT is assigned to GA 5/7/6. The GA is not connected to a device communication object in the ETS.
                Not adding Rollos+Verschattung.Zentralfunktionen.Zimmer_2_KG_Rollos_Pos because no DPT is assigned to GA 5/7/7. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.EG.Wohnen_Steckd_1_schalten because no DPT is assigned to GA 6/0/0. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.EG.Wohnen_Steckd_2_schalten because no DPT is assigned to GA 6/0/1. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.EG.Esszimmer_Steckd_schalten because no DPT is assigned to GA 6/0/2. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.EG.Küche_Steckd_schalten because no DPT is assigned to GA 6/0/3. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.EG.Flur_Steckd_schalten because no DPT is assigned to GA 6/0/4. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.EG.Schlafen_Steckd_li_Bett_schalten because no DPT is assigned to GA 6/0/5. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.EG.Schlafen_Steckd_re_Bett_schalten because no DPT is assigned to GA 6/0/6. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.EG.Spielezimmer_Steckd_schalten because no DPT is assigned to GA 6/0/7. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.EG.Bad_Radio_schalten because no DPT is assigned to GA 6/0/8. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.EG.Ankleide_Steckd_schalten because no DPT is assigned to GA 6/0/9. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.OG.Büro_Steckdosen_1_schalten because no DPT is assigned to GA 6/1/0. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.OG.Büro_Steckdosen_2_schalten because no DPT is assigned to GA 6/1/1. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.OG.Büro_Steckdosen_1_RM because no DPT is assigned to GA 6/1/2. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.OG.Büro_Steckdosen_2_RM because no DPT is assigned to GA 6/1/3. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.EG_RM.Wohnen_Steckd_1_schalten because no DPT is assigned to GA 6/3/0. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.EG_RM.Wohnen_Steckd_2_schalten because no DPT is assigned to GA 6/3/1. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.EG_RM.Esszimmer_Steckd_schalten because no DPT is assigned to GA 6/3/2. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.EG_RM.Küche_Steckd_schalten because no DPT is assigned to GA 6/3/3. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.EG_RM.Flur_Steckd_schalten because no DPT is assigned to GA 6/3/4. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.EG_RM.Schlafen_Steckd_li_Bett_schalten because no DPT is assigned to GA 6/3/5. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.EG_RM.Schlafen_Steckd_re_Bett_schalten because no DPT is assigned to GA 6/3/6. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.EG_RM.Spielezimmer_Steckd_schalten because no DPT is assigned to GA 6/3/7. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.EG_RM.Bad_Radio_schalten because no DPT is assigned to GA 6/3/8. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.EG_RM.Ankleide_Steckd_schalten because no DPT is assigned to GA 6/3/9. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.Terrasse.Balkon_Steckdose_Straße because no DPT is assigned to GA 6/4/0. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.Terrasse.Neue_Gruppenadresse because no DPT is assigned to GA 6/4/1. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.Garten.Steckdose_linke_Hausseite_schalten because no DPT is assigned to GA 6/5/0. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.Garten.Steckdose_linke_Hausseite_dimmen because no DPT is assigned to GA 6/5/1. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.Garten.Steckdose_linke_Hausseite_Helligkeitswert because no DPT is assigned to GA 6/5/2. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.Garten.Steckdose_linke_Hausseite_Rückm__Schaltstatus because no DPT is assigned to GA 6/5/3. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.Garten.Steckdose_linke_Hausseite_Rück__Helligkeitswert because no DPT is assigned to GA 6/5/4. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.Garten.Steckdose_rechte_Hausseite_schalten because no DPT is assigned to GA 6/5/5. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.Garten.Steckdose_rechte_Hausseite_dimmen because no DPT is assigned to GA 6/5/6. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.Garten.Steckdose_rechte_Hausseite_Helligkeitswert because no DPT is assigned to GA 6/5/7. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.Garten.Steckdose_rechte_Hausseite_Rückm__Schaltstatus because no DPT is assigned to GA 6/5/8. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.Garten.Steckdose_rechte_Hausseite_Rückm__Helligkeitswert because no DPT is assigned to GA 6/5/9. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.Balkon_OG.Balkonsteckdose_schalten because no DPT is assigned to GA 6/6/0. The GA is not connected to a device communication object in the ETS.
