  4. Panasonic Wärmepumpenmanager, Script / Ideen gesucht
    5.1k
74 Beiträge 5 Kommentatoren 11.3k Aufrufe 5 Beobachtet
  • S sonny
    @ticaki
    Ich stell 2 Kaffee in den Raum hier inzwischen !
    T Nicht stören
    T Nicht stören
    ticaki
    @sonny
    Hab den schedule eingebaut, dauert bis zur vollen Minute bevor es durchläuft.
    brauche 3 Logeinträge vor dem Fehler.
    const ip = '192.168.8.165';
    const prefix = '0_userdata.0.test'; // wird erstellt oder erweitert bei jedem durchlauf
    const channelName = 'My great channel';
    const interval = '* * * * *';
    const DEBUG = true
    const axios = require('axios');
    const { HTMLToJSON } = require('html-to-json-parser');
    let values: any = {};
    async function main() {
        const result = await axios(`http://${ip}`);
        if ( result && result.data) {
            logDebug(`Get data from http://${ip}`);
            logDebug(``);
            for (const r of db) {
                const match = result.data.match(r);
                if (match && Array.isArray(match) && match.length >= 1) {
                    log(`http://${ip}/${match[0]}`)
                    const response = await axios(`http://${ip}/${match[0]}`);
                    if (response && response.data) {
                        logDebug(`Get data from http://${ip}/${match[0]}`);
                        const body = response.data.replace(/\n/gm, '').match(/<body>.*?<\/body>/gm)[0]
                        let data
                        try {
                            data = await HTMLToJSON(body, false);
                        } catch (e) {
                            log(e)
                        if (data && data.type == 'body') {
                            logDebug(`Parse data ok, found body`);
                            let d = data.content;
                            for (const c in d) {
                                const v = d[c];
                                if (v.type === 'div') {
                                    logDebug(`div found`);
                                    for (const i of v.content) {
                                        if (i.attributes && i.attributes.class == 'dp') {
                                            logDebug(`class db found`);
                                            for (const b of i.content) {
                                                if (b.type) {
                                                    logDebug(`type ${b.type} found`);
                                                    let val = b.content.join(' ').match(/ [0-9\.,]+/);
                                                    let end = '';
                                                    logDebug(val);
                                                    if (!val || isNaN(val.join(''))) val = b.content.join(' ');
                                                    else {
                                                        end = '_' + b.content.join(' ').replace(val, '');
                                                        val = parseFloat(val.join(''));
                                                    values[(b.attributes.href + end).replace(/^.*?sessionid\=[0-9A-Z]+\&id\=/, '').replace(/[^_\-/:!#$%&()+=@^{}|~\p{Ll}\p{Lu}\p{Nd}]+/gu, '_')] = val;
                        } else logDebug(`${data ? 'Parse data ok' : 'Parse data failed!'}, ${data.type == 'body' ? 'body found' : 'body not found'}`);
                    } else logDebug(`Don't get data from http://${ip}/${match[0]}`);
        } else logDebug(`Don't get data from http://${ip}`);
        for (const id in values) {
            const val = values[id];
            await extendObjectAsync(`${prefix}`,{type: 'channel', common:{name: channelName}});
            if (!existsState(`${prefix}.${id}`)) await createStateAsync(`${prefix}.${id}`, val, {name: 'no description', role: typeof val === 'string' ? 'text' : 'value', type: typeof val, read: true, write: false})
            await setStateAsync(`${prefix}.${id}`, val, true);
    function logDebug(l: string): void {
        if (DEBUG) log(l);
    const db: RegExp[] = [
        /v107000\.rsp\?sessionid=[0-9A-Z]+/,
        /v21\.rsp\?sessionid=[0-9A-Z]+/,
        /v50\.rsp\?sessionid=[0-9A-Z]+/
    schedule(interval, main);
    Spenden
    • T ticaki
      @sonny
      const DEBUG = true
              logDebug(``);
                          let data
                          try {
                          } catch (e) {
                              log(e)
                                  const v = d[c];
                                                  if (b.type) {
                                                      let end = '';
                                                      logDebug(val);
                                                      else {
          if (DEBUG) log(l);
      sonny
      schrieb am zuletzt editiert von sonny
      @ticaki
      Das kommt raus dabei ...
