  4. Bose Soundtouch steuern
    6.8k
286 Beiträge 36 Kommentatoren 100.8k Aufrufe 8 Beobachtet
  • N Offline
    N Offline
    Nanouk
    #112
    Schau mal auf Deinem Screenshot unter den Preset Ordnern.
    Da steht "key"
    Den Datenpunkt musst Du auswählen.
    Über vis nun mit einem widget den entsprechenden Preset Wert schreiben.
    Probier mal das widget:
    [{"tpl":"tplJquiRadioList","data":{"oid":"bosesoundtouch.0.key","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","values":"PRESET_1","texts":"Preset 1","signals-cond-0":"consist","signals-val-0":"","signals-icon-0":"","signals-icon-size-0":"76","signals-blink-0":true,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"not consist","signals-val-1":"radioffh","signals-icon-1":"/vis/img/radiobuttons/ffh.jpg","signals-icon-size-1":"75","signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"signals-oid-0":"","signals-oid-1":"javascript.0.RadioURL","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"629px","top":"245px","border-width":"","width":"76px","height":"76px","z-index":"4"},"widgetSet":"jqui"}]
    Der vis Button ist jetzt nur quick'n'dirty, aber funktionieren sollte er.
    Nanouk
    PS:
    Die Punkte in den Preset Ordnern helfen Dir evtl. beim optischen Gestalten in vis.
    Für die Funktion "Preset 1" abspielen sind sie aber nicht nötig.
    Das wird über den Wert in "key" gesteuert.
    • apollon77A Offline
      #113
      @SwedishChef. Schon das neue Bose-Developer Portalund das letzte API update gesten?
      API kann jetzt bei Lifestyles auch die echten EIngänge Switchen. UND es gibt eine "Audio Notification API" wo man Notofy-Sounds (custom mp3-File/Stream oder so) angeben kann und "Texte" das wird dann abgespielt und danach der normale stream fortgesetzt …
      Welcome "sayit" in besser als Sonos ;-))
      • SwedishChefS Offline
        SwedishChef
        #114
        @apollon77:
        @SwedishChef. Schon das neue Bose-Developer Portalund das letzte API update gesten? `
        Ja, hab mir das Portal und die neue Doku kurz angesehen. Leider komme ich aktuell nicht dazu, den Adapter zu erweitern. Meine ersten Versuche, ein Play-everywhere zu realisieren, scheiterten am Zusammensammeln der jeweiligen states - alles asynchron :-(
        Wie kann ich mehrere states abfragen, die Ergebnisse sammeln und - wenn alles beisammen ist - eine Aktion starten? Die einzelnen Instanzen bekomme ich mit getObjectView(), aber der Rest ist mühsam… Und wie gesagt, es fehlt aktuell ein wenig die Zeit. In den Weihnachtsferien gehts hoffentlich weiter.
          #115
          Solche "schleifen" kann man asynchron grob (pseudocode) so machen:
          Am besten ein Array definieren mit dem was man abfragen will.
          function doIt(thingsToDoArray, callback) {
          -> Wenn thingsToDoArray.length === 0 dann callback() und return
          -> mit thingsToDoArray.shift das erste Array-Element holen, rest-Array wird automatisch verkürzt
          -> Array element verarbeiten, ggf asynchron und für nächsten Schritt wieder "doIt(thingsToDoArray, callback)" aufrufen
          und ausserhalb rufst Du einmal doIt(thingsToDoArray,callBackFunctionFürNachEnde) auf
          Damit wird die "doIt" so lange aufgerufen bis dann abzuarbeitende Array leer ist und danach wird die "callBackFunctionFürNachEnde" aufgerufen.
          Die Ergebnisse kann man in einer globalen Variable ablegen oder schiebst noch ein arameter durch der dann am Ende ans das callback übergeben wird.