                Not adding Steckdosen.Balkon_OG.Balkonsteckdose_RM because no DPT is assigned to GA 6/6/1. The GA is not connected to a device communication object in the ETS.
                Not adding Wetter_Zeit_Datum_Alarm.Daten.Türöffner_Haustür because no DPT is assigned to GA 7/0/2. The GA is not connected to a device communication object in the ETS.
                Not adding Wetter_Zeit_Datum_Alarm.Daten.RM_Türöffner_Haustür because no DPT is assigned to GA 7/0/3. The GA is not connected to a device communication object in the ETS.
                Not adding Wetter_Zeit_Datum_Alarm.Daten.Freigabe_Datum because no DPT is assigned to GA 7/0/4. The GA is not connected to a device communication object in the ETS.
                Not adding Wetter_Zeit_Datum_Alarm.Daten.Freigabe_Uhrzeit because no DPT is assigned to GA 7/0/5. The GA is not connected to a device communication object in the ETS.
                Not adding Wetter_Zeit_Datum_Alarm.Bewegungsmelder.Meldung_Haupt_Nebenstelle_Flur_EG because no DPT is assigned to GA 7/1/0. The GA is not connected to a device communication object in the ETS.
                Not adding Wetter_Zeit_Datum_Alarm.Rauchmelder.Rauchmelder_Alarm_manuell_starten because no DPT is assigned to GA 7/2/0. The GA is not connected to a device communication object in the ETS.
                Not adding Wetter_Zeit_Datum_Alarm.Rauchmelder.Rauchmelder_ALARM because no DPT is assigned to GA 7/2/1. The GA is not connected to a device communication object in the ETS.
                See log for more information
                OK
                lessthanmore
                @tomtulli Und zu allen hier genannten sind DPT und KO zugeordnet?
                Zeig mal bitte Screenshots aus der ETS zu den ersten drei GA, die im Log stehen, sowohl zum KO als auch die Eigenschaften zum DPT.
                  tomtulli
                  ich bin gerade am KNX Adapter habe die Lizenz für 1000 Datenpunkte gebraucht werden 360
                  aber der Adapter startet imm neu.
                  024-04-09 20:20:13.774 info Connecting to knx GW: 192.168.2.100:3671 with phy. Adr: 4.7.11
                  knx.0
                  2024-04-09 20:20:13.764 info knx license is OK.
                  knx.0
                  2024-04-09 20:20:09.320 info starting. Version 2.0.26 in /opt/iobroker/node_modules/iobroker.knx, node: v18.19.0, js-controller: 5.0.19
                  knx.0
                  2024-04-09 20:20:00.601 info terminating
                  knx.0
                  2024-04-09 20:20:00.162 info Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  knx.0
                  2024-04-09 20:20:00.157 info terminating
                  knx.0
                  2024-04-09 20:20:00.069 info Scheduled restart.
                  knx.0
                  2024-04-09 20:19:14.028 info Connecting to knx GW: 192.168.2.100:3671 with phy. Adr: 4.7.11
                  knx.0
                  2024-04-09 20:19:14.019 info knx license is OK.
                  knx.0
                  2024-04-09 20:19:09.316 info starting. Version 2.0.26 in /opt/iobroker/node_modules/iobroker.knx, node: v18.19.0, js-controller: 5.0.19
                  knx.0
                  2024-04-09 20:19:00.561 info terminating
                  knx.0
                  2024-04-09 20:19:00.116 info Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  knx.0
                  2024-04-09 20:19:00.109 info terminating
                  knx.0
                  2024-04-09 20:19:00.034 info Scheduled restart.
                  knx.0
                  2024-04-09 20:18:14.063 info Connecting to knx GW: 192.168.2.100:3671 with phy. Adr: 4.7.11
                  knx.0
                  2024-04-09 20:18:14.053 info knx license is OK.
                  82.8k