      Hab 4 Durchläufe durch, Session ID ändert sich brav mit (Einmal pro Minute geht sich aus, mehr wie 3 Sitzungen, wo ich nicht wusste wann er die letzte "vergisst" mag er nicht)
      Also soweit:
      script.js.Statische_Scripte.Wärmepumpe: Get data from http://192.168.8.165/v107000.rsp?sessionid=0417D206
      klappt es
      • S sonny
        @ticaki
        Also soweit:
        klappt es
        T Nicht stören
        T Nicht stören
        ticaki
        @sonny
        Ja ich weiß wo der Fehler liegt, aber muß rumprobieren wie ich ihn behebe. die Regex kommt mit den Zeilenumbrüchen nicht klar und das entfernen sebiger hat scheinbar nicht geholfen.
        const DEBUG = true
                logDebug(``);
                            let body = response.data.replace(/\n/gm, '').match(/<body>.*?<\/body>/gms)
                            if (body || Array.isArray(body) ) {
                                body = body[0];
                            if (!body) {
                                log('Regex: Body not found', 'error');
                                continue;
                            let data
                            try {
                            } catch (e) {
                                log(e)
                                    const v = d[c];
                                                    if (b.type) {
                                                        let end = '';
                                                        logDebug(val);
                                                        else {
            if (DEBUG) log(l);
        Jetzt gibts nicht mehr den großen Fehler sondern nur noch welche die zeigen das die Regex noch immer nicht funktioniert.
        Spenden
        • T ticaki
          @sonny
          const DEBUG = true
                  logDebug(``);
                                  body = body[0];
                              if (!body) {
                                  continue;
                              let data
                              try {
                              } catch (e) {
                                  log(e)
                                      const v = d[c];
                                                      if (b.type) {
                                                          let end = '';
                                                          logDebug(val);
                                                          else {
              if (DEBUG) log(l);
          sonny
          @ticaki
          Ich kann dir hier vielleicht helfen: fängst du mit Python etwas an ?
          Es gibt jemanden aus dem Haustechnikdialog , der das mit Python geschafft hat, vermutlich eh auf gleichem Weg wie du hier:
          Ich füg hier ein Codebeispiel ein- Eigentum "Ladyshave" aus dem Haustechnikforum. (Ist öffentlich , ich hoffe man hat nichts dagegen wenn ich mir den für Demonstrationszwecke ausborge)
          [code]
          # Script zum Auslesen des HPM Waermepumpenmanagers #
          # getestete Firmware H1.1.20 vom 22.01.2015 #
          # programmed by ladyshave ;-) #
          # V1.0 vom 14.03.2016 #
          import requests
          #ip-Adresse des HPM
          website="http://192.168.101.10"
          #Auslesen der Daten und Aufbereiten
          t = requests.get(website)
          url = t.url
          print (url)
          #holen der SessionID für die Sitzung
          sessionid = url[39:47]
          print (sessionid)
          #URLs mit SessionID basteln:
          url_wp= "http://192.168.101.10/v21.rsp?sessionid=" + sessionid
          url_bw= "http://192.168.101.10/v107000.rsp?sessionid=" + sessionid
          url_pu= "http://192.168.101.10/v100100.rsp?sessionid=" + sessionid
          url_hk1= "http://192.168.101.10/v30.rsp?sessionid=" + sessionid