            SwedishChef
            #116
            Danke, das werde ich demnächst probieren. Vielleicht gibt es ja eine erste Version für play-everywhere als Weihnachtsgeschenk ;-)
            Gesendet von meinem A0001 mit Tapatalk
              #117
              Falls das oben zu abstrakt war kann ich gern mal ein echtes Code-beispiel raussuchen :-)
                SwedishChef
                #118
                Hallo Leute.
                Es gibt zwei neue Versionen auf Github:
                • 0.0.10 - erster Versuch von multi-room (zone) playEverywhere
                [https://github.com/SwedishChef1/iobroke … ball/zones](https://github.com/SwedishChef1/iobroker.bosesoundtouch/tarball/zones)
                Einfach den Status 'playEverywhere' im Master-Adapter auf TRUE setzen
                • 0.1.1 - now playing: neuer Status 'art' (URL zum aktuellen Song/Album/Radiosender-Bild, falls vorhanden)
                  https://github.com/SwedishChef1/iobroke … all/master
                Sobald playEverywhere grob funktioniert (bitte um euer Feedback, ich konnte das mit nur einer Box nicht wirklich testen), werde ich das auf 'master' mergen.
                • N Offline
                  N Offline
                  Nanouk
                  #119
                  Hallo und schönen 3 Advent euch allen.
                  Wie kann ich die playEverywhere Version installieren?
                  Ich bekomme immer 404 Fehler.
                  Wie muss der Link aussehen um es im Admin zu installieren?
                  Grüße,
                  Nanouk
                    SwedishChef
                    #120
                    Hallo Nanouk,
                    Sorry, ich hab die links einfach aus dem Browser kopiert. Sind in meinem vorigen Post korrigiert.
                      #121
                      Wann stellst DU den Adapter den mal auf npm und ins ioBroker repo? Also für "latest" ist er allemal stabil genug!! das macht dann einiges einfacher
                        SwedishChef
                        #122
                        @apollon77:
                        Wann stellst DU den Adapter den mal auf npm und ins ioBroker repo? Also für "latest" ist er allemal stabil genug!! das macht dann einiges einfacher `
                        Was ist hier zu tun? Brauche hier Unterstützung, soll ja auch das repo laut einem GitHub issue auf ioBroker.bosesoundtouch (großes B) umbenennen. Möchte nichts kaputt machen…
                          #123
                          Ok,
                          1.) Umbenennen: alles committen, lokal löschen, bei Github umbenennen, neu lokal auschecken
                          2.) npm … https://docs.npmjs.com/getting-started/ ... m-packages
                          3.) Repo: https://github.com/ioBroker/ioBroker.re ... positories
                          das github ioBroker.repositories forken auf Github, auschecken, Deinen Adapter eintragen (nimm einen der anderen als Blaupause), alphabetisch einsortieren und am besten erstmal nur ins "Latest" file. Dann Pull-Request stellen.
                          Vorher checke nochmal deine io-package.json (Authors sollte korrekt gefüllt sein) und package.json das da alles passt.
                          Und (falls nicht gemacht) Testing travis-ci.org/appveyor bei dir aktivieren
                            #124
                            Ansonsten noch eine Idee: Macht es sinn die "presets" regelmäßig neu einzulesen? Einmal am Tag oder so?
                            Ich habe gestern bei mir was geändert und ioBroker kennt immer noch die Alten infos … Klar Adapter-Restart löst es, aber vllt so ein "Einmal am Tag" (oder in h konfigurierbar) wäre vllt sinnvoll.
                            Ingo
                              der_Auge
                              #125
                              erst einmal ein Dank an den Entwickler und die Unterstützer.
                              Habe mir den Adapter auch über Github installiert.
                              Folgendes steht im LOG:
                              ! 2017-12-18 07:21:01.699 - [32minfo[39m: iobroker url "https://github.com/SwedishChef1/iobroke … all/master" --debug
                              ! 2017-12-18 07:21:02.412 - [32minfo[39m: iobroker install https://github.com/SwedishChef1/iobroke ... all/master
                              ! 2017-12-18 07:21:02.626 - [32minfo[39m: iobroker npm install https://github.com/SwedishChef1/iobroke ... all/master --production --prefix "/opt/iobroker" (System call)
                              ! 2017-12-18 07:21:36.255 - [32minfo[39m: iobroker npm WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
                              ! npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
                              ! npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
                              ! npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
                              ! npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
                              ! npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
                              ! npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15)
                              ! npm WARN addRemoteGit git://github.com/noopkat/browser-serialport.git#api-updates resetting remote /root/.npm/_git-remotes/git-github-com-noopkat-browser-serialport-git-api-updates-0f82caf3 because of error: { Error: not found: git
                              ! npm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
                              ! 2017-12-18 07:21:36.268 - [32minfo[39m: iobroker at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
                              ! npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
                              ! npm WARN addRemoteGit Error: not found: git
                              ! npm WARN addRemoteGit git://github.com/noopkat/js-stk500v1.git#avrgirl resetting remote /root/.npm/_git-remotes/git-github-com-noopkat-js-stk500v1-git-avrgirl-31bc3a47 because of error: { Error: not found: git
                              ! 2017-12-18 07:21:36.299 - [32minfo[39m: iobroker npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/browser-serialport.git /root/.npm/_git-remotes/git-github-com-noopkat-browser-serialport-git-api-updates-0f82caf3: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/browser-serialport.git /root/.npm/_git-remotes/git-github-com-noopkat-browser-serialport-git-api-updates-0f82caf3: undefined
                              ! 2017-12-18 07:21:36.349 - [32minfo[39m: iobroker npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/js-stk500v1.git /root/.npm/_git-remotes/git-github-com-noopkat-js-stk500v1-git-avrgirl-31bc3a47: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/js-stk500v1.git /root/.npm/_git-remotes/git-github-com-noopkat-js-stk500v1-git-avrgirl-31bc3a47: undefined
                              ! 2017-12-18 07:22:00.040 - [32minfo[39m: host.NUC instance system.adapter.dwd.0 started with pid 21593
                              ! 2017-12-18 07:22:01.713 - [32minfo[39m: dwd.0 starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.dwd, node: v6.12.0
                              ! 2017-12-18 07:22:02.853 - [32minfo[39m: host.NUC instance system.adapter.dwd.0 terminated with code 0 (OK)
                              ! 2017-12-18 07:22:04.552 - [32minfo[39m: iobroker > usb@1.3.1 install /opt/iobroker/node_modules/usb
                              ! > node-pre-gyp install --fallback-to-build
                              ! 2017-12-18 07:22:06.288 - [32minfo[39m: iobroker node-pre-gyp
                              ! 2017-12-18 07:22:06.289 - [32minfo[39m: iobroker
                              ! 2017-12-18 07:22:06.293 - [32minfo[39m: iobroker ERR! Tried to download(404): https://github.com/tessel/node-usb/rele ... x64.tar.gz node-pre-gyp ERR! Pre-built binaries not found for usb@1.3.1 and node@6.12.0 (node-v48 ABI, glibc) (falling back to source compile with node-gyp)
                              ! 2017-12-18 07:22:08.628 - [32minfo[39m: iobroker make: Verzeichnis „/opt/iobroker/node_modules/usb/build“ wird betreten
                              ! 2017-12-18 07:22:08.631 - [32minfo[39m: iobroker CC(target) Release/obj.target/libusb/libusb/libusb/core.o
                              ! 2017-12-18 07:22:09.380 - [32minfo[39m: iobroker CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
                              ! 2017-12-18 07:22:10.033 - [32minfo[39m: iobroker CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
                              ! 2017-12-18 07:22:10.286 - [32minfo[39m: iobroker CC(target) Release/obj.target/libusb/libusb/libusb/io.o
                              ! 2017-12-18 07:22:10.944 - [32minfo[39m: iobroker CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
                              ! 2017-12-18 07:22:11.093 - [32minfo[39m: iobroker CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
                              ! 2017-12-18 07:22:11.308 - [32minfo[39m: iobroker CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
                              ! 2017-12-18 07:22:11.439 - [32minfo[39m: iobroker CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
                              ! 2017-12-18 07:22:11.546 - [32minfo[39m: iobroker CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
                              ! 2017-12-18 07:22:12.938 - [32minfo[39m: iobroker CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
                              ! 2017-12-18 07:22:13.031 - [32minfo[39m: iobroker ../libusb/libusb/os/linux_udev.c:40:21: fatal error: libudev.h: Datei oder Verzeichnis nicht gefundencompilation terminated.