          url_hk2= "http://192.168.101.10/v3.rsp?sessionid=" + sessionid
          #Daten der Seiten abholen
          daten_wp = requests.get(url_wp)
          daten_bw = requests.get(url_bw)
          daten_pu = requests.get(url_pu)
          daten_hk1 = requests.get(url_hk1)
          daten_hk2 = requests.get(url_hk2)
          #Test Augabe der Website als Text
          #print (daten_wp.text)
          #print (daten_bw.text)
          #print (daten_pu.text)
          #print (daten_hk1.text)
          #print (daten_hk2.text)
          #Funktion zum Auslesen der Daten aus der Seite
          def daten_lesen(text, suchstring, bezeichnung):
          index = text.find(suchstring) #Anfangsindex im String suchen
          indexend = text.find("</a>", index) #Endindex im String suchen
          #print (index)
          #print (indexend)
          if index == -1:
          return -1
          index = index + 14 #Index nach ID setzen
          i=0
          rueckgabe=""
          laenge = indexend-index #laenge des Index berechnen
          while i != laenge: #Schleife ueber laenge
          # falls Zahl im Namen wird dies mit isalpaha() ausgeblendet
          # ansonsten Zahl oder "." oder "-"schreiben
          if text[index + i-1].isalpha() == False and (text[index + i].isdigit() == True or text[index + i] == "." or text[index + i] == "-"):
          rueckgabe = rueckgabe + text[index + i]
          i = i + 1 #naechter bitte
          return (bezeichnung + ":" + rueckgabe) #Rueckgabe des Textes
          #id=126:6.6.22">Freq 0</a>
          #id=110:6.6.5">SollwertBW 2 °C
          #id=109:6.6.4">SollwertHK 2 °C</a>
          #Vorlauf id=111:6.6.6"> 29 °C</a>
          #Ruecklauf id=112:6.6.7"> 29 °C</a>
          print (daten_lesen (daten_wp.text, "id=126:6.6.22", "WP_Freq"))
          print (daten_lesen (daten_wp.text, "id=110:6.6.5", "WP_SollBW"))
          print (daten_lesen (daten_wp.text, "id=109:6.6.4", "WP_SollHK"))
          print (daten_lesen (daten_wp.text, "id=111:6.6.6", "WP_Vorl"))
          print (daten_lesen (daten_wp.text, "id=112:6.6.7", "WP_Rueckl"))
          #Pufferdaten auslesen:
          #Istwert id=61:6.5.5"> 32.0 °C</a>
          #Sollwert id=59:6.5.3">SW-Zone1 32.4 °C</a>
          print (daten_lesen (daten_pu.text, "id=61:6.5.5", "PU_Istwert"))
          print (daten_lesen (daten_pu.text, "id=59:6.5.3", "PU_Sollwert"))
          #Brauchwasser:
          #Istwertid=38:6.4.8"> 42.0 °C</a>
          #Sollwertid=37:6.4.7">SW-Spei 45.0 °C</a>
          print (daten_lesen (daten_bw.text, "id=38:6.4.8", "BW_Istwert"))
          print (daten_lesen (daten_bw.text, "id=37:6.4.7", "BW_Sollwert"))
          #HK1
          #Istwert id=13:6.2.12"> 22.7 °C</a>
          #Sollwert id=12:6.2.11">SW-Vorl 30.9 °C</a>
          #Ausstemp id=9:6.2.8"> 2.0 °C</a>
          print (daten_lesen (daten_hk1.text, "id=13:6.2.12", "HK1_Istwert"))
          print (daten_lesen (daten_hk1.text, "id=12:6.2.11", "HK1_Sollwert"))
          print (daten_lesen (daten_hk1.text, "id=9:6.2.8", "HK1_Aussen"))
          #HK2
          #Istwert id=27:6.3.12"> 30.7 °C</a>
          #Sollwert id=26:6.3.11">SW-Vorl 31.0 °C</a>
          print (daten_lesen (daten_hk2.text, "id=27:6.3.12", "HK2_Istwert"))
          print (daten_lesen (daten_hk2.text, "id=26:6.3.11", "HK2_Sollwert"))
          [/code]
          und hier ein Forumsbeitrag, sehr versprechend, mit selbigem Projekt: Da gabs ne Lösung dazu (aus der ich natürlich absolut nicht schlau werd)
          https://www.loxforum.com/forum/german/software-konfiguration-programm-und-visualisierung/35354-web-interface-einer-panasonic-lwp-mit-hpm-über-virtuelle-http-eingänge-einlesen
          Die Infos hab ich in vergangenheit zusammengekrazt, es war alles was ich finden konnte darüber
          LG und danke derweil für alles !