                              ! 2017-12-18 07:22:13.037 - [32minfo[39m: iobroker libusb.target.mk:133: die Regel für Ziel „Release/obj.target/libusb/libusb/libusb/os/linux_udev.o“ scheitertemake: Verzeichnis „/opt/iobroker/node_modules/usb/build“ wird verlassen
                              ! make: *** [Release/obj.target/libusb/libusb/libusb/os/linux_udev.o] Fehler 1
                              ! 2017-12-18 07:22:13.042 - [32minfo[39m: iobroker gyp
                              ! 2017-12-18 07:22:13.046 - [32minfo[39m: iobroker ERR! build error
                              ! 2017-12-18 07:22:13.052 - [32minfo[39m: iobroker gyp
                              ! 2017-12-18 07:22:13.053 - [32minfo[39m: iobroker ERR! stack
                              ! 2017-12-18 07:22:13.056 - [32minfo[39m: iobroker Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                              ! gyp ERR! stack at emitTwo (events.js:106:13)
                              ! 2017-12-18 07:22:13.057 - [32minfo[39m: iobroker gyp ERR! stack
                              ! 2017-12-18 07:22:13.058 - [32minfo[39m: iobroker at ChildProcess.emit (events.js:191:7)gyp
                              ! 2017-12-18 07:22:13.059 - [32minfo[39m: iobroker ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
                              ! 2017-12-18 07:22:13.064 - [32minfo[39m: iobroker gyp ERR! System Linux 4.4.0-101-genericgyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "–fallback-to-build" "--module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node" "--module_name=usb_bindings" "--module_path=/opt/iobroker/node_modules/usb/src/binding"
                              ! gyp ERR! cwd /opt/iobroker/node_modules/usb
                              ! 2017-12-18 07:22:13.069 - [32minfo[39m: iobroker gyp ERR! node -v v6.12.0gyp ERR! node-gyp -v v3.4.0
                              ! gyp ERR! not ok
                              ! 2017-12-18 07:22:13.085 - [32minfo[39m: iobroker node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding' (1)
                              ! node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                              ! node-pre-gyp ERR! stack at emitTwo (events.js:106:13)
                              ! node-pre-gyp ERR! stack at ChildProcess.emit (events.js:191:7)
                              ! node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:920:16)
                              ! node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
                              ! node-pre-gyp ERR! System Linux 4.4.0-101-generic
                              ! node-pre-gyp
                              ! 2017-12-18 07:22:13.092 - [32minfo[39m: iobroker ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                              ! 2017-12-18 07:22:13.096 - [32minfo[39m: iobroker node-pre-gyp ERR! cwd /opt/iobroker/node_modules/usbnode-pre-gyp ERR! node -v v6.12.0
                              ! node-pre-gyp ERR! node-pre-gyp -v v0.6.39
                              ! node-pre-gyp ERR! not ok
                              ! Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding' (1)
                              ! 2017-12-18 07:22:13.135 - [32minfo[39m: iobroker > mdns@2.3.4 install /opt/iobroker/node_modules/mdns
                              ! > node-gyp rebuild
                              ! 2017-12-18 07:22:14.595 - [32minfo[39m: iobroker make: Verzeichnis „/opt/iobroker/node_modules/mdns/build“ wird betreten
                              ! 2017-12-18 07:22:14.606 - [32minfo[39m: iobroker CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o
                              ! 2017-12-18 07:22:14.852 - [32minfo[39m: iobroker In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
                              ! compilation terminated.