          • S sonny
            @ticaki
            [code]
            import requests
            #ip-Adresse des HPM
            url = t.url
            print (url)
            print (sessionid)
            #print (index)
            #print (indexend)
            if index == -1:
            return -1
            i=0
            rueckgabe=""
            #Brauchwasser:
            #HK1
            #HK2
            [/code]
            T Nicht stören
            T Nicht stören
            ticaki
            @sonny
            Erstmal kann ich python nicht leiden und die Arbeit mache ich mir für einen Adapter und dann bis du das Opfer :D
            bitte probiere noch meinen Code aus ich will das mit der RegEx noch probieren (vorheriger Beitrag) wenn nicht klappt mache ich es auf dem langweiliigen weg.
            EDIT: gehts?
            Spenden
            • T ticaki
              @sonny
              EDIT: gehts?
              sonny
              @ticaki
              Moment ich hab das Script gerade gestartet, der Ordner wurde erstellt.
              Ich gleich das eben ab und "suche" nach fehler :) Das Log wird halt überfüllt, das unmengen "gefunden" wurde .aber Infos, keine Fehler.
              Opfer immer gern, für die Entwicklung sowieso. Soll ja jedem helfen.
              T 2 Antworten Letzte Antwort
              • S sonny
                @ticaki
                T Nicht stören
                T Nicht stören
                ticaki
                @sonny
                Dann mache DEBUG=false Dann hält es die klappe :)
                Wenn du einen Adapter haben möchtest trage bitte sorgfällig englische Bezeichnungen in das Namenfeld der Objekte ein. (stift rechts klicken) Wenn du das hast exportiere den ganze Ordner und stelle ihn hier ein.
                Spenden
                • T ticaki
                  @sonny
                  sonny
                  @ticaki
                  Du ich glaub das funktioniert !!!
                  So z.b ?
                  Für mich extra brauchst keinen machen. Ich glaub auch nicht, das den jemals jemand braucht- Das Script sollte reichen.
                  Wenn du allerdings willst, mach ich das gern. (Bin eigentlich eh grad dabei, was ich weiß geb ich einen Namen)
                  Ich tests mal kommende Tage auf Herz und Nieren. Sieht MOMENTAN aber alles wunderbar aus hey !
                  • S sonny
                    @ticaki
                    T Nicht stören
                    T Nicht stören
                    ticaki
                    @sonny
                    und wenn alles geht kannst du das
                    auskommentieren:
                    //log(`http://${ip}/${match[0]}`)
                    Spenden
                    • S sonny
                      @ticaki
                      So z.b ?
                      T Nicht stören
                      T Nicht stören
                      ticaki
                      @sonny sagte in Panasonic Wärmepumpenmanager, Script / Ideen gesucht:
                      Ist dein Gerät hier dabei, oder mit denen kompatibel?
                      https://github.com/search?q=repo%3AioBroker%2FAdapterRequests+Panasonic&type=issues
                      Spenden
                      • T ticaki
                        sonny
                        @ticaki
                        Moment ich brauch ein bissl ich schau mir das an, ob diese Wärmepumpe vom Pumpenmanager Unterstützt wird.
                        Ich kann dir, vorrausgesetzt man HAT diesen Pumpenmanager und entsprechendes Adapterkabel von Panasonic , die Liste der unterstützten Geräte hier posten....
                        Für Google: Das Geräte heißt: Panasonic PAW-HPM oder PAW-HPM1 (Das sich Leute hierher verlaufen)
                        Alle anderen Requests, Seitens Wärmepumpen: sind beim Projekt: HEISHAMON besser aufgehoben.
                        Was der HPM kann, kann Heishamon nicht und umgekehrt .
                        Wir handeln hier die Generationen ab, die Heishamon NICHT kann (und vermutlich auch nie können wird- Anderes Kommunikationsprotokoll) - Aber auch älter sind, aber von den Kübeln sind noch genug im Umlauf.
                        Ich hatte Heishamon an meiner Probiert, keine Chance, daher den HPM gekauft. Es sind immer mal wieder auf Ebay Kleinanzeigen, welche zu gutem Kurs zu bekommen.
                        Ich geb hier alles mal einen Namen, mach meine Datenbank fertig- und werd kommende Tage schaun ob alles passt (Ich nehm aber an ja, würde ja jetzt schon Probleme geben denk ich).
                        Nächste Woche möcht ich mich noch wegen paar Kisten Bier oder was auch immer du gerne hättest, was ich dir schuldig bin, unterhalten :) - Ich sag in jedem Fall : Tausend dank derweil !- Ich meld mich hier sollte es Probleme geben, und in jedem Fall Dienstag/Mittwoch und sorge für ein selbstverständliches entgegenkommen meinerseits .
                        LG
                        • S sonny
                          @ticaki
                          LG
                          sonny
                          @ticaki
                          Einen Schönheitsfehler hab ich bisher gefunden (Sonst scheint das wirklich bisher ohne Probleme zu laufen !).
                          Sonderzeichen. Aussentemperatur wird mir als : "-1.1 �C"
                          angezeigt und gespeichert. Was Grad Celsius " °C" sein soll nehm ich an.
                          statt eines "ö" wird als "�" dargestellt (Störung z.b) , vermutlich Zeichensatzproblem ?
                          Hab eben gesehen, das bei deinem Screenshot von den States, das "ö" zumindest richtig dargestellt wird. Komisch, hab ich hier Blödsinn bei mir beinander ?
                          • S sonny
                            @ticaki
                            T Nicht stören
                            T Nicht stören
                            ticaki
                            @sonny im Wert wird kein - dargestellt imho müsste die Temperatur aktuell im State sein. Bitte ein Bild davon.
                            Spenden
                            • T ticaki
                              sonny
                              @ticaki
                              Naja es hat ja Die Temperatur, Die 1,5 Grad minus stimmen ja
                              Schau hier siehst es , das "ö" (Störung) und "Grad Celsius" Zeichenproblem
                              hab am Raspi mit "locale" nachgeschaut, von da sollt alles passen.
                              Das versucht er darzustellen:
                              • S sonny
                                @ticaki
                                T Nicht stören
                                T Nicht stören
                                ticaki
                                @sonny
                                Jo passt, wenn du guckst sind alles Zahlen nur das ist eine Zeichenkette. folgendes bitte Anpassen:
                                suche nach: / [0-9\.,]+/ und ersetze durch / [0-9\-.,]+/
                                State bitte auch löschen sonst gibts warnungen.
                                Spenden
                                • T ticaki
                                  @sonny
                                  sonny
                                  @ticaki
                                  Das hat Wunderbar geklappt, danke.
                                  Das mit den "ö" - ist kein Problem (Diese Daten verwend ich eh nicht)
                                  LG dweil, Wünsch einen angenehmen Wochenstart, ich meld mich .
                                  Sieht soweit aber echt alles bestens aus .
                                  • S sonny
                                    @ticaki
                                    T Nicht stören
                                    T Nicht stören
                                    ticaki
                                    @sonny
                                    Ups da war ich zuschnell
                                    / [0-9\-.,]+/ ist falsch / [0-9\.,-]+/ ist richtig der \ muss vor dem Punkt sein :)
                                    Spenden
                                    S W 2 Antworten Letzte Antwort
                                    • T ticaki
                                      @sonny
                                      sonny
                                      @ticaki
                                      Okay hab das nochmal geändert
                                      Geändert hat sich aber beim drüberschauen nichts :)
                                      Hast du Punkt mit Bindestrich verwechselt ? :)
                                      • S sonny
                                        @ticaki
                                        T Nicht stören
                                        T Nicht stören
                                        ticaki
                                        @sonny
                                        Ne ich hab das - einfach rein geknallt, weil ich am telefonieren war :D
                                        das findet halt -19.3 und -2,1 und 19.3 - der . ohne \ findet aber 1 zeichen egal was. :)
                                        Spenden
                                        • T ticaki
                                          @sonny
                                          sonny
                                          @ticaki
                                          Achherrje , natürlich hab ich vergessen mich hier zu melden ...
                                          Alles hier funktioniert einwandfrei und wie es soll !.
                                          Hab echt ne Mega Freude damit .Tausend dank nochmals.
                                          Sag mir bitte was ich dir schuldig bin - Ich werd das über deinen Spenden Link in deiner Signatur dann erledigen.
                                          LG derweil
                                          T SaettelS 2 Antworten Letzte Antwort