                              ! 2017-12-18 07:22:14.855 - [32minfo[39m: iobroker dns_sd_bindings.target.mk:152: die Regel für Ziel „Release/obj.target/dns_sd_bindings/src/dns_sd.o“ scheitertemake: Verzeichnis „/opt/iobroker/node_modules/mdns/build“ wird verlassen
                              ! make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1
                              ! 2017-12-18 07:22:14.863 - [32minfo[39m: iobroker gyp
                              ! 2017-12-18 07:22:14.866 - [32minfo[39m: iobroker ERR! build error
                              ! 2017-12-18 07:22:14.878 - [32minfo[39m: iobroker gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack
                              ! 2017-12-18 07:22:14.885 - [32minfo[39m: iobroker at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp ERR! stack at emitTwo (events.js:106:13)
                              ! gyp ERR! stack at ChildProcess.emit (events.js:191:7)
                              ! gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
                              ! gyp ERR! System Linux 4.4.0-101-generic
                              ! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                              ! gyp ERR! cwd /opt/iobroker/node_modules/mdns
                              ! gyp ERR! node -v v6.12.0
                              ! gyp ERR! node-gyp -v v3.4.0
                              ! gyp ERR! not ok
                              ! > serialport@4.0.7 install /opt/iobroker/node_modules/serialport
                              ! > node-pre-gyp install –fallback-to-build
                              ! 2017-12-18 07:22:18.445 - [32minfo[39m: iobroker [serialport] Success: "/opt/iobroker/node_modules/serialport/build/Release/serialport.node" is installed via remote
                              ! 2017-12-18 07:22:30.111 - [32minfo[39m: iobroker iobroker.core@1.0.0 /opt/iobroker├── async@2.6.0 extraneous
                              ! ├── awty@0.1.0 extraneous
                              ! ├── chip.avr.avr109@1.1.0 extraneous
                              ! ├── colors@1.1.2 extraneous
                              ! ├─┬ iobroker.bosesoundtouch@0.1.0
                              ! │ ├── es6-promise@4.1.1
                              ! │ ├── string-format@0.5.0
                              ! │ ├─┬ ws@3.3.3
                              ! │ │ ├── async-limiter@1.0.0
                              ! │ │ └── ultron@1.1.1
                              ! │ └─┬ xml2js@0.4.19
                              ! │ ├── sax@1.2.4
                              ! │ └── xmlbuilder@9.0.4
                              ! ├── serialport@4.0.7 extraneous
                              ! └── stk500-v2@1.0.2 extraneous
                              ! 2017-12-18 07:22:30.118 - [32minfo[39m: iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                              ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: browser-serialport@git://github.com/noopkat/browser-serialport.git#api-updates (node_modules/avrgirl-arduino/node_modules/browser-serialport):
                              ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: not found: git
                              ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: stk500@git://github.com/noopkat/js-stk500v1.git#avrgirl (node_modules/avrgirl-arduino/node_modules/stk500):
                              ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.3.1 (node_modules/usb):
                              ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.3.1 install: node-pre-gyp install –fallback-to-build
                              ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                              ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.4 (node_modules/mdns):
                              ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.4 install: node-gyp rebuild
                              ! 2017-12-18 07:22:30.226 - [32minfo[39m: iobroker got /opt/iobroker/node_modules/iobroker.bosesoundtouch/admin
                              ! 2017-12-18 07:22:30.264 - [32minfo[39m: iobroker upload [2] bosesoundtouch.admin /opt/iobroker/node_modules/iobroker.bosesoundtouch/admin/words.js words.js application/javascript
                              ! 2017-12-18 07:22:30.341 - [32minfo[39m: iobroker upload [1] bosesoundtouch.admin /opt/iobroker/node_modules/iobroker.bosesoundtouch/admin/index.html index.html text/html
                              ! 2017-12-18 07:22:30.418 - [32minfo[39m: iobroker upload [0] bosesoundtouch.admin /opt/iobroker/node_modules/iobroker.bosesoundtouch/admin/bosesoundtouch.png bosesoundtouch.png image/png
                              ! 2017-12-18 07:22:30.533 - [32minfo[39m: iobroker exit 0
                              ! 2017-12-18 07:22:31.035 - [32minfo[39m: host.NUC Update repository "online" under "https://raw.githubusercontent.com/ioBro … -dist.json"[/spoiler]</anonymous>
                              Nach der Installation sind mir noch ein paar Kleinigkeiten aufgefallen.
                              Adapter-Seite:
                              • es fehle das kleine und das große Bild bei MousOver
                              • in der Beschreibung steht noch die Infos aus der Vorlage (Template)
                              Ansonsten bin ich Begeistert.
                              Nun werde ich einen weiteren Nutzer von ioBroker überzeugen können
                              Frage: Zum umschalten unter Objekte -> presents > key die Zahl 1 oder 2 oder…. eintragen?
                              Jürgen
                              Master: DN2820FYKH (4GB) Linux NUC 4.4.0-22-generic #40-Ubuntu x86_64
                              Slave: Linux RPi2-1 4.1.19-v7+ #858 v4.4.3 # 2.15.1
                              SQL-DB : Linux DS 3.10.77 #7321 x86_64 synology412+
                              Test : DS916+ VM Debian
                              Test : Tinker mit piVCCU
                                Master77
                                #126
                                Hi
                                Als Datenpunkt musst du Key auswählen und als Wert im Widget dann PRESET_1 beispielsweise eintragen.
                                Gesendet von meinem HUAWEI NXT-L29 mit Tapatalk
                                  #127
                                  Alle aktuell möglichen "Key"-Werte sind auf der Github REDME.md aufgelistet
                                    der_Auge
                                    #128
                                    @apollon77:
                                    Alle aktuell möglichen "Key"-Werte sind auf der Github REDME.md aufgelistet `
                                    Super
                                    nun habe ich es gefunden
                                    key
                                    One of the following keys to send:
                                    PLAY
                                    PAUSE
                                    STOP
                                    PREV_TRACK
                                    NEXT_TRACK
                                    THUMBS_UP
                                    THUMBS_DOWN
                                    BOOKMARK
                                    POWER
                                    MUTE
                                    VOLUME_UP
                                    VOLUME_DOWN
                                    PRESET_1
                                    PRESET_2
                                    PRESET_3
                                    PRESET_4
                                    PRESET_5
                                    PRESET_6
                                    AUX_INPUT
                                    SHUFFLE_OFF
                                    SHUFFLE_ON
                                    REPEAT_OFF
                                    REPEAT_ONE
                                    REPEAT_ALL
                                    PLAY_PAUSE
                                    ADD_FAVORITE
                                    REMOVE_FAVORITE
                                    INVALID_KEY
                                      kekel
                                      #129
                                      ich muss jetzt unbedingt ein ganz großes Lob an alle Beteiligten aussprechen.
                                      Ich hatte gestern den Gedanken, dass es doch schön wäre wenn meine Soundtouch-Geräte aufs Wort gehorchen würden … und stelle fest, Super, das gibt es ja schon.
                                      Danke!
                                      Besonders faszinierend finde ich die zukünftige Möglichkeit von PlayEverywhere (MultiRoom). Ganz hervorragend wäre es, wenn man dabei noch Gruppen bilden könnte.
                                      Frei nach dem Motto "Alle" ... also wirklich alle oder z.B "Wohnzimmer" ... also nur die Geräte im Wohnzimmer.
                                      Ich wünsche euch schöne und geruhsame Feiertage.
                                      schaun wir mal … dann sehn wir schon
                                        #130
                                        @SwedishChef: siehe Github Pull-Request: Damit tut Testing dann. Musst nur noch im package.json den Author korrigieren ;-)
                                        Und sobald Du es auch npm hast kann ich auch Discovery Adapter releasen wo das Soundtouch Erkennung drin ist
                                          der_Auge
                                          #131
                                          Super Sache
                                          mein Zwischenstand im VIS
                                          nun müsste ich die Tasten (die über dem Bild liegen) noch transparent werden. :?:
                                          Jürgen
